[GRASS-SVN] r54123 - grass-addons/grass6/raster/mcda/r.to.drsa
Sat Dec 1 09:10:09 PST 2012
Author: gianluca
Date: 2012-12-01 09:10:08 -0800 (Sat, 01 Dec 2012)
New Revision: 54123
Removed:
   grass-addons/grass6/raster/mcda/r.to.drsa/Makefile
   grass-addons/grass6/raster/mcda/r.to.drsa/description.html
   grass-addons/grass6/raster/mcda/r.to.drsa/r.to.drsa.py
Deleted: grass-addons/grass6/raster/mcda/r.to.drsa/Makefile
--- grass-addons/grass6/raster/mcda/r.to.drsa/Makefile	2012-12-01 17:09:48 UTC (rev 54122)
+++ grass-addons/grass6/raster/mcda/r.to.drsa/Makefile	2012-12-01 17:10:08 UTC (rev 54123)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = r.to.drsa
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Deleted: grass-addons/grass6/raster/mcda/r.to.drsa/description.html
--- grass-addons/grass6/raster/mcda/r.to.drsa/description.html	2012-12-01 17:09:48 UTC (rev 54122)
+++ grass-addons/grass6/raster/mcda/r.to.drsa/description.html	2012-12-01 17:10:08 UTC (rev 54123)
@@ -1,35 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>r.ro.drsa</em> module will export raster maps as a *isf file
-readable in jMAF, JAMM or 4eMka2 sofware <a href="http://idss.cs.put.poznan.pl/">Laboratory of Intelligent Decision Support Systems - Poznan University.</a>
-<p>
-<em>(GRASS python Script)</em>
-<h2>NOTES</h2>
-<p>
-This module, as all GRASS raster modules, will export cells based on the
-current region settings. See the <em>g.region</em> module for details.
-<h2>TODO</h2>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.roughset.html">r.roughset</a>,
-<a href="r.mcda.regime.html">r.mcda.regime</a>,
-<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
-<a href="r.mcda.electre.html">r.mcda.electre</a>,
-<a href="r.in.drsa.html">r.in.drsa</a>
-</em>
-<h2>AUTHORS</h2>
-Antonio Boggia - Gianluca Massei<br>
-Department of Economics and Appraisal - University of Perugia - Italy
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/mcda/r.to.drsa/r.to.drsa.py
--- grass-addons/grass6/raster/mcda/r.to.drsa/r.to.drsa.py	2012-12-01 17:09:48 UTC (rev 54122)
+++ grass-addons/grass6/raster/mcda/r.to.drsa/r.to.drsa.py	2012-12-01 17:10:08 UTC (rev 54123)
@@ -1,127 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       r.to.drsa
-# AUTHOR:       Gianluca Massei - Antonio Boggia
-# PURPOSE:      Export criteria raster maps and decision raster map in a *.isf
-#               file for dominance rough set approach analysis (DRSA)
-#               Dominance Rough Set Analysis (e.g. 4eMka2,JAMM, jMAF).
-# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#               Development Team. This program is free software under the
-#               GNU General PublicLicense (>=v2). Read the file COPYING
-#               that comes with GRASS for details.
-#%Module
-#% description: Export criteria raster maps and decision raster map in a *.isf file (e.g. 4eMka2, jMAF) for dominance rough set approach analysis
-#% keywords: raster, Dominance Rough Set Approach
-#% keywords: Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: attributes
-#% type: string
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: preferences
-#% type: string
-#% key_desc: character
-#% description: gain,cost,none
-#% required: yes
-#%end
-#%option
-#% key: decision
-#% type: string
-#% key_desc: name
-#% description: Name of decision raster map
-#% required: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% description: Name for output file (*.isf file, Information System)
-#% answer:infosys.isf
-#% required: yes
-#%end
-import sys
-##from grass.script import core as grass
-import grass.script as grass
-def main():
-    attributes = options['attributes'].split(',')
-    preferences=options['preferences'].split(',')
-    decision=options['decision']
-    output = options['output']
-    gregion = grass.region()
-    nrows = gregion['rows']
-    ncols = gregion['cols']
-    ewres=int(gregion['ewres'])
-    nsres=int(gregion['nsres'])
-    print nrows, ncols, ewres,nsres
-    outf = file(output,"w")
-    outf.write("**ATTRIBUTES\n")
-    for i in range(len(attributes)):
-        outf.write("+ %s: (continuous)\n" % attributes[i])
-    outf.write("+ %s: [" % decision)
-    value=[]
-    value=grass.read_command("r.describe", flags = "1n", map = decision)
-    v=value.split()
-    for i in range(len(v)-1):
-        outf.write("%s, " % str(v[i]))
-    outf.write("%s]\n" % str(v[len(v)-1]))
-    outf.write("decision: %s\n" % decision)
-    outf.write("\n**PREFERENCES\n")
-        if(preferences[i]==""):
-            preferences[i]="none"
-        outf.write("%s: %s\n" % (attributes[i], preferences[i]))
-    outf.write("%s: gain\n" % decision)
-    outf.write("\n**EXAMPLES\n")
-    examples=[]
-    MATRIX=[]
-        grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
-                         rast="rast",
-                         decision=decision,
-                         attribute=attributes[i])
-        tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
-        example=tmp.split()
-        examples.append(example)
-    tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
-    MATRIX=map(list,zip(*examples))
-    MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
-    MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
-    print "rows:%d - col:%d" %(len(MATRIX),len(MATRIX[0]))
-    for r in range(len(MATRIX)):
-        for c in range(len(MATRIX[0])):
-            outf.write("%s " %  str(MATRIX[r][c]))
-        outf.write("\n")
-    outf.write("**END")
-    outf.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
