[GRASS-SVN] r52755 - grass/branches/develbranch_6/vector/v.in.ogr
svn_grass at osgeo.org
Mon Aug 20 02:42:16 PDT 2012
Author: mmetz
Date: 2012-08-20 02:42:16 -0700 (Mon, 20 Aug 2012)
New Revision: 52755
grass/branches/develbranch_6/vector/v.in.ogr/main.c
v.in.ogr fix #1328
Modified: grass/branches/develbranch_6/vector/v.in.ogr/main.c
--- grass/branches/develbranch_6/vector/v.in.ogr/main.c 2012-08-20 09:41:30 UTC (rev 52754)
+++ grass/branches/develbranch_6/vector/v.in.ogr/main.c 2012-08-20 09:42:16 UTC (rev 52755)
@@ -638,6 +638,7 @@
/* Add DB link */
if (!notab_flag->answer) {
char *cat_col_name = "cat";
+ char *table_name;
if (nlayers == 1) { /* one layer only */
Fi = Vect_default_field_info(&Map, layer + 1, NULL,
@@ -651,8 +652,15 @@
if (ncnames > 0) {
cat_col_name = cnames_opt->answers[0];
- Vect_map_add_dblink(&Map, layer + 1, layer_names[layer], Fi->table,
+ /* replace all spaces with underscore, otherwise dbln can't be read */
+ table_name = G_store(layer_names[layer]);
+ G_strip(table_name);
+ G_strchg(table_name, ' ', '_');
+ Vect_map_add_dblink(&Map, layer + 1, table_name, Fi->table,
cat_col_name, Fi->database, Fi->driver);
+ G_free(table_name);
ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
G_debug(2, "%d columns", ncols);
