[GRASS-SVN] r52677 - grass-web/trunk/grass64/binary/mswindows/native
Wed Aug 15 16:14:26 PDT 2012
Author: hamish
Date: 2012-08-15 16:14:26 -0700 (Wed, 15 Aug 2012)
New Revision: 52677
   grass-web/trunk/grass64/binary/mswindows/native/README.html
bump version number
Modified: grass-web/trunk/grass64/binary/mswindows/native/README.html
--- grass-web/trunk/grass64/binary/mswindows/native/README.html	2012-08-15 15:26:29 UTC (rev 52676)
+++ grass-web/trunk/grass64/binary/mswindows/native/README.html	2012-08-15 23:14:26 UTC (rev 52677)
@@ -185,16 +185,17 @@
 <table><tr>
 <td width="32" align="left" valign="top"><img src="img/Install_GRASS.png"></td>
 <td align="left">To install GRASS, launch
- '<a href="WinGRASS-6.4.2-1-Setup.exe">WinGRASS-6.4.2-1-Setup.exe</a>'
+ '<a href="WinGRASS-6.4.2-2-Setup.exe">WinGRASS-6.4.2-2-Setup.exe</a>'
  and simply follow the step by step instructions.</td>
 </tr></table>
 <p>If installed into a directory that has spaces in either its name or the
-path of directories leading up to it, some functionalities of GRASS might
+path of directories leading up to it, there's a slight chance that some
+functionalities of GRASS might
 be hampered. We would highly appreciate if you tried and reported any problems,
 so that we can fix them. However, if you want to avoid any such issues,
 we recommend that you choose a simple installation path without spaces,
-such as <code>C:\GRASS</code>.
+such as <code>C:\GRASS64</code>.
 </p>
