[GRASS-SVN] r54132 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Sat Dec 1 11:46:15 PST 2012
Author: mmetz
Date: 2012-12-01 11:46:15 -0800 (Sat, 01 Dec 2012)
New Revision: 54132
grass/trunk/vector/v.overlay/area_area.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.overlay/v.overlay.html
v.overlay: use Vect_snap_line()
Modified: grass/trunk/vector/v.overlay/area_area.c
--- grass/trunk/vector/v.overlay/area_area.c 2012-12-01 19:45:13 UTC (rev 54131)
+++ grass/trunk/vector/v.overlay/area_area.c 2012-12-01 19:46:15 UTC (rev 54132)
@@ -15,6 +15,15 @@
#include <grass/glocale.h>
#include "local.h"
+/* for ilist qsort'ing and bsearch'ing */
+static int cmp_int(const void *a, const void *b)
+ int ai = *(int *)a;
+ int bi = *(int *)b;
+ return (ai < bi ? -1 : (ai > bi));
int area_area(struct Map_info *In, int *field, struct Map_info *Out,
struct field_info *Fi, dbDriver * driver, int operator,
int *ofield, ATTRIBUTES * attr, struct ilist *BList, double snap)
@@ -34,13 +43,63 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
/* optional snap */
if (snap > 0) {
- G_message(_("Snapping lines..."));
+ int i, j, snapped_lines = 0;
+ struct bound_box box;
+ struct boxlist *boxlist = Vect_new_boxlist(0);
+ struct ilist *reflist = Vect_new_list();
+ G_message(_("Snapping boundaries with %g ..."), snap);
/* snap boundaries in B to boundaries in A
* not modifying boundaries in A */
- Vect_snap_lines_list2(Out, BList, GV_BOUNDARY, snap, NULL);
+ if (BList->n_values > 1)
+ qsort(BList->value, BList->n_values, sizeof(int), cmp_int);
+ snapped_lines = 0;
+ nlines = BList->n_values;
+ for (i = 0; i < nlines; i++) {
+ line = BList->value[i];
+ Vect_read_line(Out, Points, Cats, line);
+ /* select lines by box */
+ Vect_get_line_box(Out, line, &box);
+ box.E += snap;
+ box.W -= snap;
+ box.N += snap;
+ box.S -= snap;
+ box.T = 0.0;
+ box.B = 0.0;
+ Vect_select_lines_by_box(Out, &box, GV_BOUNDARY, boxlist);
+ if (boxlist->n_values > 0) {
+ Vect_reset_list(reflist);
+ for (j = 0; j < boxlist->n_values; j++) {
+ int aline = boxlist->id[j];
+ if (!bsearch(&aline, BList->value, BList->n_values,
+ sizeof(int), cmp_int)) {
+ G_ilist_add(reflist, aline);
+ /* snap bline to alines */
+ if (Vect_snap_line(Out, reflist, Points, snap, 0, NULL, NULL)) {
+ /* rewrite bline*/
+ Vect_delete_line(Out, line);
+ ret = Vect_write_line(Out, GV_BOUNDARY, Points, Cats);
+ G_ilist_add(BList, ret);
+ snapped_lines++;
+ G_debug(3, "line %d snapped", line);
+ Vect_destroy_boxlist(boxlist);
+ Vect_destroy_list(reflist);
+ G_verbose_message(_("%d boundaries snapped"), snapped_lines);
/* same procedure like for v.in.ogr
@@ -49,7 +108,7 @@
* and Vect_clean_small_angles_at_nodes() until no more small dangles are found */
do {
G_message(_("Breaking lines..."));
- Vect_break_lines_list(Out, NULL, BList, GV_LINE | GV_BOUNDARY, NULL);
+ Vect_break_lines_list(Out, NULL, BList, GV_BOUNDARY, NULL);
/* Probably not necessary for LINE x AREA */
G_message(_("Removing duplicates..."));
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2012-12-01 19:45:13 UTC (rev 54131)
+++ grass/trunk/vector/v.overlay/main.c 2012-12-01 19:46:15 UTC (rev 54132)
@@ -9,6 +9,7 @@
* Markus Neteler <neteler itc.it>,
* Paul Kelly <paul-grass stjohnspoint.co.uk>
* OGR support by Martin Landa <landa.martin gmail.com>
+ * Markus Metz
* PURPOSE:
* COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
@@ -228,6 +229,7 @@
nlines_out = 0;
for (line = 1; line <= nlines; line++) {
int ltype;
+ int vertices = 100; /* max number of vertices per line */
G_percent(line, nlines, 1); /* must be before any continue */
@@ -248,10 +250,11 @@
continue;
/* TODO: figure out a reasonable threshold */
- if (Points->n_points > 100) {
- int vertices = 100;
+ if (Points->n_points > vertices) {
int start = 0; /* number of coordinates written */
+ vertices = Points->n_points / (Points->n_points / vertices + 1);
/* split */
while (start < Points->n_points - 1) {
int v = 0;
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2012-12-01 19:45:13 UTC (rev 54131)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2012-12-01 19:46:15 UTC (rev 54132)
@@ -11,9 +11,12 @@
can be created. Snapping is enabled by default and can be disabled by
setting the <em>snap</em> option to a negative value. Recommended values
are between 0.00000001 and 0.0001. Using larger values for snapping can
-have undesired side-effects. Snapping modifies only boundaries in binput,
-which are snapped to boundaries in ainput. Boundaries in ainput are not
-modified.
+have undesired side-effects, but may sometimes be necessary to get a
+clean output (see example below). In general, it is recommended to start
+with a small snapping threshold, gradually increasing the threshold until
+the result is reasonably clean. Snapping modifies only boundaries in
+binput, which are snapped to boundaries in ainput. Boundaries in ainput
+are not modified.
<!-- This is outdated
There are 3 links attached to features in output map,
<ul>
@@ -70,13 +73,13 @@
it! Therefore it is advisable to copy tables from ainput and binput first and
connect the copied tables to the output map.-->
-<h2>EXAMPLE POLYGON TO POLYGON UNION</h2>
+<h2>EXAMPLES</h2>
+<h4>Polygons overlaid with ploygons</h4>
<div class="code"><pre>
v.overlay ainput=lake binput=province output=lakeXprovince operator=or
</pre></div>
Polygon union of urban area and Census 2000 areas (North Carolina dataset):
@@ -120,11 +123,14 @@
<img src="v_overlay_census_wake2000.png" alt="GRASS v.overlay: polygon to polygon union (input 2)" border=1>
<img src="v_overlay_urban_census2000.png" alt="GRASS v.overlay: polygon to polygon union (result)" border=1>
<br>
-<i>v.overlay: Polygon union of urban area and Census 2000 areas (North Carolina dataset)</i>
+<i>v.overlay: Polygon union (right) of urban area (left) and Census 2000 (middle) areas (North Carolina dataset)</i>
</center>
+As can be seen by the resulting large number of centroids on boundaries,
+the urban areas do not match exactly the Census 2000 areas. In this case
+a clean result can be obtained by snapping with a threshold of 0.1 (1 cm).
-<h2>EXAMPLE LINE TO POLYGON CLIPPING</h2>
+<h4>Lines overlaid with polygons</h4>
Using the North Carolina sample dataset, we clip the roads map to the area
of city of Raleigh, preserving road attributes in layer 1:
