[GRASS-SVN] r54161 - grass-addons/grass6/raster/r.mcda.roughset
Mon Dec 3 07:23:41 PST 2012
Author: gianluca
Date: 2012-12-03 07:23:41 -0800 (Mon, 03 Dec 2012)
New Revision: 54161
   grass-addons/grass6/raster/r.mcda.roughset/r.mcda.roughset.py
Modified: grass-addons/grass6/raster/r.mcda.roughset/r.mcda.roughset.py
--- grass-addons/grass6/raster/r.mcda.roughset/r.mcda.roughset.py	2012-12-03 12:42:47 UTC (rev 54160)
+++ grass-addons/grass6/raster/r.mcda.roughset/r.mcda.roughset.py	2012-12-03 15:23:41 UTC (rev 54161)
@@ -1,611 +1,611 @@
-#!/usr/bin/env python
-# MODULE:	   r.mcda.roughset
-# AUTHOR:	   Gianluca Massei - Antonio Boggia
-# PURPOSE:	  Generate a MCDA map from several criteria maps using Dominance Rough Set Approach - DRSA
-#					   (DOMLEM algorithm proposed by  (S. Greco, B. Matarazzo, R. Slowinski)
-# COPYRIGHT:  c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#					   Development Team. This program is free software under the
-#					   GNU General PublicLicense (>=v2). Read the file COPYING
-#					   that comes with GRASS for details.
-#%Module
-#% description: Generate a MCDA map from several criteria maps using Dominance Rough Set Approach.
-#% keywords: raster, Dominance Rough Set Approach
-#% keywords: Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: criteria
-#% type: string
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: preferences
-#% type: string
-#% key_desc: character
-#% description: gain,cost
-#% required: yes
-#%end
-#%option
-#% key: decision
-#% type: string
-#% key_desc: name
-#% description: Name of decision raster map
-#% required: yes
-#%end
-#%option
-#% key: outputMap
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: Output classified raster map
-#% required: yes
-#%end
-#%option
-#% key: outputTxt
-#% type: string
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% description: Name for output files (base for *.isf  and *.rls files)
-#% answer:infosys
-#% required: yes
-#%end
-#%flag
-#% key: l
-#% description: do not remove single rules in vector format
-#% answer:false
-#%end
-#%flag
-#% key: n
-#% description: compute null value as zero
-#% answer:true
-#%end
-import sys
-import copy
-import numpy as np
-from time import time, ctime
-import grass.script as grass
-import grass.script.array as garray
-def BuildFileISF(attributes, preferences, decision, outputMap, outputTxt):
-	outputTxt=outputTxt+".isf"
-	outf = file(outputTxt,"w")
-	outf.write("**ATTRIBUTES\n")
-	for i in range(len(attributes)):
-		outf.write("+ %s: (continuous)\n" % attributes[i])
-	outf.write("+ %s: [" % decision)
-	value=[]
-	value=grass.read_command("r.describe", flags = "1n", map = decision)
-	v=value.split()
-	for i in range(len(v)-1):
-		outf.write("%s, " % str(v[i]))
-	outf.write("%s]\n" % str(v[len(v)-1]))
-	outf.write("decision: %s\n" % decision)
-	outf.write("\n**PREFERENCES\n")
-		if(preferences[i]==""):
-			preferences[i]="none"
-		outf.write("%s: %s\n" % (attributes[i], preferences[i]))
-	outf.write("%s: gain\n" % decision)
-	if flags['n']:
-			print "%s - convert null to 0" % str(attributes[i])
-			grass.run_command("r.null", map=attributes[i], null=0)
-	outf.write("\n**EXAMPLES\n")
-	examples=[]
-	MATRIX=[]
-		grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
-						 rast="rast",
-						 decision=decision,
-						 attribute=attributes[i])
-		tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
-		example=tmp.split()
-		examples.append(example)
-	tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
-	MATRIX=map(list,zip(*examples))
-	MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
-	MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
-	for r in range(len(MATRIX)):
-		for c in range(len(MATRIX[0])):
-			outf.write("%s " % (MATRIX[r][c]))
-#			outf.write("%s " % round(float(MATRIX[r][c]), 2))
-		outf.write("\n")
-	outf.write("**END")
-	outf.close()
-	return outputTxt
-def collect_attributes (data):
-	"Collects the values of header files isf, puts them in an array of dictionaries"
-	header=[]
-	attribute=dict()
-	j=0
-	start=(data.index(['**ATTRIBUTES'])+1)
-	end=(data.index(['**PREFERENCES'])-1)
-	for r in range(start, end):
-		attribute={'name':data[r][1].strip('+:')}
-		header.append(attribute)
-	decision=data[end-1][1]
-	end=(data.index(['**EXAMPLES']))
-	start=(data.index(['**PREFERENCES'])+1)
-	for r in header:
-		r['preference']=data[start+j][1]
-		j=j+1
-	return header
-def collect_examples (data):
-	"Collect examples values and put them in a matrix (list of lists) "
-	matrix=[]
-	data=[r for r in data if not '?' in r] #filter objects with " ?"
-#	data=[data.remove(r) for r in data if data.count(r)>1]
-	start=(data.index(['**EXAMPLES'])+1)
-	end=data.index(['**END'])
-	for i in range(start, end):
-		data[i]=(map(float, data[i]))
-		matrix.append(data[i])
-	i=1
-	for r in matrix:
-		r.insert(0, str(i))
-		i=i+1
-##	matrix=[list(i) for i in set(tuple(j) for j in matrix)] #remove duplicate example
-	return matrix
-def FileToInfoSystem(isf):
-	"Read *.isf file and copy it's values in Infosystem dictionary"
-	data=[]
-	try:
-		infile=open(isf,"r")
-		rows=infile.readlines()
-		for line in rows:
-			line=(line.split())
-			if (len(line)>0 ):
-				data.append(line)
-		infile.close()
-		infosystem={'attributes':collect_attributes(data),'examples':collect_examples(data)}
-	except TypeError:
-		print "\n\n Computing error or input file %s is not readeable. Exiting gracefully" % isf
-		sys.exit(0)
-	return infosystem
-def UnionOfClasses (infosystem):
-	"Find upward and downward union for all classes and put it in a dictionary"
-	DecisionClass=[]
-	AllClasses=[]
-	matrix=infosystem['examples']
-	for r in matrix:
-		DecisionClass.append(int(r[-1]))
-	DecisionClass=list(set(DecisionClass))
-	for c in range(len(DecisionClass)):
-		tmplist=[r for r in matrix if int(r[-1])==DecisionClass[c]]
-		AllClasses.append(tmplist)
-	return AllClasses
-def DownwardUnionsOfClasses (infosystem):
-	"For each decision class, downward union corresponding to a decision class\
-	is composed of this class and all worse classes (<=)"
-	DownwardUnionClass=[]
-	DecisionClass=[]
-	for r in matrix:
-	for c in DecisionClass:
-		tmplist=[r for r in matrix if int(r[-1])<=c]
-		DownwardUnionClass.append(tmplist)
-		#label=[row[0] for row in tmplist]
-	return DownwardUnionClass
-def UpwardUnionsOfClasses (infosystem):
-	"For each decision class, upward union corresponding to a decision class \
-	is composed of this class and all better classes.(>=)"
-	UpwardUnionClass=[]
-	DecisionClass=[]
-	for r in matrix:
-		tmplist=[r for r in matrix if int(r[-1])>=c]
-		UpwardUnionClass.append(tmplist)
-	return UpwardUnionClass
-def is_better (r1,r2, preference):
-	"Check if r1 is better than r2"
-	return all((( x >=y and p=='gain') or (x<=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
-def is_worst (r1,r2, preference):
-	"Check if r1 is worst than r2"
-	return all((( x <=y and p=='gain') or (x>=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
-def DominatingSet (infosystem):
-	"Find P-dominating set"
-	preference=[s['preference'] for s in infosystem['attributes'] ]
-	Dominating=[]
-	for row in matrix:
-		examples=[r  for r in matrix if  is_better(r[1:-1], row[1:-1], preference) ]
-		Dominating.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
-##	for dom in Dominating:
-##		print  dom['dominance'] ,' dominating ', dom['object']
-	return Dominating
-def DominatedSet (infosystem):
-	"Find P-Dominated set"
-	Dominated=[]
-		examples=[r  for r in matrix if  is_worst(r[1:-1], row[1:-1], preference[:-1]) ]
-		Dominated.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
-##	for dom in Dominated:
-##		print  dom['dominance'] ,' is dominated by ', dom['object']
-	return Dominated
-def LowerApproximation (UnionClasses,  Dom):
-	"Find Lower approximation and return a dictionaries list"
-	c=1
-	LowApprox=[]
-	single=dict()
-	for union in UnionClasses:
-		tmp=[]
-		UClass=set([row[0] for row in union] )
-		for d in Dom:
-			if (UClass.issuperset(set(d['dominance']))): #if Union class is a superse of dominating/dominated set, =>single Loer approx.
-				tmp.append(d['object'])
-		single={'class':c, 'objects':tmp} #dictionary for lower approximation  --
-		LowApprox.append(single) #insert all Lower approximation in a list
-		c+=1
-	return LowApprox
-def UpperApproximation (UnionClasses,  Dom):
-	"Find Upper approximation and return a dictionaries list"
-	c=1
-	UppApprox=[]
-	single=dict()
-		UnClass=[row[0] for row in union]  #single union class
-		s=[]
-		for d in Dom:
-		   if len(set(d['dominance']) & set(UnClass)) >0:
-			   s.append(d['object'])
-#			   print set(s)
-		single={'class':c,'objects':list(set(s))}
-		UppApprox.append(single)
-		c+=1
-	return UppApprox
-def Boundaries (UppApprox, LowApprox):
-	"Find Boundaries like doubtful regions"
-	Boundary=[]
-	single=dict()
-	for i in range(len(UppApprox)):
-		single={'class':i, 'objects':list (set(UppApprox[i]['objects'])-set(LowApprox[i]['objects']) )}
-		Boundary.append(single)
-	return Boundary
-def AccuracyOfApproximation(UppApprox, LowApprox):
-	"Define the accuracy of approximation of Upward and downward approximation class"
-	return len(LowApprox)/len(UppApprox)
-def QualityOfQpproximation(DownwardBoundary,  infosystem):
-	"Defines the quality of approximation of the partition Cl or, briefly, the quality of sorting"
-	UnionBoundary=set()
-	U=set([i[0] for i in infosystem['examples']])
-	for b in DownwardBoundary:
-		UnionBoundary=set(UnionBoundary) | set(b['objects'])
-	return float(len(U-UnionBoundary)) / float(len(U))
-def FindObjectCovered (rules, selected):
-	"Find objects covered by a single rule and return\
-	all related examples covered"
-	obj=[]
-	examples=[]
-	for rule in rules:
-		examples.append(rule['objectsCovered'])
-	if len(examples)>0:
-		examples = reduce(set.intersection,map(set,examples))  #functional approach: intersect all lists if example is not empty
-		examples = list(set(examples) & set([r[0] for r in selected]))
-	return examples #all examples covered from a single rule
-def Evaluate (elem,rules,G,selected,infosystem):
-	"Calcolate first and second evaluate index, according with original DOMLEM Algorithm"
-	tmpRules=copy.deepcopy(rules)
-	tmpElem=copy.deepcopy(elem)
-	tmpRules.append(tmpElem)
-	Object=[]
-	Object=FindObjectCovered(tmpRules,selected)
-	if(float(len(Object)))>0:
-			 firstEvaluate=float(len(set(G) & set(Object))) / float(len(Object))
-			 secondEvaluate=float(len(set(G) & set(Object)))
-	else:
-			 firstEvaluate=0
-			 secondEvaluate=0
-	return firstEvaluate,secondEvaluate
-def FindBestCondition (best, elem, rules, selected, G, infosystem):
-	"Choose the best condition"
-	firstElem,secondElem=Evaluate(elem,rules,G,selected,infosystem)
-	firstBest,secondBest=Evaluate(best,rules,G,selected,infosystem)
-	if (firstElem>firstBest) or (firstElem==firstBest and secondElem>=secondBest):
-		best=copy.deepcopy(elem)
-	else:
-		best=best
-	return best
-def Type_one_rule (c,  e,  preference,  matrix):
-	elem={'criterion':c,'condition':e, 'sign':preference[c-1],'class':'', \
-	'objectsCovered':[r[0] for r in matrix if (((r[c] >= e ) and (preference[c-1] == 'gain')) \
-																			  or ((r[c] <= e ) and (preference[c-1] == 'cost' )))],'label':''}
-	return elem
-def Type_three_rule (c,  e,  preference,  matrix):
-	'objectsCovered':[r[0] for r in matrix if (((r[c] <= e ) and (preference[c-1] == 'gain')) \
-														or ((r[c] >= e ) and (preference[c-1] == 'cost' )))],'label':''}
-	return elem
-def Find_rules (B, infosystem, type_rule):
-	"Search rule from a family of lower approximation of upward unions \
-	of decision classes"
-	start=time()
-	matrix=copy.deepcopy(infosystem['examples'])
-	criteria_num=len(infosystem['attributes'])
-	criteria=[r[1:-1] for r in matrix]
-	preference=[s['preference'] for s in infosystem['attributes'] ] #extract preference label
-	num_rules=0 #total rules number for each lower approximation
-	G=copy.deepcopy(B)		#a set of objects from the given approximation
-	E=[]		#a set  of rules covering set B (is a list of dictionary)
-	all_obj_cov_by_rules=[] #all objects covered by all rules in E
-	selected=copy.deepcopy(matrix) #storage reduct matrix by single elementary condition
-	while (len(G)!=0 ):
-		rules=[]	 #starting comples (single rule built from elementary conditions  )
-		S=copy.deepcopy(G)		 #set of objects currently covered by rule
-		control=0
-		while (len(rules)==0 or set(obj_cov_by_rules).issubset(B)==False):
-			obj_cov_by_rules=[] #set covered by rules
-			best={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''} #best candidate for elementary condition - start as empty
-			for c in range(1, criteria_num):
-				Cond=[r[c] for r in selected if  r[0] in S] #for each positive object from S create an elementary condition
-				for e in Cond:
-					if type_rule=='one':
-						elem= Type_one_rule (c,  e,  preference,  matrix)
-					elif type_rule=='three':
-						elem= Type_three_rule (c,  e,  preference,  matrix)
-					else:
-						elem={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''}
-					best=FindBestCondition(best, elem, rules, selected, G, infosystem)
-			if best not in rules:
-				rules.append(best)   #add the best condition to the complex
-			for r in rules:
-				obj_cov_by_rules.append(r['objectsCovered'])
-			obj_cov_by_rules=list((reduce(set.intersection,map(set,obj_cov_by_rules)))) #reduce():Apply function of two arguments cumulatively to the items of iterable, from left to right, so as to reduce the iterable to a single value.
-			S=list(set(S) & set(best['objectsCovered'] ))
-			control+=1
-#		rules=CheckMinimalCondition (rules,B,matrix)
-		if rules not in E:
-			E.append(rules) #add the induced rule
-			num_rules+=1
-		all_obj_cov_by_rules=list(set(all_obj_cov_by_rules) | set(obj_cov_by_rules))
-		G=list(set(B)-set(all_obj_cov_by_rules)) #remove example coverred by all finded rule -- this operation is a set difference
-		selected=[o  for o in selected if  not  o[0]  in all_obj_cov_by_rules] #reduct matrix, remove object coverred by all finded rule
-		num_rules+=1
-	return E
-def Domlem(Lu,Ld, infosystem):
-	"DOMLEM algoritm \
-	(An algorithm for induction of decision rules consistent with the dominance\
-	principle - Greco S., Matarazzo, B., Slowinski R., Stefanowski J.)"
-	attributes=infosystem['attributes']
-	RULES=[]
-##  *** AT MOST {<= Class} - Type 3 rules ***"
-	for b in Ld[:-1]:
-		B=b['objects']
-		E=Find_rules(B, infosystem, 'three')
-		for e in E:
-			for i in e:
-				i['class']=b['class']
-				i['label']=attributes[i['criterion']-1]['name']
-				i['type']='at_most'
-				if (attributes[i['criterion']-1]['preference']=='gain'):
-					i['sign']='<='
-				else:
-					i['sign']='>='
-			RULES.append(e)
-## *** AT LEAST {>= Class} - Type 1 rules *** "
-	for a in Lu[1:]:
-		B=a['objects']
-		E=Find_rules (B, infosystem, 'one')
-		for e in E:
-			for i in e:
-				i['class']=a['class']
-				i['type']='at_least'
-					i['sign']='>='
-				else:
-					i['sign']='<='
-			RULES.append(e)
-	return RULES
-def Print_rules(RULES, outputTxt):
-	"Print rls output file"
-	i=1
-	outfile=open(outputTxt+".rls","w")
-	outfile.write('[RULES]\n')
-	for R in RULES:
-		outfile.write("%d: " % i, )
-		for e in R:
-				outfile.write("( %s %s %.3f )" % (e['label'], e['sign'],e['condition'] ))
-		outfile.write("=> ( class %s , %s )\n" % ( e['type'], e['class'] ))
-		i+=1
-	outfile.close()
-	return 0
-def Parser_mapcalc(RULES, outputMap):
-	"Parser to build a formula to be included  in mapcalc command"
-	i=1
-	category=[]
-	maps=[]
-	stringa=[]
-	for R in RULES:
-		formula="if("
-		for e in R[:-1]: #build a mapcalc formula
-			formula+= "(%s %s %.4f ) && " % (e['label'],  e['sign'] ,  e['condition'] )
-		formula+= "(%s %s %.4f ),%d,null())" % (R[-1]['label'],R[-1]['sign'], R[-1]['condition'] ,i )
-		mappa="r%d_%s_%d" % ( i, R[0]['type'], R[0]['class'] ) #build map name for mapcalc output
-		category.append({'id':i, 'type': R[0]['type'], 'class':R[0]['class']}) #extract category name
-		maps.append(mappa) #extract maps name
-		grass.mapcalc(mappa +"=" +formula)
-		i+=1
-	mapstring=",".join(maps)
-	#make one layer for each label rule
-	labels=["_".join(m.split('_')[1:]) for m in maps]
-	labels=list(set(labels))
-	for l in labels:
-		print "mapping %s rule" % str(l)
-		map_synth=[]
-		for m in maps:
-			if l == "_".join(m.split('_')[1:]):
-				map_synth.append(m)
-		if len(map_synth)>1:
-			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
-		else:
-			grass.run_command("g.copy",rast=(str(map_synth),l))
-		print "__",str(map_synth),l
-		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
-		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
-		grass.run_command("v.db.update", map=l, column='rule', value=l)
-		grass.run_command("v.db.update", map=l, column='label', value=l)
-	mapslabels=",".join(labels)
-	if len(maps)>1:
-		grass.run_command("v.patch", overwrite='True', flags='e', input=mapslabels, output=outputMap)
-	else:
-		grass.run_command("g.copy",vect=(mapslabels,outputMap))
-	if not flags['l']:
-		grass.run_command("g.remove",  rast=mapstring)
-		grass.run_command("g.remove",  vect=mapstring)
-	return 0
-def main():
-	"main function for DOMLEM algorithm"
-	#try:
-	start=time()
-	attributes = options['criteria'].split(',')
-	preferences=options['preferences'].split(',')
-	decision=options['decision']
-	outputMap= options['outputMap']
-	outputTxt= options['outputTxt']
-	out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
-	infosystem=FileToInfoSystem(out)
-	UnionOfClasses(infosystem)
-	DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
-	UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
-	Dominating=DominatingSet(infosystem)
-	Dominated=DominatedSet(infosystem)
-##	upward union class
-	print "elaborate upward union"
-	Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
-	Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
-	UpwardBoundary=Boundaries(Uu, Lu)
-##	downward union class
-	print "elaborate downward union"
-	Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of  downward union for type 3 rules
-	Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of  downward union
-	DownwardBoundary=Boundaries(Ud, Ld)
-	QualityOfQpproximation(DownwardBoundary,  infosystem)
-	print "RULES extraction (*)"
-	RULES=Domlem(Lu,Ld, infosystem)
-	Parser_mapcalc(RULES, outputMap)
-	Print_rules(RULES, outputTxt)
-	end=time()
-	print "Time computing-> %.4f s" % (end-start)
-	return 0
-	#except:
-		#print "ERROR! Rules does not generated!"
-		#sys.exit()
-if __name__ == "__main__":
-	options, flags = grass.parser()
-	sys.exit(main())
+#!/usr/bin/env python
+# MODULE:	   r.mcda.roughset
+# AUTHOR:	   Gianluca Massei - Antonio Boggia
+# PURPOSE:	  Generate a MCDA map from several criteria maps using Dominance Rough Set Approach - DRSA
+#					   (DOMLEM algorithm proposed by  (S. Greco, B. Matarazzo, R. Slowinski)
+# COPYRIGHT:  c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#					   Development Team. This program is free software under the
+#					   GNU General PublicLicense (>=v2). Read the file COPYING
+#					   that comes with GRASS for details.
+#%Module
+#% description: Generate a MCDA map from several criteria maps using Dominance Rough Set Approach.
+#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: criteria
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: preferences
+#% type: string
+#% key_desc: character
+#% description: gain,cost
+#% required: yes
+#%end
+#%option
+#% key: decision
+#% type: string
+#% key_desc: name
+#% description: Name of decision raster map
+#% required: yes
+#%end
+#%option
+#% key: outputMap
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: Output classified raster map
+#% required: yes
+#%end
+#%option
+#% key: outputTxt
+#% type: string
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% description: Name for output files (base for *.isf  and *.rls files)
+#% answer:infosys
+#% required: yes
+#%end
+#%flag
+#% key: l
+#% description: do not remove single rules in vector format
+#% answer:false
+#%end
+#%flag
+#% key: n
+#% description: compute null value as zero
+#% answer:true
+#%end
+import sys
+import copy
+import numpy as np
+from time import time, ctime
+import grass.script as grass
+import grass.script.array as garray
+def BuildFileISF(attributes, preferences, decision, outputMap, outputTxt):
+	outputTxt=outputTxt+".isf"
+	outf = file(outputTxt,"w")
+	outf.write("**ATTRIBUTES\n")
+	for i in range(len(attributes)):
+		outf.write("+ %s: (continuous)\n" % attributes[i])
+	outf.write("+ %s: [" % decision)
+	value=[]
+	value=grass.read_command("r.describe", flags = "1n", map = decision)
+	v=value.split()
+	for i in range(len(v)-1):
+		outf.write("%s, " % str(v[i]))
+	outf.write("%s]\n" % str(v[len(v)-1]))
+	outf.write("decision: %s\n" % decision)
+	outf.write("\n**PREFERENCES\n")
+		if(preferences[i]==""):
+			preferences[i]="none"
+		outf.write("%s: %s\n" % (attributes[i], preferences[i]))
+	outf.write("%s: gain\n" % decision)
+	if flags['n']:
+			print "%s - convert null to 0" % str(attributes[i])
+			grass.run_command("r.null", map=attributes[i], null=0)
+	outf.write("\n**EXAMPLES\n")
+	examples=[]
+	MATRIX=[]
+		grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
+						 rast="rast",
+						 decision=decision,
+						 attribute=attributes[i])
+		tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
+		example=tmp.split()
+		examples.append(example)
+	tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
+	MATRIX=map(list,zip(*examples))
+	MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
+	MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
+	for r in range(len(MATRIX)):
+		for c in range(len(MATRIX[0])):
+			outf.write("%s " % (MATRIX[r][c]))
+#			outf.write("%s " % round(float(MATRIX[r][c]), 2))
+		outf.write("\n")
+	outf.write("**END")
+	outf.close()
+	return outputTxt
+def collect_attributes (data):
+	"Collects the values of header files isf, puts them in an array of dictionaries"
+	header=[]
+	attribute=dict()
+	j=0
+	start=(data.index(['**ATTRIBUTES'])+1)
+	end=(data.index(['**PREFERENCES'])-1)
+	for r in range(start, end):
+		attribute={'name':data[r][1].strip('+:')}
+		header.append(attribute)
+	decision=data[end-1][1]
+	end=(data.index(['**EXAMPLES']))
+	start=(data.index(['**PREFERENCES'])+1)
+	for r in header:
+		r['preference']=data[start+j][1]
+		j=j+1
+	return header
+def collect_examples (data):
+	"Collect examples values and put them in a matrix (list of lists) "
+	matrix=[]
+	data=[r for r in data if not '?' in r] #filter objects with " ?"
+#	data=[data.remove(r) for r in data if data.count(r)>1]
+	start=(data.index(['**EXAMPLES'])+1)
+	end=data.index(['**END'])
+	for i in range(start, end):
+		data[i]=(map(float, data[i]))
+		matrix.append(data[i])
+	i=1
+	for r in matrix:
+		r.insert(0, str(i))
+		i=i+1
+##	matrix=[list(i) for i in set(tuple(j) for j in matrix)] #remove duplicate example
+	return matrix
+def FileToInfoSystem(isf):
+	"Read *.isf file and copy it's values in Infosystem dictionary"
+	data=[]
+	try:
+		infile=open(isf,"r")
+		rows=infile.readlines()
+		for line in rows:
+			line=(line.split())
+			if (len(line)>0 ):
+				data.append(line)
+		infile.close()
+		infosystem={'attributes':collect_attributes(data),'examples':collect_examples(data)}
+	except TypeError:
+		print "\n\n Computing error or input file %s is not readeable. Exiting gracefully" % isf
+		sys.exit(0)
+	return infosystem
+def UnionOfClasses (infosystem):
+	"Find upward and downward union for all classes and put it in a dictionary"
+	DecisionClass=[]
+	AllClasses=[]
+	matrix=infosystem['examples']
+	for r in matrix:
+		DecisionClass.append(int(r[-1]))
+	DecisionClass=list(set(DecisionClass))
+	for c in range(len(DecisionClass)):
+		tmplist=[r for r in matrix if int(r[-1])==DecisionClass[c]]
+		AllClasses.append(tmplist)
+	return AllClasses
+def DownwardUnionsOfClasses (infosystem):
+	"For each decision class, downward union corresponding to a decision class\
+	is composed of this class and all worse classes (<=)"
+	DownwardUnionClass=[]
+	DecisionClass=[]
+	for r in matrix:
+	for c in DecisionClass:
+		tmplist=[r for r in matrix if int(r[-1])<=c]
+		DownwardUnionClass.append(tmplist)
+		#label=[row[0] for row in tmplist]
+	return DownwardUnionClass
+def UpwardUnionsOfClasses (infosystem):
+	"For each decision class, upward union corresponding to a decision class \
+	is composed of this class and all better classes.(>=)"
+	UpwardUnionClass=[]
+	DecisionClass=[]
+	for r in matrix:
+		tmplist=[r for r in matrix if int(r[-1])>=c]
+		UpwardUnionClass.append(tmplist)
+	return UpwardUnionClass
+def is_better (r1,r2, preference):
+	"Check if r1 is better than r2"
+	return all((( x >=y and p=='gain') or (x<=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
+def is_worst (r1,r2, preference):
+	"Check if r1 is worst than r2"
+	return all((( x <=y and p=='gain') or (x>=y and p=='cost')) for x,y, p in zip(r1,r2, preference) )
+def DominatingSet (infosystem):
+	"Find P-dominating set"
+	preference=[s['preference'] for s in infosystem['attributes'] ]
+	Dominating=[]
+	for row in matrix:
+		examples=[r  for r in matrix if  is_better(r[1:-1], row[1:-1], preference) ]
+		Dominating.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
+##	for dom in Dominating:
+##		print  dom['dominance'] ,' dominating ', dom['object']
+	return Dominating
+def DominatedSet (infosystem):
+	"Find P-Dominated set"
+	Dominated=[]
+		examples=[r  for r in matrix if  is_worst(r[1:-1], row[1:-1], preference[:-1]) ]
+		Dominated.append({'object':row[0], 'dominance':[i[0] for i in examples], 'examples':examples})
+##	for dom in Dominated:
+##		print  dom['dominance'] ,' is dominated by ', dom['object']
+	return Dominated
+def LowerApproximation (UnionClasses,  Dom):
+	"Find Lower approximation and return a dictionaries list"
+	c=1
+	LowApprox=[]
+	single=dict()
+	for union in UnionClasses:
+		tmp=[]
+		UClass=set([row[0] for row in union] )
+		for d in Dom:
+			if (UClass.issuperset(set(d['dominance']))): #if Union class is a superse of dominating/dominated set, =>single Loer approx.
+				tmp.append(d['object'])
+		single={'class':c, 'objects':tmp} #dictionary for lower approximation  --
+		LowApprox.append(single) #insert all Lower approximation in a list
+		c+=1
+	return LowApprox
+def UpperApproximation (UnionClasses,  Dom):
+	"Find Upper approximation and return a dictionaries list"
+	c=1
+	UppApprox=[]
+	single=dict()
+		UnClass=[row[0] for row in union]  #single union class
+		s=[]
+		for d in Dom:
+		   if len(set(d['dominance']) & set(UnClass)) >0:
+			   s.append(d['object'])
+#			   print set(s)
+		single={'class':c,'objects':list(set(s))}
+		UppApprox.append(single)
+		c+=1
+	return UppApprox
+def Boundaries (UppApprox, LowApprox):
+	"Find Boundaries like doubtful regions"
+	Boundary=[]
+	single=dict()
+	for i in range(len(UppApprox)):
+		single={'class':i, 'objects':list (set(UppApprox[i]['objects'])-set(LowApprox[i]['objects']) )}
+		Boundary.append(single)
+	return Boundary
+def AccuracyOfApproximation(UppApprox, LowApprox):
+	"Define the accuracy of approximation of Upward and downward approximation class"
+	return len(LowApprox)/len(UppApprox)
+def QualityOfQpproximation(DownwardBoundary,  infosystem):
+	"Defines the quality of approximation of the partition Cl or, briefly, the quality of sorting"
+	UnionBoundary=set()
+	U=set([i[0] for i in infosystem['examples']])
+	for b in DownwardBoundary:
+		UnionBoundary=set(UnionBoundary) | set(b['objects'])
+	return float(len(U-UnionBoundary)) / float(len(U))
+def FindObjectCovered (rules, selected):
+	"Find objects covered by a single rule and return\
+	all related examples covered"
+	obj=[]
+	examples=[]
+	for rule in rules:
+		examples.append(rule['objectsCovered'])
+	if len(examples)>0:
+		examples = reduce(set.intersection,map(set,examples))  #functional approach: intersect all lists if example is not empty
+		examples = list(set(examples) & set([r[0] for r in selected]))
+	return examples #all examples covered from a single rule
+def Evaluate (elem,rules,G,selected,infosystem):
+	"Calcolate first and second evaluate index, according with original DOMLEM Algorithm"
+	tmpRules=copy.deepcopy(rules)
+	tmpElem=copy.deepcopy(elem)
+	tmpRules.append(tmpElem)
+	Object=[]
+	Object=FindObjectCovered(tmpRules,selected)
+	if(float(len(Object)))>0:
+			 firstEvaluate=float(len(set(G) & set(Object))) / float(len(Object))
+			 secondEvaluate=float(len(set(G) & set(Object)))
+	else:
+			 firstEvaluate=0
+			 secondEvaluate=0
+	return firstEvaluate,secondEvaluate
+def FindBestCondition (best, elem, rules, selected, G, infosystem):
+	"Choose the best condition"
+	firstElem,secondElem=Evaluate(elem,rules,G,selected,infosystem)
+	firstBest,secondBest=Evaluate(best,rules,G,selected,infosystem)
+	if (firstElem>firstBest) or (firstElem==firstBest and secondElem>=secondBest):
+		best=copy.deepcopy(elem)
+	else:
+		best=best
+	return best
+def Type_one_rule (c,  e,  preference,  matrix):
+	elem={'criterion':c,'condition':e, 'sign':preference[c-1],'class':'', \
+	'objectsCovered':[r[0] for r in matrix if (((r[c] >= e ) and (preference[c-1] == 'gain')) \
+																			  or ((r[c] <= e ) and (preference[c-1] == 'cost' )))],'label':''}
+	return elem
+def Type_three_rule (c,  e,  preference,  matrix):
+	'objectsCovered':[r[0] for r in matrix if (((r[c] <= e ) and (preference[c-1] == 'gain')) \
+														or ((r[c] >= e ) and (preference[c-1] == 'cost' )))],'label':''}
+	return elem
+def Find_rules (B, infosystem, type_rule):
+	"Search rule from a family of lower approximation of upward unions \
+	of decision classes"
+	start=time()
+	matrix=copy.deepcopy(infosystem['examples'])
+	criteria_num=len(infosystem['attributes'])
+	criteria=[r[1:-1] for r in matrix]
+	preference=[s['preference'] for s in infosystem['attributes'] ] #extract preference label
+	num_rules=0 #total rules number for each lower approximation
+	G=copy.deepcopy(B)		#a set of objects from the given approximation
+	E=[]		#a set  of rules covering set B (is a list of dictionary)
+	all_obj_cov_by_rules=[] #all objects covered by all rules in E
+	selected=copy.deepcopy(matrix) #storage reduct matrix by single elementary condition
+	while (len(G)!=0 ):
+		rules=[]	 #starting comples (single rule built from elementary conditions  )
+		S=copy.deepcopy(G)		 #set of objects currently covered by rule
+		control=0
+		while (len(rules)==0 or set(obj_cov_by_rules).issubset(B)==False):
+			obj_cov_by_rules=[] #set covered by rules
+			best={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''} #best candidate for elementary condition - start as empty
+			for c in range(1, criteria_num):
+				Cond=[r[c] for r in selected if  r[0] in S] #for each positive object from S create an elementary condition
+				for e in Cond:
+					if type_rule=='one':
+						elem= Type_one_rule (c,  e,  preference,  matrix)
+					elif type_rule=='three':
+						elem= Type_three_rule (c,  e,  preference,  matrix)
+					else:
+						elem={'criterion':'','condition':'','sign':'','class':'','objectsCovered':'','label':'', 'type':''}
+					best=FindBestCondition(best, elem, rules, selected, G, infosystem)
+			if best not in rules:
+				rules.append(best)   #add the best condition to the complex
+			for r in rules:
+				obj_cov_by_rules.append(r['objectsCovered'])
+			obj_cov_by_rules=list((reduce(set.intersection,map(set,obj_cov_by_rules)))) #reduce():Apply function of two arguments cumulatively to the items of iterable, from left to right, so as to reduce the iterable to a single value.
+			S=list(set(S) & set(best['objectsCovered'] ))
+			control+=1
+#		rules=CheckMinimalCondition (rules,B,matrix)
+		if rules not in E:
+			E.append(rules) #add the induced rule
+			num_rules+=1
+		all_obj_cov_by_rules=list(set(all_obj_cov_by_rules) | set(obj_cov_by_rules))
+		G=list(set(B)-set(all_obj_cov_by_rules)) #remove example coverred by all finded rule -- this operation is a set difference
+		selected=[o  for o in selected if  not  o[0]  in all_obj_cov_by_rules] #reduct matrix, remove object coverred by all finded rule
+		num_rules+=1
+	return E
+def Domlem(Lu,Ld, infosystem):
+	"DOMLEM algoritm \
+	(An algorithm for induction of decision rules consistent with the dominance\
+	principle - Greco S., Matarazzo, B., Slowinski R., Stefanowski J.)"
+	attributes=infosystem['attributes']
+	RULES=[]
+##  *** AT MOST {<= Class} - Type 3 rules ***"
+	for b in Ld[:-1]:
+		B=b['objects']
+		E=Find_rules(B, infosystem, 'three')
+		for e in E:
+			for i in e:
+				i['class']=b['class']
+				i['label']=attributes[i['criterion']-1]['name']
+				i['type']='at_most'
+				if (attributes[i['criterion']-1]['preference']=='gain'):
+					i['sign']='<='
+				else:
+					i['sign']='>='
+			RULES.append(e)
+## *** AT LEAST {>= Class} - Type 1 rules *** "
+	for a in Lu[1:]:
+		B=a['objects']
+		E=Find_rules (B, infosystem, 'one')
+		for e in E:
+			for i in e:
+				i['class']=a['class']
+				i['type']='at_least'
+					i['sign']='>='
+				else:
+					i['sign']='<='
+			RULES.append(e)
+	return RULES
+def Print_rules(RULES, outputTxt):
+	"Print rls output file"
+	i=1
+	outfile=open(outputTxt+".rls","w")
+	outfile.write('[RULES]\n')
+	for R in RULES:
+		outfile.write("%d: " % i, )
+		for e in R:
+				outfile.write("( %s %s %.3f )" % (e['label'], e['sign'],e['condition'] ))
+		outfile.write("=> ( class %s , %s )\n" % ( e['type'], e['class'] ))
+		i+=1
+	outfile.close()
+	return 0
+def Parser_mapcalc(RULES, outputMap):
+	"Parser to build a formula to be included  in mapcalc command"
+	i=1
+	category=[]
+	maps=[]
+	stringa=[]
+	for R in RULES:
+		formula="if("
+		for e in R[:-1]: #build a mapcalc formula
+			formula+= "(%s %s %.4f ) && " % (e['label'],  e['sign'] ,  e['condition'] )
+		formula+= "(%s %s %.4f ),%d,null())" % (R[-1]['label'],R[-1]['sign'], R[-1]['condition'] ,i )
+		mappa="r%d_%s_%d" % ( i, R[0]['type'], R[0]['class'] ) #build map name for mapcalc output
+		category.append({'id':i, 'type': R[0]['type'], 'class':R[0]['class']}) #extract category name
+		maps.append(mappa) #extract maps name
+		grass.mapcalc(mappa +"=" +formula)
+		i+=1
+	mapstring=",".join(maps)
+	#make one layer for each label rule
+	labels=["_".join(m.split('_')[1:]) for m in maps]
+	labels=list(set(labels))
+	for l in labels:
+		print "mapping %s rule" % str(l)
+		map_synth=[]
+		for m in maps:
+			if l == "_".join(m.split('_')[1:]):
+				map_synth.append(m)
+		if len(map_synth)>1:
+			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
+		else:
+			grass.run_command("g.copy",rast=(str(map_synth),l))
+		print "__",str(map_synth),l
+		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
+		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
+		grass.run_command("v.db.update", map=l, column='rule', value=l)
+		grass.run_command("v.db.update", map=l, column='label', value=l)
+	mapslabels=",".join(labels)
+	if len(maps)>1:
+		grass.run_command("v.patch", overwrite='True', flags='e', input=mapslabels, output=outputMap)
+	else:
+		grass.run_command("g.copy",vect=(mapslabels,outputMap))
+	if not flags['l']:
+		grass.run_command("g.remove",  rast=mapstring)
+		grass.run_command("g.remove",  vect=mapstring)
+	return 0
+def main():
+	"main function for DOMLEM algorithm"
+	#try:
+	start=time()
+	attributes = options['criteria'].split(',')
+	preferences=options['preferences'].split(',')
+	decision=options['decision']
+	outputMap= options['outputMap']
+	outputTxt= options['outputTxt']
+	out=BuildFileISF(attributes, preferences, decision, outputMap, outputTxt)
+	infosystem=FileToInfoSystem(out)
+	UnionOfClasses(infosystem)
+	DownwardUnionClass=DownwardUnionsOfClasses(infosystem)
+	UpwardUnionClass=UpwardUnionsOfClasses(infosystem)
+	Dominating=DominatingSet(infosystem)
+	Dominated=DominatedSet(infosystem)
+##	upward union class
+	print "elaborate upward union"
+	Lu=LowerApproximation(UpwardUnionClass, Dominating) #lower approximation of upward union for type 1 rules
+	Uu=UpperApproximation(UpwardUnionClass,Dominated ) #upper approximation of upward union
+	UpwardBoundary=Boundaries(Uu, Lu)
+##	downward union class
+	print "elaborate downward union"
+	Ld=LowerApproximation(DownwardUnionClass, Dominated) # lower approximation of  downward union for type 3 rules
+	Ud=UpperApproximation(DownwardUnionClass,Dominating ) # upper approximation of  downward union
+	DownwardBoundary=Boundaries(Ud, Ld)
+	QualityOfQpproximation(DownwardBoundary,  infosystem)
+	print "RULES extraction (*)"
+	RULES=Domlem(Lu,Ld, infosystem)
+	Parser_mapcalc(RULES, outputMap)
+	Print_rules(RULES, outputTxt)
+	end=time()
+	print "Time computing-> %.4f s" % (end-start)
+	return 0
+	#except:
+		#print "ERROR! Rules does not generated!"
+		#sys.exit()
+if __name__ == "__main__":
+	options, flags = grass.parser()
+	sys.exit(main())
