[GRASS-SVN] r54128 - grass-addons/grass6/raster/mcda/r.mcda.electre
svn_grass at osgeo.org
Sat Dec 1 09:12:23 PST 2012
Author: gianluca
Date: 2012-12-01 09:12:23 -0800 (Sat, 01 Dec 2012)
New Revision: 54128
Removed:
grass-addons/grass6/raster/mcda/r.mcda.electre/Makefile
grass-addons/grass6/raster/mcda/r.mcda.electre/description.html
grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c
grass-addons/grass6/raster/mcda/r.mcda.electre/local_proto.h
grass-addons/grass6/raster/mcda/r.mcda.electre/main.c
Deleted: grass-addons/grass6/raster/mcda/r.mcda.electre/Makefile
--- grass-addons/grass6/raster/mcda/r.mcda.electre/Makefile 2012-12-01 17:12:08 UTC (rev 54127)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/Makefile 2012-12-01 17:12:23 UTC (rev 54128)
@@ -1,10 +0,0 @@
-MODULE_TOPDIR = ../../..
-PGM = r.mcda.electre
-LIBES= $(GISLIB) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP)
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
Deleted: grass-addons/grass6/raster/mcda/r.mcda.electre/description.html
--- grass-addons/grass6/raster/mcda/r.mcda.electre/description.html 2012-12-01 17:12:08 UTC (rev 54127)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/description.html 2012-12-01 17:12:23 UTC (rev 54128)
@@ -1,40 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.mcda.electre</em> is the implementation of the ELECTRE multicriteria
-algorithm in GRASS GIS environment. It is one of the available tools in the
-r.mcda suite. It requires as an input the list of raster representing the
-criteria to be assessed in the multicriteria evaluation and the vector of
-weights to be assigned. Every single cell of the GRASS region is considered
-as one of the possible alternatives to evaluate and it is described with
-the value assumed for the same cell by the raster used as criteria. There
-are two output files. One represents the spatial distribution of the
-concordance index, the other one of the discordance index. The optimal
-solution is the one presenting the maximum concordance value and the minimum
-discordance value at the same time.
-<h2>NOTES</h2>
-The module does not standardize the raster-criteria. Therefore, they must
-be prepared before by using, for example, r.mapcalc. The weights vector
-is always normalized so that the sum of the weights is 1.
-<h2>REFERENCE</h2>
-<p>Roy, B. (1971) Problem and methods with multiple objective functions
- Mathematical programming 1, 239-266.</P>
-<p>Roy, B. (1990): The outranking approach and the foundations of Electre
- methods , Document du LAMSADE, Paris.</P>
-<p>Janssen R. (1994) - Multiobjective decision support for environmental
- management, Kluwer Academic Publishers.</P>
-<p>GRASS Development Team (2008)</P>
-<h2>SEE ALSO</h2>
-<em>r.mcda.fuzzy, r.mcda.electre, r.roughet, r.mapcalc</em>
-<h2>AUTHORS</h2>
-Antonio Boggia - Gianluca Massei<br>
-Department of Economics and Appraisal - University of Perugia - Italy
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c
--- grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c 2012-12-01 17:12:08 UTC (rev 54127)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/dominance.c 2012-12-01 17:12:23 UTC (rev 54128)
@@ -1,116 +0,0 @@
-#include "local_proto.h"
- * global function declaration
-void build_weight_vect(int nrows, int ncols, int ncriteria,
- struct Option *weight, double *weight_vect);
-void build_dominance_matrix(int nrows, int ncols, int ncriteria,
- double *weight_vect, double ***decision_vol);
- * function definitions
- int i, nweight = 0;
- double weight_sum = 0;
- while (weight->answers[nweight] != NULL)
- nweight++;
- if (nweight != ncriteria)
- G_fatal_error(_("criteria number and weight number are different"));
- for (i = 0; i < nweight; i++)
- weight_vect[i] = (atof(weight->answers[i])); /*transfer weight value in double array */
- weight_sum = weight_sum + weight_vect[i]; /*calculate sum weight */
- weight_vect[i] = weight_vect[i] / weight_sum; /*normalize vector weight */
- int row1, col1, row2, col2;
- int i, j, k, cont;
- double *row_sum_conc;
- double *col_sum_conc;
- double *row_sum_disc;
- double *col_sum_disc;
- row_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
- col_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
- row_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
- col_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
- k = 0; /* make pairwise comparation and build concordance/discordance matrix */
- for (row1 = 0; row1 < nrows; row1++)
- G_percent(row1, nrows, 2);
- for (col1 = 0; col1 < ncols; col1++)
- j = 0;
- for (row2 = 0; row2 < nrows; row2++)
- for (col2 = 0; col2 < ncols; col2++)
- double conc = 0, disc = 0;
- for (i = 0; i < ncriteria; i++)
- double d;
- d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
- if (d >= 0 )
- conc += weight_vect[i];
- if (d < disc) /*WARNING: if(d>conc) */
- /**/ disc = -d;
- row_sum_conc[k] += conc;
- col_sum_conc[j] += conc;
- row_sum_disc[k] += disc;
- col_sum_disc[j] += disc;
- j++; /* increase rows index up to nrows*ncols */
- k++; /* increase columns index up to nrows*ncols */;
- /*calculate concordance and discordance index and storage in decision_vol */
- cont = 0; /*variabile progressiva per riga/colonna della concordance_map */
- /*fill matrix with concordance index for each DCELL */
- decision_vol[row1][col1][ncriteria] =
- row_sum_conc[cont] - col_sum_conc[cont];
- /*fill matrix with discordance index for each DCELL */
- decision_vol[row1][col1][ncriteria + 1] =
- row_sum_disc[cont] - col_sum_disc[cont];
- cont++;
Deleted: grass-addons/grass6/raster/mcda/r.mcda.electre/local_proto.h
--- grass-addons/grass6/raster/mcda/r.mcda.electre/local_proto.h 2012-12-01 17:12:08 UTC (rev 54127)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/local_proto.h 2012-12-01 17:12:23 UTC (rev 54128)
@@ -1,15 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/config.h>
-struct input
- char *name, *mapset; /* input raster name and mapset name */
- int infd;
- void *inrast; /* input buffer */
Deleted: grass-addons/grass6/raster/mcda/r.mcda.electre/main.c
--- grass-addons/grass6/raster/mcda/r.mcda.electre/main.c 2012-12-01 17:12:08 UTC (rev 54127)
+++ grass-addons/grass6/raster/mcda/r.mcda.electre/main.c 2012-12-01 17:12:23 UTC (rev 54128)
@@ -1,232 +0,0 @@
- * MODULE: r.mcda.electre
- * AUTHORS: Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
- * PURPOSE: Make a multicriterio decision analysis based on ELECTRE algorthm
- * COPYRIGHT: (C) GRASS Development Team (2008)
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * main function
-int main(int argc, char *argv[])
- struct Cell_head cellhd; /* it stores region information, and header information of rasters */
- char *result_concordance, *result_discordance; /* outputs raster name */
- char *mapset; /* mapset name */
- unsigned char *outrast_concordance, *outrast_discordance; /* output buffer */
- char *message;
- int i,j, ncriteria=0; /* index and files number*/
- int nrows, ncols;
- int row1, row2, col1, col2;
- int outfd_concordance, outfd_discordance; /* output file descriptor */
- double *weight_vect, ***decision_vol;/* vector and matrix */
- struct History history; /* holds meta-data (title, comments,..) */
- struct GModule *module; /* GRASS module for parsing arguments */
- struct Option *criteria, *weight, *discordance, *concordance; /* options */
- struct input *attributes; /*storage alla input criteria GRID files and output concordance and discordance GRID files*/
- /* initialize GIS environment */
- G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
- /* initialize module */
- module = G_define_module();
- module->keywords = _("raster,MCDA");
- module->description = _("Multicirtieria decision analysis based on ELECTRE method");
- /* Define the different options as defined in gis.h */
- criteria = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
- criteria->key = "criteria";
- criteria->type = TYPE_STRING;
- criteria->required = YES;
- criteria->multiple = YES;
- criteria->gisprompt = "old,cell,raster" ;
- criteria->description = "Input geographics criteria in information system";
- weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
- weight->key = "weight";
- weight->type = TYPE_DOUBLE;
- weight->required = YES;
- weight->multiple = YES;
- weight->description = _("Criteria weight(s) (w1,w2,..)");
- concordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- concordance->key = "concordance";
- concordance->type = TYPE_STRING;
- concordance->required = YES;
- concordance->gisprompt = "new,cell,raster";
- concordance->answer ="concordance";
- concordance->description = "concordance output map";
- discordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- discordance->key = "discordance";
- discordance->type = TYPE_STRING;
- discordance->required = YES;
- discordance->gisprompt = "new,cell,raster";
- discordance->answer ="discordance";
- discordance->description = "discordance output map";
- /* options and flags parser */
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- G_message("Start: %s",G_date()); /*write calculation start time*/
- /* number of file (=criteria) */
- while (criteria->answers[ncriteria]!=NULL)
- ncriteria++;
- /* process the input maps: stores options and flags to variables */
- /* CRITERIA grid */
- attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files*/
- weight_vect=G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight*/
- build_weight_vect(nrows,ncols,ncriteria,weight,weight_vect); /*calcolate weight vector*/
- struct input *p = &attributes[i];
- p->name = criteria->answers[i];
- p->mapset = G_find_cell2(p->name,""); /* G_find_cell: Looks for the raster map "name" in the database. */
- if (p->mapset==NULL) /* returns NULL if the map was not found in any mapset, mapset name otherwise */
- G_fatal_error(_("Raster file <%s> not found"), p->name);
- if ((p->infd = G_open_cell_old(p->name, p->mapset))<0) /* G_open_cell_old - returns file destriptor (>0) */
- G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),p->name, p->mapset);
- if (G_get_cellhd(p->name,p->mapset,&cellhd)<0)/* controlling, if we can open input raster */
- G_fatal_error(_("Unable to read file header of <%s>"), p->name);
- p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL */
- result_concordance=concordance->answer; /* store outputn name in variables*/
- result_discordance=discordance->answer;
- if (G_legal_filename(result_concordance) < 0) /* check for legal database file names */
- G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
- if (G_legal_filename(result_discordance) < 0) /* check for legal database file names */
- G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
- /*values = G_malloc(ncriteria * sizeof(DCELL));*/
- nrows = G_window_rows();
- ncols = G_window_cols();
- /*memory allocation for-three dimensional matrix*/
- decision_vol=G_malloc(nrows * sizeof(double*));
- for (i=0; i<nrows; ++i)
- decision_vol[i]=G_malloc(ncols * sizeof(double*));
- for (j=0; j<ncols; ++j)
- decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage enven concordance and discordance index map****/
- /* Allocate output buffer, use DCELL_TYPE */
- outrast_concordance = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
- outrast_discordance = G_allocate_raster_buf(DCELL_TYPE);
- /* controlling, if we can write the raster */
- if ((outfd_concordance = G_open_raster_new(result_concordance, DCELL_TYPE)) < 0)
- G_fatal_error(_("Unable to create raster map <%s>"), result_concordance);
- if ((outfd_discordance = G_open_raster_new(result_discordance, DCELL_TYPE)) < 0)
- G_fatal_error(_("Unable to create raster map <%s>"), result_discordance);
- /*build a three dimensional matrix for storage all critera maps*/
- for (i=0;i<ncriteria;i++)
- for (row1 = 0; row1 < nrows;row1++)
- G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
- /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
- /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array*/
- DCELL v1 = ((DCELL *)attributes[i].inrast)[col1];
- decision_vol[row1][col1][i]=(double)(v1);
- build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
- ((DCELL *) outrast_concordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];/*write concordance map*/
- ((DCELL *) outrast_discordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+1];/*write discordance map*/
- if (G_put_raster_row(outfd_concordance, outrast_concordance, DCELL_TYPE) < 0)
- G_fatal_error(_("Failed writing raster map <%s>"), result_concordance);
- if (G_put_raster_row(outfd_discordance, outrast_discordance, DCELL_TYPE) < 0)
- G_fatal_error(_("Failed writing raster map <%s>"), result_discordance);
- G_message("End: %s",G_date());
- /* memory cleanup */
- for (i = 0; i<ncriteria; i++)
- G_free(attributes[i].inrast);
- G_free(outrast_concordance);
- G_free(outrast_discordance);
- G_free(decision_vol);
- /* closing raster maps */
- G_close_cell(attributes[i].infd);
- G_close_cell(outfd_concordance);
- G_close_cell(outfd_discordance);
- /* add command line incantation to history concordance file */
- G_short_history(result_concordance, "raster", &history);
- G_command_history(&history);
- G_write_history(result_concordance, &history);
- /* add command line incantation to history discordance file */
- G_short_history(result_discordance, "raster", &history);
- G_write_history(result_discordance, &history);
- exit(EXIT_SUCCESS);
