[GRASS-SVN] r52854 - grass/trunk/vector/v.generalize
Thu Aug 23 01:32:23 PDT 2012
Author: mmetz
Date: 2012-08-23 01:32:22 -0700 (Thu, 23 Aug 2012)
New Revision: 52854
   grass/trunk/vector/v.generalize/main.c
v.generalize: copy attributes by default
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2012-08-23 08:12:54 UTC (rev 52853)
+++ grass/trunk/vector/v.generalize/main.c	2012-08-23 08:32:22 UTC (rev 52854)
@@ -54,7 +54,7 @@
     struct Option *angle_thresh_opt, *degree_thresh_opt,
 	*closeness_thresh_opt;
     struct Option *betweeness_thresh_opt;
-    struct Flag *ca_flag;
+    struct Flag *notab_flag;
     int with_z;
     int total_input, total_output;	/* Number of points in the input/output map respectively */
     double thresh, alpha, beta, reduction, slide, angle_thresh;
@@ -226,10 +226,9 @@
     where_opt = G_define_standard_option(G_OPT_DB_WHERE);
     where_opt->guisection = _("Selection");
-    ca_flag = G_define_flag();
-    ca_flag->key = 'c';
-    ca_flag->description = _("Copy attributes");
-    ca_flag->guisection = _("Attributes");
+    notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
+    notab_flag->description = _("Do not copy attributes");
+    notab_flag->guisection = _("Attributes");
     /* options and flags parser */
     if (G_parser(argc, argv))
@@ -355,7 +354,7 @@
     /* copy tables here because method == NETWORK is complete and
      * tables for Out may be needed for parse_filter_options() below */
-    if (ca_flag->answer) {
+    if (!notab_flag->answer) {
 	if (method == NETWORK)
 	    copy_tables_by_cats(&In, &Out);
 	else
