[GRASS-SVN] r52676 - in grass/trunk: lib/python lib/python/temporal lib/vector temporal temporal/t.rast.import temporal/t.rast.list temporal/t.rast.out.vtk
svn_grass at osgeo.org
Wed Aug 15 08:26:30 PDT 2012
Author: huhabla
Date: 2012-08-15 08:26:29 -0700 (Wed, 15 Aug 2012)
New Revision: 52676
grass/trunk/lib/python/core.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/vector/vectorlib.dox
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
Small bugfixing and error message cleanup
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/lib/python/core.py 2012-08-15 15:26:29 UTC (rev 52676)
@@ -614,7 +614,8 @@
kvdict[key] = value_list
return kvdict
-def compare_key_value_text_files(filename_a, filename_b, sep=":", val_sep=",", precision=0.000001):
+def compare_key_value_text_files(filename_a, filename_b, sep=":",
+ val_sep=",", precision=0.000001):
!Compare two key-value text files that may contain projection parameter
@@ -661,7 +662,8 @@
if missing_keys == len(dict_a):
return False
if missing_keys > 0:
- grass.warning(_("Several keys (%i out of %i) are missing in the target file")%(missing_keys, len(dict_a)))
+ warning(_("Several keys (%i out of %i) are missing "
+ "in the target file")%(missing_keys, len(dict_a)))
return True
# interface to g.gisenv
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-08-15 15:26:29 UTC (rev 52676)
@@ -628,6 +628,12 @@
dbif, connect = init_dbif(dbif)
obj_list = []
+ if self.get_map_time() == "point" or self.get_map_time() == "mixed":
+ core.error(_("The space time %(type)s dataset <%(name)s> must have"
+ " interval time"%\
+ {"type":self.get_new_map_instance(None).get_type(),
+ "name":self.get_id()}))
if gran is None:
gran = self.get_granularity()
@@ -646,7 +652,11 @@
if rows is not None:
if len(rows) > 1:
- core.warning(_("More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."))
+ core.warning(_("More than one map found in a granule. "
+ "Temporal granularity seems to be invalid or"
+ " the chosen granularity is not a greatest "
+ "common divider of all intervals and gaps "
+ "in the dataset."))
maplist = []
for row in rows:
@@ -656,7 +666,8 @@
if self.is_time_absolute():
map.set_absolute_time(start, next)
elif self.is_time_relative():
- map.set_relative_time(start, next, self.get_relative_time_unit())
+ map.set_relative_time(start, next,
+ self.get_relative_time_unit())
maplist.append(copy.copy(map))
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-08-15 15:26:29 UTC (rev 52676)
@@ -418,14 +418,14 @@
@param separator: The field separator character between the columns
@param method: String identifier to select a method out of cols,
comma,delta or deltagaps
- * "cols": Print preselected columns specified by columns
- * "comma": Print the map ids (name at mapset) as comma separated string
- * "delta": Print the map ids (name at mapset) with start time,
+ - "cols": Print preselected columns specified by columns
+ - "comma": Print the map ids (name at mapset) as comma separated string
+ - "delta": Print the map ids (name at mapset) with start time,
end time, relative length of intervals and the relative
distance to the begin
- * "deltagaps": Same as "delta" with additional listing of gaps.
+ - "deltagaps": Same as "delta" with additional listing of gaps.
Gaps can be simply identified as the id is "None"
- * "gran": List map using the granularity of the space time dataset,
+ - "gran": List map using the granularity of the space time dataset,
columns are identical to deltagaps
@param header: Set True to print column names
@@ -458,6 +458,8 @@
maps = sp.get_registered_maps_as_objects(where, "start_time", None)
elif method == "gran":
maps = sp.get_registered_maps_as_objects_by_granularity(None)
+ print "The maps object:", maps
if header:
string = ""
@@ -477,7 +479,8 @@
if len(maps[0]) > 0:
first_time, dummy = maps[0][0].get_valid_time()
else:
- core.fatal(_("Unable to list maps. Internal Error."))
+ core.warning(_("Empty map list."))
+ return
else:
first_time, dummy = maps[0].get_valid_time()
@@ -487,7 +490,7 @@
if len(mymap) > 0:
map = mymap[0]
else:
+ core.error(_("Empty entry in map list, continue to next entry"))
else:
map = mymap
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/lib/vector/vectorlib.dox 2012-08-15 15:26:29 UTC (rev 52676)
@@ -1,4 +1,4 @@
-/*! \page vectorlib GRASS Vector Library
+/*! \mainpage vectorlib GRASS Vector Library
by GRASS Development Team (http://grass.osgeo.org)
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/temporal/Makefile 2012-08-15 15:26:29 UTC (rev 52676)
@@ -28,7 +28,9 @@
t.rast3d.univar \
t.vect.list \
t.vect.db.select \
+ t.vect.export \
t.vect.extract \
+ t.vect.import \
t.vect.what.strds \
t.vect.observe.strds \
t.vect.univar
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-08-15 15:26:29 UTC (rev 52676)
@@ -73,9 +73,9 @@
t.remove type=strds input=precip_abs1
g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
rm -rf test
-#rm strds_export.tar.bz2
-#rm strds_export.tar.gz
-#rm strds_export_pack.tar
-#rm strds_export_pack.tar.gz
-#rm strds_export_pack.tar.bz2
+rm strds_export.tar.bz2
+rm strds_export.tar.gz
+rm strds_export_pack.tar
+rm strds_export_pack.tar.gz
+rm strds_export_pack.tar.bz2
Modified: grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
--- grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2012-08-15 15:26:29 UTC (rev 52676)
@@ -87,7 +87,6 @@
t.rast.list -h fs=" | " method=cols input=precip_abs1
t.rast.list -h fs=" | " method=delta input=precip_abs1
t.rast.list -h fs=" | " method=deltagaps input=precip_abs1
-t.rast.list -h fs=" | " method=gran input=precip_abs1
t.register type=rast -i input=precip_abs2 file="${n2}"
t.rast.list fs=" | " method=comma input=precip_abs2
@@ -115,7 +114,10 @@
t.rast.list -h fs=" | " method=cols input=precip_abs5
t.rast.list -h fs=" | " method=delta input=precip_abs5
t.rast.list -h fs=" | " method=deltagaps input=precip_abs5
+# @test of @failure, time instances and mixed time is not supported
t.rast.list -h fs=" | " method=gran input=precip_abs5
+t.rast.list -h fs=" | " method=gran input=precip_abs1
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=strds input=precip_abs0,precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-08-14 10:18:31 UTC (rev 52675)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-08-15 15:26:29 UTC (rev 52676)
@@ -124,7 +124,7 @@
if maps is not None:
for map in maps:
if use_granularity:
- if len(map[0]) > 0:
+ if len(map) > 0:
id = map[0].get_map_id()
else:
continue
