[GRASS-SVN] r52647 - in grass/trunk/temporal: t.create t.info t.list t.rast.aggregate t.rast.aggregate.ds t.rast.export t.rast.extract t.rast.gapfill t.rast.import t.rast.list t.rast.mapcalc t.rast.out.vtk t.rast.series t.rast.to.rast3 t.rast.univar t.rast3d.extract t.rast3d.list t.rast3d.mapcalc t.rast3d.univar t.register t.remove t.sample t.support t.topology t.unregister t.vect.db.select t.vect.export t.vect.extract t.vect.import t.vect.list t.vect.observe.strds t.vect.univar t.vect.what.strds
svn_grass at osgeo.org
Sun Aug 12 16:10:21 PDT 2012
Author: huhabla
Date: 2012-08-12 16:10:21 -0700 (Sun, 12 Aug 2012)
New Revision: 52647
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.rast.export/t.rast.export.py
grass/trunk/temporal/t.rast.extract/t.rast.extract.py
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
grass/trunk/temporal/t.rast.import/t.rast.import.py
grass/trunk/temporal/t.rast.list/t.rast.list.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.rast.univar/t.rast.univar.py
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/t.unregister/t.unregister.py
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
grass/trunk/temporal/t.vect.export/t.vect.export.py
grass/trunk/temporal/t.vect.extract/t.vect.extract.py
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
grass/trunk/temporal/t.vect.import/t.vect.import.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
grass/trunk/temporal/t.vect.univar/t.vect.univar.py
grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
PEP8 compliance. Using the new class naming scheme.
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.create/t.create.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.create
# AUTHOR(S): Soeren Gebbert
# PURPOSE: Create a space time dataset
# COPYRIGHT: (C) 2011 by the GRASS Development Team
@@ -60,6 +60,7 @@
def main():
# Get the options
@@ -75,7 +76,7 @@
#Get the current mapset to create the id of the space time dataset
- mapset = grass.gisenv()["MAPSET"]
+ mapset = grass.gisenv()["MAPSET"]
id = name + "@" + mapset
sp = tgis.dataset_factory(type, id)
@@ -85,16 +86,22 @@
if sp.is_in_db(dbif) and grass.overwrite() == False:
dbif.close()
- grass.fatal(_("Space time %s dataset <%s> is already in the database. Use the overwrite flag.") % (sp.get_new_map_instance(None).get_type(), name))
+ grass.fatal(_("Space time %s dataset <%s> is already in the database. "
+ "Use the overwrite flag.") %
+ (sp.get_new_map_instance(None).get_type(), name))
if sp.is_in_db(dbif) and grass.overwrite() == True:
- grass.info(_("Overwrite space time %s dataset <%s> and unregister all maps.") % (sp.get_new_map_instance(None).get_type(), name))
+ grass.info(_("Overwrite space time %s dataset <%s> "
+ "and unregister all maps.") %
sp.delete(dbif)
sp = sp.get_new_instance(id)
- grass.verbose(_("Create space time %s dataset.") % sp.get_new_map_instance(None).get_type())
+ grass.verbose(_("Create space time %s dataset.") %
+ sp.get_new_map_instance(None).get_type())
- sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic, title=title, description=descr)
+ sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
+ title=title, description=descr)
sp.insert(dbif)
dbif.close()
@@ -102,4 +109,3 @@
if __name__ == "__main__":
options, flags = grass.parser()
main()
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.info/t.info.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.info
# PURPOSE: Print information about a space-time dataset
@@ -53,6 +53,7 @@
def main():
name = options["input"]
@@ -67,8 +68,10 @@
# 0123456789012345678901234567890
print " +------------------- Temporal DBMI backend information ----------------------+"
print " | DBMI Python interface:...... " + str(tgis.dbmi.__name__)
- print " | DBMI init string:........... " + str(tgis.get_temporal_dbmi_init_string())
- print " | SQL template path:.......... " + str(tgis.get_sql_template_path())
+ print " | DBMI init string:........... " + str(
+ tgis.get_temporal_dbmi_init_string())
+ print " | SQL template path:.......... " + str(
+ tgis.get_sql_template_path())
print " +----------------------------------------------------------------------------+"
return
@@ -78,14 +81,14 @@
if name.find("@") >= 0:
id = name
else:
ds = tgis.dataset_factory(type, id)
if ds.is_in_db() == False:
grass.fatal(_("Dataset <%s> not found") % (id))
ds.select()
if shellstyle == True:
@@ -96,4 +99,3 @@
main()
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.list/t.list.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.list
# PURPOSE: List space time datasets and maps registered in the temporal database
@@ -72,6 +72,7 @@
def main():
# Get the options
@@ -110,14 +111,13 @@
if order:
sql += " ORDER BY " + order
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
dbif.close()
# Print the query result to stout
if rows:
- if separator == None or separator == "":
+ if separator is None or separator == "":
separator = "\t"
# Print the column names if requested
@@ -141,7 +141,7 @@
else:
output += str(col)
count += 1
print output
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,15 +2,15 @@
# -*- coding: utf-8 -*-
-# MODULE: tr.aggregate
-# AUTHOR(S): Soeren Gebbert
+# MODULE: tr.aggregate
+# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Temporally aggregates the maps of a space time raster dataset by a user defined granularity.
-# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# PURPOSE: Temporally aggregates the maps of a space time raster dataset by a user defined granularity.
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (version 2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
@@ -56,7 +56,7 @@
#%end
#%option G_OPT_R_BASE
-#% gisprompt:
+#% gisprompt:
#%end
#%flag
@@ -70,6 +70,7 @@
def main():
# Get the options
@@ -87,19 +88,20 @@
# We need a database interface
dbif = tgis.SQLDatabaseInterfaceConnection()
dbif.connect()
if input.find("@") >= 0:
id = input
else:
id = input + "@" + mapset
- sp = tgis.space_time_raster_dataset(id)
+ sp = tgis.SpaceTimeRasterDataset(id)
if sp.is_in_db() == False:
dbif.close()
- grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ grass.fatal(_("Space time %s dataset <%s> not found") % (
+ sp.get_new_map_instance(None).get_type(), id))
sp.select(dbif)
@@ -109,14 +111,15 @@
out_id = output + "@" + mapset
# The new space time raster dataset
- new_sp = tgis.space_time_raster_dataset(out_id)
+ new_sp = tgis.SpaceTimeRasterDataset(out_id)
if new_sp.is_in_db(dbif):
if grass.overwrite() == True:
new_sp.delete(dbif)
else:
dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is already in the database, use overwrite flag to overwrite") % out_id)
+ grass.fatal(_("Space time raster dataset <%s> is already in the "
+ "database, use overwrite flag to overwrite") % out_id)
temporal_type, semantic_type, title, description = sp.get_initial_values()
new_sp.set_initial_values(temporal_type, semantic_type, title, description)
@@ -125,13 +128,14 @@
rows = sp.get_registered_maps("id,start_time", where, "start_time", dbif)
if not rows:
- dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
+ dbif.close()
+ grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
# Modify the start time to fit the granularity
if sp.is_time_absolute():
- first_start_time = tgis.adjust_datetime_to_granularity( rows[0]["start_time"], gran)
+ first_start_time = tgis.adjust_datetime_to_granularity(
+ rows[0]["start_time"], gran)
else:
first_start_time = rows[0]["start_time"]
@@ -139,7 +143,7 @@
next_start_time = first_start_time
count = 0
while next_start_time <= last_start_time:
start = next_start_time
@@ -148,18 +152,21 @@
end = next_start_time + int(gran)
next_start_time = end
- input_map_names = tgis.collect_map_names(sp, dbif, start, end, sampling)
+ input_map_names = tgis.collect_map_names(
+ sp, dbif, start, end, sampling)
if input_map_names:
- new_map = tgis.aggregate_raster_maps(input_map_names, base, start, end,
- count, method, register_null, dbif)
+ new_map = tgis.aggregate_raster_maps(
+ input_map_names, base, start, end,
+ count, method, register_null, dbif)
if new_map:
# Set the time stamp and write it to the raster map
new_map.set_absolute_time(start, end, None)
else:
- new_map.set_relative_time(start, end, sp.get_relative_time_unit())
+ new_map.set_relative_time(start,
+ end, sp.get_relative_time_unit())
# Insert map in temporal database
new_map.insert(dbif)
@@ -169,10 +176,9 @@
# Update the spatio-temporal extent and the raster metadata table entries
new_sp.update_from_registered_maps(dbif)
dbif.close()
main()
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -30,7 +30,7 @@
#%option G_OPT_STDS_TYPE
#% description: Type of the aggregation space time dataset, default is strds
-#%end
+#%end
#%option
#% key: output
@@ -54,7 +54,7 @@
#%end
-#% gisprompt:
+#% gisprompt:
#%end
#%flag
@@ -67,6 +67,7 @@
def main():
# Get the options
@@ -84,19 +85,20 @@
dbif.connect()
id = input
else:
dbif.close()
sp.select(dbif)
@@ -106,7 +108,7 @@
sampler_id = sampler + "@" + mapset
sampler_sp = tgis.dataset_factory(type, sampler_id)
if sampler_sp.is_in_db() == False:
dbif.close()
grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
@@ -115,17 +117,19 @@
if sampler_sp.get_temporal_type() != sp.get_temporal_type():
dbif.close()
- grass.fatal(_("Input and aggregation dataset must have the same temporal type"))
+ grass.fatal(_("Input and aggregation dataset must have "
+ "the same temporal type"))
# Check if intervals are present
if sampler_sp.get_temporal_type() == "absolute":
map_time = sampler_sp.absolute_time.get_map_time()
else:
map_time = sampler_sp.relative_time.get_map_time()
if map_time != "interval":
dbif.close()
- grass.fatal(_("All registered maps of the aggregation dataset must have time intervals"))
+ grass.fatal(_("All registered maps of the aggregation dataset "
+ "must have time intervals"))
if output.find("@") >= 0:
out_id = output
@@ -133,20 +137,22 @@
new_sp.delete(dbif)
else:
dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
+ grass.fatal(_("Space time raster dataset <%s> is already in "
new_sp.insert(dbif)
- rows = sampler_sp.get_registered_maps("id,start_time,end_time", None, "start_time", dbif)
+ rows = sampler_sp.get_registered_maps(
+ "id,start_time,end_time", None, "start_time", dbif)
if not rows:
dbif.close()
@@ -158,28 +164,31 @@
start = row["start_time"]
end = row["end_time"]
if input_map_names:
- new_map = tgis.aggregate_raster_maps(input_map_names, base, start, end, count, method, register_null, dbif)
+ new_map = tgis.aggregate_raster_maps(input_map_names, base,
+ start, end, count, method,
+ register_null, dbif)
if new_map:
else:
new_sp.register_map(new_map, dbif)
dbif.close()
main()
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.py
--- grass/trunk/temporal/t.rast.export/t.rast.export.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.rast.export
-# PURPOSE: Export a space time raster dataset
+# MODULE: t.rast.export
-# for details.
+# PURPOSE: Export a space time raster dataset
+# for details.
#%module
@@ -60,23 +60,24 @@
import grass.script as grass
import grass.temporal as tgis
def main():
- # Get the options
- _input = options["input"]
- output = options["output"]
- compression = options["compression"]
- workdir = options["workdir"]
- where = options["where"]
- _format = options["format"]
+ # Get the options
+ _input = options["input"]
+ output = options["output"]
+ compression = options["compression"]
+ workdir = options["workdir"]
+ where = options["where"]
+ _format = options["format"]
- # Make sure the temporal database exists
- tgis.create_temporal_database()
- # Export the space time raster dataset
- tgis.export_stds(_input, output, compression, workdir, where, _format, "strds")
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ # Export the space time raster dataset
+ tgis.export_stds(
+ _input, output, compression, workdir, where, _format, "strds")
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.py
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -43,7 +43,7 @@
#% description: The base name of the new created raster maps. This name will be extended with a numerical prefix
#% required: no
#% multiple: no
-#% gisprompt:
+#% gisprompt:
#%end
#%option
@@ -66,6 +66,7 @@
def main():
# Get the options
@@ -79,12 +80,12 @@
- tgis.extract_dataset(input, output, "raster", where, expression, base, nprocs, register_null)
+ tgis.extract_dataset(input, output, "raster", where, expression,
+ base, nprocs, register_null)
main()
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,15 +2,15 @@
-# MODULE: t.rast.gapfill
+# MODULE: t.rast.gapfill
-# PURPOSE: Replace gaps in a space time raster dataset with interpolated raster maps.
-# COPYRIGHT: (C) 2012 by the GRASS Development Team
+# PURPOSE: Replace gaps in a space time raster dataset with interpolated raster maps.
+# COPYRIGHT: (C) 2012 by the GRASS Development Team
-# for details.
+# for details.
@@ -54,7 +54,7 @@
def main():
# Get the options
@@ -69,108 +69,116 @@
id = input
else:
dbif.connect()
if sp.is_in_db(dbif) == False:
+ (sp.get_new_map_instance(None).get_type(), id))
sp.select(dbif)
maps = sp.get_registered_maps_as_objects_with_gaps(where, dbif)
num = len(maps)
gap_list = []
# Identify all gaps and create new names
count = 0
for _map in maps:
- if _map.get_id() == None:
- count += 1
- _id = "%s_%d@%s"%(base, num + count, mapset)
- print _id
- _map.set_id(_id)
- if _map.map_exists() or _map.is_in_db(dbif):
- grass.fatal(_("Map with name <%s> already exists. Please use another base name."%(_id)))
- gap_list.append(_map)
+ if _map.get_id() is None:
+ count += 1
+ _id = "%s_%d@%s" % (base, num + count, mapset)
+ print _id
+ _map.set_id(_id)
+ if _map.map_exists() or _map.is_in_db(dbif):
+ grass.fatal(_("Map with name <%s> already exists. "
+ "Please use another base name." % (_id)))
+ gap_list.append(_map)
if len(gap_list) == 0:
- grass.message(_("No gaps found"))
- return
+ grass.message(_("No gaps found"))
+ return
# Build the temporal topology
tb = tgis.temporal_topology_builder()
tb.build(maps)
# Do some checks before computation
- for _map in gap_list:
- if not _map.get_precedes() or not _map.get_follows():
- grass.fatal(_("Unable to determine successor and predecessor of a gap."))
- if len(_map.get_precedes()) > 1:
- grass.warning(_("More than one successor of the gap found. Using the first found."))
- if len(_map.get_follows()) > 1:
- grass.warning(_("More than one predecessor of the gap found. Using the first found."))
+ for _map in gap_list:
+ if not _map.get_precedes() or not _map.get_follows():
+ grass.fatal(_("Unable to determine successor "
+ "and predecessor of a gap."))
- # Interpolate the maps using parallel processing
+ if len(_map.get_precedes()) > 1:
+ grass.warning(_("More than one successor of the gap found. "
+ "Using the first found."))
+ if len(_map.get_follows()) > 1:
+ grass.warning(_("More than one predecessor of the gap found. "
+ # Interpolate the maps using parallel processing
proc_list = []
proc_count = 0
num = len(gap_list)
- predecessor = _map.get_follows()[0]
- successor = _map.get_precedes()[0]
- # Build the module inputs strings
- inputs = "%s,%s"%(predecessor.get_map_id(), successor.get_map_id())
- dpos = "0,1"
- output = "%s"%(_map.get_name())
- outpos = "0.5"
- # Start several processes in parallel
- proc_list.append(Process(target=run_interp, args=(inputs,dpos,output,outpos)))
- proc_list[proc_count].start()
- proc_count += 1
- if proc_count == nprocs or proc_count == num:
- proc_count = 0
- exitcodes = 0
- for proc in proc_list:
- proc.join()
- exitcodes += proc.exitcode
- if exitcodes != 0:
- dbif.close()
- grass.fatal(_("Error while interpolation computation"))
- # Empty process list
- proc_list = []
+ predecessor = _map.get_follows()[0]
+ successor = _map.get_precedes()[0]
+ # Build the module inputs strings
+ inputs = "%s,%s" % (predecessor.get_map_id(), successor.get_map_id())
+ dpos = "0,1"
+ output = "%s" % (_map.get_name())
+ outpos = "0.5"
+ # Start several processes in parallel
+ proc_list.append(Process(
+ target=run_interp, args=(inputs, dpos, output, outpos)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ if proc_count == nprocs or proc_count == num:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ dbif.close()
+ grass.fatal(_("Error while interpolation computation"))
+ # Empty process list
+ proc_list = []
# Insert new interpolated maps in temporal database and dataset
- _map.load()
- _map.insert(dbif)
- sp.register_map(_map, dbif)
+ _map.load()
+ _map.insert(dbif)
+ sp.register_map(_map, dbif)
dbif.close()
def run_interp(inputs, dpos, output, outpos):
"""Helper function to run r.series.interp in parallel"""
- return grass.run_command("r.series.interp", input=inputs, datapos=dpos, output=output, samplingpos=outpos, overwrite=grass.overwrite(), quiet=True)
+ return grass.run_command("r.series.interp", input=inputs, datapos=dpos,
+ output=output, samplingpos=outpos,
+ overwrite=grass.overwrite(), quiet=True)
main()
Modified: grass/trunk/temporal/t.rast.import/t.rast.import.py
--- grass/trunk/temporal/t.rast.import/t.rast.import.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.import/t.rast.import.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.rast.import
# PURPOSE: Import a space time raster dataset
@@ -78,23 +78,24 @@
def main():
- # Get the options
- input = options["input"]
- extrdir = options["extrdir"]
- title = options["title"]
- descr = options["description"]
- location = options["location"]
- link = flags["l"]
- exp = flags["e"]
- overr = flags["o"]
- create = flags["c"]
- tgis.import_stds(input, output, extrdir, title, descr, location,
- link, exp, overr, create, "strds")
+ # Get the options
+ input = options["input"]
+ extrdir = options["extrdir"]
+ title = options["title"]
+ descr = options["description"]
+ location = options["location"]
+ link = flags["l"]
+ exp = flags["e"]
+ overr = flags["o"]
+ create = flags["c"]
+ tgis.import_stds(input, output, extrdir, title, descr, location,
+ link, exp, overr, create, "strds")
main()
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,8 +4,8 @@
# MODULE: t.rast.list
-# PURPOSE: List registered maps of a space time raster dataset
+# PURPOSE: List registered maps of a space time raster dataset
@@ -30,7 +30,7 @@
#% description: Order the space time dataset by category
#% required: no
#% multiple: yes
-#% options: id,name,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,nsres,ewres,cols,rows,number_of_cells,min,max
+#% options: id,name,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,nsres,ewres,cols,rows,number_of_cells,min,max
#% answer: start_time
#%end
@@ -40,7 +40,7 @@
#% description: Select columns to be printed to stdout
#% required: no
#% multiple: yes
#% answer: name,mapset,start_time,end_time
#%end
@@ -66,7 +66,7 @@
#%flag
#% key: h
-#% description: Print column names
+#% description: Print column names
#%end
@@ -74,6 +74,7 @@
def main():
# Get the options
@@ -88,7 +89,8 @@
- tgis.list_maps_of_stds("strds", input, columns, order, where, separator, method, header)
+ tgis.list_maps_of_stds(
+ "strds", input, columns, order, where, separator, method, header)
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -74,6 +74,7 @@
def main():
# Get the options
@@ -85,18 +86,18 @@
nprocs = int(options["nprocs"])
register_null = flags["n"]
spatial = flags["s"]
# Create the method list
method = method.split(",")
- tgis.dataset_mapcalculator(inputs, output, "raster", expression, base, method, nprocs, register_null, spatial)
+ tgis.dataset_mapcalculator(inputs, output, "raster", expression,
+ base, method, nprocs, register_null, spatial)
main()
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.rast.out.vtk
-# PURPOSE: Export space time raster dataset as VTK time series
+# MODULE: t.rast.out.vtk
-# for details.
+# PURPOSE: Export space time raster dataset as VTK time series
+# for details.
#%module
@@ -71,6 +71,7 @@
def main():
# Get the options
@@ -86,27 +87,28 @@
- if not os.path.exists(expdir):
+ if not os.path.exists(expdir):
grass.fatal(_("Export directory <%s> not found.") % expdir)
os.chdir(expdir)
id = input
else:
sp.select()
if use_granularity:
- # Attention: A list of lists of maps will be returned
+ # Attention: A list of lists of maps will be returned
maps = sp.get_registered_maps_as_objects_by_granularity()
# Create a NULL map in case of granularity support
null_map = "temporary_null_map_%i" % os.getpid()
@@ -114,24 +116,29 @@
else:
maps = sp.get_registered_maps_as_objects(where, "start_time", None)
- # To have scalar values with the same name, we need to copy the raster maps using a single name
+ # To have scalar values with the same name, we need to copy the
+ # raster maps using a single name
map_name = "%s_%i" % (sp.base.get_name(), os.getpid())
count = 0
- if maps:
+ if maps is not None:
for map in maps:
- if use_granularity:
- id = map[0].get_map_id()
- else:
- id = map.get_map_id()
+ if use_granularity:
+ if len(map[0]) > 0:
+ id = map[0].get_map_id()
+ else:
+ continue
+ else:
+ id = map.get_map_id()
# None ids will be replaced by NULL maps
- if id == None:
+ if id is None:
id = null_map
- grass.run_command("g.copy", rast="%s,%s" % (id, map_name), overwrite=True)
- out_name = "%6.6i_%s.vtk" % (count, sp.base.get_name())
- mflags=""
+ grass.run_command("g.copy", rast="%s,%s" % (id, map_name),
+ overwrite=True)
+ out_name = "%6.6i_%s.vtk" % (count, sp.base.get_name())
+ mflags = ""
if use_pdata:
mflags += "p"
if coorcorr:
@@ -139,9 +146,14 @@
# Export the raster map with r.out.vtk
if elevation:
- ret = grass.run_command("r.out.vtk", flags=mflags, null=null, input=map_name, elevation=elevation, output=out_name, overwrite=grass.overwrite())
+ ret = grass.run_command("r.out.vtk", flags=mflags, null=null,
+ input=map_name, elevation=elevation,
+ output=out_name,
+ overwrite=grass.overwrite())
else:
- ret = grass.run_command("r.out.vtk", flags=mflags, null=null, input=map_name, output=out_name, overwrite=grass.overwrite())
+ input=map_name, output=out_name,
if ret != 0:
grass.fatal(_("Unable to export raster map <%s>" % name))
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -59,6 +59,7 @@
def main():
# Get the options
@@ -75,13 +76,14 @@
id = input
else:
sp.select()
@@ -95,22 +97,24 @@
for row in rows:
string = "%s\n" % (row["id"])
file.write(string)
file.close()
- ret = grass.run_command("r.series", flags="z", file=filename, output=output, overwrite=grass.overwrite(), method=method)
+ ret = grass.run_command("r.series", flags="z", file=filename,
+ output=output, overwrite=grass.overwrite(),
+ method=method)
if ret == 0 and not add_time:
start_time, end_time, tz = sp.get_absolute_time()
else:
start_time, end_time = sp.get_relative_time()
# Create the time range for the output map
id = output
else:
map = sp.get_new_map_instance(id)
@@ -130,4 +134,3 @@
main()
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.rast.to.rast3
-# PURPOSE: Convert a space time raster dataset into a rast3d map
+# MODULE: t.rast.to.rast3
-# for details.
+# PURPOSE: Convert a space time raster dataset into a rast3d map
+# for details.
#%module
@@ -34,6 +34,7 @@
def main():
# Get the options
@@ -43,74 +44,79 @@
id = input
else:
sp.select()
grass.use_temp_region()
num_maps = len(maps)
# Get the granularity and set bottom, top and top-bottom resolution
granularity = sp.get_granularity()
# This is the reference time to scale the z coordinate
reftime = datetime(1900, 1, 1)
- # We set top and bottom according to the start time in relation to the date 1900-01-01 00:00:00
- # In case of days, hours, minutes and seconds, a double number is used to represent days and fracs of a day
- # Space time voxel cubes with montly or yearly granularity can not be mixed with other temporal units
+ # We set top and bottom according to the start time in relation
+ # to the date 1900-01-01 00:00:00
+ # In case of days, hours, minutes and seconds, a double number
+ # is used to represent days and fracs of a day
+ # Space time voxel cubes with montly or yearly granularity can not be
+ # mixed with other temporal units
# Compatible temporal units are : days, hours, minutes and seconds
# Incompatible are years and moths
start, end = sp.get_valid_time()
- unit = granularity.split(" ")[1]
+ unit = granularity.split(" ")[1]
granularity = int(granularity.split(" ")[0])
if unit == "years":
- bottom = start.year - 1900
- top = granularity * num_maps
- elif unit == "months":
- bottom = (start.year - 1900) * 12 + start.month
- else:
- bottom = tgis.time_delta_to_relative_time(start - reftime)
- days = 0
- hours = 0
- minutes = 0
- seconds = 0
- if unit == "days":
- days = granularity
- if unit == "hours":
- hours = granularity
- if unit == "minutes":
- minutes = granularity
- if unit == "seconds":
- seconds = granularity
- granularity = days + hours/24.0 + minutes/1440.0 + seconds/86400.0
+ bottom = start.year - 1900
+ top = granularity * num_maps
+ elif unit == "months":
+ bottom = (start.year - 1900) * 12 + start.month
+ else:
+ bottom = tgis.time_delta_to_relative_time(start - reftime)
+ days = 0
+ hours = 0
+ minutes = 0
+ seconds = 0
+ if unit == "days":
+ days = granularity
+ if unit == "hours":
+ hours = granularity
+ if unit == "minutes":
+ minutes = granularity
+ if unit == "seconds":
+ seconds = granularity
+ granularity = days + hours / 24.0 + minutes / \
+ 1440.0 + seconds / 86400.0
else:
unit = sp.get_relative_time_unit()
- bottom = start
+ bottom = start
top = bottom + granularity * num_maps
ret = grass.run_command("g.region", t=top, b=bottom, tbres=granularity)
if ret != 0:
grass.fatal(_("Unable to set 3d region"))
@@ -119,24 +125,25 @@
grass.mapcalc("%s = null()" % (null_map))
if maps:
- count = 0
- map_names = ""
+ count = 0
+ map_names = ""
for map in maps:
- # Use the first map
+ # Use the first map
id = map[0].get_id()
- if id == None:
+ if id is None:
id = null_map
- if count == 0:
- map_names = id
+ if count == 0:
+ map_names = id
else:
map_names += ",%s" % id
count += 1
- ret = grass.run_command("r.to.rast3", input=map_names, output=output, overwrite=grass.overwrite())
+ ret = grass.run_command("r.to.rast3", input=map_names,
+ output=output, overwrite=grass.overwrite())
if ret != 0:
grass.fatal(_("Unable to create raster3d map <%s>" % output))
@@ -146,7 +153,9 @@
descr = _("This space time voxel cube was created with t.rast.to.rast3")
# Set the unit
- ret = grass.run_command("r3.support", map=output, vunit=unit, title=title, description=descr, overwrite=grass.overwrite())
+ ret = grass.run_command("r3.support", map=output, vunit=unit,
+ title=title, description=descr,
# Register the space time voxel cube in the temporal GIS
@@ -155,12 +164,12 @@
- r3ds = tgis.raster3d_dataset(id)
+ r3ds = tgis.Raster3DDataset(id)
if r3ds.is_in_db():
r3ds.select()
r3ds.delete()
r3ds.load()
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -42,7 +42,7 @@
#%flag
#% key: h
#%end
@@ -50,6 +50,7 @@
def main():
# Get the options
@@ -61,10 +62,10 @@
- tgis.print_gridded_dataset_univar_statistics("strds", input, where, extended, header, fs)
+ tgis.print_gridded_dataset_univar_statistics(
+ "strds", input, where, extended, header, fs)
main()
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -64,6 +64,7 @@
def main():
# Get the options
@@ -77,10 +78,10 @@
- tgis.extract_dataset(input, output, "raster3d", where, expression, base, nprocs, register_null)
+ tgis.extract_dataset(input, output, "raster3d", where, expression,
main()
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,8 +4,8 @@
# MODULE: t.rast3d.list
-# PURPOSE: List registered maps of a space time raster3d dataset
+# PURPOSE: List registered maps of a space time raster3d dataset
@@ -31,7 +31,7 @@
#% required: no
#% multiple: yes
-#% options: id,name,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,nsres,tbres,ewres,cols,rows,depths,number_of_cells,min,max
+#% options: id,name,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,nsres,tbres,ewres,cols,rows,depths,number_of_cells,min,max
#%end
@@ -41,7 +41,7 @@
#% description: Columns to be printed to stdout
#% required: no
#% multiple: yes
#%end
@@ -67,7 +67,7 @@
#%flag
#% key: h
#%end
@@ -75,6 +75,7 @@
def main():
# Get the options
@@ -89,7 +90,8 @@
- tgis.list_maps_of_stds("str3ds", input, columns, order, where, separator, method, header)
+ "str3ds", input, columns, order, where, separator, method, header)
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -73,6 +73,7 @@
def main():
# Get the options
@@ -84,18 +85,18 @@
- tgis.dataset_mapcalculator(inputs, output, "raster3d", expression, base, method, nprocs, register_null, spatial)
+ tgis.dataset_mapcalculator(inputs, output, "raster3d", expression,
main()
Modified: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -42,7 +42,7 @@
#%flag
#% key: h
#%end
@@ -50,6 +50,7 @@
def main():
# Get the options
@@ -61,10 +62,10 @@
- tgis.print_gridded_dataset_univar_statistics("str3ds", input, where, extended, header, fs)
+ "str3ds", input, where, extended, header, fs)
main()
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.register/t.register.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -87,6 +87,7 @@
def main():
# Get the options
@@ -104,8 +105,9 @@
# Register maps
- tgis.register_maps_in_space_time_dataset(type=type, name=name, maps=maps, file=file, start=start, end=end, \
- unit=unit, increment=increment, dbif=None, interval=interval, fs=fs)
+ tgis.register_maps_in_space_time_dataset(
+ type=type, name=name, maps=maps, file=file, start=start, end=end,
+ unit=unit, increment=increment, dbif=None, interval=interval, fs=fs)
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.remove/t.remove.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.remove
# PURPOSE: Remove space time datasets from the temporal database
@@ -46,15 +46,16 @@
def main():
# Get the options
datasets = options["input"]
file = options["file"]
type = options["type"]
if datasets and file:
- core.fata(_("%s= and %s= are mutually exclusive") % ("input","file"))
+ core.fata(_("%s= and %s= are mutually exclusive") % ("input", "file"))
@@ -84,9 +85,9 @@
line_list = line.split("\n")
dataset_name = line_list[0]
dataset_list.append(dataset_name)
statement = ""
for name in dataset_list:
@@ -101,7 +102,8 @@
dbif.close()
+ % (sp.get_new_map_instance(None).get_type(), id))
statement += sp.delete(dbif=dbif, execute=False)
@@ -113,4 +115,3 @@
main()
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.sample/t.sample.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.sample
# PURPOSE: Sample the input space time dataset(s) with a sample space time dataset and print the result to stdout
@@ -25,7 +25,7 @@
#%option G_OPT_STDS_INPUT
#% key: sample
-#% description: Name of the sample space time dataset
+#% description: Name of the sample space time dataset
#%end
@@ -51,12 +51,12 @@
#%flag
#% key: c
#%end
#%flag
#% key: s
-#% description: Check spatial overlap to perform spatio-temporal sampling
+#% description: Check spatial overlap to perform spatio-temporal sampling
#%end
@@ -65,6 +65,7 @@
def main():
# Get the options
@@ -82,7 +83,8 @@
- tgis.sample_stds_by_stds_topology(intype, samtype, inputs, sampler, header, separator, method, spatial)
+ tgis.sample_stds_by_stds_topology(intype, samtype, inputs, sampler,
+ header, separator, method, spatial)
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.support/t.support.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.support
-# PURPOSE: Modify the metadata of a space time dataset
+# MODULE: t.support
-# for details.
+# PURPOSE: Modify the metadata of a space time dataset
+# for details.
#%module
@@ -67,6 +67,7 @@
def main():
# Get the options
@@ -82,13 +83,13 @@
id = name
else:
dbif.connect()
@@ -96,24 +97,25 @@
if stds.is_in_db(dbif=dbif) == False:
dbif.close()
- grass.fatal(_("Space time %s dataset <%s> not found") % (stds.get_new_map_instance(None).get_type(), id))
+ stds.get_new_map_instance(None).get_type(), id))
stds.select(dbif=dbif)
update = False
if title:
- stds.metadata.set_title(title=title)
- update = True
- # Update only non-null entries
+ stds.metadata.set_title(title=title)
+ update = True
+ # Update only non-null entries
if description:
- stds.metadata.set_description(description=description)
- update = True
+ stds.metadata.set_description(description=description)
+ update = True
if semantic:
- stds.base.set_semantic_type(semantic_type=semantic)
- update = True
+ stds.base.set_semantic_type(semantic_type=semantic)
+ update = True
if update:
- stds.update(dbif=dbif)
+ stds.update(dbif=dbif)
if map_update:
#Update the registered maps from the grass spatial database
@@ -123,41 +125,40 @@
count = 0
maps = stds.get_registered_maps_as_objects(dbif=dbif)
# We collect the delete and update statements
for map in maps:
- grass.percent(count, len(maps), 1)
- count += 1
- map.select(dbif=dbif)
- # Check if the map is present in the grass spatial database
- # Update if present, delete if not present
- if map.map_exists():
- # Read new metadata from the spatial database
- map.load()
- statement += map.update(dbif=dbif, execute=False)
- else:
- # Delete the map from the temporal database
- # We need to update all effected space time datasets
- rows = map.get_registered_datasets(dbif)
- if rows:
- for row in rows:
- dataset_dict[row["id"]] = row["id"]
- # Collect the delete statements
- statement += map.delete(dbif=dbif, update=False, execute=False)
+ grass.percent(count, len(maps), 1)
+ count += 1
+ map.select(dbif=dbif)
+ # Check if the map is present in the grass spatial database
+ # Update if present, delete if not present
+ if map.map_exists():
+ # Read new metadata from the spatial database
+ map.load()
+ statement += map.update(dbif=dbif, execute=False)
+ else:
+ # Delete the map from the temporal database
+ # We need to update all effected space time datasets
+ rows = map.get_registered_datasets(dbif)
+ if rows:
+ for row in rows:
+ dataset_dict[row["id"]] = row["id"]
+ # Collect the delete statements
+ statement += map.delete(dbif=dbif, update=False, execute=False)
# Execute the collected SQL statements
dbif.execute_transaction(statement)
- # Update the effected space time datasets
+ # Update the effected space time datasets
for id in dataset_dict:
- stds_new = stds.get_new_instance(id)
- stds_new.select(dbif=dbif)
+ stds_new = stds.get_new_instance(id)
+ stds_new.select(dbif=dbif)
stds_new.update_from_registered_maps(dbif=dbif)
if map_update or update:
stds.update_from_registered_maps(dbif=dbif)
@@ -166,4 +167,3 @@
main()
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.topology/t.topology.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.topology
# PURPOSE: List and modify temporal topology of a space time dataset
@@ -39,6 +39,7 @@
def main():
# Get the options
@@ -54,19 +55,21 @@
id = name
else:
# Insert content from db
sp.select()
# Get ordered map list
- maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=None)
+ maps = sp.get_registered_maps_as_objects(
+ where=where, order="start_time", dbif=None)
if tmatrix:
sp.print_temporal_relationships(maps)
@@ -84,13 +87,13 @@
check = sp.check_temporal_topology(maps)
if check:
- print " | Temporal topology is: ...... valid"
+ print " | Temporal topology is: ...... valid"
else:
- print " | Temporal topology is: ...... invalid"
+ print " | Temporal topology is: ...... invalid"
dict = sp.count_temporal_types(maps)
for key in dict.keys():
if key == "interval":
@@ -101,7 +104,7 @@
print " | Invalid time stamps: ....... %s" % (dict[key])
- print " | Number of gaps: ............ %i" % sp.count_gaps(maps)
+ print " | Number of gaps: ............ %i" % sp.count_gaps(maps)
gran = tgis.compute_absolute_time_granularity(maps)
@@ -145,4 +148,3 @@
main()
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.unregister/t.unregister.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.unregister
-# PURPOSE: Unregister raster, vector and raster3d maps from the temporal database or a specific space time dataset
+# MODULE: t.unregister
-# for details.
+# PURPOSE: Unregister raster, vector and raster3d maps from the temporal database or a specific space time dataset
+# for details.
#%module
@@ -44,6 +44,7 @@
def main():
# Get the options
@@ -56,12 +57,13 @@
if maps and file:
- grass.fatal(_("%s= and %s= are mutually exclusive") % ("input","file"))
+ grass.fatal(_(
+ "%s= and %s= are mutually exclusive") % ("input", "file"))
if not maps and not file:
- grass.fatal(_("%s= or %s= must be specified") % ("input","file"))
+ grass.fatal(_("%s= or %s= must be specified") % ("input", "file"))
dbif.connect()
@@ -83,25 +85,26 @@
dbif.close()
maplist = []
- dummy = tgis.raster_dataset(None)
+ dummy = tgis.RasterDataset(None)
# Map names as comma separated string
- if maps != None:
- if maps.find(",") == -1:
- maplist = [maps,]
- else:
- maplist = maps.split(",")
- # Build the maplist
- for count in range(len(maplist)):
- mapname = maplist[count]
- mapid = dummy.build_id(mapname, mapset)
+ if maps.find(",") == -1:
+ maplist = [maps, ]
+ else:
+ maplist = maps.split(",")
+ # Build the maplist
+ for count in range(len(maplist)):
+ mapname = maplist[count]
+ mapid = dummy.build_id(mapname, mapset)
maplist[count] = mapid
# Read the map list from file
if file:
fd = open(file, "r")
@@ -113,9 +116,9 @@
break
mapname = line.strip()
maplist.append(mapid)
num_maps = len(maplist)
update_dict = {}
count = 0
@@ -125,8 +128,8 @@
# Unregister already registered maps
grass.message(_("Unregistered maps"))
for mapid in maplist:
- grass.percent(count, num_maps, 1)
+ grass.percent(count, num_maps, 1)
map = tgis.dataset_factory(type, mapid)
# Unregister map if in database
@@ -135,8 +138,9 @@
if name:
sp.metadata.select(dbif)
# Collect SQL statements
- statement += sp.unregister_map(map=map, dbif=dbif, execute=False)
+ statement += sp.unregister_map(
+ map=map, dbif=dbif, execute=False)
# Unregister from temporal database
else:
# We need to update all datasets after the removement of maps
@@ -149,17 +153,18 @@
else:
- grass.warning(_("Unable to find %s map <%s> in temporal database"%(map.get_type(), map.get_id())))
- count += 1
+ grass.warning(_("Unable to find %s map <%s> in temporal database" %
+ (map.get_type(), map.get_id())))
+ count += 1
# Execute the collected SQL statenents
grass.percent(num_maps, num_maps, 1)
# Update space time datasets
grass.message(_("Unregistered maps from space time dataset(s)"))
if name:
@@ -179,7 +184,7 @@
grass.percent(count, len(update_dict), 1)
- count += 1
+ count += 1
dbif.close()
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,15 +2,15 @@
-# MODULE: t.vect.db.select
+# MODULE: t.vect.db.select
-# PURPOSE: Prints attributes of vector maps registered in a space time vector dataset.
+# PURPOSE: Prints attributes of vector maps registered in a space time vector dataset.
-# for details.
+# for details.
@@ -52,6 +52,7 @@
def main():
# Get the options
@@ -70,54 +71,62 @@
id = input
else:
- sp = tgis.space_time_vector_dataset(id)
+ sp = tgis.SpaceTimeVectorDataset(id)
sp.select()
- rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time", tempwhere, "start_time", None)
+ rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time",
+ tempwhere, "start_time", None)
col_names = ""
if rows:
- for row in rows:
- vector_name = "%s@%s"%(row["name"], row["mapset"])
- # In case a layer is defined in the vector dataset, we override the option layer
- if row["layer"]:
- layer = row["layer"]
- select = grass.read_command("v.db.select", map=vector_name, layer=layer, columns=columns, fs="%s"%(fs), where=where)
- if not select:
- grass.fatal(_("Unable to run v.db.select for vector map <%s> with layer %s")%(vector_name, layer))
- # The first line are the column names
- list = select.split("\n")
- count = 0
- for entry in list:
- if entry.strip() != "":
- # print the column names in case they change
- if count == 0:
- col_names_new = "start_time%send_time%s%s"%(fs, fs, entry)
- if col_names != col_names_new:
- col_names = col_names_new
- print col_names
- else:
- if row["end_time"]:
- print "%s%s%s%s%s"%(row["start_time"],fs, row["end_time"], fs, entry)
- else:
- print "%s%s%s%s"%(row["start_time"], fs, fs, entry)
- count += 1
+ for row in rows:
+ vector_name = "%s@%s" % (row["name"], row["mapset"])
+ # In case a layer is defined in the vector dataset,
+ # we override the option layer
+ if row["layer"]:
+ layer = row["layer"]
+ select = grass.read_command("v.db.select", map=vector_name,
+ layer=layer, columns=columns,
+ fs="%s" % (fs), where=where)
+ if not select:
+ grass.fatal(_("Unable to run v.db.select for vector map <%s> "
+ "with layer %s") % (vector_name, layer))
+ # The first line are the column names
+ list = select.split("\n")
+ count = 0
+ for entry in list:
+ if entry.strip() != "":
+ # print the column names in case they change
+ if count == 0:
+ col_names_new = "start_time%send_time%s%s" % (
+ fs, fs, entry)
+ if col_names != col_names_new:
+ col_names = col_names_new
+ print col_names
+ else:
+ if row["end_time"]:
+ print "%s%s%s%s%s" % (row["start_time"], fs,
+ row["end_time"], fs, entry)
+ else:
+ print "%s%s%s%s" % (row["start_time"],
+ fs, fs, entry)
+ count += 1
main()
Modified: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2012-08-12 23:10:21 UTC (rev 52647)
@@ -19,7 +19,7 @@
# The @test
# We need to create a nice space time vector dataset with layers for testing
-t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer column=observation
+t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column=observation
t.vect.list input=prec_observer
t.vect.db.select input=prec_observer
t.vect.db.select input=prec_observer where="cat = 1" fs=" | "
@@ -28,7 +28,7 @@
# Time instances
t.register --o input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2004-01-01 00:00:00" increment="3 months"
-t.vect.observe.strds --o input=prec strds=precip_abs1 output=prec_observer
+t.vect.observe.strds --o input=prec strds=precip_abs1 output=prec_observer vector=prec_observer
Modified: grass/trunk/temporal/t.vect.export/t.vect.export.py
--- grass/trunk/temporal/t.vect.export/t.vect.export.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.export/t.vect.export.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,16 +2,16 @@
-# MODULE: t.vect.export
-# PURPOSE: Export a space time vector dataset.as GRASS specific archive file
+# MODULE: t.vect.export
-# for details.
+# PURPOSE: Export a space time vector dataset.as GRASS specific archive file
+# for details.
#%module
@@ -60,23 +60,24 @@
def main():
- # Get the options
+ # Get the options
- tgis.export_stds(_input, output, compression, workdir, where, _format, "stvds")
+ tgis.export_stds(
+ _input, output, compression, workdir, where, _format, "stvds")
Modified: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -67,6 +67,7 @@
def main():
# Get the options
@@ -82,12 +83,12 @@
- tgis.extract_dataset(input, output, "vector", where, expression, base, nprocs, register_null, layer, type)
+ tgis.extract_dataset(input, output, "vector", where, expression,
+ base, nprocs, register_null, layer, type)
main()
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2012-08-12 23:10:21 UTC (rev 52647)
@@ -19,7 +19,7 @@
t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
# The @test
-t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer column=prec
+t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column=prec
v.info prec_observer
t.info type=stvds input=prec_observer
Modified: grass/trunk/temporal/t.vect.import/t.vect.import.py
--- grass/trunk/temporal/t.vect.import/t.vect.import.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.import/t.vect.import.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,7 +4,7 @@
# MODULE: t.vect.import
# PURPOSE: Import a space time vector dataset archive file
@@ -73,23 +73,23 @@
def main():
- # Get the options
- exp = flags["e"]
- None, exp, overr, create, "stvds")
+ # Get the options
+ exp = flags["e"]
+ None, exp, overr, create, "stvds")
main()
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -4,8 +4,8 @@
# MODULE: t.vect.list
-# PURPOSE: List registered maps of a space time vector dataset
+# PURPOSE: List registered maps of a space time vector dataset
@@ -36,7 +36,7 @@
#%option
#% key: columns
#% type: string
-#% description: Select columns to be printed to stdout
+#% description: Select columns to be printed to stdout
#% required: no
#% multiple: yes
#% options: id,name,layer,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,points,lines,boundaries,centroids,faces,kernels,primitives,nodes,areas,islands,holes,volumes
@@ -65,7 +65,7 @@
#%flag
#% key: h
#%end
@@ -73,6 +73,7 @@
def main():
# Get the options
@@ -87,7 +88,8 @@
- tgis.list_maps_of_stds("stvds", input, columns, order, where, separator, method, header)
+ "stvds", input, columns, order, where, separator, method, header)
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,15 +2,15 @@
-# MODULE: t.vect.oberve.rast
+# MODULE: t.vect.oberve.rast
-# PURPOSE: Observe specific locations in a space time raster dataset over a periode of time using vector points
+# PURPOSE: Observe specific locations in a space time raster dataset over a periode of time using vector points
-# for details.
+# for details.
@@ -32,13 +32,13 @@
#%option G_OPT_V_OUTPUT
#% key: vector_output
-#% description: Name of the new created vector map that stores the sampled values
+#% description: Name of the new created vector map that stores the sampled values
#%end
#%option
#% key: column
#% type: string
-#% description: Name of the vector column to be created and to store sampled raster values, otherwise the space time raster name is used as column name
+#% description: Name of the vector column to be created and to store sampled raster values, otherwise the space time raster name is used as column name
#% required: no
#% multiple: no
#%end
@@ -57,6 +57,7 @@
def main():
# Get the options
@@ -76,16 +77,16 @@
dbif.connect()
if strds.find("@") >= 0:
strds_id = strds
else:
strds_id = strds + "@" + mapset
- strds_sp = tgis.space_time_raster_dataset(strds_id)
+ strds_sp = tgis.SpaceTimeRasterDataset(strds_id)
if strds_sp.is_in_db() == False:
dbif.close()
grass.fatal(_("Space time raster dataset <%s> not found") % (strds_id))
@@ -97,24 +98,27 @@
else:
- out_sp = tgis.space_time_vector_dataset(id)
- if out_sp.is_in_db(dbif) == True and grass.overwrite() == False:
+ out_sp = tgis.SpaceTimeVectorDataset(id)
+ if out_sp.is_in_db(dbif) == True and grass.overwrite() == False:
dbif.close()
- grass.fatal(_("Dataset <%s> found in temporal database, use the overwrite flag to overwrite") % (id))
+ grass.fatal(_("Dataset <%s> found in temporal database, "
+ "use the overwrite flag to overwrite") % (id))
# Overwrite existing stvds
if out_sp.is_in_db(dbif) == True and grass.overwrite() == True:
out_sp.select(dbif)
out_sp.delete(dbif)
# Select the raster maps
- rows = strds_sp.get_registered_maps("name,mapset,start_time,end_time", tempwhere, "start_time", dbif)
+ rows = strds_sp.get_registered_maps(
+ "name,mapset,start_time,end_time", tempwhere, "start_time", dbif)
if not rows:
dbif.close()
- grass.fatal(_("Space time vector dataset <%s> is empty") % out_sp.get_id())
+ grass.fatal(_("Space time vector dataset <%s> is empty") %
+ out_sp.get_id())
num_rows = len(rows)
@@ -122,95 +126,116 @@
vector_db = grass.vector.vector_db(input)
# We copy the vector table and create the new layers
if vector_db:
- # Use the first layer to copy the categories from
- layers= "1,"
+ # Use the first layer to copy the categories from
+ layers = "1,"
else:
- layers= ""
+ layers = ""
first = True
for layer in range(num_rows):
layer += 1
# Skip existing layer
- if vector_db and vector_db.has_key(layer) and vector_db[layer]["layer"] == layer:
- continue
+ if vector_db and layer in vector_db and \
+ vector_db[layer]["layer"] == layer:
+ continue
if first:
- layers += "%i"%(layer)
+ layers += "%i" % (layer)
first = False
else:
- layers += ",%i"%(layer)
+ layers += ",%i" % (layer)
# Use the name of the space time vector dataset as new vector name
vectmap = vector_output
# We create a new vector map using the categories of the original map
- ret = grass.run_command("v.category", input=input, layer=layers, output=vectmap, option="transfer", overwrite=grass.overwrite())
+ ret = grass.run_command("v.category", input=input, layer=layers,
+ output=vectmap, option="transfer",
if ret != 0:
- grass.fatal(_("Unable to create new layers for vector map <%s>") % (vectmap))
+ grass.fatal(_("Unable to create new layers for vector map <%s>")
+ % (vectmap))
# Create the output space time vector dataset
- out_sp.set_initial_values(strds_sp.get_temporal_type(), \
- strds_sp.get_semantic_type(),\
- _("Observaion of space time raster dataset <%s>")%(strds_id),\
- _("Observation of space time raster dataset <%s> with vector map <%s>")%(strds_id, input))
+ out_sp.set_initial_values(strds_sp.get_temporal_type(),
+ strds_sp.get_semantic_type(),
+ _("Observaion of space time raster "
+ "dataset <%s>") % (strds_id),
+ _("Observation of space time raster dataset <%s>"
+ " with vector map <%s>") % (strds_id, input))
out_sp.insert(dbif)
dummy = out_sp.get_new_map_instance(None)
- # Sample the space time raster dataset with the vector map at specific layer with v.what.rast
+ # Sample the space time raster dataset with the vector
+ # map at specific layer with v.what.rast
count = 1
for row in rows:
rastmap = row["name"] + "@" + row["mapset"]
- if column:
- col_name = column
- else:
- # Create a new column with name of the sampled space time raster dataset
- col_name = row["name"]
+ if column:
+ col_name = column
+ else:
+ # Create a new column with name of the
+ # sampled space time raster dataset
+ col_name = row["name"]
- coltype = "DOUBLE PRECISION"
- # Get raster map type
- rasterinfo = raster.raster_info(rastmap)
- if rasterinfo["datatype"] == "CELL":
- coltype = "INT"
+ coltype = "DOUBLE PRECISION"
+ # Get raster map type
+ rasterinfo = raster.raster_info(rastmap)
+ if rasterinfo["datatype"] == "CELL":
+ coltype = "INT"
# Try to add a column
- if vector_db and vector_db.has_key(count) and vector_db[count]["table"]:
- ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=count, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
- if ret != 0:
- dbif.close()
- grass.fatal(_("Unable to add column %s to vector map <%s> with layer %i")%(col_name, vectmap, count))
+ if vector_db and count in vector_db and vector_db[count]["table"]:
+ ret = grass.run_command("v.db.addcolumn", map=vectmap,
+ layer=count,
+ column="%s %s" % (col_name, coltype),
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to add column %s to vector map <%s> "
+ "with layer %i") % (col_name, vectmap, count))
else:
# Try to add a new table
- grass.message("Add table to layer %i"%(count))
- ret = grass.run_command("v.db.addtable", map=vectmap, layer=count, columns="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
- if ret != 0:
- dbif.close()
- grass.fatal(_("Unable to add table to vector map <%s> with layer %i")%(vectmap, count))
+ grass.message("Add table to layer %i" % (count))
+ ret = grass.run_command("v.db.addtable", map=vectmap, layer=count,
+ columns="%s %s" % (col_name, coltype),
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to add table to vector map "
+ "<%s> with layer %i") % (vectmap, count))
- # Call v.what.rast
- ret = grass.run_command("v.what.rast", map=vectmap, layer=count, raster=rastmap, column=col_name, where=where)
- if ret != 0:
- dbif.close()
- grass.fatal(_("Unable to run v.what.rast for vector map <%s> with layer %i and raster map <%s>")%(vectmap, count, rastmap))
- vect = out_sp.get_new_map_instance(dummy.build_id(vectmap, mapset, str(count)))
+ # Call v.what.rast
+ ret = grass.run_command("v.what.rast", map=vectmap,
+ layer=count, raster=rastmap,
+ column=col_name, where=where)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to run v.what.rast for vector map <%s> "
+ "with layer %i and raster map <%s>") % \
+ (vectmap, count, rastmap))
+ vect = out_sp.get_new_map_instance(dummy.build_id(vectmap,
+ mapset, str(count)))
vect.load()
if out_sp.is_time_absolute():
vect.set_absolute_time(start, end)
else:
- vect.set_relative_time(start, end, strds_sp.get_relative_time_unit())
+ vect.set_relative_time(
+ start, end, strds_sp.get_relative_time_unit())
if vect.is_in_db(dbif):
vect.update_all(dbif)
else:
vect.insert(dbif)
- out_sp.register_map(vect, dbif)
+ out_sp.register_map(vect, dbif)
count += 1
out_sp.update_from_registered_maps(dbif)
@@ -219,4 +244,3 @@
main()
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2012-08-12 23:10:21 UTC (rev 52647)
@@ -25,7 +25,7 @@
-t.vect.observe.strds input=test_1 strds=precip_abs1 output=test_1_observer vector=test_1_observer
+t.vect.observe.strds input=test_1 strds=precip_abs1 output=test_1_observer vector=test_1_observer
v.info test_1_observer
t.info type=stvds input=test_1_observer
t.vect.list input=test_1_observer
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -59,7 +59,7 @@
#%flag
#% key: h
#%end
@@ -67,6 +67,7 @@
def main():
# Get the options
@@ -82,10 +83,10 @@
- tgis.print_vector_dataset_univar_statistics(input, twhere, layer, type, column, where, extended, header, fs)
+ tgis.print_vector_dataset_univar_statistics(
+ input, twhere, layer, type, column, where, extended, header, fs)
main()
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-08-12 23:08:53 UTC (rev 52646)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-08-12 23:10:21 UTC (rev 52647)
@@ -2,15 +2,15 @@
-# MODULE: t.vect.what.strds
+# MODULE: t.vect.what.strds
-# PURPOSE: Uploads raster map values at spatial and temporal positions of vector points to the tables.
+# PURPOSE: Uploads raster map values at spatial and temporal positions of vector points to the tables.
-# for details.
+# for details.
@@ -63,6 +63,7 @@
def main():
# Get the options
@@ -82,19 +83,20 @@
dbif.connect()
id = input
else:
dbif.close()
sp.select(dbif)
@@ -103,8 +105,8 @@
else:
dbif.close()
@@ -113,20 +115,23 @@
if strds_sp.get_temporal_type() != sp.get_temporal_type():
dbif.close()
+ grass.fatal(_("Input and aggregation dataset must "
+ "have the same temporal type"))
# Check if intervals are present in the sample dataset
if sp.get_temporal_type() == "absolute":
map_time = sp.absolute_time.get_map_time()
else:
map_time = sp.relative_time.get_map_time()
dbif.close()
- grass.fatal(_("All registered maps of the space time vector dataset must have time intervals"))
+ grass.fatal(_("All registered maps of the space time vector "
+ "dataset must have time intervals"))
- rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time", tempwhere, "start_time", dbif)
- dummy = tgis.vector_dataset(None)
+ tempwhere, "start_time", dbif)
+ dummy = tgis.VectorDataset(None)
if not rows:
dbif.close()
@@ -140,28 +145,34 @@
count = 0
- raster_maps = tgis.collect_map_names(strds_sp, dbif, start, end, sampling)
+ raster_maps = tgis.collect_map_names(
+ strds_sp, dbif, start, end, sampling)
aggreagated_map_name = None
if raster_maps:
- # Aggregation
- if method != "disabled" and len(raster_maps) > 1:
- # Generate the temporary map name
- aggreagated_map_name = "aggreagated_map_name_"+ str(os.getpid())
- new_map = tgis.aggregate_raster_maps(raster_maps, aggreagated_map_name, start, end, 0, method, False, dbif)
- aggreagated_map_name = aggreagated_map_name + "_0"
- if new_map == None:
- continue
- # We overwrite the raster_maps list
- raster_maps = (new_map.get_id(), )
+ # Aggregation
+ if method != "disabled" and len(raster_maps) > 1:
+ # Generate the temporary map name
+ aggreagated_map_name = "aggreagated_map_name_" + \
+ str(os.getpid())
+ new_map = tgis.aggregate_raster_maps(raster_maps,
+ aggreagated_map_name,
+ start, end, 0, method,
+ False, dbif)
+ aggreagated_map_name = aggreagated_map_name + "_0"
+ if new_map is None:
+ continue
+ # We overwrite the raster_maps list
+ raster_maps = (new_map.get_id(), )
for rastermap in raster_maps:
if column:
col_name = column
else:
- # Create a new column with the SQL compliant name of the sampled raster map
+ # Create a new column with the SQL compliant
+ # name of the sampled raster map
col_name = rastermap.split("@")[0].replace(".", "_")
@@ -169,31 +180,45 @@
rasterinfo = raster.raster_info(rastermap)
coltype = "INT"
- if layer:
- ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=layer, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
- else:
- ret = grass.run_command("v.db.addcolumn", map=vectmap, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
+ if layer:
+ map=vectmap, layer=layer,
+ else:
if ret != 0:
dbif.close()
- grass.fatal(_("Unable to add column %s to vector map <%s>")%(col_name, vectmap))
+ grass.fatal(_("Unable to add column %s to vector map <%s>")
+ % (col_name, vectmap))
# Call v.what.rast
if layer:
- ret = grass.run_command("v.what.rast", map=vectmap, layer=layer, raster=rastermap, column=col_name, where=where)
- else:
- ret = grass.run_command("v.what.rast", map=vectmap, raster=rastermap, column=col_name, where=where)
+ layer=layer, raster=rastermap,
+ else:
+ raster=rastermap, column=col_name,
+ where=where)
if ret != 0:
dbif.close()
- grass.fatal(_("Unable to run v.what.rast for vector map <%s> and raster map <%s>")%(vectmap, rastermap))
+ grass.fatal(_("Unable to run v.what.rast for vector map "
+ "<%s> and raster map <%s>") % (vectmap,
+ rastermap))
if aggreagated_map_name:
- ret = grass.run_command("g.remove", rast=aggreagated_map_name)
- if ret != 0:
- dbif.close()
- grass.fatal(_("Unable to remove raster map <%s>")%(aggreagated_map_name))
+ ret = grass.run_command("g.remove",
+ rast=aggreagated_map_name)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to remove raster map <%s>")
+ % (aggreagated_map_name))
# Use the first map in case a column names was provided
if column:
break
@@ -203,4 +228,3 @@
if __name__ == "__main__":
options, flags = grass.parser()
main()
