[GRASS-SVN] r52675 - grass/trunk/scripts/r.reclass.area
svn_grass at osgeo.org
Tue Aug 14 03:18:31 PDT 2012
Author: annakrat
Date: 2012-08-14 03:18:31 -0700 (Tue, 14 Aug 2012)
New Revision: 52675
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
r.reclass.area: fp maps support, remove temp maps, spaces instead of tabs
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2012-08-14 09:16:17 UTC (rev 52674)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2012-08-14 10:18:31 UTC (rev 52675)
@@ -13,6 +13,7 @@
# for details.
+# 8/2012: added fp maps support, cleanup, removed tabs AK
# 3/2007: added label support MN
# 3/2004: added parser support MN
# 11/2001 added mapset support markus
@@ -49,8 +50,11 @@
import sys
import os
+import atexit
import grass.script as grass
+TMPRAST = []
def main():
infile = options['input']
lesser = options['lesser']
@@ -61,59 +65,80 @@
kv = grass.parse_key_val(s, sep = ':')
s = kv['projection'].strip().split()
if s == '0':
- grass.fatal(_("xy-locations are not supported"))
- grass.fatal(_("Need projected data with grids in meters"))
+ grass.fatal(_("xy-locations are not supported"))
+ grass.fatal(_("Need projected data with grids in meters"))
if not lesser and not greater:
- grass.fatal(_("You have to specify either lesser= or greater="))
+ grass.fatal(_("You have to specify either lesser= or greater="))
if lesser and greater:
- grass.fatal(_("lesser= and greater= are mutually exclusive"))
+ grass.fatal(_("lesser= and greater= are mutually exclusive"))
if lesser:
- limit = float(lesser)
+ limit = float(lesser)
if greater:
- limit = float(greater)
+ limit = float(greater)
if not grass.find_file(infile)['name']:
- grass.fatal(_("Raster map <%s> not found") % infile)
+ grass.fatal(_("Raster map <%s> not found") % infile)
clumpfile = "%s.clump.%s" % (infile.split('@')[0], outfile)
+ TMPRAST.append(clumpfile)
if not grass.overwrite():
- if grass.find_file(clumpfile)['name']:
- grass.fatal(_("Temporary raster map <%s> exists") % clumpfile)
+ if grass.find_file(clumpfile)['name']:
+ grass.fatal(_("Temporary raster map <%s> exists") % clumpfile)
grass.message(_("Generating a clumped raster file ..."))
grass.run_command('r.clump', input = infile, output = clumpfile)
if lesser:
- grass.message(_("Generating a reclass map with area size less than or equal to %f hectares...") % limit)
+ grass.message(_("Generating a reclass map with area size less than or equal to %f hectares...") % limit)
else:
- grass.message(_("Generating a reclass map with area size greater than or equal to %f hectares...") % limit)
+ grass.message(_("Generating a reclass map with area size greater than or equal to %f hectares...") % limit)
recfile = outfile + '.recl'
+ TMPRAST.append(recfile)
- p1 = grass.pipe_command('r.stats', flags = 'aln', input = (clumpfile, infile), fs = '|')
+ flags = 'aln'
+ if grass.raster_info(infile)['datatype'] in ('FCELL', 'DCELL'):
+ flags += 'i'
+ p1 = grass.pipe_command('r.stats', flags = flags, input = (clumpfile, infile), fs = '|')
p2 = grass.feed_command('r.reclass', input = clumpfile, output = recfile, rules = '-')
+ rules = ''
for line in p1.stdout:
- f = line.rstrip('\r\n').split('|')
- if len(f) < 5:
- continue
- hectares = float(f[4]) * 0.0001
- if lesser:
- test = hectares <= limit
- else:
- test = hectares >= limit
- if test:
- p2.stdin.write("%s = %s %s\n" % (f[0], f[2], f[3]))
+ f = line.rstrip('\r\n').split('|')
+ if len(f) < 5:
+ continue
+ hectares = float(f[4]) * 0.0001
+ if lesser:
+ test = hectares <= limit
+ else:
+ test = hectares >= limit
+ if test:
+ rules += "%s = %s %s\n" % (f[0], f[2], f[3])
+ if rules:
+ p2.stdin.write(rules)
p1.wait()
p2.stdin.close()
p2.wait()
+ if p2.returncode != 0:
+ if lesser:
+ grass.fatal(_("No areas of size less than or equal to %f hectares found.") % limit)
+ else:
+ grass.fatal(_("No areas of size greater than or equal to %f hectares found.") % limit)
grass.message(_("Generating output raster map <%s>...") % outfile)
grass.mapcalc("$outfile = $recfile", outfile = outfile, recfile = recfile)
- grass.run_command('g.remove', rast = [recfile, clumpfile], quiet = True)
+def cleanup():
+ """!Delete temporary maps"""
+ TMPRAST.reverse() # reclassed map first
+ for rast in TMPRAST:
+ grass.run_command("g.remove",
+ rast = rast,
+ quiet = True)
if __name__ == "__main__":
options, flags = grass.parser()
- main()
+ atexit.register(cleanup)
+ sys.exit(main())
