[GRASS-SVN] r52933 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Mon Aug 27 06:17:13 PDT 2012
Author: annakrat
Date: 2012-08-27 06:17:13 -0700 (Mon, 27 Aug 2012)
New Revision: 52933
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/layertree: fixed second issue in #1616
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-08-27 11:21:31 UTC (rev 52932)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-08-27 13:17:13 UTC (rev 52933)
@@ -124,6 +124,7 @@
self.rerender = False # layer change requires a rerendering if auto render
self.reorder = False # layer change requires a reordering
self.hitCheckbox = False # if cursor points at layer checkbox (to cancel selection changes)
+ self.forceCheck = False # force check layer if CheckItem is called
try:
ctstyle |= CT.TR_ALIGN_WINDOWS
@@ -228,6 +229,7 @@
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnChangeSel)
self.Bind(wx.EVT_TREE_SEL_CHANGING, self.OnChangingSel)
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
+ self.Bind(CT.EVT_TREE_ITEM_CHECKING, self.OnLayerChecking)
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
self.Bind(wx.EVT_TREE_END_DRAG, self.OnEndDrag)
@@ -833,6 +835,7 @@
else:
checked = True
+ self.forceCheck = True
self.CheckItem(layer, checked = checked)
# add text and icons for each layer ltype
@@ -1124,6 +1127,17 @@
event.Skip()
+ def OnLayerChecking(self, event):
+ """!Layer checkbox is being checked.
+ Continue only if mouse is above checkbox or layer was checked programatically.
+ if self.hitCheckbox or self.forceCheck:
+ event.Skip()
+ else:
+ event.Veto()
def OnLayerChecked(self, event):
"""!Enable/disable data layer"""
self.lmgr.WorkspaceChanged()
@@ -1137,6 +1151,7 @@
if self.GetPyData(item)[0]['type'] == 'group':
child, cookie = self.GetFirstChild(item)
while child:
self.CheckItem(child, checked)
mapLayer = self.GetPyData(child)[0]['maplayer']
if not digitToolbar or \
@@ -1212,7 +1227,10 @@
Detects if mouse points at checkbox.
thisItem, flags = self.HitTest(event.GetPosition())
- if flags & CT.TREE_HITTEST_ONITEMCHECKICON:
+ # workaround: in order not to check checkox when clicking outside
+ # we need flag TREE_HITTEST_ONITEMCHECKICON but not TREE_HITTEST_ONITEMLABEL
+ # this applies only for TR_FULL_ROW_HIGHLIGHT style
+ if (flags & CT.TREE_HITTEST_ONITEMCHECKICON) and not (flags & CT.TREE_HITTEST_ONITEMLABEL):
self.hitCheckbox = True
else:
@@ -1436,6 +1454,7 @@
else:
self.GetPyData(newItem)[0]['ctrl'] = None
self.CheckItem(newItem, checked = checked) # causes a new render
return newItem
