[GRASS-SVN] r53015 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Fri Aug 31 03:44:42 PDT 2012
Author: neteler
Date: 2012-08-31 03:44:41 -0700 (Fri, 31 Aug 2012)
New Revision: 53015
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassnviz_pl.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-08-31 10:42:58 UTC (rev 53014)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-08-31 10:44:41 UTC (rev 53015)
@@ -9,7 +9,7 @@
"Project-Id-Version: grassmods_pl\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2012-08-30 00:45+0100\n"
+"PO-Revision-Date: 2012-08-30 16:49+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
"Language: pl\n"
@@ -1521,7 +1521,7 @@
#: ../misc/m.nviz.image/args.c:49
msgid "Use draw mode for all loaded surfaces"
-msgstr ""
+msgstr "Użyj trybu rysowania dla wszyskich wczytanych powierzchni"
#: ../misc/m.nviz.image/args.c:50 ../misc/m.nviz.image/args.c:122
#: ../misc/m.nviz.image/args.c:131 ../misc/m.nviz.image/args.c:138
@@ -1580,15 +1580,15 @@
#: ../misc/m.nviz.image/args.c:178
msgid "Name of raster map(s) for shininess"
-msgstr "Nazwa mapy rastrowej, która ma być użyta do błyszczenia"
+msgstr "Nazwa mapy rastrowej do nałożenia jasności"
#: ../misc/m.nviz.image/args.c:188
msgid "Shininess value(s)"
-msgstr ""
+msgstr "Wartości jasności"
#: ../misc/m.nviz.image/args.c:196
msgid "Name of raster map(s) for emission"
-msgstr "Nazwa mapy rastrowej, która ma być użyta do emisji"
+msgstr "Nazwa mapy rastrowej do nałożenia emisji"
#: ../misc/m.nviz.image/args.c:206
msgid "Emission value(s)"
@@ -1672,7 +1672,7 @@
#: ../misc/m.nviz.image/args.c:378
msgid "Icon size"
-msgstr "Rozmiar ikon"
+msgstr "Rozmiar ikony"
#: ../misc/m.nviz.image/args.c:390
msgid "Icon width"
@@ -1684,7 +1684,7 @@
#: ../misc/m.nviz.image/args.c:411
msgid "Icon marker"
-msgstr ""
+msgstr "Symbol ikony"
#: ../misc/m.nviz.image/args.c:424
msgid "Vector points position"
@@ -1726,11 +1726,11 @@
#: ../misc/m.nviz.image/args.c:505
msgid "Volume draw mode"
-msgstr ""
+msgstr "Tryb rysowania rastrów 3D"
#: ../misc/m.nviz.image/args.c:517
msgid "Volume shading"
-msgstr ""
+msgstr "Cieniowanie rastrów 3D"
#: ../misc/m.nviz.image/args.c:529
msgid "Volume position"
@@ -1742,11 +1742,11 @@
#: ../misc/m.nviz.image/args.c:551
msgid "Isosurface level"
-msgstr ""
+msgstr "Poziom izopowierzchni"
#: ../misc/m.nviz.image/args.c:566
msgid "Light position (x,y,z model coordinates)"
-msgstr "Pozycja źródła światła (x,y,z)"
+msgstr "Pozycja źródła światła (x,y,z współrzędne modelu)"
#: ../misc/m.nviz.image/args.c:567 ../misc/m.nviz.image/args.c:573
#: ../misc/m.nviz.image/args.c:582 ../misc/m.nviz.image/args.c:592
@@ -1759,11 +1759,11 @@
#: ../misc/m.nviz.image/args.c:581
msgid "Light brightness"
-msgstr ""
+msgstr "Jasność światła"
#: ../misc/m.nviz.image/args.c:591
msgid "Light ambient"
-msgstr ""
+msgstr "Otoczenie światła"
#: ../misc/m.nviz.image/args.c:603
msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
@@ -1771,7 +1771,7 @@
#: ../misc/m.nviz.image/args.c:607
msgid "Fringe edges"
-msgstr ""
+msgstr "Granice obramowania"
#: ../misc/m.nviz.image/args.c:608 ../misc/m.nviz.image/args.c:614
#: ../misc/m.nviz.image/args.c:623
@@ -1784,7 +1784,7 @@
#: ../misc/m.nviz.image/args.c:622
msgid "Fringe elevation"
-msgstr ""
+msgstr "Uniesienie obramowania"
#: ../misc/m.nviz.image/args.c:667
#, c-format
@@ -2286,9 +2286,8 @@
msgstr "Problem z odczytem wyników r.stats"
#: ../raster/r.profile/main.c:53
-#, fuzzy
msgid "raster, profile"
-msgstr "raster, serie"
+msgstr "raster, profil"
#: ../raster/r.profile/main.c:55
msgid "Outputs the raster map layer values lying on user-defined line(s)."
@@ -23066,7 +23065,7 @@
#: ../vector/v.digit/attr.c:403
msgid "Deselect Source"
-msgstr ""
+msgstr "Odznacz źródło"
#: ../vector/v.digit/attr.c:462
msgid "Display attributes:"
@@ -23219,7 +23218,7 @@
#: ../vector/v.digit/zoom.c:27 ../vector/v.digit/zoom.c:44
#: ../vector/v.digit/zoom.c:75
msgid "1. corner"
-msgstr ""
+msgstr "1. róg"
#: ../vector/v.digit/zoom.c:75 ../vector/v.digit/zoom.c:158
@@ -23228,7 +23227,7 @@
#: ../vector/v.digit/zoom.c:44
msgid "2. corner"
-msgstr ""
+msgstr "2. róg"
#: ../vector/v.digit/zoom.c:157
msgid "Pan"
@@ -23523,11 +23522,11 @@
#: ../vector/v.in.db/main.c:138
#, c-format
msgid "Missing column <%s> in table <%s>"
-msgstr ""
+msgstr "Brak kolumny <%s> w tabeli <%s>"
#: ../vector/v.db.connect/main.c:290 ../vector/v.in.db/main.c:141
msgid "Data type of key column must be integer"
-msgstr ""
+msgstr "Typ danych kolumny musi być integer"
#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
#, c-format
@@ -23548,7 +23547,7 @@
#: ../vector/v.delaunay2/main.c:149
msgid "Delaunay triangulation..."
-msgstr ""
+msgstr "Triangulacja Delaunay"
#: ../vector/v.delaunay2/main.c:152
#, fuzzy
@@ -24976,27 +24975,27 @@
#: ../vector/v.transform/main.c:121
msgid "Shifting value for x coordinates"
-msgstr ""
+msgstr "Wartość przesunięcia dla współrzędnych x"
#: ../vector/v.transform/main.c:130
msgid "Shifting value for y coordinates"
-msgstr ""
+msgstr "Wartość przesunięcia dla współrzędnych y"
#: ../vector/v.transform/main.c:139 ../vector/v.extrude/main.c:85
msgid "Shifting value for z coordinates"
-msgstr ""
+msgstr "Wartość przesunięcia dla współrzędnych z"
#: ../vector/v.transform/main.c:148
msgid "Scaling factor for x coordinates"
-msgstr ""
+msgstr "Współczynnik skali dla współrzędnych x"
#: ../vector/v.transform/main.c:157
msgid "Scaling factor for y coordinates"
-msgstr ""
+msgstr "Współczynnik skali dla współrzędnych y"
#: ../vector/v.transform/main.c:166
msgid "Scaling factor for z coordinates"
-msgstr ""
+msgstr "Współczynnik skali dla współrzędnych z"
#: ../vector/v.transform/main.c:176
#, fuzzy
@@ -25305,7 +25304,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:78
msgid "vector, LIDAR, edges"
-msgstr ""
+msgstr "wektor LIDAR, granice"
#: ../vector/lidar/v.lidar.edgedetection/main.c:80
msgid "Detects the object's edges from a LIDAR data set."
@@ -26378,7 +26377,7 @@
#: ../vector/v.out.pov/main.c:207
#, c-format
msgid "%d features written"
-msgstr ""
+msgstr "%d obiektów zapisano"
#: ../vector/v.select/args.c:45
msgid "Operator defines required relation between features"
@@ -26806,7 +26805,7 @@
#: ../vector/v.clean/main.c:210
msgid "Snap vertices"
-msgstr ""
+msgstr "Snapowanie węzłów"
#: ../vector/v.clean/main.c:213
#, fuzzy
@@ -29974,7 +29973,7 @@
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:3
msgid "B"
-msgstr ""
+msgstr "B"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:4
msgid "C"
@@ -29990,12 +29989,12 @@
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:7
msgid "F"
-msgstr ""
+msgstr "F"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
msgid "Formula (e.g. A-B or A*C+B)"
-msgstr ""
+msgstr "Formuła (np. A-B lub A*C+B)"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
@@ -30340,13 +30339,13 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:20
msgid "GeoTIFF creation option(s)"
-msgstr ""
+msgstr "Opcje tworzenia GeoTIFF"
#: ../locale/scriptstrings/d.out.file_to_translate.c:22
#: ../locale/scriptstrings/d.out.file_to_translate.c:25
#: ../locale/scriptstrings/d.out.file_to_translate.c:34
msgid "GeoTIFF"
-msgstr ""
+msgstr "GeoTIFF"
#: ../locale/scriptstrings/d.out.file_to_translate.c:23
msgid "GeoTIFF metadata key(s) and value(s) to add"
@@ -30374,14 +30373,12 @@
msgstr ""
#: ../locale/scriptstrings/d.out.file_to_translate.c:33
-#, fuzzy
msgid "Do not crop away margins"
-msgstr "Kopiowanie tablicy nie powiodło się"
+msgstr "Nie obcinaj marginesów"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
msgid "Name of aspect raster map"
-msgstr "Nazwa bazoewj mapy rastrowej"
+msgstr "Nazwa mapy rastrowej spadku"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
msgid "Width of display canvas"
@@ -30821,27 +30818,27 @@
#: ../locale/scriptstrings/i.oif_to_translate.c:3
msgid "LANDSAT TM band 1."
-msgstr ""
+msgstr "LANDSAT TM kanał 1."
#: ../locale/scriptstrings/i.oif_to_translate.c:4
msgid "LANDSAT TM band 2."
-msgstr ""
+msgstr "LANDSAT TM kanał 2."
#: ../locale/scriptstrings/i.oif_to_translate.c:5
msgid "LANDSAT TM band 3."
-msgstr ""
+msgstr "LANDSAT TM kanał 3."
#: ../locale/scriptstrings/i.oif_to_translate.c:6
msgid "LANDSAT TM band 4."
-msgstr ""
+msgstr "LANDSAT TM kanał 4."
#: ../locale/scriptstrings/i.oif_to_translate.c:7
msgid "LANDSAT TM band 5."
-msgstr ""
+msgstr "LANDSAT TM kanał 5."
#: ../locale/scriptstrings/i.oif_to_translate.c:8
msgid "LANDSAT TM band 7."
-msgstr ""
+msgstr "LANDSAT TM kanał 7."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
msgid "Drops a column from the attribute table connected to a given vector map."
@@ -30994,19 +30991,19 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
msgid "1st map for mosaic (top of image stack)."
-msgstr ""
+msgstr "Pierwsza mapa do mozaiki (wierzch zestawu obrazów)."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
msgid "2nd map for mosaic."
-msgstr ""
+msgstr "Druga mapa do mozaiki."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
msgid "3rd map for mosaic."
-msgstr ""
+msgstr "Trzecia mapa do mozaiki."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
msgid "4th map for mosaic."
-msgstr ""
+msgstr "Czwarta mapa do mozaiki."
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
msgid "calculates univariate statistics from a GRASS raster map"
@@ -31079,7 +31076,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
msgid "wms"
-msgstr ""
+msgstr "wms"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
@@ -31284,21 +31281,21 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
msgid "LANDSAT sensor"
-msgstr ""
+msgstr "Sensor LANDSAT'a"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
msgid "Sensor"
-msgstr ""
+msgstr "Sensor"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
msgid "QuickBird sensor"
-msgstr ""
+msgstr "Sensor QuickBird"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
msgid "SPOT sensor"
-msgstr ""
+msgstr "Sensor SPOT"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassnviz_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassnviz_pl.po 2012-08-31 10:42:58 UTC (rev 53014)
+++ grass/branches/releasebranch_6_4/locale/po/grassnviz_pl.po 2012-08-31 10:44:41 UTC (rev 53015)
@@ -450,7 +450,7 @@
#: ../visualization/nviz/scripts/panel_fringe.tcl:68
msgid "Elevation of fringe bottom: "
-msgstr ""
+msgstr "Uniesienie obramowania od podłoża:"
#: ../visualization/nviz/scripts/panel_fringe.tcl:69
#: ../visualization/nviz/scripts/panel_scale.tcl:60
@@ -1483,11 +1483,11 @@
#: ../visualization/nviz/scripts/panel_main.tcl:249
msgid "Set field of view size (degrees)"
-msgstr ""
+msgstr "Ustaw pole widzenia (w stopniach)"
#: ../visualization/nviz/scripts/panel_main.tcl:250
msgid "Set twist angle (degrees)"
-msgstr ""
+msgstr "Ustaw kąt skręcenia (w stopniach)"
#: ../visualization/nviz/scripts/panel_main.tcl:253
msgid "reset"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-08-31 10:42:58 UTC (rev 53014)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-08-31 10:44:41 UTC (rev 53015)
@@ -8,7 +8,7 @@
"Project-Id-Version: grasswxpy_pl\n"
-"PO-Revision-Date: 2012-08-30 01:13+0100\n"
+"PO-Revision-Date: 2012-08-30 17:01+0100\n"
"Language: pl\n"
@@ -76,7 +76,7 @@
#: ../gui/wxpython/gui_modules/psmap.py:330
msgid "Preview generated"
-msgstr ""
+msgstr "Podgląd wygenerowany"
#: ../gui/wxpython/gui_modules/psmap.py:358
msgid "Save file as"
@@ -978,7 +978,7 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:2407
msgid "Add new GRASS module to the model"
-msgstr ""
+msgstr "Dodaj nowy moduł GRASS do modelu"
#: ../gui/wxpython/gui_modules/gmodeler.py:2425
#: ../gui/wxpython/gui_modules/gmodeler.py:4204
@@ -1080,9 +1080,8 @@
msgstr "Niewłaściwy:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3339
-#, fuzzy
msgid "Running:"
-msgstr "Uruchomiony"
+msgstr "Uruchomiony:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3359
#: ../gui/wxpython/gui_modules/gmodeler.py:3478
@@ -1132,7 +1131,6 @@
msgstr "Wektor:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3530
-#, fuzzy
msgid "Loop"
msgstr "Pętla"
@@ -6147,9 +6145,8 @@
msgstr "Kopiuj bieżącą komendę do schowka"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:71
-#, fuzzy
msgid "GRASS GIS Manage Ground Control Points"
-msgstr "Zarządzaj Terenowymi Punktami Kontrolnymi (GCP)"
+msgstr "Zarządzanie Terenowymi Punktami Kontrolnymi (GCP)"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:155
msgid "Go to GCP No."
@@ -6172,9 +6169,8 @@
msgstr "Ekran docelowy"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:361
-#, fuzzy
msgid "GCP Display toolbar"
-msgstr "Wyświetl mapę"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:374
msgid "GCP Manager toolbar"
@@ -10343,9 +10339,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:746
-#, fuzzy
msgid "Topographic correction"
-msgstr "Korekcja atmosferyczna"
+msgstr "Korekcja topograficzna"
#: ../gui/wxpython/menustrings.py:747
#, fuzzy
@@ -11454,9 +11449,8 @@
msgid "Source name"
msgstr "Nazwa źródła"
-#, fuzzy
msgid "Close all"
-msgstr "Zamknij okno dialogu"
+msgstr "Zamknij wszystkie"
msgid "Duplicate attributes"
msgstr "Duplikuj atrybuty"
