[GRASS-SVN] r52781 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Mon Aug 20 08:26:10 PDT 2012
Author: turek
Date: 2012-08-20 08:26:09 -0700 (Mon, 20 Aug 2012)
New Revision: 52781
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
vnet: Added comments, bugs fixing
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-20 14:26:27 UTC (rev 52780)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-20 15:26:09 UTC (rev 52781)
@@ -53,12 +53,11 @@
from vnet.toolbars import MainToolbar, PointListToolbar, AnalysisToolbar
#Main TODOs
-# when layer tree is lmgr is changed, tmp layer is removed from render list
-# optimization of map drawing
-# static box placement??
-# tmp maps add number of process
-# destructor problem
-# statusbar
+# - when layer tree of is changed, tmp result map is removed from render list
+# - optimization of map drawing
+# - tmp maps - add number of process
+# - destructor problem - when GRASS GIS is closed with open VNETDialog,
+# it's destructor is not called
class VNETDialog(wx.Dialog):
def __init__(self, parent,
@@ -263,7 +262,7 @@
maxDistPanel = wx.Panel(parent = anSettingsPanel)
maxDistLabel = wx.StaticText(parent = maxDistPanel, id = wx.ID_ANY, label = _("Maximum distance of point to the network:"))
- self.anSettings["max_dist"] = wx.SpinCtrl(parent = maxDistPanel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
+ self.anSettings["max_dist"] = wx.SpinCtrl(parent = maxDistPanel, id = wx.ID_ANY, min = 0, max = maxValue)
self.anSettings["max_dist"].SetValue(100000) #TODO init val
#showCutPanel = wx.Panel(parent = anSettingsPanel)
@@ -273,7 +272,7 @@
isoLinesPanel = wx.Panel(parent = anSettingsPanel)
isoLineslabel = wx.StaticText(parent = isoLinesPanel, id = wx.ID_ANY, label = _("Iso lines:"))
- self.anSettings["iso_lines"] = wx.TextCtrl(parent = isoLinesPanel, id = wx.ID_ANY) #TODO
+ self.anSettings["iso_lines"] = wx.TextCtrl(parent = isoLinesPanel, id = wx.ID_ANY)
self.anSettings["iso_lines"].SetValue("1000,2000,3000")
# Layout
@@ -801,8 +800,8 @@
wxPen = "unused"
item.hide = False
elif len(cats) > 1:
- idxs = self.list.selIdxs[key] #TODO some public method
- if idxs[1] == 2: #End/To/Sink point
+ idx = self.list.GetCellSelIdx(key, 'type')
+ if idx == 2: #End/To/Sink point
wxPen = "used2cat"
else:
wxPen = "used1cat"
@@ -813,7 +812,7 @@
item.SetPropertyVal('penName', wxPen)
def OnMapClickHandler(self, event):
- """!Takes coordinates from map window."""
+ """!Takes coordinates from map window"""
if event == 'unregistered':
ptListToolbar = self.toolbars['pointsList']
if ptListToolbar:
@@ -857,10 +856,11 @@
self.list.Select(self.list.selected)
def _snapPoint(self, coords):
+ """!Finds nearest node to click coordiantes (within given threshold)"""
e = coords[0]
n = coords[1]
+ # compute threshold
snapTreshPix = int(UserSettings.Get(group ='vnet',
key = 'other',
subkey = 'snap_tresh'))
@@ -919,20 +919,26 @@
if self.tmp_result:
self.tmp_result.DeleteRenderLayer()
- self.tmpVectMapsToHist= []#TODO
+ # history - delete data in buffer for hist step
+ self.history.DeleteNewHistStepData()
+ # empty list for maps to be saved to history
+ self.tmpVectMapsToHist= []
+ # create new map (included to history) for result of analysis
self.tmp_result = self.NewTmpVectMapToHist('vnet_tmp_result')
if not self.tmp_result:
return
- elif not self.CheckAnMapState(self.tmp_result):
- return
self.stBar.AddStatusItem(text = _('Analysing...'),
key = 'analyze',
priority = self.stPriorities['important'])
+ # just in case there is some map with same name
+ # (when analysis does not produce any map, this wrong map would have been shown as result)
RunCommand('g.remove',
vect = self.tmp_result.GetVectMapName())
+ # save data from
self._saveAnInputToHist()
self.resultDbMgrData['analysis'] = self.currAnModule
@@ -1041,7 +1047,7 @@
maxCat = maxCat,
layerNum = layerNum)
- self.tmpPtsAsciiFile = grass.tempfile()#TODO better tmp files cleanup (when interrupt)
+ self.tmpPtsAsciiFile = grass.tempfile()#TODO better tmp files cleanup (make class for managing tmp files)
tmpPtsAsciiFileOpened = open(self.tmpPtsAsciiFile, 'w')
tmpPtsAsciiFileOpened.write(pt_ascii)
tmpPtsAsciiFileOpened.close()
@@ -1057,6 +1063,7 @@
cmdParams.append("input=" + self.tmpInPtsConnected.GetVectMapName())
cmdParams.append("--overwrite")
+ # append parameters needed for particular analysis
if self.currAnModule == "v.net.distance":
cmdParams.append("from_layer=1")
cmdParams.append("to_layer=1")
@@ -1064,8 +1071,6 @@
self.vnetFlowTmpCut = self.NewTmpVectMapToHist('vnet_tmp_flow_cut')
if not self.vnetFlowTmpCut:
return
- elif not self.CheckAnMapState(self.vnetFlowTmpCut):
- return
cmdParams.append("cut=" + self.vnetFlowTmpCut.GetVectMapName())
elif self.currAnModule == "v.net.iso":
costs = self.anSettings["iso_lines"].GetValue()
@@ -1076,6 +1081,7 @@
else:
cmdParams.append(catName + "=" + str(catNum[0]) + "-" + str(catNum[1]))
+ # create and run commands which goes to analysis thread
cmdVEdit = [
"v.edit",
"map=" + self.tmpInPts.GetVectMapName(),
@@ -1097,7 +1103,7 @@
"operation=connect",
"thresh=" + str(self.anSettings["max_dist"].GetValue()),
"--overwrite"
+ ] #TODO snapping to nodes optimization
self._prepareCmd(cmdVNet)
self.goutput.RunCmd(command = cmdVNet)
@@ -1106,7 +1112,7 @@
def _runAnDone(self, cmd, returncode):
"""!Called when analysis is done"""
- self.tmpMaps.DeleteTmpMap(self.tmpInPts) #TODO remove earlier (ondone lambda?)
+ self.tmpMaps.DeleteTmpMap(self.tmpInPts) #TODO remove earlier (OnDone lambda?)
self.tmpMaps.DeleteTmpMap(self.tmpInPtsConnected)
grass.try_remove(self.tmpPtsAsciiFile)
@@ -1128,6 +1134,11 @@
self.stBar.RemoveStatusItem(key = 'analyze')
def _getInputParams(self):
+ """!Returns list of chosen values (vector map, layers) from Parameters tab.
+ The list items are in form to be used in command for analysis e.g. 'alayer=1'.
inParams = []
for col in self.vnetParams[self.currAnModule]["cmdParams"]["cols"]:
@@ -1181,7 +1192,7 @@
return pt_ascii, catsNums
def _prepareCmd(self, cmd):
- """!Helper function for preparation of cmd in list into form for RunCmd method"""
+ """!Helper function for preparation of cmd list into form for RunCmd method"""
for c in cmd[:]:
if c.find("=") == -1:
continue
@@ -1191,27 +1202,6 @@
elif not v[1].strip():
cmd.remove(c)
- def CheckAnMapState(self, vectMap):
- vectMapState = vectMap.VectMapState()
- if vectMapState == 0:
- dlg = wx.MessageDialog(parent = self,
- message = _("Map %s was changed outside " +
- "of vector network analysis tool. " +
- "Do you want to continue in analysis and " +
- "overwrite it?") % (vectMap.GetVectMapName()),
- caption = _("Overwrite map"),
- style = wx.YES_NO | wx.NO_DEFAULT |
- wx.ICON_QUESTION | wx.CENTRE)
- ret = dlg.ShowModal()
- dlg.Destroy()
- if ret == wx.ID_NO:
- self.tmpMaps.RemoveFromTmpMaps(vectMap)
- return False
- return True
def GetLayerStyle(self):
"""!Returns cmd for d.vect, with set style for analysis result"""
resProps = self.vnetParams[self.currAnModule]["resultProps"]
@@ -1232,7 +1222,7 @@
layerStyleVnetColors = [
"v.colors",
"map=" + self.tmp_result.GetVectMapName(),
- "color=" + colorStyle,#TODO
+ "color=" + colorStyle,
"column=" + resProps["attrColColor"],
if invert:
@@ -1246,7 +1236,7 @@
return layerStyleCmd
def OnShowResult(self, event):
- """!Shows, hides analysis result"""
+ """!Show/hide analysis result"""
mainToolbar = self.toolbars['mainToolbar']
id = vars(mainToolbar)['showResult']
toggleState = mainToolbar.GetToolState(id)
@@ -1255,7 +1245,7 @@
mainToolbar.ToggleTool(id =id,
toggle = False)
elif toggleState:
- self.CheckAnMapState(self.tmp_result)
+ self._checkResultMapChanged(self.tmp_result)
cmd = self.GetLayerStyle()
self.tmp_result.AddRenderLayer(cmd)
else:
@@ -1300,7 +1290,12 @@
return
addedMap = dlg.vectSel.GetValue()
- existsMap = grass.find_file(name = addedMap,
+ mapName, mapSet = self._parseMapStr(addedMap)
+ if mapSet != grass.gisenv()['MAPSET']:
+ GMessage(parent = self,
+ message = _("Map can be saved only to currently set mapset"))
+ return
+ existsMap = grass.find_file(name = mapName,
element = 'vector',
mapset = grass.gisenv()['MAPSET'])
dlg.Destroy()
@@ -1316,27 +1311,27 @@
if ret == wx.ID_NO:
dlg.Destroy()
return
+ dlg.Destroy()
RunCommand("g.copy",
overwrite = True,
- vect = [self.tmp_result.GetVectMapName(), addedMap])
+ vect = [self.tmp_result.GetVectMapName(), mapName])
cmd = self.GetLayerStyle()#TODO get rid of insert
cmd.insert(0, 'd.vect')
- cmd.append('map=%s' % addedMap)
+ cmd.append('map=%s' % mapName)
if not self.mapWin.tree:
- dlg.Destroy()
return
- if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None:
+ if self.mapWin.tree.FindItemByData(key = 'name', value = mapName) is None:
self.mapWin.tree.AddLayer(ltype = "vector",
- lname = addedMap,
+ lname = mapName,
lcmd = cmd,
lchecked = True)
+ else:
+ self.mapWin.UpdateMap(render=True, renderVector=True)
- #self.mapWin.UpdateMap(render=True, renderVector=True)
def OnSettings(self, event):
"""!Displays vnet settings dialog"""
dlg = SettingsDialog(parent=self, id=wx.ID_ANY, title=_('Settings'))
@@ -1348,30 +1343,22 @@
def OnAnalysisChanged(self, event):
"""!Updates dialog when analysis is changed"""
- # finds module name according to value in anChoice
- for module, params in self.vnetParams.iteritems():
- chLabel = self.toolbars['analysisToolbar'].anChoice.GetValue()
- if params["label"] == chLabel:
- self.currAnModule = module
- break
+ # set chosen analysis
+ iAn = self.toolbars['analysisToolbar'].anChoice.GetSelection()
+ self.currAnModule = self.vnetModulesOrder[iAn]
- if self.currAnModule == "v.net.path":
- self.list.UpdateCheckedItems(index = None)
- # self.anSettings['line_id'].GetParent().Show()
- #else:
- # self.anSettings['line_id'].GetParent().Hide()
+ # update dialog for particular analysis
self.anSettings['iso_lines'].GetParent().Show()
else:
self.anSettings['iso_lines'].GetParent().Hide()
- #if self.currAnModule == "v.net.flow":
+ #if self.currAnModule == "v.net.flow": TODO not implemented
# self.anSettings['show_cut'].GetParent().Show()
#else:
# self.anSettings['show_cut'].GetParent().Hide()
- # Show only corresponding selects for chosen v.net module
+ # show only corresponding selects for chosen v.net module
skip = []
for col in self.attrCols.iterkeys():
if "inputField" in self.attrCols[col]:
@@ -1393,7 +1380,7 @@
self.inputData[colInptF].GetParent().Hide()
self.Layout()
- # If module has only one category -> hide type column in points list otherwise show it
+ # if module has only one category -> hide type column in points list otherwise show it
if len(self.vnetParams[self.currAnModule]["cmdParams"]["cats"]) > 1:
if not self.list.IsShown('type'):
self.list.ShowColumn('type', 1)
@@ -1404,9 +1391,15 @@
if self.list.IsShown('type'):
self.list.HideColumn('type')
+ # for v.net.path just one start point and one end point can be checked
+ if self.currAnModule == "v.net.path":
+ self.list.UpdateCheckedItems(index = None)
def OnSnapping(self, event):
+ """!Start/stop snapping mode"""
if not haveCtypes:
ptListToolbar.ToggleTool(id = ptListToolbar.GetToolId("snapping"),
toggle = False)
@@ -1422,8 +1415,10 @@
if self.tmpMaps.HasTmpVectMap("vnet_snap_points"):
self.snapPts.DeleteRenderLayer()
self.mapWin.UpdateMap(render = False, renderVector = False)
if self.snapData.has_key('cmdThread'):
self.snapData['cmdThread'].abort()
self.snapData['snap_mode'] = False
return
@@ -1437,10 +1432,11 @@
if not self.tmpMaps.HasTmpVectMap("vnet_snap_points"):
endStr = _("Do you really want to activate snapping and overwrite it?")
self.snapPts = self.tmpMaps.AddTmpVectMap("vnet_snap_points", endStr)
if not self.snapPts:
toggle = False)
- return
+ return
elif self.snapPts.VectMapState() == 0:
dlg = wx.MessageDialog(parent = self.parent,
message = _("Temporary map '%s' was changed outside " +
@@ -1476,6 +1472,7 @@
if self.snapData["inputMap"].VectMapState() == 1:
computeNodes = False
+ # new map need
if computeNodes:
self.stBar.AddStatusItem(text = _('Computing nodes...'),
key = 'snap',
@@ -1495,12 +1492,14 @@
self.snapData['cmdThread'].RunCmd(cmd)
self.snapData["inputMapNlayer"] = self.inputData["nlayer"].GetValue()
+ # map is already created and up to date for input data
else:
self.snapPts.AddRenderLayer()
self.mapWin.UpdateMap(render = True, renderVector = True)
def _onToPointsDone(self, event):
+ """!Update map window, when map with nodes to snap is created"""
self.stBar.RemoveStatusItem(key = 'snap')
if not event.aborted:
self.snapPts.SaveVectMapState()
@@ -1508,6 +1507,7 @@
def OnUndo(self, event):
+ """!Step back in history"""
histStepData = self.history.GetPrev()
self.toolbars['mainToolbar'].UpdateUndoRedo()
@@ -1515,6 +1515,7 @@
self._updateHistStepData(histStepData)
def OnRedo(self, event):
+ """!Step forward in history"""
histStepData = self.history.GetNext()
@@ -1522,7 +1523,7 @@
def _saveAnInputToHist(self):
+ """!Save all data needed for analysis into history buffer"""
pts = self.pointsToDraw.GetAllItems()
for iPt, pt in enumerate(pts):
@@ -1532,18 +1533,20 @@
self.history.Add(key = "points",
subkey = [ptName, "coords"],
value = coords)
+ # save type column
+ # if is shown
- cat = self.list.GetCellText(iPt, 'type')
+ cat = self.list.GetCellSelIdx(iPt, 'type')
subkey = [ptName, "catIdx"],
value = cat)
+ # if is hidden
else:
self.history.Add(key = 'points_hidden_cols',
subkey = 'type',
value = self.list.GetHiddenColSelIdxs('type'))
- topology = self.list.GetCellText(iPt, 'topology')
+ topology = self.list.GetCellValue(iPt, 'topology')
subkey = [ptName, "topology"],
value = topology)
@@ -1554,16 +1557,21 @@
value = self.list.IsChecked(iPt))
for inpName, inp in self.inputData.iteritems():
if inpName == "input":
vectMapName, mapSet = self._parseMapStr(inp.GetValue())
- vectorMap = vectMapName + '@' + mapSet
- inpMap = VectMap(self, vectorMap)
+ inpMapFullName = vectMapName + '@' + mapSet
+ inpMap = VectMap(self, inpMapFullName)
self.history.Add(key = "other",
subkey = "input_modified",
- value = inpMap.GetLastModified())
+ value = inpMap.GetLastModified())
+ inpVal = inpMapFullName
+ else:
+ inpVal = inp.GetValue()
self.history.Add(key = "input_data",
subkey = inpName,
- value = inp.GetValue())
+ value = inpVal)
self.history.Add(key = "vnet_modules",
subkey = "curr_module",
@@ -1576,13 +1584,14 @@
def _saveHistStep(self):
+ """!Save buffer created with (_saveAnInputToHist) into history"""
removedHistData = self.history.SaveHistStep()
if not removedHistData:
return
+ # delete temporary maps saved in history steps which were deleted
for removedStep in removedHistData.itervalues():
mapsNames = removedStep["tmp_data"]["maps"]
for vectMapName in mapsNames:
@@ -1590,14 +1599,19 @@
self.tmpMaps.DeleteTmpMap(tmpMap)
def _updateHistStepData(self, histStepData):
+ """!Updates dialog according to chosen history step"""
+ # set analysis module
self.currAnModule = histStepData["vnet_modules"]["curr_module"]
- anChoice = self.toolbars['analysisToolbar'].anChoice
+ # optimization -map is not re-rendered when change in points list is done
self.list.SetUpdateMap(updateMap = False)
+ # delete points list items
while self.list.GetSelected() != wx.NOT_FOUND:
self.list.DeleteItem()
+ # show/hide 'type' column according to particular analysis
hasType = True
@@ -1605,8 +1619,8 @@
hasType = False
+ # add points to list
for iPt in range(len(histStepData["points"])):
ptData = histStepData["points"]["pt" + str(iPt)]
coords = ptData["coords"]
self.list.AddItem()
@@ -1627,8 +1641,11 @@
else:
self.list.SetHiddenSelIdxs('type', histStepData["points_hidden_cols"]["type"])
- anChoice.SetStringSelection(self.vnetParams[self.currAnModule]["label"])
+ # set analysis combobox
+ anChoice = self.toolbars['analysisToolbar'].anChoice
+ anChoice.SetSelection(self.vnetModulesOrder.index(self.currAnModule))
+ # update analysis result maps
mapsNames = histStepData["tmp_data"]["maps"]
if "vnet_tmp_result" in vectMapName:
@@ -1639,24 +1656,16 @@
+ # update Parameters tab
histInputData = histStepData["input_data"]
for inpName, inp in histInputData.iteritems():
self.inputData[inpName].SetValue(str(inp))
inpMap = inp
- histAnSettData = histStepData["an_settings"]
- for settName, sett in histAnSettData.iteritems():
- if settName == 'iso_lines':
- sett = str(sett)
- self.anSettings[settName].SetValue(sett)
prevInpModTime = str(histStepData["other"]["input_modified"])
+ currInpModTime = VectMap(self, inpMap).GetLastModified()
- inpMapFullName = inpMap + "@" + grass.gisenv()['MAPSET'] #TODO mapset changed?
- currInpModTime = VectMap(self, inpMapFullName).GetLastModified()
if currInpModTime.strip()!= prevInpModTime.strip():
message = _("Input map '%s' for analysis was changed outside " +
@@ -1669,14 +1678,23 @@
dlg.ShowModal()
dlg.Destroy()
+ # update Points tab (analysis settings)
+ histAnSettData = histStepData["an_settings"]
+ for settName, sett in histAnSettData.iteritems():
+ if settName == 'iso_lines':
+ sett = str(sett)
+ self.anSettings[settName].SetValue(sett)
self._updateResultDbMgrPage()
self._updateDbMgrData()
+ self.OnAnalysisChanged(None)
self.list.SetUpdateMap(updateMap = True)
def _checkResultMapChanged(self, resultVectMap):
+ """!Check if map was modified outside"""
if resultVectMap.VectMapState() == 0:
message = _("Temporary map '%s' with result " +
@@ -1690,6 +1708,7 @@
dlg.Destroy()
def NewTmpVectMapToHist(self, prefMapName):
+ """!Adds new vector map to be saved into history step"""
mapName = prefMapName + str(self.histTmpVectMapNum)
self.histTmpVectMapNum += 1
@@ -1706,7 +1725,7 @@
return tmpMap
def _addTmpMapAnalysisMsg(self, mapName):
+ """!Wraped AddTmpVectMap method + message text, if map to be created during analysis exists"""
msg = _("Temporary map %s already exists.\n" +
"Do you want to continue in analysis and overwrite it?") \
% (mapName +'@' + grass.gisenv()['MAPSET'])
@@ -1753,7 +1772,7 @@
"resultProps" : {
"singleColor" : None,
- "dbMgr" : True
+ "dbMgr" : True
@@ -1814,7 +1833,7 @@
"resultProps" : {
- "dbMgr" : False #TODO
+ "dbMgr" : False
"v.net.distance" : {
@@ -1851,7 +1870,7 @@
+ # order in combobox for choosing analysis
self.vnetModulesOrder = ["v.net.path",
"v.net.salesman",
"v.net.flow",
@@ -1859,14 +1878,11 @@
"v.net.distance",
"v.net.iso",
#"v.net.steiner"
- ] # order in the choice of analysis
self.currAnModule = self.vnetModulesOrder[0]
def _initSettings(self):
"""!Initialization of settings (if not already defined)"""
- #if 'vnet' in UserSettings.userSettings:
- # return
# initializes default settings
initSettings = [
['res_style', 'line_width', 5],
@@ -1915,17 +1931,14 @@
class PtsList(PointsList):
def __init__(self, parent, dialog, cols, id=wx.ID_ANY):
- """! List with points for analysis
+ """! List with points for analysis"""
self.updateMap = True
self.dialog = dialog # VNETDialog class
PointsList.__init__(self, parent = parent, cols = cols, id = id)
def AddItem(self, event = None, updateMap = True):
- Appends point to list
+ """!Appends point to list"""
self.dialog.pointsToDraw.AddItem(coords = [0,0])
PointsList.AddItem(self, event)
@@ -1935,9 +1948,7 @@
cellData = _("new point"))
def DeleteItem(self, event = None):
- Deletes selected point in list
+ """!Deletes selected point in list"""
key = self.GetItemData(self.selected)
if self.selected != wx.NOT_FOUND:
item = self.dialog.pointsToDraw.GetItem(key)
@@ -1946,10 +1957,7 @@
PointsList.DeleteItem(self, event)
def OnItemSelected(self, event):
- Item selected
+ """!Item selected"""
PointsList.OnItemSelected(self, event)
if self.updateMap:
@@ -1958,18 +1966,20 @@
def AdaptPointsList(self, currParamsCats):
"""Rename category values when module is changed. Expample: Start point -> Sink point"""
colValues = [""]
for ptCat in currParamsCats:
colValues.append(ptCat[1])
colNum = self._getColumnNum('type')
self.ChangeColEditable('type', colValues)
for iItem, item in enumerate(self.itemDataMap):
self.EditCellKey(iItem, 'type', self.selIdxs[iItem][colNum])
if not item[1]:
self.CheckItem(iItem, False)
def OnCheckItem(self, index, flag):
"""!Item is checked/unchecked"""
key = self.GetItemData(index)
checkedVal = self.itemDataMap[key][1]
@@ -1992,32 +2002,35 @@
def UpdateCheckedItems(self, index):
"""!For v.net.path - max. just one checked start point and end point """
alreadyChecked = []
+ colNum = self._getColumnNum('type')
+ if colNum == -1:
+ return
if index:
checkedKey = self.GetItemData(index)
- checkedVal = self.itemDataMap[checkedKey][1]
+ checkedVal = self.selIdxs[checkedKey][colNum]
alreadyChecked.append(checkedVal)
else:
checkedKey = -1
+ for iKey, idx in enumerate(self.selIdxs):
+ index = self._findIndex(iKey)
+ if (idx[colNum] in alreadyChecked and checkedKey != iKey) \
+ or idx[colNum] == 0:
+ self.CheckItem(index, False)
+ elif self.IsChecked(index):
+ alreadyChecked.append(idx[colNum])
- for iItem, item in enumerate(self.itemDataMap):
- itemKey = self.GetItemData(iItem)
- if (item[1] in alreadyChecked and checkedKey != iItem) \
- or not item[1]:
- self.CheckItem(itemKey, False)
- elif self.IsChecked(itemKey):
- alreadyChecked.append(item[1])
def SetUpdateMap(self, updateMap):
+ """!Update/Not update map window when some change in list is made"""
self.updateMap = updateMap
def GetHiddenColSelIdxs(self, colName):
+ """!Get indexes of chosen values in hidden 'type' column"""
if self.hiddenCols.has_key(colName):
return self.hiddenCols[colName]['selIdxs']
return None
def SetHiddenSelIdxs(self, colName, selIdxs):
+ """!Set indexes of chosen values in hidden 'type' column"""
self.hiddenCols[colName]['selIdxs'] = map(int, selIdxs)
self.hiddenCols[colName]['itemDataMap'] = []
@@ -2029,7 +2042,7 @@
class SettingsDialog(wx.Dialog):
def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_DIALOG_STYLE):
- """!Settings for v.net analysis dialog"""
+ """!Settings dialog"""
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
maxValue = 1e8
@@ -2106,12 +2119,13 @@
#Layout
+ # Analysis result style layout
self.SetMinSize(self.GetBestSize())
sizer = wx.BoxSizer(wx.VERTICAL)
styleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label =" %s " % _("Analysis outcome line style:"))
+ label =" %s " % _("Analysis result style:"))
styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
@@ -2139,6 +2153,7 @@
styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ # Point style layout
ptsStyleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label =" %s " % _("Point style:"))
ptsStyleBoxSizer = wx.StaticBoxSizer(ptsStyleBox, wx.VERTICAL)
@@ -2160,6 +2175,7 @@
ptsStyleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ # Other settings layout
otherBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label =" %s " % _("Other settings"))
otherBoxSizer = wx.StaticBoxSizer(otherBox, wx.VERTICAL)
@@ -2167,16 +2183,14 @@
gridSizer.AddGrowableCol(1)
- row = 0 #TODO for?
- gridSizer.Add(item = settsLabels["snap_tresh"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- gridSizer.Add(item = self.settings["snap_tresh"],
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
- pos = (row, 1))
- row += 1
- gridSizer.Add(item = settsLabels["max_hist_steps"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- gridSizer.Add(item = self.settings["max_hist_steps"],
- pos = (row, 1))
+ row = 0
+ for otherSettName in ["snap_tresh", "max_hist_steps"]:
+ gridSizer.Add(item = settsLabels[otherSettName], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+ gridSizer.Add(item = self.settings[otherSettName],
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
+ pos = (row, 1))
+ row += 1
otherBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -2298,22 +2312,27 @@
sizer.Fit(self)
class VnetTmpVectMaps:
+ """!Class which creates, stores and destroys all tmp maps created during analysis"""
def __init__(self, parent):
- """!Class which creates, stores and destroys all tmp maps created during analysis"""
- self.tmpMaps = []
+ self.tmpMaps = [] # temporary maps
self.parent = parent
self.mapWin = self.parent.mapWin
def AddTmpVectMap(self, mapName, msg):
+ """!New temporary map
+ @return instance of VectMap representing temporary map
currMapSet = grass.gisenv()['MAPSET']
tmpMap = grass.find_file(name = mapName,
element = 'vector',
mapset = currMapSet)
fullName = tmpMap["fullname"]
+ # map already exists
if fullName:
- dlg = wx.MessageDialog(parent = self.parent,
+ #TODO move dialog out of class, AddTmpVectMap(self, mapName, overvrite = False)
+ dlg = wx.MessageDialog(parent = self.parent,
message = msg,
caption = _("Overwrite map layer"),
@@ -2332,9 +2351,15 @@
return newVectMap
- def HasTmpVectMap(self, vectMap):
+ def HasTmpVectMap(self, vectMapName):
+ @param name of vector map
- mapValSpl = vectMap.strip().split("@")
+ @return True if it has
+ @return False if not
+ mapValSpl = vectMapName.strip().split("@")
if len(mapValSpl) > 1:
mapSet = mapValSpl[1]
else:
@@ -2348,14 +2373,20 @@
return False
def GetTmpVectMap(self, vectMapName):
+ """ Get instance of VectMap with name vectMapName"""
for vectMap in self.tmpMaps:
if vectMap.GetVectMapName() == vectMapName.strip():
return vectMap
return None
def RemoveFromTmpMaps(self, vectMap):
+ """!Temporary map is removed from the class instance however it is not deleted
+ @param vectMap instance of VectMap class to be removed
+ @return True if was removed
+ @return False if the class instance does not contain it
try:
self.tmpMaps.remove(vectMap)
return True
@@ -2363,6 +2394,13 @@
return False
def DeleteTmpMap(self, vectMap):
+ """!Temporary map is removed from the class and it is deleted
+ @param vectMap instance of VectMap class to be deleted
if vectMap:
vectMap.DeleteRenderLayer()
@@ -2372,7 +2410,7 @@
return False
def DeleteAllTmpMaps(self):
+ """Delete all temporary maps in the class"""
update = False
for tmpMap in self.tmpMaps:
@@ -2382,19 +2420,21 @@
return update
class VectMap:
+ """!Represents map
+ It can checks if it was modified or render it
def __init__(self, parent, fullName):
- """!Represents one temporary map"""
self.fullName = fullName
self.renderLayer = None
- self.modifTime = None
+ self.modifTime = None # time, for modification check
def __del__(self):
self.DeleteRenderLayer()
def AddRenderLayer(self, cmd = None):
+ """!Add map from map window layers to render """
existsMap = grass.find_file(name = self.fullName,
element = 'vector',
@@ -2418,6 +2458,7 @@
return True
def DeleteRenderLayer(self):
+ """!Remove map from map window layers to render"""
if self.renderLayer:
self.parent.mapWin.Map.DeleteLayer(self.renderLayer)
@@ -2431,19 +2472,28 @@
return self.fullName
def SaveVectMapState(self):
+ """!Save modification time for vector map"""
self.modifTime = self.GetLastModified()
def VectMapState(self):
+ """!Checks if map was modified
- if self.modifTime is None:#TODO
+ @return -1 - if no modification time was saved
+ @return - 0 if map was modified
+ @return -1 if map was not modified
+ if self.modifTime is None:
return -1
if self.modifTime != self.GetLastModified():
return 0
return 1
def GetLastModified(self):
+ """!Get modification time
+ @return MAP DATE time string from vector map head file
mapValSpl = self.fullName.split("@")
mapName = mapValSpl[0]
@@ -2468,15 +2518,22 @@
return ""
class History:
+ """!Class which reads and saves history data (based on gui.core.settings Settings class file save/load)"""
- self.maxHistSteps = 3
+ # max number of steps in history (zero based)
+ self.maxHistSteps = 3
+ # current history step
self.currHistStep = 0
+ # number of steps saved in history
self.histStepsNum = 0
- self.currHistStepData = {}
+ # dict contains data saved in history for current history step
+ self.currHistStepData = {}
- self.newHistStepData = {}
+ # buffer for data to be saved into history
+ self.newHistStepData = {}
self.histFile = grass.tempfile()
# key/value separator
@@ -2486,7 +2543,7 @@
grass.try_remove(self.histFile)
def GetNext(self):
+ """!Go one step forward in history"""
self.currHistStep -= 1
self.currHistStepData.clear()
self.currHistStepData = self._getHistStepData(self.currHistStep)
@@ -2494,7 +2551,7 @@
return self.currHistStepData
def GetPrev(self):
+ """!Go one step back in history"""
self.currHistStep += 1
@@ -2502,13 +2559,15 @@
def GetStepsNum(self):
+ """!Get number of steps saved in history"""
return self.histStepsNum
def GetCurrHistStep(self):
+ """!Get current history step"""
- def Add(self, key, subkey, value):#TODO
+ def Add(self, key, subkey, value):
+ """!Add new data into buffer"""
if key not in self.newHistStepData:
self.newHistStepData[key] = {}
@@ -2520,11 +2579,11 @@
self.newHistStepData[key][subkey] = value
def SaveHistStep(self):
+ """!Create new history step with data in buffer"""
self.maxHistSteps = UserSettings.Get(group ='vnet',
key = 'other',
subkey = 'max_hist_steps')
- self.currHistStep = 0 #TODO
+ self.currHistStep = 0
newHistFile = grass.tempfile()
newHist = open(newHistFile, "w")
@@ -2544,7 +2603,7 @@
return removedHistData
def _savePreviousHist(self, newHist, oldHist):
+ """!Save previus history into new file"""
newHistStep = False
removedHistData = {}
newHistStepsNum = self.histStepsNum
@@ -2577,7 +2636,7 @@
def _saveNewHistStep(self, newHist):
+ """!Save buffer (new step) data into file"""
newHist.write('%s%s%s' % (os.linesep, "history step=0", os.linesep))
for key in self.newHistStepData.keys():
subkeys = self.newHistStepData[key].keys()
@@ -2608,7 +2667,7 @@
def _parseValue(self, value, read = False):
+ """!Parse value"""
if read: # -> read data (cast values)
if value:
@@ -2645,6 +2704,7 @@
return value
def _castValue(self, value):
+ """!Cast value"""
try:
value = int(value)
except ValueError:
@@ -2656,7 +2716,7 @@
return value
def _getHistStepData(self, histStep):
+ """!Load data saved in history step"""
hist = open(self.histFile)
histStepData = {}
@@ -2682,36 +2742,40 @@
return histStepData
def _parseLine(self, line, histStepData):
+ """!Parse line in file with history"""
+ line = line.rstrip('%s' % os.linesep).split(self.sep)
+ key = line[0]
+ kv = line[1:]
+ idx = 0
+ subkeyMaster = None
+ if len(kv) % 2 != 0: # multiple (e.g. nviz)
+ subkeyMaster = kv[0]
+ del kv[0]
+ idx = 0
+ while idx < len(kv):
+ if subkeyMaster:
+ subkey = [subkeyMaster, kv[idx]]
+ else:
+ subkey = kv[idx]
+ value = kv[idx+1]
+ value = self._parseValue(value, read = True)
+ if key not in histStepData:
+ histStepData[key] = {}
- line = line.rstrip('%s' % os.linesep).split(self.sep)
- key = line[0]
- kv = line[1:]
- idx = 0
- subkeyMaster = None
- if len(kv) % 2 != 0: # multiple (e.g. nviz)
- subkeyMaster = kv[0]
- del kv[0]
- idx = 0
- while idx < len(kv):
- if subkeyMaster:
- subkey = [subkeyMaster, kv[idx]]
- else:
- subkey = kv[idx]
- value = kv[idx+1]
- value = self._parseValue(value, read = True)
- if key not in histStepData:
- histStepData[key] = {}
+ if type(subkey) == types.ListType:
+ if subkey[0] not in histStepData[key]:
+ histStepData[key][subkey[0]] = {}
+ histStepData[key][subkey[0]][subkey[1]] = value
+ else:
+ histStepData[key][subkey] = value
+ idx += 2
- if type(subkey) == types.ListType:
- if subkey[0] not in histStepData[key]:
- histStepData[key][subkey[0]] = {}
- histStepData[key][subkey[0]][subkey[1]] = value
- else:
- histStepData[key][subkey] = value
- idx += 2
+ def DeleteNewHistStepData(self):
+ """!Delete buffer data for new history step"""
+ self.newHistStepData.clear()
class VnetStatusbar(wx.StatusBar):
+ """!Extends wx.StatusBar class with functionality to show multiple messages with the highest priority"""
def __init__(self, parent, style, id = wx.ID_ANY, **kwargs):
wx.StatusBar.__init__(self, parent, id, style, **kwargs)
@@ -2720,7 +2784,13 @@
self.statusItems = []
def AddStatusItem(self, text, key, priority):
+ """!Add new item to show
+ @param text - string to show
+ @param key - item identifier, if already contains
+ item with same identifier, overwrites this item
+ @param priority - only items with highest priority are showed
statusTextItem = {
'text' : text,
'key' : key,
@@ -2746,7 +2816,10 @@
wx.StatusBar.SetStatusText(self, currStatusText)
def RemoveStatusItem(self, key):
+ """!Removes item
update = False
for iItem, item in enumerate(self.statusItems):
if item['key'] == key:
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-08-20 14:26:27 UTC (rev 52780)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-08-20 15:26:09 UTC (rev 52781)
@@ -123,6 +123,10 @@
def UpdateUndoRedo(self):
+ id = vars(self)['showResult']
+ self.ToggleTool(id =id,
+ toggle = True)
if self.parent.history.GetCurrHistStep() >= self.parent.history.GetStepsNum():
self.Enable("undo", False)
else:
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-20 14:26:27 UTC (rev 52780)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-20 15:26:09 UTC (rev 52781)
@@ -39,7 +39,7 @@
wx.LC_SINGLE_SEL):
"""!Creates list for points.
- PointsList class was extracted from GCPList class in GCP manager. It is possible
+ PointsList class was created from GCPList class in GCP manager. It is possible
to be shared by GCP and VNET front end.
Important parameters:
@@ -52,7 +52,7 @@
-3. item: If column is editable by user, it must contain convert function to convert
inserted string to it's type for sorting. Use None for not editable
columns. Values for insertion can be in list. This allows insert
- just values in the list during user edits.
+ just values in the list.
-4. item: Default value for column cell. Value should be given in it's type
in order to sorting would work properly. If 3. item is list, it must be index
of some item in the list.
@@ -70,11 +70,7 @@
['type', _('type'), [_(""), _("Start point"), _("End point")], 0] # Select from 3 choices ("Start point", "End point"),
# Choice with index 0 ("") is default.
- @endcode
- List self.itemDataMap stores data for sorting comparison, it can be used
- for getting present data in list. It should not be modified.
+ @endcode
wx.ListCtrl.__init__(self, parent, id, pos, size, style)
@@ -131,8 +127,7 @@
self.SetColumnWidth(0, 50)
def _createCols(self):
- """!Creates columns in list
+ """!Creates columns in list"""
if 0:
# normal, simple columns
for col in enumerate(self.colsData):
@@ -151,8 +146,7 @@
self.InsertColumnInfo(col[0], info)
def AddItem(self, event):
- """!Appends an item to list with default values
+ """!Appends an item to list with default values"""
iDefVal = self.dataTypes["itemDefaultValue"]
iColEd = self.dataTypes["colEditable"]
itemData = []
@@ -168,10 +162,10 @@
self.selIdxs.append(itemIndexes)
- for hCol in self.hiddenCols.itervalues():
+ for hCol in self.hiddenCols.itervalues():
defVal = hCol['colsData'][iDefVal]
- if type(col[iColEd]).__name__ == "list":
- hCol['itemDataMap'].append(hCol[iColEd][defVal])
+ if type(hCol['colsData'][iColEd]).__name__ == "list":
+ hCol['itemDataMap'].append(hCol['colsData'][iColEd][defVal])
hCol['selIdxs'].append(defVal)
else:
hCol['itemDataMap'].append(defVal)
@@ -194,19 +188,24 @@
return self.selected
- def GetCellText(self, key, colName):
- """!Get value in cell of list using key (same regardless of sorting)
+ def GetCellValue(self, key, colName):
+ """!Get value in cell of list using key (same regardless of sorting)"""
+ colNum = self._getColumnNum(colName)
+ iColEd = self.dataTypes["colEditable"]
+ return self.itemDataMap[key][colNum]
+ def GetCellSelIdx(self, key, colName):
+ """!Get selected index in cell of list using key (same regardless of sorting)
+ @return number of chosen value, if column has values to choose
+ @return -1 if column does not has values to choose
- if type(self.colsData[colNum][iColEd]).__name__ == "list":
- return self.selIdxs[key][colNum]
- else:
- return self.itemDataMap[key][colNum]
+ return self.selIdxs[key][colNum]
def EditCellIndex(self, index, colName, cellData):
- """!Changes value in list using key (same regardless of sorting)
+ """!Changes value in list using key (same regardless of sorting)"""
@@ -222,10 +221,8 @@
self.SetStringItem(index, colNum, str(cellVal))
def EditCellKey(self, key, colName, cellData):
- """!Changes value in list using index (changes during sorting)
- colNum = self._getColumnNum(colName)
- index = self.FindItemData(-1, key)
+ """!Changes value in list using index (changes during sorting)"""
@@ -236,11 +233,24 @@
self.selIdxs[key][colNum] = -1
self.itemDataMap[key][colNum] = cellVal
+ index = self._findIndex(key)
+ def _findIndex(self, key):
+ """!Find index for key"""
+ index = -1
+ while True:
+ index = self.GetNextItem(index,
+ wx.LIST_NEXT_BELOW)
+ if key == self.GetItemData(index):
+ return index
+ if index == -1:
+ break
+ return -1
def ChangeColEditable(self, colName, colType):
- """!Changes 3. item in constructor parameter cols (see the class constructor hint)
+ """!Changes 3. item in constructor parameter cols (see the class constructor hint)"""
self.colsData[colNum][iColEd] = colType
@@ -380,8 +390,7 @@
event.Skip()
- """!Updates class attributes holding information about selected item
+ """!Updates class attributes holding information about selected item"""
if self.selected != event.GetIndex():
self.selected = event.GetIndex()
self.selectedkey = self.GetItemData(self.selected)
@@ -389,8 +398,7 @@
event.Skip()
def getSmallUpArrowImage(self):
- """!Get arrow up symbol for indication of sorting
+ """!Get arrow up symbol for indication of sorting"""
stream = open(os.path.join(globalvar.ETCIMGDIR, 'small_up_arrow.png'), 'rb')
try:
img = wx.ImageFromStream(stream)
@@ -399,8 +407,7 @@
return img
def getSmallDnArrowImage(self):
- """!Get arrow down symbol for indication of sorting
+ """!Get arrow down symbol for indication of sorting"""
stream = open(os.path.join(globalvar.ETCIMGDIR, 'small_down_arrow.png'), 'rb')
try:
