[GRASS-SVN] r52632 - in grass/trunk/scripts: . i.pansharpen
Sat Aug 11 23:14:49 PDT 2012
Author: cmbarton
Date: 2012-08-11 23:14:49 -0700 (Sat, 11 Aug 2012)
New Revision: 52632
Added:
   grass/trunk/scripts/i.pansharpen/
   grass/trunk/scripts/i.pansharpen/Makefile
   grass/trunk/scripts/i.pansharpen/i.pansharpen.html
   grass/trunk/scripts/i.pansharpen/i.pansharpen.py
   grass/trunk/scripts/i.pansharpen/rgb_brovey321.jpg
   grass/trunk/scripts/i.pansharpen/rgb_ihs321.jpg
   grass/trunk/scripts/i.pansharpen/rgb_landsat321.jpg
   grass/trunk/scripts/i.pansharpen/rgb_pca321.jpg
Added new pan sharpening script
Added: grass/trunk/scripts/i.pansharpen/Makefile
--- grass/trunk/scripts/i.pansharpen/Makefile	                        (rev 0)
+++ grass/trunk/scripts/i.pansharpen/Makefile	2012-08-12 06:14:49 UTC (rev 52632)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=i.pansharpen
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass/trunk/scripts/i.pansharpen/i.pansharpen.html
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.html	                        (rev 0)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.html	2012-08-12 06:14:49 UTC (rev 52632)
@@ -0,0 +1,189 @@
+<h2>DESCRIPTION</h2>
+<em><b>i.pansharpen</b></em> uses a high resolution panchromatic band from a
+multispectral image to sharpen 3 lower resolution bands. The 3
+lower resolution bands can then be combined into an RGB color image at a
+higher (more detailed) resolution than is possible using the original 3
+bands. For example, Landsat ETM has low resolution spectral bands 1 (blue),
+2 (green), 3 (red), 4 (near IR), 5 (mid-IR), and 7 (mid-IR) at 30m resolution,
+and a high resolution panchromatic band 8 at 15m resolution. Pan sharpening
+allows bands 3-2-1 (or other combinations of 30m resolution bands like 4-3-2
+or 5-4-2) to be combined into a 15m resolution color image.
+<br><br>
+i.pansharpen offers a choice of three different 'pan sharpening'
+algorithms: IHS, Brovey, and PCA.
+<br><br>
+For <em>IHS pan sharpening</em>, the original 3 lower resolution bands, selected
+as red, green and blue channels for creating an RGB composite image, are
+transformed into IHS (intensity, hue, and saturation) color space. The
+panchromatic band is then substituted for the intensity channel (I), combined
+with the original hue (H) and saturation (S) channels, and transformed back to
+RGB color space at the higher resolution of the panchromatic band. The
+algorithm for this can be represented as: RGB -> IHS -> [pan]HS -> RGB.
+<br><br>
+With a <em>Brovey pan sharpening</em>, each of the 3 lower resolution bands and
+panchromatic band are combined using the following algorithm to calculate
+3 new bands at the higher resolution (example for band 1):
+<pre>
+                         band1
+    new band1 = ----------------------- * panband
+                 band1 + band2 + band3
+</pre>
+In <em>PCA pan sharpening</em>, a principal component analysis is performed on the
+original 3 lower resolution bands to create 3 principal component images
+(PC1, PC2, and PC3) and their associated eigenvectors (EV), such that:
+<pre>
+     band1  band2  band3
+PC1: EV1-1  EV1-2  EV1-3
+PC2: EV2-1  EV2-2  EV2-3
+PC3: EV3-1  EV3-2  EV3-3
+and
+PC1 = EV1-1 * band1 + EV1-2 * band2 + EV1-3 * band3 - mean(bands 1,2,3)
+</pre>
+An inverse PCA is then performed, substituting the panchromatic band for PC1.
+To do this, the eigenvectors matrix is inverted (in this case transposed), the
+PC images are multiplied by the eigenvectors with the panchromatic band
+substituted for PC1, and mean of each band is added to each transformed image
+band using the following algorithm (example for band 1):
+<pre>
+band1' = pan * EV1-1 + PC2 * EV2-1 + PC3 * EV3-1 + mean(band1)
+</pre>
+The assignment of the channels depends on the satellite. Examples of satellite
+imagery with high resolution panchromatic bands, and lower resolution spectral
+bands include Landsat 7 ETM, QuickBird, and SPOT.
+<br>
+<h2>NOTES</h2>
+The command temporarily changes the computational region to the high
+resolution of the panchromatic band during sharpening calculations, then
+restores the previous region settings. The current region coordinates (and
+null values) are respected. The high resolution panchromatic image is
+histogram matched to the band it is replaces prior to substitution (i.e., the
+intensity channel for IHS sharpening, the low res band selected for each color
+channel with Brovey sharpening, and the PC1 image for PCA sharpening).
+<br><br>
+By default, the command will attempt to employ parallel processing, using
+up to 3 cores simultaneously. The -s flag will disable parallel processing,
+but does use an optimized r.mapcalc expression to reduce disk I/O.
+<br><br>
+The three pan-sharpened output channels may be combined with <em>d.rgb</em> or
+<em>r.composite</em>. Colors may be optionally optimized with <em>i.landsat.rgb</em>.
+While the resulting color image will be at the higher resolution in all cases,
+the 3 pan sharpening algorithms differ in terms of spectral response.
+<h2>EXAMPLE</h2>
+Pan sharpening of a Landsat image from Boulder, Colorado, USA:
+<div class="code"><pre>
+# R, G, B composite at 30m
+d.rgb b=p034r032_7dt20010924_z13_10 g=lp034r032_7dt20010924_z13_20
+    r=p034r032_7dt20010924_z13_30
+# i.pansharpen with IHS algorithm
+i.pansharpen ms3=p034r032_7dt20010924_z13_30 ms2=p034r032_7dt20010924_z13_20
+    ms1=p034r032_7dt20010924_z13_10 pan=p034r032_7dp20010924_z13_80
+    output_prefix=ihs321 sharpen=ihs
+# display at 15m
+d.rgb b=ihs321_blue g=ihs321_green r=ihs321_red
+</pre></div>
+<b><em>Results:</em></b>
+<p><center>
+  <table border=1>
+  <tr>
+    <td align=center>
+       <img src="rgb_landsat321.jpg" alt="R, G, B composite of Landsat at 30m">
+      <br>
+      <font size="-1">
+      <i>R, G, B composite of Landsat at 30m</i>
+      </font>
+    </td>
+    <td align=center>
+       <img src="rgb_brovey321.jpg" alt="R, G, B composite of Brovey sharpened image at 15m">
+      <br>
+      <font size="-1">
+      <i>R, G, B composite of Brovey sharpened image at 15m</i>
+      </font>
+    </td>
+  </tr>
+  <tr>
+    <td align=center>
+       <img src="rgb_ihs321.jpg" alt="R, G, B composite of IHS sharpened image at 15m">
+      <br>
+      <font size="-1">
+      <i>R, G, B composite of IHS sharpened image at 15m</i>
+      </font>
+    </td>
+    <td align=center>
+       <img src="rgb_pca321.jpg" alt="R, G, B composite of PCA sharpened image at 15m">
+      <br>
+      <font size="-1">
+      <i>R, G, B composite of PCA sharpened image at 15m"</i>
+      </font>
+    </td>
+  </tr>
+  </table>
+</center>
+<br>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.his.rgb.html">i.his.rgb</a>,
+<a href="i.rgb.his.html">i.rgb.his</a>,
+<a href="i.pca">i.pca</a>,
+<a href="d.rgb.html">d.rgb</a>,
+<a href="r.composite.html">r.composite</a>
+</em>
+<h2>REFERENCES</h2>
+<ul>
+<li>Original Brovey formula reference unknown, probably... <br>
+   Roller, N.E.G. and Cox, S., (1980). Comparison of Landsat MSS
+   and merged MSS/RBV data for analysis of natural vegetation.
+   Proc. of the 14th International Symposium on Remote Sensing
+   of Environment, San Jose, Costa Rica, 23-30 April, pp. 1001-1007
+<li>Amarsaikhan, D., & Douglas, T. (2004). Data fusion and multisource image
+   classification. International Journal of Remote Sensing, 25(17), 3529-3539.
+<li>Behnia, P. (2005). Comparison between four methods for data fusion of ETM+
+   multispectral and pan images. Geo-spatial Information Science, 8(2), 98-103.
+<li>Du, Q., Younan, N. H., King, R., & Shah, V. P. (2007). On the Performance
+   Evaluation of Pan-Sharpening Techniques. Geoscience and Remote Sensing
+   Letters, IEEE, 4(4), 518-522.
+<li>Karathanassi, V., Kolokousis, P., & Ioannidou, S. (2007). A comparison
+   study on fusion methods using evaluation indicators. International Journal
+   of Remote Sensing, 28(10), 2309-2341.
+<li>Neteler, M, D. Grasso, I. Michelazzi, L. Miori, S. Merler, and C.
+   Furlanello (2005). An integrated toolbox for image registration, fusion and
+   classification. International Journal of Geoinformatics, 1(1):51-61
+   (<a href="http://www.grassbook.org/neteler/papers/neteler2005_IJG_051-061_draft.pdf">PDF</a>)
+<li>Pohl, C, and J.L van Genderen (1998). Multisensor image fusion in remote
+    sensing: concepts, methods and application. Int. J. of Rem. Sens., 19, 823-854.
+</ul>
+<h2>AUTHORS</h2>
+Michael Barton (Arizona State University, USA)--with contributions from Markus
+Neteler (ITC-irst, Italy); Glynn Clements; Luca Delucchi (Fondazione E. Mach,
+Italy); Markus Metz; and Hamish Bowman.
+<p><i>Last changed: $Date: $</i>
Added: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py	                        (rev 0)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2012-08-12 06:14:49 UTC (rev 52632)
@@ -0,0 +1,435 @@
+#!/usr/bin/env python
+# MODULE:	    i.pansharpen
+# AUTHOR(S):    Overall script by Michael Barton (ASU)
+#               Brovey transformation in i.fusion.brovey by Markus Neteler <<neteler at osgeo org>>
+#               i.fusion brovey converted to Python by Glynn Clements
+#               IHS and PCA transformation added by Michael Barton (ASU)
+#               histogram matching algorithm by Michael Barton and Luca Delucchi, Fondazione E. Mach (Italy)
+#               Thanks to Markus Metz for help with PCA inversion
+#               Thanks to Hamish Bowman for parallel processing algorithm
+# PURPOSE:	Sharpening of 3 RGB channels using a high-resolution panchromatic channel
+# COPYRIGHT:	(C) 2002-2012 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+# REFERENCES:
+#   Roller, N.E.G. and Cox, S., 1980. Comparison of Landsat MSS and merged MSS/RBV
+#   data for analysis of natural vegetation. Proc. of the 14th International
+#   Symposium on Remote Sensing of Environment, San Jose, Costa Rica, 23-30 April, pp. 1001-1007.
+#   Amarsaikhan, D., & Douglas, T. (2004). Data fusion and multisource image classification.
+#   International Journal of Remote Sensing, 25(17), 3529-3539.
+#   Behnia, P. (2005). Comparison between four methods for data fusion of ETM+
+#   multispectral and pan images. Geo-spatial Information Science, 8(2), 98-103
+#   for LANDSAT 5: see Pohl, C 1996 and others
+#%Module
+#%  description: Image fusion algorithms to sharpen multispectral with high-res panchromatic channels
+#%  keywords: imagery
+#%  keywords: fusion
+#%  keywords: sharpen
+#%  keywords: Brovey
+#%  keywords: IHS
+#%  keywords: PCA
+#%  overwrite: yes
+#%End
+#%option
+#%  key: sharpen
+#%  description: Choose pan sharpening method
+#%  options: brovey,ihs,pca
+#%  answer: ihs
+#%  required: yes
+#%end
+#%option G_OPT_R_INPUT
+#%  key: ms3
+#%  description: Input raster map for red channel
+#%end
+#%  key: ms2
+#%  description: Input raster map for green channel
+#%end
+#%  key: ms1
+#%  description: Input raster map for blue channel
+#%end
+#%  option G_OPT_R_INPUT
+#%  key: pan
+#%  description: Input raster map for high resolution panchromatic channel
+#%end
+#%option
+#%  key: output_prefix
+#%  type: string
+#%  description: Prefix for output raster maps
+#%  required : yes
+#%end
+#%flag
+#%  key: s
+#%  description: Serial processing rather than parallel processing
+#%end
+#%flag
+#%  key: l
+#%  description: Rebalance blue channel for landsat maps
+#%end
+import sys
+import os
+import numpy as np
+import grass.script as grass
+def main():
+    sharpen   = options['sharpen'] # sharpening algorithm
+    ms1       = options['ms1'] # blue channel
+    ms2       = options['ms2'] # green channel
+    ms3       = options['ms3'] # red channel
+    pan       = options['pan'] # high res pan channel
+    out       = options['output_prefix'] # prefix for output RGB maps
+    bladjust  = flags['l'] # adjust blue channel
+    sproc     = flags['s'] # serial processing
+    outb = grass.core.find_file('%s_blue' % out)
+    outg = grass.core.find_file('%s_green' % out)
+    outr = grass.core.find_file('%s_red' % out)
+    if (outb['name'] != '' or outg['name'] != '' or outr['name'] != '') and \
+        (not grass.overwrite() and not flags['o']):
+        grass.warning(_('Maps with selected output prefix names already exist. \
+                        Delete them or use overwrite flag'))
+        return
+    pid = str(os.getpid())
+    #get PAN resolution:
+    kv = grass.raster_info(map = pan)
+    nsres = kv['nsres']
+    ewres = kv['ewres']
+    panres = (nsres + ewres) / 2
+    # clone current region
+    grass.use_temp_region()
+    grass.run_command('g.region', res = panres, align = pan)
+    grass.message('\n ')
+    grass.message(_("Performing pan sharpening with hi res pan image: %f" % panres))
+    if sharpen == "brovey":
+        grass.message(_("Using Brovey algorithm"))
+        #pan/intensity histogram matching using linear regression
+        outname = 'tmp%s_pan1' % pid
+        panmatch1 = matchhist(pan, ms1, outname)
+        outname = 'tmp%s_pan2' % pid
+        panmatch2 = matchhist(pan, ms2, outname)
+        outname = 'tmp%s_pan3' % pid
+        panmatch3 = matchhist(pan, ms3, outname)
+        outr = '%s_red' % out
+        outg = '%s_green' % out
+        outb = '%s_blue' % out
+        #calculate brovey transformation
+        grass.message(_("Calculating Brovey transformation..."))
+        if sproc:
+            # serial processing
+            e = '''eval(k = "$ms1" + "$ms2" + "$ms3")
+                "$outr" = "$ms3" * "$panmatch3" / k
+                "$outg" = "$ms2" * "$panmatch2" / k
+                "$outb" = "$ms1" * "$panmatch1" / k'''
+            grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
+                          panmatch1=panmatch1, panmatch2=panmatch2, panmatch3=panmatch3,
+                          ms1=ms1, ms2=ms2, ms3=ms3, overwrite=True)
+        else:
+            # parallel processing
+            pb = grass.mapcalc_start('%s_blue = (%s * %s) / (%s + %s + %s)' %
+                                (out, ms1, panmatch1, ms1, ms2, ms3),
+                                overwrite=True)
+            pg = grass.mapcalc_start('%s_green = (%s * %s) / (%s + %s + %s)' %
+                                (out, ms2, panmatch2, ms1, ms2, ms3),
+                                overwrite=True)
+            pr = grass.mapcalc_start('%s_red = (%s * %s) / (%s + %s + %s)' %
+                                (out, ms3, panmatch3, ms1, ms2, ms3),
+                                overwrite=True)
+            pb.wait()
+            pg.wait()
+            pr.wait()
+        # Cleanup
+        grass.run_command('g.remove', quiet=True, rast='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
+    elif sharpen == "ihs":
+        grass.message(_("Using IHS<->RGB algorithm"))
+        #transform RGB channels into IHS color space
+        grass.message(_("Transforming to IHS color space..."))
+        grass.run_command('i.rgb.his', overwrite=True,
+                          red_input=ms3,
+                          green_input=ms2,
+                          blue_input=ms1,
+                          hue_output="tmp%s_hue" % pid,
+                          intensity_output="tmp%s_int" % pid,
+                          saturation_output="tmp%s_sat" % pid)
+        target = "tmp%s_int" % pid
+        outname = "tmp%s_pan_int" % pid
+        panmatch = matchhist(pan, target, outname)
+        #substitute pan for intensity channel and transform back to RGB color space
+        grass.message(_("Transforming back to RGB color space and sharpening..."))
+        grass.run_command('i.his.rgb', overwrite=True,
+                          hue_input="tmp%s_hue" % pid,
+                          intensity_input="%s" % panmatch,
+                          saturation_input="tmp%s_sat" % pid,
+                          red_output="%s_red" % out,
+                          green_output="%s_green" % out,
+                          blue_output="%s_blue" % out)
+        # Cleanup
+        grass.run_command('g.remove', quiet=True, rast=panmatch)
+    elif sharpen == "pca":
+        grass.message(_("Using PCA/inverse PCA algorithm"))
+        grass.message(_("Creating PCA images and calculating eigenvectors..."))
+        #initial PCA with RGB channels
+        pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0', input='%s,%s,%s' % (ms1, ms2, ms3), output_prefix='tmp%s.pca' % pid)
+        b1evect = []
+        b2evect = []
+        b3evect = []
+        for l in pca_out.replace('(',',').replace(')',',').splitlines():
+            b1evect.append(float(l.split(',')[1]))
+            b2evect.append(float(l.split(',')[2]))
+            b3evect.append(float(l.split(',')[3]))
+        #inverse PCA with hi res pan channel substituted for principal component 1
+        pca1 = 'tmp%s.pca.1' % pid
+        pca2 = 'tmp%s.pca.2' % pid
+        pca3 = 'tmp%s.pca.3' % pid
+        b1evect1 = b1evect[0]
+        b1evect2 = b1evect[1]
+        b1evect3 = b1evect[2]
+        b2evect1 = b2evect[0]
+        b2evect2 = b2evect[1]
+        b2evect3 = b2evect[2]
+        b3evect1 = b3evect[0]
+        b3evect2 = b3evect[1]
+        b3evect3 = b3evect[2]
+        outname = 'tmp%s_pan' % pid
+        panmatch = matchhist(pan, ms1, outname)
+        grass.message(_("Performing inverse PCA ..."))
+        stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
+                                           parse=(grass.parse_key_val, { 'sep' : '=' }))
+        stats2 = grass.parse_command("r.univar", map=ms2, flags='g',
+        stats3 = grass.parse_command("r.univar", map=ms3, flags='g',
+        b1mean = float(stats1['mean'])
+        b2mean = float(stats2['mean'])
+        b3mean = float(stats3['mean'])
+        if sproc:
+            cmd1 = "$outb = ($panmatch * $b1evect1) + ($pca2 * $b2evect1) + ($pca3 * $b3evect1) + $b1mean"
+            cmd2 = "$outg = ($panmatch * $b1evect2) + ($pca2 * $b2evect1) + ($pca3 * $b3evect2) + $b2mean"
+            cmd3 = "$outr = ($panmatch * $b1evect3) + ($pca2 * $b2evect3) + ($pca3 * $b3evect3) + $b3mean"
+            cmd =  '\n'.join([cmd1, cmd2, cmd3])
+            grass.mapcalc(cmd, outb=outb, outg=outg, outr=outr,
+                          panmatch=panmatch, pca2=pca2, pca3=pca3,
+                          b1evect1=b1evect1, b2evect1=b2evect1, b3evect1=b3evect1,
+                          b1evect2=b1evect2, b2evect2=b2evect2, b3evect2=b3evect2,
+                          b1evect3=b1evect3, b2evect3=b2evect3, b3evect3=b3evect3,
+                          b1mean=b1mean, b2mean=b2mean, b3mean=b3mean,
+                          overwrite=True)
+        else:
+            pb = grass.mapcalc_start('%s_blue = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+                          % (out, panmatch, b1evect1, pca2, b2evect1, pca3, b3evect1, b1mean),
+                          overwrite=True)
+            pg = grass.mapcalc_start('%s_green = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+                          % (out, panmatch, b1evect2, pca2, b2evect2, pca3, b3evect2, b2mean),
+                          overwrite=True)
+            pr = grass.mapcalc_start('%s_red = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+                          % (out, panmatch, b1evect3, pca2, b2evect3, pca3, b3evect3, b3mean),
+                          overwrite=True)
+            pr.wait()
+            pg.wait()
+            pb.wait()
+        # Cleanup
+        grass.run_command('g.mremove', flags='f', quiet=True, rast='tmp%s*,%s' % (pid,panmatch))
+    #Could add other sharpening algorithms here, e.g. wavelet transformation
+    grass.message(_("Assigning grey equalized color tables to output images..."))
+    #equalized grey scales give best contrast
+    for ch in ['red', 'green', 'blue']:
+        grass.run_command('r.colors', quiet=True, map = "%s_%s" % (out, ch), flags="e", col = 'grey')
+    #Landsat too blue-ish because panchromatic band less sensitive to blue light,
+    #  so output blue channed can be modified
+    if bladjust:
+        grass.message(_("Adjusting blue channel color table..."))
+        rules = grass.tempfile()
+        colors = open(rules, 'w')
+        colors.write('5 0 0 0\n20 200 200 200\n40 230 230 230\n67 255 255 255 \n')
+        colors.close()
+        grass.run_command('r.colors', map="%s_blue" % out, rules=rules)
+        os.remove(rules)
+    #output notice
+    grass.message(_("The following pan-sharpened output maps have been generated:"))
+        grass.message(_("%s_%s") % (out, ch))
+    grass.message(_("To visualize output, run: g.region -p rast=%s.red" % out))
+    grass.message(_("d.rgb r=%s_red g=%s_green b=%s_blue" % (out, out, out)))
+    grass.message(_("If desired, combine channels into a single RGB map with 'r.composite'."))
+    grass.message(_("Channel colors can be rebalanced using i.landsat.rgb."))
+    # write cmd history:
+        grass.raster_history("%s_%s" % (out, ch))
+    # Cleanup
+    grass.run_command('g.mremove', flags="f", rast="tmp%s*" % pid, quiet=True)
+def matchhist(original, target, matched):
+    #pan/intensity histogram matching using numpy arrays
+    grass.message(_("Histogram matching..."))
+    # input images
+    original = original.split('@')[0]
+    target = target.split('@')[0]
+    images = [original, target]
+    # create a dictionary to hold arrays for each image
+    arrays = {}
+    for i in images:
+        # calculate number of cells for each grey value for for each image
+        stats_out = grass.pipe_command('r.stats', flags='cin', input= i, fs=':')
+        stats =  stats_out.communicate()[0].split('\n')[:-1]
+        stats_dict = dict( s.split(':', 1) for s in stats)
+        total_cells = 0 # total non-null cells
+        for j in stats_dict:
+            stats_dict[j] = int(stats_dict[j])
+            if j != '*':
+                total_cells += stats_dict[j]
+        # Make a 2x256 structured array for each image with a
+        #   cumulative distribution function (CDF) for each grey value.
+        #   Grey value is the integer (i4) and cdf is float (f4).
+        arrays[i] = np.zeros((256,),dtype=('i4,f4'))
+        cum_cells = 0 # cumulative total of cells for sum of current and all lower grey values
+        for n in range(0,256):
+            if str(n) in stats_dict:
+                num_cells = stats_dict[str(n)]
+            else:
+                num_cells = 0
+            cum_cells += num_cells
+            # cdf is the the number of cells at or below a given grey value
+            #   divided by the total number of cells
+            cdf = float(cum_cells) / float(total_cells)
+            # insert values into array
+            arrays[i][n] = (n, cdf)
+    # open file for reclass rules
+    outfile = open(grass.tempfile(), 'w')
+    new_grey = 0
+    for i in arrays[original]:
+        # for each grey value and corresponding cdf value in original, find the
+        #   cdf value in target that is closest to the target cdf value
+        difference_list = []
+        for j in arrays[target]:
+            # make a list of the difference between each original cdf value and
+            #   the target cdf value
+            difference_list.append(abs(i[1] - j[1]))
+        # get the smallest difference in the list
+        min_difference = min(difference_list)
+            # find the grey value in target that correspondes to the cdf
+            #   closest to the original cdf
+            if j[1] == i[1] + min_difference or j[1] == i[1] - min_difference:
+                # build a reclass rules file from the original grey value and
+                #   corresponding grey value from target
+                out_line = "%d = %d\n" % (i[0], j[0])
+                outfile.write(out_line)
+                break
+    outfile.close()
+    # create reclass of target from reclass rules file
+    result = grass.core.find_file(matched, element = 'cell')
+    if result['fullname']:
+        grass.run_command('g.remove', quiet=True, rast=matched)
+        grass.run_command('r.reclass', input=original, out=matched, rules=outfile.name)
+    else:
+    # Cleanup
+    # remove the rules file
+    grass.try_remove(outfile.name)
+    # return reclass of target with histogram that matches original
+    return matched
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/scripts/i.pansharpen/rgb_brovey321.jpg
(Binary files differ)
Property changes on: grass/trunk/scripts/i.pansharpen/rgb_brovey321.jpg
Added: svn:mime-type
   + application/octet-stream
Added: grass/trunk/scripts/i.pansharpen/rgb_ihs321.jpg
Property changes on: grass/trunk/scripts/i.pansharpen/rgb_ihs321.jpg
Added: grass/trunk/scripts/i.pansharpen/rgb_landsat321.jpg
Property changes on: grass/trunk/scripts/i.pansharpen/rgb_landsat321.jpg
Added: grass/trunk/scripts/i.pansharpen/rgb_pca321.jpg
Property changes on: grass/trunk/scripts/i.pansharpen/rgb_pca321.jpg
