[GRASS-SVN] r52671 - grass-addons/grass6/imagery/i.despeckle
svn_grass at osgeo.org
Mon Aug 13 18:52:13 PDT 2012
Author: maning
Date: 2012-08-13 18:52:13 -0700 (Mon, 13 Aug 2012)
New Revision: 52671
grass-addons/grass6/imagery/i.despeckle/i.despeckle
new filter enhanced lee
Modified: grass-addons/grass6/imagery/i.despeckle/i.despeckle
--- grass-addons/grass6/imagery/i.despeckle/i.despeckle 2012-08-13 20:44:41 UTC (rev 52670)
+++ grass-addons/grass6/imagery/i.despeckle/i.despeckle 2012-08-14 01:52:13 UTC (rev 52671)
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/sh -x
@@ -6,8 +6,9 @@
# AUTHOR(S): Markus Neteler, Maning Sambale
# PURPOSE: FGAMMA -- Gamma SAR Speckle Filter, based on
# http://web.archive.org/web/20050826071553/http://www.pcigeomatics.com/cgi-bin/pcihlp/M_FGAMMA
-# http://web.archive.org/web/20070122173456/http://www.pcigeomatics.com/cgi-bin/pcihlp/FLE|ALGORITHM
+# http://web.archive.org/web/20050425160834/http://www.pcigeomatics.com/cgi-bin/pcihlp/M_FLE
# http://web.archive.org/web/20071216181051/http://www.pcigeomatics.com/cgi-bin/pcihlp/FELEE
+# web.archive.org/web/20050425104814/http://www.pcigeomatics.com/cgi-bin/pcihlp/M_FKUAN
# http://web.archive.org/web/20071216081728/http://www.pcigeomatics.com/cgi-bin/pcihlp/FFROST
# http://web.archive.org/web/20071216181046/http://www.pcigeomatics.com/cgi-bin/pcihlp/FEFROST
@@ -53,7 +54,7 @@
#% type: string
#% required: yes
#% multiple: no
-#% options: gamma,lee,kuan
+#% options: gamma,lee,kuan,elee
#% description: Despeckle operation
#% answer: gamma
#%End
@@ -70,11 +71,21 @@
#% type: integer
#% required: no
#% multiple: no
-#% description: Number of looks (1: single look)
+#% description: Number of looks (0 <= x <= 100)
#% answer: 1
#%End
+#%Option
+#% key: dfactor
+#% type: real
+#% required: no
+#% multiple: no
+#% description: Damping factor (0.0 <= x <= 10.0)
+#% answer: 1.0
+#%End
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." 1>&2
exit 1
@@ -95,6 +106,7 @@
NumberLooks=$GIS_OPT_LOOKS # controls the amount of smoothing applied to image
OUTPUT=$GIS_OPT_OUTPUT
METHOD=$GIS_OPT_METHOD
+DFACTOR=$GIS_OPT_DFACTOR
@@ -129,7 +141,7 @@
# Ic = center pixel in filter window
r.mapcalc "$OUTPUT = $MAP * $MAP.W + $MAP.mean * (1.0 - $MAP.W)"
- g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.W
+ g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.ci,$MAP.W
fi
if [ $METHOD == "kuan" ]
@@ -184,9 +196,42 @@
- g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.A,$MAP.B,$MAP.D,$MAP.W
+ g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.A,$MAP.B,$MAP.D
fi
+if [ $METHOD == "elee" ]
+then
+ echo "Processing with Enhanced LEE filter"
+ # A 7x7 filter usually gives the best results.
+ # Cmax = SQRT(1+2/NumberLooks)
+ Cmax="`echo $Cu | awk '{printf "%f", sqrt((1+2) * $1)}'`"
+ # W = exp (-DampFactor (Ci-Cu)/(Cmax - Ci))
+ r.mapcalc "$MAP.W = exp (((-1 * $DFACTOR) * ($MAP.Ci - $Cu)) / ($Cmax - $MAP.Ci))"
+ # Rf = Im * W + Ic * (1-W)
+ r.mapcalc "$MAP.rf = $MAP.mean * $MAP.W + $MAP * (1 - $MAP.W)"
+ # R = Im for Ci <= Cu
+ # Rf = Im * W + Ic * (1-W) for Cu < Ci < Cmax
+ # R = Ic for Ci >= Cmax
+ r.mapcalc "$OUTPUT = eval(r1 = $MAP.mean, r2 = $MAP.rf, r3 = $MAP, \\
+ if($MAP.ci <= $Cu, r1, \\
+ if($MAP.ci > $Cu && $MAP.ci < $Cmax, r2, \\
+ if($MAP.ci >= $Cmax, r3, null() ) \\
+ g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.W
+fi
r.colors $OUTPUT col=grey -e
