[GRASS-SVN] r54131 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Sat Dec 1 11:45:14 PST 2012
Author: mmetz
Date: 2012-12-01 11:45:13 -0800 (Sat, 01 Dec 2012)
New Revision: 54131
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/snap.c
Vlib: new Vect_snap_line()
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2012-12-01 17:29:28 UTC (rev 54130)
+++ grass/trunk/include/defs/vector.h 2012-12-01 19:45:13 UTC (rev 54131)
@@ -354,8 +354,8 @@
void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
struct Map_info *);
-void Vect_snap_lines_list2(struct Map_info *, struct ilist *, int,
- double, struct Map_info *);
+int Vect_snap_line(struct Map_info *, struct ilist *, struct line_pnts *,
+ double, int, int *, int *);
void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2012-12-01 17:29:28 UTC (rev 54130)
+++ grass/trunk/lib/vector/Vlib/snap.c 2012-12-01 19:45:13 UTC (rev 54131)
@@ -26,14 +26,21 @@
/* Vertex */
typedef struct
- double x, y;
+ double x, y, z;
int anchor; /* 0 - anchor, do not snap this point, that means snap others to this */
/* >0 - index of anchor to which snap this point */
/* -1 - init value */
} XPNT;
+/* Segment */
typedef struct
+ double x1, y1, z1, /* start point */
+ x2, y2, z2; /* end point */
+} XSEG;
+typedef struct
int anchor;
double along;
} NEW;
@@ -44,7 +51,7 @@
NEW *p1 = (NEW *) pa;
NEW *p2 = (NEW *) pb;
- return (p1->along < p2->along ? -1 : 1);
+ return (p1->along < p2->along ? -1 : (p1->along > p2->along));
if (p1->along < p2->along)
@@ -55,6 +62,20 @@
+typedef struct
+ double x, y, z, along;
+} NEW2;
+/* for qsort */
+static int sort_new2(const void *pa, const void *pb)
+ NEW2 *p1 = (NEW2 *) pa;
+ NEW2 *p2 = (NEW2 *) pb;
/* This function is called by RTreeSearch() to find a vertex */
static int find_item(int id, const struct RTree_Rect *rect, struct ilist *list)
@@ -69,8 +90,42 @@
return 1;
+/* This function is called by RTreeSearch() to add selected node/line/area/isle to the list */
+static int find_item_box(int id, const struct RTree_Rect *rect, void *list)
+ struct bound_box box;
+ box.W = rect->boundary[0];
+ box.S = rect->boundary[1];
+ box.B = rect->boundary[2];
+ box.E = rect->boundary[3];
+ box.N = rect->boundary[4];
+ box.T = rect->boundary[5];
+ dig_boxlist_add((struct boxlist *)list, id, &box);
+ return 0;
+static int add_item_box(int id, const struct RTree_Rect *rect, void *list)
+ return 1;
/* for ilist qsort'ing and bsearch'ing */
-int cmp_int(const void *a, const void *b)
+static int cmp_int(const void *a, const void *b)
int ai = *(int *)a;
int bi = *(int *)b;
@@ -82,6 +137,7 @@
\brief Snap selected lines to existing vertex in threshold.
Snap selected lines to existing vertices of other selected lines.
+ 3D snapping is not supported.
Lines showing how vertices were snapped may be optionally written to error map.
Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
@@ -475,462 +531,488 @@
G_verbose_message(_("New vertices: %d"), ncreated);
- \brief Snap selected lines to existing vertex in threshold.
- Snap selected lines to existing vertices of lines of type type.
- Lines in the list will only be snapped to lines not in the list.
- If a list is given, new snapped lines are added to the list.
- If no list is given, all lines of type type are snapped to lines of
- type type.
- \param Map input map where vertices will be snapped
- \param List_lines list of lines to snap
- \param type type of lines where lines in list will be snapped to
- \param thresh threshold in which snap vertices
+ \brief Snap lines in vector map to existing vertex in threshold.
+ For details see Vect_snap_lines_list()
+ \param[in] Map input map where vertices will be snapped
+ \param[in] type type of lines to snap
+ \param[in] thresh threshold in which snap vertices
\param[out] Err vector map where lines representing snap are written or NULL
\return void
void
-Vect_snap_lines_list2(struct Map_info *Map, struct ilist *List_lines,
- int type, double thresh, struct Map_info *Err)
+Vect_snap_lines(struct Map_info *Map, int type, double thresh,
+ struct Map_info *Err)
- struct line_pnts *Points, *NPoints;
+ int line, nlines, ltype;
+ struct ilist *List;
+ List = Vect_new_list();
+ nlines = Vect_get_num_lines(Map);
+ for (line = 1; line <= nlines; line++) {
+ G_debug(3, "line = %d", line);
+ if (!Vect_line_alive(Map, line))
+ continue;
+ ltype = Vect_read_line(Map, NULL, NULL, line);
+ if (!(ltype & type))
+ continue;
+ G_ilist_add(List, line);
+ Vect_snap_lines_list(Map, List, thresh, Err);
+ Vect_destroy_list(List);
+ return;
+ \brief Snap a line to reference lines in Map with threshold.
+ 3D snapping is supported. The line to snap and the reference lines
+ can but do not need to be in different vector maps.
+ Vect_snap_line() uses less memory, but is slower than
+ Vect_snap_lines_list()
+ For details on snapping, see Vect_snap_lines_list()
+ \param[in] Map input map with reference lines
+ \param[in] reflist list of reference lines
+ \param[in,out] Points line points to snap
+ \param[in] thresh threshold in which to snap vertices
+ \param[in] with_z 2D or 3D snapping
+ \param[in,out] nsnapped number of snapped verices
+ \param[in,out] ncreated number of new vertices (on segments)
+ \return 1 if line was changed, otherwise 0
+int
+Vect_snap_line(struct Map_info *Map, struct ilist *reflist,
+ struct line_pnts *Points, double thresh, int with_z,
+ int *nsnapped, int *ncreated)
+ struct line_pnts *LPoints, *NPoints;
struct line_cats *Cats;
- int line, ltype, line_idx, nlines, new_line, val;
+ int i, v, line, nlines;
+ int changed;
double thresh2;
int point; /* index in points array */
- int nanchors, ntosnap; /* number of anchors and number of points to be snapped */
- int nsnapped, ncreated; /* number of snapped verices, number of new vertices (on segments) */
- int apoints, npoints, nvertices; /* number of allocated points, registered points, vertices */
- XPNT *XPnts; /* Array of points */
- NEW *New = NULL; /* Array of new points */
+ int segment; /* index in segments array */
+ int asegments; /* number of allocated segments */
+ int nvertices; /* number of vertices */
+ XSEG *XSegs = NULL; /* Array of segments */
+ NEW2 *New = NULL; /* Array of new points */
int anew = 0, nnew; /* allocated new points , number of new points */
- struct ilist *List;
- int *Index = NULL; /* indexes of anchors for vertices */
- int aindex = 0; /* allocated Index */
+ struct boxlist *List;
- struct RTree *RTree;
- int rtreefd = -1;
+ struct RTree *pnt_tree, /* spatial index for reference points */
+ *seg_tree; /* spatial index for reference segments */
struct RTree_Rect rect;
rect.boundary = G_malloc(6 * sizeof(RectReal));
+ rect.boundary[0] = 0;
+ rect.boundary[1] = 0;
+ rect.boundary[2] = 0;
+ rect.boundary[3] = 0;
+ rect.boundary[4] = 0;
+ rect.boundary[5] = 0;
- if (List_lines) {
- nlines = List_lines->n_values;
- if (nlines < 1)
- return;
- qsort(List_lines->value, nlines, sizeof(int), cmp_int);
+ changed = 0;
+ if (nsnapped)
+ *nsnapped = 0;
+ if (ncreated)
+ *ncreated = 0;
- Points = Vect_new_line_struct();
+ point = Points->n_points;
+ Vect_line_prune(Points);
+ if (point != Points->n_points)
+ changed = 1;
+ nlines = reflist->n_values;
+ if (nlines < 1)
+ return changed;
+ LPoints = Vect_new_line_struct();
NPoints = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- List = Vect_new_list();
- if (getenv("GRASS_VECTOR_LOWMEM")) {
- char *filename = G_tempfile();
+ List = Vect_new_boxlist(1);
+ with_z = (with_z != 0);
+ pnt_tree = RTreeCreateTree(-1, 0, 2 + with_z);
+ RTreeSetOverflow(pnt_tree, 0);
+ seg_tree = RTreeCreateTree(-1, 0, 2 + with_z);
+ RTreeSetOverflow(seg_tree, 0);
- rtreefd = open(filename, O_RDWR | O_CREAT | O_EXCL, 0600);
- remove(filename);
- RTree = RTreeCreateTree(rtreefd, 0, 2);
thresh2 = thresh * thresh;
- /* Go through all lines in vector, and add each point to structure of points */
- apoints = 0;
- point = 1; /* index starts from 1 ! */
+ point = segment = 1; /* index starts from 1 ! */
nvertices = 0;
- XPnts = NULL;
+ asegments = 0;
- nlines = Vect_get_num_lines(Map);
+ /* Add all vertices and all segments of all reference lines
+ * to spatial indices */
+ for (i = 0; i < nlines; i++) {
- G_verbose_message(_("Snap vertices Pass 1: select points"));
- for (line = 1; line <= nlines; line++) {
- int v;
+ line = reflist->value[i];
- G_percent(line, nlines, 2);
continue;
- ltype = Vect_read_line(Map, Points, Cats, line);
- val = -1;
- if (List_lines) {
- if (bsearch(&line, List_lines->value, List_lines->n_values,
- sizeof(int), cmp_int)) {
- /* snap this line to other lines,
- * don't make its vertices anchor points */
- val = -2;
- else {
- if (!(ltype & type))
- continue;
- else {
- continue;
+ Vect_read_line(Map, LPoints, Cats, line);
+ Vect_line_prune(LPoints);
- for (v = 0; v < Points->n_points; v++) {
+ for (v = 0; v < LPoints->n_points; v++) {
G_debug(3, " vertex v = %d", v);
nvertices++;
/* Box */
- rect.boundary[0] = Points->x[v];
- rect.boundary[3] = Points->x[v];
- rect.boundary[1] = Points->y[v];
- rect.boundary[4] = Points->y[v];
- rect.boundary[2] = 0;
- rect.boundary[5] = 0;
+ rect.boundary[0] = LPoints->x[v];
+ rect.boundary[3] = LPoints->x[v];
+ rect.boundary[1] = LPoints->y[v];
+ rect.boundary[4] = LPoints->y[v];
+ if (with_z) {
+ rect.boundary[2] = LPoints->z[v];
+ rect.boundary[5] = LPoints->z[v];
/* Already registered ? */
- Vect_reset_list(List);
- RTreeSearch(RTree, &rect, (void *)find_item, List);
+ Vect_reset_boxlist(List);
+ RTreeSearch(pnt_tree, &rect, find_item_box, (void *)List);
G_debug(3, "List : nvalues = %d", List->n_values);
if (List->n_values == 0) { /* Not found */
- /* Add to tree and to structure */
- RTreeInsertRect(&rect, point, RTree);
- if ((point - 1) == apoints) {
- apoints += 10000;
- XPnts =
- (XPNT *) G_realloc(XPnts,
- (apoints + 1) * sizeof(XPNT));
- XPnts[point].x = Points->x[v];
- XPnts[point].y = Points->y[v];
- XPnts[point].anchor = val;
+ /* Add to points tree */
+ RTreeInsertRect(&rect, point, pnt_tree);
point++;
+ /* reference segments */
+ if (v) {
+ /* Box */
+ if (LPoints->x[v - 1] < LPoints->x[v]) {
+ rect.boundary[0] = LPoints->x[v - 1];
+ else {
+ rect.boundary[3] = LPoints->x[v - 1];
+ if (LPoints->y[v - 1] < LPoints->y[v]) {
+ rect.boundary[1] = LPoints->y[v - 1];
+ else {
+ rect.boundary[4] = LPoints->y[v - 1];
+ if (LPoints->z[v - 1] < LPoints->z[v]) {
+ rect.boundary[2] = LPoints->z[v - 1];
+ else {
+ rect.boundary[5] = LPoints->z[v - 1];
+ /* do not check for duplicates, too costly
+ * because different segments can have identical boxes */
+ RTreeInsertRect(&rect, segment, seg_tree);
+ if ((segment - 1) == asegments) {
+ asegments += 1000;
+ XSegs =
+ (XSEG *) G_realloc(XSegs,
+ (asegments + 1) * sizeof(XSEG));
+ XSegs[segment].x1 = LPoints->x[v - 1];
+ XSegs[segment].x2 = LPoints->x[v];
+ XSegs[segment].y1 = LPoints->y[v - 1];
+ XSegs[segment].y2 = LPoints->y[v];
+ if (with_z) {
+ XSegs[segment].z1 = LPoints->z[v - 1];
+ XSegs[segment].z1 = LPoints->z[v];
+ else {
+ XSegs[segment].z1 = 0;
+ XSegs[segment].z2 = 0;
+ segment++;
- npoints = point - 1;
+ /* go through all vertices of the line to snap */
+ for (v = 0; v < Points->n_points; v++) {
+ double dist2, tmpdist2;
+ double x, y, z;
- /* Go through all registered points and if not yet marked mark it as anchor and assign this anchor
- * to all not yet marked points in threshold */
+ dist2 = thresh2 + thresh2;
+ x = Points->x[v];
+ y = Points->y[v];
+ z = Points->z[v];
- G_verbose_message(_("Snap vertices Pass 2: assign anchor vertices"));
+ /* Box */
+ rect.boundary[0] = Points->x[v] - thresh;
+ rect.boundary[3] = Points->x[v] + thresh;
+ rect.boundary[1] = Points->y[v] - thresh;
+ rect.boundary[4] = Points->y[v] + thresh;
+ if (with_z) {
+ rect.boundary[2] = Points->z[v] - thresh;
+ rect.boundary[5] = Points->z[v] + thresh;
- nanchors = ntosnap = 0;
- for (point = 1; point <= npoints; point++) {
- int i;
+ /* find nearest reference vertex */
- G_percent(point, npoints, 2);
+ RTreeSearch(pnt_tree, &rect, add_item_box, (void *)List);
- G_debug(3, " point = %d", point);
- /* also skip vertices of lines to snap */
- if (XPnts[point].anchor >= 0 || XPnts[point].anchor == -2)
- continue;
- XPnts[point].anchor = 0; /* make it anchor */
- nanchors++;
- /* Find points in threshold */
- rect.boundary[0] = XPnts[point].x - thresh;
- rect.boundary[3] = XPnts[point].x + thresh;
- rect.boundary[1] = XPnts[point].y - thresh;
- rect.boundary[4] = XPnts[point].y + thresh;
- RTreeSearch(RTree, &rect, (void *)add_item, List);
- G_debug(4, " %d points in threshold box", List->n_values);
for (i = 0; i < List->n_values; i++) {
- int pointb;
- double dx, dy, dist2;
+ double dx = List->box[i].E - Points->x[v];
+ double dy = List->box[i].N - Points->y[v];
+ double dz = 0;
+ if (with_z)
+ dz = List->box[i].T - Points->z[v];
+ tmpdist2 = dx * dx + dy * dy + dz * dz;
+ if (tmpdist2 < dist2) {
+ dist2 = tmpdist2;
- pointb = List->value[i];
- if (pointb == point)
- continue;
- dx = XPnts[pointb].x - XPnts[point].x;
- dy = XPnts[pointb].y - XPnts[point].y;
- dist2 = dx * dx + dy * dy;
- if (dist2 > thresh2) /* outside threshold */
- continue;
- /* doesn't have an anchor yet */
- if (XPnts[pointb].anchor < 0) {
- XPnts[pointb].anchor = point;
- ntosnap++;
+ x = List->box[i].E;
+ y = List->box[i].N;
+ z = List->box[i].T;
- else if (XPnts[pointb].anchor > 0) { /* check distance to previously assigned anchor */
- double dist2_a;
- dx = XPnts[XPnts[pointb].anchor].x - XPnts[pointb].x;
- dy = XPnts[XPnts[pointb].anchor].y - XPnts[pointb].y;
- dist2_a = dx * dx + dy * dy;
+ if (dist2 <= thresh2 && dist2 > 0) {
+ Points->x[v] = x;
+ Points->y[v] = y;
+ Points->z[v] = z;
- /* replace old anchor */
- if (dist2 < dist2_a) {
+ changed = 1;
+ if (nsnapped)
+ (*nsnapped)++;
- /* Go through all lines and:
- * 1) for all vertices: if not anchor snap it to its anchor
- * 2) for all segments: snap it to all anchors in threshold (except anchors of vertices of course) */
+ double x, y, z;
+ x = Points->x[v];
+ y = Points->y[v];
+ z = Points->z[v];
- nsnapped = ncreated = 0;
- G_verbose_message(_("Snap vertices Pass 3: snap to assigned points"));
- if (List_lines)
- else
- for (line_idx = 0; line_idx < nlines; line_idx++) {
- int v, spoint, anchor;
- int changed = 0;
- G_percent(line_idx, nlines, 2);
- if (List_lines)
- line = List_lines->value[line_idx];
- else
- line = line_idx;
- G_debug(3, "line = %d", line);
- if (!Vect_line_alive(Map, line))
- continue;
- if (!List_lines && !(type & ltype))
- continue;
- if (Points->n_points >= aindex) {
- aindex = Points->n_points;
- Index = (int *)G_realloc(Index, aindex * sizeof(int));
+ /* Box */
+ if (with_z) {
- /* Snap all vertices */
- /* Box */
+ /* find nearest reference segment */
- /* Find point ( should always find one point ) */
+ RTreeSearch(seg_tree, &rect, add_item_box, (void *)List);
+ for (i = 0; i < List->n_values; i++) {
+ double tmpx, tmpy, tmpz;
+ int segment, status;
+ segment = List->id[i];
+ /* Check the distance */
+ tmpdist2 =
+ dig_distance2_point_to_line(Points->x[v],
+ Points->y[v],
+ Points->z[v],
+ XSegs[segment].x1,
+ XSegs[segment].y1,
+ XSegs[segment].z1,
+ XSegs[segment].x2,
+ XSegs[segment].y2,
+ XSegs[segment].z2,
+ with_z, &tmpx, &tmpy, &tmpz,
+ NULL, &status);
- spoint = List->value[0];
- anchor = XPnts[spoint].anchor;
+ if (tmpdist2 < dist2 && status == 0) {
+ dist2 = tmpdist2;
- if (anchor > 0) { /* to be snapped */
- Points->x[v] = XPnts[anchor].x;
- Points->y[v] = XPnts[anchor].y;
- nsnapped++;
- changed = 1;
- Index[v] = anchor; /* point on new location */
+ x = tmpx;
+ y = tmpy;
+ z = tmpz;
- else {
- Index[v] = spoint; /* old point */
- /* New points */
- Vect_reset_line(NPoints);
+ Points->x[v] = x;
+ Points->y[v] = y;
+ Points->z[v] = z;
+ changed = 1;
+ if (nsnapped)
+ (*nsnapped)++;
- /* Snap all segments to anchors in threshold */
- for (v = 0; v < Points->n_points - 1; v++) {
- int i;
- double x1, x2, y1, y2, xmin, xmax, ymin, ymax;
+ RTreeDestroyTree(seg_tree);
+ G_free(XSegs);
- G_debug(3, " segment = %d end anchors : %d %d", v, Index[v],
- Index[v + 1]);
+ /* go through all segments of the line to snap */
+ /* find nearest reference vertex, add this vertex */
+ for (v = 0; v < Points->n_points - 1; v++) {
+ double x1, x2, y1, y2, z1, z2;
+ double xmin, xmax, ymin, ymax, zmin, zmax;
- x1 = Points->x[v];
- x2 = Points->x[v + 1];
- y1 = Points->y[v];
- y2 = Points->y[v + 1];
+ x1 = Points->x[v];
+ x2 = Points->x[v + 1];
+ y1 = Points->y[v];
+ y2 = Points->y[v + 1];
+ if (with_z) {
+ z1 = Points->z[v];
+ z2 = Points->z[v + 1];
+ else {
+ z1 = z2 = 0;
- Vect_append_point(NPoints, Points->x[v], Points->y[v],
- Points->z[v]);
+ Vect_append_point(NPoints, Points->x[v], Points->y[v],
+ Points->z[v]);
- /* Box */
- if (x1 <= x2) {
- xmin = x1;
- xmax = x2;
- else {
- xmin = x2;
- xmax = x1;
- if (y1 <= y2) {
- ymin = y1;
- ymax = y2;
- else {
- ymin = y2;
- ymax = y1;
+ /* Box */
+ if (x1 <= x2) {
+ xmin = x1;
+ xmax = x2;
+ else {
+ xmin = x2;
+ xmax = x1;
+ if (y1 <= y2) {
+ ymin = y1;
+ ymax = y2;
+ else {
+ ymin = y2;
+ ymax = y1;
+ if (z1 <= z2) {
+ zmin = z1;
+ zmax = z2;
+ else {
+ zmin = z2;
+ zmax = z1;
- rect.boundary[0] = xmin - thresh;
- rect.boundary[3] = xmax + thresh;
- rect.boundary[1] = ymin - thresh;
- rect.boundary[4] = ymax + thresh;
+ rect.boundary[0] = xmin - thresh;
+ rect.boundary[3] = xmax + thresh;
+ rect.boundary[1] = ymin - thresh;
+ rect.boundary[4] = ymax + thresh;
+ rect.boundary[2] = zmin - thresh;
+ rect.boundary[5] = zmax + thresh;
- /* Find points */
+ /* Find points */
- G_debug(3, " %d points in box", List->n_values);
+ G_debug(3, " %d points in box", List->n_values);
- /* Snap to anchor in threshold different from end points */
- nnew = 0;
- for (i = 0; i < List->n_values; i++) {
- double dist2, along;
+ /* Snap to vertex in threshold different from end points */
+ nnew = 0;
+ double dist2, along;
+ int status;
+ if (!with_z)
+ List->box[i].T = 0;
- spoint = List->value[i];
- G_debug(4, " spoint = %d anchor = %d", spoint,
- XPnts[spoint].anchor);
+ if (Points->x[v] == List->box[i].E &&
+ Points->y[v] == List->box[i].N &&
+ Points->z[v] == List->box[i].T)
+ continue; /* start point */
- if (spoint == Index[v] || spoint == Index[v + 1])
- continue; /* end point */
- if (XPnts[spoint].anchor > 0)
- continue; /* point is not anchor */
+ if (Points->x[v + 1] == List->box[i].E &&
+ Points->y[v + 1] == List->box[i].N &&
+ Points->z[v + 1] == List->box[i].T)
+ continue; /* end point */
- /* Check the distance */
- dist2 =
- dig_distance2_point_to_line(XPnts[spoint].x,
- XPnts[spoint].y, 0, x1, y1, 0,
- x2, y2, 0, 0, NULL, NULL,
- NULL, &along, NULL);
+ dist2 =
+ dig_distance2_point_to_line(List->box[i].E,
+ List->box[i].N,
+ List->box[i].T, x1, y1, z1,
+ x2, y2, z2, with_z, NULL, NULL,
+ NULL, &along, &status);
- G_debug(4, " distance = %lf", sqrt(dist2));
+ if (dist2 <= thresh2 && status == 0) {
+ G_debug(4, " anchor in thresh, along = %lf", along);
- if (dist2 <= thresh2) {
- G_debug(4, " anchor in thresh, along = %lf", along);
- if (nnew == anew) {
- anew += 100;
- New = (NEW *) G_realloc(New, anew * sizeof(NEW));
- New[nnew].anchor = spoint;
- New[nnew].along = along;
- nnew++;
+ if (nnew == anew) {
+ anew += 100;
+ New = (NEW2 *) G_realloc(New, anew * sizeof(NEW2));
+ New[nnew].x = List->box[i].E;
+ New[nnew].y = List->box[i].N;
+ New[nnew].z = List->box[i].T;
+ New[nnew].along = along;
+ nnew++;
- G_debug(3, " nnew = %d", nnew);
- /* insert new vertices */
- if (nnew > 0) {
- /* sort by distance along the segment */
- qsort(New, sizeof(char) * nnew, sizeof(NEW), sort_new);
+ G_debug(3, "dist: %g, thresh: %g", dist2, thresh2);
+ G_debug(3, " nnew = %d", nnew);
+ /* insert new vertices */
+ if (nnew > 0) {
+ /* sort by distance along the segment */
+ qsort(New, nnew, sizeof(NEW2), sort_new2);
- for (i = 0; i < nnew; i++) {
- anchor = New[i].anchor;
- /* Vect_line_insert_point ( Points, ++v, XPnts[anchor].x, XPnts[anchor].y, 0); */
- Vect_append_point(NPoints, XPnts[anchor].x,
- XPnts[anchor].y, 0);
- ncreated++;
- changed = 1;
+ for (i = 0; i < nnew; i++) {
+ Vect_append_point(NPoints, New[i].x, New[i].y, New[i].z);
+ if (ncreated)
+ (*ncreated)++;
+ changed = 1;
- /* append end point */
- v = Points->n_points - 1;
- Vect_append_point(NPoints, Points->x[v], Points->y[v], Points->z[v]);
+ /* append end point */
+ v = Points->n_points - 1;
+ Vect_append_point(NPoints, Points->x[v], Points->y[v], Points->z[v]);
- if (changed) { /* rewrite the line */
- Vect_line_prune(NPoints); /* remove duplicates */
- if (NPoints->n_points > 1 || !(ltype & GV_LINES)) {
- new_line = Vect_rewrite_line(Map, line, ltype, NPoints, Cats);
- if (List_lines)
- G_ilist_add(List_lines, new_line);
- else {
- Vect_delete_line(Map, line);
- if (Err) {
- Vect_write_line(Err, ltype, Points, Cats);
- } /* for each line */
- G_percent(line_idx, nlines, 2); /* finish it */
+ if (Points->n_points != NPoints->n_points) {
+ Vect_line_prune(NPoints); /* remove duplicates */
+ Vect_reset_line(Points);
+ Vect_append_points(Points, NPoints, GV_FORWARD);
- Vect_destroy_line_struct(Points);
+ Vect_destroy_line_struct(LPoints);
Vect_destroy_line_struct(NPoints);
Vect_destroy_cats_struct(Cats);
- G_free(XPnts);
- G_free(Index);
+ Vect_destroy_boxlist(List);
G_free(New);
- RTreeDestroyTree(RTree);
- if (rtreefd >= 0)
- close(rtreefd);
+ RTreeDestroyTree(pnt_tree);
G_free(rect.boundary);
- G_verbose_message(_("Snapped vertices: %d"), nsnapped);
- G_verbose_message(_("New vertices: %d"), ncreated);
+ return changed;
- \brief Snap lines in vector map to existing vertex in threshold.
- For details see Vect_snap_lines_list()
- \param[in] Map input map where vertices will be snapped
- \param[in] type type of lines to snap
- \param[in] thresh threshold in which snap vertices
- \param[out] Err vector map where lines representing snap are written or NULL
- \return void
-void
-Vect_snap_lines(struct Map_info *Map, int type, double thresh,
- struct Map_info *Err)
- int line, nlines, ltype;
- continue;
- ltype = Vect_read_line(Map, NULL, NULL, line);
- continue;
- /* no need to check for duplicates:
- * use G_ilist_add() instead of Vect_list_append() */
- G_ilist_add(List, line);
- Vect_snap_lines_list(Map, List, thresh, Err);
- Vect_destroy_list(List);
- return;
