[GRASS-SVN] r53027 - grass/trunk/gui/wxpython/wxplot
Fri Aug 31 10:24:43 PDT 2012
Author: cmbarton
Date: 2012-08-31 10:24:43 -0700 (Fri, 31 Aug 2012)
New Revision: 53027
   grass/trunk/gui/wxpython/wxplot/base.py
   grass/trunk/gui/wxpython/wxplot/dialogs.py
Fixes for plotting modules
Modified: grass/trunk/gui/wxpython/wxplot/base.py
--- grass/trunk/gui/wxpython/wxplot/base.py	2012-08-31 17:14:22 UTC (rev 53026)
+++ grass/trunk/gui/wxpython/wxplot/base.py	2012-08-31 17:24:43 UTC (rev 53027)
@@ -123,10 +123,7 @@
     def InitPlotOpts(self, plottype):
         """!Initialize options for entire plot
- ## change get more saved values for initialization
         self.plottype = plottype                # histogram, profile, or scatter
         self.properties = {}                    # plot properties
@@ -183,8 +180,6 @@
         rdict = {} # initialize a dictionary
-#        self.properties['raster'] = {}
         self.properties['raster'] = UserSettings.Get(group = self.plottype, key = 'raster')
         for r in rasterList:
@@ -208,8 +203,6 @@
             rdict[r]['pline'] = None
             rdict[r]['datatype'] = ret['datatype']
-## change init with saved values
             #initialize with saved values
@@ -248,8 +241,6 @@
         if len(rasterList) == 0: return
-## change to init with saved values
         for rpair in rasterList:
             idx = rasterList.index(rpair)
@@ -317,8 +308,6 @@
         self.client.SetEnableZoom(self.zoom)
         self.client.SetEnableDrag(self.drag)
-## change - changed order so that grid settings go last and axis go first
         # axis settings
@@ -510,8 +499,6 @@
         self.ptitle = dlg.ptitle
         self.xlabel = dlg.xlabel
         self.ylabel = dlg.ylabel
-## change these are redundant and can cause problems
-#        dlg.UpdateSettings()
         self.client.SetFont(self.properties['font']['wxfont'])
         self.client.SetFontSizeTitle(self.properties['font']['prop']['titleSize'])
@@ -522,7 +509,6 @@
             self.plot.setXLabel(dlg.xlabel)
             self.plot.setYLabel(dlg.ylabel)
-#        dlg.OnSave()
         self.OnRedraw(event = None)
     def PlotText(self, event):
@@ -532,11 +518,8 @@
                                  plottype = self.plottype,
                                  title = _('Histogram text settings'))
-## change to work correctly
         btnval = dlg.ShowModal()
         if btnval == wx.ID_SAVE or btnval == wx.ID_OK or btnval == wx.ID_CANCEL:
-#            self.OnPlotText(dlg)
             dlg.Destroy()
@@ -551,14 +534,7 @@
                         title = _('Plot settings'))
-## change buttons to be like text options
-#            self.SetGraphStyle()
             dlg.Destroy()
     def PrintMenu(self, event):
Modified: grass/trunk/gui/wxpython/wxplot/dialogs.py
--- grass/trunk/gui/wxpython/wxplot/dialogs.py	2012-08-31 17:14:22 UTC (rev 53026)
+++ grass/trunk/gui/wxpython/wxplot/dialogs.py	2012-08-31 17:24:43 UTC (rev 53027)
@@ -381,7 +381,6 @@
         # Nsteps for FP maps and histogram type selection
         label = wx.StaticText(parent = self, id = wx.ID_ANY,
                               label = _("Number of bins (for FP maps)"))
         box.Add(item = label,
@@ -1112,24 +1111,12 @@
         btnCancel = wx.Button(self, wx.ID_CANCEL)
         btnOk.SetDefault()
-#        btnSave = wx.Button(self, wx.ID_SAVE)
-#        btnApply = wx.Button(self, wx.ID_APPLY)
-#        btnCancel = wx.Button(self, wx.ID_CANCEL)
-#        btnSave.SetDefault()
         # tooltips for buttons
         btnApply.SetToolTipString(_("Apply changes for the current session"))
         btnOk.SetToolTipString(_("Apply changes for the current session and close dialog"))
         btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
         btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
-#        btnApply.SetToolTipString(_("Apply changes for the current session"))
-#        btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
-#        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
         # sizers
         btnStdSizer = wx.StdDialogButtonSizer()
         btnStdSizer.AddButton(btnOk)
@@ -1142,41 +1129,10 @@
         btnSizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
         sizer.Add(item = btnSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
-#        # sizers
-#        btnStdSizer = wx.StdDialogButtonSizer()
-#        btnStdSizer.AddButton(btnCancel)
-#        btnStdSizer.AddButton(btnSave)
-#        btnStdSizer.AddButton(btnApply)
-#        btnStdSizer.Realize()
-#        sizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
         # bindings for buttons and map plot settings controls
         self.mapchoice.Bind(wx.EVT_CHOICE, self.OnSetMap)
-## change
-        # Bindings not needed. Will update with OnApply
-#        if self.plottype != 'scatter':
-#            color.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
-#            width.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
-#            style.Bind(wx.EVT_CHOICE, self.OnSetOpt)
-#            legend.Bind(wx.EVT_TEXT, self.OnSetOpt)
-#        if self.plottype != 'histogram':
-#            ptcolor.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
-#            ptsize.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
-#            ptfill.Bind(wx.EVT_CHOICE, self.OnSetOpt)
-#            ptlegend.Bind(wx.EVT_TEXT, self.OnSetOpt)
-#            pttype.Bind(wx.EVT_CHOICE, self.OnSetOpt)
-#        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
-#        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
-#        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
-        # bindings
         btnOk.Bind(wx.EVT_BUTTON, self.OnOk)
         btnOk.SetDefault()
@@ -1216,15 +1172,8 @@
         p = self.parent.CreatePlotList()
         self.parent.DrawPlot(p)
-## change if clause not relevant
-#        if self.parent.plot:
-#            p = self.parent.CreatePlotList()
-#            self.parent.DrawPlot(p)
     def UpdateSettings(self):
         """!Apply settings to each map and to entire plot"""
-## change updating properties for pcolor, pwidth, pstyle, psize, ptype, pfill
-        # update plot settings for selected map
         self.raster[self.map]['pcolor'] = self.FindWindowById(self.wxId['pcolor']).GetColour()
         self.properties['raster']['pcolor'] = self.raster[self.map]['pcolor']
@@ -1282,12 +1231,7 @@
         self.parent.SetGraphStyle()
-##change
     def OnOk(self, event):
         """!Button 'OK' pressed"""
         self.OnApply(None)
