[GRASS-SVN] r52860 - in grass/trunk/gui/wxpython: . lmgr location_wizard
Thu Aug 23 09:08:20 PDT 2012
Author: annakrat
Date: 2012-08-23 09:08:19 -0700 (Thu, 23 Aug 2012)
New Revision: 52860
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/location_wizard/dialogs.py
   grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI/locationWizard: automatic import of file used for creating location, automatic GUI start (co-author wenzeslaus), merge from releasebranch, r52789
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2012-08-23 16:05:42 UTC (rev 52859)
+++ grass/trunk/gui/wxpython/gis_set.py	2012-08-23 16:08:19 UTC (rev 52860)
@@ -41,6 +41,7 @@
 from gui_core.ghelp import HelpFrame
 from core.gcmd      import GMessage, GError, DecodeString, RunCommand
 from core.utils     import GetListOfLocations, GetListOfMapsets
+from location_wizard.dialogs import RegionDef
 sys.stderr = codecs.getwriter('utf8')(sys.stderr)
@@ -387,11 +388,91 @@
         gWizard = LocationWizard(parent = self,
                                  grassdatabase = self.tgisdbase.GetValue())
         if gWizard.location !=  None:
-            self.OnSetDatabase(event)
+            self.tgisdbase.SetValue(gWizard.grassdatabase)
+            self.OnSetDatabase(None)
             self.UpdateMapsets(os.path.join(self.gisdbase, gWizard.location))
             self.lblocations.SetSelection(self.listOfLocations.index(gWizard.location))
             self.lbmapsets.SetSelection(0)
+            self.SetLocation(self.gisdbase, gWizard.location, 'PERMANENT')
+            if gWizard.georeffile:
+                message = _("Do you want to import data source <%(name)s> to created location?"
+                            " Default region will be set to match imported map.") % {'name': gWizard.georeffile}
+                dlg = wx.MessageDialog(parent = self,
+                                       message = message,
+                                       caption = _("Import data"),
+                                       style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+                dlg.CenterOnScreen()
+                if dlg.ShowModal() == wx.ID_YES:
+                    self.ImportFile(gWizard.georeffile)
+                else:
+                    self.SetDefaultRegion(location = gWizard.location)
+                dlg.Destroy()
+            else:
+            self.ExitSuccessfully()
+    def SetDefaultRegion(self, location):
+        """!Asks to set default region."""
+                               message = _("Do you want to set the default "
+                                           "region extents and resolution now?"),
+                               caption = _("Location <%s> created") % location,
+                               style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
+            dlg.Destroy()
+            defineRegion = RegionDef(self, location = location)
+            defineRegion.CenterOnScreen()
+            defineRegion.ShowModal()
+            defineRegion.Destroy()
+        else:
+            dlg.Destroy()
+    def ImportFile(self, filePath):
+        """!Tries to import file as vector or raster.
+        If successfull sets default region from imported map.
+        returncode, stdout, messagesIfVector = RunCommand('v.in.ogr', dsn = filePath, flags = 'l',
+                                                  read = True, getErrorMsg = True)
+        if returncode == 0:
+            wx.BeginBusyCursor()
+            wx.Yield()
+            returncode, messages = RunCommand('v.in.ogr', dsn = filePath,
+                                              output = os.path.splitext(os.path.basename(filePath))[0],
+                                              getErrorMsg = True)
+            wx.EndBusyCursor()
+            if returncode != 0:
+                message = _("Import of vector data source <%(name)s> failed.") % {'name': filePath}
+                message += "\n" + messages
+                GError(message = message)
+            else:
+                GMessage(message = _("Vector data source <%(name)s> imported successfully.") % {'name': filePath})
+                stdout = RunCommand('g.list', type = 'vect', read = True)
+                maps = stdout.splitlines()
+                if maps:
+                    # TODO: what about resolution?
+                    RunCommand('g.region', flags = 's', vect = maps[0])
+        else:
+            wx.Yield()
+            returncode, messages = RunCommand('r.in.gdal', input = filePath,
+                message = _("Attempt to import data source <%(name)s> as raster or vector failed. ") % {'name': filePath}
+                message += "\n\n" +  messagesIfVector + "\n" + messages
+            else:
+                GMessage(message = _("Raster data source <%(name)s> imported successfully.") % {'name': filePath})
+                stdout = RunCommand('g.list', type = 'rast', read = True)
+                if maps:
+                    RunCommand('g.region', flags = 's', rast = maps[0])
     def OnManageLoc(self, event):
         """!Location management choice control handler
@@ -774,7 +855,10 @@
                     return
             else:
                 return
+        self.SetLocation(dbase, location, mapset)
+    def SetLocation(self, dbase, location, mapset):
         RunCommand("g.gisenv",
                    set = "GISDBASE=%s" % dbase)
@@ -782,6 +866,8 @@
                    set = "MAPSET=%s" % mapset)
+    def ExitSuccessfully(self):
         self.Destroy()
         sys.exit(0)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-08-23 16:05:42 UTC (rev 52859)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-08-23 16:08:19 UTC (rev 52860)
@@ -324,6 +324,7 @@
     def OnLocationWizard(self, event):
         """!Launch location wizard"""
         from location_wizard.wizard import LocationWizard
+        from location_wizard.dialogs import RegionDef
                                  grassdatabase = grass.gisenv()['GISDBASE'])
@@ -350,6 +351,22 @@
                          message = _("Current location is <%(loc)s>.\n"
                                      "Current mapset is <%(mapset)s>.") % \
                              { 'loc' : location, 'mapset' : 'PERMANENT' })
+                # code duplication with gis_set.py
+                    dlg.Destroy()
+                else:
+                    dlg.Destroy()
     def OnSettingsChanged(self, event):
         """!Here can be functions which have to be called after EVT_SETTINGS_CHANGED.
Modified: grass/trunk/gui/wxpython/location_wizard/dialogs.py
--- grass/trunk/gui/wxpython/location_wizard/dialogs.py	2012-08-23 16:05:42 UTC (rev 52859)
+++ grass/trunk/gui/wxpython/location_wizard/dialogs.py	2012-08-23 16:08:19 UTC (rev 52860)
@@ -29,12 +29,12 @@
 from grass.script import core as grass
-class RegionDef(BaseClass, wx.Frame):
+class RegionDef(BaseClass, wx.Dialog):
     """!Page for setting default region extents and resolution
     def __init__(self, parent, id = wx.ID_ANY,
                  title = _("Set default region extent and resolution"), location = None):
-        wx.Frame.__init__(self, parent, id, title, size = (650,300))
+        wx.Dialog.__init__(self, parent, id, title, size = (650,300))
         panel = wx.Panel(self, id = wx.ID_ANY)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py	2012-08-23 16:05:42 UTC (rev 52859)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py	2012-08-23 16:08:19 UTC (rev 52860)
@@ -43,7 +43,7 @@
 from core.gcmd               import RunCommand, GError, GMessage, GWarning
 from location_wizard.base    import BaseClass
-from location_wizard.dialogs import RegionDef, SelectTransformDialog
+from location_wizard.dialogs import SelectTransformDialog
@@ -1758,7 +1758,10 @@
         self.datumtrans = None
         self.proj4string = ''
+        # file from which new location is created
+        self.georeffile = None
         # define wizard pages
@@ -1846,21 +1849,11 @@
             if not msg:
                 self.wizard.Destroy()
                 self.location = self.startpage.location
-                if self.altdb == False:
-                    dlg = wx.MessageDialog(parent = self.parent,
-                                           message = _("Do you want to set the default "
-                                                     "region extents and resolution now?"),
-                                           caption = _("Location <%s> created") % self.location,
-                                           style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
-                    dlg.CenterOnScreen()
-                    if dlg.ShowModal() == wx.ID_YES:
-                        dlg.Destroy()
-                        defineRegion = RegionDef(self.parent, location = self.location)
-                        defineRegion.CenterOnScreen()
-                        defineRegion.Show()
-                    else:
-                        dlg.Destroy()
+                self.grassdatabase = self.startpage.grassdatabase
+                self.georeffile = self.filepage.georeffile
+                # FIXME here was code for setting default region, what for is this if:
+                # if self.altdb == False:
             else: # -> error
                 GError(parent = self.parent,
