[GRASS-SVN] r54162 - grass-addons/grass6/raster/r.in.drsa
Mon Dec 3 07:30:52 PST 2012
Author: gianluca
Date: 2012-12-03 07:30:51 -0800 (Mon, 03 Dec 2012)
New Revision: 54162
   grass-addons/grass6/raster/r.in.drsa/r.in.drsa.py
remove bud format
Modified: grass-addons/grass6/raster/r.in.drsa/r.in.drsa.py
--- grass-addons/grass6/raster/r.in.drsa/r.in.drsa.py	2012-12-03 15:23:41 UTC (rev 54161)
+++ grass-addons/grass6/raster/r.in.drsa/r.in.drsa.py	2012-12-03 15:30:51 UTC (rev 54162)
@@ -1,179 +1,179 @@
-#!/usr/bin/env python
-# MODULE:	   r.in.drsa
-# AUTHOR:	   Gianluca Massei - Antonio Boggia
-# PURPOSE:	  Import roles from *.rls file and apply those condition
-#			   at geographics information system for generate a raster
-#			   map classified under Dominance Rough Set Approach
-# COPYRIGHT:	c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#			   Development Team. This program is free software under the
-#			   GNU General PublicLicense (>=v2). Read the file COPYING
-#			   that comes with GRASS for details.
-#%Module
-#% description: Generate a raster map classified with Dominance Rough Set Approach. Use *.rls file from JAMM, 4eMka2 etc.
-#% keywords: raster, Dominance Rough Set Approach
-#% keywords: Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,file,input
-#% description: File name with rules (*.rls)
-#% required: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: output classified raster map
-#% required: yes
-#%end
-#%flag
-#% key:k
-#% description:file *.rls from software 4eMka2
-#% answer:true
-#%end
-#%flag
-#% key:j
-#% description:file *.rls from software jMAF (NOT YET IMPLEMENTED)
-#%end
-#%flag
-#% key: l
-#% description: do not remove single rules in vector format
-#% answer:false
-#%end
-import sys
-import grass.script as grass
-import pdb
-import string
-def parser_4eMka2_rule(tags):
-	"parser file *.rls from 4eMka2 software and extract information for make new classified raster"
-	rule=dict()
-	rules=[]
-	for t in tags:
-		condition=[]
-		decision=[]
-		row=t.split()
-		if(len(row)>0 and row[0]=="Rule"):
-			#rules_list.append(row)
-			i=row.index("=>")
-			for j in range(2,i):
-				 if( row[j]!="&"):
-					 condition.append(row[j].strip('[,;]'))
-			for j in range(i+1,len(row)-2):
-					 decision.append(row[j].strip('([,;])'))
-			rule={'id_rule':row[1].strip('[.;]'),
-				  'condition':condition,
-				  'decision':(decision[0]),
-				  'class':"_".join(decision[1:]),
-				  'support':int(row[-2].strip('[.,;]')),
-				  'strength':row[-1].strip('[,:]')}
-			rules.append(rule)
-	rls = open('rules',"w")
-	for l in rules:
-		factor=l['decision'].strip('()').split(' ')
-		rls.write('id_rule:%s - condition:%s - decision: %s - class:%s \n' % (l['id_rule'],l['condition'], l['decision'],l['class']))
-	rls.close
-	return rules
-def parser_JAMM_rule(tags):
-	"parser file *.rls from JAMM software and extract information for make new classified raster"
-def parser_mapcalc(rules,i):
-	"parser to build a formula to be included  in mapcalc command"
-	mapalgebra="if("
-	for j in rules[i]['condition'][:-1]:
-		mapalgebra+= j + " && "
-	mapalgebra+=rules[i]['condition'][-1]+","+rules[i]['id_rule']+",null())"
-	return mapalgebra
-def clean_rules(rules):
-	"cleans rules to no processed vaue from rules (eg = -> ==) "
-	for i in range(len(rules)):
-		for j in rules[i]['condition']:
-			if (j.find("<=")!=-1):
-				return 1
-			elif (j.find("<=")!=-1):
-				return 1
-			elif (j.find("=")!=-1):
-				j=j.replace("=","==")
-				return 0
-			else:
-				return -1
-def patch_georules(maps,outputMap):
-	labels=["_".join(m.split('_')[1:]) for m in maps]
-	labels=list(set(labels))
-	for l in labels:
-		print "mapping %s rule" % str(l)
-		map_synth=[]
-		for m in maps:
-			if l == "_".join(m.split('_')[1:]):
-				map_synth.append(m)
-		if len(map_synth)>1:
-			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
-		else:
-			grass.run_command("g.copy",rast=(str(map_synth),l))
-		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
-		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
-		grass.run_command("v.db.update", map=l, column='rule', value=l)
-		grass.run_command("v.db.update", map=l, column='label', value=l)
-	mapstring=",".join(labels)
-	if len(maps)>1:
-		grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
-	else:
-		grass.run_command("g.copy",vect=(mapstring,outputMap))
-def main():
-	input_rules = options['input']
-	outputMap = options['output']
-	gregion = grass.region()
-	nrows = gregion['rows']
-	ncols = gregion['cols']
-	ewres=int(gregion['ewres'])
-	nsres=int(gregion['nsres'])
-	input_rules=open(input_rules,"r")
-	tags=input_rules.readlines()
-	rules=[]  #single rule (dictionary) in array
-	maps=[]
-	rules=parser_4eMka2_rule(tags)
-##	clean_rules(rules)
-		mappa="r"+rules[i]['id_rule']+"_"+rules[i]['class']
-		formula=parser_mapcalc(rules,i)
-		grass.mapcalc(mappa +"=" +formula)
-		maps.append(mappa)
-	maplist=",".join(maps)
-	print maplist
-	patch_georules(maps,outputMap)
-	if not flags['l']:
-		grass.run_command("g.remove",flags="quiet", rast=maplist)
-		grass.run_command("g.remove",flags="quiet", vect=maplist)
-	input_rules.close()
-	return 0
-if __name__ == "__main__":
-	options, flags = grass.parser()
-	sys.exit(main())
+#!/usr/bin/env python
+# MODULE:	   r.in.drsa
+# AUTHOR:	   Gianluca Massei - Antonio Boggia
+# PURPOSE:	  Import roles from *.rls file and apply those condition
+#			   at geographics information system for generate a raster
+#			   map classified under Dominance Rough Set Approach
+# COPYRIGHT:	c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#			   Development Team. This program is free software under the
+#			   GNU General PublicLicense (>=v2). Read the file COPYING
+#			   that comes with GRASS for details.
+#%Module
+#% description: Generate a raster map classified with Dominance Rough Set Approach. Use *.rls file from JAMM, 4eMka2 etc.
+#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,file,input
+#% description: File name with rules (*.rls)
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: output classified raster map
+#% required: yes
+#%end
+#%flag
+#% key:k
+#% description:file *.rls from software 4eMka2
+#% answer:true
+#%end
+#%flag
+#% key:j
+#% description:file *.rls from software jMAF (NOT YET IMPLEMENTED)
+#%end
+#%flag
+#% key: l
+#% description: do not remove single rules in vector format
+#% answer:false
+#%end
+import sys
+import grass.script as grass
+import pdb
+import string
+def parser_4eMka2_rule(tags):
+	"parser file *.rls from 4eMka2 software and extract information for make new classified raster"
+	rule=dict()
+	rules=[]
+	for t in tags:
+		condition=[]
+		decision=[]
+		row=t.split()
+		if(len(row)>0 and row[0]=="Rule"):
+			#rules_list.append(row)
+			i=row.index("=>")
+			for j in range(2,i):
+				 if( row[j]!="&"):
+					 condition.append(row[j].strip('[,;]'))
+			for j in range(i+1,len(row)-2):
+					 decision.append(row[j].strip('([,;])'))
+			rule={'id_rule':row[1].strip('[.;]'),
+				  'condition':condition,
+				  'decision':(decision[0]),
+				  'class':"_".join(decision[1:]),
+				  'support':int(row[-2].strip('[.,;]')),
+				  'strength':row[-1].strip('[,:]')}
+			rules.append(rule)
+	rls = open('rules',"w")
+	for l in rules:
+		factor=l['decision'].strip('()').split(' ')
+		rls.write('id_rule:%s - condition:%s - decision: %s - class:%s \n' % (l['id_rule'],l['condition'], l['decision'],l['class']))
+	rls.close
+	return rules
+def parser_JAMM_rule(tags):
+	"parser file *.rls from JAMM software and extract information for make new classified raster"
+def parser_mapcalc(rules,i):
+	"parser to build a formula to be included  in mapcalc command"
+	mapalgebra="if("
+	for j in rules[i]['condition'][:-1]:
+		mapalgebra+= j + " && "
+	mapalgebra+=rules[i]['condition'][-1]+","+rules[i]['id_rule']+",null())"
+	return mapalgebra
+def clean_rules(rules):
+	"cleans rules to no processed vaue from rules (eg = -> ==) "
+	for i in range(len(rules)):
+		for j in rules[i]['condition']:
+			if (j.find("<=")!=-1):
+				return 1
+			elif (j.find("<=")!=-1):
+				return 1
+			elif (j.find("=")!=-1):
+				j=j.replace("=","==")
+				return 0
+			else:
+				return -1
+def patch_georules(maps,outputMap):
+	labels=["_".join(m.split('_')[1:]) for m in maps]
+	labels=list(set(labels))
+	for l in labels:
+		print "mapping %s rule" % str(l)
+		map_synth=[]
+		for m in maps:
+			if l == "_".join(m.split('_')[1:]):
+				map_synth.append(m)
+		if len(map_synth)>1:
+			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
+		else:
+			grass.run_command("g.copy",rast=(str(map_synth),l))
+		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
+		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
+		grass.run_command("v.db.update", map=l, column='rule', value=l)
+		grass.run_command("v.db.update", map=l, column='label', value=l)
+	mapstring=",".join(labels)
+	if len(maps)>1:
+		grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
+	else:
+		grass.run_command("g.copy",vect=(mapstring,outputMap))
+def main():
+	input_rules = options['input']
+	outputMap = options['output']
+	gregion = grass.region()
+	nrows = gregion['rows']
+	ncols = gregion['cols']
+	ewres=int(gregion['ewres'])
+	nsres=int(gregion['nsres'])
+	input_rules=open(input_rules,"r")
+	tags=input_rules.readlines()
+	rules=[]  #single rule (dictionary) in array
+	maps=[]
+	rules=parser_4eMka2_rule(tags)
+##	clean_rules(rules)
+		mappa="r"+rules[i]['id_rule']+"_"+rules[i]['class']
+		formula=parser_mapcalc(rules,i)
+		grass.mapcalc(mappa +"=" +formula)
+		maps.append(mappa)
+	maplist=",".join(maps)
+	print maplist
+	patch_georules(maps,outputMap)
+	if not flags['l']:
+		grass.run_command("g.remove",flags="quiet", rast=maplist)
+		grass.run_command("g.remove",flags="quiet", vect=maplist)
+	input_rules.close()
+	return 0
+if __name__ == "__main__":
+	options, flags = grass.parser()
+	sys.exit(main())
