[GRASS-SVN] r52861 - in grass/trunk: display/d.info display/d.mon general/g.message imagery/i.aster.toar imagery/i.fft imagery/i.ifft imagery/i.landsat.toar scripts/r.in.aster temporal/t.list temporal/t.vect.list
svn_grass at osgeo.org
Thu Aug 23 09:22:22 PDT 2012
Author: neteler
Date: 2012-08-23 09:22:21 -0700 (Thu, 23 Aug 2012)
New Revision: 52861
grass/trunk/display/d.info/main.c
grass/trunk/display/d.mon/main.c
grass/trunk/general/g.message/main.c
grass/trunk/imagery/i.aster.toar/main.c
grass/trunk/imagery/i.fft/main.c
grass/trunk/imagery/i.ifft/main.c
grass/trunk/imagery/i.landsat.toar/main.c
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
homogenize keywords
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/display/d.info/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -29,6 +29,7 @@
module = G_define_module();
G_add_keyword(_("display"));
+ G_add_keyword(_("graphics"));
G_add_keyword(_("monitors"));
module->label =
_("Displays information about the active display monitor.");
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/display/d.mon/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -37,7 +37,6 @@
- G_add_keyword(_("CLI"));
module->description = _("Controls graphics display monitors from the command line.");
start_opt = G_define_option();
Modified: grass/trunk/general/g.message/main.c
--- grass/trunk/general/g.message/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/general/g.message/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -31,6 +31,7 @@
G_add_keyword(_("general"));
+ G_add_keyword(_("support"));
G_add_keyword(_("scripts"));
module->label =
_("Prints a message, warning, progress info, or fatal error in the GRASS way.");
Modified: grass/trunk/imagery/i.aster.toar/main.c
--- grass/trunk/imagery/i.aster.toar/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/imagery/i.aster.toar/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -95,8 +95,8 @@
G_gisinit(argv[0]);
G_add_keyword(_("imagery"));
+ G_add_keyword(_("radiometric conversion"));
G_add_keyword(_("Terra-ASTER"));
- G_add_keyword(_("DN"));
G_add_keyword(_("radiance"));
G_add_keyword(_("reflectance"));
G_add_keyword(_("brightness temperature"));
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/imagery/i.fft/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -76,7 +76,7 @@
- G_add_keyword(_("FFT"));
+ G_add_keyword(_("Fast Fourier Transform"));
_("Fast Fourier Transform (FFT) for image processing.");
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/imagery/i.ifft/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -75,7 +75,7 @@
/* Set description */
_("Inverse Fast Fourier Transform (IFFT) for image processing.");
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2012-08-23 16:22:21 UTC (rev 52861)
@@ -66,6 +66,7 @@
_("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+.");
G_add_keyword(_("landsat"));
G_add_keyword(_("top-of-atmosphere reflectance"));
G_add_keyword(_("dos-type simple atmospheric correction"));
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2012-08-23 16:22:21 UTC (rev 52861)
@@ -25,6 +25,7 @@
#% keywords: raster
#% keywords: imagery
#% keywords: import
+#% keywords: Terra-ASTER
#%End
#%option G_OPT_F_INPUT
#% description: Name of input ASTER image
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/temporal/t.list/t.list.py 2012-08-23 16:22:21 UTC (rev 52861)
@@ -15,8 +15,9 @@
#%module
-#% description: List space time datasets and maps registered in the temporal database
+#% description: List space time datasets and maps registered in the temporal database.
#% keywords: temporal
+#% keywords: map management
#% keywords: list
#%end
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-08-23 16:08:19 UTC (rev 52860)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-08-23 16:22:21 UTC (rev 52861)
@@ -17,6 +17,7 @@
#%module
#% description: Lists registered maps of a space time vector dataset.
#% keywords: list
#%end
