[GRASS-SVN] r52631 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Sat Aug 11 18:54:40 PDT 2012
Author: huhabla
Date: 2012-08-11 18:54:40 -0700 (Sat, 11 Aug 2012)
New Revision: 52631
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/lib/python/temporal/stds_import.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/temporal_granularity.py
grass/trunk/lib/python/temporal/temporal_relationships.py
grass/trunk/lib/python/temporal/unit_tests.py
grass/trunk/lib/python/temporal/univar_statistics.py
PEP8 compliance and better doxygen formatting. New rtree tests.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -7,6 +7,8 @@
Usage:
+ at code
>>> import grass.temporal as tgis
>>> ad = AbstractDataset()
>>> ad.reset(ident="soil at PERMANENT")
@@ -19,7 +21,9 @@
raise ImplementationError("This method must be implemented in the subclasses")
ImplementationError: 'This method must be implemented in the subclasses'
-(C) 2008-2011 by the GRASS Development Team
+ at endcode
+(C) 2011-2012 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -43,7 +47,8 @@
return repr(self.msg)
class AbstractDataset(object):
- """!This is the base class for all datasets (raster, vector, raster3d, strds, stvds, str3ds)"""
+ """!This is the base class for all datasets
+ (raster, vector, raster3d, strds, stvds, str3ds)"""
def reset(self, ident):
"""!Reset the internal structure and set the identifier
@@ -107,7 +112,8 @@
return self.base.get_mapset()
def get_valid_time(self):
- """!Returns a tuple of the start, the end valid time, this can be either datetime or double values
+ """!Returns a tuple of the start, the end valid time,
+ this can be either datetime or double values
@return A tuple of (start_time, end_time)
@@ -124,7 +130,9 @@
return (start, end)
def get_absolute_time(self):
- """!Returns a tuple of the start, the end valid time and the timezone of the map
+ valid time and the timezone of the map
@return A tuple of (start_time, end_time, timezone)
@@ -135,7 +143,8 @@
return (start, end, tz)
def get_relative_time(self):
- """!Returns the relative time interval (start_time, end_time, unit) or None if not present"""
+ """!Returns the relative time interval (start_time, end_time, unit)
+ or None if not present"""
start = self.relative_time.get_start_time()
end = self.relative_time.get_end_time()
@@ -151,7 +160,8 @@
return unit
def check_relative_time_unit(self, unit):
- """!Check if unit is of type years, months, days, hours, minutes or seconds
+ """!Check if unit is of type years, months, days, hours,
+ minutes or seconds
Return True if success or False otherwise
@@ -166,11 +176,13 @@
return self.base.get_ttype()
def get_spatial_extent(self):
- """!Return a tuple of spatial extent (north, south, east, west, top, bottom) """
+ """!Return a tuple of spatial extent
+ (north, south, east, west, top, bottom) """
return self.spatial_extent.get_spatial_extent()
def select(self, dbif=None):
- """!Select temporal dataset entry from database and fill up the internal structure"""
+ """!Select temporal dataset entry from database and fill
+ up the internal structure"""
dbif, connect = init_dbif(dbif)
@@ -197,12 +209,14 @@
def insert(self, dbif=None, execute=True):
- """!Insert temporal dataset entry into database from the internal structure
+ """!Insert temporal dataset entry into
+ database from the internal structure
@param dbif: The database interface to be used
@param execute: If True the SQL statements will be executed.
- If False the prepared SQL statements are returned and must be executed by the caller.
+ If False the prepared SQL statements are returned
+ and must be executed by the caller.
@@ -234,7 +248,8 @@
@@ -266,7 +281,8 @@
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -8,8 +8,8 @@
Usage:
->>> tmr = TemporalMapRelations()
->>> amd = AbstractMapDataset()
+>>> tmr = tgis.TemporalMapRelations()
+>>> amd = tgis.AbstractMapDataset()
@@ -27,8 +27,8 @@
This object will be set up by temporal topology creation methods.
- If correctly initialize the calls next() and prev() let the user walk temporally forward
- and backward in time.
+ If correctly initialize the calls next() and prev()
+ let the user walk temporally forward and backward in time.
The following temporal relations with access methods are supported:
* equal
@@ -55,11 +55,14 @@
Usage:
- >>> import grass.temporal as tgis
+ @code
>>> tmr.print_temporal_topology_info()
+-------------------- Temporal Topology -------------------------------------+
>>> tmr.print_temporal_topology_shell_info()
+ @code
def __init__(self):
@@ -89,7 +92,8 @@
temporally located AFTER the start time of this map, but temporally
near than other maps of the same dataset.
- @param map_: This object should be of type AbstractMapDataset or derived classes
+ @param map_: This object should be of type AbstractMapDataset
+ or derived classes
self._temporal_topology["NEXT"] = map_
@@ -100,7 +104,8 @@
temporally located BEFORE the start time of this map, but temporally
self._temporal_topology["PREV"] = map_
@@ -127,7 +132,8 @@
def append_temporal_equivalent(self, map_):
"""!Append a map with equivalent temporal extent as this map
if "EQUAL" not in self._temporal_topology:
self._temporal_topology["EQUAL"] = []
@@ -145,7 +151,8 @@
def append_temporal_overlaps(self, map_):
"""!Append a map that this map temporally overlaps
if "OVERLAPS" not in self._temporal_topology:
self._temporal_topology["OVERLAPS"] = []
@@ -163,7 +170,8 @@
def append_temporal_overlapped(self, map_):
"""!Append a map that this map temporally overlapped
if "OVERLAPPED" not in self._temporal_topology:
self._temporal_topology["OVERLAPPED"] = []
@@ -181,7 +189,8 @@
def append_temporal_follows(self, map_):
"""!Append a map that this map temporally follows
if "FOLLOWS" not in self._temporal_topology:
self._temporal_topology["FOLLOWS"] = []
@@ -199,7 +208,8 @@
def append_temporal_precedes(self, map_):
"""!Append a map that this map temporally precedes
if "PRECEDES" not in self._temporal_topology:
self._temporal_topology["PRECEDES"] = []
@@ -218,7 +228,8 @@
"""!Append a map that this map is temporally located during
This includes temporal relationships starts and finishes
+ AbstractMapDataset or derived classes
if "DURING" not in self._temporal_topology:
self._temporal_topology["DURING"] = []
@@ -238,7 +249,8 @@
"""!Append a map that this map temporally contains
This includes temporal relationships started and finished
if "CONTAINS" not in self._temporal_topology:
self._temporal_topology["CONTAINS"] = []
@@ -389,7 +401,8 @@
def set_stds_register(self, name):
"""!Set the space time dataset register table name.
- This table stores all space time datasets in which this map is registered.
+ This table stores all space time datasets in
+ which this map is registered.
@param ident: The name of the register table
@@ -397,9 +410,13 @@
def check_resolution_with_current_region(self):
- """!Check if the raster or voxel resolution is finer than the current resolution
- Return "finer" in case the raster/voxel resolution is finer than the current region
- Return "coarser" in case the raster/voxel resolution is coarser than the current region
+ """!Check if the raster or voxel resolution is
+ finer than the current resolution
+ * Return "finer" in case the raster/voxel resolution is finer
+ than the current region
+ * Return "coarser" in case the raster/voxel resolution is coarser
Vector maps are alwyas finer than the current region
@@ -413,14 +430,15 @@
def write_timestamp_to_grass(self):
- """!Write the timestamp of this map into the map metadata in the grass file system based spatial
- database.
+ """!Write the timestamp of this map into the map metadata
+ in the grass file system based spatial database.
def remove_timestamp_from_grass(self):
- """!Remove the timestamp from the grass file system based spatial database
+ """!Remove the timestamp from the grass file
+ system based spatial database
@@ -434,19 +452,21 @@
def read_info(self):
- """!Read the map info from the grass file system based database and store the content
- into a dictionary
+ """!Read the map info from the grass file system based database and
+ store the content into a dictionary
def load(self):
- """!Load the content of this object from the grass file system based database"""
+ """!Load the content of this object from the grass
+ file system based database"""
def _convert_timestamp(self):
- """!Convert the valid time into a grass datetime library compatible timestamp string
+ """!Convert the valid time into a grass datetime library
+ compatible timestamp string
This methods works for reltaive and absolute time
@@ -486,9 +506,11 @@
def build_id(self, name, mapset, layer=None):
"""!Convenient method to build the unique identifier
- Existing layer and mapset definitions in the name string will be reused
+ Existing layer and mapset definitions in the name
+ string will be reused
- @param return the id of the vector map as name(:layer)@mapset while layer is optional
+ @param return the id of the vector map as name(:layer)@mapset
+ while layer is optional
# Check if the name includes any mapset
@@ -514,17 +536,14 @@
if self.get_type() == "raster":
# 1 2 3 4 5 6 7
# 0123456789012345678901234567890123456789012345678901234567890123456789012345678
- print ""
print " +-------------------- Raster Dataset ----------------------------------------+"
if self.get_type() == "raster3d":
# 1 2 3 4 5 6 7
- print ""
print " +-------------------- Raster3d Dataset --------------------------------------+"
if self.get_type() == "vector":
# 1 2 3 4 5 6 7
- print ""
print " +-------------------- Vector Dataset ----------------------------------------+"
print " | |"
self.base.print_info()
@@ -629,22 +648,37 @@
if start_time and not isinstance(start_time, datetime):
if self.get_layer() is not None:
- core.fatal(_("Start time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+ core.fatal(_("Start time must be of type datetime "
+ "for %s map <%s> with layer: %s") % \
+ (self.get_type(), self.get_map_id(),
+ self.get_layer()))
else:
- core.fatal(_("Start time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
+ core.fatal(_("Start time must be of type "
+ "datetime ""for %s map <%s>") % \
+ (self.get_type(), self.get_map_id()))
if end_time and not isinstance(end_time, datetime):
if self.get_layer():
- core.fatal(_("End time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+ core.fatal(_("End time must be of type datetime "
else:
- core.fatal(_("End time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
+ "for %s map <%s>") % (self.get_type(),
+ self.get_map_id()))
if start_time is not None and end_time is not None:
if start_time > end_time:
- core.fatal(_("End time must be greater than start time for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+ core.fatal(_("End time must be greater than "
+ "start time for %s map <%s> with layer: %s") %\
else:
- core.fatal(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_map_id()))
+ "start time for %s map <%s>") % \
else:
# Do not create an interval in case start and end time are equal
if start_time == end_time:
@@ -655,7 +689,8 @@
self.absolute_time.set_end_time(end_time)
self.absolute_time.set_timezone(timezone)
- def update_absolute_time(self, start_time, end_time=None, timezone=None, dbif=None):
+ def update_absolute_time(self, start_time, end_time=None,
+ timezone=None, dbif=None):
"""!Update the absolute time
This functions assures that the timetsamp is written to the
@@ -690,17 +725,28 @@
if not self.check_relative_time_unit(unit):
- core.error(_("Unsupported relative time unit type for %s map <%s> with layer %s: %s") % (self.get_type(), self.get_id(), self.get_layer(), unit))
+ core.error(_("Unsupported relative time unit type for %s map "
+ "<%s> with layer %s: %s") % (self.get_type(),
+ self.get_id(),
+ self.get_layer(),
+ unit))
else:
- core.error(_("Unsupported relative time unit type for %s map <%s>: %s") % (self.get_type(), self.get_id(), unit))
+ "<%s>: %s") % (self.get_type(), self.get_id(),
+ unit))
return False
if int(start_time) > int(end_time):
- core.error(_("End time must be greater than start time for %s map <%s> with layer %s") % (self.get_type(), self.get_id(), self.get_layer()))
+ core.error(_("End time must be greater than start time for"
+ " %s map <%s> with layer %s") % \
+ (self.get_type(), self.get_id(),
else:
- core.error(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
+ " %s map <%s>") % (self.get_type(),
+ self.get_id()))
return False
else:
@@ -763,9 +809,14 @@
if end is not None:
if start >= end:
- core.error(_("Map <%s> with layer %s has incorrect time interval, start time is greater than end time") % (self.get_map_id(), self.get_layer()))
+ core.error(_("Map <%s> with layer %s has incorrect "
+ "time interval, start time is greater "
+ "than end time") % (self.get_map_id(),
else:
- core.error(_("Map <%s> has incorrect time interval, start time is greater than end time") % (self.get_map_id()))
+ core.error(_("Map <%s> has incorrect time interval, "
+ "start time is greater than end time") % \
+ (self.get_map_id()))
return False
else:
core.error(_("Map <%s> has incorrect start time") %
@@ -778,14 +829,16 @@
"""!Delete a map entry from database if it exists
Remove dependent entries:
- * Remove the map entry in each space time dataset in which this map is registered
+ * Remove the map entry in each space time dataset in which this map
+ is registered
* Remove the space time dataset register table
@param update: Call for each unregister statement the update from
registered maps of the space time dataset.
This can slow down the un-registration process significantly.
- @param execute: If True the SQL DELETE and DROP table statements will be executed.
+ @param execute: If True the SQL DELETE and DROP table statements will
+ be executed.
@@ -812,7 +865,8 @@
core.verbose(_("Delete %s dataset <%s> from temporal database")
- # Delete yourself from the database, trigger functions will take care of dependencies
+ # Delete yourself from the database, trigger functions will
+ # take care of dependencies
statement += self.base.get_delete_statement()
if execute:
@@ -832,13 +886,15 @@
return statement
def unregister(self, dbif=None, update=True, execute=True):
- """! Remove the map entry in each space time dataset in which this map is registered
+ """! Remove the map entry in each space time dataset in which this map
+ is registered
- @param update: Call for each unregister statement the update from registered maps
- of the space time dataset. This can slow down the
- un-registration process significantly.
+ @param update: Call for each unregister statement the update from
+ registered maps of the space time dataset. This can
+ slow down the un-registration process significantly.
+ will be executed.
@@ -846,11 +902,14 @@
- core.verbose(_("Unregister %s map <%s> with layer %s from space time datasets") %
- (self.get_type(), self.get_map_id(), self.get_layer()))
+ core.verbose(_("Unregister %(type)s map <%(map)s> with "
+ "layer %(layer)s from space time datasets" % \
+ {'type':self.get_type(), 'map':self.get_map_id(),
+ 'layer':self.get_layer()}))
else:
- core.verbose(_("Unregister %s map <%s> from space time datasets")
- % (self.get_type(), self.get_map_id()))
+ core.verbose(_("Unregister %(type)s map <%(map)s> "
+ "from space time datasets"
+ % {'type':self.get_type(), 'map':self.get_map_id()}))
statement = ""
@@ -906,7 +965,8 @@
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
except:
- core.error(_("Unable to select space time dataset register table <%s>") % (self.get_stds_register()))
+ core.error(_("Unable to select space time dataset register table "
+ "<%s>") % (self.get_stds_register()))
if connect:
dbif.close()
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -5,7 +5,6 @@
Temporal GIS related functions to be used in temporal GIS Python library package.
@@ -37,7 +36,8 @@
self.map_counter = 0
def get_new_map_instance(self, ident=None):
- """!Return a new instance of a map dataset which is associated with the type of this class
+ """!Return a new instance of a map dataset which is associated
+ with the type of this class
@param ident: The unique identifier of the new object
@@ -52,7 +52,8 @@
def set_map_register(self, name):
"""!Set the name of the map register table
- This table stores all map names which are registered in this space time dataset.
+ This table stores all map names which are registered
+ in this space time dataset.
@param name: The name of the register table
@@ -75,17 +76,14 @@
if self.get_type() == "strds":
# 1 2 3 4 5 6 7
- print ""
print " +-------------------- Space Time Raster Dataset -----------------------------+"
if self.get_type() == "str3ds":
# 1 2 3 4 5 6 7
- print ""
print " +-------------------- Space Time Raster3d Dataset ---------------------------+"
if self.get_type() == "stvds":
# 1 2 3 4 5 6 7
- print ""
print " +-------------------- Space Time Vector Dataset -----------------------------+"
print " | |"
@@ -111,7 +109,8 @@
title=None, description=None):
"""!Set the initial values of the space time dataset
- @param temporal_type: The temporal type of this space time dataset (absolute or relative)
+ @param temporal_type: The temporal type of this space
+ time dataset (absolute or relative)
@param semantic_type: The semantic type of this dataset
@param title: The title
@param description: The description of this dataset
@@ -133,7 +132,8 @@
return self.base.get_semantic_type()
def get_initial_values(self):
- """!Return the initial values: temporal_type, semantic_type, title, description"""
+ """!Return the initial values: temporal_type,
+ semantic_type, title, description"""
temporal_type = self.get_temporal_type()
semantic_type = self.base.get_semantic_type()
@@ -143,7 +143,13 @@
return temporal_type, semantic_type, title, description
def get_granularity(self):
- """!Return the granularity"""
+ """!Return the granularity
+ Granularity can be of absolute time or relative time.
+ In case of absolute time a string containing an integer
+ value and the time unit (years, months, days, hours, minuts, seconds).
+ In case of relative time an integer value is expected.
@@ -155,6 +161,13 @@
return granularity
def set_granularity(self, granularity):
+ """!Set the granularity
@@ -168,9 +181,11 @@
core.fatal(_("Unknown temporal type \"%s\"") % (temporal_type))
def set_relative_time_unit(self, unit):
- """!Set the relative time unit which may be of type: years, months, days, hours, minutes or seconds
+ """!Set the relative time unit which may be of type:
+ years, months, days, hours, minutes or seconds
- All maps registered in a (relative time) space time dataset must have the same unit
+ All maps registered in a (relative time)
+ space time dataset must have the same unit
@@ -277,8 +292,9 @@
def count_temporal_relations(self, maps=None, dbif=None):
"""!Count the temporal relations between the registered maps.
- The map list must be ordered by start time. Temporal relations are counted
- by analysing the sparse upper right side temporal relationships matrix.
+ The map list must be ordered by start time.
+ Temporal relations are counted by analysing the sparse
+ upper right side temporal relationships matrix.
@param maps: A sorted (start_time) list of AbstractDataset objects
@@ -295,26 +311,28 @@
"""!Check the temporal topology
Correct topology means, that time intervals are not overlap or
- that intervals does not contain other intervals. Equal time intervals or
- points of time are not allowed.
+ that intervals does not contain other intervals.
+ Equal time intervals are not allowed.
- Allowed and not allowed temporal relationships for correct topology
- after -> allowed
- precedes -> allowed
- follows -> allowed
+ Allowed and not allowed temporal relationships for correct topology:
+ @verbatim
+ * after -> allowed
+ * precedes -> allowed
+ * follows -> allowed
- equivalent -> not allowed
- during -> not allowed
- contains -> not allowed
- overlaps -> not allowed
- overlapped -> not allowed
- starts -> not allowed
- finishes -> not allowed
- started -> not allowed
- finished -> not allowed
+ * equivalent -> not allowed
+ * during -> not allowed
+ * contains -> not allowed
+ * overlaps -> not allowed
+ * overlapped -> not allowed
+ * starts -> not allowed
+ * finishes -> not allowed
+ * started -> not allowed
+ * finished -> not allowed
+ @endverbatim
@return True if topology is correct
@@ -355,20 +373,26 @@
return True
def sample_by_dataset(self, stds, method=None, spatial=False, dbif=None):
- """!Sample this space time dataset with the temporal topology of a second space time dataset
+ """!Sample this space time dataset with the temporal topology
+ of a second space time dataset
- The sample dataset must have "interval" as temporal map type, so all sample maps have valid interval time.
+ The sample dataset must have "interval" as temporal map type,
+ so all sample maps have valid interval time.
- In case spatial is True, the spatial overlap between temporal related maps is performed. Only
+ In case spatial is True, the spatial overlap between
+ temporal related maps is performed. Only
temporal related and spatial overlapping maps are returned.
Return all registered maps as ordered (by start_time) object list with
"gap" map objects (id==None). Each list entry is a list of map objects
- which are potentially located in temporal relation to the actual granule of the second space time dataset.
+ which are potentially located in temporal relation to the actual
+ granule of the second space time dataset.
- Each entry in the object list is a dict. The actual sampler map and its temporal extent (the actual granule) and
+ Each entry in the object list is a dict. The actual sampler
+ map and its temporal extent (the actual granule) and
the list of samples are stored:
+ @code
list = self.sample_by_dataset(stds=sampler, method=[
"during","overlap","contain","equal"])
for entry in list:
@@ -377,58 +401,89 @@
for map in maplist:
map.select()
map.print_info()
+ @endcode
- A valid temporal topology (no overlapping or inclusion allowed) is needed to get correct results in case of gaps
- in the sample dataset.
+ A valid temporal topology (no overlapping or inclusion allowed)
+ is needed to get correct results in case of gaps in the sample dataset.
Gaps between maps are identified as unregistered maps with id==None.
- The map objects are initialized with the id and the temporal extent of the granule (temporal type, start time, end time).
- In case more map information are needed, use the select() method for each listed object.
+ The map objects are initialized with the id and the temporal
+ extent of the granule (temporal type, start time, end time).
+ In case more map information are needed, use the select()
+ method for each listed object.
@param stds: The space time dataset to be used for temporal sampling
- @param method: This option specifies what sample method should be used. In case the registered maps are of temporal point type,
- only the start time is used for sampling. In case of mixed of interval data the user can chose between:
- * start: Select maps of which the start time is located in the selection granule
- map : s
- granule: s-----------------e
+ @param method: This option specifies what sample method should be used.
+ In case the registered maps are of temporal point type,
+ only the start time is used for sampling. In case of mixed
+ of interval data the user can chose between:
+ * start: Select maps of which the start time is
+ located in the selection granule
+ @verbatim
+ map : s
+ granule: s-----------------e
- map : s--------------------e
+ map : s--------------------e
- map : s--------e
+ map : s--------e
+ @endverbatim
- * during: Select maps which are temporal during the selection granule
- map : s-----------e
+ * during: Select maps which are temporal
+ during the selection granule
+ @verbatim
+ map : s-----------e
+ @endverbatim
- * overlap: Select maps which temporal overlap the selection granule
+ * overlap: Select maps which temporal overlap
+ the selection granule
+ @verbatim
- granule: s----------e
+ granule: s----------e
+ @endverbatim
- * contain: Select maps which temporally contain the selection granule
- map : s-----------------e
- granule: s-----------e
+ * contain: Select maps which temporally contain
+ @verbatim
+ map : s-----------------e
+ granule: s-----------e
+ @endverbatim
- * equal: Select maps which temporally equal to the selection granule
+ * equal: Select maps which temporally equal
+ to the selection granule
+ @verbatim
+ @endverbatim
- * follows: Select maps which temporally follow the selection granule
+ * follows: Select maps which temporally follow
+ @verbatim
+ @endverbatim
- * precedes: Select maps which temporally precedes the selection granule
+ * precedes: Select maps which temporally precedes
+ @verbatim
+ @endverbatim
- All these methods can be combined. Method must be of type tuple including the identification strings.
- @param spatial: If set True additional the spatial overlapping is used for selection -> spatio-temporal relation.
- The returned map objects will have temporal and spatial extents
+ All these methods can be combined. Method must be of
+ type tuple including the identification strings.
+ @param spatial: If set True additional the spatial overlapping
+ is used for selection -> spatio-temporal relation.
+ The returned map objects will have temporal and
+ spatial extents
In case nothing found None is returned
@@ -466,11 +521,13 @@
use_equal = True
if self.get_temporal_type() != stds.get_temporal_type():
- core.error(_("The space time datasets must be of the same temporal type"))
+ core.error(_("The space time datasets must be of "
+ "the same temporal type"))
return None
if stds.get_map_time() != "interval":
- core.error(_("The temporal map type of the sample dataset must be interval"))
+ core.error(_("The temporal map type of the sample "
+ "dataset must be interval"))
return None
# In case points of time are available, disable the interval specific methods
@@ -542,23 +599,28 @@
def get_registered_maps_as_objects_by_granularity(self, gran=None, dbif=None):
"""!Return all registered maps as ordered (by start_time) object list with
- "gap" map objects (id==None) for temporal topological operations using the
- granularity of the space time dataset as increment. Each list entry is a list of map objects
+ "gap" map objects (id==None) for temporal topological operations using
+ the granularity of the space time dataset as increment.
+ Each list entry is a list of map objects
which are potentially located in the actual granule.
- A valid temporal topology (no overlapping or inclusion allowed) is needed to get correct results.
+ is needed to get correct results.
- The dataset must have "interval" as temporal map type, so all maps have valid interval time.
+ The dataset must have "interval" as temporal map type,
+ so all maps have valid interval time.
- The objects are initialized with the id and the temporal extent (temporal type, start time, end time).
+ The objects are initialized with the id and the temporal
+ extent (temporal type, start time, end time).
@param gran: The granularity to be used
- In case nothing found None is returned
+ @return ordered object list, in case nothing found None is returned
@@ -611,13 +673,16 @@
Gaps between maps are identified as maps with id==None
+ temporal extent (temporal type, start time, end time).
- @param where: The SQL where statement to select a subset of the registered maps without "WHERE"
+ @param where: The SQL where statement to select a
+ subset of the registered maps without "WHERE"
@@ -646,7 +711,8 @@
if self.is_time_absolute():
map.set_absolute_time(start, end)
elif self.is_time_relative():
- map.set_relative_time(start, end, self.get_relative_time_unit())
+ map.set_relative_time(start, end,
+ self.get_relative_time_unit())
obj_list.append(copy.copy(map))
if connect:
@@ -654,14 +720,20 @@
return obj_list
- def get_registered_maps_as_objects(self, where=None, order="start_time", dbif=None):
- """!Return all registered maps as ordered object list for temporal topological operations
+ def get_registered_maps_as_objects(self, where=None, order="start_time",
+ dbif=None):
+ """!Return all registered maps as ordered object list for
+ temporal topological operations
+ The objects are initialized with the id and the temporal extent
+ (temporal type, start time, end time).
- @param order: The SQL order statement to be used to order the objects in the list without "ORDER BY"
+ @param where: The SQL where statement to select a subset of
+ the registered maps without "WHERE"
+ @param order: The SQL order statement to be used to order the
+ objects in the list without "ORDER BY"
@@ -695,16 +767,20 @@
return obj_list
def get_registered_maps(self, columns=None, where=None, order=None, dbif=None):
- """!Return sqlite rows of all registered maps.
+ """!Return SQL rows of all registered maps.
- In case columns are not specified, each row includes all columns specified in the datatype specific view
+ In case columns are not specified, each row includes all columns
+ specified in the datatype specific view.
@param columns: Columns to be selected as SQL compliant string
+ of the registered maps without "WHERE"
+ @return SQL rows of all registered maps,
+ In case nothing found None is returned
@@ -721,9 +797,11 @@
None).get_type() + "_view_rel_time"
if columns is not None:
- sql = "SELECT %s FROM %s WHERE %s.id IN (SELECT id FROM %s)" % (columns, map_view, map_view, self.get_map_register())
+ sql = "SELECT %s FROM %s WHERE %s.id IN (SELECT id FROM %s)" %\
+ (columns, map_view, map_view, self.get_map_register())
else:
- sql = "SELECT * FROM %s WHERE %s.id IN (SELECT id FROM %s)" % (map_view, map_view, self.get_map_register())
+ sql = "SELECT * FROM %s WHERE %s.id IN (SELECT id FROM %s)" % \
+ (map_view, map_view, self.get_map_register())
if where is not None:
sql += " AND (%s)" % (where.split(";")[0])
@@ -748,18 +826,24 @@
def delete(self, dbif=None, execute=True):
"""!Delete a space time dataset from the temporal database
- This method removes the space time dataset from the temporal database and drops its map register table
+ This method removes the space time dataset from the temporal
+ database and drops its map register table
+ statements will be executed.
@return The SQL statements if execute == False, else an empty string
# First we need to check if maps are registered in this dataset and
# unregister them
- core.verbose(_("Delete space time %s dataset <%s> from temporal database") % (self.get_new_map_instance(ident=None).get_type(), self.get_id()))
+ core.verbose(_("Delete space time %s dataset <%s> from temporal "
+ "database") % \
+ (self.get_new_map_instance(ident=None).get_type(),
+ self.get_id()))
statement = ""
@@ -809,8 +893,8 @@
This method takes care of the registration of a map
in a space time dataset.
- In case the map is already registered this function will break with a warning
- and return False
+ In case the map is already registered this function
+ will break with a warning and return False.
@@ -818,11 +902,19 @@
if map.is_in_db(dbif) == False:
dbif.close()
- core.fatal(_("Only maps with absolute or relative valid time can be registered"))
+ core.fatal(_("Only maps with absolute or relative valid time can "
+ "be registered"))
if map.get_layer():
- core.verbose(_("Register %s map <%s> with layer %s in space time %s dataset <%s>") % (map.get_type(), map.get_map_id(), map.get_layer(), map.get_type(), self.get_id()))
+ core.verbose(_("Register %s map <%s> with layer %s in space "
+ "time %s dataset <%s>") % (map.get_type(),
+ map.get_map_id(),
+ map.get_layer(),
+ map.get_type(),
+ self.get_id()))
else:
- core.verbose(_("Register %s map <%s> in space time %s dataset <%s>") % (map.get_type(), map.get_map_id(), map.get_type(), self.get_id()))
+ core.verbose(_("Register %s map <%s> in space time %s "
+ "dataset <%s>") % (map.get_type(), map.get_map_id(),
+ map.get_type(), self.get_id()))
# First select all data from the database
map.select(dbif)
@@ -855,27 +947,39 @@
# Check temporal types
if stds_ttype != map_ttype:
if map.get_layer():
- core.fatal(_("Temporal type of space time dataset <%s> and map <%s> with layer %s are different") % (self.get_id(), map.get_map_id(), map.get_layer()))
+ core.fatal(_("Temporal type of space time dataset <%s> and "
+ "map <%s> with layer %s are different") % \
+ (self.get_id(), map.get_map_id(), map.get_layer()))
else:
- core.fatal(_("Temporal type of space time dataset <%s> and map <%s> are different") % (self.get_id(), map.get_map_id()))
+ "map <%s> are different") % \
+ (self.get_id(), map.get_map_id()))
- # In case no map has been registered yet, set the relative time unit from the first map
- if (self.metadata.get_number_of_maps() is None or self.metadata.get_number_of_maps() == 0) and \
+ # In case no map has been registered yet, set the
+ # relative time unit from the first map
+ if (self.metadata.get_number_of_maps() is None or \
+ self.metadata.get_number_of_maps() == 0) and \
self.map_counter == 0 and self.is_time_relative():
self.set_relative_time_unit(map_rel_time_unit)
statement += self.relative_time.get_update_all_statement_mogrified(
dbif)
- core.verbose(_("Set temporal unit for space time %s dataset <%s> to %s") % (map.get_type(), self.get_id(), map_rel_time_unit))
+ core.verbose(_("Set temporal unit for space time %s dataset "
+ "<%s> to %s") % (map.get_type(), self.get_id(),
+ map_rel_time_unit))
stds_rel_time_unit = self.get_relative_time_unit()
# Check the relative time unit
if self.is_time_relative() and (stds_rel_time_unit != map_rel_time_unit):
if map.get_layer():
- core.fatal(_("Relative time units of space time dataset <%s> and map <%s> with layer %s are different") % (self.get_id(), map.get_map_id(), map.get_layer()))
+ core.fatal(_("Relative time units of space time dataset "
+ "<%s> and map <%s> with layer %s are different") %\
else:
- core.fatal(_("Relative time units of space time dataset <%s> and map <%s> are different") % (self.get_id(), map.get_map_id()))
+ "<%s> and map <%s> are different") % \
#print "STDS register table", stds_register_table
@@ -904,7 +1008,9 @@
dbif.close()
if map.get_layer() is not None:
- core.warning(_("Map <%s> with layer %s is already registered.") % (map.get_map_id(), map.get_layer()))
+ core.warning(_("Map <%s> with layer %s is already "
+ "registered.") % (map.get_map_id(),
+ map.get_layer()))
else:
core.warning(_("Map <%s> is already registered.")
% (map.get_map_id()))
@@ -922,7 +1028,9 @@
self.get_type() + "_register"
# Read the SQL template
- sql = open(os.path.join(sql_path, "map_stds_register_table_template.sql"), 'r').read()
+ sql = open(os.path.join(sql_path,
+ "map_stds_register_table_template.sql"),
+ 'r').read()
# Create the raster, raster3d and vector tables
sql = sql.replace("GRASS_MAP", map.get_type())
sql = sql.replace("MAP_NAME", map_name + "_" + map_mapset)
@@ -937,11 +1045,14 @@
statement += map.metadata.get_update_statement_mogrified(dbif)
if map.get_layer():
- core.verbose(_("Created register table <%s> for %s map <%s> with layer %s") %
- (map_register_table, map.get_type(), map.get_map_id(), map.get_layer()))
+ core.verbose(_("Created register table <%s> for "
+ "%s map <%s> with layer %s") %
+ (map_register_table, map.get_type(),
+ map.get_map_id(), map.get_layer()))
else:
core.verbose(_("Created register table <%s> for %s map <%s>") %
- (map_register_table, map.get_type(), map.get_map_id()))
+ map.get_map_id()))
# We need to create the table and register it
if stds_register_table is None:
@@ -949,7 +1060,9 @@
stds_register_table = stds_name + "_" + \
stds_mapset + "_" + map.get_type() + "_register"
- sql = open(os.path.join(sql_path, "stds_map_register_table_template.sql"), 'r').read()
+ "stds_map_register_table_template.sql"),
+ 'r').read()
sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset)
@@ -961,7 +1074,8 @@
self.set_map_register(stds_register_table)
statement += self.metadata.get_update_statement_mogrified(dbif)
- core.verbose(_("Created register table <%s> for space time %s dataset <%s>") %
+ core.verbose(_("Created register table <%s> for space "
(stds_register_table, map.get_type(), self.get_id()))
# We need to execute the statement at this time
@@ -1021,10 +1135,13 @@
@param map: The map object to unregister
+ returned and must be executed by the caller.
- @return The SQL statements if execute == False, else an empty string, None in case of a failure
+ @return The SQL statements if execute == False, else an empty
+ string, None in case of a failure
statement = ""
@@ -1060,9 +1177,14 @@
# Break if the map is not registered
if row is None:
- core.warning(_("Map <%s> with layer %s is not registered in space time dataset <%s>") % (map.get_map_id(), map.get_layer(), self.base.get_id()))
+ core.warning(_("Map <%s> with layer %s is not registered "
+ "in space time dataset <%s>") % \
+ (map.get_map_id(), map.get_layer(),
+ self.base.get_id()))
else:
- core.warning(_("Map <%s> is not registered in space time dataset <%s>") % (map.get_map_id(), self.base.get_id()))
+ core.warning(_("Map <%s> is not registered in space "
+ "time dataset <%s>") % (map.get_map_id(),
if connect == True:
dbif.close()
return ""
@@ -1117,7 +1239,8 @@
- core.verbose(_("Update metadata, spatial and temporal extent from all registered maps of <%s>") % (self.get_id()))
+ core.verbose(_("Update metadata, spatial and temporal extent from "
+ "all registered maps of <%s>") % (self.get_id()))
# Nothing to do if the register is not present
if not self.get_map_register():
@@ -1139,7 +1262,9 @@
# Update the spatial and temporal extent from registered maps
- sql = open(os.path.join(sql_path, "update_stds_spatial_temporal_extent_template.sql"), 'r').read()
+ "update_stds_spatial_temporal_extent_template.sql"),
+ 'r').read()
sql = sql.replace(
"GRASS_MAP", self.get_new_map_instance(None).get_type())
@@ -1171,20 +1296,23 @@
else:
start_time, end_time, unit = self.get_relative_time()
- # In case no end time is set, use the maximum start time of all registered maps as end time
+ # In case no end time is set, use the maximum start time of
+ # all registered maps as end time
if end_time is None:
use_start_time = True
else:
# Check if the end time is smaller than the maximum start time
- sql = """SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+ sql = """SELECT max(start_time) FROM GRASS_MAP_absolute_time
+ WHERE GRASS_MAP_absolute_time.id IN
(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register);"""
sql = sql.replace("GRASS_MAP", self.get_new_map_instance(
None).get_type())
else:
- sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+ sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time
+ WHERE GRASS_MAP_relative_time.id IN
None).get_type())
@@ -1219,7 +1347,8 @@
if use_start_time:
sql = """UPDATE STDS_absolute_time SET end_time =
- (SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+ (SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE
+ GRASS_MAP_absolute_time.id IN
) WHERE id = 'SPACETIME_ID';"""
@@ -1230,7 +1359,8 @@
sql = sql.replace("STDS", self.get_type())
sql = """UPDATE STDS_relative_time SET end_time =
- (SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+ (SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE
+ GRASS_MAP_relative_time.id IN
@@ -1246,11 +1376,14 @@
maps = self.get_registered_maps_as_objects(dbif=dbif)
tlist = self.count_temporal_types(maps)
- if tlist["interval"] > 0 and tlist["point"] == 0 and tlist["invalid"] == 0:
+ if tlist["interval"] > 0 and tlist["point"] == 0 and \
+ tlist["invalid"] == 0:
map_time = "interval"
- elif tlist["interval"] == 0 and tlist["point"] > 0 and tlist["invalid"] == 0:
+ elif tlist["interval"] == 0 and tlist["point"] > 0 and \
map_time = "point"
- elif tlist["interval"] > 0 and tlist["point"] > 0 and tlist["invalid"] == 0:
+ elif tlist["interval"] > 0 and tlist["point"] > 0 and \
map_time = "mixed"
else:
map_time = "invalid"
@@ -1302,6 +1435,7 @@
@param start: The start time
@param end: The end time
@param use_start: Select maps of which the start time is located in the selection granule
+ @verbatim
map : s
@@ -1310,36 +1444,51 @@
map : s--------e
+ @endverbatim
@param use_during: during: Select maps which are temporal during the selection granule
+ @verbatim
map : s-----------e
+ @endverbatim
@param use_overlap: Select maps which temporal overlap the selection granule
+ @verbatim
map : s-----------e
map : s-----------e
+ @endverbatim
@param use_contain: Select maps which temporally contain the selection granule
+ @verbatim
+ @endverbatim
@param use_equal: Select maps which temporally equal to the selection granule
+ @verbatim
map : s-----------e
+ @endverbatim
@param use_follows: Select maps which temporally follow the selection granule
+ @verbatim
map : s-----------e
+ @endverbatim
@param use_precedes: Select maps which temporally precedes the selection granule
+ @verbatim
map : s-----------e
+ @endverbatim
Usage:
+ @code
>>> # Relative time
>>> start = 1
>>> end = 2
@@ -1405,6 +1554,8 @@
... use_start=True, use_during=True, use_overlap=True, use_contain=True,
... use_equal=True, use_follows=True, use_precedes=True)
"((start_time >= '2001-01-01 12:30:00' and start_time < '2001-03-31 14:30:00') OR ((start_time > '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time >= '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time > '2001-01-01 12:30:00' and end_time <= '2001-03-31 14:30:00')) OR ((start_time < '2001-01-01 12:30:00' and end_time > '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time < '2001-03-31 14:30:00' and start_time > '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00')) OR ((start_time < '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00') OR (start_time <= '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00') OR (start_time < '2001-01-01 12:30:00' and end_time >= '2001-03-31 14:30:00')) OR (start_time = '2001-01-01 12:30:00' and end_time = '2001-03-31 14:30:00') OR (start_time = '2001-03-31 14:30:00') OR (end_time = '2001-01-01 12:30:00'))"
+ @endcode
where = "("
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/aggregation.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -9,7 +9,8 @@
@code
-tgis.aggregate_raster_maps(dataset, mapset, inputs, base, start, end, count, method, register_null, dbif)
+tgis.aggregate_raster_maps(dataset, mapset, inputs, base, start, end,
+ count, method, register_null, dbif)
@endcode
@@ -27,6 +28,7 @@
def collect_map_names(sp, dbif, start, end, sampling):
"""!Gather all maps from dataset using a specific sample method
@@ -36,7 +38,7 @@
@param end: The end time of the sample interval, may be relative or absolute
@param sampling: The sampling methods to use
use_start = False
use_during = False
use_overlap = False
@@ -75,8 +77,15 @@
use_follows = False
use_precedes = False
- where = create_temporal_relation_sql_where_statement(start, end, use_start, use_during, use_overlap, use_contain, use_equal, use_follows, use_precedes)
+ where = create_temporal_relation_sql_where_statement(start, end,
+ use_start,
+ use_during,
+ use_overlap,
+ use_contain,
+ use_equal,
+ use_follows,
+ use_precedes)
rows = sp.get_registered_maps("id", where, "start_time", dbif)
if not rows:
@@ -86,13 +95,15 @@
for row in rows:
names.append(row["id"])
- return names
+ return names
-def aggregate_raster_maps(inputs, base, start, end, count, method, register_null, dbif):
+def aggregate_raster_maps(inputs, base, start, end, count, method,
+ register_null, dbif):
"""!Aggregate a list of raster input maps with r.series
@param inputs: The names of the raster maps to be aggregated
@param base: The basename of the new created raster maps
@param start: The start time of the sample interval, may be relative or absolute
@@ -103,13 +114,11 @@
@param dbif: The temporal database interface to use
- core.verbose(_("Aggregate %s raster maps") %(len(inputs)))
+ core.verbose(_("Aggregate %s raster maps") % (len(inputs)))
output = "%s_%i" % (base, count)
mapset = libgis.G_mapset()
map_id = output + "@" + mapset
new_map = raster_dataset(map_id)
# Check if new map is in the temporal database
@@ -122,7 +131,8 @@
core.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
return
- core.verbose(_("Compute aggregation of maps between %s - %s" % (str(start), str(end))))
+ core.verbose(_("Compute aggregation of maps between %s - %s" % (
+ str(start), str(end))))
# Create the r.series input file
filename = core.tempfile(True)
@@ -134,20 +144,21 @@
file.close()
# Run r.series
- ret = core.run_command("r.series", flags="z", file=filename, output=output, overwrite=core.overwrite(), method=method)
+ ret = core.run_command("r.series", flags="z", file=filename,
+ output=output, overwrite=core.overwrite(),
+ method=method)
if ret != 0:
dbif.close()
core.fatal(_("Error while r.series computation"))
# Read the raster map data
new_map.load()
# In case of a null map continue, do not register null maps
- if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+ if new_map.metadata.get_min() is None and new_map.metadata.get_max() is None:
if not register_null:
core.run_command("g.remove", rast=output)
return None
return new_map
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/base.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -5,12 +5,14 @@
Temporal GIS base classes to be used in other
Python temporal gis packages.
-This packages includes all base classes to store basic information like id, name,
-mapset creation and modification time as well as sql serialization and de-serialization
-and the sql database interface.
+This packages includes all base classes to store basic information
+like id, name, mapset creation and modification time as well as sql
+serialization and de-serialization and the sql database interface.
Usage:
+ at code
>>> rbase = tgis.RasterBase(ident="soil at PERMANENT")
>>> vbase = tgis.VectorBase(ident="soil:1 at PERMANENT")
@@ -19,7 +21,9 @@
>>> stvdsbase = tgis.STVDSBase(ident="soil at PERMANENT")
>>> str3dsbase = tgis.STR3DSBase(ident="soil at PERMANENT")
+ at endcode
for details.
@@ -38,12 +42,15 @@
self.D = {}
def serialize(self, type, table, where=None):
- """!Convert the internal dictionary into a string of semicolon separated SQL statements
- The keys are the column names and the values are the row entries
+ """!Convert the internal dictionary into a string of semicolon
+ separated SQL statements The keys are the column names and
+ the values are the row entries
- >>> from datetime import datetime, date, time, timedelta
- >>> t = tgis.DictSQLSerializer()
+ Usage:
+ \code
+ >>> t = DictSQLSerializer()
>>> t.D["id"] = "soil at PERMANENT"
>>> t.D["name"] = "soil"
>>> t.D["mapset"] = "PERMANENT"
@@ -63,6 +70,8 @@
@table The name of the table to select, insert or update
@where The optional where statement
@return a tuple containing the SQL string and the arguments
+ \endcode
sql = ""
@@ -166,7 +175,8 @@
return sql, tuple(args)
def deserialize(self, row):
- """!Convert the content of the dbmi dictionary like row into the internal dictionary
+ """!Convert the content of the dbmi dictionary like row into the
+ internal dictionary
@param row: The dictionary like row to store in the internal dict
@@ -188,10 +198,10 @@
class SQLDatabaseInterface(DictSQLSerializer):
"""!This class represents the SQL database interface
- Functions to insert, select and update the internal structure of this class
- in the temporal database are implemented.
- This is the base class for raster, raster3d, vector and space time datasets
- data management classes:
+ Functions to insert, select and update the internal
+ structure of this class in the temporal database are implemented.
+ This is the base class for raster, raster3d, vector and
+ space time datasets data management classes:
* Identification information (base)
* Spatial extent
* Temporal extent
@@ -199,9 +209,9 @@
Usage:
- >>> t = tgis.SQLDatabaseInterface("raster", "soil at PERMANENT")
+ \code
+ >>> t = SQLDatabaseInterface("raster", "soil at PERMANENT")
>>> t.D["creator"] = "soeren"
@@ -226,12 +236,15 @@
("UPDATE raster SET creation_time = ? ,mapset = ? ,name = ? ,creator = ? WHERE id = 'soil at PERMANENT';\\n", (datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil', 'soeren'))
>>> t.get_update_all_statement_mogrified()
"UPDATE raster SET creation_time = '2001-01-01 00:00:00' ,mapset = 'PERMANENT' ,name = 'soil' ,creator = 'soeren' WHERE id = 'soil at PERMANENT';\\n"
+ \endcode
def __init__(self, table=None, ident=None):
"""!Constructor of this class
@param table: The name of the table
- @param ident: The identifier (primary key) of this object in the database table
+ @param ident: The identifier (primary key) of this
+ object in the database table
DictSQLSerializer.__init__(self)
@@ -239,17 +252,20 @@
self.ident = ident
def get_table_name(self):
- """!Return the name of the table in which the internal data are inserted, updated or selected"""
+ """!Return the name of the table in which the internal
+ data are inserted, updated or selected"""
return self.table
def get_delete_statement(self):
"""!Return the delete string"""
- return "DELETE FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
+ return "DELETE FROM " + self.get_table_name() + \
def delete(self, dbif=None):
"""!Delete the entry of this object from the temporal database
- @param dbif: The database interface to be used, if None a temporary connection will be established
+ @param dbif: The database interface to be used,
+ if None a temporary connection will be established
sql = self.get_delete_statement()
#print sql
@@ -264,12 +280,14 @@
def get_is_in_db_statement(self):
"""Return the selection string"""
- return "SELECT id FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
+ return "SELECT id FROM " + self.get_table_name() + \
def is_in_db(self, dbif=None):
"""!Check if this object is present in the temporal database
sql = self.get_is_in_db_statement()
@@ -292,13 +310,16 @@
return True
def get_select_statement(self):
- """!Return the sql statement and the argument list in database specific style"""
- return self.serialize("SELECT", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+ """!Return the sql statement and the argument list in
+ database specific style"""
+ return self.serialize("SELECT", self.get_table_name(),
+ "WHERE id = \'" + str(self.ident) + "\'")
def get_select_statement_mogrified(self, dbif=None):
"""!Return the select statement as mogrified string
if not dbif:
dbif = SQLDatabaseInterfaceConnection()
@@ -309,7 +330,8 @@
"""!Select the content from the temporal database and store it
in the internal dictionary structure
sql, args = self.get_select_statement()
#print sql
@@ -344,13 +366,15 @@
return True
def get_insert_statement(self):
+ list in database specific style"""
return self.serialize("INSERT", self.get_table_name())
def get_insert_statement_mogrified(self, dbif=None):
"""!Return the insert statement as mogrified string
if not dbif:
@@ -361,7 +385,8 @@
"""!Serialize the content of this object and store it in the temporal
database using the internal identifier
sql, args = self.get_insert_statement()
#print sql
@@ -376,13 +401,16 @@
dbif.close()
def get_update_statement(self):
- return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+ in database specific style"""
+ return self.serialize("UPDATE", self.get_table_name(),
def get_update_statement_mogrified(self, dbif=None):
"""!Return the update statement as mogrified string
if not dbif:
@@ -395,7 +423,8 @@
Only object entries which are exists (not None) are updated
if self.ident is None:
raise IOError("Missing identifer")
@@ -413,13 +442,16 @@
dbif.close()
def get_update_all_statement(self):
- return self.serialize("UPDATE ALL", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+ return self.serialize("UPDATE ALL", self.get_table_name(),
def get_update_all_statement_mogrified(self, dbif=None):
"""!Return the update all statement as mogrified string
if not dbif:
@@ -427,10 +459,11 @@
return dbif.mogrify_sql_statement(self.get_update_all_statement())
def update_all(self, dbif=None):
- """!Serialize the content of this object, including None objects, and update it in the temporal
- database using the internal identifier
+ """!Serialize the content of this object, including None objects,
+ and update it in the temporal database using the internal identifier
@@ -455,10 +488,10 @@
basic identification information
Usage:
+ \code
- >>> t = tgis.DatasetBase("raster", "soil at PERMANENT", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
+ >>> t = DatasetBase("raster", "soil at PERMANENT", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
>>> t.id
'soil at PERMANENT'
>>> t.name
@@ -486,15 +519,19 @@
creator=soeren
creation_time=2001-01-01 00:00:00
temporal_type=absolute
+ \endcode
def __init__(self, table=None, ident=None, name=None, mapset=None,
creator=None, ctime=None,ttype=None):
"""!Constructor
- @param table: The name of the temporal database table that should be used to store the values
- @param ident: The unique identifier must be a combination of the dataset name,
- layer name and the mapset name at mapset or name:1 at mapset
+ @param table: The name of the temporal database table
+ that should be used to store the values
+ @param ident: The unique identifier must be a combination of
+ the dataset name, layer name and the mapset
+ name at mapset or name:1 at mapset
used as as primary key in the temporal database
@param name: The name of the map or dataset
@param mapset: The name of the mapset
@@ -525,8 +562,9 @@
def set_id(self, ident):
"""!Convenient method to set the unique identifier (primary key)
+ of the dataset name, layer name and the mapset
self.ident = ident
self.D["id"] = ident
@@ -575,7 +613,8 @@
self.D["creator"] = creator
def set_ctime(self, ctime=None):
- """!Set the creation time of the dataset, if nothing set the current time is used
+ """!Set the creation time of the dataset,
+ if nothing set the current time is used
@param ctime: The current time of type datetime
@@ -617,13 +656,15 @@
return None
def get_map_id(self):
- """!Convenient method to get the unique map identifier without layer information
+ """!Convenient method to get the unique map identifier
+ without layer information
@param return the name of the vector map as name at mapset
if self.id.find(":") >= 0:
# Remove the layer identifier from the id
- return iself.d.split("@")[0].split(":")[0] + "@" + self.id.split("@")[1]
+ return iself.d.split("@")[0].split(":")[0] + "@" + \
else:
return self.id
@@ -782,9 +823,9 @@
Usage:
- >>> t = tgis.STDSBase("stds", "soil at PERMANENT", semantic_type="average", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
+ \code
+ >>> t = STDSBase("stds", "soil at PERMANENT", semantic_type="average", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
>>> t.semantic_type
'average'
>>> t.print_info()
@@ -804,6 +845,8 @@
semantic_type=average
+ \endcode
semantic_type=None, creator=None, ctime=None,
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/core.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -9,6 +9,8 @@
Usage:
+\code
>>> # Create the temporal database
>>> tgis.create_temporal_database()
@@ -18,10 +20,13 @@
>>> # Execute a SQL statement
>>> dbif.execute_transaction("SELECT datetime(0, 'unixepoch', 'localtime');")
>>> # Mogrify an SQL statement
->>> dbif.mogrify_sql_statement(["SELECT name from raster_base where name = ?", ("precipitation",)])
+>>> dbif.mogrify_sql_statement(["SELECT name from raster_base where name = ?",
+... ("precipitation",)])
"SELECT name from raster_base where name = 'precipitation'"
>>> dbif.close()
+\endcode
@@ -47,7 +52,8 @@
# Needed for dictionary like cursors
import psycopg2.extras
else:
- core.fatal(_("Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"))
+ core.fatal(_("Unable to initialize the temporal DBMI interface. Use "
+ "t.connect to specify the driver and the database string"))
else:
# Use the default sqlite variable
core.run_command("t.connect", flags="d")
@@ -67,13 +73,17 @@
"$LOCATION_NAME", grassenv["LOCATION_NAME"])
return string
else:
- core.fatal(_("Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"))
+ core.fatal(_("Unable to initialize the temporal GIS DBMI "
+ "interface. Use t.connect to specify the driver "
+ "and the database string"))
elif dbmi.__name__ == "psycopg2":
if "database" in kv:
string = kv["database"]
return string
else:
return "dbname=grass_test user=soeren password=abcdefgh"
@@ -88,10 +98,12 @@
def create_temporal_database():
- """!This function creates the grass location database structure for raster, vector and raster3d maps
- as well as for the space-time datasets strds, str3ds and stvds
+ """!This function creates the grass location database structure for raster,
+ vector and raster3d maps as well as for the space-time datasets strds,
+ str3ds and stvds
- This functions must be called before any spatio-temporal processing can be started
+ This functions must be called before any spatio-temporal processing
+ can be started
database = get_temporal_dbmi_init_string()
@@ -108,7 +120,8 @@
connection = dbmi.connect(database)
cursor = connection.cursor()
# Check for raster_base table
- cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables WHERE table_name=%s)", ('raster_base',))
+ cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
+ "WHERE table_name=%s)", ('raster_base',))
db_exists = cursor.fetchone()[0]
connection.commit()
cursor.close()
@@ -214,7 +227,8 @@
init = get_temporal_dbmi_init_string()
#print "Connect to", self.database
if dbmi.__name__ == "sqlite3":
- self.connection = dbmi.connect(init, detect_types=dbmi.PARSE_DECLTYPES | dbmi.PARSE_COLNAMES)
+ self.connection = dbmi.connect(init,
+ detect_types=dbmi.PARSE_DECLTYPES | dbmi.PARSE_COLNAMES)
self.connection.row_factory = dbmi.Row
self.connection.isolation_level = None
self.cursor = self.connection.cursor()
@@ -277,8 +291,8 @@
break
if args[count] is None:
- statement = "%sNULL%s" % (statement[0:
- pos], statement[pos + 1:])
+ statement = "%sNULL%s" % (statement[0:pos],
+ statement[pos + 1:])
elif isinstance(args[count], (int, long)):
statement = "%s%d%s" % (statement[0:pos], args[count],
@@ -286,8 +300,11 @@
statement = "%s%f%s" % (statement[0:pos], args[count],
else:
- # Default is a string, this works for datetime objects too
- statement = "%s\'%s\'%s" % (statement[0:pos], str(args[count]), statement[pos + 1:])
+ # Default is a string, this works for datetime
+ # objects too
+ statement = "%s\'%s\'%s" % (statement[0:pos],
+ str(args[count]),
count += 1
return statement
@@ -301,7 +318,7 @@
@param statement The executable SQL statement or SQL script
connect = False
- if self.connected == False:
+ if not self.connected:
self.connect()
connect = True
@@ -309,6 +326,7 @@
sql_script += "BEGIN TRANSACTION;\n"
sql_script += statement
sql_script += "END TRANSACTION;"
try:
self.cursor.executescript(statement)
@@ -316,9 +334,10 @@
self.cursor.execute(statement)
self.connection.commit()
except:
- if connect == True:
+ if connect:
self.close()
- core.error(_("Unable to execute transaction:\n %s") % (statement))
+ core.error(_("Unable to execute transaction:\n %(sql)s" % \
+ {"sql":statement}))
raise
if connect:
@@ -327,13 +346,17 @@
def init_dbif(dbif):
- """!This method checks if the database interface connection exists, if not a new one
- will be created, connected and True will be returned
+ """!This method checks if the database interface connection exists,
+ if not a new one will be created, connected and True will be returned
Usage code sample:
+ \code
dbif, connect = tgis.init_dbif(dbif)
if connect:
dbif.close()
+ \code
if dbif is None:
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -2,17 +2,8 @@
@brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS datetime math functions to be used in Python scripts.
+Temporal GIS datetime math functions to be used in library functions and modules.
-Usage:
- at code
-import grass.temporal as tgis
-tgis.increment_datetime_by_string(mydate, "3 month, 2 hours")
- at endcode
(C) 2008-2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,10 +17,11 @@
from dateutil import parser
DAY_IN_SECONDS = 86400
-SECOND_AS_DAY = 1.1574074074074073e-05
+SECOND_AS_DAY = 1.1574074074074073e-05
def relative_time_to_time_delta(value):
"""!Convert the double value representing days
into a timedelta object.
@@ -43,6 +35,7 @@
def time_delta_to_relative_time(delta):
"""!Convert the time delta into a
double value, representing days.
@@ -52,17 +45,69 @@
-def increment_datetime_by_string(mydate, increment, mult = 1):
- """!Return a new datetime object incremented with the provided
+def increment_datetime_by_string(mydate, increment, mult=1):
+ """!Return a new datetime object incremented with the provided
relative dates specified as string.
- Additional a multiplier can be specified to multiply the increment
+ Additional a multiplier can be specified to multiply the increment
before adding to the provided datetime object.
+ Usage:
+ @code
+ >>> dt = datetime(2001, 9, 1, 0, 0, 0)
+ >>> string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
+ >>> increment_datetime_by_string(dt, string)
+ datetime.datetime(2003, 2, 18, 12, 5)
+ >>> dt = datetime(2001, 11, 1, 0, 0, 0)
+ >>> string = "1 months"
+ datetime.datetime(2001, 12, 1, 0, 0)
+ >>> string = "13 months"
+ datetime.datetime(2002, 12, 1, 0, 0)
+ >>> dt = datetime(2001, 1, 1, 0, 0, 0)
+ >>> string = "72 months"
+ datetime.datetime(2007, 1, 1, 0, 0)
+ >>> string = "5 minutes"
+ datetime.datetime(2001, 1, 1, 0, 5)
+ >>> string = "49 hours"
+ datetime.datetime(2001, 1, 3, 1, 0)
+ >>> string = "3600 seconds"
+ datetime.datetime(2001, 1, 1, 1, 0)
+ >>> string = "30 days"
+ datetime.datetime(2001, 1, 31, 0, 0)
+ @endcode
@param mydate A datetime object to incremented
@param increment A string providing increment information:
- The string may include comma separated values of type seconds,
+ The string may include comma separated values of type seconds,
minutes, hours, days, weeks, months and years
- Example: Increment the datetime 2001-01-01 00:00:00
+ Example: Increment the datetime 2001-01-01 00:00:00
with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
will result in the datetime 2003-02-18 12:05:00
@param mult A multiplier, default is 1
@@ -83,12 +128,11 @@
incparts = increment.split(",")
for incpart in incparts:
inclist.append(incpart.strip().split(" "))
for inc in inclist:
- if len(inc) < 2:
- core.error(_("Wrong increment format: %s") % (increment))
- return None
+ if len(inc) < 2:
+ core.error(_("Wrong increment format: %s") % (increment))
+ return None
if inc[1].find("seconds") >= 0:
seconds = mult * int(inc[0])
elif inc[1].find("minutes") >= 0:
@@ -108,14 +152,17 @@
return None
return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
return mydate
-def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0, minutes=0, seconds=0):
- """!Return a new datetime object incremented with the provided relative dates and times"""
+def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0,
+ minutes=0, seconds=0):
+ relative dates and times"""
tdelta_seconds = timedelta(seconds=seconds)
tdelta_minutes = timedelta(minutes=minutes)
tdelta_hours = timedelta(hours=hours)
@@ -124,14 +171,13 @@
tdelta_months = timedelta(0)
tdelta_years = timedelta(0)
if months > 0:
# Compute the actual number of days in the month to add as timedelta
year = mydate.year
month = mydate.month
all_months = int(months) + int(month)
- years_to_add = int(all_months/12.001)
+ years_to_add = int(all_months / 12.001)
residual_months = all_months - (years_to_add * 12)
# Make a deep copy of the datetime object
@@ -141,7 +187,7 @@
if residual_months == 0:
residual_months = 1
- dt1 = dt1.replace(year = year + years_to_add, month = residual_months)
+ dt1 = dt1.replace(year=year + years_to_add, month=residual_months)
tdelta_months = dt1 - mydate
if years > 0:
@@ -152,12 +198,60 @@
tdelta_years = dt1 - mydate
return mydate + tdelta_seconds + tdelta_minutes + tdelta_hours + \
- tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
+ tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
def adjust_datetime_to_granularity(mydate, granularity):
- """!Mofiy the datetime object to fit the given granularity """
+ """!Modify the datetime object to fit the given granularity
+ * Years will start at the first of Januar
+ * Months will start at the first day of the month
+ * Days will start at the first Hour of the day
+ * Hours will start at the first minute of an hour
+ * Minutes will start at the first second of a minute
+ Usage:
+ @code
+ >>> dt = datetime(2001, 8, 8, 12,30,30)
+ >>> adjust_datetime_to_granularity(dt, "5 seconds")
+ datetime.datetime(2001, 8, 8, 12, 30, 30)
+ >>> adjust_datetime_to_granularity(dt, "20 minutes")
+ datetime.datetime(2001, 8, 8, 12, 30)
+ >>> adjust_datetime_to_granularity(dt, "3 hours")
+ datetime.datetime(2001, 8, 8, 12, 0)
+ >>> adjust_datetime_to_granularity(dt, "5 days")
+ datetime.datetime(2001, 8, 8, 0, 0)
+ >>> adjust_datetime_to_granularity(dt, "2 weeks")
+ datetime.datetime(2001, 8, 6, 0, 0)
+ >>> adjust_datetime_to_granularity(dt, "6 months")
+ datetime.datetime(2001, 8, 1, 0, 0)
+ >>> adjust_datetime_to_granularity(dt, "2 years")
+ datetime.datetime(2001, 1, 1, 0, 0)
+ >>> adjust_datetime_to_granularity(dt, "2 years, 3 months, 5 days, 3 hours, 3 minutes, 2 seconds")
+ >>> adjust_datetime_to_granularity(dt, "3 months, 5 days, 3 minutes")
+ >>> adjust_datetime_to_granularity(dt, "3 weeks, 5 days")
+ @endcode
if granularity:
@@ -203,30 +297,30 @@
return None
if has_seconds:
- pass
- elif has_minutes: # Start at 0 seconds
+ pass
+ elif has_minutes: # Start at 0 seconds
seconds = 0
- elif has_hours: # Start at 0 minutes and seconds
+ elif has_hours: # Start at 0 minutes and seconds
seconds = 0
minutes = 0
- elif has_days: # Start at 0 hours, minutes and seconds
+ elif has_days: # Start at 0 hours, minutes and seconds
seconds = 0
minutes = 0
hours = 0
- elif has_weeks: # Start at the first day of the week (Monday) at 00:00:00
+ elif has_weeks: # Start at the first day of the week (Monday) at 00:00:00
seconds = 0
minutes = 0
hours = 0
if days > weekday:
- days = days - weekday # this needs to be fixed
+ days = days - weekday # this needs to be fixed
else:
- days = days + weekday # this needs to be fixed
- elif has_months: # Start at the first day of the month at 00:00:00
+ days = days + weekday # this needs to be fixed
+ elif has_months: # Start at the first day of the month at 00:00:00
seconds = 0
minutes = 0
hours = 0
days = 1
- elif has_years: # Start at the first day of the first month at 00:00:00
+ elif has_years: # Start at the first day of the first month at 00:00:00
seconds = 0
minutes = 0
hours = 0
@@ -234,16 +328,142 @@
months = 1
dt = copy.copy(mydate)
- result = dt.replace(year=years, month=months, day=days, hour=hours, minute=minutes, second=seconds)
- core.verbose(_("Adjust datetime from %s to %s with granularity %s") % (dt, result, granularity))
+ return dt.replace(year=years, month=months, day=days,
+ hour=hours, minute=minutes, second=seconds)
- return result
def compute_datetime_delta(start, end):
- """!Return a dictionary with the accumulated delta in year, month, day, hour, minute and second
+ """!Return a dictionary with the accumulated delta in year, month, day,
+ hour, minute and second
+ Usage:
+ @code
+ >>> start = datetime(2001, 1, 1, 00,00,00)
+ >>> end = datetime(2001, 1, 1, 00,00,00)
+ >>> compute_datetime_delta(start, end)
+ {'hour': 0, 'month': 0, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
+ >>> start = datetime(2001, 1, 1, 00,00,14)
+ >>> end = datetime(2001, 1, 1, 00,00,44)
+ {'hour': 0, 'month': 0, 'second': 30, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
+ >>> start = datetime(2001, 1, 1, 00,00,44)
+ >>> end = datetime(2001, 1, 1, 00,01,14)
+ {'hour': 0, 'month': 0, 'second': 30, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 1}
+ >>> start = datetime(2001, 1, 1, 00,00,30)
+ >>> end = datetime(2001, 1, 1, 00,05,30)
+ {'hour': 0, 'month': 0, 'second': 300, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 5}
+ >>> end = datetime(2001, 1, 1, 00,01,00)
+ {'hour': 0, 'month': 0, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 1}
+ >>> start = datetime(2011,10,31, 00,45,00)
+ >>> end = datetime(2011,10,31, 01,45,00)
+ {'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 60}
+ >>> end = datetime(2011,10,31, 01,15,00)
+ {'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 30}
+ >>> end = datetime(2011,10,31, 12,15,00)
+ {'hour': 12, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 690}
+ >>> start = datetime(2011,10,31, 00,00,00)
+ >>> end = datetime(2011,10,31, 01,00,00)
+ {'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
+ >>> end = datetime(2011,11,01, 01,00,00)
+ {'hour': 25, 'second': 0, 'max_days': 1, 'year': 0, 'day': 1, 'minute': 0}
+ >>> start = datetime(2011,10,31, 12,00,00)
+ >>> end = datetime(2011,11,01, 06,00,00)
+ {'hour': 18, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
+ >>> start = datetime(2011,11,01, 00,00,00)
+ >>> end = datetime(2011,12,01, 01,00,00)
+ {'hour': 721, 'month': 1, 'second': 0, 'max_days': 30, 'year': 0, 'day': 0, 'minute': 0}
+ >>> end = datetime(2011,11,05, 00,00,00)
+ {'hour': 0, 'second': 0, 'max_days': 4, 'year': 0, 'day': 4, 'minute': 0}
+ >>> start = datetime(2011,10,06, 00,00,00)
+ {'hour': 0, 'second': 0, 'max_days': 30, 'year': 0, 'day': 30, 'minute': 0}
+ >>> start = datetime(2011,12,02, 00,00,00)
+ >>> end = datetime(2012,01,01, 00,00,00)
+ {'hour': 0, 'second': 0, 'max_days': 30, 'year': 1, 'day': 30, 'minute': 0}
+ >>> start = datetime(2011,01,01, 00,00,00)
+ >>> end = datetime(2011,02,01, 00,00,00)
+ {'hour': 0, 'month': 1, 'second': 0, 'max_days': 31, 'year': 0, 'day': 0, 'minute': 0}
+ >>> start = datetime(2011,12,01, 00,00,00)
+ {'hour': 0, 'month': 1, 'second': 0, 'max_days': 31, 'year': 1, 'day': 0, 'minute': 0}
+ >>> end = datetime(2012,06,01, 00,00,00)
+ {'hour': 0, 'month': 6, 'second': 0, 'max_days': 183, 'year': 1, 'day': 0, 'minute': 0}
+ >>> start = datetime(2011,06,01, 00,00,00)
+ >>> end = datetime(2021,06,01, 00,00,00)
+ {'hour': 0, 'month': 120, 'second': 0, 'max_days': 3653, 'year': 10, 'day': 0, 'minute': 0}
+ >>> end = datetime(2012,06,01, 12,00,00)
+ {'hour': 8796, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
+ >>> end = datetime(2012,06,01, 12,30,00)
+ {'hour': 8796, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 527790}
+ >>> end = datetime(2012,06,01, 12,00,05)
+ {'hour': 8796, 'month': 12, 'second': 31665605, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
+ >>> end = datetime(2012,06,01, 00,30,00)
+ {'hour': 0, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 527070}
+ >>> end = datetime(2012,06,01, 00,00,05)
+ {'hour': 0, 'month': 12, 'second': 31622405, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
+ @endcode
@return A dictionary with year, month, day, hour, minute and second as keys()
comp = {}
@@ -281,11 +501,11 @@
else:
d = end.hour - start.hour
if d < 0:
- d = d + 24 + 24 * day_diff
+ d = d + 24 + 24 * day_diff
else:
d = d + 24 * day_diff
comp["hour"] = d
# Minutes
if start.minute == 0 and end.minute == 0:
comp["minute"] = 0
@@ -298,7 +518,7 @@
d = d + 24 * 60 * day_diff
elif d == 0:
if comp["hour"]:
- d = 60* comp["hour"]
+ d = 60 * comp["hour"]
else:
d = 24 * 60 * day_diff
@@ -311,14 +531,14 @@
d = end.second - start.second
if d != 0:
if comp["minute"]:
- d = d + 60* comp["minute"]
+ d = d + 60 * comp["minute"]
elif comp["hour"]:
- d = d + 3600* comp["hour"]
+ d = d + 3600 * comp["hour"]
else:
d = d + 24 * 60 * 60 * day_diff
elif d == 0:
if comp["minute"]:
- d = 60* comp["minute"]
+ d = 60 * comp["minute"]
elif comp["hour"]:
d = 3600 * comp["hour"]
else:
@@ -329,12 +549,15 @@
def string_to_datetime(time_string):
- """!Convert a string into a datetime object using the dateutil parser. Return None in case of failure"""
+ """!Convert a string into a datetime object using the dateutil parser.
+ Return None in case of failure"""
# BC is not supported
if time_string.find("bc") > 0:
- core.error("Dates Before Christ are not supported in the temporal database")
+ core.error("Dates Before Christ are not supported "
+ "in the temporal database")
return None
try:
@@ -345,17 +568,27 @@
def datetime_to_grass_datetime_string(dt):
"""!Convert a python datetime object into a GRASS datetime string"""
# GRASS datetime month names
- month_names = ["", "jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec"]
+ month_names = ["", "jan", "feb", "mar", "apr", "may", "jun",
+ "jul", "aug", "sep", "oct", "nov", "dec"]
# Check for time zone info in the datetime object
- if dt.tzinfo != None:
- string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i"%(dt.day, month_names[dt.month], dt.year, \
- dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds/60)
+ if dt.tzinfo is not None:
+ string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i" % (dt.day,
+ month_names[dt.month], dt.year,
+ dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds / 60)
else:
- string = "%.2i %s %.4i %.2i:%.2i:%.2i"%(dt.day, month_names[dt.month], dt.year, dt.hour, dt.minute, dt.second)
+ string = "%.2i %s %.4i %.2i:%.2i:%.2i" % (dt.day, month_names[
+ dt.month], dt.year, dt.hour, dt.minute, dt.second)
return string
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
\ No newline at end of file
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/extract.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -4,12 +4,6 @@
Temporal GIS related functions to be used in Python scripts.
-Usage:
- at code
- at endcode
@@ -23,54 +17,61 @@
-def extract_dataset(input, output, type, where, expression, base, nprocs=1, register_null=False, layer=1, vtype="point,line,boundary,centroid,area,face"):
+def extract_dataset(input, output, type, where, expression, base, nprocs=1,
+ register_null=False, layer=1,
+ vtype="point,line,boundary,centroid,area,face"):
"""!Extract a subset of a space time raster, raster3d or vector dataset
A mapcalc expression can be provided to process the temporal extracted maps.
Mapcalc expressions are supported for raster and raster3d maps.
- @param input The name of the input space time raster/raster3d dataset
+ @param input The name of the input space time raster/raster3d dataset
@param output The name of the extracted new space time raster/raster3d dataset
@param type The type of the dataset: "raster", "raster3d" or vector
@param where The temporal SQL WHERE statement for subset extraction
@param expression The r(3).mapcalc expression or the v.extract where statement
- @param base The base name of the new created maps in case a mapclac expression is provided
+ @param base The base name of the new created maps in case a mapclac
+ expression is provided
@param nprocs The number of parallel processes to be used for mapcalc processing
- @param register_null Set this number True to register empty maps (only raster and raster3d maps)
- @param layer The vector layer number to be used when no timestamped layer is present, default is 1
- @param vtype The feature type to be extracted for vector maps, default is point,line,boundary,centroid,area and face
+ @param register_null Set this number True to register empty maps
+ (only raster and raster3d maps)
+ @param layer The vector layer number to be used when no timestamped
+ layer is present, default is 1
+ @param vtype The feature type to be extracted for vector maps, default
+ is point,line,boundary,centroid,area and face
# Check the parameters
if expression and not base:
core.fatal(_("You need to specify the base name of new created maps"))
- mapset = core.gisenv()["MAPSET"]
+ mapset = core.gisenv()["MAPSET"]
if input.find("@") >= 0:
id = input
else:
id = input + "@" + mapset
if type == "raster":
- sp = space_time_raster_dataset(id)
+ sp = space_time_raster_dataset(id)
elif type == "raster3d":
- sp = space_time_raster3d_dataset(id)
+ sp = space_time_raster3d_dataset(id)
elif type == "vector":
- sp = space_time_vector_dataset(id)
+ sp = space_time_vector_dataset(id)
dummy = sp.get_new_map_instance(None)
dbif = ()
dbif.connect()
- if sp.is_in_db(dbif) == False:
- dbif.close()
+ if not sp.is_in_db(dbif):
+ dbif.close()
core.fatal(_("Space time %s dataset <%s> not found") % (type, id))
- dbif.close()
+ dbif.close()
core.fatal(_("Please specify base="))
sp.select(dbif)
@@ -82,192 +83,214 @@
# The new space time dataset
new_sp = sp.get_new_instance(out_id)
if new_sp.is_in_db():
- if core.overwrite() == False:
- dbif.close()
- core.fatal(_("Space time %s dataset <%s> is already in database, use overwrite flag to overwrite") % (type, out_id))
+ if not core.overwrite():
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is already in database,"
+ " use overwrite flag to overwrite") % (type, out_id))
- rows = sp.get_registered_maps("id,name,mapset,layer", where, "start_time", dbif)
+ rows = sp.get_registered_maps(
+ "id,name,mapset,layer", where, "start_time", dbif)
else:
- rows = sp.get_registered_maps("id", where, "start_time", dbif)
+ rows = sp.get_registered_maps("id", where, "start_time", dbif)
new_maps = {}
if rows:
- num_rows = len(rows)
- core.percent(0, num_rows, 1)
- # Run the mapcalc expression
+ num_rows = len(rows)
+ core.percent(0, num_rows, 1)
+ # Run the mapcalc expression
if expression:
- count = 0
- proc_count = 0
- proc_list = []
- for row in rows:
- count += 1
- core.percent(count, num_rows, 1)
- map_name = "%s_%i" % (base, count)
- # We need to modify the r(3).mapcalc expression
- if type != "vector":
- expr = "%s = %s" % (map_name, expression)
- expr = expr.replace(sp.base.get_map_id(), row["id"])
- expr = expr.replace(sp.base.get_name(), row["id"])
- # We need to build the id
- map_id = dummy.build_id(map_name, mapset)
- else:
- map_id = dummy.build_id(map_name, mapset, row["layer"])
+ count = 0
+ proc_count = 0
+ proc_list = []
- new_map = sp.get_new_map_instance(map_id)
+ for row in rows:
+ count += 1
- # Check if new map is in the temporal database
- if new_map.is_in_db(dbif):
- if core.overwrite() == True:
- # Remove the existing temporal database entry
- new_map.delete(dbif)
- else:
- core.error(_("Map <%s> is already in temporal database, use overwrite flag to overwrite")%(new_map.get_map_id()))
- continue
- # Add process to the process list
- if type == "raster":
- core.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
- proc_list.append(Process(target=run_mapcalc2d, args=(expr,)))
- elif type == "raster3d":
- core.verbose(_("Apply r3.mapcalc expression: \"%s\"") % expr)
- proc_list.append(Process(target=run_mapcalc3d, args=(expr,)))
- elif type == "vector":
- core.verbose(_("Apply v.extract where statement: \"%s\"") % expression)
- if row["layer"]:
- proc_list.append(Process(target=run_vector_extraction, args=(row["name"] + "@" + row["mapset"], map_name, row["layer"], vtype, expression)))
- else:
- proc_list.append(Process(target=run_vector_extraction, args=(row["name"] + "@" + row["mapset"], map_name, layer, vtype, expression)))
- proc_list[proc_count].start()
- proc_count += 1
- # Join processes if the maximum number of processes are reached or the end of the
- # loop is reached
- if proc_count == nprocs or proc_count == num_rows:
- proc_count = 0
- exitcodes = 0
- for proc in proc_list:
- proc.join()
- exitcodes += proc.exitcode
- if exitcodes != 0:
- dbif.close()
- core.fatal(_("Error while computation"))
- # Empty process list
- proc_list = []
- # Store the new maps
- new_maps[row["id"]] = new_map
- # Insert the new space time dataset
- if new_sp.is_in_db(dbif):
- new_sp.delete(dbif)
- new_sp = sp.get_new_instance(out_id)
+ core.percent(count, num_rows, 1)
- temporal_type, semantic_type, title, description = sp.get_initial_values()
- new_sp.set_initial_values(temporal_type, semantic_type, title, description)
- new_sp.insert(dbif)
- # collect empty maps to remove them
- empty_maps = []
- # Register the maps in the database
+ map_name = "%s_%i" % (base, count)
+ # We need to modify the r(3).mapcalc expression
+ if type != "vector":
+ expr = "%s = %s" % (map_name, expression)
+ expr = expr.replace(sp.base.get_map_id(), row["id"])
+ expr = expr.replace(sp.base.get_name(), row["id"])
+ # We need to build the id
+ map_id = dummy.build_id(map_name, mapset)
+ else:
+ map_id = dummy.build_id(map_name, mapset, row["layer"])
+ new_map = sp.get_new_map_instance(map_id)
+ # Check if new map is in the temporal database
+ if new_map.is_in_db(dbif):
+ if core.overwrite():
+ # Remove the existing temporal database entry
+ new_map.delete(dbif)
+ else:
+ core.error(_("Map <%s> is already in temporal database,"
+ (new_map.get_map_id()))
+ continue
+ # Add process to the process list
+ if type == "raster":
+ core.verbose(_("Apply r.mapcalc expression: \"%s\"")
+ % expr)
+ proc_list.append(Process(target=run_mapcalc2d,
+ args=(expr,)))
+ elif type == "raster3d":
+ core.verbose(_("Apply r3.mapcalc expression: \"%s\"")
+ % expr)
+ proc_list.append(Process(target=run_mapcalc3d,
+ args=(expr,)))
+ elif type == "vector":
+ core.verbose(_("Apply v.extract where statement: \"%s\"")
+ % expression)
+ if row["layer"]:
+ proc_list.append(Process(target=run_vector_extraction,
+ args=(row["name"] + "@" + row["mapset"],
+ map_name, row["layer"],
+ vtype, expression)))
+ else:
+ map_name, layer, vtype,
+ expression)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ # Join processes if the maximum number of processes are reached or the end of the
+ # loop is reached
+ if proc_count == nprocs or proc_count == num_rows:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ dbif.close()
+ core.fatal(_("Error while computation"))
+ # Empty process list
+ proc_list = []
+ # Store the new maps
+ new_maps[row["id"]] = new_map
+ # Insert the new space time dataset
+ if new_sp.is_in_db(dbif):
+ new_sp.delete(dbif)
+ new_sp = sp.get_new_instance(out_id)
+ temporal_type, semantic_type, title, description = sp.get_initial_values()
+ new_sp.set_initial_values(
+ temporal_type, semantic_type, title, description)
+ new_sp.insert(dbif)
+ # collect empty maps to remove them
+ empty_maps = []
+ # Register the maps in the database
count = 0
for row in rows:
count += 1
old_map = sp.get_new_map_instance(row["id"])
old_map.select(dbif)
if expression:
- # Register the new maps
- if new_maps.has_key(row["id"]):
- new_map = new_maps[row["id"]]
+ # Register the new maps
+ if row["id"] in new_maps:
+ new_map = new_maps[row["id"]]
- # Read the raster map data
- new_map.load()
- # In case of a empty map continue, do not register empty maps
- if type == "raster" or type == "raster3d":
- if not register_null:
- empty_maps.append(new_map)
- continue
- if new_map.metadata.get_primitives() == 0 or new_map.metadata.get_primitives() == None:
- continue
+ # Read the raster map data
+ new_map.load()
- # Set the time stamp
- if old_map.is_time_absolute():
- start, end, tz = old_map.get_absolute_time()
- new_map.set_absolute_time(start, end, tz)
- else:
- start, end = old_map.get_relative_time()
- new_map.set_relative_time(start, end)
+ # In case of a empty map continue, do not register empty maps
+ if type == "raster" or type == "raster3d":
+ if new_map.metadata.get_min() is None and \
+ new_map.metadata.get_max() is None:
+ if not register_null:
+ empty_maps.append(new_map)
+ continue
+ if new_map.metadata.get_primitives() == 0 or \
+ new_map.metadata.get_primitives() is None:
+ continue
- # Insert map in temporal database
- new_map.insert(dbif)
+ # Set the time stamp
+ if old_map.is_time_absolute():
+ start, end, tz = old_map.get_absolute_time()
+ new_map.set_absolute_time(start, end, tz)
+ else:
+ start, end = old_map.get_relative_time()
+ new_map.set_relative_time(start, end)
- new_sp.register_map(new_map, dbif)
- else:
- new_sp.register_map(old_map, dbif)
+ # Insert map in temporal database
+ new_map.insert(dbif)
+ new_sp.register_map(new_map, dbif)
+ else:
+ new_sp.register_map(old_map, dbif)
# Update the spatio-temporal extent and the metadata table entries
new_sp.update_from_registered_maps(dbif)
- core.percent(num_rows, num_rows, 1)
- # Remove empty maps
- if len(empty_maps) > 0:
- names = ""
- count = 0
- for map in empty_maps:
- if count == 0:
- names += "%s"%(map.get_name())
- else:
- names += ",%s"%(map.get_name())
- count += 1
- core.run_command("g.remove", rast=names, quiet=True)
- core.run_command("g.remove", rast3d=names, quiet=True)
- core.run_command("g.remove", vect=names, quiet=True)
+ core.percent(num_rows, num_rows, 1)
+ # Remove empty maps
+ if len(empty_maps) > 0:
+ names = ""
+ count = 0
+ for map in empty_maps:
+ if count == 0:
+ names += "%s" % (map.get_name())
+ else:
+ names += ",%s" % (map.get_name())
+ count += 1
+ core.run_command("g.remove", rast=names, quiet=True)
+ core.run_command("g.remove", rast3d=names, quiet=True)
+ core.run_command("g.remove", vect=names, quiet=True)
dbif.close()
def run_mapcalc2d(expr):
"""Helper function to run r.mapcalc in parallel"""
- return core.run_command("r.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
+ return core.run_command("r.mapcalc", expression=expr,
+ overwrite=core.overwrite(), quiet=True)
def run_mapcalc3d(expr):
"""Helper function to run r3.mapcalc in parallel"""
- return core.run_command("r3.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
+ return core.run_command("r3.mapcalc", expression=expr,
def run_vector_extraction(input, output, layer, type, where):
- return core.run_command("v.extract", input=input, output=output, layer=layer, type=type, where=where, overwrite=core.overwrite(), quiet=True)
+ return core.run_command("v.extract", input=input, output=output,
+ layer=layer, type=type, where=where,
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -4,12 +4,6 @@
-Usage:
- at code
- at endcode
@@ -23,87 +17,96 @@
-def dataset_mapcalculator(inputs, output, type, expression, base, method, nprocs=1, register_null=False, spatial=False):
- """!Perform map-calculations of maps from different space time raster/raster3d datasets, using
- a specific sampling method to select temporal related maps.
- A mapcalc expression can be provided to process the temporal extracted maps.
+def dataset_mapcalculator(inputs, output, type, expression, base, method,
+ nprocs=1, register_null=False, spatial=False):
+ """!Perform map-calculations of maps from different space time
+ raster/raster3d datasets, using a specific sampling method
+ to select temporal related maps.
+ A mapcalc expression can be provided to process the temporal
+ extracted maps.
- @param output The name of the extracted new space time raster/raster3d dataset
+ @param output The name of the extracted new space time raster(3d) dataset
@param type The type of the dataset: "raster" or "raster3d"
@param method The method to be used for temporal sampling
- @param nprocs The number of parallel processes to be used for mapcalc processing
+ mapclac expression is provided
+ @param nprocs The number of parallel processes to be used for
+ mapcalc processing
@param spatial Check spatial overlap
# We need a database interface for fast computation
dbif = ()
dbif.connect()
input_name_list = inputs.split(",")
# Process the first input
if input_name_list[0].find("@") >= 0:
- id = input_name_list[0]
+ id = input_name_list[0]
else:
- id = input_name_list[0] + "@" + mapset
+ id = input_name_list[0] + "@" + mapset
- first_input = space_time_raster_dataset(id)
+ first_input = space_time_raster_dataset(id)
else:
- first_input = space_time_raster3d_dataset(id)
- if first_input.is_in_db(dbif) == False:
- dbif.close()
+ first_input = space_time_raster3d_dataset(id)
+ if not first_input.is_in_db(dbif):
+ dbif.close()
# Fill the object with data from the temporal database
first_input.select(dbif)
- # All additional inputs in reverse sorted order to avoid wrong name substitution
+ # All additional inputs in reverse sorted order to avoid
+ # wrong name substitution
input_name_list = input_name_list[1:]
input_name_list.sort()
input_name_list.reverse()
input_list = []
for input in input_name_list:
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = first_input.get_new_instance(id)
- dbif.close()
- core.fatal(_("Space time %s dataset <%s> not found in temporal database") % (type, id))
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
- sp.select(dbif)
- input_list.append(copy.copy(sp))
+ sp = first_input.get_new_instance(id)
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> not "
+ "found in temporal database") % (type, id))
+ sp.select(dbif)
+ input_list.append(copy.copy(sp))
# Create the new space time dataset
if output.find("@") >= 0:
out_id = output
else:
out_id = output + "@" + mapset
new_sp = first_input.get_new_instance(out_id)
# Check if in database
- dbif.close()
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is already in database, "
+ "use overwrite flag to overwrite") % (type, out_id))
# Sample all inputs by the first input and create a sample matrix
if spatial:
core.message(_("Start spatio-temporal sampling"))
@@ -114,217 +117,226 @@
sample_map_list = []
# First entry is the first dataset id
id_list.append(first_input.get_name())
if len(input_list) > 0:
- has_samples = False
- for dataset in input_list:
- list = dataset.sample_by_dataset(stds=first_input, method=method, spatial=spatial, dbif=dbif)
- # In case samples are not found
- if not list and len(list) == 0:
- dbif.close()
- core.message(_("No samples found for map calculation"))
- return 0
- # The fist entries are the samples
- map_name_list = []
- if has_samples == False:
- for entry in list:
- granule = entry["granule"]
- # Do not consider gaps
- if granule.get_id() == None:
- continue
- sample_map_list.append(granule)
- map_name_list.append(granule.get_name())
- # Attach the map names
- map_matrix.append(copy.copy(map_name_list))
- has_samples = True
- maplist = entry["samples"]
- # Do not consider gaps in the sampler
- continue
- if len(maplist) > 1:
- core.warning(_("Found more than a single map in a sample granule. "\
- "Only the first map is used for computation. "\
- "Use t.rast.aggregate.ds to create synchronous raster datasets."))
- # Store all maps! This includes non existent maps, identified by id == None
- map_name_list.append(maplist[0].get_name())
+ has_samples = False
+ for dataset in input_list:
+ list = dataset.sample_by_dataset(stds=first_input,
+ method=method, spatial=spatial,
+ dbif=dbif)
- id_list.append(dataset.get_name())
+ # In case samples are not found
+ if not list and len(list) == 0:
+ dbif.close()
+ core.message(_("No samples found for map calculation"))
+ return 0
+ # The fist entries are the samples
+ map_name_list = []
+ if not has_samples:
+ for entry in list:
+ granule = entry["granule"]
+ # Do not consider gaps
+ if granule.get_id() is None:
+ continue
+ sample_map_list.append(granule)
+ map_name_list.append(granule.get_name())
+ # Attach the map names
+ map_matrix.append(copy.copy(map_name_list))
+ has_samples = True
+ maplist = entry["samples"]
+ # Do not consider gaps in the sampler
+ continue
+ if len(maplist) > 1:
+ core.warning(_("Found more than a single map in a sample "
+ "granule. Only the first map is used for "
+ "computation. Use t.rast.aggregate.ds to "
+ "create synchronous raster datasets."))
+ # Store all maps! This includes non existent maps,
+ # identified by id == None
+ map_name_list.append(maplist[0].get_name())
+ id_list.append(dataset.get_name())
else:
- list = first_input.get_registered_maps_as_objects(dbif=dbif)
- if list == None:
- dbif.close()
+ list = first_input.get_registered_maps_as_objects(dbif=dbif)
+ if list is None:
+ dbif.close()
core.message(_("No maps in input dataset"))
return 0
- for map in list:
- map_name_list.append(map.get_name())
- sample_map_list.append(map)
+ for map in list:
+ map_name_list.append(map.get_name())
+ sample_map_list.append(map)
# Needed for map registration
map_list = []
if len(map_matrix) > 0:
- core.message(_("Start mapcalc computation"))
- count = 0
- # Get the number of samples
- num = len(map_matrix[0])
- # Parallel processing
+ core.message(_("Start mapcalc computation"))
+ count = 0
+ # Get the number of samples
+ num = len(map_matrix[0])
+ # Parallel processing
proc_list = []
proc_count = 0
- # For all samples
+ # For all samples
for i in range(num):
count += 1
- core.percent(count, num, 1)
+ core.percent(count, num, 1)
- # Create the r.mapcalc statement for the current time step
+ # Create the r.mapcalc statement for the current time step
# Check that all maps are in the sample
valid_maps = True
- # Replace all dataset names with their map names of the current time step
+ # Replace all dataset names with their map names of the
+ # current time step
for j in range(len(map_matrix)):
- if map_matrix[j][i] == None:
- valid_maps = False
- break
- # Substitute the dataset name with the map name
- expr = expr.replace(id_list[j], map_matrix[j][i])
+ if map_matrix[j][i] is None:
+ valid_maps = False
+ break
+ # Substitute the dataset name with the map name
+ expr = expr.replace(id_list[j], map_matrix[j][i])
- # Proceed with the next sample
- if valid_maps == False:
- continue
- # Create the new map id and check if the map is already in the database
- map_id = map_name + "@" + mapset
+ # Proceed with the next sample
+ if not valid_maps:
+ continue
- new_map = first_input.get_new_map_instance(map_id)
+ # Create the new map id and check if the map is already
+ # in the database
+ map_id = map_name + "@" + mapset
- else:
- core.error(_("Map <%s> is already in temporal database, use overwrite flag to overwrite"))
- continue
+ new_map = first_input.get_new_map_instance(map_id)
- if sample_map_list[i].is_time_absolute():
- start, end, tz = sample_map_list[i].get_absolute_time()
- else:
- start, end = sample_map_list[i].get_relative_time()
- map_list.append(new_map)
- # Start the parallel r.mapcalc computation
- core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
+ else:
+ core.error(_("Map <%s> is already in temporal database, "
+ "use overwrite flag to overwrite"))
+ continue
- else:
- proc_count += 1
- if proc_count == nprocs or proc_count == num:
- proc_count = 0
- exitcodes = 0
- proc.join()
- dbif.close()
- core.fatal(_("Error while mapcalc computation"))
- proc_list = []
- # Register the new maps in the output space time dataset
- core.message(_("Start map registration in temporal database"))
- # Overwrite an existing dataset if requested
- new_sp = first_input.get_new_instance(out_id)
- # Copy the ids from the first input
- temporal_type, semantic_type, title, description = first_input.get_initial_values()
- # Insert the dataset in the temporal database
- count = 0
- empty_maps = []
- # Insert maps in the temporal database and in the new space time dataset
- for new_map in map_list:
+ if sample_map_list[i].is_time_absolute():
+ start, end, tz = sample_map_list[i].get_absolute_time()
+ else:
+ start, end = sample_map_list[i].get_relative_time()
+ map_list.append(new_map)
+ # Start the parallel r.mapcalc computation
+ core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
+ proc_list.append(Process(target=run_mapcalc2d, args=(expr,)))
+ else:
+ proc_list.append(Process(target=run_mapcalc3d, args=(expr,)))
+ proc_count += 1
+ if proc_count == nprocs or proc_count == num:
+ proc_count = 0
+ exitcodes = 0
+ proc.join()
+ dbif.close()
+ core.fatal(_("Error while mapcalc computation"))
+ proc_list = []
+ # Register the new maps in the output space time dataset
+ core.message(_("Start map registration in temporal database"))
+ # Overwrite an existing dataset if requested
+ new_sp = first_input.get_new_instance(out_id)
+ # Copy the ids from the first input
+ temporal_type, semantic_type, title, description = first_input.get_initial_values()
+ # Insert the dataset in the temporal database
+ count = 0
+ empty_maps = []
+ # Insert maps in the temporal database and in the new space time dataset
+ for new_map in map_list:
count += 1
- # Read the map data
- new_map.load()
- # In case of a null map continue, do not register null maps
- continue
+ # Read the map data
+ new_map.load()
+ # In case of a null map continue, do not register null maps
+ continue
- core.percent(1, 1, 1)
- names = ""
- count = 0
- if count == 0:
- else:
- count += 1
+ core.percent(1, 1, 1)
+ names = ""
+ count = 0
+ if count == 0:
+ else:
+ count += 1
dbif.close()
@@ -332,10 +344,13 @@
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/metadata.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -6,6 +6,8 @@
Usage:
+ at code
>>> meta = tgis.RasterMetadata()
>>> meta = tgis.Raster3DMetadata()
@@ -14,6 +16,8 @@
>>> meta = tgis.STR3DSMetadata()
>>> meta = tgis.STVDSMetadata()
+ at endcode
@@ -31,8 +35,9 @@
Usage:
- >>> import grass.temporal as tgis
- >>> meta = tgis.RasterMetadataBase(table="metadata", ident="soil at PERMANENT",
+ @code
+ >>> meta = RasterMetadataBase(table="metadata", ident="soil at PERMANENT",
... datatype="CELL", cols=100, rows=100, number_of_cells=10000, nsres=0.1,
... ewres=0.1, min=0, max=100)
>>> meta.datatype
@@ -69,7 +74,8 @@
ewres=0.1
min=0.0
max=100.0
+ @endcode
def __init__(self, table=None, ident=None, datatype=None, cols=None,
rows=None, number_of_cells=None, nsres=None, ewres=None,
@@ -267,9 +273,10 @@
register table is stored.
Usage:
+ @code
- >>> meta = tgis.RasterMetadata(ident="soil at PERMANENT",
+ >>> meta = RasterMetadata(ident="soil at PERMANENT",
>>> meta.datatype
@@ -310,6 +317,8 @@
min=0.0
max=100.0
strds_register=None
+ @endcode
def __init__(self, ident=None, strds_register=None, datatype=None,
cols=None, rows=None, number_of_cells=None, nsres=None,
@@ -363,9 +372,10 @@
raster dataset register table is stored.
Usage:
+ @code
- >>> meta = tgis.Raster3DMetadata(ident="soil at PERMANENT",
+ >>> meta = Raster3DMetadata(ident="soil at PERMANENT",
... datatype="FCELL", cols=100, rows=100, depths=100,
... number_of_cells=1000000, nsres=0.1, ewres=0.1, tbres=0.1,
... min=0, max=100)
@@ -415,6 +425,8 @@
str3ds_register=None
depths=100
tbres=0.1
+ @endcode
def __init__(self, ident=None, str3ds_register=None, datatype=None,
cols=None, rows=None, depths=None, number_of_cells=None,
@@ -507,8 +519,9 @@
Usage:
+ @code
>>> meta = VectorMetadata(ident="lidar at PERMANENT", is_3d=True,
... number_of_points=1, number_of_lines=2, number_of_boundaries=3,
... number_of_centroids=4, number_of_faces=5, number_of_kernels=6,
@@ -573,6 +586,8 @@
islands=10
holes=11
volumes=12
+ @endcode
def __init__(
self, ident=None, stvds_register=None, is_3d=False,
@@ -851,13 +866,15 @@
class STDSMetadataBase(SQLDatabaseInterface):
- """!This is the space time dataset metadata base class for strds, stvds and str3ds datasets
+ """!This is the space time dataset metadata base class for
+ strds, stvds and str3ds datasets
setting/getting the id, the title and the description
Usage:
- >>> meta = tgis.STDSMetadataBase(ident="soils at PERMANENT",
+ @code
+ >>> meta = STDSMetadataBase(ident="soils at PERMANENT",
... title="Soils", description="Soils 1950 - 2010")
>>> meta.id
'soils at PERMANENT'
@@ -874,6 +891,8 @@
| Soils 1950 - 2010
>>> meta.print_shell_info()
number_of_maps=None
+ @endcode
def __init__(self, table=None, ident=None, title=None, description=None):
@@ -956,16 +975,18 @@
class STDSRasterMetadataBase(STDSMetadataBase):
- """!This is the space time dataset metadata base class for strds and str3ds datasets
+ class for strds and str3ds datasets
Most of the metadata values are set by triggers in the database when
- new raster or voxel maps are added. Therefor only some set- an many get-functions
- are available.
+ new raster or voxel maps are added. Therefor only some
+ set- an many get-functions are available.
Usage:
- >>> meta = tgis.STDSRasterMetadataBase(ident="soils at PERMANENT",
+ @code
+ >>> meta = STDSRasterMetadataBase(ident="soils at PERMANENT",
>>> meta.id
@@ -1006,6 +1027,8 @@
min_max=None
max_min=None
max_max=None
+ @endcode
@@ -1147,8 +1170,9 @@
Usage:
- >>> meta = tgis.STRDSMetadata(ident="soils at PERMANENT",
+ @code
+ >>> meta = STRDSMetadata(ident="soils at PERMANENT",
>>> meta.id
@@ -1193,6 +1217,8 @@
max_min=None
max_max=None
raster_register=None
+ @endcode
def __init__(self, ident=None, raster_register=None, title=None, description=None):
@@ -1241,8 +1267,9 @@
Usage:
- >>> meta = tgis.STR3DSMetadata(ident="soils at PERMANENT",
+ @code
+ >>> meta = STR3DSMetadata(ident="soils at PERMANENT",
>>> meta.id
@@ -1293,6 +1320,8 @@
tbres_min=None
tbres_max=None
raster3d_register=None
+ @endcode
def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
@@ -1366,9 +1395,12 @@
new vector maps are added. Therefor only some set- an many get-functions
are available.
- >>> meta = tgis.STVDSMetadata(ident="lidars at PERMANENT",
+ Usage:
+ @code
+ >>> meta = STVDSMetadata(ident="lidars at PERMANENT",
... title="LIDARS", description="LIDARS 2008 - 2010")
>>> meta.id
'lidars at PERMANENT'
@@ -1424,6 +1456,8 @@
islands=None
holes=None
volumes=None
+ @endcode
def __init__(
self, ident=None, vector_register=None, title=None, description=None):
@@ -1600,18 +1634,18 @@
STDSMetadataBase.print_info(self)
print " | Vector register table:...... " + str(
self.get_vector_register())
- print " | Number of points ........... " + str(self.get_number_of_points())
- print " | Number of lines ............ " + str(self.get_number_of_lines())
- print " | Number of boundaries ....... " + str(self.get_number_of_boundaries())
- print " | Number of centroids ........ " + str(self.get_number_of_centroids())
- print " | Number of faces ............ " + str(self.get_number_of_faces())
- print " | Number of kernels .......... " + str(self.get_number_of_kernels())
- print " | Number of primitives ....... " + str(self.get_number_of_primitives())
- print " | Number of nodes ............ " + str(self.get_number_of_nodes())
- print " | Number of areas ............ " + str(self.get_number_of_areas())
- print " | Number of islands .......... " + str(self.get_number_of_islands())
- print " | Number of holes ............ " + str(self.get_number_of_holes())
- print " | Number of volumes .......... " + str(self.get_number_of_volumes())
+ print " | Number of points ........... " + str(self.number_of_points)
+ print " | Number of lines ............ " + str(self.number_of_lines)
+ print " | Number of boundaries ....... " + str(self.number_of_boundaries)
+ print " | Number of centroids ........ " + str(self.number_of_centroids)
+ print " | Number of faces ............ " + str(self.number_of_faces)
+ print " | Number of kernels .......... " + str(self.number_of_kernels)
+ print " | Number of primitives ....... " + str(self.number_of_primitives)
+ print " | Number of nodes ............ " + str(self.number_of_nodes)
+ print " | Number of areas ............ " + str(self.number_of_areas)
+ print " | Number of islands .......... " + str(self.number_of_islands)
+ print " | Number of holes ............ " + str(self.number_of_holes)
+ print " | Number of volumes .......... " + str(self.number_of_volumes)
def print_shell_info(self):
"""!Print information about this class in shell style"""
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -4,21 +4,20 @@
-Usage:
- at code
-strds = tgis.space_time_raster_dataset("soils_1950_2010")
- at endcode
for details.
+>>> import grass.script as grass
+>>> grass.run_command("r3.mapcalc", overwrite=True, expression="str3ds_map_test_case = 1")
+0
+>>> grass.run_command("v.random", overwrite=True, output="stvds_map_test_case",
+... n=100, zmin=0, zmax=100, flags="z", column="elevation")
+0
@author Soeren Gebbert
import getpass
@@ -29,216 +28,300 @@
import grass.lib.raster3d as libraster3d
import grass.script.array as garray
-from datetime_math import *
-from abstract_map_dataset import *
from abstract_space_time_dataset import *
-class raster_dataset(AbstractMapDataset):
+class RasterDataset(AbstractMapDataset):
"""!Raster dataset class
This class provides functions to select, update, insert or delete raster
map information and valid time stamps into the SQL temporal database.
+ Usage:
+ @code
+ >>> import grass.script as grass
+ >>> grass.use_temp_region()
+ >>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
+ ... t=1.0, b=0.0, res=10.0)
+ 0
+ >>> grass.run_command("r.mapcalc", overwrite=True,
+ ... expression="strds_map_test_case = 1")
+ 0
+ >>> mapset = grass.gisenv()["MAPSET"]
+ >>> name = "strds_map_test_case"
+ >>> identifier = "%s@%s" % (name, mapset)
+ >>> rmap = RasterDataset(identifier)
+ >>> rmap.set_absolute_time(start_time=datetime(2001,1,1),
+ ... end_time=datetime(2012,1,1))
+ >>> rmap.map_exists()
+ True
+ >>> rmap.load()
+ >>> rmap.spatial_extent.print_info()
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 0.0
+ | East:.. .................... 120.0
+ | West:....................... 0.0
+ | Top:........................ 0.0
+ | Bottom:..................... 0.0
+ >>> rmap.absolute_time.print_info()
+ +-------------------- Absolute time -----------------------------------------+
+ | Start time:................. 2001-01-01 00:00:00
+ | End time:................... 2012-01-01 00:00:00
+ >>> rmap.metadata.print_info()
+ +-------------------- Metadata information ----------------------------------+
+ | Datatype:................... CELL
+ | Number of columns:.......... 8
+ | Number of rows:............. 12
+ | Number of cells:............ 96
+ | North-South resolution:..... 10.0
+ | East-west resolution:....... 10.0
+ | Minimum value:.............. 1.0
+ | Maximum value:.............. 1.0
+ | STRDS register table ....... None
+ >>> newmap = rmap.get_new_instance("new at PERMANENT")
+ >>> isinstance(newmap, RasterDataset)
+ True
+ >>> newstrds = rmap.get_new_stds_instance("new at PERMANENT")
+ >>> isinstance(newstrds, SpaceTimeRasterDataset)
+ True
+ >>> rmap.get_type()
+ 'raster'
+ >>> rmap.get_stds_register()
+ >>> rmap.get_absolute_time()
+ (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0), None)
+ >>> rmap.get_valid_time()
+ (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
+ >>> rmap.get_name()
+ 'strds_map_test_case'
+ >>> rmap.get_mapset() == mapset
+ True
+ >>> rmap.get_temporal_type()
+ 'absolute'
+ >>> rmap.get_spatial_extent()
+ (80.0, 0.0, 120.0, 0.0, 0.0, 0.0)
+ >>> rmap.is_time_absolute()
+ True
+ >>> rmap.is_time_relative()
+ False
+ >>> grass.run_command("g.remove", rast=name)
+ 0
+ >>> grass.del_temp_region()
+ @endcode
def __init__(self, ident):
- AbstractMapDataset.__init__(self)
- self.reset(ident)
+ AbstractMapDataset.__init__(self)
+ self.reset(ident)
def get_type(self):
- return "raster"
+ return 'raster'
def get_new_instance(self, ident):
"""!Return a new instance with the type of this class"""
- return raster_dataset(ident)
+ return RasterDataset(ident)
def get_new_stds_instance(self, ident):
- """!Return a new space time dataset instance in which maps are stored with the type of this class"""
- return space_time_raster_dataset(ident)
+ """!Return a new space time dataset instance in which maps
+ are stored with the type of this class"""
+ return SpaceTimeRasterDataset(ident)
def get_stds_register(self):
- """!Return the space time dataset register table name in which stds are listed in which this map is registered"""
+ """!Return the space time dataset register table name in which stds
+ are listed in which this map is registered"""
return self.metadata.get_strds_register()
def set_stds_register(self, name):
- """!Set the space time dataset register table name in which stds are listed in which this map is registered"""
+ """!Set the space time dataset register table name in which stds
self.metadata.set_strds_register(name)
def spatial_overlapping(self, dataset):
"""!Return True if the spatial extents 2d overlap"""
return self.spatial_extent.overlapping_2d(dataset.spatial_extent)
def spatial_relation(self, dataset):
- """Return the two dimensional spatial relation"""
+ """!Return the two dimensional spatial relation"""
return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
def get_np_array(self):
- """Return this raster map as memmap numpy style array to access the raster
- values in numpy style without loading the whole map in the RAM.
- In case this raster map does exists in the grass spatial database, the map
- will be exported using r.out.bin to a temporary location and assigned to the
- memmap object that is returned by this function.
- In case the raster map does not exists, an empty temporary binary file will be created
- and assigned to the memap object.
- You need to call the write function to write the memmap array back into grass.
- a = garray.array()
- if self.map_exists():
- a.read(self.get_map_id())
- return a
+ """!Return this raster map as memmap numpy style array to access the raster
+ values in numpy style without loading the whole map in the RAM.
+ In case this raster map does exists in the grass spatial database,
+ the map will be exported using r.out.bin to a temporary location
+ and assigned to the memmap object that is returned by this function.
+ In case the raster map does not exists, an empty temporary
+ binary file will be created and assigned to the memap object.
+ You need to call the write function to write the memmap
+ array back into grass.
+ a = garray.array()
+ if self.map_exists():
+ a.read(self.get_map_id())
+ return a
def reset(self, ident):
- """!Reset the internal structure and set the identifier"""
- self.base = RasterBase(ident=ident)
- self.absolute_time = RasterAbslouteTime(ident=ident)
- self.relative_time = RasterRelativeTime(ident=ident)
- self.spatial_extent = RasterSpatialExtent(ident=ident)
- self.metadata = RasterMetadata(ident=ident)
+ """!Reset the internal structure and set the identifier"""
+ self.base = RasterBase(ident=ident)
+ self.absolute_time = RasterAbsoluteTime(ident=ident)
+ self.relative_time = RasterRelativeTime(ident=ident)
+ self.spatial_extent = RasterSpatialExtent(ident=ident)
+ self.metadata = RasterMetadata(ident=ident)
def has_grass_timestamp(self):
- """!Check if a grass file bsased time stamp exists for this map.
+ """!Check if a grass file bsased time stamp exists for this map.
if G_has_raster_timestamp(self.get_name(), self.get_mapset()):
- return True
- else:
- return False
+ return True
+ else:
+ return False
def write_timestamp_to_grass(self):
- """!Write the timestamp of this map into the map metadata in the grass file system based spatial
- database.
+ """!Write the timestamp of this map into the map metadata in
+ the grass file system based spatial database.
Internally the libgis API functions are used for writing
- ts = libgis.TimeStamp()
- libgis.G_scan_timestamp(byref(ts), self._convert_timestamp())
- check = libgis.G_write_raster_timestamp(self.get_name(), byref(ts))
- if check == -1:
- core.error(_("Unable to create timestamp file for raster map <%s>"%(self.get_map_id())))
- if check == -2:
- core.error(_("Invalid datetime in timestamp for raster map <%s>"%(self.get_map_id())))
+ ts = libgis.TimeStamp()
+ libgis.G_scan_timestamp(byref(ts), self._convert_timestamp())
+ check = libgis.G_write_raster_timestamp(self.get_name(), byref(ts))
+ if check == -1:
+ core.error(_("Unable to create timestamp file "
+ "for raster map <%s>" % (self.get_map_id())))
+ if check == -2:
+ core.error(_("Invalid datetime in timestamp for raster map <%s>" %
+ (self.get_map_id())))
def remove_timestamp_from_grass(self):
- """!Remove the timestamp from the grass file system based spatial database
+ """!Remove the timestamp from the grass file system based
+ spatial database
Internally the libgis API functions are used for removal
check = libgis.G_remove_raster_timestamp(self.get_name())
if check == -1:
- core.error(_("Unable to remove timestamp for raster map <%s>"%(self.get_name())))
+ core.error(_("Unable to remove timestamp for raster map <%s>" %
+ (self.get_name())))
def map_exists(self):
"""!Return True in case the map exists in the grass spatial database
@return True if map exists, False otherwise
mapset = libgis.G_find_raster(self.get_name(), self.get_mapset())
if not mapset:
return False
- return True
+ return True
def read_info(self):
- """!Read the raster map info from the file system and store the content
+ """!Read the raster map info from the file system and store the content
into a dictionary
This method uses the ctypes interface to the gis and raster libraries
to read the map metadata information
kvp = {}
name = self.get_name()
mapset = self.get_mapset()
if not self.map_exists():
- core.fatal(_("Raster map <%s> not found" % name))
+ core.fatal(_("Raster map <%s> not found" % name))
# Read the region information
region = libgis.Cell_head()
- libraster.Rast_get_cellhd(name, mapset, byref(region))
- kvp["north"] = region.north
- kvp["south"] = region.south
- kvp["east"] = region.east
- kvp["west"] = region.west
- kvp["nsres"] = region.ns_res
- kvp["ewres"] = region.ew_res
- kvp["rows"] = region.cols
- kvp["cols"] = region.rows
- maptype = libraster.Rast_map_type(name, mapset)
- if maptype == libraster.DCELL_TYPE:
- kvp["datatype"] = "DCELL"
+ libraster.Rast_get_cellhd(name, mapset, byref(region))
+ kvp["north"] = region.north
+ kvp["south"] = region.south
+ kvp["east"] = region.east
+ kvp["west"] = region.west
+ kvp["nsres"] = region.ns_res
+ kvp["ewres"] = region.ew_res
+ kvp["rows"] = region.cols
+ kvp["cols"] = region.rows
+ maptype = libraster.Rast_map_type(name, mapset)
+ if maptype == libraster.DCELL_TYPE:
+ kvp["datatype"] = "DCELL"
elif maptype == libraster.FCELL_TYPE:
- kvp["datatype"] = "FCELL"
+ kvp["datatype"] = "FCELL"
elif maptype == libraster.CELL_TYPE:
- kvp["datatype"] = "CELL"
- # Read range
- if libraster.Rast_map_is_fp(name, mapset):
- range = libraster.FPRange()
- libraster.Rast_init_fp_range (byref(range))
- ret = libraster.Rast_read_fp_range(name, mapset, byref(range))
- if ret < 0:
- core.fatal(_("Unable to read range file"))
- if ret == 2:
- kvp["min"] = None
- kvp["max"] = None
- else:
- min = libgis.DCELL()
- max = libgis.DCELL()
- libraster.Rast_get_fp_range_min_max(byref(range), byref(min), byref(max))
- kvp["min"] = min.value
- kvp["max"] = max.value
- else:
- range = libraster.Range()
- libraster.Rast_init_range (byref(range))
- ret = libraster.Rast_read_range(name, mapset, byref(range))
- if ret < 0:
- if ret == 2:
- kvp["min"] = None
- kvp["max"] = None
- else:
- min = libgis.CELL()
- max = libgis.CELL()
- libraster.Rast_get_range_min_max(byref(range), byref(min), byref(max))
- return kvp
+ kvp["datatype"] = "CELL"
+ # Read range
+ if libraster.Rast_map_is_fp(name, mapset):
+ range = libraster.FPRange()
+ libraster.Rast_init_fp_range(byref(range))
+ ret = libraster.Rast_read_fp_range(name, mapset, byref(range))
+ if ret < 0:
+ core.fatal(_("Unable to read range file"))
+ if ret == 2:
+ kvp["min"] = None
+ kvp["max"] = None
+ else:
+ min = libgis.DCELL()
+ max = libgis.DCELL()
+ libraster.Rast_get_fp_range_min_max(
+ byref(range), byref(min), byref(max))
+ kvp["min"] = min.value
+ kvp["max"] = max.value
+ else:
+ range = libraster.Range()
+ libraster.Rast_init_range(byref(range))
+ ret = libraster.Rast_read_range(name, mapset, byref(range))
+ if ret < 0:
+ if ret == 2:
+ kvp["min"] = None
+ kvp["max"] = None
+ else:
+ min = libgis.CELL()
+ max = libgis.CELL()
+ libraster.Rast_get_range_min_max(
+ return kvp
def load(self):
- """!Load all info from an existing raster map into the internal structure"""
+ """!Load all info from an existing raster map into the internal s
+ tructure"""
# Fill base information
self.base.set_creator(str(getpass.getuser()))
# Get the data from an existing raster map
kvp = self.read_info()
# Fill spatial extent
- self.set_spatial_extent(north=kvp["north"], south=kvp["south"], \
- east=kvp["east"], west=kvp["west"])
+ self.set_spatial_extent(north=kvp["north"], south=kvp["south"],
+ east=kvp["east"], west=kvp["west"])
# Fill metadata
@@ -259,38 +342,41 @@
-class raster3d_dataset(AbstractMapDataset):
+class Raster3DDataset(AbstractMapDataset):
"""!Raster3d dataset class
This class provides functions to select, update, insert or delete raster3d
- self.reset(ident)
+ self.reset(ident)
def get_type(self):
return "raster3d"
- return raster3d_dataset(ident)
+ return Raster3DDataset(ident)
- return space_time_raster3d_dataset(ident)
+ return SpaceTimeRaster3DDataset(ident)
+ which stds are listed in which this map is registered"""
return self.metadata.get_str3ds_register()
self.metadata.set_str3ds_register(name)
"""!Return True if the spatial extents overlap"""
if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
return self.spatial_extent.overlapping(dataset.spatial_extent)
else:
@@ -298,140 +384,146 @@
"""!Return the two or three dimensional spatial relation"""
return self.spatial_extent.spatial_relation(dataset.spatial_extent)
else:
- self.base = Raster3DBase(ident=ident)
- self.absolute_time = Raster3DAbslouteTime(ident=ident)
- self.relative_time = Raster3DRelativeTime(ident=ident)
- self.spatial_extent = Raster3DSpatialExtent(ident=ident)
- self.metadata = Raster3DMetadata(ident=ident)
+ self.base = Raster3DBase(ident=ident)
+ self.absolute_time = Raster3DAbsoluteTime(ident=ident)
+ self.relative_time = Raster3DRelativeTime(ident=ident)
+ self.spatial_extent = Raster3DSpatialExtent(ident=ident)
+ self.metadata = Raster3DMetadata(ident=ident)
if G_has_raster3d_timestamp(self.get_name(), self.get_mapset()):
- return True
- else:
- return False
+ return True
+ else:
+ return False
- database.
+ in the grass file system based spatial database.
- check = libgis.G_write_raster3d_timestamp(self.get_name(), byref(ts))
- if check == -1:
- core.error(_("Unable to create timestamp file for raster3d map <%s>"%(self.get_map_id())))
- if check == -2:
- core.error(_("Invalid datetime in timestamp for raster3d map <%s>"%(self.get_map_id())))
+ check = libgis.G_write_raster3d_timestamp(self.get_name(), byref(ts))
+ if check == -1:
+ "for raster3d map <%s>" % (self.get_map_id())))
+ if check == -2:
+ core.error(_("Invalid datetime in timestamp "
check = libgis.G_remove_raster3d_timestamp(self.get_name())
if check == -1:
- core.error(_("Unable to remove timestamp for raster3d map <%s>"%(self.get_name())))
+ core.error(_("Unable to remove timestamp for raster3d map <%s>" %
mapset = libgis.G_find_raster3d(self.get_name(), self.get_mapset())
if not mapset:
return False
- return True
+ return True
- """!Read the raster3d map info from the file system and store the content
+ """!Read the raster3d map info from the file system and store the content
into a dictionary
This method uses the ctypes interface to the gis and raster3d libraries
kvp = {}
- core.fatal(_("Raster3d map <%s> not found" % name))
+ core.fatal(_("Raster3d map <%s> not found" % name))
region = libraster3d.RASTER3D_Region()
- libraster3d.Rast3d_read_region_map(name, mapset, byref(region))
- kvp["tbres"] = region.tb_res
- kvp["depths"] = region.depths
- kvp["top"] = region.top
- kvp["bottom"] = region.bottom
- # We need to open the map, this function returns a void pointer
- # but we may need the correct type which is RASTER3D_Map, hence the casting
- g3map = cast(libraster3d.Rast3d_open_cell_old(name, mapset, \
- libraster3d.RASTER3D_DEFAULT_WINDOW, libraster3d.RASTER3D_TILE_SAME_AS_FILE, \
- libraster3d.RASTER3D_NO_CACHE), POINTER(libraster3d.RASTER3D_Map))
- if not g3map:
- core.fatal(_("Unable to open 3D raster map <%s>"%(name)));
+ libraster3d.Rast3d_read_region_map(name, mapset, byref(region))
- maptype = libraster3d.Rast3d_file_type_map(g3map)
+ kvp["tbres"] = region.tb_res
+ kvp["depths"] = region.depths
+ kvp["top"] = region.top
+ kvp["bottom"] = region.bottom
+ # We need to open the map, this function returns a void pointer
+ # but we may need the correct type which is RASTER3D_Map, hence
+ # the casting
+ g3map = cast(libraster3d.Rast3d_open_cell_old(name, mapset,
+ libraster3d.RASTER3D_DEFAULT_WINDOW,
+ libraster3d.RASTER3D_TILE_SAME_AS_FILE,
+ libraster3d.RASTER3D_NO_CACHE),
+ POINTER(libraster3d.RASTER3D_Map))
+ if not g3map:
+ core.fatal(_("Unable to open 3D raster map <%s>" % (name)))
+ maptype = libraster3d.Rast3d_file_type_map(g3map)
- # Read range
- ret = libraster3d.Rast3d_range_load(g3map)
- if not ret:
- core.fatal(_("Unable to load range of 3D raster map <%s>"%(name)));
- libraster3d.Rast3d_range_min_max(g3map, byref(min), byref(max))
- if min.value != min.value:
- kvp["min"] = None
- else:
- kvp["min"] = float(min.value)
- if max.value != max.value:
- kvp["max"] = None
- else:
- kvp["max"] = float(max.value)
- if not libraster3d.Rast3d_close(g3map):
- G_fatal_error(_("Unable to close 3D raster map <%s>"%(name)))
- return kvp
+ # Read range
+ ret = libraster3d.Rast3d_range_load(g3map)
+ if not ret:
+ core.fatal(_("Unable to load range of 3D raster map <%s>" %
+ (name)))
+ libraster3d.Rast3d_range_min_max(g3map, byref(min), byref(max))
+ if min.value != min.value:
+ kvp["min"] = None
+ else:
+ kvp["min"] = float(min.value)
+ if max.value != max.value:
+ kvp["max"] = None
+ else:
+ kvp["max"] = float(max.value)
+ if not libraster3d.Rast3d_close(g3map):
+ G_fatal_error(_("Unable to close 3D raster map <%s>" % (name)))
+ return kvp
def load(self):
"""!Load all info from an existing raster3d map into the internal structure"""
@@ -442,9 +534,9 @@
- east=kvp["east"], west=kvp["west"],\
+ east=kvp["east"], west=kvp["west"],
top=kvp["top"], bottom=kvp["bottom"])
# Fill metadata
@@ -470,33 +562,36 @@
-class vector_dataset(AbstractMapDataset):
+class VectorDataset(AbstractMapDataset):
"""!Vector dataset class
This class provides functions to select, update, insert or delete vector
- self.reset(ident)
+ self.reset(ident)
def get_type(self):
return "vector"
- return vector_dataset(ident)
+ return VectorDataset(ident)
- return space_time_vector_dataset(ident)
+ return SpaceTimeVectorDataset(ident)
return self.metadata.get_stvds_register()
self.metadata.set_stvds_register(name)
def get_layer(self):
@@ -505,172 +600,188 @@
- self.base = VectorBase(ident=ident)
- self.absolute_time = VectorAbslouteTime(ident=ident)
- self.relative_time = VectorRelativeTime(ident=ident)
- self.spatial_extent = VectorSpatialExtent(ident=ident)
- self.metadata = VectorMetadata(ident=ident)
+ self.base = VectorBase(ident=ident)
+ self.absolute_time = VectorAbsoluteTime(ident=ident)
+ self.relative_time = VectorRelativeTime(ident=ident)
+ self.spatial_extent = VectorSpatialExtent(ident=ident)
+ self.metadata = VectorMetadata(ident=ident)
- if G_has_raster_timestamp(self.get_name(), self.get_layer(), self.get_mapset()):
- return True
- else:
- return False
+ if G_has_raster_timestamp(self.get_name(), self.get_layer(),
+ self.get_mapset()):
+ return True
+ else:
+ return False
- database.
- check = libgis.G_write_vector_timestamp(self.get_name(), self.get_layer(), byref(ts))
- if check == -1:
- core.error(_("Unable to create timestamp file for vector map <%s>"%(self.get_map_id())))
- if check == -2:
- core.error(_("Invalid datetime in timestamp for vector map <%s>"%(self.get_map_id())))
+ check = libgis.G_write_vector_timestamp(
+ self.get_name(), self.get_layer(), byref(ts))
+ if check == -1:
+ "for vector map <%s>" % (self.get_map_id())))
+ if check == -2:
+ core.error(_("Invalid datetime in timestamp for vector map <%s>" %
+ """!Remove the timestamp from the grass file system based spatial
+ database
- check = libgis.G_remove_vector_timestamp(self.get_name(), self.get_layer())
+ check = libgis.G_remove_vector_timestamp(
+ self.get_name(), self.get_layer())
if check == -1:
- core.error(_("Unable to remove timestamp for vector map <%s>"%(self.get_name())))
+ core.error(_("Unable to remove timestamp for vector map <%s>" %
mapset = libgis.G_find_vector(self.get_name(), self.get_mapset())
if not mapset:
return False
- return True
+ return True
- """!Read the vector map info from the file system and store the content
+ """!Read the vector map info from the file system and store the content
into a dictionary
This method uses the ctypes interface to the vector libraries
kvp = {}
- core.fatal(_("Vector map <%s> not found" % name))
- # The vector map structure
- Map = libvector.Map_info()
+ core.fatal(_("Vector map <%s> not found" % name))
+ # The vector map structure
+ Map = libvector.Map_info()
# We open the maps always in topology mode first
libvector.Vect_set_open_level(2)
with_topo = True
# Code lend from v.info main.c
if libvector.Vect_open_old_head2(byref(Map), name, mapset, "1") < 2:
- # force level 1, open fully
- # NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available
- libvector.Vect_set_open_level(1) # no topology
- with_topo = False
- core.message(_("Open map without topology support"))
- if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
- core.fatal(_("Unable to open vector map <%s>"%(libvector.Vect_get_full_name(byref(Map)))))
+ # force level 1, open fully
+ # NOTE: number of points, lines, boundaries, centroids,
+ # faces, kernels is still available
+ libvector.Vect_set_open_level(1) # no topology
+ with_topo = False
+ core.message(_("Open map without topology support"))
+ if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
+ core.fatal(_("Unable to open vector map <%s>" %
+ (libvector.Vect_get_full_name(byref(Map)))))
# Read the extent information
bbox = libvector.bound_box()
- libvector.Vect_get_map_box(byref(Map), byref(bbox));
- kvp["north"] = bbox.N
- kvp["south"] = bbox.S
- kvp["east"] = bbox.E
- kvp["west"] = bbox.W
- kvp["top"] = bbox.T
- kvp["bottom"] = bbox.B
- kvp["is_3d"] = bool(libvector.Vect_is_3d(byref(Map)))
- # Read number of features
- if with_topo:
- kvp["points"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_POINT)
- kvp["lines"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_LINE)
- kvp["boundaries"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_BOUNDARY)
- kvp["centroids"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_CENTROID)
- kvp["faces"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_FACE)
- kvp["kernels"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_KERNEL)
- # Summarize the primitives
- kvp["primitives"] = kvp["points"] + kvp["lines"] + kvp["boundaries"] + kvp["centroids"]
- if kvp["is_3d"]:
- kvp["primitives"] += kvp["faces"] + kvp["kernels"]
+ libvector.Vect_get_map_box(byref(Map), byref(bbox))
- # Read topology information
- kvp["nodes"] = libvector.Vect_get_num_nodes(byref(Map))
- kvp["areas"] = libvector.Vect_get_num_areas(byref(Map))
- kvp["islands"] = libvector.Vect_get_num_islands(byref(Map))
- kvp["holes"] = libvector.Vect_get_num_holes(byref(Map))
- kvp["volumes"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_VOLUME)
- else:
- kvp["points"] = None
- kvp["lines"] = None
- kvp["boundaries"] = None
- kvp["centroids"] = None
- kvp["faces"] = None
- kvp["kernels"] = None
- kvp["primitives"] = None
- kvp["nodes"] = None
- kvp["areas"] = None
- kvp["islands"] = None
- kvp["holes"] = None
- kvp["volumes"] = None
- libvector.Vect_close(byref(Map))
- return kvp
+ kvp["north"] = bbox.N
+ kvp["south"] = bbox.S
+ kvp["east"] = bbox.E
+ kvp["west"] = bbox.W
+ kvp["top"] = bbox.T
+ kvp["bottom"] = bbox.B
+ kvp["is_3d"] = bool(libvector.Vect_is_3d(byref(Map)))
+ # Read number of features
+ if with_topo:
+ kvp["points"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_POINT)
+ kvp["lines"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_LINE)
+ kvp["boundaries"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_BOUNDARY)
+ kvp["centroids"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_CENTROID)
+ kvp["faces"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_FACE)
+ kvp["kernels"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_KERNEL)
+ # Summarize the primitives
+ kvp["primitives"] = kvp["points"] + kvp["lines"] + \
+ if kvp["is_3d"]:
+ kvp["primitives"] += kvp["faces"] + kvp["kernels"]
+ # Read topology information
+ kvp["nodes"] = libvector.Vect_get_num_nodes(byref(Map))
+ kvp["areas"] = libvector.Vect_get_num_areas(byref(Map))
+ kvp["islands"] = libvector.Vect_get_num_islands(byref(Map))
+ kvp["holes"] = libvector.Vect_get_num_holes(byref(Map))
+ kvp["volumes"] = libvector.Vect_get_num_primitives(
+ byref(Map), libvector.GV_VOLUME)
+ else:
+ kvp["points"] = None
+ kvp["lines"] = None
+ kvp["boundaries"] = None
+ kvp["centroids"] = None
+ kvp["faces"] = None
+ kvp["kernels"] = None
+ kvp["primitives"] = None
+ kvp["nodes"] = None
+ kvp["areas"] = None
+ kvp["islands"] = None
+ kvp["holes"] = None
+ kvp["volumes"] = None
+ libvector.Vect_close(byref(Map))
+ return kvp
def load(self):
- """!Load all info from an existing vector map into the internal structure"""
+ """!Load all info from an existing vector map into the internal
+ structure"""
- # Fill metadata
- self.metadata.set_3d_info(kvp["is_3d"])
+ # Fill metadata
+ self.metadata.set_3d_info(kvp["is_3d"])
self.metadata.set_points(kvp["points"])
self.metadata.set_lines(kvp["lines"])
self.metadata.set_boundaries(kvp["boundaries"])
@@ -686,7 +797,7 @@
-class space_time_raster_dataset(AbstractSpaceTimeDataset):
+class SpaceTimeRasterDataset(AbstractSpaceTimeDataset):
"""!Space time raster dataset class
@@ -697,11 +808,11 @@
def get_new_map_instance(self, ident):
"""!Return a new instance of a map dataset which is associated with the type of this class"""
def get_map_register(self):
"""!Return the name of the map register table"""
@@ -713,27 +824,27 @@
- self.base = STRDSBase(ident=ident)
+ self.base = STRDSBase(ident=ident)
- self.absolute_time = STRDSAbslouteTime(ident=ident)
+ self.absolute_time = STRDSAbsoluteTime(ident=ident)
self.relative_time = STRDSRelativeTime(ident=ident)
- self.spatial_extent = STRDSSpatialExtent(ident=ident)
- self.metadata = STRDSMetadata(ident=ident)
+ self.spatial_extent = STRDSSpatialExtent(ident=ident)
+ self.metadata = STRDSMetadata(ident=ident)
-class space_time_raster3d_dataset(AbstractSpaceTimeDataset):
+class SpaceTimeRaster3DDataset(AbstractSpaceTimeDataset):
"""!Space time raster3d dataset class
@@ -745,11 +856,12 @@
- """!Return a new instance of a map dataset which is associated with the type of this class"""
+ """!Return a new instance of a map dataset which is associated
+ with the type of this class"""
@@ -761,7 +873,7 @@
else:
@@ -769,25 +881,27 @@
- if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
+ if self.get_type() == dataset.get_type() or \
+ dataset.get_type() == "str3ds":
else:
- self.base = STR3DSBase(ident=ident)
+ self.base = STR3DSBase(ident=ident)
- self.absolute_time = STR3DSAbslouteTime(ident=ident)
+ self.absolute_time = STR3DSAbsoluteTime(ident=ident)
self.relative_time = STR3DSRelativeTime(ident=ident)
- self.spatial_extent = STR3DSSpatialExtent(ident=ident)
- self.metadata = STR3DSMetadata(ident=ident)
+ self.spatial_extent = STR3DSSpatialExtent(ident=ident)
+ self.metadata = STR3DSMetadata(ident=ident)
-class space_time_vector_dataset(AbstractSpaceTimeDataset):
+class SpaceTimeVectorDataset(AbstractSpaceTimeDataset):
"""!Space time vector dataset class
@@ -799,11 +913,12 @@
@@ -815,28 +930,30 @@
- self.base = STVDSBase(ident=ident)
+ self.base = STVDSBase(ident=ident)
- self.absolute_time = STVDSAbslouteTime(ident=ident)
+ self.absolute_time = STVDSAbsoluteTime(ident=ident)
self.relative_time = STVDSRelativeTime(ident=ident)
- self.spatial_extent = STVDSSpatialExtent(ident=ident)
- self.metadata = STVDSMetadata(ident=ident)
+ self.spatial_extent = STVDSSpatialExtent(ident=ident)
+ self.metadata = STVDSMetadata(ident=ident)
class AbstractDatasetComparisonKeyStartTime(object):
- """!This comparison key can be used to sort lists of abstract datasets by start time
+ """!This comparison key can be used to sort lists of abstract datasets
+ by start time
Example:
@@ -882,8 +999,10 @@
class AbstractDatasetComparisonKeyEndTime(object):
- """!This comparison key can be used to sort lists of abstract datasets by end time
+ by end time
Example:
@@ -927,3 +1046,8 @@
startB, endB = other.obj.get_valid_time()
return endA != endB
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -23,14 +23,16 @@
from space_time_datasets import *
-def register_maps_in_space_time_dataset(type, name, maps=None, file=None, start=None, \
- end=None, unit=None, increment=None, dbif = None, \
- interval=False, fs="|"):
- """!Use this method to register maps in space time datasets. This function is generic and
+def register_maps_in_space_time_dataset(
+ type, name, maps=None, file=None, start=None,
+ end=None, unit=None, increment=None, dbif=None,
+ interval=False, fs="|"):
+ """!Use this method to register maps in space time datasets.
Additionally a start time string and an increment string can be specified
to assign a time interval automatically to the maps.
@@ -40,86 +42,100 @@
@param type: The type of the maps rast, rast3d or vect
@param name: The name of the space time dataset
@param maps: A comma separated list of map names
- @param file: Input file one map with start and optional end time, one per line
- @param start: The start date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
- @param end: The end date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
- @param unit: The unit of the relative time: years, months, days, hours, minutes, seconds
- @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+ @param file: Input file one map with start and optional end time,
+ one per line
+ @param start: The start date and time of the first raster map
+ (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd",
+ format relative is integer 5)
+ @param end: The end date and time of the first raster map
+ @param unit: The unit of the relative time: years, months, days,
+ hours, minutes, seconds
+ @param increment: Time increment between maps for time stamp creation
+ (format absolute: NNN seconds, minutes, hours, days,
+ weeks, months, years; format relative: 1.0)
@param dbif: The database interface to be used
- @param interval: If True, time intervals are created in case the start time and an increment is provided
+ @param interval: If True, time intervals are created in case the start
+ time and an increment is provided
@param fs: Field separator used in input file
start_time_in_file = False
end_time_in_file = False
if maps and file:
- core.fatal(_("%s= and %s= are mutually exclusive") % ("input","file"))
+ core.fatal(_("%s= and %s= are mutually exclusive") % ("input", "file"))
if end and increment:
- core.fatal(_("%s= and %s= are mutually exclusive") % ("end","increment"))
+ "end", "increment"))
if end and not start:
- core.fatal(_("Please specify %s= and %s=") % ("start_time","end_time"))
+ core.fatal(_("Please specify %s= and %s=") % ("start_time",
+ "end_time"))
if not maps and not file:
- core.fatal(_("Please specify %s= or %s=") % ("input","file"))
+ core.fatal(_("Please specify %s= or %s=") % ("input", "file"))
# We may need the mapset
- mapset = core.gisenv()["MAPSET"]
+ mapset = core.gisenv()["MAPSET"]
# The name of the space time dataset is optional
if name:
- # Check if the dataset name contains the mapset as well
- if name.find("@") < 0:
- id = name + "@" + mapset
- else:
- id = name
+ # Check if the dataset name contains the mapset as well
+ if name.find("@") < 0:
+ id = name + "@" + mapset
+ else:
+ id = name
- if type == "rast" or type == "raster":
- sp = dataset_factory("strds", id)
- elif type == "rast3d":
- sp = dataset_factory("str3ds", id)
- elif type == "vect" or type == "vector":
- sp = dataset_factory("stvds", id)
- else:
- core.fatal(_("Unkown map type: %s")%(type))
+ if type == "rast" or type == "raster":
+ sp = dataset_factory("strds", id)
+ elif type == "rast3d":
+ sp = dataset_factory("str3ds", id)
+ elif type == "vect" or type == "vector":
+ sp = dataset_factory("stvds", id)
+ else:
+ core.fatal(_("Unkown map type: %s") % (type))
dbif, connect = init_dbif(None)
if name:
- # Read content from temporal database
- sp.select(dbif)
+ # Read content from temporal database
+ sp.select(dbif)
- if sp.is_in_db(dbif) == False:
- dbif.close()
- core.fatal(_("Space time %s dataset <%s> no found") % (sp.get_new_map_instance(None).get_type(), name))
+ if not sp.is_in_db(dbif):
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> no found") %
+ (sp.get_new_map_instance(None).get_type(), name))
- if sp.is_time_relative() and not unit:
- dbif.close()
- core.fatal(_("Space time %s dataset <%s> with relative time found, but no relative unit set for %s maps") % (sp.get_new_map_instance(None).get_type(), name, sp.get_new_map_instance(None).get_type()))
+ if sp.is_time_relative() and not unit:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> with relative time found, "
+ "but no relative unit set for %s maps") %
+ name, sp.get_new_map_instance(None).get_type()))
# We need a dummy map object to build the map ids
dummy = dataset_factory(type, None)
maplist = []
# Map names as comma separated string
if maps:
if maps.find(",") < 0:
- maplist = [maps,]
+ maplist = [maps, ]
else:
maplist = maps.split(",")
- # Build the map list again with the ids
- for count in range(len(maplist)):
- row = {}
- mapid = dummy.build_id(maplist[count], mapset, None)
- row["id"] = mapid
+ # Build the map list again with the ids
+ for count in range(len(maplist)):
+ row = {}
+ mapid = dummy.build_id(maplist[count], mapset, None)
+ row["id"] = mapid
maplist[count] = row
# Read the map list from file
if file:
fd = open(file, "r")
@@ -145,69 +161,73 @@
mapname = line_list[0].strip()
row = {}
- if start_time_in_file and end_time_in_file:
- row["start"] = line_list[1].strip()
- row["end"] = line_list[2].strip()
- if start_time_in_file and not end_time_in_file:
- row["id"] = dummy.build_id(mapname, mapset)
+ if start_time_in_file and end_time_in_file:
+ row["start"] = line_list[1].strip()
+ row["end"] = line_list[2].strip()
+ if start_time_in_file and not end_time_in_file:
+ row["id"] = dummy.build_id(mapname, mapset)
maplist.append(row)
num_maps = len(maplist)
map_object_list = []
statement = ""
core.message(_("Gathering map informations"))
- core.percent(count, num_maps, 1)
+ core.percent(count, num_maps, 1)
# Get a new instance of the map type
map = dataset_factory(type, maplist[count]["id"])
# Use the time data from file
- if maplist[count].has_key("start"):
+ if "start" in maplist[count]:
start = maplist[count]["start"]
- if maplist[count].has_key("end"):
+ if "end" in maplist[count]:
end = maplist[count]["end"]
is_in_db = False
# Put the map into the database
- if map.is_in_db(dbif) == False:
+ if not map.is_in_db(dbif):
is_in_db = False
# Break in case no valid time is provided
- if start == "" or start == None:
+ if start == "" or start is None:
dbif.close()
if map.get_layer():
- core.fatal(_("Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set.") % \
- (map.get_type(), map.get_map_id(), map.get_layer() ))
- else:
- core.fatal(_("Unable to register %s map <%s>. The map has no valid time and the start time is not set.") % \
- (map.get_type(), map.get_map_id() ))
- if unit:
+ core.fatal(_("Unable to register %s map <%s> with layer %s. "
+ "The map has no valid time and the start time is not set.") %
+ (map.get_type(), map.get_map_id(), map.get_layer()))
+ else:
+ core.fatal(_("Unable to register %s map <%s>. The map has no valid"
+ " time and the start time is not set.") %
+ (map.get_type(), map.get_map_id()))
+ if unit:
map.set_time_to_relative()
else:
map.set_time_to_absolute()
else:
is_in_db = True
- if core.overwrite == False:
- continue
+ if not core.overwrite:
+ continue
map.select(dbif)
if name and map.get_temporal_type() != sp.get_temporal_type():
dbif.close()
if map.get_layer():
- core.fatal(_("Unable to register %s map <%s> with layer. The temporal types are different.") % \
- (map.get_type(), map.get_map_id(), map.get_layer()))
- else:
- core.fatal(_("Unable to register %s map <%s>. The temporal types are different.") % \
- (map.get_type(), map.get_map_id()))
+ core.fatal(_("Unable to register %s map <%s> with layer. "
+ "The temporal types are different.") %
+ else:
+ core.fatal(_("Unable to register %s map <%s>. "
# Load the data from the grass file database
map.load()
@@ -217,21 +237,25 @@
# In case the time is in the input file we ignore the increment counter
if start_time_in_file:
count = 1
- assign_valid_time_to_map(ttype=map.get_temporal_type(), map=map, start=start, end=end, unit=unit, increment=increment, mult=count, interval=interval)
+ assign_valid_time_to_map(ttype=map.get_temporal_type(),
+ map=map, start=start, end=end, unit=unit,
+ increment=increment, mult=count,
+ interval=interval)
if is_in_db:
- # Gather the SQL update statement
- statement += map.update_all(dbif=dbif, execute=False)
+ # Gather the SQL update statement
+ statement += map.update_all(dbif=dbif, execute=False)
else:
- # Gather the SQL insert statement
- statement += map.insert(dbif=dbif, execute=False)
+ # Gather the SQL insert statement
+ statement += map.insert(dbif=dbif, execute=False)
# Sqlite3 performace better for huge datasets when committing in small chunks
if dbmi.__name__ == "sqlite3":
if count % 100 == 0:
- if statement != None and statement != "":
- core.message(_("Registering maps in the temporal database"))
- dbif.execute_transaction(statement)
+ if statement is not None and statement != "":
+ core.message(_("Registering maps in the temporal database")
+ dbif.execute_transaction(statement)
statement = ""
# Store the maps in a list to register in a space time dataset
@@ -240,7 +264,7 @@
core.percent(num_maps, num_maps, 1)
core.message(_("Register maps in the temporal database"))
@@ -251,63 +275,80 @@
num_maps = len(map_object_list)
core.message(_("Register maps in the space time raster dataset"))
for map in map_object_list:
- sp.register_map(map=map, dbif=dbif)
+ sp.register_map(map=map, dbif=dbif)
count += 1
# Update the space time tables
if name:
core.message(_("Update space time raster dataset"))
- sp.update_from_registered_maps(dbif)
+ sp.update_from_registered_maps(dbif)
if connect == True:
dbif.close()
def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, interval=False):
"""!Assign the valid time to a map dataset
- @param ttype: The temporal type which should be assigned and which the time format is of
+ @param ttype: The temporal type which should be assigned
+ and which the time format is of
@param map: A map dataset object derived from abstract_map_dataset
- @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer 1)
+ days, hours, minutes, seconds
+ weeks, months, years; format relative is integer 1)
@param multi: A multiplier for the increment
if ttype == "absolute":
start_time = string_to_datetime(start)
- if start_time == None:
+ if start_time is None:
dbif.close()
- core.fatal(_("Unable to convert string \"%s\"into a datetime object")%(start))
+ core.fatal(_("Unable to convert string \"%s\"into a "
+ "datetime object") % (start))
end_time = None
if end:
end_time = string_to_datetime(end)
- if end_time == None:
+ if end_time is None:
dbif.close()
- core.fatal(_("Unable to convert string \"%s\"into a datetime object")%(end))
+ "datetime object") % (end))
# Add the increment
if increment:
- start_time = increment_datetime_by_string(start_time, increment, mult)
- core.fatal(_("Error in increment computation"))
+ start_time = increment_datetime_by_string(
+ start_time, increment, mult)
+ core.fatal(_("Error in increment computation"))
if interval:
- end_time = increment_datetime_by_string(start_time, increment, 1)
- if map.get_layer():
- core.verbose(_("Set absolute valid time for map <%s> with layer %s to %s - %s") % (map.get_map_id(), map.get_layer(), str(start_time), str(end_time)))
+ end_time = increment_datetime_by_string(
+ start_time, increment, 1)
+ if map.get_layer():
+ core.verbose(_("Set absolute valid time for map <%(id)s> with "
+ "layer %(layer)s to %(start)s - %(end)s") %
+ {'id': map.get_map_id(), 'layer': map.get_layer(),
+ 'start': str(start_time), 'end': str(end_time)})
else:
- core.verbose(_("Set absolute valid time for map <%s> to %s - %s") % (map.get_map_id(), str(start_time), str(end_time)))
+ core.verbose(_("Set absolute valid time for map <%s> to %s - %s") %
+ (map.get_map_id(), str(start_time), str(end_time)))
map.set_absolute_time(start_time, end_time, None)
else:
start_time = int(start)
@@ -321,19 +362,26 @@
if interval:
end_time = start_time + int(increment)
- core.verbose(_("Set relative valid time for map <%s> with layer %s to %i - %s with unit %s") % (map.get_map_id(), map.get_layer(), start_time, str(end_time), unit))
+ core.verbose(_("Set relative valid time for map <%s> with layer %s "
+ "to %i - %s with unit %s") %
+ (map.get_map_id(), map.get_layer(), start_time,
+ str(end_time), unit))
else:
- core.verbose(_("Set relative valid time for map <%s> to %i - %s with unit %s") % (map.get_map_id(), start_time, str(end_time), unit))
+ core.verbose(_("Set relative valid time for map <%s> to %i - %s "
+ "with unit %s") % (map.get_map_id(), start_time,
map.set_relative_time(start_time, end_time, unit)
def dataset_factory(type, id):
"""!A factory functions to create space time or map datasets
- @param type: the dataset type: rast or raster, rast3d, vect or vector, strds, str3ds, stvds
+ @param type: the dataset type: rast or raster, rast3d,
+ vect or vector, strds, str3ds, stvds
@param id: The id of the dataset ("name at mapset")
if type == "strds":
@@ -346,7 +394,7 @@
sp = raster_dataset(id)
sp = raster3d_dataset(id)
sp = vector_dataset(id)
else:
core.error(_("Unknown dataset type: %s") % type)
@@ -356,24 +404,32 @@
def list_maps_of_stds(type, input, columns, order, where, separator, method, header):
"""! List the maps of a space time dataset using diffetent methods
@param type: The type of the maps raster, raster3d or vector
@param input: Name of a space time raster dataset
- @param columns: A comma separated list of columns to be printed to stdout
- @param order: A comma separated list of columns to order the space time dataset by category
- @param where: A where statement for selected listing without "WHERE" e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
+ @param columns: A comma separated list of columns to be printed to stdout
+ @param order: A comma separated list of columns to order the
+ space time dataset by category
+ @param where: A where statement for selected listing without "WHERE"
+ e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
@param separator: The field separator character between the columns
- @param method: String identifier to select a method out of cols,comma,delta or deltagaps
+ @param method: String identifier to select a method out of cols,
+ comma,delta or deltagaps
* "cols": Print preselected columns specified by columns
* "comma": Print the map ids (name at mapset) as comma separated string
- * "delta": Print the map ids (name at mapset) with start time, end time, relative length of intervals and the relative distance to the begin
- * "deltagaps": Same as "delta" with additional listing of gaps. Gaps can be simply identified as the id is "None"
- * "gran": List map using the granularity of the space time dataset, columns are identical to deltagaps
- @param header: Set True to print column names
+ * "delta": Print the map ids (name at mapset) with start time,
+ end time, relative length of intervals and the relative
+ distance to the begin
+ * "deltagaps": Same as "delta" with additional listing of gaps.
+ Gaps can be simply identified as the id is "None"
+ * "gran": List map using the granularity of the space time dataset,
+ columns are identical to deltagaps
+ @param header: Set True to print column names
if input.find("@") >= 0:
id = input
@@ -381,21 +437,21 @@
id = input + "@" + mapset
sp = dataset_factory(type, id)
- if sp.is_in_db() == False:
+ if not sp.is_in_db():
core.fatal(_("Dataset <%s> not found in temporal database") % (id))
sp.select()
- if separator == None or separator == "":
+ if separator is None or separator == "":
separator = "\t"
# This method expects a list of objects for gap detection
if method == "delta" or method == "deltagaps" or method == "gran":
- if type == "stvds":
- columns = "id,name,layer,mapset,start_time,end_time"
- else:
- columns = "id,name,mapset,start_time,end_time"
+ if type == "stvds":
+ columns = "id,name,layer,mapset,start_time,end_time"
+ else:
+ columns = "id,name,mapset,start_time,end_time"
if method == "deltagaps":
maps = sp.get_registered_maps_as_objects_with_gaps(where, None)
elif method == "delta":
@@ -405,15 +461,15 @@
if header:
string = ""
- string += "%s%s" % ("id", separator)
- string += "%s%s" % ("name", separator)
+ string += "%s%s" % ("id", separator)
+ string += "%s%s" % ("name", separator)
if type == "stvds":
- string += "%s%s" % ("layer", separator)
- string += "%s%s" % ("mapset", separator)
+ string += "%s%s" % ("layer", separator)
+ string += "%s%s" % ("mapset", separator)
string += "%s%s" % ("start_time", separator)
string += "%s%s" % ("end_time", separator)
string += "%s%s" % ("interval_length", separator)
- string += "%s" % ("distance_from_begin")
+ string += "%s" % ("distance_from_begin")
if maps and len(maps) > 0:
@@ -431,7 +487,7 @@
start, end = map.get_valid_time()
if end:
- delta = end -start
+ delta = end - start
else:
delta = None
delta_first = start - first_time
@@ -444,13 +500,13 @@
string = ""
string += "%s%s" % (map.get_id(), separator)
string += "%s%s" % (map.get_name(), separator)
- string += "%s%s" % (map.get_layer(), separator)
+ string += "%s%s" % (map.get_layer(), separator)
string += "%s%s" % (map.get_mapset(), separator)
string += "%s%s" % (start, separator)
string += "%s%s" % (end, separator)
string += "%s%s" % (delta, separator)
- string += "%s" % (delta_first)
+ string += "%s" % (delta_first)
print string
else:
@@ -497,30 +553,35 @@
else:
output += str(col)
count += 1
print output
def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header, separator, method, spatial=False):
- """! Sample the input space time datasets with a sample space time dataset and print the result to stdout
+ """!Sample the input space time datasets with a sample
+ space time dataset and print the result to stdout
- In case multiple maps are located in the current granule, the map names are separated by comma.
- In case a layer is present, the names map ids are extended in this form: name:layer at mapset
+ In case multiple maps are located in the current granule,
+ the map names are separated by comma.
+ In case a layer is present, the names map ids are extended
+ in this form: name:layer at mapset
Attention: Do not use the comma as separator
@param intype: Type of the input space time dataset (strds, stvds or str3ds)
@param samtype: Type of the sample space time dataset (strds, stvds or str3ds)
@param input: Name of a space time dataset
@param sampler: Name of a space time dataset used for temporal sampling
- @param method: The method to be used for temporal sampling (start,during,contain,overlap,equal)
+ @param method: The method to be used for temporal sampling
+ (start,during,contain,overlap,equal)
@param spatial: Perform spatial overlapping check
input_list = inputs.split(",")
sts = []
@@ -554,9 +615,9 @@
sst.select(dbif)
- if separator == None or separator == "" or separator.find(",") >= 0:
+ if separator is None or separator == "" or separator.find(",") >= 0:
separator = " | "
mapmatrizes = []
for st in sts:
mapmatrix = st.sample_by_dataset(sst, method, spatial, dbif)
@@ -573,7 +634,7 @@
first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
@@ -590,7 +651,7 @@
mapnames += ",%s" % str(sample.get_id())
count += 1
mapname_list.append(mapnames)
entry = mapmatrizes[0][i]
map = entry["granule"]
@@ -613,8 +674,7 @@
print string
dbif.close()
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -6,6 +6,8 @@
Usage:
+ at code
>>> extent = tgis.RasterSpatialExtent(
... ident="raster at PERMANENT", north=90, south=90, east=180, west=180,
@@ -26,6 +28,7 @@
... ident="stvds at PERMANENT", north=90, south=90, east=180, west=180,
... top=100, bottom=-20)
+ at endcode
(C) 2008-2011 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -43,8 +46,11 @@
This class implements a three dimensional axis aligned bounding box
and functions to compute topological relationships
- >>> extent = tgis.SpatialExtent(table="raster_spatial_extent",
+ Usage:
+ @code
+ >>> extent = SpatialExtent(table="raster_spatial_extent",
... ident="soil at PERMANENT", north=90, south=90, east=180, west=180,
>>> extent.id
@@ -76,6 +82,8 @@
west=180.0
top=100.0
bottom=-20.0
+ @endcode
def __init__(self, table=None, ident=None, north=None, south=None,
east=None, west=None, top=None, bottom=None, proj="XY"):
@@ -98,7 +106,8 @@
if self.get_projection() != extent.get_projection():
- core.error(_("Projections are different. Unable to compute overlapping_2d for spatial extents"))
+ core.error(_("Projections are different. Unable to compute "
+ "overlapping_2d for spatial extents"))
return False
N = extent.get_north()
@@ -142,11 +151,14 @@
Usage:
- >>> A = tgis.SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
- >>> B = tgis.SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ @code
+ >>> A = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
>>> A.overlapping(B)
True
+ @endcode
if not self.overlapping_2d(extent):
@@ -164,8 +176,8 @@
return True
def intersect_2d(self, extent):
- """!Return the two dimensional intersection as spatial_extent object or None
- in case no intersection was found.
+ """!Return the two dimensional intersection as spatial_extent
+ object or None in case no intersection was found.
@@ -211,14 +223,15 @@
return new
def intersect(self, extent):
- """!Return the three dimensional intersection as spatial_extent object or None
+ """!Return the three dimensional intersection as spatial_extent
Usage:
+ @code
>>> C = A.intersect(B)
>>> C.print_info()
@@ -228,7 +241,7 @@
| West:....................... 10.0
| Top:........................ 50.0
| Bottom:..................... -50.0
- >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -238,7 +251,7 @@
- >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -248,7 +261,7 @@
| West:....................... 30.0
- >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -258,7 +271,7 @@
| Bottom:..................... -30.0
- >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -268,6 +281,8 @@
| Top:........................ 30.0
+ @endcode
if not self.overlapping(extent):
@@ -295,15 +310,19 @@
return new
def is_in_2d(self, extent):
- """Check two dimensional if the self is located in extent
+ """!Check two dimensional if the self is located in extent
+ @verbatim
_____
|A _ |
| |_| |
|_____|B
+ @endverbatim
- core.error(_("Projections are different. Unable to compute is_in_2d for spatial extents"))
+ "is_in_2d for spatial extents"))
return False
eN = extent.get_north()
@@ -338,17 +357,20 @@
return True
def is_in(self, extent):
- """Check three dimensional if the self is located in extent
+ """!Check three dimensional if the self is located in extent
Usage:
- >>> import grass.temporal as tgis
- >>> A = tgis.SpatialExtent(north=79, south=21, east=59, west=11, bottom=-49, top=49)
+ @code
+ >>> A = SpatialExtent(north=79, south=21, east=59, west=11, bottom=-49, top=49)
>>> A.is_in(B)
True
>>> B.is_in(A)
False
+ @endcode
if not self.is_in_2d(extent):
return False
@@ -367,18 +389,19 @@
return True
def contain_2d(self, extent):
- """Check two dimensional if self contains extent """
+ """!Check two dimensional if self contains extent """
return extent.is_in_2d(self)
def contain(self, extent):
- """Check three dimensional if self contains extent """
+ """!Check three dimensional if self contains extent """
return extent.is_in(self)
def equivalent_2d(self, extent):
- """Check two dimensional if self is equivalent to extent """
+ """!Check two dimensional if self is equivalent to extent """
- core.error(_("Projections are different. Unable to compute equivalent_2d for spatial extents"))
+ "equivalent_2d for spatial extents"))
return False
@@ -413,7 +436,7 @@
return True
def equivalent(self, extent):
- """Check three dimensional if self is equivalent to extent """
+ """!Check three dimensional if self is equivalent to extent """
if not self.equivalent_2d(extent):
return False
@@ -432,7 +455,9 @@
return True
def cover_2d(self, extent):
- """Return True if two dimensional self covers extent
+ """!Return True if two dimensional self covers extent
+ @verbatim
_____ _____ _____ _____
|A __| |__ A| |A | B| |B | A|
| |B | | B| | | |__| |__| |
@@ -447,6 +472,8 @@
|A|B | |_____|A |A|B|A| |_____|A
| | | |B | | | | | |_____|B
|_|___| |_____| |_|_|_| |_____|A
+ @endverbatim
The following cases are excluded:
* contain
@@ -513,7 +540,7 @@
return True
def cover(self, extent):
- """Return True if three dimensional self covers extent
+ """!Return True if three dimensional self covers extent
* contain
@@ -598,22 +625,27 @@
return True
def covered_2d(self, extent):
- """Check two dimensional if self is covered by extent """
+ """!Check two dimensional if self is covered by extent """
return extent.cover_2d(self)
def covered(self, extent):
- """Check three dimensional if self is covered by extent """
+ """!Check three dimensional if self is covered by extent """
return extent.cover(self)
def overlap_2d(self, extent):
- """Return True if the two dimensional extents overlap. Code is lend from wind_overlap.c in lib/gis
+ """!Return True if the two dimensional extents overlap. Code is
+ lend from wind_overlap.c in lib/gis
+ @verbatim
_____
|A __|__
| | | B|
|__|__| |
|_____|
+ @endverbatim
* contain
@@ -668,7 +700,7 @@
return True
def overlap(self, extent):
- """Return True if the three dimensional extents overlap
+ """!Return True if the three dimensional extents overlap
* contain
@@ -731,22 +763,26 @@
return True
def meet_2d(self, extent):
- """ Check if self and extent meet each other in two dimensions
+ """!Check if self and extent meet each other in two dimensions
+ @verbatim
| A | B | | B | A |
|_____| | | | |
|_____| |_____|_____|
- ___
- | A |
- |___| _____
- | B | | B |
- |_____| |_____|_
- | A |
- |_____|
+ ___
+ | A |
+ |___| _____
+ | B | | B |
+ |_____| |_____|_
+ | A |
+ |_____|
+ @endverbatim
@@ -805,7 +841,7 @@
return True
def meet(self, extent):
- """ Check if self and extent meet each other in three dimensions"""
+ """!Check if self and extent meet each other in three dimensions"""
eS = extent.get_south()
eE = extent.get_east()
@@ -880,7 +916,7 @@
return True
def disjoint_2d(self, extent):
- """Return True if the two dimensional extents are disjoint
+ """!Return True if the two dimensional extents are disjoint
if self.overlapping_2d(extent) or self.meet_2d(extent):
@@ -888,7 +924,7 @@
return True
def disjoint(self, extent):
- """Return True if the three dimensional extents are disjoint
+ """!Return True if the three dimensional extents are disjoint
if self.overlapping(extent) or self.meet(extent):
@@ -896,7 +932,7 @@
return True
def spatial_relation_2d(self, extent):
- """Returns the two dimensional spatial relation between self and extent
+ """!Returns the two dimensional spatial relation between self and extent
Spatial relations are:
* disjoint
@@ -931,7 +967,7 @@
return "unknown"
def spatial_relation(self, extent):
- """Returns the three dimensional spatial relation between self and extent
+ """!Returns the three dimensional spatial relation between self and extent
* disjoint
@@ -946,19 +982,20 @@
Usage:
+ @code
>>> A.spatial_relation(B)
'equivalent'
>>> B.spatial_relation(A)
'equivalent'
- >>> B = tgis.SpatialExtent(north=70, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=70, south=20, east=60, west=10, bottom=-50, top=50)
>>> A.spatial_relation_2d(B)
'cover'
'cover'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=70, south=30, east=60, west=10, bottom=-50, top=50)
'cover'
@@ -967,135 +1004,137 @@
'covered'
'covered'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=50)
'cover'
>>> B.spatial_relation_2d(A)
'covered'
'cover'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=20, bottom=-50, top=50)
'covered'
'contain'
'cover'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=50)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=50)
'cover'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=40)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=40)
'contain'
'in'
- >>> B = tgis.SpatialExtent(north=90, south=30, east=50, west=20, bottom=-40, top=40)
+ >>> B = SpatialExtent(north=90, south=30, east=50, west=20, bottom=-40, top=40)
'overlap'
'overlap'
- >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
+ >>> B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
'in'
'overlap'
- >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
+ >>> B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
'overlap'
- >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
+ >>> B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
'in'
- >>> A = tgis.SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
- >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> A = SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=60, south=20, east=60, west=10, bottom=-50, top=50)
'meet'
'meet'
- >>> A = tgis.SpatialExtent(north=60, south=40, east=60, west=10, bottom=-50, top=50)
- >>> B = tgis.SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
+ >>> A = SpatialExtent(north=60, south=40, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
'meet'
'meet'
- >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=40, bottom=-50, top=50)
- >>> B = tgis.SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
+ >>> A = SpatialExtent(north=80, south=40, east=60, west=40, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
'meet'
'meet'
- >>> A = tgis.SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
- >>> B = tgis.SpatialExtent(north=90, south=30, east=60, west=40, bottom=-50, top=50)
+ >>> A = SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=90, south=30, east=60, west=40, bottom=-50, top=50)
'meet'
'meet'
- >>> B = tgis.SpatialExtent(north=70, south=50, east=60, west=40, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=70, south=50, east=60, west=40, bottom=-50, top=50)
'meet'
'meet'
- >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=40, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=60, south=20, east=60, west=40, bottom=-50, top=50)
'meet'
'meet'
- >>> B = tgis.SpatialExtent(north=40, south=20, east=60, west=40, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=40, south=20, east=60, west=40, bottom=-50, top=50)
'disjoint'
'disjoint'
- >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=40, bottom=-60, top=60)
+ >>> B = SpatialExtent(north=60, south=20, east=60, west=40, bottom=-60, top=60)
'meet'
- >>> B = tgis.SpatialExtent(north=90, south=30, east=60, west=40, bottom=-40, top=40)
+ >>> B = SpatialExtent(north=90, south=30, east=60, west=40, bottom=-40, top=40)
'meet'
- >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
- >>> B = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+ >>> A = SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+ >>> B = SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
'meet'
- >>> B = tgis.SpatialExtent(north=80, south=50, east=60, west=30, bottom=-50, top=0)
+ >>> B = SpatialExtent(north=80, south=50, east=60, west=30, bottom=-50, top=0)
'meet'
- >>> B = tgis.SpatialExtent(north=70, south=50, east=50, west=30, bottom=-50, top=0)
+ >>> B = SpatialExtent(north=70, south=50, east=50, west=30, bottom=-50, top=0)
'meet'
- >>> B = tgis.SpatialExtent(north=90, south=30, east=70, west=10, bottom=-50, top=0)
+ >>> B = SpatialExtent(north=90, south=30, east=70, west=10, bottom=-50, top=0)
'meet'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=0)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=0)
'meet'
- >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
- >>> B = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+ >>> A = SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+ >>> B = SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
'meet'
- >>> B = tgis.SpatialExtent(north=80, south=50, east=60, west=30, bottom=0, top=50)
+ >>> B = SpatialExtent(north=80, south=50, east=60, west=30, bottom=0, top=50)
'meet'
- >>> B = tgis.SpatialExtent(north=70, south=50, east=50, west=30, bottom=0, top=50)
+ >>> B = SpatialExtent(north=70, south=50, east=50, west=30, bottom=0, top=50)
'meet'
- >>> B = tgis.SpatialExtent(north=90, south=30, east=70, west=10, bottom=0, top=50)
+ >>> B = SpatialExtent(north=90, south=30, east=70, west=10, bottom=0, top=50)
'meet'
- >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=0, top=50)
+ >>> B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=0, top=50)
'meet'
+ @endverbatim
if self.equivalent(extent):
@@ -1118,7 +1157,7 @@
return "unknown"
def set_spatial_extent(self, north, south, east, west, top, bottom):
- """Set the spatial extent"""
+ """!Set the spatial extent"""
self.set_north(north)
self.set_south(south)
@@ -1128,7 +1167,7 @@
self.set_bottom(bottom)
def set_projection(self, proj):
- """Set the projection of the spatial extent it should be XY or LL.
+ """!Set the projection of the spatial extent it should be XY or LL.
As default the projection is XY
if proj is None or (proj != "XY" and proj != "LL"):
@@ -1144,54 +1183,54 @@
self.set_west(west)
def set_id(self, ident):
- """Convenient method to set the unique identifier (primary key)"""
+ """!Convenient method to set the unique identifier (primary key)"""
self.ident = ident
self.D["id"] = ident
def set_north(self, north):
- """Set the northern edge of the map"""
+ """!Set the northern edge of the map"""
if north is not None:
self.D["north"] = float(north)
else:
self.D["north"] = None
def set_south(self, south):
- """Set the southern edge of the map"""
+ """!Set the southern edge of the map"""
if south is not None:
self.D["south"] = float(south)
else:
self.D["south"] = None
def set_west(self, west):
- """Set the western edge of the map"""
+ """!Set the western edge of the map"""
if west is not None:
self.D["west"] = float(west)
else:
self.D["west"] = None
def set_east(self, east):
- """Set the eastern edge of the map"""
+ """!Set the eastern edge of the map"""
if east is not None:
self.D["east"] = float(east)
else:
self.D["east"] = None
def set_top(self, top):
- """Set the top edge of the map"""
+ """!Set the top edge of the map"""
if top is not None:
self.D["top"] = float(top)
else:
self.D["top"] = None
def set_bottom(self, bottom):
- """Set the bottom edge of the map"""
+ """!Set the bottom edge of the map"""
if bottom is not None:
self.D["bottom"] = float(bottom)
else:
self.D["bottom"] = None
def get_id(self):
- """Convenient method to get the unique identifier (primary key)
+ """!Convenient method to get the unique identifier (primary key)
@return None if not found
if "id" in self.D:
@@ -1200,15 +1239,16 @@
return None
def get_projection(self):
- """Get the projection of the spatial extent"""
+ """!Get the projection of the spatial extent"""
return self.D["proj"]
def get_volume(self):
- """Compute the volume of the extent, in case z is zero
+ """!Compute the volume of the extent, in case z is zero
(top == bottom or top - bottom = 1) the area is returned"""
if self.get_projection() == "LL":
- core.error(_("Volume computation is not supported for LL projections"))
+ core.error(_("Volume computation is not supported "
+ "for LL projections"))
area = self.get_area()
@@ -1222,10 +1262,11 @@
return area * z
def get_area(self):
- """Compute the area of the extent, extent in z direction is ignored"""
+ """!Compute the area of the extent, extent in z direction is ignored"""
- core.error(_("Area computation is not supported for LL projections"))
+ core.error(_("Area computation is not supported "
bbox = self.get_spatial_extent()
@@ -1235,18 +1276,20 @@
return x * y
def get_spatial_extent(self):
- """Return a tuple (north, south, east, west, top, bottom) of the spatial extent"""
+ """!Return a tuple (north, south, east, west, top, bottom)
+ of the spatial extent"""
return (
- self.get_north(), self.get_south, self.get_east(), self.get_west(),
- self.get_top(), self.get_bottom())
+ self.north, self.south, self.east, self.west,
+ self.top, self.bottom)
def get_spatial_extent_2d(self):
- """Return a tuple (north, south, east, west,) of the 2d spatial extent"""
- return (self.get_north(), self.get_south, self.get_east(), self.get_west())
+ """!Return a tuple (north, south, east, west,) of the 2d spatial extent
+ return (self.north, self.south, self.east, self.west)
def get_north(self):
- """Get the northern edge of the map
+ """!Get the northern edge of the map
@return None if not found"""
if "north" in self.D:
return self.D["north"]
@@ -1254,7 +1297,7 @@
return None
def get_south(self):
- """Get the southern edge of the map
+ """!Get the southern edge of the map
if "south" in self.D:
return self.D["south"]
@@ -1262,7 +1305,7 @@
return None
def get_east(self):
- """Get the eastern edge of the map
+ """!Get the eastern edge of the map
if "east" in self.D:
return self.D["east"]
@@ -1270,7 +1313,7 @@
return None
def get_west(self):
- """Get the western edge of the map
+ """!Get the western edge of the map
if "west" in self.D:
return self.D["west"]
@@ -1278,7 +1321,7 @@
return None
def get_top(self):
- """Get the top edge of the map
+ """!Get the top edge of the map
if "top" in self.D:
return self.D["top"]
@@ -1286,7 +1329,7 @@
return None
def get_bottom(self):
- """Get the bottom edge of the map
+ """!Get the bottom edge of the map
if "bottom" in self.D:
return self.D["bottom"]
@@ -1302,7 +1345,7 @@
bottom= property(fget=get_bottom, fset=set_bottom)
def print_info(self):
- """Print information about this class in human readable style"""
+ """!Print information about this class in human readable style"""
# 0123456789012345678901234567890
print " +-------------------- Spatial extent ----------------------------------------+"
print " | North:...................... " + str(self.get_north())
@@ -1325,37 +1368,38 @@
class RasterSpatialExtent(SpatialExtent):
- def __init__(self, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
+ def __init__(self, ident=None, north=None, south=None, east=None,
+ west=None, top=None, bottom=None):
SpatialExtent.__init__(self, "raster_spatial_extent",
ident, north, south, east, west, top, bottom)
class Raster3DSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "raster3d_spatial_extent",
class VectorSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "vector_spatial_extent",
class STRDSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "strds_spatial_extent",
class STR3DSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "str3ds_spatial_extent",
class STVDSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "stvds_spatial_extent",
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/stds_export.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -14,9 +14,9 @@
compression="gzip"
workdir="/tmp"
where=None
-_format="GTiff"
-_type="strds"
-tgis.export_stds(input, output, compression, workdir, where, _format, _type)
+format_="GTiff"
+type_="strds"
+tgis.export_stds(input, output, compression, workdir, where, format_, type_)
@endcode
@@ -39,7 +39,7 @@
metadata_file_name = "metadata.txt"
read_file_name = "readme.txt"
list_file_name = "list.txt"
-tmp_tar_file_name = "archive"
+tmp_tar_file_name = "archive"
# This global variable is for unique vector map export,
# since single vector maps may have several layer
@@ -47,6 +47,8 @@
exported_maps = {}
def _export_raster_maps_as_geotiff(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -59,40 +61,46 @@
end = start
string = "%s%s%s%s%s\n" % (name, fs, start, fs, end)
# Write the filename, the start_time and the end_time
- list_file.write(string)
+ list_file.write(string)
# Export the raster map with r.out.gdal as tif
out_name = name + ".tif"
if datatype == "CELL":
nodata = max_val + 1
if nodata < 256 and min_val >= 0:
- gdal_type = "Byte"
+ gdal_type = "Byte"
elif nodata < 65536 and min_val >= 0:
- gdal_type = "UInt16"
+ gdal_type = "UInt16"
elif min_val >= 0:
- gdal_type = "UInt32"
+ gdal_type = "UInt32"
else:
- gdal_type = "Int32"
- ret = core.run_command("r.out.gdal", flags="c", input=name, output=out_name, nodata=nodata, type=gdal_type, format="GTiff")
+ gdal_type = "Int32"
+ ret = core.run_command("r.out.gdal", flags="c", input=name,
+ output=out_name, nodata=nodata,
+ type=gdal_type, format="GTiff")
else:
- ret = core.run_command("r.out.gdal", flags="c", input=name, output=out_name, format="GTiff")
+ input=name, output=out_name, format="GTiff")
if ret != 0:
shutil.rmtree(new_cwd)
tar.close()
core.fatal(_("Unable to export raster map <%s>" % name))
tar.add(out_name)
- # Export the color rules
+ # Export the color rules
out_name = name + ".color"
ret = core.run_command("r.colors.out", map=name, rules=out_name)
if ret != 0:
tar.close()
- core.fatal(_("Unable to export color rules for raster map <%s> r.out.gdal" % name))
+ core.fatal(_("Unable to export color rules for raster "
+ "map <%s> r.out.gdal" % name))
tar.add(out_name)
def _export_raster_maps(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -102,17 +110,20 @@
end = start
# Export the raster map with r.pack
ret = core.run_command("r.pack", input=name, flags="c")
if ret != 0:
tar.close()
- core.fatal(_("Unable to export raster map <%s> with r.pack" % name))
+ core.fatal(_("Unable to export raster map <%s> with r.pack" %
+ name))
tar.add(name + ".pack")
def _export_vector_maps_as_gml(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -125,29 +136,33 @@
end = start
# Export the vector map with v.out.ogr
- ret = core.run_command("v.out.ogr", input=name, dsn=(name + ".xml"), layer=layer, format="GML")
+ ret = core.run_command("v.out.ogr", input=name,
+ dsn=(name + ".xml"), layer=layer, format="GML")
if ret != 0:
tar.close()
- core.fatal(_("Unable to export vector map <%s> as GML with v.out.ogr" % name))
+ core.fatal(_("Unable to export vector map <%s> as "
+ "GML with v.out.ogr" % name))
tar.add(name + ".xml")
tar.add(name + ".xsd")
def _export_vector_maps(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
start = row["start_time"]
end = row["end_time"]
layer = row["layer"]
# Export unique maps only
if name in exported_maps:
continue
if not layer:
layer = 1
if not end:
@@ -160,13 +175,16 @@
if ret != 0:
tar.close()
- core.fatal(_("Unable to export vector map <%s> with v.pack" % name))
+ core.fatal(_("Unable to export vector map <%s> with v.pack" %
+ name))
exported_maps[name] = name
def _export_raster3d_maps(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -176,172 +194,192 @@
end = start
# Export the raster map with r3.pack
ret = core.run_command("r3.pack", input=name, flags="c")
if ret != 0:
tar.close()
- core.fatal(_("Unable to export raster map <%s> with r3.pack" % name))
+ core.fatal(_("Unable to export raster map <%s> with r3.pack" %
+ name))
-def export_stds(input, output, compression, workdir, where, _format="pack", _type="strds"):
- !Export space time datasets as tar archive with optional compression
- This method should be used to export space time datasets of type raster and vector
- as tar archive that can be reimported with the method import_stds().
- @param input The name of the space time dataset to export
- @param output The name of the archive file
- @param compression The compression of the archive file:
- * "no" no compression
- * "gzip" GNU zip compression
- * "bzip2" Bzip compression
- @param workdir The working directory used for extraction and packing
- @param where The temporal WHERE SQL statement to select a subset of maps from the space time dataset
- @param _format The export format:
- * "GTiff" Geotiff format, only for raster maps
- * "pack" The GRASS raster, 3D raster or vector Pack format, this is the default setting
- * "GML" GML file export format, only for vector maps, v.out.ogr export option
- @param type The space time dataset type
- * "strds" Space time raster dataset
- * "str3ds" Space time 3D raster dataset
- * "stvds" Space time vector dataset
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = dataset_factory(_type, id)
- core.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+def export_stds(input, output, compression, workdir, where, format_="pack",
+ type_="strds"):
+ !Export space time datasets as tar archive with optional compression
- # Save current working directory path
- old_cwd = os.getcwd()
+ This method should be used to export space time datasets
+ of type raster and vector as tar archive that can be reimported
+ with the method import_stds().
- # Create the temporary directory and jump into it
- new_cwd = tempfile.mkdtemp(dir=workdir)
- os.chdir(new_cwd)
+ @param input: The name of the space time dataset to export
+ @param output: The name of the archive file
+ @param compression: The compression of the archive file:
+ * "no" no compression
+ * "gzip" GNU zip compression
+ * "bzip2" Bzip compression
+ @param workdir: The working directory used for extraction and packing
+ @param where: The temporal WHERE SQL statement to select a subset
+ of maps from the space time dataset
+ @param format:_ The export format:
+ * "GTiff" Geotiff format, only for raster maps
+ * "pack" The GRASS raster, 3D raster or vector Pack format,
+ this is the default setting
+ * "GML" GML file export format, only for vector maps,
+ v.out.ogr export option
+ @param type_: The space time dataset type
+ * "strds" Space time raster dataset
+ * "str3ds" Space time 3D raster dataset
+ * "stvds" Space time vector dataset
- sp.select()
- if _type == "strds":
- columns = "name,start_time,end_time,min,max,datatype"
- elif _type == "stvds":
- columns = "name,start_time,end_time,layer"
- else:
- columns = "name,start_time,end_time"
- rows = sp.get_registered_maps(columns, where, "start_time", None)
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
- if compression == "gzip":
- flag = "w:gz"
- elif compression == "bzip2":
- flag = "w:bz2"
- else:
- flag = "w:"
+ sp = dataset_factory(type_, id)
- # Open the tar archive to add the files
- tar = tarfile.open(tmp_tar_file_name, flag)
- list_file = open(list_file_name, "w")
+ if sp.is_in_db() == False:
+ core.fatal(_("Space time %s dataset <%s> not found") % (
+ sp.get_new_map_instance(None).get_type(), id))
- fs = "|"
+ # Save current working directory path
+ old_cwd = os.getcwd()
- if rows:
- if _format == "GTiff":
- _export_raster_maps_as_geotiff(rows, tar, list_file, new_cwd, fs)
- else:
- _export_raster_maps(rows, tar, list_file, new_cwd, fs)
- if _format == "GML":
- _export_vector_maps_as_gml(rows, tar, list_file, new_cwd, fs)
- else:
- _export_vector_maps(rows, tar, list_file, new_cwd, fs)
- elif _type == "str3ds":
- _export_raster3d_maps(rows, tar, list_file, new_cwd, fs)
- list_file.close()
+ # Create the temporary directory and jump into it
+ new_cwd = tempfile.mkdtemp(dir=workdir)
+ os.chdir(new_cwd)
- # Write projection and metadata
- proj = core.read_command("g.proj", flags="j")
+ sp.select()
- proj_file = open(proj_file_name, "w")
- proj_file.write(proj)
- proj_file.close()
+ if type_ == "strds":
+ columns = "name,start_time,end_time,min,max,datatype"
+ elif type_ == "stvds":
+ columns = "name,start_time,end_time,layer"
+ else:
+ columns = "name,start_time,end_time"
+ rows = sp.get_registered_maps(columns, where, "start_time", None)
- init_file = open(init_file_name, "w")
- # Create the init string
- string = ""
- string += "%s=%s\n" % ("stds_type", sp.get_type()) # This is optional, if not present strds will be assumed for backward compatibility
- string += "%s=%s\n" % ("format", _format) # This is optional, if not present gtiff will be assumed for backward compatibility
- string += "%s=%s\n" % ("temporal_type", sp.get_temporal_type())
- string += "%s=%s\n" % ("semantic_type", sp.get_semantic_type())
- string += "%s=%s\n" % ("number_of_maps", sp.metadata.get_number_of_maps())
- north, south, east, west, top, bottom = sp.get_spatial_extent()
- string += "%s=%s\n" % ("north", north)
- string += "%s=%s\n" % ("south", south)
- string += "%s=%s\n" % ("east", east)
- string += "%s=%s\n" % ("west", west)
- init_file.write(string)
- init_file.close()
+ if compression == "gzip":
+ flag = "w:gz"
+ elif compression == "bzip2":
+ flag = "w:bz2"
+ else:
+ flag = "w:"
- metadata = core.read_command("t.info", type=_type, input=id)
- metadata_file = open(metadata_file_name, "w")
- metadata_file.write(metadata)
- metadata_file.close()
+ # Open the tar archive to add the files
+ tar = tarfile.open(tmp_tar_file_name, flag)
+ list_file = open(list_file_name, "w")
- read_file = open(read_file_name, "w")
- read_file.write("This space time raster dataset was exported with t.rast.export of GRASS GIS 7\n")
- read_file.write("This space time vector dataset was exported with t.vect.export of GRASS GIS 7\n")
- read_file.write("This space time 3D raster dataset was exported with t.rast3d.export of GRASS GIS 7\n")
- read_file.write("\n")
- read_file.write("Files:\n")
- #123456789012345678901234567890
- read_file.write(" *.tif -- GeoTIFF raster files\n")
- read_file.write(" *.color -- GRASS GIS raster color rules\n")
- elif _format == "pack":
- read_file.write(" *.pack -- GRASS raster files packed with r.pack\n")
- read_file.write(" *.xml -- Vector GML files\n")
- else:
- read_file.write(" *.pack -- GRASS vector files packed with v.pack\n")
- read_file.write(" *.pack -- GRASS 3D raster files packed with r3.pack\n")
- read_file.write("%13s -- Projection information in PROJ.4 format\n" % (proj_file_name))
- read_file.write("%13s -- GRASS GIS space time %s dataset information\n" % (init_file_name, sp.get_new_map_instance(None).get_type()))
- read_file.write("%13s -- Time series file, lists all maps by name with interval\n" % (list_file_name))
- read_file.write(" time stamps in ISO-Format. Field separator is |\n")
- read_file.write("%13s -- Projection information in PROJ.4 format\n" % (metadata_file_name))
- read_file.write("%13s -- This file\n" % (read_file_name))
- read_file.close()
+ fs = "|"
- # Append the file list
- tar.add(list_file_name)
- tar.add(proj_file_name)
- tar.add(init_file_name)
- tar.add(read_file_name)
- tar.add(metadata_file_name)
- tar.close()
+ if rows:
+ if format_ == "GTiff":
+ _export_raster_maps_as_geotiff(
+ rows, tar, list_file, new_cwd, fs)
+ else:
+ _export_raster_maps(rows, tar, list_file, new_cwd, fs)
+ if format_ == "GML":
+ _export_vector_maps_as_gml(rows, tar, list_file, new_cwd, fs)
+ else:
+ _export_vector_maps(rows, tar, list_file, new_cwd, fs)
+ elif type_ == "str3ds":
+ _export_raster3d_maps(rows, tar, list_file, new_cwd, fs)
- os.chdir(old_cwd)
+ list_file.close()
- # Move the archive to its destination
- shutil.move(os.path.join(new_cwd, tmp_tar_file_name), output)
+ # Write projection and metadata
+ proj = core.read_command("g.proj", flags="j")
- # Remove the temporary created working directory
- shutil.rmtree(new_cwd)
+ proj_file = open(proj_file_name, "w")
+ proj_file.write(proj)
+ proj_file.close()
+ init_file = open(init_file_name, "w")
+ # Create the init string
+ string = ""
+ # This is optional, if not present strds will be assumed for backward
+ # compatibility
+ string += "%s=%s\n" % ("stds_type", sp.get_type())
+ # This is optional, if not present gtiff will be assumed for
+ # backward compatibility
+ string += "%s=%s\n" % ("format", format_)
+ string += "%s=%s\n" % ("temporal_type", sp.get_temporal_type())
+ string += "%s=%s\n" % ("semantic_type", sp.get_semantic_type())
+ string += "%s=%s\n" % ("number_of_maps", sp.metadata.get_number_of_maps())
+ north, south, east, west, top, bottom = sp.get_spatial_extent()
+ string += "%s=%s\n" % ("north", north)
+ string += "%s=%s\n" % ("south", south)
+ string += "%s=%s\n" % ("east", east)
+ string += "%s=%s\n" % ("west", west)
+ init_file.write(string)
+ init_file.close()
+ metadata = core.read_command("t.info", type=type_, input=id)
+ metadata_file = open(metadata_file_name, "w")
+ metadata_file.write(metadata)
+ metadata_file.close()
+ read_file = open(read_file_name, "w")
+ read_file.write("This space time raster dataset was exported with "
+ "t.rast.export of GRASS GIS 7\n")
+ read_file.write("This space time vector dataset was exported with "
+ "t.vect.export of GRASS GIS 7\n")
+ read_file.write("This space time 3D raster dataset was exported "
+ "with t.rast3d.export of GRASS GIS 7\n")
+ read_file.write("\n")
+ read_file.write("Files:\n")
+ #123456789012345678901234567890
+ read_file.write(" *.tif -- GeoTIFF raster files\n")
+ read_file.write(" *.color -- GRASS GIS raster color rules\n")
+ elif format_ == "pack":
+ read_file.write(" *.pack -- GRASS raster files packed with r.pack\n")
+ read_file.write(" *.xml -- Vector GML files\n")
+ else:
+ read_file.write(" *.pack -- GRASS vector files packed with v.pack\n")
+ read_file.write(" *.pack -- GRASS 3D raster files packed with r3.pack\n")
+ read_file.write("%13s -- Projection information in PROJ.4 format\n" %
+ (proj_file_name))
+ read_file.write("%13s -- GRASS GIS space time %s dataset information\n" %
+ (init_file_name, sp.get_new_map_instance(None).get_type()))
+ read_file.write("%13s -- Time series file, lists all maps by name "
+ "with interval\n" % (list_file_name))
+ read_file.write(" time stamps in ISO-Format. Field separator is |\n")
+ (metadata_file_name))
+ read_file.write("%13s -- This file\n" % (read_file_name))
+ read_file.close()
+ # Append the file list
+ tar.add(list_file_name)
+ tar.add(proj_file_name)
+ tar.add(init_file_name)
+ tar.add(read_file_name)
+ tar.add(metadata_file_name)
+ tar.close()
+ os.chdir(old_cwd)
+ # Move the archive to its destination
+ shutil.move(os.path.join(new_cwd, tmp_tar_file_name), output)
+ # Remove the temporary created working directory
+ shutil.rmtree(new_cwd)
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/stds_import.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -19,7 +19,7 @@
exp=True
overr=False
create=False
-tgis.import_stds(input, output, extrdir, title, descr, location,
+tgis.import_stds(input, output, extrdir, title, descr, location,
link, exp, overr, create, "strds")
@endcode
@@ -51,317 +51,345 @@
imported_maps = {}
def _import_raster_maps_from_geotiff(maplist, overr, exp, location, link):
- impflags = ""
- if overr:
- impflags += "o"
- if exp or location:
- impflags += "e"
- for row in maplist:
- name = row["name"]
- filename = str(row["name"]) + ".tif"
+ impflags = ""
+ if overr:
+ impflags += "o"
+ if exp or location:
+ impflags += "e"
+ for row in maplist:
+ name = row["name"]
+ filename = str(row["name"]) + ".tif"
- if link:
- ret = core.run_command("r.external", input = filename,
- output = name,
- flags = impflags,
- overwrite = core.overwrite())
- else:
- ret = core.run_command("r.in.gdal", input = filename,
- output = name,
- flags = impflags,
+ if link:
+ ret = core.run_command("r.external", input=filename,
+ output=name,
+ flags=impflags,
+ overwrite=core.overwrite())
+ else:
+ ret = core.run_command("r.in.gdal", input=filename,
+ output=name,
+ flags=impflags,
- if ret != 0:
- core.fatal(_("Unable to import/link raster map <%s>.") % name)
+ if ret != 0:
+ core.fatal(_("Unable to import/link raster map <%s>.") % name)
- # Set the color rules if present
- filename = str(row["name"]) + ".color"
- if os.path.isfile(filename):
- ret = core.run_command("r.colors", map = name,
- rules = filename,
- if ret != 0:
- core.fatal(_("Unable to set the color rules for raster map <%s>.") % name)
+ # Set the color rules if present
+ filename = str(row["name"]) + ".color"
+ if os.path.isfile(filename):
+ ret = core.run_command("r.colors", map=name,
+ rules=filename,
+ if ret != 0:
+ core.fatal(_("Unable to set the color rules for "
+ "raster map <%s>.") % name)
def _import_raster_maps(maplist):
- # We need to disable the projection check because of its simple implementation
- impflags = "o"
- filename = str(row["name"]) + ".pack"
- ret = core.run_command("r.unpack", input = filename,
- output = name,
- flags = impflags,
- overwrite = core.overwrite(),
- verbose = True)
+ # We need to disable the projection check because of its
+ # simple implementation
+ impflags = "o"
+ filename = str(row["name"]) + ".pack"
+ ret = core.run_command("r.unpack", input=filename,
+ output=name,
+ flags=impflags,
+ overwrite=core.overwrite(),
+ verbose=True)
- if ret != 0:
- core.fatal(_("Unable to unpack raster map <%s>.") % name)
+ if ret != 0:
+ core.fatal(_("Unable to unpack raster map <%s>.") % name)
def _import_vector_maps_from_gml(maplist, overr, exp, location, link):
- impflags = "o"
- impflags += "e"
- filename = str(row["name"]) + ".xml"
+ impflags = "o"
+ impflags += "e"
+ filename = str(row["name"]) + ".xml"
- ret = core.run_command("v.in.ogr", dsn = filename,
- output = name,
- flags = impflags,
+ ret = core.run_command("v.in.ogr", dsn=filename,
+ output=name,
+ flags=impflags,
- if ret != 0:
- core.fatal(_("Unable to import vector map <%s>.") % name)
+ if ret != 0:
+ core.fatal(_("Unable to import vector map <%s>.") % name)
def _import_vector_maps(maplist):
- impflags = "o"
- # Separate the name from the layer
- name = row["name"].split(":")[0]
- # Import only unique maps
- if name in imported_maps:
- continue
- filename = name + ".pack"
- ret = core.run_command("v.unpack", input = filename,
- output = name,
- flags = impflags,
- verbose = True)
+ impflags = "o"
+ # Separate the name from the layer
+ name = row["name"].split(":")[0]
+ # Import only unique maps
+ if name in imported_maps:
+ continue
+ filename = name + ".pack"
+ ret = core.run_command("v.unpack", input=filename,
+ output=name,
+ flags=impflags,
+ verbose=True)
- if ret != 0:
- core.fatal(_("Unable to unpack vector map <%s>.") % name)
- imported_maps[name] = name
+ if ret != 0:
+ core.fatal(_("Unable to unpack vector map <%s>.") % name)
+ imported_maps[name] = name
-def import_stds(input, output, extrdir, title = None, descr = None, location = None,
- link = False, exp = False, overr = False, create = False, stds_type = "strds"):
- !Import space time datasets of type raster and vector
- @param input Name of the input archive file
- @param output The name of the output space time dataset
- @param extrdir The extraction directory
- @param title The title of the new created space time dataset
- @param description The description of the new created space time dataset
- @param location The name of the location that should be created,
- maps are imported into this location
- @param link Switch to link raster maps instead importing them
- @param exp Extend location extents based on new dataset
- @param overr Override projection (use location's projection)
- @param create Create the location specified by the "location" parameter and exit.
- Do not import the space time datasets.
- @param stds_type The type of the space time dataset that should be imported
+def import_stds(
+ input, output, extrdir, title=None, descr=None, location=None,
+ link=False, exp=False, overr=False, create=False, stds_type="strds"):
+ """!Import space time datasets of type raster and vector
- core.set_raise_on_error(True)
+ @param input: Name of the input archive file
+ @param output: The name of the output space time dataset
+ @param extrdir: The extraction directory
+ @param title: The title of the new created space time dataset
+ @param description: The description of the new created
+ @param location: The name of the location that should be created,
+ maps are imported into this location
+ @param link: Switch to link raster maps instead importing them
+ @param exp: Extend location extents based on new dataset
+ @param overr: Override projection (use location's projection)
+ @param create: Create the location specified by the "location"
+ parameter and exit.
+ Do not import the space time datasets.
+ @param stds_type: The type of the space time dataset that
+ should be imported
- # Check if input file and extraction directory exits
- if not os.path.exists(input):
- core.fatal(_("Space time raster dataset archive <%s> not found") % input)
- if not create and not os.path.exists(extrdir):
- core.fatal(_("Extraction directory <%s> not found") % extrdir)
+ core.set_raise_on_error(True)
- tar = tarfile.open(name = input, mode = 'r')
+ # Check if input file and extraction directory exits
+ if not os.path.exists(input):
+ core.fatal(_("Space time raster dataset archive <%s> not found")
+ % input)
+ if not create and not os.path.exists(extrdir):
+ core.fatal(_("Extraction directory <%s> not found") % extrdir)
- # Check for important files
- members = tar.getnames()
+ tar = tarfile.open(name=input, mode='r')
- if init_file_name not in members:
- core.fatal(_("Unable to find init file <%s>") % init_file_name)
- if list_file_name not in members:
- core.fatal(_("Unable to find list file <%s>") % list_file_name)
- if proj_file_name not in members:
- core.fatal(_("Unable to find projection file <%s>") % proj_file_name)
+ # Check for important files
+ members = tar.getnames()
- tar.extractall(path = extrdir)
- tar.close()
+ if init_file_name not in members:
+ core.fatal(_("Unable to find init file <%s>") % init_file_name)
+ if list_file_name not in members:
+ core.fatal(_("Unable to find list file <%s>") % list_file_name)
+ if proj_file_name not in members:
+ core.fatal(_("Unable to find projection file <%s>") % proj_file_name)
+ tar.extractall(path=extrdir)
+ tar.close()
- # Switch into the data directory
- os.chdir(extrdir)
- # Check projection information
- if not location:
- temp_name = core.tempfile()
- temp_file = open(temp_name, "w")
- proj_name = os.path.abspath(proj_file_name)
+ # Switch into the data directory
+ os.chdir(extrdir)
- p = core.start_command("g.proj", flags = "j", stdout = temp_file)
- p.communicate()
- temp_file.close()
+ # Check projection information
+ if not location:
+ temp_name = core.tempfile()
+ temp_file = open(temp_name, "w")
+ proj_name = os.path.abspath(proj_file_name)
- if not core.compare_key_value_text_files(temp_name, proj_name, sep="="):
- if overr:
- core.warning(_("Projection information does not match. Proceeding..."))
- else:
- core.fatal(_("Projection information does not match. Aborting."))
+ p = core.start_command("g.proj", flags="j", stdout=temp_file)
+ p.communicate()
+ temp_file.close()
- # Create a new location based on the projection information and switch into it
- old_env = core.gisenv()
- if location:
- try:
- proj4_string = open(proj_file_name, 'r').read()
- core.create_location(dbase = old_env["GISDBASE"],
- location = location,
- proj4 = proj4_string)
- # Just create a new location and return
- if create:
- os.chdir(old_cwd)
- return
- except Exception as e:
- core.fatal(_("Unable to create location %s. Reason: %s") % (location, str(e)))
- # Switch to the new created location
- ret = core.run_command("g.mapset", mapset = "PERMANENT",
- gisdbase = old_env["GISDBASE"])
- if ret != 0:
- core.fatal(_("Unable to switch to location %s") % location)
- # create default database connection
- ret = core.run_command("t.connect", flags = "d")
- if ret != 0:
- core.fatal(_("Unable to create default temporal database in new location %s") % location)
+ if not core.compare_key_value_text_files(temp_name, proj_name, sep="="):
+ if overr:
+ core.warning(_("Projection information does not match. "
+ "Proceeding..."))
+ else:
+ core.fatal(_("Projection information does not match. Aborting."))
- try:
- # Make sure the temporal database exists
- create_temporal_database()
+ # Create a new location based on the projection information and switch into it
+ old_env = core.gisenv()
+ if location:
+ try:
+ proj4_string = open(proj_file_name, 'r').read()
+ core.create_location(dbase=old_env["GISDBASE"],
+ location=location,
+ proj4=proj4_string)
+ # Just create a new location and return
+ if create:
+ os.chdir(old_cwd)
+ return
+ except Exception as e:
+ core.fatal(_("Unable to create location %s. Reason: %s")
+ % (location, str(e)))
+ # Switch to the new created location
+ ret = core.run_command("g.mapset", mapset="PERMANENT",
+ gisdbase=old_env["GISDBASE"])
+ if ret != 0:
+ core.fatal(_("Unable to switch to location %s") % location)
+ # create default database connection
+ ret = core.run_command("t.connect", flags="d")
+ if ret != 0:
+ core.fatal(_("Unable to create default temporal database "
+ "in new location %s") % location)
- fs = "|"
- maplist = []
- mapset = core.gisenv()["MAPSET"]
- list_file = open(list_file_name, "r")
+ try:
+ # Make sure the temporal database exists
+ create_temporal_database()
- # Read the map list from file
- line_count = 0
- while True:
- line = list_file.readline()
- if not line:
- break
+ fs = "|"
+ maplist = []
+ mapset = core.gisenv()["MAPSET"]
+ list_file = open(list_file_name, "r")
- line_list = line.split(fs)
+ # Read the map list from file
+ line_count = 0
+ while True:
+ line = list_file.readline()
+ if not line:
+ break
- mapname = line_list[0].strip()
- mapid = mapname + "@" + mapset
+ line_list = line.split(fs)
- row = {}
- row["name"] = mapname
- row["id"] = mapid
- row["start"] = line_list[1].strip()
- row["end"] = line_list[2].strip()
+ mapname = line_list[0].strip()
+ mapid = mapname + "@" + mapset
- maplist.append(row)
- line_count += 1
+ row = {}
+ row["name"] = mapname
+ row["id"] = mapid
+ row["start"] = line_list[1].strip()
+ row["end"] = line_list[2].strip()
- list_file.close()
+ maplist.append(row)
+ line_count += 1
- # Read the init file
- fs = "="
- init = {}
- init_file = open(init_file_name, "r")
- while True:
- line = init_file.readline()
- if not line:
- break
+ list_file.close()
- kv = line.split(fs)
- init[kv[0]] = kv[1].strip()
+ # Read the init file
+ fs = "="
+ init = {}
+ init_file = open(init_file_name, "r")
+ while True:
+ line = init_file.readline()
+ if not line:
+ break
- init_file.close()
+ kv = line.split(fs)
+ init[kv[0]] = kv[1].strip()
- if not init.has_key("temporal_type") or \
- not init.has_key("semantic_type") or \
- not init.has_key("number_of_maps"):
- core.fatal(_("Key words %s, %s or %s not found in init file.") %
- ("temporal_type", "semantic_type", "number_of_maps"))
+ init_file.close()
- if line_count != int(init["number_of_maps"]):
- core.fatal(_("Number of maps mismatch in init and list file."))
+ if "temporal_type" not in init or \
+ "semantic_type" not in init or \
+ "number_of_maps" not in init:
+ core.fatal(_("Key words %s, %s or %s not found in init file.") %
+ ("temporal_type", "semantic_type", "number_of_maps"))
- _format = "GTiff"
- _type = "strds"
+ if line_count != int(init["number_of_maps"]):
+ core.fatal(_("Number of maps mismatch in init and list file."))
- if init.has_key("stds_type"):
- _type = init["stds_type"]
- if init.has_key("format"):
- _format = init["format"]
+ _format = "GTiff"
+ _type = "strds"
- if stds_type != _type:
- core.fatal(_("The archive file is of wrong space time dataset type"))
+ if "stds_type" in init:
+ _type = init["stds_type"]
+ if "format" in init:
+ _format = init["format"]
- # Check the existence of the files
- if not os.path.exists(filename):
- core.fatal(_("Unable to find geotiff raster file <%s> in archive.") % filename)
- elif _format == "GML":
- core.fatal(_("Unable to find GML vector file <%s> in archive.") % filename)
- if _type == "stvds":
- filename = str(row["name"].split(":")[0]) + ".pack"
- else:
- core.fatal(_("Unable to find GRASS package file <%s> in archive.") % filename)
- else:
- core.fatal(_("Unsupported input format"))
+ if stds_type != _type:
+ core.fatal(_("The archive file is of wrong space time dataset type"))
- # Check the space time dataset
- id = output + "@" + mapset
- if sp.is_in_db() and core.overwrite() == False:
- core.fatal(_("Space time %s dataset <%s> is already in the database. Use the overwrite flag.") % (_type, sp.get_id()))
+ # Check the existence of the files
+ if _format == "GTiff":
+ if not os.path.exists(filename):
+ core.fatal(_("Unable to find geotiff raster file "
+ "<%s> in archive.") % filename)
+ elif _format == "GML":
+ core.fatal(_("Unable to find GML vector file "
+ elif _format == "pack":
+ if _type == "stvds":
+ filename = str(row["name"].split(":")[0]) + ".pack"
+ else:
+ core.fatal(_("Unable to find GRASS package file "
+ else:
+ core.fatal(_("Unsupported input format"))
- # Import the maps
- _import_raster_maps_from_geotiff(maplist, overr, exp, location, link)
- if _format == "pack":
- _import_raster_maps(maplist)
- _import_vector_maps_from_gml(maplist, overr, exp, location, link)
- _import_vector_maps(maplist)
+ # Check the space time dataset
+ id = output + "@" + mapset
+ sp = dataset_factory(_type, id)
+ if sp.is_in_db() and core.overwrite() == False:
+ core.fatal(_("Space time %s dataset <%s> is already in the "
+ "database. Use the overwrite flag.") % \
+ (_type, sp.get_id()))
- # Create the space time dataset
- if sp.is_in_db() and core.overwrite() == True:
- core.info(_("Overwrite space time %s dataset <%s> and unregister all maps.") % (sp.get_new_map_instance(None).get_type(), sp.get_id()))
- sp.delete()
- sp = sp.get_new_instance(id)
+ # Import the maps
+ if _type == "strds":
+ _import_raster_maps_from_geotiff(
+ maplist, overr, exp, location, link)
+ if _format == "pack":
+ _import_raster_maps(maplist)
+ elif _type == "stvds":
+ if _format == "GML":
+ _import_vector_maps_from_gml(
+ _import_vector_maps(maplist)
- temporal_type = init["temporal_type"]
- semantic_type = init["semantic_type"]
- core.verbose(_("Create space time %s dataset.") % sp.get_new_map_instance(None).get_type())
+ # Create the space time dataset
+ if sp.is_in_db() and core.overwrite() == True:
+ core.info(_("Overwrite space time %s dataset "
+ "<%s> and unregister all maps.") % \
+ (sp.get_new_map_instance(None).get_type(), sp.get_id()))
+ sp.delete()
+ sp = sp.get_new_instance(id)
- sp.set_initial_values(temporal_type = temporal_type, semantic_type = semantic_type, title = title, description = descr)
- sp.insert()
+ temporal_type = init["temporal_type"]
+ semantic_type = init["semantic_type"]
+ core.verbose(_("Create space time %s dataset.") %
+ sp.get_new_map_instance(None).get_type())
- # register the maps
- fs = "|"
- register_maps_in_space_time_dataset(type = sp.get_new_map_instance(None).get_type(),
- name = output, file = list_file_name, start = "file", end = "file", dbif = None, fs = fs)
+ sp.set_initial_values(temporal_type=temporal_type,
+ semantic_type=semantic_type, title=title,
+ description=descr)
+ sp.insert()
- os.chdir(old_cwd)
- except:
- raise
+ # register the maps
+ fs = "|"
+ register_maps_in_space_time_dataset(
+ type=sp.get_new_map_instance(None).get_type(),
+ name=output, file=list_file_name, start="file",
+ end="file", dbif=None, fs=fs)
- # Make sure the location is switched back correctly
- finally:
- if location:
- # Switch to the old location
- ret = core.run_command("g.mapset", mapset = old_env["MAPSET"],
- location = old_env["LOCATION_NAME"],
+ os.chdir(old_cwd)
+ except:
+ raise
+ # Make sure the location is switched back correctly
+ finally:
+ if location:
+ # Switch to the old location
+ ret = core.run_command("g.mapset", mapset=old_env["MAPSET"],
+ location=old_env["LOCATION_NAME"],
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -6,11 +6,15 @@
Usage:
+ at code
>>> from datetime import datetime
>>> t = tgis.RasterRelativeTime()
>>> t = tgis.RasterAbsoluteTime()
+ at endcode
License (>=v2). Read the file COPYING that comes with GRASS
@@ -34,8 +38,9 @@
Usage:
- >>> A = tgis.AbstractTemporalExtent(table="raster_absolute_time",
+ @code
+ >>> A = AbstractTemporalExtent(table="raster_absolute_time",
... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
... end_time=datetime(2005,01,01) )
>>> A.id
@@ -51,7 +56,7 @@
start_time=2001-01-01 00:00:00
end_time=2005-01-01 00:00:00
>>> # relative time
... ident="soil at PERMANENT", start_time=0, end_time=1 )
>>> A.id
'soil at PERMANENT'
@@ -65,6 +70,8 @@
>>> A.print_shell_info()
start_time=0
end_time=1
+ @endcode
def __init__(self, table=None, ident=None, start_time=None, end_time=None):
@@ -77,21 +84,25 @@
def starts(self, extent):
"""!Return True if this temporal extent (A) starts at the start of the
provided temporal extent (B) and finishes within it
+ @verbatim
A |-----|
B |---------|
+ @endverbatim
@param extent: The temporal extent object with which this extent starts
Usage:
+ @code
- >>> A = tgis.AbstractTemporalExtent(start_time=5, end_time=6 )
- >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=7 )
+ >>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
+ >>> B = AbstractTemporalExtent(start_time=5, end_time=7 )
>>> A.starts(B)
True
>>> B.starts(A)
False
+ @endcode
if self.D["end_time"] is None or extent.D["end_time"] is None:
return False
@@ -105,20 +116,25 @@
def started(self, extent):
"""!Return True if this temporal extent (A) started at the start of the
provided temporal extent (B) and finishes after it
+ @verbatim
A |---------|
B |-----|
+ @endverbatim
@param extent: The temporal extent object with which this extent started
Usage:
- >>> A = tgis.AbstractTemporalExtent(start_time=5, end_time=7 )
- >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=6 )
+ @code
+ >>> A = AbstractTemporalExtent(start_time=5, end_time=7 )
+ >>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
>>> A.started(B)
True
>>> B.started(A)
False
+ @endcode
return False
@@ -132,20 +148,25 @@
def finishes(self, extent):
"""!Return True if this temporal extent (A) starts after the start of the
provided temporal extent (B) and finishes with it
+ @verbatim
A |-----|
B |---------|
+ @endverbatim
@param extent: The temporal extent object with which this extent finishes
Usage:
- >>> A = tgis.AbstractTemporalExtent(start_time=6, end_time=7 )
+ @code
+ >>> A = AbstractTemporalExtent(start_time=6, end_time=7 )
>>> A.finishes(B)
True
>>> B.finishes(A)
False
+ @endcode
return False
@@ -159,20 +180,25 @@
def finished(self, extent):
"""!Return True if this temporal extent (A) starts before the start of the
+ @verbatim
A |---------|
B |-----|
+ @endverbatim
Usage:
- >>> B = tgis.AbstractTemporalExtent(start_time=6, end_time=7 )
+ @code
+ >>> B = AbstractTemporalExtent(start_time=6, end_time=7 )
>>> A.finished(B)
True
>>> B.finished(A)
False
+ @endcode
return False
@@ -186,20 +212,25 @@
def after(self, extent):
"""!Return True if this temporal extent (A) is located after the
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is located before this extent
Usage:
- >>> A = tgis.AbstractTemporalExtent(start_time=8, end_time=9 )
+ @code
+ >>> A = AbstractTemporalExtent(start_time=8, end_time=9 )
>>> A.after(B)
True
>>> B.after(A)
False
+ @endcode
if extent.D["end_time"] is None:
if self.D["start_time"] > extent.D["start_time"]:
@@ -215,20 +246,25 @@
def before(self, extent):
"""!Return True if this temporal extent (A) is located before the
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is located after this extent
Usage:
- >>> B = tgis.AbstractTemporalExtent(start_time=8, end_time=9 )
+ @code
+ >>> B = AbstractTemporalExtent(start_time=8, end_time=9 )
>>> A.before(B)
True
>>> B.before(A)
False
+ @endcode
if self.D["end_time"] is None:
if self.D["start_time"] < extent.D["start_time"]:
@@ -244,29 +280,34 @@
def adjacent(self, extent):
"""!Return True if this temporal extent (A) is a meeting neighbor the
+ @verbatim
A |---------|
B |---------|
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is a meeting neighbor
of this extent
Usage:
- >>> B = tgis.AbstractTemporalExtent(start_time=7, end_time=9 )
+ @code
+ >>> B = AbstractTemporalExtent(start_time=7, end_time=9 )
>>> A.adjacent(B)
True
>>> B.adjacent(A)
True
- >>> B = tgis.AbstractTemporalExtent(start_time=3, end_time=5 )
+ >>> B = AbstractTemporalExtent(start_time=3, end_time=5 )
>>> A.adjacent(B)
True
>>> B.adjacent(A)
True
+ @endcode
if self.D["end_time"] is None and extent.D["end_time"] is None:
return False
@@ -280,19 +321,26 @@
def follows(self, extent):
"""!Return True if this temporal extent (A) follows the
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is the predecessor
of this extent
+ Usage:
+ @code
>>> A.follows(B)
True
>>> B.follows(A)
False
+ @endcode
return False
@@ -305,21 +353,26 @@
def precedes(self, extent):
"""!Return True if this temporal extent (A) precedes the provided
temporal extent (B)
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is the successor
of this extent
Usage:
+ @code
>>> A.precedes(B)
True
>>> B.precedes(A)
False
+ @endcode
return False
@@ -332,20 +385,25 @@
def during(self, extent):
"""!Return True if this temporal extent (A) is located during the provided
temporal extent (B)
+ @verbatim
A |-------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that contains this extent
Usage:
- >>> B = tgis.AbstractTemporalExtent(start_time=4, end_time=9 )
+ @code
+ >>> B = AbstractTemporalExtent(start_time=4, end_time=9 )
>>> A.during(B)
True
>>> B.during(A)
False
+ @endcode
# Check single point of time in interval
@@ -368,21 +426,26 @@
def contains(self, extent):
"""!Return True if this temporal extent (A) contains the provided
temporal extent (B)
+ @verbatim
A |---------|
B |-------|
+ @endverbatim
during this extent
Usage:
- >>> A = tgis.AbstractTemporalExtent(start_time=4, end_time=9 )
- >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=8 )
+ @code
+ >>> A = AbstractTemporalExtent(start_time=4, end_time=9 )
+ >>> B = AbstractTemporalExtent(start_time=5, end_time=8 )
>>> A.contains(B)
True
>>> B.contains(A)
False
+ @endcode
@@ -405,21 +468,26 @@
"""!Return True if this temporal extent (A) is equivalent to the provided
temporal extent (B)
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is equivalent
during this extent
Usage:
+ @code
>>> A.equivalent(B)
True
>>> B.equivalent(A)
True
+ @endcode
if self.D["start_time"] == extent.D["start_time"]:
@@ -439,21 +507,25 @@
def overlapped(self, extent):
"""!Return True if this temporal extent (A) overlapped the provided
temporal extent (B)
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is overlaps
this extent
Usage:
- >>> B = tgis.AbstractTemporalExtent(start_time=6, end_time=8 )
+ @code
+ >>> B = AbstractTemporalExtent(start_time=6, end_time=8 )
>>> A.overlapped(B)
True
>>> B.overlapped(A)
False
+ @endcode
return False
@@ -468,21 +540,26 @@
def overlaps(self, extent):
"""!Return True if this temporal extent (A) overlapps the provided
temporal extent (B)
+ @verbatim
A |---------|
B |---------|
+ @endverbatim
@param extent: The temporal extent object that is overlapped
this extent
Usage:
- >>> A = tgis.AbstractTemporalExtent(start_time=6, end_time=8 )
+ @code
+ >>> A = AbstractTemporalExtent(start_time=6, end_time=8 )
>>> A.overlaps(B)
True
>>> B.overlaps(A)
False
+ @endcode
return False
@@ -663,17 +740,20 @@
class RasterAbsoluteTime(AbsoluteTemporalExtent):
- def __init__(self, ident=None, start_time=None, end_time=None, timezone=None):
+ def __init__(self, ident=None, start_time=None, end_time=None,
+ timezone=None):
AbsoluteTemporalExtent.__init__(self, "raster_absolute_time",
ident, start_time, end_time, timezone)
class Raster3DAbsoluteTime(AbsoluteTemporalExtent):
+ timezone=None):
AbsoluteTemporalExtent.__init__(self, "raster3d_absolute_time",
class VectorAbsoluteTime(AbsoluteTemporalExtent):
+ timezone=None):
AbsoluteTemporalExtent.__init__(self, "vector_absolute_time",
@@ -687,8 +767,9 @@
Usage:
- >>> A = tgis.STDSAbsoluteTime(table="strds_absolute_time",
+ @code
+ >>> A = STDSAbsoluteTime(table="strds_absolute_time",
... ident="strds at PERMANENT", start_time=datetime(2001, 01, 01),
... end_time=datetime(2005,01,01), granularity="1 days",
... map_time="interval")
@@ -713,6 +794,8 @@
granularity=1 days
map_time=interval
+ @endcode
def __init__(self, table=None, ident=None, start_time=None, end_time=None,
granularity=None, timezone=None, map_time=None):
@@ -808,9 +891,10 @@
start_time and end_time must be of type integer
Usage:
+ @code
- >>> A = tgis.RelativeTemporalExtent(table="raster_absolute_time",
+ >>> A = RelativeTemporalExtent(table="raster_absolute_time",
... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years")
>>> A.id
'soil at PERMANENT'
@@ -829,6 +913,8 @@
start_time=0
end_time=1
unit=years
+ @endcode
unit=None):
@@ -916,9 +1002,10 @@
Usage:
+ @code
- >>> A = tgis.STDSRelativeTime(table="raster_absolute_time",
+ >>> A = STDSRelativeTime(table="raster_absolute_time",
... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years",
... granularity=5, map_time="interval")
>>> A.id
@@ -946,6 +1033,8 @@
unit=years
granularity=5
map_time=interval
+ @endcode
unit=None, granularity=None, map_time=None):
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -25,14 +25,14 @@
-def compute_relative_time_granularity(maps):
+def compute_relative_time_granularity(maps):
"""!Compute the relative time granularity
- Attention: The computation of the granularity is only correct in case of not
- overlapping intervals. Hence a correct temporal topology is required for
- computation.
+ Attention: The computation of the granularity
+ is only correct in case of not overlapping intervals.
+ Hence a correct temporal topology is required for computation.
@param maps: a ordered by start_time list of map objects
@@ -44,7 +44,7 @@
for map in maps:
start, end = map.get_valid_time()
if start and end:
- t = abs(end - start)
+ t = abs(end - start)
delta.append(int(t))
# Compute the timedelta of the gaps
@@ -54,12 +54,13 @@
if relation == "after":
start1, end1 = maps[i].get_valid_time()
start2, end2 = maps[i + 1].get_valid_time()
- # Gaps are between intervals, intervals and points, points and points
+ # Gaps are between intervals, intervals and
+ # points, points and points
if end1 and start2:
- t = abs(end1 - start2)
+ t = abs(end1 - start2)
- if not end1 and start2:
- t = abs(start1 - start2)
+ if not end1 and start2:
+ t = abs(start1 - start2)
delta.sort()
@@ -76,16 +77,16 @@
-def compute_absolute_time_granularity(maps):
+def compute_absolute_time_granularity(maps):
"""!Compute the absolute time granularity
- computation.
has_seconds = False
has_minutes = False
@@ -117,83 +118,85 @@
if end1 and start2:
delta.append(end1 - start2)
datetime_delta.append(compute_datetime_delta(end1, start2))
delta.append(start2 - start1)
- datetime_delta.append(compute_datetime_delta(start1, start2))
+ datetime_delta.append(compute_datetime_delta(
+ start1, start2))
# Check what changed
dlist = []
for d in datetime_delta:
- if d.has_key("second") and d["second"] > 0:
+ if "second" in d and d["second"] > 0:
has_seconds = True
- if d.has_key("minute") and d["minute"] > 0:
+ if "minute" in d and d["minute"] > 0:
has_minutes = True
- if d.has_key("hour") and d["hour"] > 0:
+ if "hour" in d and d["hour"] > 0:
has_hours = True
- if d.has_key("day") and d["day"] > 0:
+ if "day" in d and d["day"] > 0:
has_days = True
- if d.has_key("month") and d["month"] > 0:
+ if "month" in d and d["month"] > 0:
has_months = True
- if d.has_key("year") and d["year"] > 0:
+ if "year" in d and d["year"] > 0:
has_years = True
# Create a list with a single time unit only
if has_seconds:
- if d.has_key("second"):
- dlist.append(d["second"])
- elif d.has_key("minute"):
- dlist.append(d["minute"] * 60)
- elif d.has_key("hour"):
- dlist.append(d["hour"] * 3600)
- elif d.has_key("day"):
- dlist.append(d["day"] * 24 * 3600)
+ if "second" in d:
+ dlist.append(d["second"])
+ elif "minute" in d:
+ dlist.append(d["minute"] * 60)
+ elif "hour" in d:
+ dlist.append(d["hour"] * 3600)
+ elif "day" in d:
+ dlist.append(d["day"] * 24 * 3600)
else:
- dlist.append(d["max_days"] * 24 * 3600)
- use_seconds = True
+ dlist.append(d["max_days"] * 24 * 3600)
+ use_seconds = True
elif has_minutes:
- if d.has_key("minute"):
- dlist.append(d["minute"])
- dlist.append(d["hour"] * 60)
- dlist.append(d["day"] * 24 * 60)
+ if "minute" in d:
+ dlist.append(d["minute"])
+ elif "hour" in d:
+ dlist.append(d["hour"] * 60)
+ elif "day" in d:
+ dlist.append(d["day"] * 24 * 60)
else:
- dlist.append(d["max_days"] * 24 * 60)
- use_minutes = True
+ dlist.append(d["max_days"] * 24 * 60)
+ use_minutes = True
elif has_hours:
- if d.has_key("hour"):
- dlist.append(d["hour"])
- dlist.append(d["day"] * 24)
+ if "hour" in d:
+ dlist.append(d["hour"])
+ elif "day" in d:
+ dlist.append(d["day"] * 24)
else:
- dlist.append(d["max_days"] * 24)
- use_hours = True
+ dlist.append(d["max_days"] * 24)
+ use_hours = True
elif has_days:
- if d.has_key("day"):
- dlist.append(d["day"])
+ if "day" in d:
+ dlist.append(d["day"])
else:
- dlist.append(d["max_days"])
- use_days = True
+ dlist.append(d["max_days"])
+ use_days = True
elif has_months:
- if d.has_key("month"):
- dlist.append(d["month"])
- elif d.has_key("year"):
- dlist.append(d["year"] * 12)
- use_months = True
+ if "month" in d:
+ dlist.append(d["month"])
+ elif "year" in d:
+ dlist.append(d["year"] * 12)
+ use_months = True
elif has_years:
- if d.has_key("year"):
- dlist.append(d["year"])
- use_years = True
+ if "year" in d:
+ dlist.append(d["year"])
+ use_years = True
dlist.sort()
ulist = list(set(dlist))
@@ -229,20 +232,23 @@
# See http://www.opensource.org/licenses/mit-license.php
# Error Codes:
# None
-def gcd(a,b):
- """!The Euclidean Algorithm """
- a = abs(a)
- b = abs(b)
- while a:
- a, b = b%a, a
- return b
+def gcd(a, b):
+ """!The Euclidean Algorithm """
+ a = abs(a)
+ b = abs(b)
+ while a:
+ a, b = b % a, a
+ return b
def gcd_list(list):
- """!Finds the GCD of numbers in a list.
- Input: List of numbers you want to find the GCD of
- E.g. [8, 24, 12]
- Returns: GCD of all numbers
- return reduce(gcd, list)
+ """!Finds the GCD of numbers in a list.
+ Input: List of numbers you want to find the GCD of
+ E.g. [8, 24, 12]
+ Returns: GCD of all numbers
+ return reduce(gcd, list)
Modified: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -25,43 +25,45 @@
class temporal_topology_builder(object):
- """!This class is designed to build the temporal topology based on a lists of maps
- Example:
- @code
- # We have a space time raster dataset and build a map list
- # from all registered maps ordered by start time
- maps = strds.get_registered_maps_as_objects()
- # Now lets build the temporal topology of the maps in the list
- tb = temporal_topology_builder()
- tb.build(maps)
- for _map in tb:
- _map.print_temporal_topology_info()
- _follows = _map.get_follows()
- if _follows:
- for f in _follows:
- f.print_temporal_topology_info()
- # Using the next and previous methods, we can iterate over the
- # topological related maps in this way
- _first = tb.get_first()
- while _first:
- _first.print_temporal_topology_info()
- _first = _first.next()
- # Dictionary like accessed
- _map = tb["name at mapset"]
- @endcode
+ """!This class is designed to build the temporal topology
+ based on a lists of maps
+ Example:
+ @code
+ # We have a space time raster dataset and build a map list
+ # from all registered maps ordered by start time
+ maps = strds.get_registered_maps_as_objects()
+ # Now lets build the temporal topology of the maps in the list
+ tb = temporal_topology_builder()
+ tb.build(maps)
+ for _map in tb:
+ _map.print_temporal_topology_info()
+ _follows = _map.get_follows()
+ if _follows:
+ for f in _follows:
+ f.print_temporal_topology_info()
+ # Using the next and previous methods, we can iterate over the
+ # topological related maps in this way
+ _first = tb.get_first()
+ while _first:
+ _first.print_temporal_topology_info()
+ _first = _first.next()
+ # Dictionary like accessed
+ _map = tb["name at mapset"]
+ @endcode
def __init__(self):
- self._reset()
+ self._reset()
def _reset(self):
self._store = {}
self._first = None
@@ -69,192 +71,214 @@
def _set_first(self, first):
self._first = first
- self._insert(first)
+ self._insert(first)
def _detect_first(self):
- if len(self) > 0:
- _prev = self._store.values()[0]
- while _prev != None:
- self._first = _prev
- _prev = _prev.prev()
+ if len(self) > 0:
+ prev_ = self._store.values()[0]
+ while prev_ is not None:
+ self._first = prev_
+ prev_ = prev_.temporal_prev()
def _insert(self, t):
self._store[t.get_id()] = t
def get_first(self):
- """!Return the first map with the earliest start time
- @return The map with the earliest start time
- return self._first
+ """!Return the first map with the earliest start time
+ @return The map with the earliest start time
+ return self._first
def _build_internal_iteratable(self, maps):
- """!Build an iteratable temporal topology structure for all maps in the list and store the maps internally
- Basically the "next" and "prev" relations will be set in the temporal topology structure of each map
- The maps will be added to the object, so they can be accessed using the iterator of this class
- @param maps: A sorted (by start_time)list of abstract_dataset objects with initiated temporal extent
- self._build_iteratable(maps)
+ """!Build an iteratable temporal topology structure for all maps in
+ the list and store the maps internally
- for _map in maps:
- self._insert(_map)
- # Detect the first map
- self._detect_first()
+ Basically the "next" and "prev" relations will be set in the
+ temporal topology structure of each map
+ The maps will be added to the object, so they can be
+ accessed using the iterator of this class
+ @param maps: A sorted (by start_time)list of abstract_dataset
+ objects with initiated temporal extent
+ self._build_iteratable(maps)
+ for _map in maps:
+ self._insert(_map)
+ # Detect the first map
+ self._detect_first()
def _build_iteratable(self, maps):
- Basically the "next" and "prev" relations will be set in the temporal topology structure of each map.
- for i in xrange(len(maps)):
- offset = i + 1
- for j in xrange(offset, len(maps)):
- # Get the temporal relationship
- relation = maps[j].temporal_relation(maps[i])
- # Build the next reference
- if relation != "equivalent" and relation != "started":
- maps[i].set_next(maps[j])
- break
- for _map in maps:
- _next = _map.next()
- if _next:
- _next.set_prev(_map)
- _map.set_temporal_topology_build_true()
+ all maps in the list
+ the temporal topology structure of each map.
+ for i in xrange(len(maps)):
+ offset = i + 1
+ for j in xrange(offset, len(maps)):
+ # Get the temporal relationship
+ relation = maps[j].temporal_relation(maps[i])
+ # Build the next reference
+ if relation != "equivalent" and relation != "started":
+ maps[i].set_temporal_next(maps[j])
+ break
+ for map_ in maps:
+ next_ = map_.temporal_next()
+ if next_:
+ next_.set_temporal_prev(map_)
+ map_.set_temporal_topology_build_true()
def build2(self, mapsA, mapsB):
- """!Build the temporal topology structure between two ordered lists of maps
- This method builds the temporal topology from mapsA to mapsB and vice verse.
- The temporal topology structure of each map, defined in class temporal_map_relations,
- will be reseted and rebuild for mapsA and mapsB.
- After building the temporal topology the modified map objects of mapsA can be accessed
- in the same way as a dictionary using there id. The implemented iterator assures
- the chronological iteration over the mapsA.
- @param mapsA: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
- @param mapsB: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
- if mapsA == mapsB:
- self.build(mapsA, True)
- return
- for _map in mapsA:
- _map.reset_temporal_topology()
- for _map in mapsB:
- for i in xrange(len(mapsA)):
- for j in xrange(len(mapsB)):
- relation = mapsB[j].temporal_relation(mapsA[i])
- if relation == "before":
- continue
- if relation == "equivalent":
- mapsB[j].append_equivalent(mapsA[i])
- mapsA[i].append_equivalent(mapsB[j])
- elif relation == "follows":
- mapsB[j].append_follows(mapsA[i])
- mapsA[i].append_precedes(mapsB[j])
- elif relation == "precedes":
- mapsB[j].append_precedes(mapsA[i])
- mapsA[i].append_follows(mapsB[j])
- elif relation == "during" or relation == "starts" or relation == "finishes":
- mapsB[j].append_during(mapsA[i])
- mapsA[i].append_contains(mapsB[j])
- elif relation == "contains" or relation == "started" or relation == "finished":
- mapsB[j].append_contains(mapsA[i])
- mapsA[i].append_during(mapsB[j])
- elif relation == "overlaps":
- mapsB[j].append_overlaps(mapsA[i])
- mapsA[i].append_overlapped(mapsB[j])
- elif relation == "overlapped":
- mapsB[j].append_overlapped(mapsA[i])
- mapsA[i].append_overlaps(mapsB[j])
+ """!Build the temporal topology structure between
+ two ordered lists of maps
- # Break if the next map follows and the over-next maps is after
- if relation == "follows":
- if j < len(mapsB) - 1:
- relation = mapsB[j + 1].temporal_relation(mapsA[i])
- if relation == "after":
- break
- # Break if the the next map is after
- break
- self._build_internal_iteratable(mapsA)
- self._build_iteratable(mapsB)
+ This method builds the temporal topology from mapsA to
+ mapsB and vice verse. The temporal topology structure of each map,
+ defined in class temporal_map_relations,
+ will be reseted and rebuild for mapsA and mapsB.
+ After building the temporal topology the modified
+ map objects of mapsA can be accessed
+ in the same way as a dictionary using there id.
+ The implemented iterator assures
+ the chronological iteration over the mapsA.
+ @param mapsA: A sorted list (by start_time) of abstract_dataset
+ @param mapsB: A sorted list (by start_time) of abstract_dataset
+ if mapsA == mapsB:
+ self.build(mapsA, True)
+ return
+ for map_ in mapsA:
+ map_.reset_temporal_topology()
+ for map_ in mapsB:
+ for i in xrange(len(mapsA)):
+ for j in xrange(len(mapsB)):
+ relation = mapsB[j].temporal_relation(mapsA[i])
+ if relation == "before":
+ continue
+ if relation == "equivalent":
+ mapsB[j].append_temporal_equivalent(mapsA[i])
+ mapsA[i].append_temporal_equivalent(mapsB[j])
+ elif relation == "follows":
+ mapsB[j].append_temporal_follows(mapsA[i])
+ mapsA[i].append_temporal_precedes(mapsB[j])
+ elif relation == "precedes":
+ mapsB[j].append_temporal_precedes(mapsA[i])
+ mapsA[i].append_temporal_follows(mapsB[j])
+ elif relation == "during" or relation == "starts" or \
+ relation == "finishes":
+ mapsB[j].append_temporal_during(mapsA[i])
+ mapsA[i].append_temporal_contains(mapsB[j])
+ elif relation == "contains" or relation == "started" or \
+ relation == "finished":
+ mapsB[j].append_temporal_contains(mapsA[i])
+ mapsA[i].append_temporal_during(mapsB[j])
+ elif relation == "overlaps":
+ mapsB[j].append_temporal_overlaps(mapsA[i])
+ mapsA[i].append_temporal_overlapped(mapsB[j])
+ elif relation == "overlapped":
+ mapsB[j].append_temporal_overlapped(mapsA[i])
+ mapsA[i].append_temporal_overlaps(mapsB[j])
+ # Break if the next map follows and the over-next maps is after
+ if relation == "follows":
+ if j < len(mapsB) - 1:
+ relation = mapsB[j + 1].temporal_relation(mapsA[i])
+ if relation == "after":
+ break
+ # Break if the the next map is after
+ break
+ self._build_internal_iteratable(mapsA)
+ self._build_iteratable(mapsB)
def build(self, maps):
- This method builds the temporal topology based on all maps in the provided map list.
- will be reseted and rebuild.
- After building the temporal topology the modified map objects can be accessed
- the chronological iteration over the maps.
- @param maps: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
- for _map in maps:
- offset = i + 1
- # The start time of map j is equal or later than map i
- maps[j].append_equivalent(maps[i])
- maps[i].append_equivalent(maps[j])
- maps[j].append_follows(maps[i])
- maps[i].append_precedes(maps[j])
- maps[j].append_during(maps[i])
- maps[i].append_contains(maps[j])
- elif relation == "started":
- # Consider equal start time, in case "started" map j contains map i
- maps[j].append_contains(maps[i])
- maps[i].append_during(maps[j])
- maps[j].append_overlaps(maps[i])
- maps[i].append_overlapped(maps[j])
- # Break if the last map follows
- if j < len(maps) - 1:
- relation = maps[j + 1].temporal_relation(maps[i])
- break
- break
- self._build_internal_iteratable(maps)
+ This method builds the temporal topology based on
+ all maps in the provided map list.
+ The temporal topology structure of each map,
+ will be reseted and rebuild.
+ modified map objects can be accessed
+ the chronological iteration over the maps.
+ @param maps: A sorted list (by start_time) of abstract_dataset
+ for map_ in maps:
+ offset = i + 1
+ # The start time of map j is equal or later than map i
+ maps[j].append_temporal_equivalent(maps[i])
+ maps[i].append_temporal_equivalent(maps[j])
+ maps[j].append_temporal_follows(maps[i])
+ maps[i].append_temporal_precedes(maps[j])
+ maps[j].append_temporal_during(maps[i])
+ maps[i].append_temporal_contains(maps[j])
+ elif relation == "started":
+ # Consider equal start time, in case
+ # "started" map j contains map i
+ maps[j].append_temporal_contains(maps[i])
+ maps[i].append_temporal_during(maps[j])
+ maps[j].append_temporal_overlaps(maps[i])
+ maps[i].append_temporal_overlapped(maps[j])
+ # Break if the last map follows
+ if j < len(maps) - 1:
+ relation = maps[j + 1].temporal_relation(maps[i])
+ break
+ break
+ self._build_internal_iteratable(maps)
def __iter__(self):
- _start = self._first
- while _start != None:
- yield _start
- _start = _start.next()
+ start_ = self._first
+ while start_ is not None:
+ yield start_
+ start_ = start_.temporal_next()
def __getitem__(self, index):
return self._store[index.get_id()]
@@ -269,86 +293,93 @@
def print_temporal_topology_relationships(maps1, maps2):
- """!Print the temporal relation matrix of the temporal ordered map lists maps1 and maps2
- to stdout.
- @param maps1: A sorted (by start_time) list of abstract_dataset objects with initiated temporal extent
- @param maps2: A sorted (by start_time) list of abstract_dataset objects with initiated temporal extent
+ """!Print the temporal relation matrix of the temporal ordered
+ map lists maps1 and maps2 to stdout.
+ @param maps1: A sorted (by start_time) list of abstract_dataset
+ @param maps2: A sorted (by start_time) list of abstract_dataset
identical = False
use_id = True
if maps1 == maps2:
- identical = True
- use_id = False
+ identical = True
+ use_id = False
for i in range(len(maps1)):
- if identical == True:
- start = i + 1
- else:
- start = 0
- for j in range(start, len(maps2)):
- relation = maps1[j].temporal_relation(maps2[i])
+ if identical == True:
+ start = i + 1
+ else:
+ start = 0
+ for j in range(start, len(maps2)):
+ relation = maps1[j].temporal_relation(maps2[i])
- if use_id == False:
- print maps2[j].base.get_name(), relation, maps1[i].base.get_name()
- else:
- print maps2[j].base.get_id(), relation, maps1[i].base.get_id()
+ if use_id == False:
+ print maps2[j].base.get_name(
+ ), relation, maps1[i].base.get_name()
+ else:
+ print maps2[j].base.get_id(), relation, maps1[i].base.get_id()
- if j < len(maps1) - 1:
- relation = maps1[j + 1].temporal_relation(maps2[i])
- break
- break
+ if j < len(maps1) - 1:
+ relation = maps1[j + 1].temporal_relation(maps2[i])
+ break
+ break
def count_temporal_topology_relationships(maps1, maps2):
"""!Count the temporal relations between the two lists of maps
- The map lists must be ordered by start time. Temporal relations are counted
- by analyzing the sparse (upper right side in case maps1 == maps2) temporal relationships matrix.
+ The map lists must be ordered by start time.
+ Temporal relations are counted by analyzing the sparse
+ (upper right side in case maps1 == maps2) temporal relationships matrix.
- @return A dictionary with counted temporal relationships
+ @return A dictionary with counted temporal relationships
tcount = {}
identical = False
if maps1 == maps2:
- identical = True
+ identical = True
- start = i + 1
- else:
- start = 0
+ if identical:
+ start = i + 1
+ else:
+ start = 0
- continue
- if tcount.has_key(relation):
- tcount[relation] = tcount[relation] + 1
- else:
- tcount[relation] = 1
+ continue
- break
- break
+ if relation in tcount:
+ tcount[relation] = tcount[relation] + 1
+ else:
+ tcount[relation] = 1
+ break
+ break
return tcount
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -32,7 +32,7 @@
from ctypes import *
# Uncomment this to detect the error
-#core.set_raise_on_error(True)
+core.set_raise_on_error(True)
@@ -43,13 +43,13 @@
dt = datetime(2001, 9, 1, 0, 0, 0)
string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
- dt1 = datetime(2003,2,18,12,5,0)
+ dt1 = datetime(2003, 2, 18, 12, 5, 0)
dt2 = increment_datetime_by_string(dt, string)
print dt
print dt2
- delta = dt1 -dt2
+ delta = dt1 - dt2
if delta.days != 0 or delta.seconds != 0:
core.fatal("increment computation is wrong %s" % (delta))
@@ -59,13 +59,13 @@
dt = datetime(2001, 11, 1, 0, 0, 0)
string = "1 months"
- dt1 = datetime(2001,12,1)
+ dt1 = datetime(2001, 12, 1)
print dt
print dt2
- delta = dt1 -dt2
+ delta = dt1 - dt2
@@ -75,13 +75,13 @@
string = "13 months"
- dt1 = datetime(2002,12,1)
+ dt1 = datetime(2002, 12, 1)
print dt
print dt2
- delta = dt1 -dt2
+ delta = dt1 - dt2
@@ -91,13 +91,13 @@
dt = datetime(2001, 1, 1, 0, 0, 0)
string = "72 months"
- dt1 = datetime(2007,1,1)
+ dt1 = datetime(2007, 1, 1)
print dt
print dt2
- delta = dt1 -dt2
+ delta = dt1 - dt2
@@ -108,11 +108,11 @@
# First test
print "Test 1"
- dt = datetime(2001, 8, 8, 12,30,30)
+ dt = datetime(2001, 8, 8, 12, 30, 30)
result = adjust_datetime_to_granularity(dt, "5 seconds")
- correct = datetime(2001, 8, 8, 12,30,30)
+ correct = datetime(2001, 8, 8, 12, 30, 30)
- delta = correct - result
+ delta = correct - result
core.fatal("Granularity adjustment computation is wrong %s" % (delta))
@@ -120,9 +120,9 @@
# Second test
print "Test 2"
result = adjust_datetime_to_granularity(dt, "20 minutes")
- correct = datetime(2001, 8, 8, 12,30,00)
+ correct = datetime(2001, 8, 8, 12, 30, 00)
@@ -130,9 +130,9 @@
# Third test
print "Test 2"
@@ -140,9 +140,9 @@
# 4. test
print "Test 4"
result = adjust_datetime_to_granularity(dt, "3 hours")
- correct = datetime(2001, 8, 8, 12,00,00)
+ correct = datetime(2001, 8, 8, 12, 00, 00)
@@ -150,9 +150,9 @@
# 5. test
print "Test 5"
result = adjust_datetime_to_granularity(dt, "5 days")
- correct = datetime(2001, 8, 8, 00,00,00)
+ correct = datetime(2001, 8, 8, 00, 00, 00)
@@ -160,9 +160,9 @@
# 6. test
print "Test 6"
result = adjust_datetime_to_granularity(dt, "2 weeks")
- correct = datetime(2001, 8, 6, 00,00,00)
+ correct = datetime(2001, 8, 6, 00, 00, 00)
@@ -170,9 +170,9 @@
# 7. test
print "Test 7"
result = adjust_datetime_to_granularity(dt, "6 months")
- correct = datetime(2001, 8, 1, 00,00,00)
+ correct = datetime(2001, 8, 1, 00, 00, 00)
@@ -180,19 +180,20 @@
# 8. test
print "Test 8"
result = adjust_datetime_to_granularity(dt, "2 years")
- correct = datetime(2001, 1, 1, 00,00,00)
+ correct = datetime(2001, 1, 1, 00, 00, 00)
# 9. test
print "Test 9"
- result = adjust_datetime_to_granularity(dt, "2 years, 3 months, 5 days, 3 hours, 3 minutes, 2 seconds")
+ result = adjust_datetime_to_granularity(
+ dt, "2 years, 3 months, 5 days, 3 hours, 3 minutes, 2 seconds")
@@ -200,9 +201,9 @@
# 10. test
print "Test 10"
result = adjust_datetime_to_granularity(dt, "3 months, 5 days, 3 minutes")
@@ -210,9 +211,9 @@
# 11. test
print "Test 11"
result = adjust_datetime_to_granularity(dt, "3 weeks, 5 days")
@@ -222,275 +223,274 @@
def test_compute_datetime_delta():
print "Test 1"
- start = datetime(2001, 1, 1, 00,00,00)
- end = datetime(2001, 1, 1, 00,00,00)
+ start = datetime(2001, 1, 1, 00, 00, 00)
+ end = datetime(2001, 1, 1, 00, 00, 00)
comp = compute_datetime_delta(start, end)
result = comp["second"]
correct = 0
if delta != 0:
core.fatal("Compute datetime delta is wrong %s" % (delta))
print "Test 2"
- start = datetime(2001, 1, 1, 00,00,14)
- end = datetime(2001, 1, 1, 00,00,44)
+ start = datetime(2001, 1, 1, 00, 00, 14)
+ end = datetime(2001, 1, 1, 00, 00, 44)
correct = 30
if delta != 0:
print "Test 3"
- start = datetime(2001, 1, 1, 00,00,44)
- end = datetime(2001, 1, 1, 00,01,14)
+ start = datetime(2001, 1, 1, 00, 00, 44)
+ end = datetime(2001, 1, 1, 00, 01, 14)
correct = 30
if delta != 0:
print "Test 4"
- start = datetime(2001, 1, 1, 00,00,30)
- end = datetime(2001, 1, 1, 00,05,30)
+ start = datetime(2001, 1, 1, 00, 00, 30)
+ end = datetime(2001, 1, 1, 00, 05, 30)
correct = 300
if delta != 0:
print "Test 5"
- end = datetime(2001, 1, 1, 00,01,00)
+ end = datetime(2001, 1, 1, 00, 01, 00)
result = comp["minute"]
correct = 1
if delta != 0:
print "Test 6"
- start = datetime(2011,10,31, 00,45,00)
- end = datetime(2011,10,31, 01,45,00)
+ start = datetime(2011, 10, 31, 00, 45, 00)
+ end = datetime(2011, 10, 31, 01, 45, 00)
correct = 60
if delta != 0:
print "Test 7"
- end = datetime(2011,10,31, 01,15,00)
+ end = datetime(2011, 10, 31, 01, 15, 00)
correct = 30
if delta != 0:
print "Test 8"
- end = datetime(2011,10,31, 12,15,00)
+ end = datetime(2011, 10, 31, 12, 15, 00)
correct = 690
if delta != 0:
print "Test 9"
- start = datetime(2011,10,31, 00,00,00)
- end = datetime(2011,10,31, 01,00,00)
+ start = datetime(2011, 10, 31, 00, 00, 00)
+ end = datetime(2011, 10, 31, 01, 00, 00)
result = comp["hour"]
correct = 1
if delta != 0:
print "Test 10"
- end = datetime(2011,11,01, 01,00,00)
+ end = datetime(2011, 11, 01, 01, 00, 00)
correct = 25
if delta != 0:
print "Test 11"
- start = datetime(2011,10,31, 12,00,00)
- end = datetime(2011,11,01, 06,00,00)
+ start = datetime(2011, 10, 31, 12, 00, 00)
+ end = datetime(2011, 11, 01, 06, 00, 00)
correct = 18
if delta != 0:
print "Test 12"
- start = datetime(2011,11,01, 00,00,00)
- end = datetime(2011,12,01, 01,00,00)
+ start = datetime(2011, 11, 01, 00, 00, 00)
+ end = datetime(2011, 12, 01, 01, 00, 00)
correct = 30 * 24 + 1
if delta != 0:
print "Test 13"
- end = datetime(2011,11,05, 00,00,00)
+ end = datetime(2011, 11, 05, 00, 00, 00)
result = comp["day"]
correct = 4
if delta != 0:
print "Test 14"
- start = datetime(2011,10,06, 00,00,00)
+ start = datetime(2011, 10, 06, 00, 00, 00)
correct = 30
if delta != 0:
print "Test 15"
- start = datetime(2011,12,02, 00,00,00)
- end = datetime(2012,01,01, 00,00,00)
+ start = datetime(2011, 12, 02, 00, 00, 00)
+ end = datetime(2012, 01, 01, 00, 00, 00)
correct = 30
if delta != 0:
print "Test 16"
- start = datetime(2011,01,01, 00,00,00)
- end = datetime(2011,02,01, 00,00,00)
+ start = datetime(2011, 01, 01, 00, 00, 00)
+ end = datetime(2011, 02, 01, 00, 00, 00)
result = comp["month"]
correct = 1
if delta != 0:
print "Test 17"
- start = datetime(2011,12,01, 00,00,00)
+ start = datetime(2011, 12, 01, 00, 00, 00)
correct = 1
if delta != 0:
print "Test 18"
- end = datetime(2012,06,01, 00,00,00)
+ end = datetime(2012, 06, 01, 00, 00, 00)
correct = 6
if delta != 0:
print "Test 19"
- start = datetime(2011,06,01, 00,00,00)
- end = datetime(2021,06,01, 00,00,00)
+ start = datetime(2011, 06, 01, 00, 00, 00)
+ end = datetime(2021, 06, 01, 00, 00, 00)
result = comp["year"]
correct = 10
if delta != 0:
print "Test 20"
- end = datetime(2012,06,01, 12,00,00)
+ end = datetime(2012, 06, 01, 12, 00, 00)
@@ -498,14 +498,14 @@
d = end - start
correct = 12 + d.days * 24
if delta != 0:
print "Test 21"
- end = datetime(2012,06,01, 12,30,00)
+ end = datetime(2012, 06, 01, 12, 30, 00)
@@ -513,14 +513,14 @@
d = end - start
correct = d.days * 24 * 60 + 12 * 60 + 30
if delta != 0:
print "Test 22"
- end = datetime(2012,06,01, 12,00,05)
+ end = datetime(2012, 06, 01, 12, 00, 05)
@@ -528,14 +528,14 @@
d = end - start
correct = 5 + 60 * 60 * 12 + d.days * 24 * 60 * 60
if delta != 0:
print "Test 23"
- end = datetime(2012,06,01, 00,30,00)
+ end = datetime(2012, 06, 01, 00, 30, 00)
@@ -543,14 +543,14 @@
d = end - start
correct = 30 + d.days * 24 * 60
if delta != 0:
print "Test 24"
- end = datetime(2012,06,01, 00,00,05)
+ end = datetime(2012, 06, 01, 00, 00, 05)
@@ -558,18 +558,16 @@
d = end - start
correct = 5 + d.days * 24 * 60 * 60
if delta != 0:
-def test_compute_relative_time_granularity():
+def test_compute_relative_time_granularity():
# First we test intervals
print "Test 1"
maps = []
fact = 5
@@ -577,7 +575,7 @@
end = start * fact
for i in range(6):
end = start * fact
- map = raster_dataset(None)
+ map = RasterDataset(None)
map.set_relative_time(start, end, "years")
maps.append(map)
start = end
@@ -586,15 +584,15 @@
gran = round(compute_relative_time_granularity(maps))
if fact - gran != 0:
core.fatal("Wrong granularity reference %i != gran %i" % (fact, gran))
print "Test 2"
maps = []
fact = 3
- start = 1.0/86400
+ start = 1.0 / 86400
end = start * fact
for i in range(10):
end = start * fact
maps.append(map)
start = end
@@ -610,11 +608,11 @@
start = 1
end = start + fact
for i in range(10):
- shift = i*2*fact
+ shift = i * 2 * fact
start = shift
end = start + fact
map.set_relative_time(start, end)
maps.append(map)
@@ -632,7 +630,7 @@
count = 0
for i in range(6):
end = start * fact
if count % 2 == 0:
else:
@@ -645,16 +643,16 @@
# Second we test points only
print "Test 5 points only"
maps = []
fact = 3
- start = 1.0/86400
for i in range(10):
- point = (i + 1)*fact*start
+ point = (i + 1) * fact * start
map.set_relative_time(point, None)
maps.append(map)
@@ -665,10 +663,8 @@
def test_compute_absolute_time_granularity():
print "Test 1"
maps = []
a = datetime(2001, 1, 1)
@@ -676,13 +672,14 @@
for i in range(10):
start = increment_datetime_by_string(a, increment, i)
end = increment_datetime_by_string(a, increment, i + 1)
map.set_absolute_time(start, end)
maps.append(map)
gran = compute_absolute_time_granularity(maps)
if increment != gran:
- core.fatal("Wrong granularity reference %s != gran %s" % (increment, gran))
+ core.fatal("Wrong granularity reference %s != gran %s" % (
+ increment, gran))
print "Test 2"
maps = []
@@ -691,13 +688,14 @@
for i in range(10):
maps.append(map)
+ increment, gran))
print "Test 3"
maps = []
@@ -706,13 +704,14 @@
for i in range(20):
maps.append(map)
+ increment, gran))
print "Test 4"
maps = []
@@ -721,13 +720,14 @@
for i in range(20):
maps.append(map)
+ increment, gran))
print "Test 3"
maps = []
@@ -736,13 +736,14 @@
for i in range(6):
maps.append(map)
+ increment, gran))
print "Test 4"
maps = []
@@ -751,13 +752,14 @@
for i in range(6):
maps.append(map)
+ increment, gran))
print "Test 5"
maps = []
@@ -766,14 +768,15 @@
for i in range(20):
maps.append(map)
increment = "1 days"
+ increment, gran))
print "Test 6"
maps = []
@@ -782,14 +785,15 @@
for i in range(20):
maps.append(map)
increment = "25 hours"
+ increment, gran))
print "Test 7"
maps = []
@@ -798,13 +802,14 @@
for i in range(20):
maps.append(map)
+ increment, gran))
print "Test 8"
maps = []
@@ -813,13 +818,14 @@
for i in range(20):
maps.append(map)
+ increment, gran))
print "Test 9"
maps = []
@@ -828,14 +834,15 @@
for i in range(20):
maps.append(map)
increment = "325 minutes"
+ increment, gran))
print "Test 10"
maps = []
@@ -844,195 +851,209 @@
for i in range(20):
maps.append(map)
increment = "330 seconds"
+ increment, gran))
print "Test 11"
maps = []
- a = datetime(2001,12,31)
+ a = datetime(2001, 12, 31)
increment = "60 minutes, 30 seconds"
for i in range(24):
maps.append(map)
increment = "3630 seconds"
+ increment, gran))
print "Test 12"
maps = []
- a = datetime(2001,12,31, 12, 30, 30)
+ a = datetime(2001, 12, 31, 12, 30, 30)
increment = "3600 seconds"
for i in range(24):
maps.append(map)
+ increment, gran))
- # Test absolute time points
+ # Test absolute time points
print "Test 13"
maps = []
for i in range(24):
end = None
maps.append(map)
+ increment, gran))
print "Test 14"
maps = []
- a = datetime(2001,12,31, 00, 00, 00)
+ a = datetime(2001, 12, 31, 00, 00, 00)
increment = "20 days"
for i in range(24):
end = None
maps.append(map)
+ increment, gran))
print "Test 15"
maps = []
- a = datetime(2001,12,01, 00, 00, 00)
+ a = datetime(2001, 12, 01, 00, 00, 00)
increment = "5 months"
for i in range(24):
end = None
maps.append(map)
+ increment, gran))
- # Test absolute time interval and points
+ # Test absolute time interval and points
print "Test 16"
maps = []
for i in range(24):
maps.append(map)
- a = datetime(2002,02,01, 12, 30, 30)
+ a = datetime(2002, 02, 01, 12, 30, 30)
for i in range(24):
end = None
maps.append(map)
+ increment, gran))
print "Test 17"
maps = []
- a = datetime(2001,1,1)
+ a = datetime(2001, 1, 1)
increment = "2 days"
for i in range(8):
maps.append(map)
- a = datetime(2001,02,02)
+ a = datetime(2001, 02, 02)
for i in range(8):
end = None
maps.append(map)
+ increment, gran))
def test_spatial_extent_intersection():
# Generate the extents
- A = spatial_extent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ A = SpatialExtent(
+ north=80, south=20, east=60, west=10, bottom=-50, top=50)
A.print_info()
- B = spatial_extent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ B = SpatialExtent(
B.print_info()
C = A.intersect(B)
C.print_info()
if C.get_north() != B.get_north() or C.get_south() != B.get_south() or \
- C.get_west() != B.get_west() or C.get_east() != B.get_east() or \
- C.get_bottom() != B.get_bottom() or C.get_top() != B.get_top():
+ C.get_west() != B.get_west() or C.get_east() != B.get_east() or \
+ C.get_bottom() != B.get_bottom() or C.get_top() != B.get_top():
core.fatal("Wrong intersection computation")
- B = spatial_extent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
+ north=40, south=30, east=60, west=10, bottom=-50, top=50)
B.print_info()
C = A.intersect(B)
C.print_info()
- B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
+ north=40, south=30, east=60, west=30, bottom=-50, top=50)
B.print_info()
C = A.intersect(B)
C.print_info()
- B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
+ north=40, south=30, east=60, west=30, bottom=-30, top=50)
B.print_info()
C = A.intersect(B)
C.print_info()
- B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
+ north=40, south=30, east=60, west=30, bottom=-30, top=30)
B.print_info()
C = A.intersect(B)
C.print_info()
@@ -1042,402 +1063,429 @@
def test_spatial_relations():
A.print_info()
B.print_info()
relation = A.spatial_relation(B)
print relation
- if relation!= "equivalent":
- core.fatal("Wrong spatial relation: %s"%(relation))
- B = spatial_extent(north=70, south=20, east=60, west=10, bottom=-50, top=50)
+ if relation != "equivalent":
+ core.fatal("Wrong spatial relation: %s" % (relation))
+ north=70, south=20, east=60, west=10, bottom=-50, top=50)
B.print_info()
relation = A.spatial_relation_2d(B)
print relation
- if relation!= "cover":
+ if relation != "cover":
print relation
- B = spatial_extent(north=70, south=30, east=60, west=10, bottom=-50, top=50)
+ north=70, south=30, east=60, west=10, bottom=-50, top=50)
B.print_info()
print relation
print relation
relation = B.spatial_relation_2d(A)
print relation
- if relation!= "covered":
+ if relation != "covered":
relation = B.spatial_relation(A)
print relation
- B = spatial_extent(north=70, south=30, east=50, west=10, bottom=-50, top=50)
+ north=70, south=30, east=50, west=10, bottom=-50, top=50)
B.print_info()
print relation
print relation
print relation
- B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-50, top=50)
+ north=70, south=30, east=50, west=20, bottom=-50, top=50)
print relation
B.print_info()
print relation
- if relation!= "contain":
+ if relation != "contain":
print relation
- B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-40, top=50)
+ north=70, south=30, east=50, west=20, bottom=-40, top=50)
B.print_info()
print relation
- B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-40, top=40)
+ north=70, south=30, east=50, west=20, bottom=-40, top=40)
B.print_info()
print relation
print relation
- if relation!= "in":
- B = spatial_extent(north=90, south=30, east=50, west=20, bottom=-40, top=40)
+ if relation != "in":
+ north=90, south=30, east=50, west=20, bottom=-40, top=40)
B.print_info()
print relation
- if relation!= "overlap":
+ if relation != "overlap":
print relation
- B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
+ B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
A.print_info()
B.print_info()
print relation
print relation
- B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
+ B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
A.print_info()
B.print_info()
print relation
- B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
+ B = SpatialExtent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
A.print_info()
B.print_info()
print relation
- A = spatial_extent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
+ north=80, south=60, east=60, west=10, bottom=-50, top=50)
A.print_info()
- B = spatial_extent(north=60, south=20, east=60, west=10, bottom=-50, top=50)
+ north=60, south=20, east=60, west=10, bottom=-50, top=50)
B.print_info()
print relation
- if relation!= "meet":
+ if relation != "meet":
print relation
- A = spatial_extent(north=60, south=40, east=60, west=10, bottom=-50, top=50)
+ north=60, south=40, east=60, west=10, bottom=-50, top=50)
A.print_info()
- B = spatial_extent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
B.print_info()
print relation
print relation
- A = spatial_extent(north=80, south=40, east=60, west=40, bottom=-50, top=50)
+ north=80, south=40, east=60, west=40, bottom=-50, top=50)
A.print_info()
- B = spatial_extent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
+ north=80, south=40, east=40, west=20, bottom=-50, top=50)
B.print_info()
print relation
print relation
- A = spatial_extent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
A.print_info()
- B = spatial_extent(north=90, south=30, east=60, west=40, bottom=-50, top=50)
+ north=90, south=30, east=60, west=40, bottom=-50, top=50)
B.print_info()
print relation
print relation
A.print_info()
- B = spatial_extent(north=70, south=50, east=60, west=40, bottom=-50, top=50)
+ north=70, south=50, east=60, west=40, bottom=-50, top=50)
B.print_info()
print relation
print relation
A.print_info()
- B = spatial_extent(north=60, south=20, east=60, west=40, bottom=-50, top=50)
+ north=60, south=20, east=60, west=40, bottom=-50, top=50)
B.print_info()
print relation
print relation
A.print_info()
- B = spatial_extent(north=40, south=20, east=60, west=40, bottom=-50, top=50)
+ north=40, south=20, east=60, west=40, bottom=-50, top=50)
B.print_info()
print relation
- if relation!= "disjoint":
+ if relation != "disjoint":
print relation
A.print_info()
- B = spatial_extent(north=60, south=20, east=60, west=40, bottom=-60, top=60)
+ north=60, south=20, east=60, west=40, bottom=-60, top=60)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=90, south=30, east=60, west=40, bottom=-40, top=40)
+ north=90, south=30, east=60, west=40, bottom=-40, top=40)
B.print_info()
print relation
- A = spatial_extent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+ A = SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
A.print_info()
- B = spatial_extent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+ B = SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=80, south=50, east=60, west=30, bottom=-50, top=0)
+ B = SpatialExtent(north=80, south=50, east=60, west=30, bottom=-50, top=0)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=70, south=50, east=50, west=30, bottom=-50, top=0)
+ B = SpatialExtent(north=70, south=50, east=50, west=30, bottom=-50, top=0)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=90, south=30, east=70, west=10, bottom=-50, top=0)
+ B = SpatialExtent(north=90, south=30, east=70, west=10, bottom=-50, top=0)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=70, south=30, east=50, west=10, bottom=-50, top=0)
+ B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=0)
B.print_info()
print relation
- A = spatial_extent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+ A = SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
A.print_info()
- B = spatial_extent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+ B = SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=80, south=50, east=60, west=30, bottom=0, top=50)
+ B = SpatialExtent(north=80, south=50, east=60, west=30, bottom=0, top=50)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=70, south=50, east=50, west=30, bottom=0, top=50)
+ B = SpatialExtent(north=70, south=50, east=50, west=30, bottom=0, top=50)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=90, south=30, east=70, west=10, bottom=0, top=50)
+ B = SpatialExtent(north=90, south=30, east=70, west=10, bottom=0, top=50)
B.print_info()
print relation
A.print_info()
- B = spatial_extent(north=70, south=30, east=50, west=10, bottom=0, top=50)
+ B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=0, top=50)
B.print_info()
print relation
def test_temporal_topology_builder():
map_listA = []
- _map = raster_dataset(ident = "1 at a")
+ _map = RasterDataset(ident="1 at a")
_map.set_absolute_time(datetime(2001, 01, 01), datetime(2001, 02, 01))
map_listA.append(copy.copy(_map))
- _map = raster_dataset(ident = "2 at a")
+ _map = RasterDataset(ident="2 at a")
_map.set_absolute_time(datetime(2001, 02, 01), datetime(2001, 03, 01))
- _map = raster_dataset(ident = "3 at a")
+ _map = RasterDataset(ident="3 at a")
_map.set_absolute_time(datetime(2001, 03, 01), datetime(2001, 04, 01))
- _map = raster_dataset(ident = "4 at a")
+ _map = RasterDataset(ident="4 at a")
_map.set_absolute_time(datetime(2001, 04, 01), datetime(2001, 05, 01))
- _map = raster_dataset(ident = "5 at a")
+ _map = RasterDataset(ident="5 at a")
_map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 06, 01))
@@ -1446,170 +1494,254 @@
count = 0
for _map in tb:
- print "[%s]"%(_map.get_name())
- if _map.get_id() != map_listA[count].get_id():
- core.fatal("Error building temporal topology <%s> != <%s>"%( _map.get_id(), map_listA[count].get_id()))
- count += 1
+ print "[%s]" % (_map.get_name())
+ if _map.get_id() != map_listA[count].get_id():
+ core.fatal("Error building temporal topology <%s> != <%s>" %
+ (_map.get_id(), map_listA[count].get_id()))
+ count += 1
map_listB = []
- _map = raster_dataset(ident = "1 at b")
+ _map = RasterDataset(ident="1 at b")
_map.set_absolute_time(datetime(2001, 01, 14), datetime(2001, 03, 14))
map_listB.append(copy.copy(_map))
- _map = raster_dataset(ident = "2 at b")
+ _map = RasterDataset(ident="2 at b")
_map.set_absolute_time(datetime(2001, 02, 01), datetime(2001, 04, 01))
- _map = raster_dataset(ident = "3 at b")
+ _map = RasterDataset(ident="3 at b")
_map.set_absolute_time(datetime(2001, 02, 14), datetime(2001, 04, 30))
- _map = raster_dataset(ident = "4 at b")
+ _map = RasterDataset(ident="4 at b")
_map.set_absolute_time(datetime(2001, 04, 02), datetime(2001, 04, 30))
- _map = raster_dataset(ident = "5 at b")
+ _map = RasterDataset(ident="5 at b")
_map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 05, 14))
tb.build(map_listB)
# Probing some relations
- if map_listB[0].get_overlapped()[0] != map_listB[1]:
- core.fatal("Error building temporal topology")
- if map_listB[0].get_overlapped()[1] != map_listB[2]:
- if map_listB[2].get_contains()[0] != map_listB[3]:
- if map_listB[3].get_during()[0] != map_listB[2]:
+ if map_listB[0].get_temporal_overlapped()[0] != map_listB[1]:
+ core.fatal("Error building temporal topology")
+ if map_listB[0].get_temporal_overlapped()[1] != map_listB[2]:
+ if map_listB[2].get_temporal_contains()[0] != map_listB[3]:
+ if map_listB[3].get_temporal_during()[0] != map_listB[2]:
count = 0
for _map in tb:
- print "[%s]"%(_map.get_map_id
- _map.print_temporal_topology_shell_info()
- if _map.get_id() != map_listB[count].get_id():
- core.fatal("Error building temporal topology <%s> != <%s>"%( _map.get_id(), map_listB[count].get_id()))
- count += 1
+ print "[%s]" % (_map.get_map_id
+ _map.print_temporal_topology_shell_info()
+ if _map.get_id() != map_listB[count].get_id():
+ (_map.get_id(), map_listB[count].get_id()))
+ count += 1
tb.build2(map_listA, map_listB)
count = 0
for _map in tb:
- print "[%s]"%(_map.get_map_id())
- count += 1
+ print "[%s]" % (_map.get_map_id())
+ count += 1
count = 0
for _map in map_listB:
- if map_listA[3].get_follows()[0] != map_listB[1]:
- if map_listA[3].get_precedes()[0] != map_listB[4]:
- if map_listA[3].get_overlaps()[0] != map_listB[2]:
- if map_listA[3].get_contains()[0] != map_listB[3]:
- if map_listA[2].get_during()[0] != map_listB[1]:
- if map_listA[2].get_during()[1] != map_listB[2]:
+ if map_listA[3].get_temporal_follows()[0] != map_listB[1]:
+ if map_listA[3].get_temporal_precedes()[0] != map_listB[4]:
+ if map_listA[3].get_temporal_overlaps()[0] != map_listB[2]:
+ if map_listA[3].get_temporal_contains()[0] != map_listB[3]:
+ if map_listA[2].get_temporal_during()[0] != map_listB[1]:
+ if map_listA[2].get_temporal_during()[1] != map_listB[2]:
def test_map_list_sorting():
map_list = []
map_list.append(copy.copy(_map))
print "Original"
for _map in map_list:
- print _map.get_valid_time()[0], _map.get_valid_time()[1]
+ print _map.get_valid_time()[0], _map.get_valid_time()[1]
print "Sorted by start time"
- new_list = sorted(map_list, key=abstract_dataset_comparison_key_start_time)
+ new_list = sorted(map_list, key=AbstractDatasetComparisonKeyStartTime)
for _map in new_list:
if new_list[0] != map_list[1]:
- core.fatal("Sorting by start time failed")
+ core.fatal("Sorting by start time failed")
if new_list[1] != map_list[0]:
if new_list[2] != map_list[2]:
print "Sorted by end time"
- new_list = sorted(map_list, key=abstract_dataset_comparison_key_end_time)
+ new_list = sorted(map_list, key=AbstractDatasetComparisonKeyEndTime)
- core.fatal("Sorting by end time failed")
+ core.fatal("Sorting by end time failed")
-def test_rtree():
+def test_1d_rtree():
"""Testing the rtree ctypes wrapper"""
tree = vector.RTreeNewIndex(-1, 0, 1)
- for i in xrange(50):
+ for i in xrange(10):
rect = vector.RTree_Rect()
- vector.RTreeInitRect(byref(rect))
+ # Allocate the boundary
+ vector.RTreeNewRect(byref(rect), tree)
+ vector.RTreeSetRect1D(byref(rect), tree, float(i - 2), float(i + 2))
+ vector.RTreeInsertRect(byref(rect), i + 1, tree)
- rect.boundary[0] = i - 3.75
- rect.boundary[1] = 0
- rect.boundary[2] = 0
- rect.boundary[3] = i + 3.75
- rect.boundary[4] = 0
- rect.boundary[5] = 0
+ rect = vector.RTree_Rect()
+ vector.RTreeSetRect1D(byref(rect), tree, 2.0, 7.0)
- # vector.RTreePrintRect(byref(rect), 0)
+ list_ = gis.ilist()
+ num = vector.RTreeSearch2(tree, byref(rect), byref(list_))
+ # print rectangle ids
+ print "Number of overlapping rectangles", num
+ for i in xrange(list_.n_values):
+ print "id", list_.value[i]
+def test_2d_rtree():
+ """Testing the rtree ctypes wrapper"""
+ tree = vector.RTreeNewIndex(-1, 0, 2)
+ vector.RTreeSetRect2D(byref(rect), tree,
+ float(i - 2), float(i + 2),
+ float(i - 2), float(i + 2))
+ vector.RTreeSetRect2D(byref(rect), tree, 2.0, 7.0, 2.0, 7.0)
- i = 25
- _list = gis.ilist()
- num = vector.RTreeSearch2(tree, byref(rect), byref(_list))
- # print rectanlge ids
+def test_3d_rtree():
+ tree = vector.RTreeNewIndex(-1, 0, 3)
+ vector.RTreeSetRect3D(byref(rect), tree,
+ print i + 1
+ vector.RTreePrintRect(byref(rect), 1, tree)
+ vector.RTreeSetRect3D(byref(rect), tree, 2.0, 7.0, 2.0, 7.0, 2.0, 7.0)
+ print "Select"
- for i in xrange(_list.n_values):
- print "id", _list.value[i]
+def test_4d_rtree():
+ tree = vector.RTreeNewIndex(-1, 0, 4)
+ rect = vector.RTreeNewRect(None, tree)
+ vector.RTreeSetRect4D(rect, tree,
+ vector.RTreeInsertRect(rect, i + 1, tree)
+ vector.RTreeSetRect4D(rect, tree, 2.0, 7.0, 2.0,
+ 7.0, 2.0, 7.0, 2.0, 7.0)
+ num = vector.RTreeSearch2(tree, rect, byref(list_))
if __name__ == "__main__":
@@ -1623,5 +1755,7 @@
- #test_rtree()
+ test_1d_rtree()
+ test_2d_rtree()
+ test_3d_rtree()
+ test_4d_rtree()
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2012-08-11 21:26:18 UTC (rev 52630)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2012-08-12 01:54:40 UTC (rev 52631)
@@ -9,7 +9,8 @@
@code
import grass.temporal as tgis
-tgis.print_gridded_dataset_univar_statistics(type, input, where, extended, header, fs)
+tgis.print_gridded_dataset_univar_statistics(
+ type, input, where, extended, header, fs)
@endcode
@@ -25,172 +26,208 @@
from space_time_datasets_tools import *
def print_gridded_dataset_univar_statistics(type, input, where, extended, header, fs):
"""!Print univariate statistics for a space time raster or raster3d dataset
- param type Must be "strds" or "str3ds"
+ @param type Must be "strds" or "str3ds"
@param input The name of the space time dataset
@param where A temporal database where statement
- @param extended If True compute extended statistics
- @param header If True print column names as header
- @param fs Field separator
+ @param extended If True compute extended statistics
+ @param header If True print column names as header
+ @param fs Field separator
# We need a database interface
dbif = SQLDatabaseInterfaceConnection()
dbif.connect()
- mapset = core.gisenv()["MAPSET"]
+ mapset = core.gisenv()["MAPSET"]
if input.find("@") >= 0:
id = input
else:
id = input + "@" + mapset
sp = dataset_factory(type, id)
if sp.is_in_db(dbif) == False:
dbif.close()
- core.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ core.fatal(_("Space time %s dataset <%s> not found") % (
+ sp.get_new_map_instance(None).get_type(), id))
sp.select(dbif)
- rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
+ rows = sp.get_registered_maps(
+ "id,start_time,end_time", where, "start_time", dbif)
if not rows:
dbif.close()
- core.fatal(_("Space time %s dataset <%s> is empty") % (sp.get_new_map_instance(None).get_type(), id))
+ core.fatal(_("Space time %s dataset <%s> is empty") % (
if header == True:
- print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
+ print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + \
print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
if extended == True:
- print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells" + fs,
- print "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
+ print "coeff_var" + fs + "sum" + fs + \
+ print "first_quartile" + fs + "median" + fs + \
else:
+ print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells"
for row in rows:
id = row["id"]
start = row["start_time"]
end = row["end_time"]
- flag="g"
+ flag = "g"
flag += "e"
- if type == "strds":
- stats = core.parse_command("r.univar", map=id, flags=flag)
- elif type == "str3ds":
- stats = core.parse_command("r3.univar", map=id, flags=flag)
+ if type == "strds":
+ stats = core.parse_command("r.univar", map=id, flags=flag)
+ elif type == "str3ds":
+ stats = core.parse_command("r3.univar", map=id, flags=flag)
print str(id) + fs + str(start) + fs + str(end),
- print fs + str(stats["mean"]) + fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
- print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
+ print fs + str(stats["mean"]) + fs + str(stats["min"]) + \
+ print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + \
- print fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs,
- print str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
+ print fs + str(stats["null_cells"]) + fs + str(
+ stats["cells"]) + fs,
+ print str(stats["first_quartile"]) + fs + str(stats["median"]) + \
+ fs + str(stats["third_quartile"]) + \
else:
dbif.close()
-def print_vector_dataset_univar_statistics(input, twhere, layer, type, column, where, extended, header, fs):
+def print_vector_dataset_univar_statistics(input, twhere, layer, type, column,
+ where, extended, header, fs):
"""!Print univariate statistics for a space time vector dataset
- @param input The name of the space time dataset
- @param twhere A temporal database where statement
- @param layer The layer number used in case no layer is present in the temporal dataset
- @param type options: point,line,boundary,centroid,area
- @param column The name of the attribute column
- @param where A temporal database where statement
+ @param input: The name of the space time dataset
+ @param twhere: A temporal database where statement
+ @param layer: The layer number used in case no layer is present
+ in the temporal dataset
+ @param type: options: point,line,boundary,centroid,area
+ @param column: The name of the attribute column
+ @param where: A temporal database where statement
+ @param extended: If True compute extended statistics
+ @param header: If True print column names as header
+ @param fs: Field separator
dbif.connect()
id = input
else:
sp = dataset_factory("stvds", id)
dbif.close()
sp.select(dbif)
- rows = sp.get_registered_maps("id,name,mapset,start_time,end_time,layer", twhere, "start_time", dbif)
+ rows = sp.get_registered_maps("id,name,mapset,start_time,end_time,layer",
+ twhere, "start_time", dbif)
if not rows:
dbif.close()
string = ""
if header == True:
- string += "id" + fs + "start" + fs + "end" + fs + "n" + fs + "nmissing" + fs + "nnull" + fs
+ string += "id" + fs + "start" + fs + "end" + fs + "n" + \
string += "min" + fs + "max" + fs + "range"
- if type == "point" or type == "centroid":
- string += fs + "mean" + fs + "mean_abs" + fs + "population_stddev" + fs + "population_variance" + fs
- string += "population_coeff_variation" + fs + "sample_stddev" + fs + "sample_variance" + fs
- string += "kurtosis" + fs + "skewness"
+ if type == "point" or type == "centroid":
+ string += fs + "mean" + fs + "mean_abs" + fs + "population_stddev" +\
+ string += "population_coeff_variation" + fs + \
+ string += "kurtosis" + fs + "skewness"
- string+= fs + "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
+ string += fs + "first_quartile" + fs + "median" + fs + \
- print string
+ print string
for row in rows:
id = row["name"] + "@" + row["mapset"]
- mylayer = row["layer"]
+ mylayer = row["layer"]
- flags="g"
+ flags = "g"
flags += "e"
- if not mylayer:
- mylayer = layer
+ if not mylayer:
+ mylayer = layer
- stats = core.parse_command("v.univar", map=id, where=where, column=column, layer=mylayer, type=type, flags=flags)
+ stats = core.parse_command("v.univar", map=id, where=where,
+ column=column, layer=mylayer,
+ type=type, flags=flags)
- string = ""
- if stats:
+ string = ""
+ if stats:
string += str(id) + fs + str(start) + fs + str(end)
- string += fs + str(stats["n"]) + fs + str(stats["nmissing"]) + fs + str(stats["nnull"])
- if stats.has_key("min"):
- string += fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["range"])
- else:
- string += fs + fs + fs
+ string += fs + str(stats["n"]) + fs + str(stats[
+ "nmissing"]) + fs + str(stats["nnull"])
+ if "min" in stats:
+ string += fs + str(stats["min"]) + fs + str(
+ stats["max"]) + fs + str(stats["range"])
+ else:
+ string += fs + fs + fs
- if stats.has_key("mean"):
- string += fs + str(stats["mean"]) + fs + str(stats["mean_abs"]) + fs + str(stats["population_stddev"]) + fs + str(stats["population_variance"])
- string += fs + str(stats["population_coeff_variation"]) + fs + str(stats["sample_stddev"]) + fs + str(stats["sample_variance"])
- string += fs + str(stats["kurtosis"]) + fs + str(stats["skewness"])
- else:
- string += fs + fs + fs + fs + fs + fs + fs + fs + fs
+ if "mean" in stats:
+ string += fs + str(stats["mean"]) + fs + \
+ str(stats["mean_abs"]) + fs + \
+ str(stats["population_stddev"]) + fs + \
+ string += fs + str(stats["population_coeff_variation"]) + \
+ fs + str(stats["sample_stddev"]) + fs + \
+ string += fs + str(stats["kurtosis"]) + fs + \
+ else:
+ string += fs + fs + fs + fs + fs + fs + fs + fs + fs
- if stats.has_key("first_quartile"):
- string += fs + str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
- else:
- print string
+ if "first_quartile" in stats:
+ string += fs + str(stats["first_quartile"]) + fs + \
+ str(stats["median"]) + fs + \
+ str(stats["third_quartile"]) + fs + \
+ else:
+ print string
dbif.close()
