[GRASS-SVN] r52862 - in grass/trunk: imagery/i.sunhours raster/r.contour raster/r.horizon raster/r.sun raster/r.sunmask vector/v.overlay vector/v.select
svn_grass at osgeo.org
Thu Aug 23 09:41:40 PDT 2012
Author: neteler
Date: 2012-08-23 09:41:40 -0700 (Thu, 23 Aug 2012)
New Revision: 52862
grass/trunk/imagery/i.sunhours/main.c
grass/trunk/raster/r.contour/main.c
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.sun/main.c
grass/trunk/raster/r.sunmask/main.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.select/main.c
homogenize keywords
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/imagery/i.sunhours/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -43,6 +43,8 @@
G_gisinit(argv[0]);
module = G_define_module();
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("solar"));
G_add_keyword(_("sunshine"));
G_add_keyword(_("hours"));
G_add_keyword(_("daytime"));
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/raster/r.contour/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -84,7 +84,7 @@
G_add_keyword(_("raster"));
- G_add_keyword(_("DEM"));
+ G_add_keyword(_("surface"));
G_add_keyword(_("contours"));
G_add_keyword(_("vector"));
module->description = _("Produces a vector map of specified "
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/raster/r.horizon/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -175,6 +175,7 @@
G_gisinit(argv[0]);
G_add_keyword(_("sun position"));
module->label =
_("Horizon angle computation from a digital elevation model.");
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/raster/r.sun/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -227,6 +227,7 @@
G_add_keyword(_("sun energy"));
module->label = _("Solar irradiance and irradiation model.");
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/raster/r.sunmask/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -114,6 +114,7 @@
module->label = _("Calculates cast shadow areas from sun position and elevation raster map.");
module->description = _("Either exact sun position (A) is specified, or date/time to calculate "
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/vector/v.overlay/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -54,6 +54,7 @@
G_add_keyword(_("geometry"));
+ G_add_keyword(_("spatial query"));
module->description = _("Overlays two vector maps.");
in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2012-08-23 16:22:21 UTC (rev 52861)
+++ grass/trunk/vector/v.select/main.c 2012-08-23 16:41:40 UTC (rev 52862)
@@ -45,6 +45,7 @@
+ G_add_keyword(_("geometry"));
_("Selects features from vector map (A) by features from other vector map (B).");
