[GRASS-SVN] r54164 - grass-addons/grass6/raster/r.to.drsa
    svn_grass at osgeo.org
    Mon Dec  3 07:34:03 PST 2012
Author: gianluca
Date: 2012-12-03 07:34:03 -0800 (Mon, 03 Dec 2012)
New Revision: 54164
   grass-addons/grass6/raster/r.to.drsa/r.to.drsa.py
remove bud format
Modified: grass-addons/grass6/raster/r.to.drsa/r.to.drsa.py
--- grass-addons/grass6/raster/r.to.drsa/r.to.drsa.py	2012-12-03 15:32:09 UTC (rev 54163)
+++ grass-addons/grass6/raster/r.to.drsa/r.to.drsa.py	2012-12-03 15:34:03 UTC (rev 54164)
@@ -1,127 +1,127 @@
-#!/usr/bin/env python
-# MODULE:       r.to.drsa
-# AUTHOR:       Gianluca Massei - Antonio Boggia
-# PURPOSE:      Export criteria raster maps and decision raster map in a *.isf
-#               file for dominance rough set approach analysis (DRSA)
-#               Dominance Rough Set Analysis (e.g. 4eMka2,JAMM, jMAF).
-# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#               Development Team. This program is free software under the
-#               GNU General PublicLicense (>=v2). Read the file COPYING
-#               that comes with GRASS for details.
-#%Module
-#% description: Export criteria raster maps and decision raster map in a *.isf file (e.g. 4eMka2, jMAF) for dominance rough set approach analysis
-#% keywords: raster, Dominance Rough Set Approach
-#% keywords: Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: attributes
-#% type: string
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: preferences
-#% type: string
-#% key_desc: character
-#% description: gain,cost,none
-#% required: yes
-#%end
-#%option
-#% key: decision
-#% type: string
-#% key_desc: name
-#% description: Name of decision raster map
-#% required: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% description: Name for output file (*.isf file, Information System)
-#% answer:infosys.isf
-#% required: yes
-#%end
-import sys
-##from grass.script import core as grass
-import grass.script as grass
-def main():
-    attributes = options['attributes'].split(',')
-    preferences=options['preferences'].split(',')
-    decision=options['decision']
-    output = options['output']
-    gregion = grass.region()
-    nrows = gregion['rows']
-    ncols = gregion['cols']
-    ewres=int(gregion['ewres'])
-    nsres=int(gregion['nsres'])
-    print nrows, ncols, ewres,nsres
-    outf = file(output,"w")
-    outf.write("**ATTRIBUTES\n")
-    for i in range(len(attributes)):
-        outf.write("+ %s: (continuous)\n" % attributes[i])
-    outf.write("+ %s: [" % decision)
-    value=[]
-    value=grass.read_command("r.describe", flags = "1n", map = decision)
-    v=value.split()
-    for i in range(len(v)-1):
-        outf.write("%s, " % str(v[i]))
-    outf.write("%s]\n" % str(v[len(v)-1]))
-    outf.write("decision: %s\n" % decision)
-    outf.write("\n**PREFERENCES\n")
-        if(preferences[i]==""):
-            preferences[i]="none"
-        outf.write("%s: %s\n" % (attributes[i], preferences[i]))
-    outf.write("%s: gain\n" % decision)
-    outf.write("\n**EXAMPLES\n")
-    examples=[]
-    MATRIX=[]
-        grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
-                         rast="rast",
-                         decision=decision,
-                         attribute=attributes[i])
-        tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
-        example=tmp.split()
-        examples.append(example)
-    tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
-    MATRIX=map(list,zip(*examples))
-    MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
-    MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
-    print "rows:%d - col:%d" %(len(MATRIX),len(MATRIX[0]))
-    for r in range(len(MATRIX)):
-        for c in range(len(MATRIX[0])):
-            outf.write("%s " %  str(MATRIX[r][c]))
-        outf.write("\n")
-    outf.write("**END")
-    outf.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
+#!/usr/bin/env python
+# MODULE:       r.to.drsa
+# AUTHOR:       Gianluca Massei - Antonio Boggia
+# PURPOSE:      Export criteria raster maps and decision raster map in a *.isf
+#               file for dominance rough set approach analysis (DRSA)
+#               Dominance Rough Set Analysis (e.g. 4eMka2,JAMM, jMAF).
+# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#               Development Team. This program is free software under the
+#               GNU General PublicLicense (>=v2). Read the file COPYING
+#               that comes with GRASS for details.
+#%Module
+#% description: Export criteria raster maps and decision raster map in a *.isf file (e.g. 4eMka2, jMAF) for dominance rough set approach analysis
+#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: attributes
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: preferences
+#% type: string
+#% key_desc: character
+#% description: gain,cost,none
+#% required: yes
+#%end
+#%option
+#% key: decision
+#% type: string
+#% key_desc: name
+#% description: Name of decision raster map
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% description: Name for output file (*.isf file, Information System)
+#% answer:infosys.isf
+#% required: yes
+#%end
+import sys
+##from grass.script import core as grass
+import grass.script as grass
+def main():
+    attributes = options['attributes'].split(',')
+    preferences=options['preferences'].split(',')
+    decision=options['decision']
+    output = options['output']
+    gregion = grass.region()
+    nrows = gregion['rows']
+    ncols = gregion['cols']
+    ewres=int(gregion['ewres'])
+    nsres=int(gregion['nsres'])
+    print nrows, ncols, ewres,nsres
+    outf = file(output,"w")
+    outf.write("**ATTRIBUTES\n")
+    for i in range(len(attributes)):
+        outf.write("+ %s: (continuous)\n" % attributes[i])
+    outf.write("+ %s: [" % decision)
+    value=[]
+    value=grass.read_command("r.describe", flags = "1n", map = decision)
+    v=value.split()
+    for i in range(len(v)-1):
+        outf.write("%s, " % str(v[i]))
+    outf.write("%s]\n" % str(v[len(v)-1]))
+    outf.write("decision: %s\n" % decision)
+    outf.write("\n**PREFERENCES\n")
+        if(preferences[i]==""):
+            preferences[i]="none"
+        outf.write("%s: %s\n" % (attributes[i], preferences[i]))
+    outf.write("%s: gain\n" % decision)
+    outf.write("\n**EXAMPLES\n")
+    examples=[]
+    MATRIX=[]
+        grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
+                         rast="rast",
+                         decision=decision,
+                         attribute=attributes[i])
+        tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
+        example=tmp.split()
+        examples.append(example)
+    tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
+    MATRIX=map(list,zip(*examples))
+    MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
+    MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
+    print "rows:%d - col:%d" %(len(MATRIX),len(MATRIX[0]))
+    for r in range(len(MATRIX)):
+        for c in range(len(MATRIX[0])):
+            outf.write("%s " %  str(MATRIX[r][c]))
+        outf.write("\n")
+    outf.write("**END")
+    outf.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
