[GRASS-SVN] r53026 - in grass/trunk/gui/wxpython: core wxplot
svn_grass at osgeo.org
Fri Aug 31 10:14:23 PDT 2012
Author: cmbarton
Date: 2012-08-31 10:14:22 -0700 (Fri, 31 Aug 2012)
New Revision: 53026
grass/trunk/gui/wxpython/core/settings.py
grass/trunk/gui/wxpython/wxplot/base.py
grass/trunk/gui/wxpython/wxplot/dialogs.py
grass/trunk/gui/wxpython/wxplot/histogram.py
grass/trunk/gui/wxpython/wxplot/profile.py
grass/trunk/gui/wxpython/wxplot/scatter.py
Fix for broken plotting modules
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/core/settings.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -535,7 +535,7 @@
'scatter': {
- 'rasters' : {
+ 'raster' : {
'pcolor' : (0, 0, 255, 255),
'pfill' : 'solid',
'psize' : 1,
Modified: grass/trunk/gui/wxpython/wxplot/base.py
--- grass/trunk/gui/wxpython/wxplot/base.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/wxplot/base.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -51,7 +51,7 @@
wx.Frame.__init__(self, parent, id, size = size, style = style, **kwargs)
- self.parent = parent # MapFrame
+ self.parent = parent # MapFrame for a plot type
self.mapwin = self.parent.MapWindow
self.Map = Map() # instance of render.Map to be associated with display
self.rasterList = rasterList #list of rasters to plot
@@ -124,6 +124,8 @@
def InitPlotOpts(self, plottype):
"""!Initialize options for entire plot
+ ## change get more saved values for initialization
self.plottype = plottype # histogram, profile, or scatter
@@ -134,11 +136,17 @@
wx.FONTSTYLE_NORMAL,
wx.FONTWEIGHT_NORMAL)
+ self.properties['raster'] = {}
+ self.properties['raster'] = UserSettings.Get(group = self.plottype, key = 'raster')
+ colstr = str(self.properties['raster']['pcolor'])
+ self.properties['raster']['pcolor'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
if self.plottype == 'profile':
self.properties['marker'] = UserSettings.Get(group = self.plottype, key = 'marker')
# changing color string to tuple for markers/points
colstr = str(self.properties['marker']['color'])
self.properties['marker']['color'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
self.properties['grid'] = UserSettings.Get(group = self.plottype, key = 'grid')
colstr = str(self.properties['grid']['color']) # changing color string to tuple
@@ -176,6 +184,9 @@
rdict = {} # initialize a dictionary
+# self.properties['raster'] = {}
for r in rasterList:
idx = rasterList.index(r)
@@ -185,9 +196,8 @@
continue
# if r.info cannot parse map, skip it
- self.raster[r] = UserSettings.Get(group = plottype, key = 'raster') # some default settings
+ self.raster[r] = self.properties['raster'] # some default settings
rdict[r] = {} # initialize sub-dictionaries for each raster in the list
rdict[r]['units'] = ''
if ret['units'] not in ('(none)', '"none"', '', None):
@@ -197,11 +207,32 @@
rdict[r]['datalist'] = [] # list of cell value,frequency pairs for plotting histogram
rdict[r]['pline'] = None
rdict[r]['datatype'] = ret['datatype']
- rdict[r]['pwidth'] = 1
- rdict[r]['pstyle'] = 'solid'
+## change init with saved values
+ #initialize with saved values
+ if self.properties['raster']['pwidth'] != None:
+ rdict[r]['pwidth'] = self.properties['raster']['pwidth']
+ else:
+ rdict[r]['pwidth'] = 1
+ if self.properties['raster']['pstyle'] != None and \
+ self.properties['raster']['pstyle'] != '':
+ rdict[r]['pstyle'] = self.properties['raster']['pstyle']
+ else:
+ rdict[r]['pstyle'] = 'solid'
if idx <= len(self.colorList):
- rdict[r]['pcolor'] = self.colorDict[self.colorList[idx]]
+ if idx == 0:
+ # use saved color for first plot
+ if self.properties['raster']['pcolor'] != None:
+ rdict[r]['pcolor'] = self.properties['raster']['pcolor']
+ else:
+ rdict[r]['pcolor'] = self.colorDict[self.colorList[idx]]
+ else:
else:
r = randint(0, 255)
b = randint(0, 255)
@@ -216,6 +247,8 @@
if len(rasterList) == 0: return
+## change to init with saved values
for rpair in rasterList:
@@ -243,11 +276,26 @@
rdict[rpair]['plegend'] = rpair[0].split('@')[0] + ' vs ' + rpair[1].split('@')[0]
rdict[rpair]['datalist'] = [] # list of cell value,frequency pairs for plotting histogram
- rdict[rpair]['ptype'] = 'dot'
rdict[rpair][0]['datatype'] = ret0['datatype']
rdict[rpair][1]['datatype'] = ret1['datatype']
- rdict[rpair]['psize'] = 1
- rdict[rpair]['pfill'] = 'solid'
+ if self.properties['raster']['ptype'] != None and \
+ self.properties['raster']['ptype'] != '':
+ rdict[rpair]['ptype'] = self.properties['raster']['ptype']
+ else:
+ rdict[rpair]['ptype'] = 'dot'
+ if self.properties['raster']['psize'] != None:
+ rdict[rpair]['psize'] = self.properties['raster']['psize']
+ else:
+ rdict[rpair]['psize'] = 1
+ if self.properties['raster']['pfill'] != None and \
+ self.properties['raster']['pfill'] != '':
+ rdict[rpair]['pfill'] = self.properties['raster']['pfill']
+ else:
+ rdict[rpair]['pfill'] = 'solid'
rdict[rpair]['pcolor'] = self.colorDict[self.colorList[idx]]
@@ -269,6 +317,8 @@
self.client.SetEnableZoom(self.zoom)
self.client.SetEnableDrag(self.drag)
+## change - changed order so that grid settings go last and axis go first
# axis settings
@@ -295,26 +345,32 @@
self.properties['y-axis']['prop']['max'])
else:
self.properties['y-axis']['axis'] = None
- self.client.SetEnableGrid(self.properties['grid']['enabled'])
- self.client.SetGridColour(wx.Color(self.properties['grid']['color'][0],
- self.properties['grid']['color'][1],
- self.properties['grid']['color'][2],
- 255))
- self.client.SetFontSizeLegend(self.properties['font']['prop']['legendSize'])
- self.client.SetEnableLegend(self.properties['legend']['enabled'])
if self.properties['x-axis']['prop']['log'] == True:
self.properties['x-axis']['axis'] = None
self.client.SetXSpec('min')
if self.properties['y-axis']['prop']['log'] == True:
self.client.SetYSpec('min')
self.client.setLogScale((self.properties['x-axis']['prop']['log'],
self.properties['y-axis']['prop']['log']))
+ # grid settings
+ self.client.SetEnableGrid(self.properties['grid']['enabled'])
+ self.client.SetGridColour(wx.Color(self.properties['grid']['color'][0],
+ self.properties['grid']['color'][1],
+ self.properties['grid']['color'][2],
+ 255))
+ # legend settings
+ self.client.SetFontSizeLegend(self.properties['font']['prop']['legendSize'])
+ self.client.SetEnableLegend(self.properties['legend']['enabled'])
def DrawPlot(self, plotlist):
"""!Draw line and point plot from list plot elements.
@@ -454,7 +510,8 @@
self.ptitle = dlg.ptitle
self.xlabel = dlg.xlabel
self.ylabel = dlg.ylabel
- dlg.UpdateSettings()
+## change these are redundant and can cause problems
+# dlg.UpdateSettings()
self.client.SetFont(self.properties['font']['wxfont'])
self.client.SetFontSizeTitle(self.properties['font']['prop']['titleSize'])
@@ -464,7 +521,8 @@
self.plot.setTitle(dlg.ptitle)
self.plot.setXLabel(dlg.xlabel)
self.plot.setYLabel(dlg.ylabel)
+# dlg.OnSave()
self.OnRedraw(event = None)
def PlotText(self, event):
@@ -474,27 +532,34 @@
plottype = self.plottype,
title = _('Histogram text settings'))
- if dlg.ShowModal() == wx.ID_OK:
- self.OnPlotText(dlg)
+## change to work correctly
- dlg.Destroy()
+ btnval = dlg.ShowModal()
+ if btnval == wx.ID_SAVE or btnval == wx.ID_OK or btnval == wx.ID_CANCEL:
+# self.OnPlotText(dlg)
+ dlg.Destroy()
def PlotOptions(self, event):
"""!Set various profile options, including: line width, color,
style; marker size, color, fill, and style; grid and legend
options. Calls OptDialog class.
dlg = OptDialog(parent = self, id = wx.ID_ANY,
title = _('Plot settings'))
- if btnval == wx.ID_SAVE:
- self.SetGraphStyle()
+## change buttons to be like text options
+# self.SetGraphStyle()
dlg.Destroy()
- elif btnval == wx.ID_CANCEL:
- dlg.Destroy()
def PrintMenu(self, event):
"""!Print options and output menu
Modified: grass/trunk/gui/wxpython/wxplot/dialogs.py
--- grass/trunk/gui/wxpython/wxplot/dialogs.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/wxplot/dialogs.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -110,7 +110,7 @@
wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
self.rasterList = self.parent.rasterList
self.bins = self.parent.bins
self.scattertype = self.parent.scattertype
@@ -487,7 +487,7 @@
class TextDialog(wx.Dialog):
- def __init__(self, parent, id, title, plottype = '',
+ def __init__(self, parent, id, title, plottype = '',
style = wx.DEFAULT_DIALOG_STYLE, **kwargs):
"""!Dialog to set histogram text options: font, title
and font size, axis labels and font size
@@ -514,6 +514,7 @@
'bold' : wx.FONTWEIGHT_BOLD }
+ self.plottype = plottype
self.ptitle = self.parent.ptitle
self.xlabel = self.parent.xlabel
@@ -716,12 +717,12 @@
def OnSave(self, event):
"""!Button 'Save' pressed"""
- self.UpdateSettings()
+ self.OnApply(None)
fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['plot'] = UserSettings.Get(group = 'plot')
- file = UserSettings.SaveToFile(fileSettings)
- self.parent.parent.GetLayerManager().goutput.WriteLog(_('Plot text settings saved to file \'%s\'.') % file)
+ UserSettings.ReadSettingsFile(settings = fileSettings)
+ fileSettings[self.plottype] = UserSettings.Get(group = self.plottype)
+ UserSettings.SaveToFile(fileSettings)
+ self.parent.parent.GetLayerManager().goutput.WriteLog(_('Plot text sizes saved to file \'%s\'.') % UserSettings.filePath)
self.EndModal(wx.ID_OK)
def OnApply(self, event):
@@ -731,7 +732,7 @@
def OnOk(self, event):
"""!Button 'OK' pressed"""
def OnCancel(self, event):
@@ -739,17 +740,19 @@
self.EndModal(wx.ID_CANCEL)
class OptDialog(wx.Dialog):
"""!Dialog to set various options for data plotted, including: line
width, color, style; marker size, color, fill, and style; grid
and legend options.
# init variables
self.linestyledict = parent.linestyledict
self.ptfilldict = parent.ptfilldict
self.pttypelist = ['circle',
@@ -794,8 +797,8 @@
return list
def _do_layout(self):
- """!Do layout"""
- # dialog layout
+ """!Options dialog layout
sizer = wx.BoxSizer(wx.VERTICAL)
box = wx.StaticBox(parent = self, id = wx.ID_ANY,
@@ -1105,43 +1108,78 @@
btnSave = wx.Button(self, wx.ID_SAVE)
btnApply = wx.Button(self, wx.ID_APPLY)
+ btnOk = wx.Button(self, wx.ID_OK)
btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnSave.SetDefault()
+ btnOk.SetDefault()
+# btnSave = wx.Button(self, wx.ID_SAVE)
+# btnApply = wx.Button(self, wx.ID_APPLY)
+# btnCancel = wx.Button(self, wx.ID_CANCEL)
+# btnSave.SetDefault()
# tooltips for buttons
btnApply.SetToolTipString(_("Apply changes for the current session"))
+ btnOk.SetToolTipString(_("Apply changes for the current session and close dialog"))
btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+# btnApply.SetToolTipString(_("Apply changes for the current session"))
+# btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+# btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
# sizers
btnStdSizer = wx.StdDialogButtonSizer()
+ btnStdSizer.AddButton(btnOk)
+ btnStdSizer.AddButton(btnApply)
btnStdSizer.AddButton(btnCancel)
- btnStdSizer.AddButton(btnSave)
- btnStdSizer.AddButton(btnApply)
btnStdSizer.Realize()
- sizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(item = btnSave, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = 5)
+ btnSizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ sizer.Add(item = btnSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+# # sizers
+# btnStdSizer = wx.StdDialogButtonSizer()
+# btnStdSizer.AddButton(btnCancel)
+# btnStdSizer.AddButton(btnSave)
+# btnStdSizer.AddButton(btnApply)
+# btnStdSizer.Realize()
+# sizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
# bindings for buttons and map plot settings controls
self.mapchoice.Bind(wx.EVT_CHOICE, self.OnSetMap)
- if self.plottype != 'scatter':
- color.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
- width.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
- style.Bind(wx.EVT_CHOICE, self.OnSetOpt)
- legend.Bind(wx.EVT_TEXT, self.OnSetOpt)
+## change
+ # Bindings not needed. Will update with OnApply
+# if self.plottype != 'scatter':
+# color.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
+# width.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
+# style.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+# legend.Bind(wx.EVT_TEXT, self.OnSetOpt)
- if self.plottype != 'histogram':
- ptcolor.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
- ptsize.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
- ptfill.Bind(wx.EVT_CHOICE, self.OnSetOpt)
- ptlegend.Bind(wx.EVT_TEXT, self.OnSetOpt)
- pttype.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+# if self.plottype != 'histogram':
+# ptcolor.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
+# ptsize.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
+# ptfill.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+# ptlegend.Bind(wx.EVT_TEXT, self.OnSetOpt)
+# pttype.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+# btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+# btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+# btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+ # bindings
+ btnOk.Bind(wx.EVT_BUTTON, self.OnOk)
@@ -1175,25 +1213,36 @@
self.map = self.rasterList[self.mapchoice.GetCurrentSelection()]
self.parent.SetGraphStyle()
- if self.parent.plot:
- p = self.parent.CreatePlotList()
- self.parent.DrawPlot(p)
+ p = self.parent.CreatePlotList()
+ self.parent.DrawPlot(p)
+## change if clause not relevant
+# if self.parent.plot:
+# p = self.parent.CreatePlotList()
+# self.parent.DrawPlot(p)
def UpdateSettings(self):
"""!Apply settings to each map and to entire plot"""
+## change updating properties for pcolor, pwidth, pstyle, psize, ptype, pfill
# update plot settings for selected map
self.raster[self.map]['pcolor'] = self.FindWindowById(self.wxId['pcolor']).GetColour()
+ self.properties['raster']['pcolor'] = self.raster[self.map]['pcolor']
self.raster[self.map]['plegend'] = self.FindWindowById(self.wxId['plegend']).GetValue()
self.raster[self.map]['pwidth'] = int(self.FindWindowById(self.wxId['pwidth']).GetValue())
+ self.properties['raster']['pwidth'] = self.raster[self.map]['pwidth']
self.raster[self.map]['pstyle'] = self.FindWindowById(self.wxId['pstyle']).GetStringSelection()
+ self.properties['raster']['pstyle'] = self.raster[self.map]['pstyle']
elif self.plottype == 'scatter':
self.raster[self.map]['psize'] = self.FindWindowById(self.wxId['psize']).GetValue()
+ self.properties['raster']['psize'] = self.raster[self.map]['psize']
self.raster[self.map]['ptype'] = self.FindWindowById(self.wxId['ptype']).GetValue()
+ self.properties['raster']['ptype'] = self.raster[self.map]['ptype']
self.raster[self.map]['pfill'] = self.FindWindowById(self.wxId['pfill']).GetValue()
+ self.properties['raster']['pfill'] = self.raster[self.map]['pfill']
# update settings for entire plot
for axis in ('x-axis', 'y-axis'):
@@ -1212,6 +1261,8 @@
self.properties['grid']['color'] = self.FindWindowById(self.wxId['grid']['color']).GetColour()
self.properties['grid']['enabled'] = self.FindWindowById(self.wxId['grid']['enabled']).IsChecked()
+ # this makes more sense in the text properties, including for settings update. But will need to change
+ # layout for controls to text dialog too.
self.properties['font']['prop']['legendSize'] = self.FindWindowById(self.wxId['font']['legendSize']).GetValue()
self.properties['legend']['enabled'] = self.FindWindowById(self.wxId['legend']['enabled']).IsChecked()
@@ -1221,17 +1272,26 @@
fileSettings = {}
- self.parent.parent.GetLayerManager().goutput.WriteLog(_('Plot settings saved to file \'%s\'.') % file)
+ self.parent.parent.GetLayerManager().goutput.WriteLog(_('Plot settings saved to file \'%s\'.') % UserSettings.filePath)
self.Close()
"""!Button 'Apply' pressed. Does not close dialog"""
+##change
+ def OnOk(self, event):
+ """!Button 'OK' pressed"""
+ self.EndModal(wx.ID_OK)
"""!Button 'Cancel' pressed"""
Modified: grass/trunk/gui/wxpython/wxplot/histogram.py
--- grass/trunk/gui/wxpython/wxplot/histogram.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/wxplot/histogram.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -55,11 +55,13 @@
"aqua", "black", "grey", "orange", "brown", "purple", "violet", \
"indigo"]
+ self._initOpts()
if len(self.rasterList) > 0: # set raster name(s) from layer manager if a map is selected
self.InitRasterOpts(self.rasterList, self.plottype)
+ else:
+ self.raster = {}
- self._initOpts()
def _initOpts(self):
"""!Initialize plot options
Modified: grass/trunk/gui/wxpython/wxplot/profile.py
--- grass/trunk/gui/wxpython/wxplot/profile.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/wxplot/profile.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -66,13 +66,13 @@
"indigo"]
+ self._initOpts()
self.raster = self.InitRasterOpts(self.rasterList, self.plottype)
else:
self.raster = {}
- self._initOpts()
# determine units (axis labels)
if self.parent.Map.projinfo['units'] != '':
self.xlabel = _('Distance (%s)') % self.parent.Map.projinfo['units']
Modified: grass/trunk/gui/wxpython/wxplot/scatter.py
--- grass/trunk/gui/wxpython/wxplot/scatter.py 2012-08-31 16:56:02 UTC (rev 53025)
+++ grass/trunk/gui/wxpython/wxplot/scatter.py 2012-08-31 17:14:22 UTC (rev 53026)
@@ -54,11 +54,13 @@
"aqua", "grey", "orange", "brown", "purple", "violet", \
"indigo"]
+ self._initOpts()
if len(self.rasterList) > 1: # set raster name(s) from layer manager if a map is selected
self.InitRasterOpts(self.rasterList, 'scatter')
+ else:
+ self.raster = {}
- self._initOpts()
