[GRASS-SVN] r52646 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Sun Aug 12 16:08:53 PDT 2012
Author: huhabla
Date: 2012-08-12 16:08:53 -0700 (Sun, 12 Aug 2012)
New Revision: 52646
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/unit_tests.py
PEP8 compliance. Added RTree unit tests for 1 - 4 dimensional trees.
Bug fixing after class name conversion to camel case style.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -796,16 +796,16 @@
map_view = self.get_new_map_instance(
None).get_type() + "_view_rel_time"
- if columns is not None:
+ if columns is not None and columns != "":
sql = "SELECT %s FROM %s WHERE %s.id IN (SELECT id FROM %s)" %\
(columns, map_view, map_view, self.get_map_register())
else:
sql = "SELECT * FROM %s WHERE %s.id IN (SELECT id FROM %s)" % \
(map_view, map_view, self.get_map_register())
- if where is not None:
+ if where is not None and where != "":
sql += " AND (%s)" % (where.split(";")[0])
- if order is not None:
+ if order is not None and order != "":
sql += " ORDER BY %s" % (order.split(";")[0])
try:
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/aggregation.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -119,14 +119,14 @@
mapset = libgis.G_mapset()
map_id = output + "@" + mapset
- new_map = raster_dataset(map_id)
+ new_map = RasterDataset(map_id)
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
if core.overwrite() == True:
# Remove the existing temporal database entry
new_map.delete(dbif)
else:
core.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
return
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/base.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -663,7 +663,7 @@
if self.id.find(":") >= 0:
# Remove the layer identifier from the id
- return iself.d.split("@")[0].split(":")[0] + "@" + \
+ return self.id.split("@")[0].split(":")[0] + "@" + \
self.id.split("@")[1]
else:
return self.id
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/extract.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -17,7 +17,6 @@
def extract_dataset(input, output, type, where, expression, base, nprocs=1,
register_null=False, layer=1,
vtype="point,line,boundary,centroid,area,face"):
@@ -55,15 +54,15 @@
id = input + "@" + mapset
if type == "raster":
- sp = space_time_raster_dataset(id)
+ sp = SpaceTimeRasterDataset(id)
elif type == "raster3d":
- sp = space_time_raster3d_dataset(id)
+ sp = SpaceTimeRaster3DDataset(id)
elif type == "vector":
- sp = space_time_vector_dataset(id)
+ sp = SpaceTimeVectorDataset(id)
dummy = sp.get_new_map_instance(None)
- dbif = ()
+ dbif = SQLDatabaseInterfaceConnection()
dbif.connect()
if not sp.is_in_db(dbif):
@@ -156,20 +155,22 @@
% expression)
if row["layer"]:
proc_list.append(Process(target=run_vector_extraction,
- args=(row["name"] + "@" + row["mapset"],
+ args=(row["name"] + "@" + \
+ row["mapset"],
map_name, row["layer"],
vtype, expression)))
else:
+ row["mapset"],
map_name, layer, vtype,
expression)))
proc_list[proc_count].start()
proc_count += 1
- # Join processes if the maximum number of processes are reached or the end of the
- # loop is reached
+ # Join processes if the maximum number of processes are
+ # reached or the end of the loop is reached
if proc_count == nprocs or proc_count == num_rows:
proc_count = 0
exitcodes = 0
@@ -229,8 +230,8 @@
empty_maps.append(new_map)
continue
- if new_map.metadata.get_primitives() == 0 or \
- new_map.metadata.get_primitives() is None:
+ if new_map.metadata.get_number_of_primitives() == 0 or \
+ new_map.metadata.get_number_of_primitives() is None:
if not register_null:
continue
@@ -276,19 +277,16 @@
def run_mapcalc2d(expr):
"""Helper function to run r.mapcalc in parallel"""
return core.run_command("r.mapcalc", expression=expr,
overwrite=core.overwrite(), quiet=True)
def run_mapcalc3d(expr):
"""Helper function to run r3.mapcalc in parallel"""
return core.run_command("r3.mapcalc", expression=expr,
def run_vector_extraction(input, output, layer, type, where):
return core.run_command("v.extract", input=input, output=output,
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -42,7 +42,7 @@
# We need a database interface for fast computation
- dbif = ()
dbif.connect()
mapset = core.gisenv()["MAPSET"]
@@ -56,9 +56,9 @@
id = input_name_list[0] + "@" + mapset
- first_input = space_time_raster_dataset(id)
+ first_input = SpaceTimeRasterDataset(id)
else:
- first_input = space_time_raster3d_dataset(id)
+ first_input = SpaceTimeRaster3DDataset(id)
if not first_input.is_in_db(dbif):
dbif.close()
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -782,18 +782,18 @@
# Fill metadata
self.metadata.set_3d_info(kvp["is_3d"])
- self.metadata.set_points(kvp["points"])
- self.metadata.set_lines(kvp["lines"])
- self.metadata.set_boundaries(kvp["boundaries"])
- self.metadata.set_centroids(kvp["centroids"])
- self.metadata.set_faces(kvp["faces"])
- self.metadata.set_kernels(kvp["kernels"])
- self.metadata.set_primitives(kvp["primitives"])
- self.metadata.set_nodes(kvp["nodes"])
- self.metadata.set_areas(kvp["areas"])
- self.metadata.set_islands(kvp["islands"])
- self.metadata.set_holes(kvp["holes"])
- self.metadata.set_volumes(kvp["volumes"])
+ self.metadata.set_number_of_points(kvp["points"])
+ self.metadata.set_number_of_lines(kvp["lines"])
+ self.metadata.set_number_of_boundaries(kvp["boundaries"])
+ self.metadata.set_number_of_centroids(kvp["centroids"])
+ self.metadata.set_number_of_faces(kvp["faces"])
+ self.metadata.set_number_of_kernels(kvp["kernels"])
+ self.metadata.set_number_of_primitives(kvp["primitives"])
+ self.metadata.set_number_of_nodes(kvp["nodes"])
+ self.metadata.set_number_of_areas(kvp["areas"])
+ self.metadata.set_number_of_islands(kvp["islands"])
+ self.metadata.set_number_of_holes(kvp["holes"])
+ self.metadata.set_number_of_volumes(kvp["volumes"])
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -385,17 +385,17 @@
@param id: The id of the dataset ("name at mapset")
if type == "strds":
elif type == "str3ds":
elif type == "stvds":
elif type == "rast" or type == "raster":
- sp = raster_dataset(id)
+ sp = RasterDataset(id)
elif type == "rast3d":
- sp = raster3d_dataset(id)
+ sp = Raster3DDataset(id)
elif type == "vect" or type == "vector":
- sp = vector_dataset(id)
+ sp = VectorDataset(id)
else:
core.error(_("Unknown dataset type: %s") % type)
return None
@@ -474,14 +474,20 @@
if maps and len(maps) > 0:
if isinstance(maps[0], list):
- first_time, dummy = maps[0][0].get_valid_time()
+ if len(maps[0]) > 0:
+ first_time, dummy = maps[0][0].get_valid_time()
+ else:
+ core.fatal(_("Unable to list maps. Internal Error."))
else:
first_time, dummy = maps[0].get_valid_time()
for mymap in maps:
if isinstance(mymap, list):
- map = mymap[0]
+ if len(mymap) > 0:
+ map = mymap[0]
+ else:
else:
map = mymap
@@ -602,7 +608,7 @@
sst = dataset_factory(sampletype, sid)
- dbif = ()
dbif.connect()
for st in sts:
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -880,7 +880,7 @@
class STVDSAbsoluteTime(STDSAbsoluteTime):
def __init__(self, ident=None, start_time=None, end_time=None,
granularity=None, timezone=None):
- STDSAbsoluteTime.__init__(self, "RelativeTemporalExtent",
+ STDSAbsoluteTime.__init__(self, "stvds_absolute_time",
ident, start_time, end_time, granularity, timezone)
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2012-08-12 23:06:44 UTC (rev 52645)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2012-08-12 23:08:53 UTC (rev 52646)
@@ -1622,18 +1622,18 @@
def test_1d_rtree():
"""Testing the rtree ctypes wrapper"""
- tree = vector.RTreeNewIndex(-1, 0, 1)
+ tree = vector.RTreeCreateTree(-1, 0, 1)
for i in xrange(10):
rect = vector.RTree_Rect()
# Allocate the boundary
- vector.RTreeNewRect(byref(rect), tree)
+ vector.RTreeAllocBoundary(byref(rect), tree)
vector.RTreeSetRect1D(byref(rect), tree, float(i - 2), float(i + 2))
vector.RTreeInsertRect(byref(rect), i + 1, tree)
vector.RTreeSetRect1D(byref(rect), tree, 2.0, 7.0)
list_ = gis.ilist()
@@ -1645,18 +1645,20 @@
for i in xrange(list_.n_values):
print "id", list_.value[i]
+ vector.RTreeDestroyTree(tree)
def test_2d_rtree():
- tree = vector.RTreeNewIndex(-1, 0, 2)
+ tree = vector.RTreeCreateTree(-1, 0, 2)
vector.RTreeSetRect2D(byref(rect), tree,
float(i - 2), float(i + 2),
@@ -1664,7 +1666,7 @@
vector.RTreeSetRect2D(byref(rect), tree, 2.0, 7.0, 2.0, 7.0)
list_ = gis.ilist()
@@ -1676,18 +1678,20 @@
def test_3d_rtree():
- tree = vector.RTreeNewIndex(-1, 0, 3)
+ tree = vector.RTreeCreateTree(-1, 0, 3)
vector.RTreeSetRect3D(byref(rect), tree,
@@ -1697,7 +1701,7 @@
vector.RTreePrintRect(byref(rect), 1, tree)
vector.RTreeSetRect3D(byref(rect), tree, 2.0, 7.0, 2.0, 7.0, 2.0, 7.0)
print "Select"
@@ -1710,18 +1714,20 @@
print "Number of overlapping rectangles", num
def test_4d_rtree():
- tree = vector.RTreeNewIndex(-1, 0, 4)
+ tree = vector.RTreeCreateTree(-1, 0, 4)
- rect = vector.RTreeNewRect(None, tree)
+ rect = vector.RTreeAllocRect(tree)
vector.RTreeSetRect4D(rect, tree,
@@ -1729,18 +1735,22 @@
vector.RTreeInsertRect(rect, i + 1, tree)
vector.RTreeSetRect4D(rect, tree, 2.0, 7.0, 2.0,
list_ = gis.ilist()
num = vector.RTreeSearch2(tree, rect, byref(list_))
+ vector.RTreeFreeRect(rect)
# print rectangle ids
