[GRASS-SVN] r52670 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Aug 13 13:44:41 PDT 2012
Author: huhabla
Date: 2012-08-13 13:44:41 -0700 (Mon, 13 Aug 2012)
New Revision: 52670
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/pythontemporallib.dox
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/temporal_extent.py
PEP8 compliance and documentation update
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -310,18 +310,28 @@
return statement
def set_time_to_absolute(self):
+ """!Set the temporal type to absolute"""
self.base.set_ttype("absolute")
def set_time_to_relative(self):
+ """!Set the temporal type to relative"""
self.base.set_ttype("relative")
def is_time_absolute(self):
+ """!Return True in case the temporal type is absolute
+ @return True if temporal type is absolute, False otherwise
if "temporal_type" in self.base.D:
return self.base.get_ttype() == "absolute"
else:
return None
def is_time_relative(self):
+ """!Return True in case the temporal type is relative
+ @return True if temporal type is relative, False otherwise
return self.base.get_ttype() == "relative"
else:
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -213,9 +213,10 @@
The map list must be ordered by start time
The temporal type can be:
- * point -> only the start time is present
- * interval -> start and end time
- * invalid -> No valid time point or interval found
+ - point -> only the start time is present
+ - interval -> start and end time
+ - invalid -> No valid time point or interval found
@param maps: A sorted (start_time) list of AbstractDataset objects
@param dbif: The database interface to be used
@@ -318,23 +319,24 @@
Allowed and not allowed temporal relationships for correct topology:
@verbatim
- * after -> allowed
- * precedes -> allowed
- * follows -> allowed
+ - after -> allowed
+ - precedes -> allowed
+ - follows -> allowed
- * equivalent -> not allowed
- * during -> not allowed
- * contains -> not allowed
- * overlaps -> not allowed
- * overlapped -> not allowed
- * starts -> not allowed
- * finishes -> not allowed
- * started -> not allowed
- * finished -> not allowed
+ - equivalent -> not allowed
+ - during -> not allowed
+ - contains -> not allowed
+ - overlaps -> not allowed
+ - overlapped -> not allowed
+ - starts -> not allowed
+ - finishes -> not allowed
+ - started -> not allowed
+ - finished -> not allowed
@endverbatim
+ @param dbif: The database interface to be used
@return True if topology is correct
if maps is None:
@@ -419,7 +421,7 @@
only the start time is used for sampling. In case of mixed
of interval data the user can chose between:
- * start: Select maps of which the start time is
+ - start: Select maps of which the start time is
located in the selection granule
@verbatim
map : s
@@ -432,14 +434,14 @@
granule: s-----------------e
@endverbatim
- * during: Select maps which are temporal
+ - during: Select maps which are temporal
during the selection granule
@verbatim
map : s-----------e
@endverbatim
- * overlap: Select maps which temporal overlap
+ - overlap: Select maps which temporal overlap
@verbatim
map : s-----------e
@@ -449,28 +451,28 @@
granule: s----------e
@endverbatim
- * contain: Select maps which temporally contain
+ - contain: Select maps which temporally contain
@verbatim
map : s-----------------e
granule: s-----------e
@endverbatim
- * equal: Select maps which temporally equal
+ - equal: Select maps which temporally equal
to the selection granule
@verbatim
map : s-----------e
@endverbatim
- * follows: Select maps which temporally follow
+ - follows: Select maps which temporally follow
@verbatim
map : s-----------e
@endverbatim
- * precedes: Select maps which temporally precedes
+ - precedes: Select maps which temporally precedes
@verbatim
map : s-----------e
@@ -735,8 +737,8 @@
@param order: The SQL order statement to be used to order the
objects in the list without "ORDER BY"
- In case nothing found None is returned
+ @return The ordered map object list,
+ In case nothing found None is returned
dbif, connect = init_dbif(dbif)
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/base.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -279,7 +279,7 @@
dbif.close()
def get_is_in_db_statement(self):
- """Return the selection string"""
+ """!Return the selection string"""
return "SELECT id FROM " + self.get_table_name() + \
" WHERE id = \'" + str(self.ident) + "\';\n"
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/core.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -9,7 +9,7 @@
Usage:
-\code
+ at code
>>> import grass.temporal as tgis
>>> # Create the temporal database
@@ -25,7 +25,7 @@
"SELECT name from raster_base where name = 'precipitation'"
>>> dbif.close()
-\endcode
+ at endcode
(C) 2008-2011 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -212,8 +212,8 @@
"""!This class represents the database interface connection
The following DBMS are supported:
- * sqlite via the sqlite3 standard library
- * postgresql via psycopg2
+ * sqlite via the sqlite3 standard library
+ * postgresql via psycopg2
def __init__(self):
@@ -250,6 +250,22 @@
def mogrify_sql_statement(self, content):
"""!Return the SQL statement and arguments as executable SQL string
+ @param content: The content as tuple with two entries, the first
+ entry is the SQL statement with DBMI specific
+ place holder (?), the second entry is the argument
+ list that should substitue the place holder.
+ Usage:
+ @code
+ >>> dbif = SQLDatabaseInterfaceConnection()
+ >>> dbif.mogrify_sql_statement(["SELECT ctime FROM raster_base WHERE id = ?",
+ ... ["soil at PERMANENT",]])
+ "SELECT ctime FROM raster_base WHERE id = 'soil at PERMANENT'"
+ @endcode
sql = content[0]
args = content[1]
@@ -350,13 +366,18 @@
if not a new one will be created, connected and True will be returned
Usage code sample:
- \code
+ @code
- dbif, connect = tgis.init_dbif(dbif)
+ dbif, connect = tgis.init_dbif(None)
+ sql = dbif.mogrify_sql_statement(["SELECT * FROM raster_base WHERE ? = ?"],
+ ["id", "soil at PERMANENT"])
+ dbif.execute_transaction(sql)
if connect:
dbif.close()
- \code
+ @endcode
if dbif is None:
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -206,11 +206,11 @@
def adjust_datetime_to_granularity(mydate, granularity):
"""!Modify the datetime object to fit the given granularity
- * Years will start at the first of Januar
- * Months will start at the first day of the month
- * Days will start at the first Hour of the day
- * Hours will start at the first minute of an hour
- * Minutes will start at the first second of a minute
+ - Years will start at the first of Januar
+ - Months will start at the first day of the month
+ - Days will start at the first Hour of the day
+ - Hours will start at the first minute of an hour
+ - Minutes will start at the first second of a minute
Usage:
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/metadata.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -509,15 +509,11 @@
class VectorMetadata(SQLDatabaseInterface):
"""!This is the vector metadata class
This class is the interface to the vector_metadata table in the
temporal database that stores the metadata of all registered
- 3D raster maps.
+ vector maps.
- The metadata includes all raster metadata variables and additional
- the number of depths, the top-bottom resolution and the space time 3D
- raster dataset register table is stored.
Usage:
@code
@@ -693,7 +689,8 @@
return None
def get_3d_info(self):
- """!Return True if the map is three dimensional, False if not and None if not info was found"""
+ """!Return True if the map is three dimensional,
+ False if not and None if not info was found"""
if "is_3d" in self.D:
return self.D["is_3d"]
else:
@@ -976,11 +973,12 @@
class STDSRasterMetadataBase(STDSMetadataBase):
"""!This is the space time dataset metadata base
- class for strds and str3ds datasets
+ class for strds and str3ds datasets
- Most of the metadata values are set by triggers in the database when
- new raster or voxel maps are added. Therefor only some
- set- an many get-functions are available.
+ Most of the metadata values are set by SQL scripts in the database when
+ new maps are added. Therefor only some set- an many
+ get-functions are available.
Usage:
@@ -1168,6 +1166,10 @@
space time raster datasets
+ new raster maps are added. Therefor only some set- an many
Usage:
@code
@@ -1259,12 +1261,16 @@
class STR3DSMetadata(STDSRasterMetadataBase):
- """!This is the space time raster3d metadata class
+ """!This is the space time 3D raster metadata class
This class is the interface to the str3ds_metadata table in the
space time 3D raster datasets
+ new 3D raster maps are added. Therefor only some set- an many
Usage:
@code
@@ -1391,8 +1397,12 @@
class STVDSMetadata(STDSMetadataBase):
"""!This is the space time vector dataset metadata class
+ This class is the interface to the stvds_metadata table in the
+ temporal database that stores the metadata of all registered
+ space time vector datasets
new vector maps are added. Therefor only some set- an many get-functions
are available.
Modified: grass/trunk/lib/python/temporal/pythontemporallib.dox
--- grass/trunk/lib/python/temporal/pythontemporallib.dox 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/pythontemporallib.dox 2012-08-13 20:44:41 UTC (rev 52670)
@@ -8,20 +8,57 @@
List of modules:
+Core functionality such as the database interface connection to sqlite3
+and postgresql as well as the creation of the temporal database are defined here:
+- python::temporal::core
+In these modules are the temporal database interfaces for raster maps,
+3D raster maps, vector maps and space time datasets defined.
+Additionally the temporal and spatial extent modules implement the topological
+relationship computation that is needed for spatio-temporal topology computation.
+- python::temporal::base
+- python::temporal::spatial_extent
+- python::temporal::temporal_extent
+- python::temporal::metadata
+Several "abstract" modules are defined that implement the shared functionality
+of time stamped maps and space time datasets, such as temporal and spatial
+handling and representation.
- python::temporal::abstract_dataset
- python::temporal::abstract_map_dataset
- python::temporal::abstract_space_time_dataset
-- python::temporal::aggregation
-- python::temporal::base
-- python::temporal::core
+All dataset classes that are used in the GRASS temporal modules are specified
+here:
+- python::temporal::space_time_datasets
+Helper functions to compute temporal granularity, handling of datetime objects
+and their conversion as well as topology computation are defined in these modules:
- python::temporal::datetime_math
-- python::temporal::metadata
-- python::temporal::space_time_datasets
+- python::temporal::temporal_relationships
+- python::temporal::temporal_granularity
+Functionality that is shared between different temporal GRASS modules, such as
+map listing, map registration and unregistration, aggregation, extraction,
+map calculation, statistics as well as import and export of
+space time datasets are defined here:
- python::temporal::space_time_datasets_tools
-- python::temporal::spatial_extent
-- python::temporal::temporal_extent
-- python::temporal::temporal_granularity
-- python::temporal::temporal_relationships
+- python::temporal::aggregation
+- python::temporal::extract
+- python::temporal::mapcalc
+- python::temporal::stds_export
+- python::temporal::stds_import
+- python::temporal::univar_statistics
+Lots of unit tests:
- python::temporal::unit_tests
\section pythonTempAuthors Authors
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -811,7 +811,8 @@
return SpaceTimeRasterDataset(ident)
def get_new_map_instance(self, ident):
- """!Return a new instance of a map dataset which is associated with the type of this class"""
+ """!Return a new instance of a map dataset which is associated "
+ "with the type of this class"""
return RasterDataset(ident)
def get_map_register(self):
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -94,15 +94,29 @@
self.set_projection(proj)
def overlapping_2d(self, extent):
- """!Return True if the two dimensional extents overlap.
- Code is lend from wind_overlap.c in lib/gis
- Overlapping includes the spatial relations:
- * contain
- * in
- * cover
- * covered
- * equivalent
+ """!Return True if this (A) and the provided spatial extent (B) overlaps
+ in two dimensional space.
+ Code is lend from wind_overlap.c in lib/gis
+ Overlapping includes the spatial relations:
+ - contain
+ - in
+ - cover
+ - covered
+ - equivalent
+ @code
+ >>> A = SpatialExtent(north=80, south=20, east=60, west=10)
+ >>> B = SpatialExtent(north=80, south=20, east=60, west=10)
+ >>> A.overlapping_2d(B)
+ True
+ @endcode
+ @param extent: The spatial extent to check overlapping with
+ @return True or False
if self.get_projection() != extent.get_projection():
@@ -140,25 +154,30 @@
return True
def overlapping(self, extent):
- """!Return True if the three dimensional extents overlap
- * contain
- * in
- * cover
- * covered
- * equivalent
- Usage:
+ extent (B) overlaps in three dimensional space.
- @code
- >>> A = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
- >>> B = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
- >>> A.overlapping(B)
- True
- @endcode
+ - contain
+ - in
+ - cover
+ - covered
+ - equivalent
+ Usage:
+ @code
+ >>> A = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> A.overlapping(B)
+ True
+ @endcode
if not self.overlapping_2d(extent):
@@ -177,7 +196,10 @@
def intersect_2d(self, extent):
"""!Return the two dimensional intersection as spatial_extent
- object or None in case no intersection was found.
+ object or None in case no intersection was found.
+ @param extent: The spatial extent to intersect with
+ @return The intersection spatial extent
@@ -230,8 +252,10 @@
@code
+ ... bottom=-50, top=50)
>>> C = A.intersect(B)
>>> C.print_info()
+-------------------- Spatial extent ----------------------------------------+
@@ -241,7 +265,8 @@
| West:....................... 10.0
| Top:........................ 50.0
| Bottom:..................... -50.0
- >>> B = SpatialExtent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=10,
>>> C = A.intersect(B)
>>> C.print_info()
@@ -251,7 +276,8 @@
- >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=30,
>>> C = A.intersect(B)
>>> C.print_info()
@@ -261,7 +287,8 @@
| West:....................... 30.0
- >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
+ ... bottom=-30, top=50)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -271,7 +298,8 @@
| Bottom:..................... -30.0
- >>> B = SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
+ ... bottom=-30, top=30)
>>> C = A.intersect(B)
>>> C.print_info()
@@ -283,6 +311,10 @@
@endcode
if not self.overlapping(extent):
@@ -310,7 +342,8 @@
return new
def is_in_2d(self, extent):
- """!Check two dimensional if the self is located in extent
+ """!Return True if this extent (A) is located in the provided spatial
+ extent (B) in two dimensions.
@verbatim
_____
@@ -319,6 +352,9 @@
|_____|B
@endverbatim
core.error(_("Projections are different. Unable to compute "
@@ -357,20 +393,26 @@
return True
def is_in(self, extent):
- """!Check three dimensional if the self is located in extent
+ extent (B) in three dimensions.
Usage:
@code
- >>> A = SpatialExtent(north=79, south=21, east=59, west=11, bottom=-49, top=49)
+ >>> A = SpatialExtent(north=79, south=21, east=59, west=11,
+ ... bottom=-49, top=49)
>>> A.is_in(B)
True
>>> B.is_in(A)
False
@endcode
if not self.is_in_2d(extent):
return False
@@ -389,16 +431,71 @@
return True
def contain_2d(self, extent):
- """!Check two dimensional if self contains extent """
+ """!Return True if this extent (A) contains the provided spatial
+ Usage:
+ @code
+ >>> B = SpatialExtent(north=79, south=21, east=59, west=11)
+ >>> A.contain_2d(B)
+ True
+ >>> B.contain_2d(A)
+ False
+ @endcode
return extent.is_in_2d(self)
- def contain(self, extent):
- """!Check three dimensional if self contains extent """
+ def contain(self, extent):
+ Usage:
+ @code
+ >>> B = SpatialExtent(north=79, south=21, east=59, west=11,
+ >>> A.contain(B)
+ True
+ >>> B.contain(A)
+ False
+ @endcode
return extent.is_in(self)
def equivalent_2d(self, extent):
- """!Check two dimensional if self is equivalent to extent """
+ """!Return True if this extent (A) is equal to the provided spatial
+ Usage:
+ @code
+ >>> A.equivalent_2d(B)
+ True
+ >>> B.equivalent_2d(A)
+ True
+ @endcode
"equivalent_2d for spatial extents"))
@@ -436,7 +533,27 @@
return True
def equivalent(self, extent):
- """!Check three dimensional if self is equivalent to extent """
+ Usage:
+ @code
+ >>> A.equivalent(B)
+ True
+ >>> B.equivalent(A)
+ True
+ @endcode
if not self.equivalent_2d(extent):
return False
@@ -455,30 +572,35 @@
return True
def cover_2d(self, extent):
- """!Return True if two dimensional self covers extent
+ """!Return True if this extent (A) covers the provided spatial
- @verbatim
- _____ _____ _____ _____
- |A __| |__ A| |A | B| |B | A|
- | |B | | B| | | |__| |__| |
- |__|__| |__|__| |_____| |_____|
+ @verbatim
+ _____ _____ _____ _____
+ |A __| |__ A| |A | B| |B | A|
+ | |B | | B| | | |__| |__| |
+ |__|__| |__|__| |_____| |_____|
+ |A|B| | |A __| |A _ | |__ A|
+ | |_| | | |__|B | |B| | B|__| |
+ |_____| |_____| |_|_|_| |_____|
+ |A|B | |_____|A |A|B|A| |_____|A
+ | | | |B | | | | | |_____|B
+ |_|___| |_____| |_|_|_| |_____|A
+ @endverbatim
+ The following cases are excluded:
+ - contain
+ - in
+ - equivalent
- |A|B| | |A __| |A _ | |__ A|
- | |_| | | |__|B | |B| | B|__| |
- |_____| |_____| |_|_|_| |_____|
- |A|B | |_____|A |A|B|A| |_____|A
- | | | |B | | | | | |_____|B
- |_|___| |_____| |_|_|_| |_____|A
- @endverbatim
- The following cases are excluded:
- * contain
- * in
- * equivalent
@@ -540,16 +662,21 @@
return True
def cover(self, extent):
- """!Return True if three dimensional self covers extent
+ """!Return True if this extent covers the provided spatial
+ extent in three dimensions.
+ - contain
+ - in
+ - equivalent
- * contain
- * in
- * equivalent
- core.error(_("Projections are different. Unable to compute cover for spatial extents"))
+ core.error(_("Projections are different. Unable to compute "
+ "cover for spatial extents"))
return False
# Exclude equivalent_2d
@@ -625,34 +752,61 @@
return True
def covered_2d(self, extent):
- """!Check two dimensional if self is covered by extent """
+ """!Return True if this extent is covered by the provided spatial
+ extent in two dimensions.
+ - contain
+ - in
+ - equivalent
return extent.cover_2d(self)
def covered(self, extent):
- """!Check three dimensional if self is covered by extent """
+ - contain
+ - in
+ - equivalent
return extent.cover(self)
def overlap_2d(self, extent):
- """!Return True if the two dimensional extents overlap. Code is
- lend from wind_overlap.c in lib/gis
+ """!Return True if this extent (A) overlaps with the provided spatial
+ @verbatim
+ _____
+ |A __|__
+ | | | B|
+ |__|__| |
+ |_____|
- @verbatim
- _____
- |A __|__
- | | | B|
- |__|__| |
- |_____|
- @endverbatim
- * contain
- * in
- * cover
- * covered
- * equivalent
+ @endverbatim
+ - contain
+ - in
+ - cover
+ - covered
+ - equivalent
if self.contain_2d(extent):
@@ -700,14 +854,19 @@
return True
def overlap(self, extent):
+ """!Return True if this extent overlaps with the provided spatial
- * contain
- * in
- * cover
- * covered
- * equivalent
+ - contain
+ - in
+ - cover
+ - covered
+ - equivalent
if self.is_in(extent):
@@ -763,27 +922,37 @@
return True
def meet_2d(self, extent):
- """!Check if self and extent meet each other in two dimensions
+ """!Return True if this extent (A) meets with the provided spatial
@verbatim
- | A | B | | B | A |
- |_____| | | | |
- |_____| |_____|_____|
+ _____ _____
+ | A | B |
+ |_____| |
+ |_____|
+ _____ _____
+ | B | A |
+ |_____|_____|
___
| A |
- |___| _____
- | B | | B |
- |_____| |_____|_
- | A |
- |_____|
+ |___|
+ | B |
+ |_____|
+ _____
+ | B |
+ |_____|_
+ | A |
+ |_____|
@endverbatim
eN = extent.get_north()
@@ -841,7 +1010,12 @@
return True
def meet(self, extent):
- """!Check if self and extent meet each other in three dimensions"""
+ """!Return True if this extent meets with the provided spatial
eS = extent.get_south()
eE = extent.get_east()
@@ -916,7 +1090,21 @@
return True
def disjoint_2d(self, extent):
- """!Return True if the two dimensional extents are disjoint
+ """!Return True if this extent (A) is disjoint with the provided spatial
+ @verbatim
+ _____
+ | A |
+ |_____|
+ _______
+ | B |
+ |_______|
+ @endverbatim
if self.overlapping_2d(extent) or self.meet_2d(extent):
@@ -924,7 +1112,11 @@
return True
def disjoint(self, extent):
- """!Return True if the three dimensional extents are disjoint
+ """!Return True if this extent is disjoint with the provided spatial
if self.overlapping(extent) or self.meet(extent):
@@ -932,18 +1124,20 @@
return True
def spatial_relation_2d(self, extent):
- """!Returns the two dimensional spatial relation between self and extent
+ """!Returns the two dimensional spatial relation between this
+ extent and the provided spatial extent in two dimensions.
Spatial relations are:
- * disjoint
- * meet
- * overlap
- * cover
- * covered
- * in
- * contain
- * equivalent
+ - disjoint
+ - meet
+ - overlap
+ - cover
+ - covered
+ - in
+ - contain
+ - equivalent
Usage: see self.spatial_relation()
@@ -967,17 +1161,19 @@
return "unknown"
def spatial_relation(self, extent):
- """!Returns the three dimensional spatial relation between self and extent
+ extent and the provided spatial extent in three dimensions.
- * disjoint
- * meet
- * overlap
- * cover
- * covered
- * in
- * contain
- * equivalent
+ - disjoint
+ - meet
+ - overlap
+ - cover
+ - covered
+ - in
+ - contain
+ - equivalent
Usage:
@@ -1157,7 +1353,7 @@
return "unknown"
def set_spatial_extent(self, north, south, east, west, top, bottom):
- """!Set the spatial extent"""
+ """!Set the three dimensional spatial extent"""
self.set_north(north)
self.set_south(south)
@@ -1176,6 +1372,7 @@
self.D["proj"] = proj
def set_spatial_extent_2d(self, north, south, east, west):
+ """!Set the two dimensional spatial extent"""
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-13 16:51:01 UTC (rev 52669)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2012-08-13 20:44:41 UTC (rev 52670)
@@ -577,20 +577,21 @@
[Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
The following temporal relationships are supported:
- * equivalent
- * during
- * contains
- * overlaps
- * overlapped
- * after
- * before
- * starts
- * finishes
- * started
- * finished
- * follows
- * precedes
+ - equivalent
+ - during
+ - contains
+ - overlaps
+ - overlapped
+ - after
+ - before
+ - starts
+ - finishes
+ - started
+ - finished
+ - follows
+ - precedes
@param extent: The temporal extent
@return The name of the temporal relation or None if no relation found
@@ -886,7 +887,7 @@
class RelativeTemporalExtent(AbstractTemporalExtent):
- """!This is the relative time class for all maps and spacetime datasets
+ """!This is the relative time class for all maps and space time datasets
start_time and end_time must be of type integer
@@ -894,7 +895,7 @@
@code
- >>> A = RelativeTemporalExtent(table="raster_absolute_time",
+ >>> A = RelativeTemporalExtent(table="raster_relative_time",
... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years")
>>> A.id
'soil at PERMANENT'
@@ -925,12 +926,13 @@
def set_unit(self, unit):
"""!Set the unit of the relative time. Valid units are:
- * years
- * months
- * days
- * hours
- * minutes
- * seconds
+ - years
+ - months
+ - days
+ - hours
+ - minutes
+ - seconds
self.D["unit"] = unit
@@ -997,7 +999,7 @@
class STDSRelativeTime(RelativeTemporalExtent):
@@ -1005,11 +1007,11 @@
@code
- >>> A = STDSRelativeTime(table="raster_absolute_time",
- ... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years",
+ >>> A = STDSRelativeTime(table="strds_relative_time",
+ ... ident="strds at PERMANENT", start_time=0, end_time=1, unit="years",
... granularity=5, map_time="interval")
>>> A.id
- 'soil at PERMANENT'
+ 'strds at PERMANENT'
>>> A.start_time
0
>>> A.end_time
