[GRASS-SVN] r53017 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Fri Aug 31 03:48:33 PDT 2012
Author: neteler
Date: 2012-08-31 03:48:32 -0700 (Fri, 31 Aug 2012)
New Revision: 53017
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
remove duplicate msg
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6610,11 +6610,6 @@
msgid "Must have a weight value for each filter"
msgstr ""
-#: ../raster/r.random.surface/init.c:425
-#, fuzzy, c-format
-msgid "<%s> is an illegal name"
-msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
#, fuzzy, c-format
msgid "Unable to write color table for raster map <%s>"
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6701,11 +6701,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> je neplatné jméno souboru"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6682,11 +6682,6 @@
msgstr "Es muss für jeden Filter einen Gewicht geben."
-#, c-format
-msgstr "<%s> ist ein ungültiger Name."
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6348,11 +6348,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6746,11 +6746,6 @@
msgstr ""
-#, c-format
-msgstr "<%s> es un nombre no admitido"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -7197,11 +7197,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] n'est pas un nom légal"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6756,11 +6756,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "हà¥"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6489,11 +6489,6 @@
msgstr "Deve avere un valore di peso per ogni filtro"
-#, c-format
-msgstr "<%s> è un nome non valido"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6474,11 +6474,6 @@
msgstr "åãã£ã«ã¿ã«å¯¾ãã¦å éå¤ãå«ãã§ããªããã°ãªãã¾ãã"
-#, c-format
-msgstr "<%s> ã¯ä¸æ£ãªãã¡ã¤ã«åã§ã"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6382,11 +6382,6 @@
msgstr ""
-#, c-format
-msgstr ""
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6501,11 +6501,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "izejas lÄ«meÅa nosaukums"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6402,11 +6402,6 @@
msgstr ""
-#, c-format
-msgstr ""
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6887,11 +6887,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] é um nome ilegal"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6797,11 +6797,6 @@
msgstr ""
-#, fuzzy, c-format
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6693,11 +6693,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr ""
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-08-31 10:48:32 UTC (rev 53017)
msgstr ""
-#, fuzzy, c-format
-msgstr "Ime izhodnega rastrskega sloja"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6631,11 +6631,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> à¸à¸·à¹à¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6414,11 +6414,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> uygun olmayan bir addır"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-08-31 10:48:32 UTC (rev 53017)
msgstr ""
-#, fuzzy, c-format
-msgstr "[%s] là tên không hợp lá»"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-08-31 10:44:53 UTC (rev 53016)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-08-31 10:48:32 UTC (rev 53017)
@@ -6652,11 +6652,6 @@
msgstr ""
-#, fuzzy, c-format
-msgstr "<%s> æ¯éæ³çåç§°"
#, fuzzy, c-format
