[GRASS-SVN] r54129 - grass-addons/grass6/raster/mcda/r.mcda.ahp
svn_grass at osgeo.org
Sat Dec 1 09:12:34 PST 2012
Author: gianluca
Date: 2012-12-01 09:12:34 -0800 (Sat, 01 Dec 2012)
New Revision: 54129
Removed:
grass-addons/grass6/raster/mcda/r.mcda.ahp/Makefile
grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html
grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
Deleted: grass-addons/grass6/raster/mcda/r.mcda.ahp/Makefile
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/Makefile 2012-12-01 17:12:23 UTC (rev 54128)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/Makefile 2012-12-01 17:12:34 UTC (rev 54129)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = r.mcda.ahp
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Deleted: grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html 2012-12-01 17:12:23 UTC (rev 54128)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html 2012-12-01 17:12:34 UTC (rev 54129)
@@ -1,33 +0,0 @@
-<h2>DESCRIPTION</h2>
-<p>The <em>r.mcda.ahp</em> Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]</p>
-<em>(GRASS python Script)</em>
-<p></p>
-<h2>NOTES</h2>
-<p>It is mandatory to build a pairwise comparation table with the same order of input of criteria maps in the criteria field.</p>
-<p>Example: r.mcda.ahp criteria=reclass_slope,reclass_sand,reclass_elev pairwise=pairwise output=outputMap</p>
-<p>The file "pairwise" has to have a structure like this:</p>
-<p>#start file</p>
-<p>1.0, 0.2, 3.0</p>
-<p>5.0, 1.0, 5.0</p>
-<p>0.3, 0.2, 1.0</p>
-<p>#comment: order: reclass_slope,reclass_sand,reclass_</p>
-<p>#end file</p>
-The first row and first column are related to the first criteria (reclass_slope in our case); the second row and second column are related to the second criteria (reclass_sand in our case) and the third row and third column are related to the third criteria
- ( reclass_elev in our cas), and so on.
-<p>In the work directory should be generated a log.txt file were you can find additional information like: eigenvectors, eigenvalues, weights</p>
-<h2>TODO</h2>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.roughset.html">r.roughset</a>,
-<a href="r.mcda.regime.html">r.mcda.regime</a>,
-<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
-<a href="r.mcda.electre.html">r.mcda.electre</a>,
-<a href="r.mcda.roughset.html">r.mcda.roughset</a>
-<a href="r.in.drsa.html">r.in.drsa</a>
-<a href="r.to.drsa.html">r.to.drsa</a>
-</em>
-<h2>AUTHORS</h2>
-Antonio Boggia - Gianluca Massei<br>
-Department of Economics and Appraisal - University of Perugia - Italy
-<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py 2012-12-01 17:12:23 UTC (rev 54128)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py 2012-12-01 17:12:34 UTC (rev 54129)
@@ -1,111 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.mcda.ahp
-# AUTHOR: Gianluca Massei - Antonio Boggia
-# PURPOSE: Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]
-# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
-# Development Team. This program is free software under the
-# GNU General PublicLicense (>=v2). Read the file COPYING
-# that comes with GRASS for details.
-#%Module
-#% description: Generate a raster map classified with analytic hierarchy process (AHP).
-#% keywords: raster, analytic hierarchy process (AHP), Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: criteria
-#% type: string
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: pairwise
-#% type: string
-#% gisprompt: old,file,input
-#% description: Pairwise comparison matrix
-#% required: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: output classified raster map
-#% required: yes
-#%end
-#%flag
-#% key:k
-#% description:build a void pairwise comparison matrix and exit (no yet implemented)
-#%end
-import sys
-import grass.script as grass
-import numpy as np
-import warnings
-def calculateWeight(pairwise):
- "Define vector of weight based on eigenvector and eigenvalues"
- pairwise=np.genfromtxt(pairwise, delimiter=",")
- warnings.simplefilter("ignore", np.ComplexWarning)
- eigenvalues, eigenvector=np.linalg.eig(pairwise)
- maxindex=np.argmax(eigenvalues)
- eigenvalues=np.float32(eigenvalues)
- eigenvector=np.float32(eigenvector)
- weight=eigenvector[:, maxindex] #extract vector from eigenvector with max vaue in eigenvalues
- weight.tolist() #convert array(numpy) to vector
- weight=[ w/sum(weight) for w in weight ]
- return weight, eigenvalues, eigenvector
-def calculateMap(criteria, weight, outputMap):
- "Parser a formula for mapcalc and run grass.mapcalc"
- formula=''
- for i in range(len(criteria)-1):
- formula += "%s*%s + " % (criteria[i], weight[i])
- formula +="%s*%s " % (criteria[len(criteria)-1], weight[len(criteria)-1])
- grass.mapcalc(outputMap +"=" +formula)
- return 0
-def Consistency(weight,eigenvalues):
- "Calculete Consistency index in accord with Saaty (1977)"
- RI=[0.00, 0.00, 0.00,0.52,0.90,1.12,1.24,1.32,1.41] #order of matrix: 0,1,2,3,4,5,6,7,8
- order=len(weight)
- CI= (np.max(eigenvalues)-order)/(order-1)
- return CI/RI[order-1]
-def ReportLog(eigenvalues,eigenvector, weight, consistency):
- "Make a log file"
- log=open("log.txt", "w")
- log.write("eigenvalues:\n%s" % eigenvalues)
- log.write("\neigenvector:\n%s" % eigenvector)
- log.write("\nweight:\n%s" % weight)
- log.write("\nconsistency:\n%s" % consistency)
- log.close()
- return 0
-def main():
- "main"
- criteria = options['criteria'].split(',')
- pairwise = options['pairwise']
- outputMap = options['output']
- gregion = grass.region()
- nrows = gregion['rows']
- ncols = gregion['cols']
- ewres=int(gregion['ewres'])
- nsres=int(gregion['nsres'])
- weight, eigenvalues, eigenvector = calculateWeight(pairwise)
- calculateMap(criteria, weight, outputMap)
- consistency=Consistency(weight,eigenvalues)
- ReportLog(eigenvalues,eigenvector, weight, consistency)
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
