[GRASS-SVN] r52987 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Thu Aug 30 00:58:41 PDT 2012
Author: neteler
Date: 2012-08-30 00:58:41 -0700 (Thu, 30 Aug 2012)
New Revision: 52987
grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
fix duplicate msg
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6420,11 +6420,6 @@
msgid "Must have a weight value for each filter"
msgstr ""
-#: ../raster/r.random.surface/init.c:425
-#, fuzzy, c-format
-msgid "<%s> is an illegal name"
-msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
#, fuzzy, c-format
msgid "Unable to write color table for raster map <%s>"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6499,11 +6499,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> je neplatné jméno souboru"
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6471,11 +6471,6 @@
msgstr "Es muss für jeden Filter einen Gewicht geben."
-#, c-format
-msgstr "<%s> ist ein ungültiger Name."
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6164,11 +6164,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6548,11 +6548,6 @@
msgstr ""
-#, c-format
-msgstr "<%s> es un nombre no admitido"
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6970,11 +6970,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] n'est pas un nom légal"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6582,11 +6582,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "हà¥"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6309,11 +6309,6 @@
msgstr "Deve avere un valore di peso per ogni filtro"
-#, c-format
-msgstr "<%s> è un nome non valido"
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6272,11 +6272,6 @@
msgstr "åãã£ã«ã¿ã«å¯¾ãã¦å éå¤ãå«ãã§ããªããã°ãªãã¾ãã"
-#, c-format
-msgstr "<%s> ã¯ä¸æ£ãªãã¡ã¤ã«åã§ã"
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6198,11 +6198,6 @@
msgstr ""
-#, c-format
-msgstr ""
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6315,11 +6315,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "izejas lÄ«meÅa nosaukums"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6216,11 +6216,6 @@
msgstr ""
-#, c-format
-msgstr ""
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6046,11 +6046,6 @@
msgstr ""
-#, c-format
-msgstr ""
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6352,11 +6352,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> jest niedozwolonÄ
nazwÄ
pliku"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6694,11 +6694,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] é um nome ilegal"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6604,11 +6604,6 @@
msgstr ""
-#, fuzzy, c-format
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6489,11 +6489,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr ""
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6510,11 +6510,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "Ime izhodnega rastrskega sloja"
#, fuzzy, c-format
@@ -11323,7 +11318,7 @@
msgid "Distance must be >= 0.0"
msgstr "navedena morata biti 2 sloja"
-#: ../raster/r.random.cells/init.c:156 ../imagery/i.topo.corr/main.c:52
+#: ../raster/r.random.cells/init.c:156 ../imagery/i.topo.corr/main.c:52 ../raster/r.random.surface/init.c:425
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6430,11 +6430,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> à¸à¸·à¹à¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6226,11 +6226,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> uygun olmayan bir addır"
#, fuzzy, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6479,11 +6479,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] là tên không hợp lá»"
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-08-30 07:52:48 UTC (rev 52986)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-08-30 07:58:41 UTC (rev 52987)
@@ -6425,11 +6425,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> æ¯éæ³çåç§°"
#, fuzzy, c-format
