[GRASS-SVN] r52780 - grass/trunk/scripts/d.vect.thematic
Mon Aug 20 07:26:28 PDT 2012
Author: neteler
Date: 2012-08-20 07:26:27 -0700 (Mon, 20 Aug 2012)
New Revision: 52780
   grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
fix example
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html	2012-08-20 14:25:40 UTC (rev 52779)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html	2012-08-20 14:26:27 UTC (rev 52780)
@@ -60,7 +60,7 @@
 v.random random n=200
 v.db.addtable random col="el10 double precision"
 # transfer elevations to attribute table of random points map:
-v.what.rast random rast=elevation.10m col=elev
+v.what.rast random rast=elevation.10m col=el10
 v.db.select random
 # comparative sampling of second map, incl. differences:
@@ -78,7 +78,6 @@
 d.vect.thematic -l precip_30ynormals column=annual type=point
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
