[GRASS-SVN] r54127 - grass-addons/grass6/raster/mcda/r.mcda.fuzzy
Sat Dec 1 09:12:09 PST 2012
Author: gianluca
Date: 2012-12-01 09:12:08 -0800 (Sat, 01 Dec 2012)
New Revision: 54127
Removed:
   grass-addons/grass6/raster/mcda/r.mcda.fuzzy/Makefile
   grass-addons/grass6/raster/mcda/r.mcda.fuzzy/description.html
   grass-addons/grass6/raster/mcda/r.mcda.fuzzy/fuzzy.c
   grass-addons/grass6/raster/mcda/r.mcda.fuzzy/local_proto.h
   grass-addons/grass6/raster/mcda/r.mcda.fuzzy/main.c
Deleted: grass-addons/grass6/raster/mcda/r.mcda.fuzzy/Makefile
--- grass-addons/grass6/raster/mcda/r.mcda.fuzzy/Makefile	2012-12-01 17:11:55 UTC (rev 54126)
+++ grass-addons/grass6/raster/mcda/r.mcda.fuzzy/Makefile	2012-12-01 17:12:08 UTC (rev 54127)
@@ -1,12 +0,0 @@
-# fix this relative to include/
-# or use absolute path to the GRASS source code
-MODULE_TOPDIR = ../../..
-PGM = r.mcda.fuzzy
-LIBES= $(GISLIB) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP)
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
Deleted: grass-addons/grass6/raster/mcda/r.mcda.fuzzy/description.html
--- grass-addons/grass6/raster/mcda/r.mcda.fuzzy/description.html	2012-12-01 17:11:55 UTC (rev 54126)
+++ grass-addons/grass6/raster/mcda/r.mcda.fuzzy/description.html	2012-12-01 17:12:08 UTC (rev 54127)
@@ -1,36 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.mcda.fuzzy</em> is the implementation of the FUZZY multicriteria
-algorithm proposed by Yager R., in GRASS GIS environment. It is one of the
-available tools in the r.mcda suite. It requires as an input the list of
-raster representing the criteria to be assessed in the multicriteria
-evaluation and the vector of linguistic modifiers to be assigned. Every
-single cell of the GRASS region is considered as one of the possible
-alternatives to evaluate and it is described with the value assumed for
-the same cell by the raster used as criteria. It is possible to get three
-different output files as the result of the intersection operator, the
-union operator and the ordered weighted averaging (OWA) operator.
-<h2>NOTES</h2>
-The module does not standardize the raster-criteria. Therefore, they must
-be prepared before by using, for example, r.mapcalc. The linguistic
-modifiers vector is always normalized so that the sum of the weights is 1.
-<h2>REFERENCE</h2>
-<p>Yager R. (1977) - Multiple objective decision making using fuzzy set,
- International Journal of Man-Machine Studies, 12, 299-322;</P>
-<p>GRASS Development Team (2008)</P>
-<h2>SEE ALSO</h2>
-<em>r.mcda.regime, r.mcda.electre, r.roughet, r.mapcalc</em>
-<h2>AUTHORS</h2>
-Antonio Boggia - Gianluca Massei<br>
-Department of Economics and Appraisal - University of Perugia - Italy
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/mcda/r.mcda.fuzzy/fuzzy.c
--- grass-addons/grass6/raster/mcda/r.mcda.fuzzy/fuzzy.c	2012-12-01 17:11:55 UTC (rev 54126)
+++ grass-addons/grass6/raster/mcda/r.mcda.fuzzy/fuzzy.c	2012-12-01 17:12:08 UTC (rev 54127)
@@ -1,131 +0,0 @@
-#include "local_proto.h"
- * global function declaration
-void build_weight_vect(int nrows, int ncols, int ncriteria,
-                       struct Option *weight, double *weight_vect);
-void build_fuzzy_matrix(int nrows, int ncols, int ncriteria,
-                        double *weight_vect, double ***decision_vol);
- * function definitions
-    int i, nweight = 0;
-    double weight_sum = 0;
-    while (weight->answers[nweight] != NULL)
-        nweight++;
-    if (nweight != ncriteria)
-        G_fatal_error(_("criteria number  and weight number are different"));
-    for (i = 0; i < nweight; i++)
-        weight_vect[i] = (atof(weight->answers[i]));	/*transfer  weight value  in double  array */
-        weight_sum = weight_sum + weight_vect[i];	/*calculate sum weight */
-        weight_vect[i] = weight_vect[i] / weight_sum;	/*normalize vector weight */
-    int row1, col1, row2, col2;
-    int i, j, k, cont;
-    double row_sum_conc, col_sum_conc, row_sum_disc, col_sum_disc;
-    double value;
-    /* apply linguistic modifier - */
-    for (row1 = 0; row1 < nrows; row1++)
-        G_percent(row1, nrows, 2);
-        for (col1 = 0; col1 < ncols; col1++)
-            for (i = 0; i < ncriteria; i++)
-                decision_vol[row1][col1][i] =
-                    pow(decision_vol[row1][col1][i], weight_vect[i]);
-    /* operate intersection - AND logic (find min value -) */
-            value = decision_vol[row1][col1][0];	/* set value to firsth matrix i-value */
-                if (decision_vol[row1][col1][i] >= value)
-                    value = value;
-                else
-                    value = decision_vol[row1][col1][i];
-            decision_vol[row1][col1][ncriteria] = value;
-    /* operate union - OR logic (find max value -) */
-                if (decision_vol[row1][col1][i] <= value)
-                    value = value;
-                else
-            decision_vol[row1][col1][ncriteria + 1] = value;
-    /* operate OWA (find average value -) */
-                value = value + decision_vol[row1][col1][i];
-            decision_vol[row1][col1][ncriteria + 2] = value / ncriteria;
Deleted: grass-addons/grass6/raster/mcda/r.mcda.fuzzy/local_proto.h
--- grass-addons/grass6/raster/mcda/r.mcda.fuzzy/local_proto.h	2012-12-01 17:11:55 UTC (rev 54126)
+++ grass-addons/grass6/raster/mcda/r.mcda.fuzzy/local_proto.h	2012-12-01 17:12:08 UTC (rev 54127)
@@ -1,15 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/config.h>
-struct input
-    char *name, *mapset;	/* input raster name  and mapset name */
-    int infd;
-    void *inrast;		/* input buffer */
Deleted: grass-addons/grass6/raster/mcda/r.mcda.fuzzy/main.c
--- grass-addons/grass6/raster/mcda/r.mcda.fuzzy/main.c	2012-12-01 17:11:55 UTC (rev 54126)
+++ grass-addons/grass6/raster/mcda/r.mcda.fuzzy/main.c	2012-12-01 17:12:08 UTC (rev 54127)
@@ -1,263 +0,0 @@
- * MODULE:	r.mcda.electre
- * AUTHORS:	 Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
- * PURPOSE:      Make a multicriterio decision  analysis based on Yager fuzzy algorthm
- * COPYRIGHT:     (C) GRASS Development Team (2008)
- *		        This program is free software under the GNU General Public
- *   	    	License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	for details.
- * main function
-int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/* it stores region information,  and header information of rasters */
-    char *result_and, *result_or, *result_owa;	/* outputs raster name */
-    char *mapset;		/* mapset name */
-    unsigned char *outrast_and, *outrast_or, *outrast_owa;	/* output buffer */
-    int i, j, ncriteria = 0;	/* index and  files number */
-    int nrows, ncols;
-    int row1, row2, col1, col2;
-    int outfd_and, outfd_or, outfd_owa;	/* output file descriptor */
-    double *weight_vect, ***decision_vol;
-    struct History history;	/* holds meta-data (title, comments,..) */
-    struct GModule *module;	/* GRASS module for parsing arguments */
-    struct Option *criteria, *weight, *and, *or, *owa;	/* options */
-    struct input *attributes;	/*storage  alla input criteria GRID files and output concordance and discordance GRID files */
-    /* initialize GIS environment */
-    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
-    /* initialize module */
-    module = G_define_module();
-    module->keywords = _("raster,fuzzy,MCDA");
-    module->description =
-        _("Multicirtieria decision analysis based on Yager fuzzy method");
-    /* Define the different options as defined in gis.h */
-    criteria = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    criteria->key = "criteria";
-    criteria->type = TYPE_STRING;
-    criteria->required = YES;
-    criteria->multiple = YES;
-    criteria->gisprompt = "old,cell,raster";
-    criteria->description = "Input geographics criteria in evaluation table";
-    weight = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    weight->key = "weight";
-    weight->type = TYPE_DOUBLE;
-    weight->required = YES;
-    weight->multiple = YES;
-    weight->description = _("Linguistic modifier (w1,w2,..)");
-    and = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    and->key = "AND";
-    and->type = TYPE_STRING;
-    and->required = YES;
-    and->gisprompt = "new,cell,raster";
-    and->answer = "intersect";
-    and->description = "Intersection output map";
-    or = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    or->key = "OR";
-    or->type = TYPE_STRING;
-    or->required = YES;
-    or->gisprompt = "new,cell,raster";
-    or->answer = "union";
-    or->description = "Union output map";
-    owa = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
-    owa->key = "OWA";
-    owa->type = TYPE_STRING;
-    owa->required = YES;
-    owa->gisprompt = "new,cell,raster";
-    owa->answer = "OWA";
-    owa->description = "OWA output map";
-    /* options and flags parser */
-    if (G_parser(argc, argv))
-        exit(EXIT_FAILURE);
-    G_message("\n\nstart: %s", G_date());	/*write calculation start time */
-    /* number of file (=criteria) */
-    while (criteria->answers[ncriteria] != NULL)
-        ncriteria++;
-    /* process the input maps:  stores options and flags to variables */
-    /* CRITERIA grid */
-    attributes = G_malloc(ncriteria * sizeof(struct input));	/*attributes is input struct defined in top file and store alla criteria files */
-    weight_vect = G_malloc(ncriteria * sizeof(double));	/*allocate memory fron vector weight */
-    build_weight_vect(nrows, ncols, ncriteria, weight, weight_vect);	/*calcolate weight vector */
-        struct input *p = &attributes[i];
-        p->name = criteria->answers[i];
-        p->mapset = G_find_cell2(p->name, "");	/* G_find_cell: Looks for the raster map "name" in the database. */
-        if (p->mapset == NULL)	/* returns NULL if the map was not found in any mapset,   mapset name otherwise */
-            G_fatal_error(_("Raster file <%s> not found"), p->name);
-        if ((p->infd = G_open_cell_old(p->name, p->mapset)) < 0)	/* G_open_cell_old - returns file destriptor (>0) */
-            G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),
-                          p->name, p->mapset);
-        if (G_get_cellhd(p->name, p->mapset, &cellhd) < 0)	/* controlling, if we can open input raster */
-            G_fatal_error(_("Unable to read file header of <%s>"), p->name);
-        p->inrast = G_allocate_d_raster_buf();	/* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
-    result_and = and->answer;	/* store outputn name in variables */
-    result_or = or->answer;
-    result_owa = owa->answer;
-    if (G_legal_filename(result_and) < 0)	/* check for legal database file names */
-        G_fatal_error(_("<%s> is an illegal file name"), result_and);
-    if (G_legal_filename(result_or) < 0)	/* check for legal database file names */
-        G_fatal_error(_("<%s> is an illegal file name"), result_or);
-    if (G_legal_filename(result_owa) < 0)	/* check for legal database file names */
-        G_fatal_error(_("<%s> is an illegal file name"), result_owa);
-    /*values = G_malloc(ncriteria * sizeof(DCELL)); */
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    /*memory allocation for-three dimensional matrix */
-    decision_vol = G_malloc(nrows * sizeof(double *));
-    for (i = 0; i < nrows; ++i)
-        decision_vol[i] = G_malloc(ncols * sizeof(double *));
-        for (j = 0; j < ncols; ++j)
-            decision_vol[i][j] = G_malloc((ncriteria + 3) * sizeof(double));	     /****NOTE: it's storage enven and, or, owa map*/
-    /* Allocate output buffer, use  DCELL_TYPE */
-    outrast_and = G_allocate_raster_buf(DCELL_TYPE);	/* Allocate memory for a raster map of type DCELL_TYPE. */
-    outrast_or = G_allocate_raster_buf(DCELL_TYPE);
-    outrast_owa = G_allocate_raster_buf(DCELL_TYPE);
-    /* controlling, if we can write the raster */
-    if ((outfd_and = G_open_raster_new(result_and, DCELL_TYPE)) < 0)
-        G_fatal_error(_("Unable to create raster map <%s>"), result_and);
-    if ((outfd_or = G_open_raster_new(result_or, DCELL_TYPE)) < 0)
-        G_fatal_error(_("Unable to create raster map <%s>"), result_or);
-    if ((outfd_owa = G_open_raster_new(result_owa, DCELL_TYPE)) < 0)
-        G_fatal_error(_("Unable to create raster map <%s>"), result_owa);
-    /*build a three dimensional matrix for storage all critera maps */
-            G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1, DCELL_TYPE);	/* Reads appropriate information into the buffer buf associated with the requested row */
-            /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row); */
-                /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array */
-                DCELL v1 = ((DCELL *) attributes[i].inrast)[col1];
-                decision_vol[row1][col1][i] = (double)(v1);
-    build_fuzzy_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol);	/*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index */
-            ((DCELL *) outrast_and)[col1] =
-                (DCELL) decision_vol[row1][col1][ncriteria];
-            ((DCELL *) outrast_or)[col1] =
-                (DCELL) decision_vol[row1][col1][ncriteria + 1];
-            ((DCELL *) outrast_owa)[col1] =
-                (DCELL) decision_vol[row1][col1][ncriteria + 2];
-        if (G_put_raster_row(outfd_and, outrast_and, DCELL_TYPE) < 0)
-            G_fatal_error(_("Failed writing raster map <%s>"), result_and);
-        if (G_put_raster_row(outfd_or, outrast_or, DCELL_TYPE) < 0)
-            G_fatal_error(_("Failed writing raster map <%s>"), result_or);
-        if (G_put_raster_row(outfd_owa, outrast_owa, DCELL_TYPE) < 0)
-            G_fatal_error(_("Failed writing raster map <%s>"), result_owa);
-    G_message("end: %s, by!", G_date());
-    /* memory cleanup */
-        G_free(attributes[i].inrast);
-    G_free(outrast_and);
-    G_free(outrast_or);
-    G_free(outrast_owa);
-    G_free(decision_vol);
-    /* closing raster maps */
-        G_close_cell(attributes[i].infd);
-    G_close_cell(outfd_and);
-    G_close_cell(outfd_or);
-    G_close_cell(outfd_owa);
-    /* add command line incantation to history AND file */
-    G_short_history(result_and, "raster", &history);
-    G_command_history(&history);
-    G_write_history(result_and, &history);
-    /* add command line incantation to history OR file */
-    G_short_history(result_or, "raster", &history);
-    G_write_history(result_or, &history);
-    /* add command line incantation to history OWA file */
-    G_short_history(result_owa, "raster", &history);
-    G_write_history(result_owa, &history);
-    exit(EXIT_SUCCESS);
