[GRASS-SVN] r52756 - grass/trunk/vector/v.out.pov
svn_grass at osgeo.org
Mon Aug 20 02:43:05 PDT 2012
Author: neteler
Date: 2012-08-20 02:43:04 -0700 (Mon, 20 Aug 2012)
New Revision: 52756
grass/trunk/vector/v.out.pov/main.c
be sure to have an empty string
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c 2012-08-20 09:42:16 UTC (rev 52755)
+++ grass/trunk/vector/v.out.pov/main.c 2012-08-20 09:43:04 UTC (rev 52756)
@@ -7,7 +7,7 @@
* * PURPOSE: Export vector to renderers' format (PovRay)
- * * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * * COPYRIGHT: (C) 2001-2012 by the GRASS Development Team
* * This program is free software under the
* * GNU General Public License (>=v2).
@@ -71,7 +71,6 @@
zmod_opt->key = "zmod";
zmod_opt->type = TYPE_STRING;
zmod_opt->required = NO;
- zmod_opt->answer = "";
zmod_opt->description = _("Modifier for z coordinates");
zmod_opt->description = _("This string is appended to each z coordinate. "
"Examples: '*10', '+1000', '*10+100', '*exaggeration'");
@@ -80,7 +79,6 @@
objmod_opt->key = "objmod";
objmod_opt->type = TYPE_STRING;
objmod_opt->required = NO;
- objmod_opt->answer = "";
objmod_opt->label = _("Object modifier (OBJECT_MODIFIER in POV-Ray documentation)");
objmod_opt->description = _("Example: \"pigment { color red 0 green 1 blue 0 }\"");
@@ -105,6 +103,11 @@
G_fatal_error(_("Unable to create output file <%s>"), out_opt->answer);
+ if (zmod_opt->answer == NULL)
+ zmod_opt->answer = G_store("");
+ if (objmod_opt->answer == NULL)
+ objmod_opt->answer = G_store("");
nlines = Vect_get_num_lines(&In);
nareas = Vect_get_num_areas(&In);
count = 0;
