[GRASS-SVN] r52763 - in grass/trunk/gui/wxpython: . gui_core location_wizard
svn_grass at osgeo.org
Mon Aug 20 04:47:53 PDT 2012
Author: annakrat
Date: 2012-08-20 04:47:53 -0700 (Mon, 20 Aug 2012)
New Revision: 52763
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_core/ghelp.py
grass/trunk/gui/wxpython/location_wizard/base.py
grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI/locationWizard: added help button to wizard, tooltips, HelpFrame base class changed to dialog (merged from releasebranch, r52759)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2012-08-20 11:46:57 UTC (rev 52762)
+++ grass/trunk/gui/wxpython/gis_set.py 2012-08-20 11:47:53 UTC (rev 52763)
@@ -794,7 +794,7 @@
# help text in lib/init/helptext.html
file = os.path.join(self.gisbase, "docs", "html", "helptext.html")
- helpFrame = HelpFrame(parent = self, id = wx.ID_ANY,
+ helpFrame = HelpFrame(parent = None, id = wx.ID_ANY,
title = _("GRASS Quickstart"),
size = (640, 480),
file = file)
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-08-20 11:46:57 UTC (rev 52762)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-08-20 11:47:53 UTC (rev 52763)
@@ -874,10 +874,16 @@
"""!Close window"""
self.Close()
-class HelpFrame(wx.Frame):
- """!GRASS Quickstart help window"""
+class HelpFrame(wx.Dialog):
+ """!GRASS Quickstart help window
+ As a base class wx.Dialog is used, because of not working
+ close button with wx.Frame when dialog is called from wizard.
+ If parent is None, application TopLevelWindow is used (wxPython standard behaviour).
def __init__(self, parent, id, title, size, file):
- wx.Frame.__init__(self, parent = parent, id = id, title = title, size = size)
+ wx.Dialog.__init__(self, parent = parent, id = id, title = title,
+ size = size, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER | wx.MINIMIZE_BOX)
sizer = wx.BoxSizer(wx.VERTICAL)
Modified: grass/trunk/gui/wxpython/location_wizard/base.py
--- grass/trunk/gui/wxpython/location_wizard/base.py 2012-08-20 11:46:57 UTC (rev 52762)
+++ grass/trunk/gui/wxpython/location_wizard/base.py 2012-08-20 11:47:53 UTC (rev 52763)
@@ -23,23 +23,32 @@
def __init__(self):
pass
- def MakeLabel(self, text = "", style = wx.ALIGN_LEFT, parent = None):
+ def MakeLabel(self, text = "", style = wx.ALIGN_LEFT, parent = None, tooltip = None):
"""!Make aligned label"""
if not parent:
parent = self
- return wx.StaticText(parent = parent, id = wx.ID_ANY, label = text,
- style = style)
+ label = wx.StaticText(parent = parent, id = wx.ID_ANY, label = text,
+ style = style)
+ if tooltip:
+ label.SetToolTipString(tooltip)
+ return label
- def MakeTextCtrl(self, text = '', size = (100,-1), style = 0, parent = None):
+ def MakeTextCtrl(self, text = '', size = (100,-1), style = 0, parent = None, tooltip = None):
"""!Generic text control"""
if not parent:
parent = self
- return wx.TextCtrl(parent = parent, id = wx.ID_ANY, value = text,
- size = size, style = style)
+ textCtrl = wx.TextCtrl(parent = parent, id = wx.ID_ANY, value = text,
+ size = size, style = style)
+ if tooltip:
+ textCtrl.SetToolTipString(tooltip)
+ return textCtrl
- def MakeButton(self, text, id = wx.ID_ANY, size = (-1,-1), parent = None):
+ def MakeButton(self, text, id = wx.ID_ANY, size = (-1,-1), parent = None, tooltip = None):
"""!Generic button"""
if not parent:
parent = self
- return wx.Button(parent = parent, id = id, label = text,
- size = size)
+ button = wx.Button(parent = parent, id = id, label = text,
+ size = size)
+ if tooltip:
+ button.SetToolTipString(tooltip)
+ return button
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-08-20 11:46:57 UTC (rev 52762)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-08-20 11:47:53 UTC (rev 52763)
@@ -19,6 +19,7 @@
- wizard::CustomPage
- wizard::SummaryPage
- wizard::LocationWizard
+ - wizard::WizardWithHelpButton
(C) 2007-2011 by the GRASS Development Team
@@ -40,6 +41,7 @@
from core import globalvar
from core import utils
from core.gcmd import RunCommand, GError, GMessage, GWarning
+from gui_core.ghelp import HelpFrame
from location_wizard.base import BaseClass
from location_wizard.dialogs import RegionDef, SelectTransformDialog
@@ -120,7 +122,8 @@
wx.ALL, border = 5,
pos = (1, 3))
- self.sizer.Add(item = self.MakeLabel("%s:" % _("Project Location")),
+ self.sizer.Add(item = self.MakeLabel("%s:" % _("Project Location"),
+ tooltip = _("Name of location directory in GIS Data Directory")),
flag = wx.ALIGN_RIGHT |
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border = 5,
@@ -131,7 +134,9 @@
wx.ALL, border = 5,
pos = (2, 2))
- self.sizer.Add(item = self.MakeLabel("%s:" % _("Location Title")),
+ self.sizer.Add(item = self.MakeLabel("%s:" % _("Location Title"),
+ tooltip = _("Optional location title, "
+ "you can leave this field blank.")),
wx.ALIGN_TOP | wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border = 5,
@@ -1757,8 +1762,10 @@
# define wizard pages
- self.wizard = wiz.Wizard(parent, id = wx.ID_ANY, title = _("Define new GRASS Location"),
- bitmap = wizbmp, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER)
+ self.wizard = WizardWithHelpButton(parent, id = wx.ID_ANY, title = _("Define new GRASS Location"),
+ bitmap = wizbmp)
+ self.wizard.Bind(wiz.EVT_WIZARD_HELP, self.OnHelp)
self.startpage = DatabasePage(self.wizard, self, grassdatabase)
self.csystemspage = CoordinateSystemPage(self.wizard, self)
self.projpage = ProjectionsPage(self.wizard, self)
@@ -2110,3 +2117,22 @@
proj4string = '%s +no_defs' % proj4string
return proj4string
+ def OnHelp(self, event):
+ """'Help' button clicked"""
+ # help text in lib/init/helptext.html
+ filePath = os.path.join(os.getenv('GISBASE'), "docs", "html", "helptext.html")
+ title = _("GRASS Quickstart"),
+ size = (640, 480),
+ file = filePath)
+ helpFrame.Show(True)
+class WizardWithHelpButton(wiz.Wizard):
+ def __init__(self, parent, id, title, bitmap):
+ pre = wiz.PreWizard()
+ pre.SetExtraStyle(wx.wizard.WIZARD_EX_HELPBUTTON)
+ pre.Create(parent = parent, id = id, title = title, bitmap = bitmap)
+ self.PostCreate(pre)
