[GRASS-SVN] r52934 - in grass-addons/grass7/vector: v.pack v.unpack v.unpack/test_suite
svn_grass at osgeo.org
Mon Aug 27 06:53:28 PDT 2012
Author: huhabla
Date: 2012-08-27 06:53:27 -0700 (Mon, 27 Aug 2012)
New Revision: 52934
Added:
grass-addons/grass7/vector/v.unpack/test_suite/
grass-addons/grass7/vector/v.unpack/test_suite/test.v.unpack.sh
grass-addons/grass7/vector/v.pack/v.pack.py
grass-addons/grass7/vector/v.unpack/v.unpack.py
Added compression option and tests to v.pack and v.unpack.
A new projection comparision method was implemented.
Modified: grass-addons/grass7/vector/v.pack/v.pack.py
--- grass-addons/grass7/vector/v.pack/v.pack.py 2012-08-27 13:17:13 UTC (rev 52933)
+++ grass-addons/grass7/vector/v.pack/v.pack.py 2012-08-27 13:53:27 UTC (rev 52934)
@@ -34,6 +34,10 @@
#% key_desc: path
#% required : no
#%end
+#%flag
+#% key: c
+#% description: Switch the compression off
+#%end
import os
import sys
@@ -45,6 +49,7 @@
def main():
infile = options['input']
+ compression_off = flags['c']
#search if file exist
gfile = grass.find_file(infile, element = 'vector')
if not gfile['name']:
@@ -71,8 +76,9 @@
db_vect = vector.vector_db(gfile['fullname'])
#db not exist and skip the db copy
+ sqlitedb = None
if not db_vect:
- grass.message('There is not database connected with vector %s' % gfile['fullname'])
+ grass.message(_('There is not database connected with vector %s') % gfile['fullname'])
else:
# for each layer connection save a table
for i, dbconn in db_vect.iteritems():
@@ -81,8 +87,12 @@
from_database = dbconn['database'], from_table = dbconn['table'],
to_driver = 'sqlite', to_database = sqlitedb,
to_table = dbconn['table'])
- #write tar file
- tar = tarfile.open(outfile, "w:gz")
+ # write tar file, optional compression
+ if compression_off:
+ tar = tarfile.open(name = outfile, mode = 'w:')
+ else:
+ tar = tarfile.open(name = outfile, mode = 'w:gz')
tar.add(os.path.join(basedir,'vector',infile),infile)
gisenv = grass.gisenv()
#add to the tar file the PROJ files to check when unpack file
@@ -93,7 +103,7 @@
tar.add(path,os.path.join(infile,'PROJ_' + support))
tar.close()
#remove the db from the vector directory #ONLY THE DB FOR THE COPY NOT DB OF GRASS
- if db_vect:
+ if db_vect and sqlitedb:
os.remove(sqlitedb)
grass.verbose(_("Vector map saved to '%s'" % os.path.join(olddir, outfile)))
Added: grass-addons/grass7/vector/v.unpack/test_suite/test.v.unpack.sh
--- grass-addons/grass7/vector/v.unpack/test_suite/test.v.unpack.sh (rev 0)
+++ grass-addons/grass7/vector/v.unpack/test_suite/test.v.unpack.sh 2012-08-27 13:53:27 UTC (rev 52934)
@@ -0,0 +1,59 @@
+# This script tests v.pack and v.unpack
+# We specific a small region in the
+# @preprocess step
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=70 w=0 e=100 b=0 t=50 -p
+# We need different vector maps, with and without tables
+# and with multiple layers
+v.random --o -z output=probe_1 n=100 zmin=0 zmax=100 seed=1
+v.random --o -z output=probe_2 n=100 zmin=0 zmax=100 column=height seed=1
+v.random --o -z output=probe_orig n=100 zmin=0 zmax=100 column=height seed=1
+# Adding new layer with categories
+v.category input=probe_orig out=probe_3 option=transfer layer=1,2,3 --o
+# Creating new tables for each layer
+db.copy from_table=probe_orig to_table=probe_3_1
+db.copy from_table=probe_orig to_table=probe_3_2
+db.copy from_table=probe_orig to_table=probe_3_3
+# Removing un-needed vectors and tables
+g.remove vect=probe_orig
+v.db.droptable -f map=probe_3 table=probe_3 layer=1
+# Adding tables to layer
+v.db.addtable --o map=probe_3 table=probe_3_1 layer=1
+v.db.addtable --o map=probe_3 table=probe_3_2 layer=2
+v.db.addtable --o map=probe_3 table=probe_3_3 layer=3
+# First we @test the packing/export with v.pack
+v.pack --o input=probe_1
+v.pack --o input=probe_2
+v.pack --o input=probe_3
+v.pack --o -c input=probe_1 output=probe_1_uncompressed.pack
+v.pack --o -c input=probe_2 output=probe_2_uncompressed.pack
+v.pack --o -c input=probe_3 output=probe_3_uncompressed.pack
+# We need to clean before import
+g.remove vect=probe_1,probe_2,probe_3
+# Test the import with v.unpack
+v.unpack --o input=probe_1.pack
+v.category input=probe_1 option=report
+v.unpack --o input=probe_2.pack
+v.category input=probe_2 option=report
+v.unpack --o input=probe_3.pack
+v.category input=probe_3 option=report
+v.unpack --o input=probe_1.pack output=probe_1_uncompressed
+v.category input=probe_1_uncompressed option=report
+v.unpack --o input=probe_2.pack output=probe_2_uncompressed
+v.category input=probe_2_uncompressed option=report
+v.unpack --o input=probe_3.pack output=probe_3_uncompressed
+v.category input=probe_3_uncompressed option=report
+g.remove vect=probe_1_uncompressed,probe_2_uncompressed,probe_3_uncompressed
+rm *.pack
Modified: grass-addons/grass7/vector/v.unpack/v.unpack.py
--- grass-addons/grass7/vector/v.unpack/v.unpack.py 2012-08-27 13:17:13 UTC (rev 52933)
+++ grass-addons/grass7/vector/v.unpack/v.unpack.py 2012-08-27 13:53:27 UTC (rev 52934)
@@ -39,6 +39,7 @@
#% description: Override projection check (use current location's projection)
#%end
import os
import sys
import shutil
@@ -54,7 +55,7 @@
def main():
- # create tempory directory
+ # create temporary directory
global tmp_dir
tmp_dir = grass.tempdir()
grass.debug('tmp_dir = %s' % tmp_dir)
@@ -65,7 +66,7 @@
input_base = os.path.basename(infile)
shutil.copyfile(infile, os.path.join(tmp_dir, input_base))
os.chdir(tmp_dir)
- tar = tarfile.TarFile.open(name = input_base, mode = 'r:gz')
+ tar = tarfile.TarFile.open(name = input_base, mode = 'r')
try:
data_name = tar.getnames()[0]
except:
@@ -98,7 +99,9 @@
# check projection compatibility in a rather crappy way
loc_proj = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
- if not filecmp.cmp(os.path.join(data_name,'PROJ_INFO'), loc_proj):
+ loc_proj_units = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
+ if not grass.compare_key_value_text_files(os.path.join(data_name,'PROJ_INFO'), loc_proj) or \
+ not grass.compare_key_value_text_files(os.path.join(data_name,'PROJ_UNITS'), loc_proj_units):
if flags['o']:
grass.warning(_("Projection information does not match. Proceeding..."))
else:
@@ -131,22 +134,40 @@
values = t.split('|')
else:
values = t.split(' ')
+ from_table = values[1]
+ layer = values[0].split('/')[0]
+ # We need to take care about the table name in case of several layer
+ if options["output"]:
+ to_table = "%s_%s"%(map_name, layer)
+ else:
+ to_table = from_table
+ grass.verbose(_("Copy table %s to table %s"%(from_table, to_table)))
#copy the table in the default database
- print "prima di db.copy"
- grass.run_command('db.copy', to_driver = dbconn['driver'],
- to_database = todb, to_table = map_name,
+ ret = grass.run_command('db.copy', to_driver = dbconn['driver'],
+ to_database = todb, to_table = to_table,
from_driver = 'sqlite', from_database = fromdb,
- from_table = values[1])
- #and connect the new tables with the rigth layer
- grass.run_command('v.db.connect', flags = "o",
+ from_table = from_table)
+ if ret != 0:
+ grass.fatal(_("Unable to copy table %s to table %s"%(from_table, to_table)))
+ grass.verbose(_("Connect table %s to vector %s at layer %s"%(to_table, map_name, layer)))
+ #and connect the new tables with the right layer
+ ret = grass.run_command('v.db.connect', flags = "o",
driver = dbconn['driver'], database = todb,
map = map_name, key = values[2],
- layer = values[0].split('/')[0], table = map_name)
+ layer = layer, table = to_table)
+ if ret != 0:
+ grass.fatal(_("Unable to connect table %s to vector map %s"%(to_table, map_name)))
#remove
os.remove(os.path.join(new_dir,'PROJ_INFO'))
os.remove(os.path.join(new_dir,'PROJ_UNITS'))
- os.remove(os.path.join(new_dir,'db.sqlite'))
+ if os.path.exists(fromdb):
+ os.remove(os.path.join(new_dir,'db.sqlite'))
grass.verbose(_("Vector map saved to <%s>") % map_name)
