[GRASS-SVN] r52764 - grass/branches/develbranch_6/vector/v.in.ogr
svn_grass at osgeo.org
Mon Aug 20 05:04:27 PDT 2012
Author: mmetz
Date: 2012-08-20 05:04:27 -0700 (Mon, 20 Aug 2012)
New Revision: 52764
grass/branches/develbranch_6/vector/v.in.ogr/main.c
v.in.ogr change misleading var name
Modified: grass/branches/develbranch_6/vector/v.in.ogr/main.c
--- grass/branches/develbranch_6/vector/v.in.ogr/main.c 2012-08-20 11:47:53 UTC (rev 52763)
+++ grass/branches/develbranch_6/vector/v.in.ogr/main.c 2012-08-20 12:04:27 UTC (rev 52764)
@@ -638,7 +638,7 @@
/* Add DB link */
if (!notab_flag->answer) {
char *cat_col_name = "cat";
- char *table_name;
+ char *lname;
if (nlayers == 1) { /* one layer only */
Fi = Vect_default_field_info(&Map, layer + 1, NULL,
@@ -654,13 +654,13 @@
/* replace all spaces with underscore, otherwise dbln can't be read */
- table_name = G_store(layer_names[layer]);
- G_strip(table_name);
- G_strchg(table_name, ' ', '_');
+ lname = G_store(layer_names[layer]);
+ G_strip(lname);
+ G_strchg(lname, ' ', '_');
- Vect_map_add_dblink(&Map, layer + 1, table_name, Fi->table,
+ Vect_map_add_dblink(&Map, layer + 1, lname, Fi->table,
cat_col_name, Fi->database, Fi->driver);
- G_free(table_name);
+ G_free(lname);
ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
G_debug(2, "%d columns", ncols);
