[GRASS-SVN] r54124 - grass-addons/grass6/raster/mcda/r.roughset
Sat Dec 1 09:11:28 PST 2012
Author: gianluca
Date: 2012-12-01 09:11:28 -0800 (Sat, 01 Dec 2012)
New Revision: 54124
Removed:
   grass-addons/grass6/raster/mcda/r.roughset/Makefile
   grass-addons/grass6/raster/mcda/r.roughset/description.html
   grass-addons/grass6/raster/mcda/r.roughset/localproto.h
   grass-addons/grass6/raster/mcda/r.roughset/main.c
   grass-addons/grass6/raster/mcda/r.roughset/raccess.c
   grass-addons/grass6/raster/mcda/r.roughset/raccess.h
   grass-addons/grass6/raster/mcda/r.roughset/rbasic.c
   grass-addons/grass6/raster/mcda/r.roughset/rbasic.h
   grass-addons/grass6/raster/mcda/r.roughset/rclass.c
   grass-addons/grass6/raster/mcda/r.roughset/rclass.h
   grass-addons/grass6/raster/mcda/r.roughset/rcore.c
   grass-addons/grass6/raster/mcda/r.roughset/rcore.h
   grass-addons/grass6/raster/mcda/r.roughset/reduct1.c
   grass-addons/grass6/raster/mcda/r.roughset/reduct1.h
   grass-addons/grass6/raster/mcda/r.roughset/reduct2.c
   grass-addons/grass6/raster/mcda/r.roughset/reduct2.h
   grass-addons/grass6/raster/mcda/r.roughset/rerror.h
   grass-addons/grass6/raster/mcda/r.roughset/rough.h
   grass-addons/grass6/raster/mcda/r.roughset/rset.c
   grass-addons/grass6/raster/mcda/r.roughset/rset.h
   grass-addons/grass6/raster/mcda/r.roughset/rsystem.c
   grass-addons/grass6/raster/mcda/r.roughset/rsystem.h
   grass-addons/grass6/raster/mcda/r.roughset/rule1.c
   grass-addons/grass6/raster/mcda/r.roughset/rule1.h
   grass-addons/grass6/raster/mcda/r.roughset/rule2.c
   grass-addons/grass6/raster/mcda/r.roughset/rule2.h
   grass-addons/grass6/raster/mcda/r.roughset/rules_extr.c
Deleted: grass-addons/grass6/raster/mcda/r.roughset/Makefile
--- grass-addons/grass6/raster/mcda/r.roughset/Makefile	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/Makefile	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,10 +0,0 @@
-MODULE_TOPDIR = ../../..
-PGM = r.roughset
-LIBES= $(GISLIB) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP)
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
Deleted: grass-addons/grass6/raster/mcda/r.roughset/description.html
--- grass-addons/grass6/raster/mcda/r.roughset/description.html	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/description.html	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,68 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.roughset</em> is the implementation of the rough set theory [1,2] in GRASS GIS environment. It requires the following input:
-<br>1. the geographical attributes constituting the information system for the rough set analysis; they have to describe environmental, economic or social issues(<b>attributes</b>=<em>string[,string,...]</em>);<br> 2.the theme in which areas with the issues to be studied are identified (<b>decision</b>=<em>string</em>).
-<p>An information system is generated and the functions of version 2 of rough set library (RSL, ver. 2.0) [3] are applied, following one of the decision strategies available with the option<b>strgy</b>=<em>string.</em></P>
-<p><em>The choice of the classification strategy, </em><em><b>clssfy</b></em><em>=string
-</em><em> is necessary to generate a map based on the attributes and the decision rules. Three options are available:</em><em><I>Classify1,Classify2,Classify3</I></em><em> </em><em>each of them is referred to a different algorithm. [3]. </em><br><br>It is possible to get three different output files; two of them are text files, the third is a raster file: </P>
-<p>a. <I>text file</I> structured following the standard of the rough set library, having the name registered in the  <b>outTXT</b><I><SPAN STYLE="font-weight: normal">=string</I> without any additional extension. The file can be used as well with RSL implementation out of GIS environment.</P>
-<p><I>NAME:  name of the information system </I></P>
-<p><I>ATTRIBUTES: 4 (number of attributes) </I></P>
-<p><I>OBJECTS: 8 (number of objects)</I></P>
-<p><I>0 0 0 0 </I>
-</P>
-<p><I>1 0 1 1</I></P>
-<p><I>1 1 0 0 </I>
-</P>
-<p><I>0 2 0 1 </I>
-</P>
-<p><I>1 2 0 1 </I>
-</P>
-<p><I>1 0 0 0 </I>
-</P>
-<p><I>1 2 0 1 </I>
-</P>
-<p><I>0 0 1 1 </I>
-</P>
-<p>The number of attributes is the number of raster given as input at <b>attributes</b>=<em>string[,string,...]
-</em><em> plus the decision raster </em><em>(</em><em><b>decision</b></em><em>=string) </em><em>located in the last column of the information system, by default. </em></P>
-<p>b. <I>text file</I>, having the name defined in  <b>outTXT</b><I><SPAN STYLE="font-weight: normal">=string</I>
-and the .<I>out</I>, extension. It contains the decision rules extracted from the geographic information system; decision rules are expressed as:
- <I>if ... then </I> and they are easy to read and to be interpreted by the user; <br>c. <I>raster, </I>having the name defined in the field  <b>outMAP</b><I>=string,
-</I> resulting from the application of the decision rules generated by the geographic information system following one of the classification strategies in  <em><b>clssfy</b></em><em>=string.
-</em><em> Rules to apply can derive from an information system generated from the data entered in </em><em><b>attributes</b></em><em>=</em><em>string
-</em><em>and</em><em>
-</em><em><b>decision</b></em><em>=string
-</em><em>or from a text file generated from a previous processing stage. In this case the file structure must be as the one reported in box 1. </em></P>
-<h2>NOTES</h2>
-<p>The module can process CELL raster, and calculations can be made only with integer (int) variables. This is a constraint imposed by the rough set library. The decision rules, therefore, provide only integer information. </P>
-<h2>REFERENCE</h2>
-<ol>
-	<li><p>Pawlak Z. Rough Sets, International Journal of
-	Information and Computer Science Vol. 11, No. 5, 1982, pp.
-	344-356.</P>
-	<li><p>Pawlak Z. Rough Sets, Theoretical Aspects of
-	Reasoning about Data, Kluwer Academic Publishers, 1991.</P>
-	<li><p>Gawrys M., Sienkiewicz J. Rough Set
-	Library - User's manual (ver. 2.0), September 1993</P>
-	<li><p><a href="http://en.wikipedia.org/wiki/Rough_set">http://en.wikipedia.org/wiki/Rough_set</a>
-	- “rough set”</P>
-	<p>
-	</P>
-</ol>
-<h2>SEE ALSO</h2>
-<p><em>r.mcda.fuzzy, r.mcda.electre, r.mcda.regime</em></P>
-<h2>AUTHORS</h2>
-Antonio Boggia - Gianluca Massei<br>
-Department of Economics and Appraisal - University of Perugia - Italy
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/mcda/r.roughset/localproto.h
--- grass-addons/grass6/raster/mcda/r.roughset/localproto.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/localproto.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,15 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <stddef.h>
-#include <time.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-struct input
-    char *name, *mapset;
-    int fd;
-    CELL *buf;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/main.c
--- grass-addons/grass6/raster/mcda/r.roughset/main.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/main.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,276 +0,0 @@
- * MODULE:       r.roughset
- * AUTHOR(S):    GRASS module authors ad Rough Set Library (RSL) maintain:
- *		 		G.Massei (g_massa at libero.it)-A.Boggia (boggia at unipg.it)
- *		 		Rough Set Library (RSL) ver. 2 original develop:
- *		 		M.Gawrys - J.Sienkiewicz
- * PURPOSE:      Geographics rough set analisys and knowledge discovery
- * COPYRIGHT:    (C) A.Boggia - G.Massei (2008)
- *               This program is free software under the GNU General Public
- *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 for details.
-#include "localproto.h"
-int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/* it stores region information, and header of rasters */
-    char *mapset;		/* mapset name */
-    int i, j;			/* index and  files number */
-    int row, col, nrows, ncols;
-    int nattributes;		/*attributes numer */
-    int strgy, cls;		/* strategy rules extraction and classifiy index */
-    char *result;		/* output raster name */
-    int *classify_vect;		/* matrix for classified value storage */
-    int outfd;			/* output file descriptor */
-    unsigned char *outrast;	/* output buffer */
-    RASTER_MAP_TYPE data_type;	/* type of the map (CELL/DCELL/...) */
-    /*int value, decvalue; *//*single attribute and decision value */
-    struct input *attributes;
-    struct History history;	/* holds meta-data (title, comments,..) */
-    struct GModule *module;	/* GRASS module for parsing arguments */
-    struct Option *attr_map, *dec_map, *dec_txt, *genrules, *clssfy, *output_txt, *output_map;	/* options */
-    /*struct Flag *flagQuiet            flags */
-    /* initialize GIS environment */
-    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
-    /* initialize module */
-    module = G_define_module();
-    module->keywords = _("raster,geographics knowledge discovery");
-    module->description = _("Rough set based geographics knowledge ");
-    /* Define the different options as defined in gis.h */
-    attr_map = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    attr_map->key = "attributes";
-    attr_map->type = TYPE_STRING;
-    attr_map->required = YES;
-    attr_map->multiple = YES;
-    attr_map->gisprompt = "old,cell,raster";
-    attr_map->description =
-        _("Input geographics ATTRIBUTES in information system");
-    dec_map = G_define_option();
-    dec_map->key = "decision";
-    dec_map->type = TYPE_STRING;
-    dec_map->required = NO;
-    dec_map->gisprompt = "old,cell,raster";
-    dec_map->description =
-        _("Input geographics DECISION in information system");
-    genrules = G_define_option();
-    genrules->key = "strgy";
-    genrules->type = TYPE_STRING;
-    genrules->required = YES;
-    genrules->options = "Very fast,Fast,Medium,Best,All,Low,Upp,Normal";
-    genrules->answer = "Very fast";
-    genrules->description = _("Strategies for generating rules");
-    dec_txt = G_define_option();
-    dec_txt->key = "sample";
-    dec_txt->type = TYPE_STRING;
-    dec_txt->required = NO;
-    dec_txt->gisprompt = "old_file,file,input";
-    dec_txt->description =
-        _("Input text file  with  data and decision sample");
-    clssfy = G_define_option();
-    clssfy->key = "clssfy";
-    clssfy->type = TYPE_STRING;
-    clssfy->required = YES;
-    clssfy->options = "Classify1,Classify2,Classify3";
-    clssfy->answer = "Classify1";
-    clssfy->description =
-        _("Strategies for classified map (conflict resolution)");
-    output_txt = G_define_option();
-    output_txt->key = "outTXT";
-    output_txt->type = TYPE_STRING;
-    output_txt->required = YES;
-    // output_txt->gisprompt = "new_file,file,output";
-    output_txt->answer = "InfoSys";
-    output_txt->description = _("Output information system file");
-    output_map = G_define_option();
-    output_map->key = "outMAP";
-    output_map->type = TYPE_STRING;
-    output_map->required = YES;
-    output_map->answer = "classify";
-    output_map->description = _("Output classified map");
-    /* options and flags parser */
-    if (G_parser(argc, argv))
-        exit(EXIT_FAILURE);
-    /* Either decision map or sample file are necesary */
-    if (dec_map->answer == NULL && dec_txt->answer == NULL)
-        G_fatal_error(_("Either decision map or sample file are necessary!"));
-    /********Prepare and controlling Information System files **************/
-    /* number of file (=attributes) */
-    nattributes = 0;
-    while (attr_map->answers[nattributes] != NULL)
-        nattributes++;
-    /* store output classified MAP name in variable */
-    result = output_map->answer;
-    /*Convert strategy rules extraction answer in index.  strcmp return 0 if answer is the passed string */
-    if (strcmp(genrules->answer, "Very fast") == 0)
-        strgy = 0;
-    else if (strcmp(genrules->answer, "Fast") == 0)
-        strgy = 1;
-    else if (strcmp(genrules->answer, "Medium") == 0)
-        strgy = 2;
-    else if (strcmp(genrules->answer, "Best") == 0)
-        strgy = 3;
-    else if (strcmp(genrules->answer, "All") == 0)
-        strgy = 4;
-    else if (strcmp(genrules->answer, "Low") == 0)
-        strgy = 5;
-    else if (strcmp(genrules->answer, "Upp") == 0)
-        strgy = 6;
-    else
-        strgy = 7;
-    /*Convert strategy map lassify answer in index.  strcmp return 0 if answer is the passed string */
-    if (strcmp(clssfy->answer, "Classify1") == 0)
-        cls = 0;
-    else if (strcmp(clssfy->answer, "Classify2") == 0)
-        cls = 1;
-    else if (strcmp(clssfy->answer, "Classify3") == 0)
-        cls = 2;
-    else
-        cls = 0;
-    /* process the input maps: */
-    /* ATTRIBUTES grid */
-    attributes = G_malloc((nattributes + 1) * sizeof(struct input));	/*attributes is input struct defined in localproto.h */
-    for (i = 0; i < nattributes; i++)
-        struct input *p = &attributes[i];
-        p->name = attr_map->answers[i];
-        p->mapset = G_find_cell(p->name, "");	/* G_find_cell: Looks for the raster map "name" in the database. */
-        p->fd = G_open_cell_old(p->name, p->mapset);
-        if (!p->mapset)
-            G_fatal_error(_("Raster file <%s> not found"), p->name);
-        if (p->fd < 0)
-            G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),
-                          p->name, p->mapset);
-        if (CELL_TYPE != G_raster_map_type(p->name, p->mapset))
-            G_fatal_error(_("Input map <%s> in mapset <%s> isn't CELL type"),
-        p->buf = G_allocate_c_raster_buf();	/* Allocate an array of CELL based on the number of columns in the current region. Return DCELL *  */
-    /* define the inputmap DECISION type (CELL) */
-    data_type = CELL_TYPE;	//
-    /* Allocate output buffer, use input map data_type */
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    outrast = G_allocate_raster_buf(data_type);
-    /* DECISION grid (at last column in Information System matrix) */
-    if (dec_map->answer != NULL)
-        struct input *p = &attributes[nattributes];
-        p->name = dec_map->answer;
-        if (!p->mapset)
-        p->fd = G_open_cell_old(p->name, p->mapset);	/*opens the raster file name in mapset for reading. A nonnegative file descriptor is returned if the open is successful. */
-        if (p->fd < 0)
-        p->buf = G_allocate_raster_buf(data_type);	/* Allocate an array of DCELL based on the number of columns in the current region.
-							   Return DCELL *  */
-        rough_set_library_out(nrows, ncols, nattributes, attributes, output_txt->answer);	/*build RSL standard file */
-    classify_vect = G_malloc(sizeof(int) * (nrows * ncols));	/* memory allocation */
-    rough_analysis(nrows, ncols, output_txt->answer, classify_vect, attributes, dec_txt->answer, strgy, cls);	/* extract rules from RSL and generate classified vector */
-    /* controlling, if we can write the raster */
-    if ((outfd = G_open_raster_new(result, CELL_TYPE)) < 0)
-        G_fatal_error(_("Unable to create raster map <%s>"), result);
-    /* generate classified map */
-    G_message("Building calssified map...");
-    j = 0;			/* builder map index */
-    for (row = 0; row < nrows; row++)
-        CELL c;
-        G_percent(row, nrows, 2);
-        for (col = 0; col < ncols; col++)
-            c = ((CELL *) classify_vect[j]);
-            ((CELL *) outrast)[col] = c;
-	    G_message("%d", c);
-            j++;
-        if (G_put_raster_row(outfd, outrast, data_type) < 0)
-            G_fatal_error(_("Failed writing raster map <%s>"), result);
-    /* memory cleanup */
-    for (i = 0; i <= nattributes; i++)
-        G_close_cell(attributes[i].fd);
-    G_close_cell(outfd);
-        G_free(attributes[i].buf);
-    //G_free(outrast);
-    G_message("End: %s, with %d cells.", G_date(), j);
-    /* add command line incantation to history file */
-    G_short_history(result, "raster", &history);
-    G_command_history(&history);
-    G_write_history(result, &history);
-    exit(EXIT_SUCCESS);
-/* dom 07 dic 2008 07:05:15 CET */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/raccess.c
--- grass-addons/grass6/raster/mcda/r.roughset/raccess.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/raccess.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,232 +0,0 @@
- *   	    	 for details.
-            FUNCTION OF ACCESS TO SYSTEM TABLES
- part of the ROUGH system written by M.Gawrys J. Sienkiewicz
-#include "rough.h"
-setA _table_element = NULL;
-setA _table_end = NULL;
-int _table_row;
-int _table_column;
-int _table_no;
-static void (*_current_next) (void);
-void next_of_d(void)
-    if (++_table_column >= _table_row)
-        _table_column = 0, _table_row++;
-    _table_element = (_mainsys->matD) + (_mainsys->setAsize * ++_table_no);
-void next_of_x(void)
-    _table_element += _mainsys->setAsize;
-    ++_table_no;
-void next_of_a(void)
-    ++_table_no;
-        _table_column = 0;
-        if (++_table_row >= _mainsys->objects_num)
-            CloseSetA(_table_element);
-            _table_end = _table_element;
-            _table_row = 0;
-            return;
-    GetDfromA(_table_element, _table_row, _table_column);
-    return;
-int start_of_tab(int matrix_type)
-    if (matrix_type == MATD)
-        _table_no = 0;
-        _table_row = 1;
-        _table_element = _mainsys->matD;
-        _table_end = _table_element + Dsize(_mainsys);
-        _current_next = next_of_d;
-    else if (matrix_type == MATX)
-        START_OF_X;
-        _table_no = 0;
-        _current_next = next_of_x;
-    else if (matrix_type == MATA)
-        _table_no = 0;
-        _table_row = 0;
-        _table_element = InitEmptySetA();
-        _table_end = _table_element + 1;
-        _current_next = next_of_a;
-        next_of_a();
-    if (_table_element == NULL)
-        ERROR(3)
-        return (1);
-int end_of_tab(void)
-    return (_table_element < _table_end);
-void next_of_tab(void)
-    (*_current_next) ();
-setA GetD(int ob1, int ob2)
-    int pom;
-    if (ob2 > ob1)
-        pom = ob1;
-        ob1 = ob2;
-        ob2 = pom;
-    return (_mainsys->matD) + ((ob1 - 1) * ob1 / 2 +
-                               ob2) * _mainsys->setAsize;
-value_type GetA(int ob, int atr)
-    return (_mainsys->matA)[ob * (_mainsys->attributes_num) + atr];
-int GetDfromA(setA elem, int obj1, int obj2)
-    int nby = (_mainsys->attributes_num) / _cluster_bits;	/* number of full clusters in element */
-    int nbi = _mainsys->attributes_num % _cluster_bits;	/* number of bits in the last cluster */
-    int atrnum = _mainsys->attributes_num;	/* number of attributes */
-    value_type *A = _mainsys->matA;
-    cluster_type val;
-    int cluster, bit;
-    for (cluster = 0; cluster < nby; cluster++)
-        val = 0;
-        for (bit = 0; bit < _cluster_bits; bit++)
-            if (A[obj1 * atrnum + _cluster_bits * cluster + bit] !=
-                    A[obj2 * atrnum + _cluster_bits * cluster + bit] &&
-                    A[obj1 * atrnum + _cluster_bits * cluster + bit] !=
-                    (value_type) - 1 &&
-                    A[obj2 * atrnum + _cluster_bits * cluster + bit] !=
-                    (value_type) - 1)
-                val = val | _mask[bit];
-        elem[cluster] = val;
-    if (nbi)
-        val = 0;
-        for (bit = 0; bit < nbi; bit++)
-                    (value_type) - 1)
-    return 1;
-int CompareA(int ob1, int ob2, setA P)
-    int attr;
-    for (attr = 0; attr < _mainsys->attributes_num; attr++)
-        if (ContSetA(P, attr))
-            if ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) + attr] ==
-                    (value_type) - 1 ||
-                    (_mainsys->matA)[ob2 * (_mainsys->attributes_num) + attr] ==
-                    (value_type) - 1)
-                continue;
-            else if ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) +
-                                      attr] !=
-                                      attr])
-                return 0;
-    return 1;
-int CompareD(int ob1, int ob2, setA P)
-    int pom;
-    int cluster;
-    setA elem;
-    if (ob2 > ob1)
-        pom = ob1;
-        ob1 = ob2;
-        ob2 = pom;
-    elem =
-        (_mainsys->matD) + ((ob1 - 1) * ob1 / 2 + ob2) * (_mainsys->setAsize);
-    for (cluster = _mainsys->setAsize - 1; cluster >= 0; cluster--)
-        if (elem[cluster] & P[cluster])
-            return 0;
-    return 1;
-int SingCompA(int ob1, int ob2, int atr)
-    return ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) + atr] ==
-            (_mainsys->matA)[ob2 * (_mainsys->attributes_num) + atr] ||
-            (_mainsys->matA)[ob1 * (_mainsys->attributes_num) + atr] ==
-            (_mainsys->matA)[ob2 * (_mainsys->attributes_num) + atr] ==
-            (value_type) - 1);
-int SingCompD(int ob1, int ob2, int atr)
-    int pom;
-    if (ob2 > ob1)
-        pom = ob1;
-        ob1 = ob2;
-        ob2 = pom;
-    return !((_mainsys->matD)[((ob1 - 1) * ob1 / 2 + ob2)
-                              * (_mainsys->setAsize) +
-                              atr / _cluster_bits] & _mask[atr %
-                                                           _cluster_bits]);
Deleted: grass-addons/grass6/raster/mcda/r.roughset/raccess.h
--- grass-addons/grass6/raster/mcda/r.roughset/raccess.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/raccess.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,77 +0,0 @@
- * COPYRIGHT:    (C) GRASS Development Team (2008)
- *   	    	 for details.
-/***             FUNCTIONS OF ACCESS TO SYSTEM TABLES                      ***/
-/***  part of the RSL system written by M.Gawrys J. Sienkiewicz            ***/
-#define START_OF_D 	_table_element=_mainsys->matD,_table_end=_table_element+Dsize(_mainsys)
-#define START_OF_X 	_table_element=_mainsys->matX,_table_end=_table_element+_mainsys->matXsize
-#define START_OF_MAT(set,num) _table_element=(set),_table_end=_table_element+(num)*_mainsys->setAsize
-#define END_OF_MAT     (_table_element<_table_end)
-#define NEXT_OF_MAT    _table_element+=_mainsys->setAsize
-#define ELEM_OF_MAT    _table_element
-#define ElemOfRule(rules,num,attr) (rules)[(num)*(_mainsys->attributes_num)+(attr)]
-extern setA _table_element;
-extern setA _table_end;
-extern int _table_row;
-extern int _table_column;
-extern int _table_no;
-int start_of_tab(int matrix_type);
-void next_of_tab(void);
-int end_of_tab(void);
-int CompareA(int ob1, int ob2, setA P);
-int CompareD(int ob1, int ob2, setA P);
-	/* compares two objects, returns 1 if all attributes from */
-	/* the set P are identical, otherwise returns 0 */
-int SingCompA(int ob1, int ob2, int atr);
-int SingCompD(int ob1, int ob2, int atr);
-	/* compares two objects on the sigle attribute atr */
-	/* returns 1 if identical, otherwise returns 0 */
-setA GetD(int ob1, int ob2);
-	/* returns a single element of matrix D, if this set */
-	/* is going to be changed, it has to be first copied */
-value_type GetA(int obj, int atr);
-	/* returns value of attribute atr of object obj */
-	/* from matrix A */
-int GetDfromA(setA elem, int ob1, int ob2);
-	/* generate a single element of matrix D into elem */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rbasic.c
--- grass-addons/grass6/raster/mcda/r.roughset/rbasic.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rbasic.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,631 +0,0 @@
- *   	    	 for details.
-/***               BASIC QUERIES FOR ACTIVE SYSTEM                         ***/
-/***  part of the RSL system written by M.Gawrys J.Sienkiewicz             ***/
-#include "rough.h"
-int LowAppr(setO lowappr, setO X, setA P, int matrix_type)
-    switch (matrix_type)
-    case MATA:
-        return LowApprA(lowappr, X, P);
-    case MATD:
-        return LowApprD(lowappr, X, P);
-    default:
-        ERROR(8)
-int LowApprA(setO lowappr, setO X, setA P)
-    setO notX;
-    int ob1, ob2, disc;
-    if (_mainsys->matA == NULL)
-        ERROR(5);
-    notX = InitEmptySetO();
-    ClearSetO(lowappr);
-    NotSetO(notX, X);
-    for (ob1 = 0; ob1 < _mainsys->objects_num; ob1++)
-        if (ContSetO(X, ob1))
-            disc = 1;
-            for (ob2 = 0; ob2 < _mainsys->objects_num; ob2++)
-                if (ContSetO(notX, ob2))
-                    if (CompareA(ob1, ob2, P))
-                        disc = 0;
-                        break;
-            if (disc)
-                AddSetO(lowappr, ob1);
-    CloseSetO(notX);
-    return 0;
-int LowApprD(setO lowappr, setO X, setA P)
-    setO notX;
-    if (_mainsys->matD == NULL)
-        ERROR(6);
-    NotSetO(notX, X);
-            disc = 1;
-                    if (CompareD(ob1, ob2, P))
-                        disc = 0;
-                        break;
-            if (disc)
-    CloseSetO(notX);
-    return 0;
-int UppAppr(setO uppappr, setO X, setA P, int matrix_type)
-    case MATA:
-        return UppApprA(uppappr, X, P);
-    case MATD:
-        return UppApprD(uppappr, X, P);
-    default:
-        ERROR(8)
-int UppApprA(setO uppappr, setO X, setA P)
-    setO notX;
-    int ob1, ob2;
-        ERROR(5);
-    CopySetO(uppappr, X);
-    NotSetO(notX, X);
-                        AddSetO(uppappr, ob2);
-    CloseSetO(notX);
-    return 0;
-int UppApprD(setO uppappr, setO X, setA P)
-    setO notX;
-    int ob1, ob2;
-        ERROR(6);
-    NotSetO(notX, X);
-    CloseSetO(notX);
-    return 0;
-int Bound(setO bound, setO X, setA P, int matrix_type)
-    case MATA:
-        return BoundA(bound, X, P);
-    case MATD:
-        return BoundD(bound, X, P);
-    default:
-        ERROR(8)
-int BoundA(setO bound, setO X, setA P)
-    setO lower, upper;
-        ERROR(5);
-    lower = InitEmptySetO();
-    upper = InitEmptySetO();
-    LowApprA(lower, X, P);
-    UppApprA(upper, X, P);
-    DifSetO(bound, upper, lower);
-    CloseSetO(lower);
-    CloseSetO(upper);
-    return 0;
-int BoundD(setO bound, setO X, setA P)
-        ERROR(6);
-    LowApprD(lower, X, P);
-    UppApprD(upper, X, P);
-    CloseSetO(lower);
-    CloseSetO(upper);
-    return 0;
-float AccurCoef(setO X, setA P, int matrix_type)
-    case MATA:
-        return AccurCoefA(X, P);
-    case MATD:
-        return AccurCoefD(X, P);
-    default:
-        ERROR(8)
-float AccurCoefA(setO X, setA P)
-    float coef;
-        ERROR(5);
-    coef = (float)CardSetO(lower) / (float)CardSetO(upper);
-    CloseSetO(lower);
-    CloseSetO(upper);
-    return coef;
-float AccurCoefD(setO X, setA P)
-    float coef;
-        ERROR(6);
-    CloseSetO(lower);
-    CloseSetO(upper);
-    return coef;
-float ClassCoef(setO X, setA P, int matrix_type)
-    case MATA:
-        return ClassCoefA(X, P);
-    case MATD:
-        return ClassCoefD(X, P);
-    default:
-        ERROR(8)
-float ClassCoefA(setO X, setA P)
-    float coef;
-    setO notX, pos;
-    int ob1, ob2;
-        ERROR(5);
-    pos = InitFullSetO();
-    NotSetO(notX, X);
-            if (ContSetO(X, ob1) && ContSetO(notX, ob2) &&
-                    CompareA(ob1, ob2, P))
-                DelSetO(pos, ob1);
-                DelSetO(pos, ob2);
-    coef = (float)CardSetO(pos) / _mainsys->objects_num;
-    CloseSetO(notX);
-    CloseSetO(pos);
-    return coef;
-float ClassCoefD(setO X, setA P)
-    float coef;
-    setO notX, pos;
-    int ob1, ob2;
-        ERROR(6);
-    NotSetO(notX, X);
-                    CompareD(ob1, ob2, P))
-    CloseSetO(notX);
-    CloseSetO(pos);
-    return coef;
-int Pos(setO pos, setA P, setA Q, int matrix_type)
-    case MATA:
-        return PosA(pos, P, Q);
-    case MATD:
-        return PosD(pos, P, Q);
-    default:
-        ERROR(8)
-int PosA(setO pos, setA P, setA Q)
-    int i, j;
-    setA redQ;
-        ERROR(5);
-    if (IsEmptySetA(P))
-        ClearSetO(pos);
-        return 0;
-    redQ = InitEmptySetA();
-    DifSetA(redQ, Q, P);
-    FillSetO(pos);
-    if (IsEmptySetA(redQ))
-        return 0;
-    for (i = _mainsys->objects_num - 1; i > 0; i--)
-        for (j = i - 1; j >= 0; j--)
-            if (!CompareA(i, j, redQ) && CompareA(i, j, P))
-                DelSetO(pos, i);
-                DelSetO(pos, j);
-    return 0;
-int PosD(setO pos, setA P, setA Q)
-    int i, j;
-    setA elem, redQ;
-        ERROR(6);
-        ClearSetO(pos);
-        return 0;
-    FillSetO(pos);
-        return 0;
-            elem = GetD(i, j);
-            if (InterSetA(elem, redQ) && !InterSetA(elem, P))
-                DelSetO(pos, i);
-                DelSetO(pos, j);
-    CloseSetA(redQ);
-    return 0;
-float DependCoef(setA P, setA Q, int matrix_type)
-    case MATA:
-        return DependCoefA(P, Q);
-    case MATD:
-        return DependCoefD(P, Q);
-    default:
-        ERROR(8)
-float DependCoefA(setA P, setA Q)
-    setO pos;
-    float coef;
-        ERROR(5);
-    pos = InitEmptySetO();
-    PosA(pos, P, Q);
-    coef = (float)CardSetO(pos) / (float)_mainsys->objects_num;
-    CloseSetO(pos);
-    return coef;
-float DependCoefD(setA P, setA Q)
-    setO pos;
-    float coef;
-        ERROR(6);
-    PosD(pos, P, Q);
-    CloseSetO(pos);
-    return coef;
-float SignifCoef(int attr, setA P, int matrix_type)
-    case MATA:
-        return SignifCoefA(attr, P);
-    case MATD:
-        return SignifCoefD(attr, P);
-    default:
-        ERROR(8)
-float SignifCoefA(int attr, setA P)
-    setO pos1, pos2;
-    setA Pprim;
-    int i, j;
-    float coef;
-        ERROR(5);
-    if (IsEmptySetA(P) || !ContSetA(P, attr))
-        return 0;
-    pos1 = InitFullSetO();
-    pos2 = InitFullSetO();
-    Pprim = InitEmptySetA();
-    CopySetA(Pprim, P);
-    DelSetA(Pprim, attr);
-            if (CompareA(i, j, P))
-                DelSetO(pos1, i);
-                DelSetO(pos2, i);
-                DelSetO(pos1, j);
-                DelSetO(pos2, j);
-                continue;
-            else if (CompareA(i, j, Pprim))
-                DelSetO(pos2, i);
-                DelSetO(pos2, j);
-    DifSetO(pos1, pos1, pos2);
-    coef = (float)CardSetO(pos1) / (float)_mainsys->objects_num;
-    CloseSetO(pos1);
-    CloseSetO(pos2);
-    CloseSetA(Pprim);
-    return coef;
-float SignifCoefD(int attr, setA P)
-    setO pos1, pos2;
-    setA Pprim, elem;
-    int i, j;
-    float coef;
-        ERROR(6);
-        return 0;
-            if (!InterSetA(elem, P))
-                DelSetO(pos1, i);
-                DelSetO(pos2, i);
-                DelSetO(pos1, j);
-                DelSetO(pos2, j);
-                continue;
-            if (!InterSetA(elem, Pprim))
-                DelSetO(pos2, i);
-                DelSetO(pos2, j);
-    CloseSetO(pos1);
-    CloseSetO(pos2);
-    CloseSetA(Pprim);
-    return coef;
-float SignifRelCoef(int attr, setA P, setA Q, int matrix_type)
-    case MATA:
-        return SignifRelCoefA(attr, P, Q);
-    case MATD:
-        return SignifRelCoefD(attr, P, Q);
-    default:
-        ERROR(8)
-float SignifRelCoefA(int attr, setA P, setA Q)
-    setO pos1, pos2;
-    setA Pprim, redQ;
-    int i, j;
-    float coef;
-        ERROR(5);
-    DifSetA(redQ, Q, Pprim);
-        return 0;
-        return 1;
-            if (CompareA(i, j, redQ))
-                continue;
-            else if (CompareA(i, j, P))
-                DelSetO(pos1, i);
-                DelSetO(pos2, i);
-                DelSetO(pos1, j);
-                DelSetO(pos2, j);
-                continue;
-                DelSetO(pos2, i);
-                DelSetO(pos2, j);
-    CloseSetO(pos1);
-    CloseSetO(pos2);
-    CloseSetA(Pprim);
-    CloseSetA(redQ);
-    return coef;
-float SignifRelCoefD(int attr, setA P, setA Q)
-    setO pos1, pos2;
-    setA Pprim, redQ, elem;
-    int i, j;
-    float coef;
-        ERROR(6);
-        return 0;
-        return 1;
-            if (!InterSetA(elem, redQ))
-                continue;
-                DelSetO(pos1, i);
-                DelSetO(pos2, i);
-                DelSetO(pos1, j);
-                DelSetO(pos2, j);
-                continue;
-                DelSetO(pos2, i);
-                DelSetO(pos2, j);
-    CloseSetO(pos1);
-    CloseSetO(pos2);
-    CloseSetA(Pprim);
-    CloseSetA(redQ);
-    return coef;
-int CardCoef(setA P, int matrix_type)
-    int res = 0;
-    for (start_of_tab(matrix_type); end_of_tab(); next_of_tab())
-        if (InterSetA(P, _table_element))
-            res++;
-    if (_rerror > 0)
-        return -_rerror;
-    return res;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rbasic.h
--- grass-addons/grass6/raster/mcda/r.roughset/rbasic.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rbasic.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,99 +0,0 @@
- *   	    	 for details.
-/***                   BASIC QUERRIES FOR SYSTEM                           ***/
-/* If a function from this section value a set, this set should be */
-/* first initialized and then given to the function as a first     */
-/* argument. Functions from this group does not work on matrix X.  */
-int LowAppr(setO appr, setO X, setA P, int matrix_type);
-int LowApprA(setO appr, setO X, setA P);
-int LowApprD(setO appr, setO X, setA P);
-	/* P-lower approximation of X */
-int UppAppr(setO appr, setO X, setA P, int matrix_type);
-int UppApprA(setO appr, setO X, setA P);
-int UppApprD(setO appr, setO X, setA P);
-	/* P-upper appriximation of X */
-int Bound(setO bound, setO X, setA P, int matrix_type);
-int BoundA(setO bound, setO X, setA P);
-int BoundD(setO bound, setO X, setA P);
-	/* P-boundary of X */
-float AccurCoef(setO X, setA P, int matrix_type);
-float AccurCoefA(setO X, setA P);
-float AccurCoefD(setO X, setA P);
-	/* Accuracy coefficient of X with respect to P */
-float ClassCoef(setO X, setA P, int matrix_type);
-float ClassCoefA(setO X, setA P);
-float ClassCoefD(setO X, setA P);
-	/* quality of classification (X,not X) */
-	/* with respect to P */
-int Pos(setO pos, setA P, setA Q, int matrix_type);
-int PosA(setO pos, setA P, setA Q);
-int PosD(setO pos, setA P, setA Q);
-	/* P-positive region of Q */
-float DependCoef(setA P, setA Q, int matrix_type);
-float DependCoefA(setA P, setA Q);
-float DependCoefD(setA P, setA Q);
-	/* degree of dependency Q from P */
-float SignifCoef(int attr, setA P, int matrix_type);
-float SignifCoefA(int attr, setA P);
-float SignifCoefD(int attr, setA P);
-	/* significance of attribute attr  */
-	/* in the set P */
-float SignifRelCoef(int attr, setA P, setA Q, int matrix_type);
-float SignifRelCoefA(int attr, setA P, setA Q);
-float SignifRelCoefD(int attr, setA P, setA Q);
-	/* in the set P, relatively to Q */
-int CardCoef(setA P, int matrix_type);
-	/* returns number of matrix fields */
-	/* covered by P (MATA is treated as MATD) */
-	/* but elements are evaluated "on-line" */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rclass.c
--- grass-addons/grass6/raster/mcda/r.roughset/rclass.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rclass.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,248 +0,0 @@
- *   	    	 for details.
-/***               SOME MORE QUERIES FOR SYSTEM                            ***/
-/***                     ( CLASSIFICATION )                                ***/
-#include "rough.h"
-int DecisionEQ(value_type * rule1, value_type * rule2, setA Q)
-    int i;
-    for (i = 0; i < _mainsys->attributes_num; i++)
-        if (ContSetA(Q, i))
-            if (rule1[i] != rule2[i])
-                return 0;
-    return 1;
-int StrengthOfRule(value_type * rule)
-    int obj, attr, find, result = 0, size = _mainsys->attributes_num;
-    for (obj = 0; obj < _mainsys->objects_num; obj++)
-        find = 1;
-        for (attr = 0; attr < size; attr++)
-            if (rule[attr] != GetA(obj, attr))
-                if (rule[attr] != MINUS && GetA(obj, attr) != MINUS)
-                    find = 0;
-                    break;
-        if (find)
-            result++;
-    return result;
-int *StrengthOfRules(value_type * rules, int N)
-    int *result;
-    int i, size = _mainsys->attributes_num;
-    if (N <= 0)
-        return NULL;
-    result = (int *)calloc(N, sizeof(int));
-    for (i = 0; i < N; i++)
-        result[i] = StrengthOfRule(rules + i * size);
-    return result;
-int ObjectsForRule(setO set, value_type * rule)
-    int i, j, find, size = _mainsys->attributes_num;
-    for (i = 0; i < _mainsys->objects_num; i++)
-        find = 1;
-        for (j = 0; j < size; j++)
-            if (rule[j] != GetA(i, j))
-                if (rule[j] != MINUS && GetA(i, j) != MINUS)
-                    find = 0;
-                    break;
-        if (find)
-            AddSetO(set, i);
-    return CardSetO(set);
-int CompareToRule(value_type * sample, value_type * rule, setA P)
-    int j, result = 0, size = _mainsys->attributes_num;
-        if (!ContSetA(P, j))
-            continue;
-        if (rule[j] != sample[j])
-            if (rule[j] != MINUS && sample[j] != MINUS)
-                result++;
-    return result;
-int *CompareToRules(value_type * sample, value_type * rules, int N, setA P)
-    int *result;
-    if (N <= 0)
-        return NULL;
-        result[i] = CompareToRule(sample, rules + i * size, P);
-    return result;
-int Classify1(value_type * sample, value_type * rules, int N, setA P, setA Q)
-    int done = 0,
-               result = -1,
-                        count = 0,
-                                *diff, minDiff = _mainsys->attributes_num,
-                                                 i, j = 0, max = 0, size = _mainsys->attributes_num;
-    diff = CompareToRules(sample, rules, N, P);
-        if (diff[i] < minDiff)
-            minDiff = diff[i];
-    while (!done)  		/* while there is an unprocessed rule */
-        while (diff[j] != minDiff)
-            j++;		/* to find the rule with new decision */
-        done = 1;
-        diff[j]++;
-        count = 1;
-        for (i = j; i < N; i++)
-            if (diff[i] == minDiff)
-                if (DecisionEQ(rules + i * size, rules + j * size, Q))
-                    diff[j]++;	/* to protect from next use */
-                    count++;
-                else
-                    done = 0;
-        if (count > max)
-            max = count, result = j;
-    free(diff);
-    return result;
-int Classify2(value_type * sample, value_type * rules, int N, setA P, setA Q)
-    int i,
-    *diff,
-    first = 0, maxindex,
-            size = _mainsys->attributes_num,
-                   minDiff = _mainsys->attributes_num, done = 0;
-    setO cover, maxcover, rulecover;
-    cover = InitEmptySetO();
-    maxcover = InitEmptySetO();
-    rulecover = InitEmptySetO();
-        while (diff[first] != minDiff)
-            first++;		/* to find the rule with new decision */
-        done = 1;
-        diff[first]++;		/* to protect from next use */
-        ObjectsForRule(cover, rules + first * size);
-        for (i = first; i < N; i++)
-                if (DecisionEQ(rules + first * size, rules + i * size, Q))
-                    diff[i]++;
-                    ObjectsForRule(rulecover, rules + i * size);
-                    OrSetO(cover, cover, rulecover);
-                else
-                    done = 0;
-        if (CardSetO(maxcover) < CardSetO(cover))
-            CopySetO(maxcover, cover);
-            maxindex = first;
-    free(diff);
-    CloseSetO(cover);
-    CloseSetO(maxcover);
-    CloseSetO(rulecover);
-    return maxindex;
-int Classify3(value_type * sample, value_type * rules, int N,
-              int *strength, setA P, setA Q)
-    int i,
-    *diff,
-    int cover, maxcover = 0;
-        done = 1;
-        cover = strength[first];
-                    diff[i]++;
-                    cover += strength[i];
-                else
-                    done = 0;
-        if (maxcover < cover)
-            maxcover = cover;
-            maxindex = first;
-    free(diff);
-    return maxindex;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rclass.h
--- grass-addons/grass6/raster/mcda/r.roughset/rclass.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rclass.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,82 +0,0 @@
- *   	    	 for details.
-int DecisionEQ(value_type * rule1, value_type * rule2, setA Q);
-	/* compares decisions of two rules */
-	/* returns 1 if equal */
-int StrengthOfRule(value_type * rule);
-	/* return a number of objects covered by rule (strength) */
-int *StrengthOfRules(value_type * rules, int N);
-	/* creates a table of rules strengths */
-	/* allocates memory, size = N * sizeof(int) */
-int ObjectsForRule(setO set, value_type * rule);
-	/* finds a set of objects covered by rule */
-int CompareToRule(value_type * sample, value_type * rule, setA P);
-	/* compares a sample with rule on a set of attributes */
-	/* returns a number of dissimilar attributes (distance) */
-int *CompareToRules(value_type * sample, value_type * rules, int N, setA P);
-	/* compares a sample with rules on a set of attributes */
-	/* creates a table of distances (number of dissimilar attributes) */
-int Classify1(value_type * sample, value_type * rules, int N, setA P, setA Q);
-	/* chooses the best rule to cover sample, strategy no. 1 */
-	/* finds the most frequent decision among rules with minimal */
-	/* distances from a given sample, returns index of a proper rule */
-int Classify2(value_type * sample, value_type * rules, int N, setA P, setA Q);
-	/* chooses the best rule to cover sample, strategy no. 2 */
-	/* finds a decision that covers the largerst number of objects */
-	/* among rules with minimal distances from a given sample */
-	/* returns index of a proper rule */
-	      int *strength, setA P, setA Q);
-	/* chooses the best rule to cover sample, strategy no. 3 */
-	/* finds a decision with the largest total strength among */
-	/* rules with minimal distances from a given sample */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rcore.c
--- grass-addons/grass6/raster/mcda/r.roughset/rcore.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rcore.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,364 +0,0 @@
- *   	    	 for details.
-/***          ( FINDING CORES AND CHECKING REDUCTS )                       ***/
-#include "rough.h"
-int Core(setA core, int matrix_type)
-    case MATA:
-        return CoreA(core);
-    case MATD:
-        return CoreDX(core, matrix_type);
-    case MATX:
-    default:
-        ERROR(8)
-int CoreA(setA core)
-    int ob1, ob2, attr, no1, pattr;
-        ERROR(5)
-        ClearSetA(core);
-    for (ob1 = _mainsys->objects_num - 1; ob1 > 0; ob1--)
-        for (ob2 = ob1 - 1; ob2 >= 0; ob2--)
-            no1 = 0;
-            for (attr = _mainsys->attributes_num - 1; attr >= 0; attr--)
-                if (!SingCompA(ob1, ob2, attr))
-                    no1++;
-                    if (no1 > 1)
-                        break;
-                    else
-                        pattr = attr;
-            if (no1 == 1)
-                AddSetA(core, pattr);
-    return 0;
-int CoreDX(setA core, int matrix_type)
-    int cluster, bit, flag, no1, pcluster;
-    ClearSetA(core);
-            ERROR(6)
-            START_OF_D;
-    else
-        if (_mainsys->matX == NULL)
-            ERROR(7)
-            START_OF_X;
-    for (; END_OF_MAT; NEXT_OF_MAT)
-        flag = 0;
-        no1 = 0;
-                if (_mask[bit] & ELEM_OF_MAT[cluster])
-                    no1++;
-                    if (no1 > 1)
-                        flag = 1;
-                        break;
-                    else
-                        pcluster = cluster;
-            if (flag)
-                break;
-        if (no1 == 1)
-            core[pcluster] |= ELEM_OF_MAT[pcluster];
-    return 0;
-int CoreRel(setA core, setA P, setA Q, int matrix_type)
-    case MATA:
-        return CoreRelA(core, P, Q);
-    case MATD:
-        return CoreRelD(core, P, Q);
-    default:
-        ERROR(8)
-int CoreRelA(setA core, setA P, setA Q)
-        ERROR(5)
-        ClearSetA(core);
-            if (!CompareA(ob1, ob2, Q))
-                no1 = 0;
-                            no1++;
-                            if (no1 > 1)
-                                break;
-                            else
-                                pattr = attr;
-                if (no1 == 1)
-    return 0;
-int CoreRelD(setA core, setA P, setA Q)
-    setA elem;
-        ERROR(6)
-        ClearSetA(core);
-    elem = InitEmptySetA();
-    for (START_OF_D; END_OF_MAT; NEXT_OF_MAT)
-        AndSetA(elem, ELEM_OF_MAT, P);
-        flag = 0;
-        no1 = 0;
-        if (!InterSetA(Q, ELEM_OF_MAT))
-            continue;
-                if (_mask[bit] & elem[cluster])
-                    no1++;
-                    if (no1 > 1)
-                        flag = 1;
-                        break;
-                    else
-            if (flag)
-                break;
-        if (no1 == 1)
-            core[pcluster] |= elem[pcluster];
-    CloseSetA(elem);
-    return 0;
-int IsOrtho(setA red, setA over, int matrix_type)
-    setA and, redprim;
-    and = InitEmptySetA();
-    redprim = InitEmptySetA();
-        AndSetA(and, _table_element, red);
-        if (CardSetA(and) == 1)
-            OrSetA(redprim, redprim, and);
-    CloseSetA(and);
-    DifSetA(over, red, redprim);
-    CloseSetA(redprim);
-    return IsEmptySetA(over);
-int IsOrthoRel(setA red, setA over, setA P, setA Q, int matrix_type)
-        if (InterSetA(_table_element, Q))
-            AndSetA(and, and, P);
-    CloseSetA(and);
-int IsCover(setA red, int matrix_type)
-    case MATA:
-        return IsCoverA(red);
-    case MATD:
-        return IsCoverDX(red, matrix_type);
-    case MATX:
-    default:
-        ERROR(8)
-int IsCoverA(setA red)
-    int ob1, ob2;
-    setA P = InitFullSetA();
-    DifSetA(P, P, red);
-        ERROR(5);
-            if (CompareA(ob1, ob2, red))
-                if (!CompareA(ob1, ob2, P))
-                    CloseSetA(P);
-                    return 0;
-    CloseSetA(P);
-    return 1;
-int IsCoverDX(setA red, int matrix_type)
-            ERROR(6)
-            START_OF_D;
-    else
-            ERROR(7)
-            START_OF_X;
-        if (!IsEmptySetA(ELEM_OF_MAT))
-            if (!InterSetA(ELEM_OF_MAT, red))
-                return 0;
-    return 1;
-int IsCoverRel(setA red, setA P, setA Q, int matrix_type)
-    case MATA:
-        return IsCoverRelA(red, P, Q);
-    case MATD:
-        return IsCoverRelD(red, P, Q);
-    default:
-        ERROR(8)
-int IsCoverRelA(setA red, setA P, setA Q)
-    int ob1, ob2;
-    setA Pprim;
-        ERROR(5);
-    DifSetA(Pprim, P, red);
-                    if (!CompareA(ob1, ob2, Pprim))
-                        CloseSetA(Pprim);
-                        return 0;
-    CloseSetA(Pprim);
-    return 1;
-int IsCoverRelD(setA red, setA P, setA Q)
-        ERROR(6);
-        if (InterSetA(ELEM_OF_MAT, Q))
-                if (InterSetA(ELEM_OF_MAT, P))
-                    return 0;
-    return 1;
-int IsRed(setA red, int matrix_type)
-    int result;
-    setA over;
-    if (!IsCover(red, matrix_type))
-        return 0;
-    over = InitEmptySetA();
-    result = IsOrtho(red, over, matrix_type);
-    CloseSetA(over);
-    return result;
-int IsRedRel(setA red, setA P, setA Q, int matrix_type)
-    int result;
-    setA over;
-    if (!IsCoverRel(red, P, Q, matrix_type))
-        return 0;
-    result = IsOrthoRel(red, over, P, Q, matrix_type);
-    CloseSetA(over);
-    return result;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rcore.h
--- grass-addons/grass6/raster/mcda/r.roughset/rcore.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rcore.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,80 +0,0 @@
- *   	    	 for details.
-int Core(setA core, int matrix_type);
-int CoreA(setA core);
-int CoreDX(setA core, int matrix_type);
-	/* finds a core of all attributes */
-int CoreRel(setA core, setA P, setA Q, int matrix_type);
-int CoreRelA(setA core, setA P, setA Q);
-int CoreRelD(setA core, setA P, setA Q);
-	/* finds a core of P relativly to Q */
-int IsOrtho(setA red, setA over, int matrix_type);
-	/* return 1 if red is orthogonal */
-	/* otherwise returns 0 */
-int IsOrthoRel(setA red, setA over, setA P, setA Q, int matrix_type);
-	/* return 1 if red is Q-orthogonal in P */
-int IsCover(setA red, int matrix_type);
-int IsCoverA(setA red);
-int IsCoverDX(setA red, int matrix_type);
-	/* return 1 if red is a cover */
-int IsCoverRel(setA red, setA P, setA Q, int matrix_type);
-int IsCoverRelA(setA red, setA P, setA Q);
-int IsCoverRelD(setA red, setA P, setA Q);
-	/* return 1 if red is Q-cover in P */
-int IsRed(setA red, int matrix_type);
-	/* returns 1 if red is a reduct */
-int IsRedRel(setA red, setA P, setA Q, int matrix_type);
-	/* returns 1 if red is a Q-relative reduct of P */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/reduct1.c
--- grass-addons/grass6/raster/mcda/r.roughset/reduct1.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/reduct1.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,1305 +0,0 @@
- *   	    	 for details.
-/***                   ( FINDING REDUCTS )                                 ***/
-#include "rough.h"
-int RedRel(setA * reducts, setA P, setA Q, int matrix_type)
-    int MEMOKWANT = _mainsys->attributes_num * _mainsys->attributes_num, j, atr, over, size = _mainsys->setAsize, memoryN = 1, memoryO = 1,	/* size of the allocated memory    */
-                    newcount = 0, oldcount;	/* number of new/old reducts       */
-    int no_A = _mainsys->attributes_num;
-    setA arg,			/* arguments are elements of matrix */
-    oldhead,			/* head of static list of reducts  */
-    oldtail,			/* tail ends the old reducts list  */
-    el, el1,			/* elements of this list           */
-    new_el,			/* probably new element of the list */
-    newhead,			/* begin of new reducts            */
-    newtail;			/* tail of the list of new reducts */
-    setA CORE, keep;
-    CORE = InitEmptySetA();
-    _rerror = 0;
-    CoreRel(CORE, P, Q, matrix_type);
-    if (_rerror != 0)
-        CloseSetA(CORE);
-        return (-_rerror);
-    if ((oldhead = (setA) malloc(MEMOKWANT)) == NULL)
-        CloseSetA(CORE);
-        ERROR(3);
-    if ((newhead = (setA) malloc(MEMOKWANT)) == NULL)
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    new_el = InitEmptySetA();
-    arg = InitEmptySetA();
-    oldtail = oldhead;
-    newtail = newhead;
-    start_of_tab(matrix_type);	/* initializing the reducts list */
-    if (!IsEmptySetA(CORE))
-        CopySetA(oldtail, CORE);
-        oldtail += size, oldcount = 1;
-    else
-        do
-            AndSetA(arg, _table_element, P);
-            oldcount = 0;
-                for (atr = 0; atr < no_A; atr++)
-                    if (ContSetA(arg, atr))
-                        ClearSetA(oldtail);
-                        AddSetA(oldtail, atr);
-                        oldtail += size;
-                        oldcount++;
-            next_of_tab();
-        while ((oldcount == 0) && end_of_tab());
-    for (; end_of_tab(); next_of_tab())  	/* for each element of matD do  */
-        AndSetA(arg, _table_element, P);	/* take next element */
-        over = 0;
-        if (InterSetA(CORE, arg))
-            continue;
-        if (!InterSetA(_table_element, Q))
-            continue;
-        if (IsEmptySetA(arg))
-            continue;
-        el = oldhead;
-        while (el < oldtail)  	/* compare arg to all the old reducts  */
-            if (!InterSetA(el, arg))
-                for (atr = 0; atr < no_A; atr++)	/* for each atribute of arg  */
-                        CopySetA(new_el, el);	/* creating potentialy new reduct */
-                        AddSetA(new_el, atr);
-                        over = 0;
-                        el1 = oldhead;
-                        while ((el1 != el) && !over)  	/* comparing new reduct to old reducts */
-                            over = InSetA(new_el, el1);
-                            el1 += size;
-                        el1 = el + size;
-                        while ((el1 != oldtail) && !over)
-                            el1 += size;
-                        if (!over)  	/* appending new reduct */
-                            newcount++;
-                            if (newcount * size * _cluster_bytes >
-                                    memoryN * MEMOKWANT)
-                                keep = newhead;
-                                if ((newhead =
-                                            (setA) realloc(keep,
-                                                           MEMOKWANT *
-                                                           (++memoryN))) == NULL)
-                                    free(oldhead);
-                                    CloseSetA(new_el);
-                                    CloseSetA(arg);
-                                    CloseSetA(CORE);
-                                    ERROR(3);
-                                if (keep != newhead)
-                                    newtail = newhead + (newcount - 1) * size;
-                            CopySetA(newtail, new_el);
-                            newtail += size;
-            else  		/* if reduct covers arg - rewrite it */
-                newcount++;
-                if (newcount * size * _cluster_bytes > memoryN * MEMOKWANT)
-                    keep = newhead;
-                    if ((newhead =
-                                               MEMOKWANT * (++memoryN))) == NULL)
-                        free(oldhead);
-                        CloseSetA(arg);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                CopySetA(newtail, el);
-                newtail += size;
-            el += size;
-        oldtail = newhead;	/* new reducts list becomes old */
-        newhead = oldhead;
-        oldhead = oldtail;
-        oldtail = newtail;
-        oldcount = newcount;
-        newcount = 0;
-        j = memoryO;
-        memoryO = memoryN;
-        memoryN = j;
-    if (oldcount == 0)
-        free(oldhead);
-        *reducts = NULL;
-    else
-        *reducts = oldhead;
-    free(newhead);
-    CloseSetA(CORE);
-    CloseSetA(arg);
-    return (oldcount);
-int Red(setA * reducts, int matrix_type)
-    int j, MEMOKWANT = _mainsys->attributes_num * _mainsys->attributes_num, atr, over, size = _mainsys->setAsize, memoryN = 1, memoryO = 1,	/* size of the allocated memory    */
-    setA oldhead,		/* head of static list of reducts  */
-    setA CORE, keep, and, redprim;
-    _rerror = 0;
-    Core(CORE, matrix_type);
-    if (_rerror != 0)
-        CloseSetA(CORE);
-        CloseSetA(CORE);
-        keep = NULL;
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    if (!IsEmptySetA(CORE))  	/* initializing of the reducts list */
-    else
-        do
-            oldcount = 0;
-                if (ContSetA(_table_element, atr))
-                    oldtail += size;
-                    oldcount++;
-            next_of_tab();
-    for (; end_of_tab(); next_of_tab())  	/* for each element of matrix */
-        over = 0;
-        if (InterSetA(CORE, _table_element))
-            continue;
-        if (IsEmptySetA(_table_element))
-            continue;
-        el = oldhead;
-        while (el < oldtail)  	/* compare _table_element to all the old reducts  */
-            if (!InterSetA(el, _table_element))  	/* old reduct does not cover new element */
-                for (atr = 0; atr < no_A; atr++)	/* for each atribute of _table_element  */
-                        over = 0;
-                        el1 = oldhead;
-                        /*  if ( matrix_type==MATX && (_mainsys->matXsize<(oldtail-oldhead)))
-                           { ClearSetA( redprim );
-                           for(el1=_mainsys->matX;el1<_table_end;el1+=size)
-                           { AndSetA( and, el1, new_el );
-                           if ( CardSetA( and ) == 1 ) OrSetA( redprim, redprim, and );
-                           over = !CompSetA( redprim, new_el );
-                           else
-                            while ((el1 != el) && !over)  	/* comparing new reduct to all the old reducts */
-                                el1 += size;
-                            el1 = el + size;
-                                el1 += size;
-                            newcount++;
-                                keep = newhead;
-                                if ((newhead =
-                                                           MEMOKWANT *
-                                    free(oldhead);
-                                    CloseSetA(CORE);
-                                    ERROR(3);
-                            newtail += size;
-            else  		/* old reduct covers new element */
-                newcount++;
-                    keep = newhead;
-                    if ((newhead =
-                        free(oldhead);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                newtail += size;
-            el += size;
-        newcount = 0;
-        j = memoryO;
-        memoryN = j;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-    CloseSetA(and);
-int RedRelLess(setA * reducts, setA P, setA Q, int N, int matrix_type)
-    setA CORE, keep;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-    if (CardSetA(CORE) > N)
-        free(CORE);
-        return (0);
-        CloseSetA(CORE);
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    else
-        do
-            oldcount = 0;
-                        oldtail += size;
-                        oldcount++;
-            next_of_tab();
-    for (; end_of_tab(); next_of_tab())  	/* for each element of matrix do  */
-        over = 0;
-            continue;
-            continue;
-            continue;
-        el = oldhead;
-        while (el < oldtail)  	/* compare arg to all old reducts  */
-            if (!InterSetA(el, arg))  	/* old reduct does not cover new element */
-                if (CardSetA(el) < N)	/* shorter elements should be corected */
-                            over = 0;
-                            el1 = oldhead;
-                            while ((el1 != el) && !over)  	/* comparing new reduct to all the old list */
-                                el1 += size;
-                            el1 = el + size;
-                                el1 += size;
-                            if (!over)  	/* appending to new list */
-                                newcount++;
-                                    keep = newhead;
-                                    if ((newhead =
-                                                               MEMOKWANT *
-                                                               (++memoryN))) ==
-                                            NULL)
-                                        free(oldhead);
-                                        CloseSetA(arg);
-                                        CloseSetA(CORE);
-                                        ERROR(3);
-                                        newtail =
-                                            newhead + (newcount - 1) * size;
-                                newtail += size;
-                newcount++;
-                    keep = newhead;
-                    if ((newhead =
-                        free(oldhead);
-                        CloseSetA(arg);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                newtail += size;
-            el += size;
-        oldtail = newhead;	/* new list becomes old */
-        newcount = 0;
-        j = memoryO;
-        memoryN = j;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-    CloseSetA(arg);
-int RedLess(setA * reducts, int N, int matrix_type)
-    setA CORE, keep;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-        free(CORE);
-        return (0);
-        CloseSetA(CORE);
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    if (!IsEmptySetA(CORE))  	/*initializing the reducts list  */
-        oldtail += size;
-        oldcount = 1;
-    else
-        do
-            oldcount = 0;
-                    oldtail += size;
-                    oldcount++;
-            next_of_tab();
-        over = 0;
-        if (InterSetA(_table_element, CORE))
-            continue;
-            continue;
-        el = oldhead;
-                    for (atr = 0; atr < no_A; atr++)	/* for each atribute of element */
-                            over = 0;
-                            el1 = oldhead;	/* comparing new reduct to the old reducts */
-                                el1 += size;
-                            el1 = el + size;
-                                el1 += size;
-                            if (!over)  	/* appending new reduct to list */
-                                newcount++;
-                                    keep = newhead;
-                                    if ((newhead =
-                                                               MEMOKWANT *
-                                                               (++memoryN))) ==
-                                            NULL)
-                                        free(oldhead);
-                                        CloseSetA(CORE);
-                                        ERROR(3);
-                                        newtail =
-                                newtail += size;
-                newcount++;
-                    keep = newhead;
-                    if ((newhead =
-                        free(oldhead);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                newtail += size;
-            el += size;
-        newcount = 0;
-        j = memoryO;
-        memoryN = j;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-int RedRelSetA(setA * reducts, setA quasicore, setA P, setA Q,
-               int matrix_type)
-    setA CORE, keep;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-    OrSetA(CORE, CORE, quasicore);
-        CloseSetA(CORE);
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-        oldtail += size;
-        oldcount = 1;
-    else
-        do
-            oldcount = 0;
-                        oldtail += size;
-                        oldcount++;
-            next_of_tab();
-        over = 0;
-            continue;
-            continue;
-            continue;
-        el = oldhead;
-        while (el < oldtail)  	/* compare element to all the old reducts  */
-                        over = 0;
-                        el1 = oldhead;
-                            el1 += size;
-                        el1 = el + size;
-                            el1 += size;
-                            newcount++;
-                                keep = newhead;
-                                if ((newhead =
-                                                           MEMOKWANT *
-                                    free(oldhead);
-                                    CloseSetA(arg);
-                                    CloseSetA(CORE);
-                                    ERROR(3);
-                            newtail += size;
-            else  		/* old reduct covers new elemet */
-                newcount++;
-                    keep = newhead;
-                    if ((newhead =
-                        free(oldhead);
-                        CloseSetA(arg);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                newtail += size;
-            el += size;
-        newcount = 0;
-        j = memoryO;
-        memoryN = j;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-    CloseSetA(arg);
-int RedSetA(setA * reducts, setA quasicore, int matrix_type)
-    setA CORE, keep;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-        CloseSetA(CORE);
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    else
-        do
-            oldcount = 0;
-                    oldtail += size;
-                    oldcount++;
-            next_of_tab();
-        over = 0;
-            continue;
-            continue;
-        el = oldhead;
-        while (el < oldtail)  	/* compare elment to all the old reducts  */
-            if (!InterSetA(el, _table_element))  	/* old reduct does not cover element */
-                        over = 0;
-                        el1 = oldhead;
-                            el1 += size;
-                        el1 = el + size;
-                            el1 += size;
-                            newcount++;
-                                keep = newhead;
-                                if ((newhead =
-                                                           MEMOKWANT *
-                                    free(oldhead);
-                                    CloseSetA(CORE);
-                                    ERROR(3);
-                            newtail += size;
-                newcount++;
-                    keep = newhead;
-                    if ((newhead =
-                        free(oldhead);
-                        CloseSetA(CORE);
-                        ERROR(3);
-                newtail += size;
-            el += size;
-        newcount = 0;
-        j = memoryO;
-        memoryN = j;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-int RedRelFirst(setA * reducts, setA P, setA Q, int N, int matrix_type)
-    int atr, over, size = _mainsys->setAsize, newcount = 0, oldcount;	/* number of new,old reducts       */
-    setA CORE;
-    if (N == 0)
-        return 0;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-    if ((oldhead = (setA) malloc(N * size * _cluster_bytes)) == NULL)
-        CloseSetA(CORE);
-        ERROR(3);
-    if ((newhead = (setA) malloc(N * size * _cluster_bytes)) == NULL)
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    if (!IsEmptySetA(CORE))  	/* initializing  the reducts list  */
-    else
-        do
-            oldcount = 0;
-                    if (ContSetA(arg, atr) && (oldcount < N))
-                        oldtail += size;
-                        oldcount++;
-            next_of_tab();
-        over = 0;
-            continue;
-            continue;
-            continue;
-        el = oldhead;
-            if (!InterSetA(el, arg))  	/* old reduct does not cover element */
-                for (atr = 0; atr < no_A; atr++)	/* for each atribute of elememt */
-                    if (ContSetA(arg, atr) && (newcount < N))
-                        over = 0;
-                        el1 = oldhead;
-                            el1 += size;
-                        el1 = el + size;
-                            el1 += size;
-                            newtail += size;
-                            newcount++;
-            else if (newcount < N)
-                newtail += size;
-                newcount++;
-            el += size;
-        newcount = 0;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
-    CloseSetA(arg);
-int RedFirst(setA * reducts, int N, int matrix_type)
-    int atr, over, size = _mainsys->setAsize, newcount = 0, oldcount;	/* sizes of reduct lists */
-    setA CORE;
-    if (N == 0)
-        return 0;
-    _rerror = 0;
-    if (_rerror != 0)
-        CloseSetA(CORE);
-        CloseSetA(CORE);
-        ERROR(3);
-        free(oldhead);
-        CloseSetA(CORE);
-        ERROR(3);
-    else
-        do
-            oldcount = 0;
-                if (ContSetA(_table_element, atr) && (oldcount < N))
-                    oldtail += size;
-                    oldcount++;
-            next_of_tab();
-        over = 0;
-            continue;
-            continue;
-        el = oldhead;
-                    if (ContSetA(_table_element, atr) && (newcount < N))
-                        CopySetA(new_el, el);	/* creating potentialy new element */
-                        over = 0;
-                        el1 = oldhead;
-                        while ((el1 != el) && !over)  	/* comparing new reduct to old list */
-                            el1 += size;
-                        el1 = el + size;
-                            el1 += size;
-                        if (!over)
-                            newtail += size;
-                            newcount++;
-                CopySetA(newtail, el);	/* rewriting reduct from old list */
-                newtail += size;
-                newcount++;
-            el += size;
-        newcount = 0;
-        free(oldhead);
-        *reducts = NULL;
-    else
-    free(newhead);
-    CloseSetA(CORE);
Deleted: grass-addons/grass6/raster/mcda/r.roughset/reduct1.h
--- grass-addons/grass6/raster/mcda/r.roughset/reduct1.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/reduct1.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,78 +0,0 @@
- *   	    	 for details.
-int Red(setA * red, int matrix);
-     /* finds all reducts for information system,      */
-     /* sets red to yhe allocated reducts table        */
-     /* function returns number of reducts             */
-int RedRel(setA * red, setA P, setA Q, int matrix_type);
-      /* like Red, but reducts are Q-relative and      */
-      /* computed from set of attributes P             */
-int RedLess(setA * red, int N, int matrix_type);
-      /* finds all reducts which contain less than     */
-      /* N attributes, other parameters and result     */
-      /* like Red                                      */
-int RedRelLess(setA * red, setA P, setA Q, int N, int matrix_type);
-      /* like RedLess, but reducts are Q-relative of P */
-int RedSetA(setA * red, setA quasicore, int matrix_type);
-      /* finds only reducts including quasicore ,      */
-      /* some reducts can be not minimal ( formally    */
-      /* they are not reducts ) , other parameters and */
-      /* result like Red                               */
-int RedRelSetA(setA * red, setA quasicore, setA P, setA Q, int matrix_type);
-      /* like RedSetA, but reducts are Q-relative of P  */
-int RedFirst(setA * red, int N, int matrix_type);
-      /* finds first N reducts ( only quasi-reduct ),  */
-      /* other parameters and result like Red          */
-int RedRelFirst(setA * red, setA P, setA Q, int N, int matrix_type);
-      /* like RedFirst, but reducts are Q-relative of P */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/reduct2.c
--- grass-addons/grass6/raster/mcda/r.roughset/reduct2.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/reduct2.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,236 +0,0 @@
- *   	    	 for details.
-/***              ( AUXILIARY  REDUCTS ROUTINES )                          ***/
-#include "rough.h"
-int RedSingle(setA red, int matrix_type)
-    int i;
-    int cont = 1;
-    setA over;
-    Core(red, matrix_type);
-    for (i = 0; (i < _mainsys->attributes_num) && cont; i++)
-        if (IsCover(red, matrix_type))
-            cont = 0;
-        else
-            AddSetA(red, i);
-    cont = 1;
-    while (cont)
-        if (IsOrtho(red, over, matrix_type))
-            cont = 0;
-        else
-                if (ContSetA(over, i))
-                    DelSetA(red, i);
-                    break;
-    CloseSetA(over);
-    return 1;
-int RedRelSingle(setA red, setA P, setA Q, int matrix_type)
-    int i;
-    int cont = 1;
-    setA over;
-    CoreRel(red, P, Q, matrix_type);
-        if (IsCoverRel(red, P, Q, matrix_type))
-            cont = 0;
-        else
-            AddSetA(red, i);
-    cont = 1;
-    while (cont)
-        if (IsOrthoRel(red, over, P, Q, matrix_type))
-            cont = 0;
-        else
-                    DelSetA(red, i);
-                    break;
-    CloseSetA(over);
-    return 1;
-int RedOptim(setA red, int matrix_type)
-    int max, f, fmax;
-    int i, atr;
-    int cont = 1;
-    setA over;
-    over = InitFullSetA();
-    fmax = CardCoef(over, matrix_type);
-    max = CardCoef(red, matrix_type);
-    while (max < fmax)
-            if (!ContSetA(red, i))
-                AddSetA(red, i);
-                f = CardCoef(red, matrix_type);
-                if (f >= max)
-                    max = f, atr = i;
-                DelSetA(red, i);
-        AddSetA(red, atr);
-    cont = 1;
-    while (cont)
-            cont = 0;
-        else
-                    DelSetA(red, i);
-                    break;
-    CloseSetA(over);
-    return 1;
-int RedRelOptim(setA red, setA P, setA Q, int matrix_type)
-    float max, f, fmax;
-    int i, atr;
-    int cont = 1;
-    setA over;
-    fmax = DependCoef(P, Q, matrix_type);
-    while (cont)
-        max = 0;
-            if (ContSetA(P, i) && !ContSetA(red, i))
-                AddSetA(red, i);
-                f = DependCoef(red, Q, matrix_type);
-                if (f >= max)
-                    max = f, atr = i;
-                DelSetA(red, i);
-        if (max == fmax)
-            cont = 0;
-    cont = 1;
-    while (cont)
-            cont = 0;
-        else
-                    DelSetA(red, i);
-                    break;
-    CloseSetA(over);
-    return 1;
-int RedFew(setA * reds, int matrix_type)
-    setA r;
-    int n;
-    r = InitEmptySetA();
-    RedSingle(r, matrix_type);
-    n = RedLess(reds, CardSetA(r), matrix_type);
-    CloseSetA(r);
-    return n;
-int RedRelFew(setA * reds, setA P, setA Q, int matrix_type)
-    setA r;
-    int n;
-    RedRelSingle(r, P, Q, matrix_type);
-    n = RedRelLess(reds, P, Q, CardSetA(r), matrix_type);
-    CloseSetA(r);
-    return n;
-int SelectOneShort(setA reds, int N)
-    int min, m, i, num = 0;
-    min = _mainsys->attributes_num;
-    for (i = 0, START_OF_MAT(reds, N); END_OF_MAT; i++, NEXT_OF_MAT)
-        if (min > (m = CardSetA(ELEM_OF_MAT)))
-            min = m, num = i;
-    return num;
-int SelectAllShort(setA * newreds, setA reds, int N)
-    int num, m, min;
-    int size = _mainsys->setAsize;
-    min = _mainsys->attributes_num + 1;
-    *newreds = (cluster_type *) malloc(N * size * _cluster_bytes);
-    for (START_OF_MAT(reds, N); END_OF_MAT; NEXT_OF_MAT)
-            min = m;
-            num = 0;
-            CopySetA(*newreds + num * size, ELEM_OF_MAT);
-        else if (min == m)
-            num++;
-    *newreds =
-        (cluster_type *) realloc(*newreds, (num + 1) * size * _cluster_bytes);
-    if (*newreds == 0)
-        num = -1;
-    return num + 1;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/reduct2.h
--- grass-addons/grass6/raster/mcda/r.roughset/reduct2.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/reduct2.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,74 +0,0 @@
- *   	    	 for details.
-/***              (AUXILIARY REDUCTS ROUTINES)                             ***/
-int RedSingle(setA red, int matrix_type);
-	/* heuristicly searches for a single reduct and stores it in red */
-int RedRelSingle(setA red, setA P, setA Q, int matrix_type);
-	/* heuristicly searches for a single Q-relative reduct of P */
-	/* and stores it in red */
-int RedOptim(setA red, int matrix_type);
-	/* dependency coefficient is used to select */
-	/* attributes for search optimization */
-int RedRelOptim(setA red, setA P, setA Q, int matrix_type);
-	/* and stores it in red; dependency coefficient is used to select */
-int RedFew(setA * reds, int matrix_type);
-	/* finds all reducts shortesest or equal in size to the first */
-	/* reduct found by the heuristic algorithm */
-int RedRelFew(setA * reds, setA P, setA Q, int matrix_type);
-	/* finds all Q-relative P-reducts shortesest or equal in size */
-	/* to the first reduct found by the heuristic algorithm */
-int SelectOneShort(setA reds, int num);
-	/* returns index of the single shortest reduct */
-	/* from the table of num reducts pointed by reds */
-int SelectAllShort(setA * newreds, setA reds, int num);
-	/* copies all the shortest reducts */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rerror.h
--- grass-addons/grass6/raster/mcda/r.roughset/rerror.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rerror.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,45 +0,0 @@
- *   	    	 for details.
-/***         OPTIONAL ERROR HANDLING AND ERROR MESSAGES                    ***/
-char *errcodes[10] = { "everything O.K.",
-    "Cannot open file",
-    "Wrong format of file",
-    "Not enough memory",
-    "Cannot write to file",
-    "Matrix A not initialized",
-    "Matrix D not initialized",
-    "Matrix X not initialized",
-    "Wrong matrix type",
-    "Set element out of domain"
-#define ErrorPrint() {printf("ERROR no: %i: %s\n",_rerror,errcodes[_rerror]);_rerror=0;}
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rough.h
--- grass-addons/grass6/raster/mcda/r.roughset/rough.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rough.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,73 +0,0 @@
- *   	    	 for details.
-/***       OBLIGATORY FILE TO INCLUDE IN APPLICATION SOURCE                ***/
-/***             (DATA TYPES, CONSTANTS AND HEADERS)	                   ***/
-/********************* CONSTANTS AND TYPES ***********************************/
-#define MATA 0
-#define MATD 1
-#define MATX 2
-#define ERROR(a)     { _rerror=a; return -a; }
-typedef unsigned int cluster_type;
-typedef unsigned int value_type;
-typedef cluster_type *setO;
-typedef cluster_type *setA;
-typedef struct
-    char name[50];
-    int objects_num;
-    int attributes_num;
-    int descr_size;
-    void *description;
-    int setAsize;
-    int setOsize;
-    value_type *matA;
-    cluster_type *matD;
-    cluster_type *matX;
-    unsigned int matXsize;
-} SYSTEM;
-/************** H-FILES CONTAINING DECLARATIONS OF FUNCTIONS *********/
-#include "rset.h"
-#include "rsystem.h"
-#include "raccess.h"
-#include "rbasic.h"
-#include "rcore.h"
-#include "reduct1.h"
-#include "reduct2.h"
-#include "rule1.h"
-#include "rule2.h"
-#include "rclass.h"
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rset.c
--- grass-addons/grass6/raster/mcda/r.roughset/rset.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rset.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,500 +0,0 @@
- *   	    	 for details.
-/***       OPERATIONS ON SETS OF ATTRIBUTES AND OBJECTS                    ***/
-#include "rough.h"
-int _cluster_bytes = sizeof(cluster_type);
-int _cluster_bits = 8 * sizeof(cluster_type);
-cluster_type _mask[8 * sizeof(cluster_type)];
-setA InitEmptySetA(void)
-    int cluster;
-    setA set;
-    set = (setA) malloc(_mainsys->setAsize * _cluster_bytes);
-        set[cluster] = 0;
-    return set;
-setO InitEmptySetO(void)
-    int cluster;
-    setO set;
-    set = (setA) malloc(_mainsys->setOsize * _cluster_bytes);
-    for (cluster = _mainsys->setOsize - 1; cluster >= 0; cluster--)
-        set[cluster] = 0;
-    return set;
-setA InitFullSetA(void)
-    int attr, cluster;
-    setA set;
-    for (cluster = _mainsys->setAsize - 2; cluster >= 0; cluster--)
-        set[cluster] = ~(cluster_type) 0;
-    set[_mainsys->setAsize - 1] = 0;
-            attr >= _cluster_bits * (_mainsys->setAsize - 1); attr--)
-        AddSetA(set, attr);
-    return set;
-setO InitFullSetO(void)
-    int cluster, attr;
-    setO set;
-    for (cluster = _mainsys->setOsize - 2; cluster >= 0; cluster--)
-    set[_mainsys->setOsize - 1] = 0;
-    for (attr = _mainsys->objects_num - 1;
-            attr >= _cluster_bits * (_mainsys->setOsize - 1); attr--)
-        AddSetO(set, attr);
-    return set;
-void TabToSetA(setA set, int num, int tab[])
-    int atr;
-    ClearSetA(set);
-    for (atr = 0; atr < num; atr++)
-        AddSetA(set, tab[atr]);
-void TabToSetO(setO set, int num, int tab[])
-    int obj;
-    ClearSetO(set);
-    for (obj = 0; obj < num; obj++)
-        AddSetO(set, tab[obj]);
-void ArgToSetA(setA set, int num, ...)
-    int atr;
-    va_list list;
-    ClearSetA(set);
-    va_start(list, num);
-        AddSetA(set, va_arg(list, int));
-    va_end(list);
-void ArgToSetO(setO set, int num, ...)
-    int obj;
-    va_list list;
-    ClearSetO(set);
-        AddSetO(set, va_arg(list, int));
-    va_end(list);
-void CloseSetA(setA set)
-    free(set);
-void CloseSetO(setA set)
-    free(set);
-void OrSetO(setO or, setO s1, setO s2)
-    int cluster;
-        or[cluster] = s1[cluster] | s2[cluster];
-    return;
-void OrSetA(setA or, setA s1, setA s2)
-    int cluster;
-    return;
-void AndSetO(setO and, setO s1, setO s2)
-    int cluster;
-        and[cluster] = s1[cluster] & s2[cluster];
-    return;
-void AndSetA(setA and, setA s1, setA s2)
-    int cluster;
-    return;
-void DifSetO(setO dif, setO s1, setO s2)
-    int cluster;
-        dif[cluster] = s1[cluster] & ~s2[cluster];
-    return;
-void DifSetA(setA dif, setA s1, setA s2)
-    int cluster;
-    return;
-void NotSetO(setO not, setO set)
-    int cluster, obj;
-        not[cluster] = ~set[cluster];
-    cluster = _mainsys->setOsize - 1;
-    for (obj =
-                _mainsys->objects_num - 1 - _cluster_bits * (_mainsys->setOsize - 1);
-            obj >= 0; obj--)
-        if (set[cluster] & _mask[obj])
-            not[cluster] &= ~_mask[obj];
-        else
-            not[cluster] |= _mask[obj];
-    return;
-void NotSetA(setA not, setA set)
-    cluster = _mainsys->setAsize - 1;
-    for (attr =
-                _mainsys->attributes_num - 1 - _cluster_bits * (_mainsys->setAsize -
-                        1); attr >= 0;
-            attr--)
-        if (set[cluster] & _mask[attr])
-            not[cluster] &= ~_mask[attr];
-        else
-            not[cluster] |= _mask[attr];
-    return;
-void ClearSetO(setO set)
-    int cluster;
-        set[cluster] = 0;
-    return;
-void ClearSetA(setA set)
-    int cluster;
-        set[cluster] = 0;
-    return;
-void FillSetO(setO set)
-    int cluster, obj;
-    for (obj = _mainsys->objects_num - 1;
-            obj >= _cluster_bits * (_mainsys->setOsize - 1); obj--)
-        AddSetO(set, obj);
-    return;
-void FillSetA(setA set)
-    return;
-int AddSetO(setO set, int obj)
-    if (obj >= _mainsys->objects_num)
-        ERROR(9)
-        set[obj / _cluster_bits] |= _mask[obj % _cluster_bits];
-    return 0;
-int AddSetA(setA set, int attr)
-    if (attr >= _mainsys->attributes_num)
-        ERROR(9)
-        set[attr / _cluster_bits] |= _mask[attr % _cluster_bits];
-    return 0;
-int DelSetO(setO set, int obj)
-        ERROR(9)
-        set[obj / _cluster_bits] &= ~_mask[obj % _cluster_bits];
-    return 0;
-int DelSetA(setA set, int attr)
-        ERROR(9)
-        set[attr / _cluster_bits] &= ~_mask[attr % _cluster_bits];
-    return 0;
-int InSetO(setO big, setO small)
-    int cluster;
-        if (big[cluster] != (big[cluster] | small[cluster]))
-            return 0;
-    return 1;
-int InSetA(setA big, setA small)
-    int cluster;
-            return 0;
-    return 1;
-int ContSetA(setA set, int attr)
-        ERROR(9)
-        return (_mask[attr % _cluster_bits] & set[attr / _cluster_bits]);
-int ContSetO(setO set, int obj)
-        ERROR(9)
-        return (_mask[obj % _cluster_bits] & set[obj / _cluster_bits]);
-int InterSetO(setO s1, setO s2)
-    int cluster;
-        if (s1[cluster] & s2[cluster])
-            return 1;
-    return 0;
-int InterSetA(setA s1, setA s2)
-    int cluster;
-            return 1;
-    return 0;
-int IsEmptySetO(setO set)
-    int cluster;
-        if (set[cluster])
-            return 0;
-    return 1;
-int IsEmptySetA(setA set)
-    int cluster;
-        if (set[cluster])
-            return 0;
-    return 1;
-int CardSetO(setO set)
-    int obj, card = 0;
-    for (obj = _mainsys->objects_num - 1; obj >= 0; obj--)
-        if (ContSetO(set, obj))
-            card++;
-    return card;
-int CardSetA(setA set)
-    int cluster, attr, card = 0;
-        for (attr = _cluster_bits - 1; attr >= 0; attr--)
-            if (_mask[attr] & set[cluster])
-                card++;
-    for (attr =
-                        1); attr >= 0;
-            attr--)
-            card++;
-    return card;
-void CopySetO(setO dest, setO source)
-    int cluster;
-        dest[cluster] = source[cluster];
-    return;
-void CopySetA(setA dest, setA source)
-    int cluster;
-    return;
-int CompSetO(setO set1, setO set2)
-    int cluster;
-        if (set1[cluster] != set2[cluster])
-            return 0;
-    return 1;
-int CompSetA(setA set1, setA set2)
-    int cluster;
-            return 0;
-    return 1;
-int SizeSetO(void)
-    return _mainsys->setOsize;
-int SizeSetA(void)
-    return _mainsys->setAsize;
-void AttrValSetO(setO set, int attr, value_type val)
-    int obj;
-    ClearSetO(set);
-        if (val == GetA(obj, attr))
-int ClassSetO(setO aclass, int obj, setA Q)
-    int i;
-    ClearSetO(aclass);
-        if (CompareA(i, obj, Q))
-            AddSetO(aclass, i);
-    return 0;
-void PrintSetO(setO set)
-    int obj, i = 0;
-    printf("{");
-            printf("%c%i", (i++ > 0 ? ',' : ' '), obj);
-    printf(" }\n");
-void PrintSetA(setA set)
-    int attr, i = 0;
-    printf("{");
-        if (ContSetA(set, attr))
-            printf("%c%i", (i++ > 0 ? ',' : ' '), attr);
-    printf(" }\n");
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rset.h
--- grass-addons/grass6/raster/mcda/r.roughset/rset.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rset.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,165 +0,0 @@
- * MODULE:       r.roughset
- * AUTHOR(S):    GRASS module authors ad Rough Set Library (RSL) maintain:
- *					G.Massei (g_massa at libero.it)-A.Boggia (boggia at unipg.it)
- *				 Rough Set Library (RSL) ver. 2 original develop:
- *		         	M.Gawrys - J.Sienkiewicz
- * PURPOSE:      Geographics rough set analisys and knowledge discovery
- *               This program is free software under the GNU General Public
- *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 for details.
-#include <stdarg.h>
-extern cluster_type _mask[];
-extern int _cluster_bytes;
-extern int _cluster_bits;
-setO InitEmptySetO(void);
-setA InitEmptySetA(void);
-	/* allocates memory for set and initializes it */
-	/* as empty, returns allocated set */
-setO InitFullSetO(void);
-setO InitFullSetA(void);
-	/* as full, returns newly allocated set */
-void TabToSetO(setO set, int num, int tab[]);
-void TabToSetA(setA set, int num, int tab[]);
-	/* sets a set with num elements of table tab */
-void ArgToSetO(setO set, int num, ...);
-void ArgToSetA(setA set, int num, ...);
-	/* sets a set with num arguments of function */
-void CloseSetO(setO set);
-void CloseSetA(setA set);
-	/* free memory used by set */
-void OrSetO(setO or, setO s1, setO s2);
-void OrSetA(setA or, setA s1, setA s2);
-	/* puts union of s1 and s2 to or */
-void AndSetO(setO and, setO s1, setO s2);
-void AndSetA(setA and, setA s1, setA s2);
-	/* puts product of s1 and s2 to and */
-void DifSetO(setO dif, setO s1, setO s2);
-void DifSetA(setA dif, setA s1, setA s2);
-	/* puts complement of s1 in s2 to dif */
-void NotSetO(setO not, setO set);
-void NotSetA(setO not, setA set);
-	/* puts a complement of set to not */
-void ClearSetO(setO set);
-void ClearSetA(setA set);
-	/* clears set */
-void FillSetO(setO set);
-void FillSetA(setA set);
-	/* fills set with domain */
-int AddSetO(setO set, int obj);
-int AddSetA(setA set, int attr);
-	/* adds element to set */
-int DelSetO(setO set, int obj);
-int DelSetA(setA set, int attr);
-	/* deletes element from set */
-int InSetO(setO big, setO small);
-int InSetA(setA big, setA small);
-	/* return 1 if set big contains set small */
-int ContSetO(setO set, int obj);
-int ContSetA(setA set, int attr);
-	/* returns 1 if set contains element */
-int InterSetO(setO s1, setO s2);
-int InterSetA(setA s1, setA s2);
-	/* returns 1 if s1 and s2 have nonempty product */
-int IsEmptySetO(setO set);
-int IsEmptySetA(setA set);
-	/* returns 1 if set is empty */
-int CardSetO(setO set);
-int CardSetA(setA set);
-	/* returns cardinality of set */
-void CopySetO(setO dest, setO source);
-void CopySetA(setA dest, setO source);
-	/* copy source to dest */
-int CompSetO(setO set1, setO set2);
-int CompSetA(setA set1, setA set2);
-	/* returns 1 if set1 and set2 are identical */
-int SizeSetO(void);
-int SizeSetA(void);
-	/* returns number of clusters in set representation */
-	/* in the active system sizeof(cluster_type)=_cluster_bytes */
-void AttrValSetO(setO set, int attr, value_type val);
-	/* puts into set all object that have value val */
-	/* on attribute attr */
-int ClassSetO(setO aclass, int obj, setA Q);
-	/* fills class with all object that have the same values */
-	/* on all attributes from Q as the object obj, uses MATA */
-void PrintSetO(setO set);
-void PrintSetA(setA set);
-	/* outputs set to screen */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rsystem.c
--- grass-addons/grass6/raster/mcda/r.roughset/rsystem.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rsystem.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,564 +0,0 @@
- * AUTHOR(S):    GRASS module authors and Rough Set Library (RSL) maintain:
- * COPYRIGHT:    (C) A.Boggia - G.Massei (2008)
- *   	    	 for details.
-/***                SYSTEM HANDLING FUNCTIONS                              ***/
-#include <stdlib.h>
-#include <string.h>
-#include <ctype.h>
-#include "rough.h"
-SYSTEM  *_mainsys=NULL;
-int      _rerror=0;
-SYSTEM  *InitEmptySys(void)
-    SYSTEM *sys;
-    int i;
-    cluster_type mask=1;
-    if ((sys=(SYSTEM *)malloc(sizeof(SYSTEM)))==NULL)
-        _rerror=3;
-        return NULL;
-    for (i=0; i<_cluster_bits; i++)
-        _mask[i]=mask;
-        mask <<= 1;
-    sys->attributes_num=0;
-    sys->objects_num=0;
-    sys->description=NULL;
-    sys->descr_size=0;
-    sys->setAsize=0;
-    sys->setOsize=0;
-    sys->matA=NULL;
-    sys->matD=NULL;
-    sys->matX=NULL;
-    sys->matXsize=0;
-    return sys;
-void SetParameters(SYSTEM *sys,int obj_num,int attr_num)
-    sys->attributes_num=attr_num;
-    sys->objects_num=obj_num;
-    sys->setAsize=1+(attr_num-1)/_cluster_bits;
-    sys->setOsize=1+(obj_num-1)/_cluster_bits;
-void ConnectDescr(SYSTEM *sys,void *descr,int size)
-    sys->description=descr;
-    sys->descr_size=size;
-void SetName(SYSTEM *sys,char *name)
-    strncpy(sys->name,name,50);
-int FileToSys(SYSTEM *sys,char *filename)
-    FILE *source;
-    value_type *buf;
-    int descr_size,matAsize;
-    long len1,len2;
-    char string[50];
-    int c,n=0;
-    if (sys->matA!=NULL)
-        free(sys->matA);
-        sys->matA=NULL;
-    if (sys->matD!=NULL)
-        free(sys->matD);
-        sys->matD=NULL;
-    if (sys->matX!=NULL)
-        free(sys->matX);
-        sys->matX=NULL;
-    if (sys->description!=NULL)
-        free(sys->description);
-    if ((source=fopen(filename,"r"))==NULL)
-        ERROR(1)
-        if (!fscanf(source,"NAME%c",string))
-            ERROR(2)
-            if (string[0]!=':') ERROR(2)
-                if (!fgets(sys->name,48,source))
-                    ERROR(2)
-                    if (sys->name[strlen(sys->name)-1]=='\n')
-                        sys->name[strlen(sys->name)-1]='\0';
-                    else
-                        while (fgetc(source)!='\n' && !feof(source));
-    if (!fscanf(source,"ATTRIBUTES:%i\n",&(sys->attributes_num)))
-        ERROR(2)
-        if (!fscanf(source,"OBJECTS:%i\n",&(sys->objects_num)))
-            ERROR(2)
-            sys->setAsize=1+(sys->attributes_num-1)/_cluster_bits;
-    sys->setOsize=1+(sys->objects_num-1)/_cluster_bits;
-    matAsize=(sys->objects_num)*(sys->attributes_num);
-    if ((buf=(value_type*)(setA)malloc(sizeof(value_type)*matAsize))==NULL)
-        ERROR(3)
-        while (!feof(source) && n<matAsize)
-            if (fscanf(source,"%s",string)==NULL)
-                ERROR(2)
-                else if (string[0]=='?' || string[0]=='*')
-                    buf[n++]=(value_type)-1;
-                else if (sscanf(string,"%d",&c)==NULL)
-                    ERROR(2)
-                    else buf[n++]=(value_type)c;
-    sys->matA=buf;
-    while (isspace(fgetc(source)));
-    if (!feof(source))
-        len1=ftell(source)-1;
-        fseek(source,0l,SEEK_END);
-        len2=ftell(source);
-        fseek(source,len1,SEEK_SET);
-        descr_size=(int)(len2-len1);
-        buf=(value_type *)(setA)malloc(descr_size);
-        fread(buf,sizeof(char),descr_size,source);
-        sys->description=buf;
-        sys->descr_size=descr_size;
-    fclose(source);
-    return 1;
-void ConnectA(SYSTEM *sys,value_type *buf)
-    sys->matA=buf;
-void PutA(SYSTEM *sys,int obj,int atr,value_type val)
-    (sys->matA)[obj*(sys->attributes_num)+atr]=val;
-int FillAfromAscii(SYSTEM *sys,FILE *file)
-    int k=0,j;
-    while (!feof(file)&&(k<Asize(sys)))
-        if (fscanf(file,"%d",&j)==NULL) ERROR(2);
-        *(sys->matA+k++)=j;
-    return 0;
-int InitD(SYSTEM *sys)
-    cluster_type *buf;
-    int nby=(sys->attributes_num)/_cluster_bits; /* number of full clusters in element of tableD */
-    int nbi=sys->attributes_num%_cluster_bits;   /* number of bits in the last cluster */
-    int atrnum=sys->attributes_num;  		/* number of attributes */
-    int row,column,cluster,bit;
-    value_type *A=sys->matA;
-    cluster_type val,*ptr;
-    if (A==NULL)
-        ERROR(5);
-    if ((buf=(setA)malloc(MatMemSize(sys,MATD)))==NULL)
-        ERROR(3);
-    ptr=buf;
-    for (row=1;row<sys->objects_num;row++)
-        for (column=0;column<row;column++)
-            for (cluster=0;cluster<nby;cluster++)
-                val=0;
-                for (bit=0;bit<_cluster_bits;bit++)
-                    if (A[row*atrnum+_cluster_bits*cluster+bit]!=A[column*atrnum+_cluster_bits*cluster+bit] &&
-                            A[row*atrnum+_cluster_bits*cluster+bit]!=(value_type)-1  &&
-                            A[column*atrnum+_cluster_bits*cluster+bit]!=(value_type)-1  )
-                        val=val|_mask[bit];
-                *ptr=val;
-                ptr++;
-            if (nbi)
-                val=0;
-                for (bit=0;bit<nbi;bit++)
-                *ptr=val;
-                ptr++;
-    sys->matD=buf;
-    return MatMemSize(sys,MATD);
-int InitX(SYSTEM* sys,setA P,setA Q,int matrix_type)
-    setA head,tail,el,el1;
-    int  memo=1,count=0,no,dif,size,MEMOKWANT=Asize(_mainsys);
-    size=_mainsys->setAsize;
-    if ((head=(setA)malloc(MEMOKWANT))==NULL) ERROR(3);
-    tail=head;
-    el=InitEmptySetA();
-    for (start_of_tab(matrix_type);end_of_tab();next_of_tab())
-        if ( !InterSetA(_table_element,Q) ) continue;
-        AndSetA(el,P,_table_element);
-        if ( IsEmptySetA(el) ) continue;
-        no=0;
-        dif=0;
-        for (el1=head;el1<tail;el1+=size)
-            if (InSetA(el,el1))
-                no=1;
-                break;
-            else
-                if (InSetA(el1,el))  dif+=size,count--;
-                else if (dif) CopySetA(el1-dif,el1);
-        if (!no)
-            if ((memo*MEMOKWANT)<((count+1)*size*_cluster_bytes))
-                if ((head=(setA)realloc(head,++memo*MEMOKWANT))==NULL)
-                    CloseSetA(el);
-                    ERROR(3);
-            CopySetA(head+count*size,el);
-            count++;
-            tail=head+count*size;
-    CloseSetA(el);
-    if ((head=(setA)realloc(head,count*size*_cluster_bytes))==NULL) ERROR(3);
-    sys->matX=head;
-    sys->matXsize=count*size;
-    return(count);
-int InitXforObject(SYSTEM* sys,int obj,setA P,setA Q,int matrix_type)
-    int  memo=1,count=0,no,dif,MEMOKWANT=Asize(_mainsys);
-    int size=_mainsys->setAsize;
-    int obj2;
-        ERROR(3);
-    tail=head;
-    for (obj2=0; obj2<_mainsys->objects_num; obj2++)
-        if ( obj==obj2 ) continue;
-        if ( matrix_type==MATA ) GetDfromA( el, obj, obj2 );
-        else
-            _table_element=GetD( obj, obj2 );
-            CopySetA( el, _table_element );
-        if ( !InterSetA(el,Q) ) continue;
-        AndSetA(el,P,el);
-        no=0;
-        dif=0;
-                no=1;
-                break;
-            else
-        if (!no)
-                    CloseSetA(el);
-                    ERROR(3);
-            count++;
-    CloseSetA(el);
-        if (count>0) ERROR(3);
-    sys->matX=head;
-    return(count);
-int InitXforObjects(SYSTEM* sys,setO objects,setA P,setA Q,int matrix_type)
-    tail=head;
-        if ( !ContSetO(objects,_table_row) &&
-                !ContSetO(objects,_table_column) ) continue;
-        no=0;
-        dif=0;
-                no=1;
-                break;
-            else
-        if (!no)
-                    CloseSetA(el);
-                    ERROR(3);
-            count++;
-    CloseSetA(el);
-    sys->matX=head;
-    return(count);
-int InitXforObjectFromClass(SYSTEM* sys,int obj,setA P,setO aclass,int matrix_type)
-    int obj2;
-    tail=head;
-        if ( ContSetO( aclass, obj2 ) ) continue;
-        else
-        AndSetA(el,P,el);
-        no=0;
-        dif=0;
-                no=1;
-                break;
-            else
-        if (!no)
-                    CloseSetA(el);
-                    ERROR(3);
-            count++;
-    CloseSetA(el);
-    sys->matX=head;
-    return(count);
-void UseSys(SYSTEM *sys)
-    _mainsys=sys;
-int SysToFile(SYSTEM *sys,char *filename)
-    FILE *output;
-    int attr,obj;
-    if ((output=fopen(filename,"wb"))==NULL)
-        ERROR(1)
-        if (!fprintf(output,"NAME: %s\n",sys->name))
-            ERROR(4)
-            if (!fprintf(output,"ATTRIBUTES: %i\n",sys->attributes_num))
-                ERROR(4);
-    if (!fprintf(output,"OBJECTS: %i\n\n",sys->objects_num))
-        ERROR(4);
-    for (obj=0;obj<sys->objects_num;obj++)
-        for (attr=0;attr<sys->attributes_num;attr++)
-            if (sys->matA[obj*sys->attributes_num+attr]==(value_type)-1 )
-                if (!fprintf(output,"%c ",'?'))
-                    ERROR(4)
-            else if (!fprintf(output,"%i ",sys->matA[obj*sys->attributes_num+attr]))
-                ERROR(4)
-                fprintf(output,"\n");
-    if (sys->descr_size!=0)
-        fwrite(sys->description,sizeof(char),sys->descr_size,output);
-    fclose(output);
-    return 1;
-void CloseSys(SYSTEM *sys)
-    if (sys->matA) free(sys->matA);
-    if (sys->matD) free(sys->matD);
-    if (sys->matX) free(sys->matX);
-    if (sys->description) free(sys->description);
-    free(sys);
-void CloseMat(SYSTEM *sys, int matrix_type)
-    case (MATA): if (sys->matA) free(sys->matA);
-        sys->matA=NULL;
-        return;
-    case (MATD): if (sys->matD) free(sys->matD);
-        sys->matD=NULL;
-        return;
-    case (MATX): if (sys->matX) free(sys->matX);
-        sys->matX=NULL;
-        return;
-    default:
-        _rerror=8;
-void DisconMat(SYSTEM *sys, int matrix_type)
-    case (MATA): sys->matA=NULL;
-        return;
-    case (MATD): sys->matD=NULL;
-        return;
-    case (MATX): sys->matX=NULL;
-        return;
-    default:
-        _rerror=8;
-unsigned int Asize(SYSTEM *sys)
-    return  (unsigned int)(sys->attributes_num)
-            *(unsigned int)(sys->objects_num);
-unsigned int Dsize(SYSTEM *sys)
-    return  (unsigned int)(sys->objects_num-1)
-            *(unsigned int)(sys->objects_num)/2
-            *(unsigned int)(sys->setAsize);
-unsigned int Xsize(SYSTEM *sys)
-    return sys->matXsize;
-unsigned int MatMemSize(SYSTEM *sys,int matrix_type)
-    case (MATA): return Asize(sys)*sizeof(value_type);
-    case (MATD): return Dsize(sys)*sizeof(cluster_type);
-    case (MATX): return Xsize(sys)*sizeof(cluster_type);
-    ERROR(8)
-void *MatExist(SYSTEM *sys,int matrix_type)
-    case (MATA): return (void *)sys->matA;
-    case (MATD): return (void *)sys->matD;
-    case (MATX): return (void *)sys->matX;
-    _rerror=8;
-    return NULL;
-int ObjectsNum(SYSTEM *sys)
-    return sys->objects_num ;
-int AttributesNum(SYSTEM *sys)
-    return sys->attributes_num;
-void *Description(SYSTEM *sys)
-    return sys->description;
-char *SysName(SYSTEM *sys)
-    return sys->name;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rsystem.h
--- grass-addons/grass6/raster/mcda/r.roughset/rsystem.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rsystem.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,172 +0,0 @@
- * COPYRIGHT:    (C) GRASS Development Team (2008)
- *   	    	 for details.
-/*** part of the RSL system written by M.Gawrys J.Sienkiewicz              ***/
-#include <stdio.h>
-extern SYSTEM *_mainsys;
-	/* active information system */
-extern int _rerror;
-	/* error code */
-SYSTEM *InitEmptySys(void);
-	/* allocates memory for a new system descriptor */
-	/* and clears all parameters, no matrices connected */
-void SetParameters(SYSTEM * sys, int objects_num, int attributes_num);
-	/* puts system parameters to the system descriptor */
-void ConnectDescr(SYSTEM * sys, void *descr, int size);
-	/* connects additional description to the system descriptor */
-void SetName(SYSTEM * sys, char *name);
-	/* puts system name to the system descriptor */
-int FileToSys(SYSTEM * sys, char *filename);
-	/* imports system from the special format file */
-	/* including parameters, desicripton and matrix A */
-	/* other matrices are left uninitialed */
-int SysToFile(SYSTEM * sys, char *filename);
-	/* exports system descriptor, additional description */
-	/* and matrix A to a special format file */
-void ConnectA(SYSTEM * sys, value_type * buf);
-	/* connects matrix A (it may be empty) with */
-	/* the system descriptor */
-void PutToA(SYSTEM * sys, int object, int attribute, value_type value);
-	/* sets value to element of matrix A */
-int FillAfromAscii(SYSTEM * sys, FILE * file);
-	/* fills matrix A with the values from Ascii file */
-int InitD(SYSTEM * sys);
-	/* fills matrix D from A, allocates memory  */
-	/* and connects it with the system descriptor */
-	/* matrix A must already exist */
-int InitX(SYSTEM * sys, setA P, setA Q, int matrix_type);
-	/* fills matrix X, allocates memory for it and */
-	/* connects it with the system descriptor */
-	/* matrix_type indicates the source matrix */
-	/* initialization is done with respect to Q from P */
-int InitXforObject(SYSTEM * sys, int obj, setA P, setA Q, int matrix_type);
-	/* works like InitX but considers only single column of MATD */
-int InitXforObjects(SYSTEM * sys, setO objects, setA P, setA Q,
-		    int matrix_type);
-	/* works like InitX but concider only columns of MATD */
-	/* belonging to objects */
-int InitXforObjectFromClass(SYSTEM * sys, int obj, setA P, setO aclass,
-			    int matrix_type);
-	/* works like InitX, conciders only specified objects */
-	/* initialization is done with respect to objects from */
-	/* outside of aclass */
-void UseSys(SYSTEM * sys);
-	/* makes indicated system active, from now on */
-	/* all query routines will operate only on it */
-void CloseSys(SYSTEM * sys);
-	/* frees memory allocated for all matrixes, */
-	/* system descriptor and additional description */
-void CloseMat(SYSTEM * sys, int matrix_type);
-	/* disconnects matrix X from the system descriptor */
-	/* and frees memory  */
-void DisconMat(SYSTEM * sys, int matrix_type);
-	/* disconnects matrix from the system descriptor */
-	/* does not free memory */
-unsigned int Asize(SYSTEM * sys);
-	/* returns number of elements in matrix A */
-	/* memory size = Asize * sizeof(value_type) */
-	/* system parameters should be valued */
-unsigned int Dsize(SYSTEM * sys);
-	/* returns number of memory clusters for matrix D */
-	/* memory size = Dsize * sizeof(cluster_type) */
-unsigned int Xsize(SYSTEM * sys);
-	/* returns number of memory cluster used by matrix X */
-	/* memory size = Xsize * sizeof(cluster_type) */
-	/* matrix X should be generated */
-unsigned int MatMemSize(SYSTEM * sys, int matrix_type);
-	/* returns the size of memory used by specified matrix */
-void *MatExist(SYSTEM * sys, int matrix_type);
-	/* return specified matrix if exist */
-	/* otherwise returns NULL */
-int ObjectsNum(SYSTEM * sys);
-	/* returns number of objects in the system */
-int AttributesNum(SYSTEM * sys);
-	/* returns number of attributes in the system */
-void *Description(SYSTEM * sys);
-	/* returns pointer to additional description */
-char *SysName(SYSTEM * sys);
-	/* returns system name */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rule1.c
--- grass-addons/grass6/raster/mcda/r.roughset/rule1.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rule1.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,55 +0,0 @@
- *   	    	 for details.
-/***                   ( MENAGING RULES )                                  ***/
-/*** part of the ROUGH system written by M.Gawrys J.Sienkiewicz            ***/
-#include "rough.h"
-void RuleCopy(value_type * dest, value_type * source)
-    memcpy(dest, source, _mainsys->attributes_num * sizeof(value_type));
-int RuleEQ(value_type * first, value_type * second)
-    return !memcmp(first, second,
-                   _mainsys->attributes_num * sizeof(value_type));
-void AddRule(value_type * rules, int *count, value_type * rule)
-    int i;
-    int size = _mainsys->attributes_num;
-    for (i = 0; i < *count; i++)
-        if (RuleEQ(rules + i * size, rule))
-            return;
-    RuleCopy(rules + (*count) * size, rule);
-    *count += 1;
-    return;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rule1.h
--- grass-addons/grass6/raster/mcda/r.roughset/rule1.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rule1.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,48 +0,0 @@
- *   	    	 for details.
-#define MINUS ((value_type)-1)
-void RuleCopy(value_type * dest, value_type * source);
-	/* copies a rule from source to dest */
-int RuleEQ(value_type * first, value_type * second);
-	/* returns 1 if first rule is equal to second */
-void AddRule(value_type * rules, int *size, value_type * rule);
-	/* adds new rule to array of rules */
-	/* if the rule is unique size is incremented */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rule2.c
--- grass-addons/grass6/raster/mcda/r.roughset/rule2.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rule2.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,666 +0,0 @@
- *   	    	 for details.
-/***                   ( FINDING RULES )                                   ***/
-#include "rough.h"
-int AllRules(value_type ** rules, setA P, setA Q, int matrix_type)
-    int obj, attr, n, red;
-    int memo = _mainsys->objects_num;
-    int count = 0;
-    setA reducts = NULL;
-    value_type *rule = NULL;
-    *rules =
-        (value_type *) malloc(memo * _mainsys->attributes_num *
-                              sizeof(value_type));
-    if (*rules == NULL)
-        ERROR(3);
-    if (!MatExist(_mainsys, MATA))
-        ERROR(5);
-    rule =
-        (value_type *) malloc(_mainsys->attributes_num * sizeof(value_type));
-    if (rule == NULL)
-        ERROR(3);
-        if (InitXforObject(_mainsys, obj, P, Q, matrix_type) < 0)
-            free(rule);
-        else if (!MatExist(_mainsys, MATX))
-            continue;
-        n = Red(&reducts, MATX);
-        CloseMat(_mainsys, MATX);
-        if (memo < count + n)
-            memo = count + n;
-            if ((*rules = (value_type *) realloc(*rules,
-                                                 memo *
-                                                 sizeof(value_type))) ==
-                    NULL)
-                free(reducts);
-                free(rule);
-                ERROR(3)
-        for (red = 0; red < n; red++)
-                if (ContSetA(reducts + red * size, attr) || ContSetA(Q, attr))
-                    rule[attr] = GetA(obj, attr);
-                else
-                    rule[attr] = MINUS;
-            AddRule(*rules, &count, rule);
-        if (n > 0)
-            free(reducts);
-        reducts = NULL;
-    free(rule);
-                  (*rules,
-                   count * _mainsys->attributes_num * sizeof(value_type))) == NULL)
-        ERROR(3);
-    return count;
-int AllRulesForReducts(value_type ** rules, cluster_type * reducts,
-                       int N, setA Q, int matrix_type)
-    int red, num, i, count = 0;
-    value_type *newrules = NULL;	/* rules for a single reduct */
-    *rules = NULL;
-    for (red = 0; red < N; red++)
-        num =
-            AllRules(&newrules, reducts + red * _mainsys->setAsize, Q,
-                     matrix_type);
-        if ((*rules =
-                    (value_type *) realloc(*rules,
-                                           (count +
-                                            num) * _mainsys->attributes_num *
-                                           sizeof(value_type))) == NULL)
-            free(newrules);
-            ERROR(3)
-        for (i = 0; i < num; i++)
-            AddRule(*rules, &count, newrules + i * _mainsys->attributes_num);
-        if (num > 0)
-            free(newrules);
-        newrules = NULL;
-                  (*rules,
-        ERROR(3);
-    return count;
-int SelectRules(value_type ** rules, int *N, setO set, setA P, int option)
-    int i, j, obj, find, newXsize,
-    newN = 0, next = -1, size = _mainsys->attributes_num;
-    setA red, newfull;
-    SYSTEM *oldsys = _mainsys, *newsys = InitEmptySys();
-    cluster_type *newX;
-    value_type *newrules;
-    SetParameters(newsys, *N, *N);
-    newXsize = CardSetO(set) * (newsys->setAsize);
-    newX = (cluster_type *) calloc(newXsize, _cluster_bytes);
-    if (newX == NULL)
-        CloseSys(newsys);
-        ERROR(3);
-            for (i = 0, next++; i < *N; i++)
-                find = 1;
-                for (j = 0; j < _mainsys->attributes_num; j++)
-                        continue;
-                    if ((*rules + i * size)[j] != GetA(obj, j))
-                        if ((*rules + i * size)[j] != MINUS)
-                            find = 0;
-                            break;
-                if (find)
-                    newX[next * newsys->setAsize + i / _cluster_bits] |=
-                        _mask[i % _cluster_bits];
-    UseSys(newsys);
-    newsys->matX = newX;
-    newsys->matXsize = newXsize;
-    newfull = InitFullSetA();
-    InitX(newsys, newfull, newfull, MATX);
-    free(newX);
-    CloseSetA(newfull);
-    if (_rerror != 0)
-        free(newsys);
-        UseSys(oldsys);
-        ERROR(3);
-    if (option == BESTOPT)
-        i = Red(&red, MATX);
-        j = SelectOneShort(red, i);
-    else
-        red = InitEmptySetA();
-        RedOptim(red, MATX);
-        j = 0;
-    newN = CardSetA(red + j * newsys->setAsize);
-    newrules = (value_type *) malloc(newN * oldsys->attributes_num *
-    if (newrules == NULL)
-        CloseSys(newsys);
-        UseSys(oldsys);
-        ERROR(3);
-    for (i = 0, obj = 0; i < *N; i++)
-        if (ContSetA(red + j * newsys->setAsize, i))
-            memcpy(newrules + obj++ * oldsys->attributes_num,
-                   *rules + i * oldsys->attributes_num,
-                   oldsys->attributes_num * sizeof(value_type));
-        free(red);
-    else
-        CloseSetA(red);
-    if (*N > 0)
-        free(*rules);
-    *N = newN;
-    *rules = newrules;
-    UseSys(oldsys);
-    CloseSys(newsys);
-    return 0;
-int BestRules(value_type ** rules, setA P, setA Q, int matrix_type)
-    int i, obj, num = 0,	/* total number of rules */
-                      classnum = 0;		/* number of rules for class */
-    setO processed,		/* already covered objects */
-    newclass;			/* class */
-    value_type *classrules = NULL;	/* rules for a single class */
-    *rules = (value_type *) malloc(Asize(_mainsys) * sizeof(value_type));
-        ERROR(3);
-        ERROR(5);
-    processed = InitEmptySetO();
-    newclass = InitEmptySetO();
-    for (obj = 0; obj < _mainsys->objects_num; obj++)
-        if (!ContSetO(processed, obj))
-            ClassSetO(newclass, obj, Q);
-            classnum = 0;
-            OrSetO(processed, processed, newclass);
-            classnum =
-                BestRulesForClass(&classrules, newclass, P, Q, matrix_type);
-            for (i = 0; i < classnum; i++)
-                AddRule(*rules, &num,
-                        classrules + i * _mainsys->attributes_num);
-            if (classnum > 0)
-                free(classrules);
-            classrules = NULL;
-    CloseSetO(processed);
-    CloseSetO(newclass);
-                                         num * _mainsys->attributes_num *
-        ERROR(3);
-    return num;
-int BestRulesForClass(value_type ** rules, setO set, setA P, setA Q,
-                      int matrix_type)
-    int n, attr, obj, red, num = 0;	/* total number of rules */
-    setA fewred = NULL,		/* selected reducts */
-                  allred = NULL;		/* all reducts */
-    value_type *rule = NULL;	/* single rule */
-    *rules = NULL;
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-                free(rule);
-                continue;
-            n = Red(&allred, MATX);
-            if (n > 0)
-                n = SelectAllShort(&fewred, allred, n);
-                free(allred);
-            else
-                free(rule);
-                          (*rules,
-                           (n +
-                            num) * _mainsys->attributes_num * sizeof(value_type))) ==
-                    NULL)
-                free(rule);
-                free(fewred);
-                    if (ContSetA(fewred + red * size, attr) ||
-                            ContSetA(Q, attr))
-                    else
-                AddRule(*rules, &num, rule);
-    if (n > 0)
-        free(fewred);
-    free(rule);
-    if (SelectRules(rules, &num, set, P, BESTOPT) < 0)
-                  (*rules,
-                   num * _mainsys->attributes_num * sizeof(value_type))) == NULL)
-        ERROR(3);
-    return num;
-int Rules(value_type ** rules, setA P, setA Q, int matrix_type)
-    value_type *rule = NULL,	/* single rule */
-                       *classrules = NULL;	/* rules for class */
-        ERROR(3);
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-            classnum = 0;
-            classnum =
-                RulesForClass(&classrules, newclass, P, Q, matrix_type);
-            if (classnum > 0)
-                free(classrules);
-    free(rule);
-                  (*rules,
-        ERROR(3);
-    return num;
-int RulesForClass(value_type ** rules, setO set, setA P, setA Q,
-                  int matrix_type)
-    int j, n, obj, red, num = 0;	/* total number of rules */
-    *rules = NULL;
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-                free(rule);
-                continue;
-            if (n > 0)
-                free(allred);
-            else
-                free(rule);
-                          (*rules,
-                           (n +
-                    NULL)
-                free(rule);
-                free(fewred);
-                for (j = _mainsys->attributes_num - 1; j >= 0; j--)
-                    if (ContSetA(fewred + red * size, j) || ContSetA(Q, j))
-                        rule[j] = GetA(obj, j);
-                    else
-                        rule[j] = MINUS;
-    if (n > 0)
-        free(fewred);
-    free(rule);
-    if (SelectRules(rules, &num, set, P, FASTOPT) < 0)
-                  (*rules,
-        ERROR(3);
-    return num;
-int FastRules(value_type ** rules, setA P, setA Q, int matrix_type)
-    int obj, attr, n, red, count = 0;
-        ERROR(3);
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-            free(rule);
-            continue;
-        red = SelectOneShort(reducts, n);
-            else
-        if (n > 0)
-            free(reducts);
-        reducts = NULL;
-    free(rule);
-                  (*rules,
-        ERROR(3);
-    return count;
-int VeryFastRules(value_type ** rules, setA P, setA Q, int matrix_type)
-    int obj, attr, count = 0;
-    setA reduct;
-        ERROR(3);
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-    reduct = InitEmptySetA();
-            free(rule);
-            continue;
-        RedOptim(reduct, MATX);
-            if (ContSetA(reduct, attr) || ContSetA(Q, attr))
-            else
-    free(rule);
-    CloseSetA(reduct);
-                  (*rules,
-        ERROR(3);
-    return count;
-int ApprRules(value_type ** rules, setA P, setA Q, int option,
-              int matrix_type)
-        ERROR(3);
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-            classnum = 0;
-            classnum = ApprRulesForClass(&classrules, newclass, P, Q,
-                                         option, matrix_type);
-            if (classnum > 0)
-                free(classrules);
-    free(rule);
-                  (*rules,
-        ERROR(3);
-    return num;
-int ApprRulesForClass(value_type ** rules, setO set, setA P, setA Q,
-                      int option, int matrix_type)
-    setO aclass;
-    *rules = NULL;
-        ERROR(5);
-    rule =
-    if (rule == NULL)
-        ERROR(3);
-    aclass = InitEmptySetO();
-    if (option == LOWER)
-        LowAppr(aclass, set, P, matrix_type);
-    else if (option == UPPER)
-        UppAppr(aclass, set, P, matrix_type);
-    else
-        CopySetO(aclass, set);
-        if (ContSetO(aclass, obj))
-            if (InitXforObjectFromClass(_mainsys, obj, P, aclass, matrix_type)
-                    < 0)
-                free(rule);
-                continue;
-            if (n > 0)
-                free(allred);
-            else
-                free(rule);
-                          (*rules,
-                           (n +
-                    NULL)
-                free(rule);
-                free(fewred);
-                    else
-                        rule[j] = MINUS;
-    if (n > 0)
-        free(fewred);
-    free(rule);
-                  (*rules,
-        ERROR(3);
-    return num;
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rule2.h
--- grass-addons/grass6/raster/mcda/r.roughset/rule2.h	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rule2.h	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,110 +0,0 @@
- *   	    	 for details.
-/***               SOME MORE QUERIES FOR SYSTEM                            ***/
-#define BESTOPT 0
-#define FASTOPT 1
-#define NORMAL  0
-#define LOWER   1
-#define UPPER   2
-int AllRules(value_type ** rules, setA P, setA Q, int matrix_type);
-	/* finds all possible rules for condition attributes P */
-	/* and decision Q, allocates memory, returns number of rules */
-		       int N, setA Q, int matrix_type);
-	/* finds all possible rules for each reduct separatly */
-	/* allocates memory, returns number of rules */
-int SelectRules(value_type ** rules, int *N, setO set, setA P, int option);
-	/* reduce set of rules to cover only some objects */
-	/* on attributes P, reallocates memory and decrease N */
-	/* option: FASTOPT for shortcomings      */
-	/*         BESTOPT for optimal computing */
-int BestRules(value_type ** rules, setA P, setA Q, int matrix_type);
-	/* finds minimal set of rules, allocates memory */
-	/* P - condition attributes; Q - decision attributes */
-	/* returns number of rules */
-		      int matrix_type);
-	/* finds minimal set of rules to cover objects from set */
-int Rules(value_type ** rules, setA P, setA Q, int matrix_type);
-	/* finds set of rules, allocates memory */
-		  int matrix_type);
-	/* finds set of rules to cover objects from set */
-int FastRules(value_type ** rules, setA P, setA Q, int matrix_type);
-	/* finds quickly set of rules, allocates memory */
-int VeryFastRules(value_type ** rules, setA P, setA Q, int matrix_type);
-	/* finds very quickly set of rules, allocates memory */
-	      int matrix_type);
-	/* finds set of rules for approximated classes */
-	/* option: LOWER - lower approximation - certain rules */
-	/*         UPPER - upper approximation - possible rules */
-	/*         NORMAL - no approximation - normal rules */
-		      int option, int matrix_type);
-	/* finds set of rules for approximated class (set) */
Deleted: grass-addons/grass6/raster/mcda/r.roughset/rules_extr.c
--- grass-addons/grass6/raster/mcda/r.roughset/rules_extr.c	2012-12-01 17:10:08 UTC (rev 54123)
+++ grass-addons/grass6/raster/mcda/r.roughset/rules_extr.c	2012-12-01 17:11:28 UTC (rev 54124)
@@ -1,489 +0,0 @@
- *   	    	 for details.
-** EXTRACT RULE FROM GEOGRAPHICS THEMES (Based on Rough Set Library
-**     		written by M.Gawrys J.Sienkiewiczbrary )
-** The RSL defines three types to be used in applications:
-**     setA - set of attributes,
-**     setO - set of objects and
-**     SYSTEM - information system descriptor.
-** The descriptor contains pointers to the information system data matrices:
-** - MATRIX A, is the attribute-value table.
-** - MATRIX D, is the discernibility matrix
-** - MATRIX X, is called a reduced discernibility matrix.
-#include "rough.h"
-#include "localproto.h"
-int rough_analysis(int nrows, int ncols, char *name, int *classify_vect,
-                   struct input *attributes, char *file_sample_txt, int strgy,
-                   int cls);
-void rough_set_library_out(int nrows, int ncols, int nattributes,
-                           struct input *attributes, char *file_out_sys);
-void output_to_txt(FILE * file_out_txt, value_type * rules, setA P, setA Q,
-                   setA core, setA beg, int n, SYSTEM * sys1, int strgy,
-                   int r, int *opr, struct input *attributes);
-void fPrintSetA(FILE * file, setA set);
-void fPrintSetO(FILE * file, setO set);
-void fPrintRules(FILE * file, value_type * rules, int N, int *opr, setA P,
-                 setA Q, struct input *attributes);
-float MeanAttrInRule(value_type * rules, int N, setA P);
-int LowRules(value_type ** rules, setA P, setA Q, int mat);
-int UppRules(value_type ** rules, setA P, setA Q, int mat);
-int NormRules(value_type ** rules, setA P, setA Q, int mat);
-                   int cls)
-    SYSTEM *sys1, *sys2;	/* Information system descriptor structures. */
-    /* It contains information about the system parameters (number of objects, number of attributes, system name. */
-    value_type value, *buf, *rules;	/* stores a single value of attribute (used for attribute-value table and rule implementation) */
-    char c;
-    int n, j, i, r, *opr;
-    setA beg, P, Q, full, core;	/*set of attributes */
-    setO train;			/*set of object */
-    FILE *file_out_txt;		/* pointer to text output file */
-    int (*genrules) (value_type **, setA, setA, int);
-    int nattributes, nobjects = nrows * ncols;	/*objects in information system are all raster cells in working location with a defined resolution */
-    int row, col, object, attribute;	/*index and counter */
-    sys1 = InitEmptySys();	/* Allocates memory for a system descriptor and returns a pointer. */
-    if (file_sample_txt != NULL)  	/*use sample txt file if input in dec_txt->answer isn't NUL */
-        name = file_sample_txt;
-        G_message("Using %s sys file for rules generation", name);
-    }				/* Imports a system from a file of the special format. */
-    FileToSys(sys1, name);	/* Imports a system from a file of the special format. */
-    if (_rerror > 0)
-        G_fatal_error("  Can't open data file \n");
-        return (1);
-    strcat(name, ".out");
-    if (!(file_out_txt = fopen(name, "a")))  	/*output text file */
-        G_fatal_error("  Can't open output file \n");
-        return (1);
-    UseSys(sys1);		/* Activates a system. All routines will work on this indicated system data and parameters. */
-    if (_rerror > 0)
-        G_fatal_error("Can't open information system <%s>\n", sys1->name);
-        return (1);
-    full = InitFullSetA();	/*Initialize a full set. Allocates memory for a set and initialize it with all elements of
-				   domain based on the active information system */
-    InitD(sys1);		/*Generates MATRIX D from MATRIX A.Connected to sys and filled */
-    P = InitEmptySetA();	/* Initialize an empty set. Memory size determined by active information system parameters */
-    Q = InitEmptySetA();
-    nattributes = (AttributesNum(sys1) - 1);
-    /* define attribute */
-    for (i = 0; i < nattributes; i++)
-        AddSetA(P, i);		/* Adds a single element to a set */
-    /* define decision */
-    AddSetA(Q, (AttributesNum(sys1) - 1));
-    InitX(sys1, P, Q, MATD);	/*Generates MATRIX X from another matrix designed for use in core and reducts queries. */
-    core = InitEmptySetA();
-    Core(core, MATX);		/* Puts a core of the active information system to core. */
-    RedOptim(core, MATX);	/* Provides the optimized heuristic search for a single reduct */
-    CloseSetA(core);		/* Frees memory allocated for a set */
-    n = RedFew(&beg, MATX);	/*Finds all reducts shorter than the first one found. */
-    CloseMat(sys1, MATX);	/* Closes a matrix. */
-    if (n > 0)
-        free(beg);
-    switch (strgy)
-    case 0:
-        genrules = VeryFastRules;
-        break;
-    case 1:
-        genrules = FastRules;
-        break;
-    case 2:
-        genrules = Rules;
-        break;
-    case 3:
-        genrules = BestRules;
-        break;
-    case 4:
-        genrules = AllRules;
-        break;
-    case 5:
-        genrules = LowRules;
-        break;
-    case 6:
-        genrules = UppRules;
-        break;
-    default:
-        genrules = NormRules;
-        break;
-    r = genrules(&rules, P, Q, MATD);	/* rules generator */
-    if (r > 0)
-        opr = StrengthOfRules(rules, r);
-    }				/* Creates a table of rules strengths */
-    /**************************Output text files************************************/
-    /***********print output about sys1 in a txt file (file_out_txt)****************/
-    output_to_txt(file_out_txt, rules, P, Q, core, beg, n, sys1, strgy, r,
-                  opr, attributes);
-    /**************************close all********************************************/
-    //CloseSys(sys1);   /* close sys1 */
-    /**************************Classify*********************************************/
-    sys2 = InitEmptySys();
-    SetParameters(sys2, nobjects, nattributes);	/* assigning system parameters */
-    ConnectA(sys2, malloc(MatMemSize(sys2, MATA)));	/* Connects MATRIX A to a system descriptor. */
-    /*MatMemSize: Returns size of memory used by matrix. */
-    SetName(sys2, "classys");
-    UseSys(sys2);		/* active system sys2 was created in application and has only MATRIX A */
-    if (_rerror > 0)
-        G_fatal_error("Can't open information system <%s>\n", _mainsys->name);
-        return (1);
-    G_message("Build information system for classification ");
-        object = 0;		/* set object numbers =0 and increase it until rows*cells for each attribute */
-        for (row = 0; row < nrows; row++)
-            G_percent(row, nrows, 1);
-            /* Reads appropriate information into the buffer buf associated with the requested row */
-            G_get_c_raster_row(attributes[i].fd, attributes[i].buf, row);
-            for (col = 0; col < ncols; col++)
-                value = (attributes[i].buf[col]);	/*make a cast on the DCELL output value */
-                PutA(_mainsys, object, i, value);	/* filling MATRIX A */
-                object++;
-    buf = MatExist(_mainsys, MATA);	/*Returns pointer to specified matrix if exists */
-    if (!buf)
-        G_fatal_error("Error in the information system <%s>\n",
-                      _mainsys->name);
-        return (1);
-    switch (cls)
-    case 0:
-        for (j = 0; j < _mainsys->objects_num; j++)  	/*Chooses the best rule to cover sample. Strategy no. 1 */
-            classify_vect[j] =
-                Classify1(buf + j * _mainsys->attributes_num, rules, r, P,
-                          Q);
-            G_percent(j, _mainsys->objects_num, 1);
-    break;
-    case 1:
-        for (j = 0; j < _mainsys->objects_num; j++)  	/*Chooses the best rule to cover sample. Strategy no. 2 */
-                Classify2(buf + j * _mainsys->attributes_num, rules, r, P,
-                          Q);
-    break;
-    case 2:
-        for (j = 0; j < _mainsys->objects_num; j++)  	/*Chooses the best rule to cover sample. Strategy no. 3 */
-                Classify3(buf + j * _mainsys->attributes_num, rules, r,
-                          opr, P, Q);
-    break;
-    default:
-        0;
-        break;
-    G_message("All cells classified (%d)", j);
-    free(rules);
-    free(opr);
-    CloseSetA(P);
-    CloseSetA(Q);
-    CloseSetA(full);
-    CloseSys(sys2);
-    //fclose(file);
-    fclose(file_out_txt);
-    return (0);
-void rough_set_library_out(int nrows, int ncols, int nattribute,
-    int row, col, i, j;
-    int value, decvalue;
-    int nobject;
-    char cell_buf[300];
-    FILE *fp;			/*file pointer for ASCII output */
-    /* open *.sys file for writing or use stdout */
-    if (NULL == (fp = fopen(file_out_sys, "w")))
-        G_fatal_error("Not able to open file [%s]", file_out_sys);
-    fprintf(fp, "NAME: %s\nATTRIBUTES: %d\nOBJECTS: %s\n", file_out_sys,
-            nattribute + 1, "            ");
-    /************** process the data *************/
-    G_message("Build information system for rules extraction in %s",
-              file_out_sys);
-    nobject = 0;
-        for (i = 0; i <= nattribute; i++)
-            G_get_c_raster_row(attributes[i].fd, attributes[i].buf, row);	/* Reads appropriate information into the buffer buf associated with the requested row */
-        for (col = 0; col < ncols; col++)  	/*make a cast on the DCELL output value */
-            decvalue = (int)attributes[nattribute].buf[col];
-            if (0 < decvalue)  	/* TODO: correct form will: decval!=null */
-                for (j = 0; j < nattribute; j++)  	/*make a cast on the DCELL output value */
-                    value = (int)(attributes[j].buf[col]);
-                    sprintf(cell_buf, "%d", value);
-                    G_trim_decimal(cell_buf);
-                    fprintf(fp, "%s ", cell_buf);
-                fprintf(fp, "%d\n", decvalue);
-                nobject++;
-    /************** write code file*************/
-        fprintf(fp, "\n%s", attributes[i].name);
-    /************** write header file*************/
-    rewind(fp);			/*move file pointer to header file */
-    /* TODO: make a system to  detect errors like: G_fatal_error("Not able to write file [%s]",file_out_sys); */
-    fprintf(fp, "NAME: %s\nATTRIBUTES: %d\nOBJECTS: %d", file_out_sys,
-            nattribute + 1, nobject);
-    /************** close all and exit ***********/
-    fclose(fp);
-    int i;
-    fprintf(file_out_txt, "Condition attributes are\n");
-    fPrintSetA(file_out_txt, P);
-    fprintf(file_out_txt, "\nDecision attributes are\n");
-    fPrintSetA(file_out_txt, Q);
-    fprintf(file_out_txt, "\nDependCoef = %f\n", DependCoef(P, Q, MATD));	/* Returns degree of dependency Q from P in the active information system. */
-    fprintf(file_out_txt, "CORE = ");
-    fPrintSetA(file_out_txt, core);
-    fprintf(file_out_txt, "\nRedOptim = ");
-    fprintf(file_out_txt, "\nFew reducts ( %i ):\n", n);
-    for (i = 0; i < n; i++)
-        fPrintSetA(file_out_txt, beg + i * sys1->setAsize);
-        fprintf(file_out_txt, "\n");
-    fprintf(file_out_txt, "%d strategy of generating rules\n", strgy);
-    if (r > 0)
-        fprintf(file_out_txt, "Rules ( %i )\n", r);
-        fPrintRules(file_out_txt, rules, r, opr, P, Q, attributes);	/*print to file generated rules */
-        fprintf(file_out_txt, "Mean number of attributes in rule = %.1f\n",
-                MeanAttrInRule(rules, r, P));
-void fPrintSetA(FILE * f, setA set)
-    int attr;
-    fprintf(f, "{");
-    for (attr = 0; attr < _mainsys->attributes_num; attr++)
-            fprintf(f, " %d", attr);
-            attr++;
-            break;
-    for (; attr < _mainsys->attributes_num; attr++)
-            fprintf(f, ",%d", attr);
-    fprintf(f, " }");
-void fPrintSetO(FILE * f, setO set)
-    int obj;
-    fprintf(f, "{");
-            fprintf(f, " %d", obj);
-            obj++;
-            break;
-    for (; obj < _mainsys->objects_num; obj++)
-            fprintf(f, ",%d", obj);
-    fprintf(f, " }");
-                 int N, int *opr, setA P, setA Q, struct input *attributes)
-    int n, j;
-    for (n = 0; n < N; n++)
-            if (ContSetA(P, j))
-                if (rules[n * _mainsys->attributes_num + j] != MINUS)
-                    fprintf(file, "%s=%d  ", attributes[j].name,
-                            rules[n * _mainsys->attributes_num + j]);
-        fprintf(file, " => ");
-            if (ContSetA(Q, j))
-                if ((rules + n * _mainsys->attributes_num)[j] != MINUS)
-                            (rules + n * _mainsys->attributes_num)[j]);
-        fprintf(file, " ( %i objects )\n", opr[n]);
-    return;
-    int counter = 0;
-    int i, j;
-    for (i = 0; i < N; i++)
-        for (j = 0; j < size; j++)
-                if ((rules + i * size)[j] != MINUS)
-                    counter++;
-    return (float)counter / N;
-    return ApprRules(rules, P, Q, LOWER, mat);
-    return ApprRules(rules, P, Q, UPPER, mat);
-    return ApprRules(rules, P, Q, NORMAL, mat);
-/* dom 07 dic 2008 07:04:58 CET */
