[GRASS-SVN] r52855 - in grass/branches/releasebranch_6_4: gui/wxpython/dbmgr gui/wxpython/mapdisp gui/wxpython/nviz lib/python
svn_grass at osgeo.org
Thu Aug 23 01:34:31 PDT 2012
Author: annakrat
Date: 2012-08-23 01:34:30 -0700 (Thu, 23 Aug 2012)
New Revision: 52855
grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/dialogs.py
grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/vinfo.py
grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py
grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/mapwindow.py
grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
grass/branches/releasebranch_6_4/lib/python/vector.py
wxGUI: reorganize querying, if vector has no db connection, show query output in gui commmand output instead of Nothing found message #1606, #1469, show more layers in attribute dialog - #1522 (merge from trunk - r52832, r52834, r52835)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/dialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/dialogs.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/dialogs.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -394,7 +394,7 @@
idx = 0
for layer in data['Layer']:
layer = int(layer)
- if 'Id' in data:
+ if data['Id'][idx] is not None:
tfid = int(data['Id'][idx])
else:
tfid = 0 # Area / Volume
Modified: grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/vinfo.py
--- grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/vinfo.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/vinfo.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -96,28 +96,37 @@
coord = (float(queryCoords[0]), float(queryCoords[1])),
distance = float(qdist))
- if len(data) < 1 or 'Table' not in data[0]:
+ if len(data) < 1 or all(('Table' not in record) for record in data):
return None
# process attributes
- table = data[0]['Table']
- for key, value in data[0]['Attributes'].iteritems():
- if len(value) < 1:
- value = None
- else:
- if self.tables[table][key]['ctype'] != types.StringType:
- value = self.tables[table][key]['ctype'] (value)
- else:
- value = unicodeValue(value)
- self.tables[table][key]['values'].append(value)
ret = dict()
- for key, value in data[0].iteritems():
- if key == 'Attributes':
+ for key in ['Category', 'Layer', 'Table', 'Id']:
+ ret[key] = list()
+ for record in data:
+ if not 'Table' in record:
continue
- ret[key] = list()
- ret[key].append(value)
+ table = record['Table']
+ for key, value in record['Attributes'].iteritems():
+ if len(value) < 1:
+ value = None
+ else:
+ if self.tables[table][key]['ctype'] != types.StringType:
+ value = self.tables[table][key]['ctype'] (value)
+ else:
+ value = unicodeValue(value)
+ self.tables[table][key]['values'].append(value)
+ for key, value in record.iteritems():
+ if key == 'Attributes':
+ continue
+ if key in ret:
+ ret[key].append(value)
+ if 'Id' not in record.keys():
+ ret['Id'].append(None)
return ret
def SelectFromTable(self, layer, cols = '*', where = None):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/frame.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -51,7 +51,7 @@
from mapdisp import statusbar as sb
-from grass.script import core as grass
+import grass.script as grass
haveCtypes = False
@@ -628,54 +628,89 @@
pgnum = self.layerbook.GetPageIndex(self.page)
if pgnum > -1:
self.layerbook.DeletePage(pgnum)
- def QueryMap(self, x, y):
- """!Query raster or vector map layers by r/v.what
+ def Query(self, x, y, layers):
+ """!Query selected layers.
+ Calls QueryMap in case of raster or more vectors,
+ or QueryVector in case of one vector with db connection.
@param x,y coordinates
+ @param layers selected tree item layers
+ num = 0
+ filteredLayers = []
+ for layer in layers:
+ ltype = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
+ if ltype in ('raster', 'rgb', 'his',
+ 'vector', 'thememap', 'themechart'):
+ filteredLayers.append(layer)
+ if not filteredLayers:
+ GMessage(parent = self,
+ message = _('No raster or vector map layer selected for querying.'))
+ return
+ layers = filteredLayers
# set query snap distance for v.what at map unit equivalent of 10 pixels
qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
east, north = self.MapWindow.Pixel2Cell((x, y))
+ posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
+ y + self.MapWindow.dialogOffset))
+ isRaster = False
+ nVectors = 0
+ isDbConnection = False
+ for l in layers:
+ maplayer = self.tree.GetPyData(l)[0]['maplayer']
+ if maplayer.GetType() == 'raster':
+ isRaster = True
+ break
+ if maplayer.GetType() == 'vector':
+ nVectors += 1
+ isDbConnection = grass.vector_db(maplayer.GetName())
+ if not self.IsPaneShown('3d'):
+ if isRaster or nVectors > 1 or not isDbConnection:
+ self.QueryMap(east, north, qdist, layers)
+ else:
+ self.QueryVector(east, north, qdist, posWindow, layers[0])
+ else:
+ if isRaster:
+ self.MapWindow.QuerySurface(x, y)
+ if nVectors > 1 or not isDbConnection:
+ elif nVectors == 1:
+ def QueryMap(self, east, north, qdist, layers):
+ """!Query raster or vector map layers by r/v.what
- if not self.IsStandalone():
- num = 0
- for layer in self.tree.GetSelections():
- ltype = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
- if ltype in ('raster', 'rgb', 'his',
- 'vector', 'thememap', 'themechart'):
- num += 1
- if num < 1:
- GMessage(parent = self,
- message = _('No raster or vector map layer selected for querying.'))
- return
+ @param east,north coordinates
+ @param qdist query distance
+ @param layers selected tree items
rast = list()
vect = list()
rcmd = ['r.what', '--v']
vcmd = ['v.what', '--v']
- if self.IsStandalone():
- pass
- else:
- dcmd = self.tree.GetPyData(layer)[0]['cmd']
- name, found = GetLayerNameFromCmd(dcmd)
- if not found:
- continue
- if ltype == 'raster':
- rast.append(name)
- elif ltype in ('rgb', 'his'):
- for iname in name.split('\n'):
- rast.append(iname)
- elif ltype in ('vector', 'thememap', 'themechart'):
- vect.append(name)
- # rasters are not queried this way in 3D, we don't want them now
- if self.IsPaneShown('3d'):
- rast = list()
+ dcmd = self.tree.GetPyData(layer)[0]['cmd']
+ name, found = GetLayerNameFromCmd(dcmd)
+ if not found:
+ continue
+ if ltype == 'raster':
+ rast.append(name)
+ elif ltype in ('rgb', 'his'):
+ for iname in name.split('\n'):
+ rast.append(iname)
+ elif ltype in ('vector', 'thememap', 'themechart'):
+ vect.append(name)
# use display region settings instead of computation region settings
self.tmpreg = os.getenv("GRASS_REGION")
os.environ["GRASS_REGION"] = self.Map.SetRegion(windres = False)
@@ -689,7 +724,7 @@
if vect:
# check for vector maps open to be edited
- digitToolbar = self.toolbars['vdigit']
+ digitToolbar = self.GetToolbar('vdigit')
if digitToolbar:
lmap = digitToolbar.GetLayer().GetName()
for name in vect:
@@ -710,19 +745,14 @@
Debug.msg(1, "QueryMap(): raster=%s vector=%s" % (','.join(rast),
','.join(vect)))
# parse query command(s)
- if rast:
- self._layerManager.goutput.RunCmd(rcmd,
- compReg = False,
- onDone = self._QueryMapDone)
- if vect:
- self._layerManager.goutput.RunCmd(vcmd,
- else:
- if rast:
- RunCommand(rcmd)
- if vect:
- RunCommand(vcmd)
+ if rast and not self.IsPaneShown('3d'):
+ self._layerManager.goutput.RunCmd(rcmd,
+ compReg = False,
+ onDone = self._QueryMapDone)
+ if vect:
+ self._layerManager.goutput.RunCmd(vcmd,
def _QueryMapDone(self, cmd, returncode):
"""!Restore settings after querying (restore GRASS_REGION)
@@ -740,29 +770,15 @@
if hasattr(self, "tmpreg"):
del self.tmpreg
- def QueryVector(self, x, y):
+ def QueryVector(self, east, north, qdist, posWindow, layer):
"""!Query vector map layer features
Attribute data of selected vector object are displayed in GUI dialog.
Data can be modified (On Submit)
- if not self.tree.layer_selected or \
- self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
- message = _("No map layer selected for querying."))
- return
+ mapName = self.tree.GetPyData(layer)[0]['maplayer'].name
- posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
- y + self.MapWindow.dialogOffset))
- qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) /
- self.Map.width)
- east, north = self.MapWindow.Pixel2Cell((x, y))
- mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
- if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
+ if self.tree.GetPyData(layer)[0]['maplayer'].GetMapset() != \
grass.gisenv()['MAPSET']:
mode = 'display'
else:
@@ -808,7 +824,7 @@
qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId = False)
# set opacity based on queried layer
- opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float = True)
+ opacity = self.tree.GetPyData(layer)[0]['maplayer'].GetOpacity(float = True)
qlayer.SetOpacity(opacity)
self.MapWindow.UpdateMap(render = False, renderVector = False)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/mapwindow.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/gui/wxpython/mapdisp/mapwindow.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -26,7 +26,7 @@
from gui_core.dialogs import SavedRegion
-from core.gcmd import RunCommand, GException, GError
+from core.gcmd import RunCommand, GException, GError, GMessage
from core.debug import Debug
from core.settings import UserSettings
from gui_core.mapwindow import MapWindow
@@ -1110,30 +1110,16 @@
elif self.mouse["use"] == "query":
# querying
- layers = self.GetSelectedLayer(multi = True)
- isRaster = False
- nVectors = 0
- for l in layers:
- if l.GetType() == 'raster':
- isRaster = True
- break
- if l.GetType() == 'vector':
- nVectors += 1
- if isRaster or nVectors > 1:
- self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
- else:
- self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
- # clear temp canvas
- self.UpdateMap(render = False, renderVector = False)
- elif self.mouse["use"] == "queryVector":
- # editable mode for vector map layers
+ if self.parent.IsStandalone():
+ GMessage(parent = self.parent,
+ message = _("Querying is not implemented in standalone mode of Map Display"))
+ return
+ layers = self.GetSelectedLayer(type = 'item', multi = True)
+ self.parent.Query(self.mouse['begin'][0],self.mouse['begin'][1], layers)
elif self.mouse["use"] in ["measure", "profile"]:
# measure or profile
if self.mouse["use"] == "measure":
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -763,21 +763,15 @@
self.mouse['end'] = event.GetPositionTuple()
# querying
- isRaster = False
- nVectors = 0
- for l in layers:
- isRaster = True
- break
- nVectors += 1
- self.OnQueryMap(event)
- else:
- self.OnQueryVector(event)
+ return
elif self.mouse["use"] in ('arrow', 'scalebar'):
self.lmgr.nviz.FindWindowById(
self.lmgr.nviz.win['decoration'][self.mouse["use"]]['place']).SetValue(False)
@@ -998,16 +992,11 @@
self.render['quick'] = False
self.Refresh(False)
- def OnQueryMap(self, event):
- """!Query raster and vector maps"""
- self.OnQuerySurface(event)
- self.parent.QueryMap(event.GetX(), event.GetY())
- def OnQuerySurface(self, event):
+ def QuerySurface(self, x, y):
"""!Query surface on given position"""
size = self.GetClientSizeTuple()
- result = self._display.QueryMap(event.GetX(), size[1] - event.GetY())
+ result = self._display.QueryMap(x, size[1] - y)
if result:
self.qpoints.append((result['x'], result['y'], result['z']))
self.log.WriteLog("%-30s: %.3f" % (_("Easting"), result['x']))
Modified: grass/branches/releasebranch_6_4/lib/python/vector.py
--- grass/branches/releasebranch_6_4/lib/python/vector.py 2012-08-23 08:32:22 UTC (rev 52854)
+++ grass/branches/releasebranch_6_4/lib/python/vector.py 2012-08-23 08:34:30 UTC (rev 52855)
@@ -24,6 +24,7 @@
import os
import types
+import copy
import __builtin__
from core import *
@@ -242,8 +243,17 @@
'Table': 'archsites', 'Type': 'Point', 'Id': 8}]
@endcode
- To query one vector map at more locations
+ To query one vector map with multiple layers (no additional parameters required)
@code
+ for q in grass.vector_what(map = 'some_map', coord = (596532.357143,4920486.21429), distance = 100.0):
+ print q['Map'], q['Layer'], q['Attributes']
+ new_bug_sites 1 {'str1': 'Beetle_site', 'GRASSRGB': '', 'cat': '80'}
+ new_bug_sites 2 {'cat': '80'}
+ @endcode
+ To query more vector maps at one location
+ @code
for q in grass.vector_what(map = ('archsites', 'roads'), coord = (595743, 4925281),
distance = 250):
print q['Map'], q['Attributes']
@@ -252,7 +262,7 @@
roads {'label': 'interstate', 'cat': '1'}
@endcode
- To query more vector maps at one location
+ To query one vector map at more locations
@code
for q in grass.vector_what(map = 'archsites', coord = [(595743, 4925281), (597950, 4918898)],
distance = 250):
@@ -299,6 +309,9 @@
return data
dict_attrb = None
+ dict_map = None
+ dict_layer = None
+ attr_pseudo_key = 'Attributes'
for item in ret.splitlines():
try:
key, value = __builtin__.map(lambda x: x.strip(), item.split('=', 1))
@@ -308,21 +321,42 @@
continue
if key == 'Map':
- dict_main = { 'Map' : value }
+ # attach the last one from the previous map
+ if dict_layer is not None:
+ dict_main = copy.copy(dict_map)
+ dict_main.update(dict_layer)
+ data.append(dict_main)
+ dict_map = { key : value }
+ dict_layer = None
dict_attrb = None
- data.append(dict_main)
- continue
+ elif key == 'Layer':
+ # attach the last the previous Layer
+ dict_layer = { key: int(value) }
+ dict_attrb = None
+ elif key == 'Key_column':
+ dict_layer[key] = value
+ dict_attrb = dict()
+ dict_layer[attr_pseudo_key] = dict_attrb
+ elif dict_attrb is not None:
+ dict_attrb[key] = value
+ elif dict_layer is not None:
+ if key == 'Category':
+ dict_layer[key] = int(value)
+ else:
else:
- if dict_attrb is not None:
- dict_attrb[key] = value
- else:
- if key in ('Category', 'Layer', 'Id'):
- dict_main[key] = int(value)
- else:
- dict_main[key] = value
- if key == 'Key_column':
- # skip attributes
- dict_attrb = dict()
- dict_main['Attributes'] = dict_attrb
+ dict_map[key] = value
+ # TODO: there are some keys which has non-string values
+ # examples: Sq_Meters, Hectares, Acres, Sq_Miles
return data
