[GRASS-SVN] r54189 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Tue Dec 4 11:43:51 PST 2012
Author: mmetz
Date: 2012-12-04 11:43:50 -0800 (Tue, 04 Dec 2012)
New Revision: 54189
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.in.ogr/v.in.ogr.html
v.in.ogr: write 3D output if input is 3D
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2012-12-04 18:35:24 UTC (rev 54188)
+++ grass/trunk/vector/v.in.ogr/main.c 2012-12-04 19:43:50 UTC (rev 54189)
@@ -54,14 +54,14 @@
struct Option *snap, *type, *outloc, *cnames;
} param;
struct _flag {
- struct Flag *list, *no_clean, *z, *notab,
+ struct Flag *list, *no_clean, *force2d, *notab,
*region;
struct Flag *over, *extend, *formats, *tolower, *no_import;
} flag;
char *desc;
- int i, j, layer, arg_s_num, nogeom, ncnames;
+ int i, j, layer, nogeom, ncnames;
double xmin, ymin, xmax, ymax;
int ncols = 0, type;
double min_area, snap;
@@ -78,10 +78,10 @@
int cat;
/* Attributes */
- struct field_info *Fi;
- dbDriver *driver;
+ struct field_info *Fi = NULL;
+ dbDriver *driver = NULL;
dbString sql, strval;
- int dim, with_z;
+ int with_z, input3d;
/* OGR */
OGRDataSourceH Ogr_ds;
@@ -233,10 +233,11 @@
flag.no_clean->description = _("Do not clean polygons (not recommended)");
flag.no_clean->guisection = _("Output");
- flag.z = G_define_flag();
- flag.z->key = 'z';
- flag.z->description = _("Create 3D output");
- flag.z->guisection = _("Output");
+ flag.force2d = G_define_flag();
+ flag.force2d->key = '2';
+ flag.force2d->label = _("Force 2D output even if input is 3D");
+ flag.force2d->description = _("Useful if input is 3D but all z coordinates are identical");
+ flag.force2d->guisection = _("Output");
flag.notab = G_define_standard_flag(G_FLG_V_TABLE);
flag.notab->guisection = _("Attributes");
@@ -702,56 +703,65 @@
db_init_string(&sql);
db_init_string(&strval);
- /* open output vector */
- /* strip any @mapset from vector output name */
- G_find_vector(output, G_mapset());
- Vect_open_new(&Map, output, flag.z->answer != 0);
- Out = ⤅
n_polygon_boundaries = 0;
- if (!flag.no_clean->answer) {
- /* check if we need a tmp vector */
+ input3d = 0;
- /* estimate distance for boundary splitting --> */
- for (layer = 0; layer < nlayers; layer++) {
- layer_id = layers[layer];
+ /* check if input id 3D and if we need a tmp vector */
+ /* estimate distance for boundary splitting --> */
+ for (layer = 0; layer < nlayers; layer++) {
+ layer_id = layers[layer];
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
- Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
+ Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- n_features = feature_count = 0;
+ n_features = feature_count = 0;
- n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
- OGR_L_ResetReading(Ogr_layer);
+ n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
+ OGR_L_ResetReading(Ogr_layer);
- /* count polygons and isles */
- G_message(_("Counting polygons for %d features (OGR layer <%s>)..."),
- n_features, layer_names[layer]);
- while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
- G_percent(feature_count++, n_features, 1); /* show something happens */
- /* Geometry */
- Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
- if (Ogr_geometry != NULL) {
+ /* count polygons and isles */
+ G_message(_("Counting polygons for %d features (OGR layer <%s>)..."),
+ n_features, layer_names[layer]);
+ while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
+ G_percent(feature_count++, n_features, 1); /* show something happens */
+ /* Geometry */
+ Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
+ if (Ogr_geometry != NULL) {
+ if (!flag.no_clean->answer)
poly_count(Ogr_geometry, (type & GV_BOUNDARY));
- OGR_F_Destroy(Ogr_feature);
+ if (OGR_G_GetCoordinateDimension(Ogr_geometry) > 2)
+ input3d = 1;
+ OGR_F_Destroy(Ogr_feature);
- G_debug(1, "n polygon boundaries: %d", n_polygon_boundaries);
- if (n_polygon_boundaries > 50) {
- split_distance =
- area_size / log(n_polygon_boundaries);
- /* divisor is the handle: increase divisor to decrease split_distance */
- split_distance = split_distance / 16.;
- G_debug(1, "root of area size: %f", area_size);
- G_verbose_message(_("Boundary splitting distance in map units: %G"),
- split_distance);
- /* <-- estimate distance for boundary splitting */
+ G_debug(1, "n polygon boundaries: %d", n_polygon_boundaries);
+ if (n_polygon_boundaries > 50) {
+ split_distance =
+ area_size / log(n_polygon_boundaries);
+ /* divisor is the handle: increase divisor to decrease split_distance */
+ split_distance = split_distance / 16.;
+ G_debug(1, "root of area size: %f", area_size);
+ G_verbose_message(_("Boundary splitting distance in map units: %G"),
+ split_distance);
+ /* <-- estimate distance for boundary splitting */
- use_tmp_vect = n_polygon_boundaries > 0;
+ use_tmp_vect = n_polygon_boundaries > 0;
+ G_debug(0, "3D ? %d", input3d);
+ with_z = input3d;
+ if (with_z)
+ with_z = !flag.force2d->answer;
+ /* open output vector */
+ /* strip any @mapset from vector output name */
+ G_find_vector(output, G_mapset());
+ Vect_open_new(&Map, output, with_z);
+ Out = ⤅
+ if (!flag.no_clean->answer) {
if (use_tmp_vect) {
/* open temporary vector, do the work in the temporary vector
* at the end copy alive lines to output vector
@@ -759,7 +769,7 @@
* only needed when cleaning polygons */
sprintf(tempvect, "%s_tmp", output);
G_verbose_message(_("Using temporary vector <%s>"), tempvect);
- Vect_open_new(&Tmp, tempvect, flag.z->answer != 0);
+ Vect_open_new(&Tmp, tempvect, with_z);
Out = &Tmp;
@@ -771,7 +781,6 @@
* Then second pass through finds all centroids in each polygon feature and adds its category
* to the centroid. The result is that one centroids may have 0, 1 ore more categories
* of one ore more (more input layers) fields. */
- with_z = 0;
@@ -956,10 +965,6 @@
nogeom++;
else {
- dim = OGR_G_GetCoordinateDimension(Ogr_geometry);
- if (dim > 2)
- with_z = 1;
geom(Ogr_geometry, Out, layer + 1, cat, min_area, type,
flag.no_clean->answer);
@@ -1070,7 +1075,7 @@
G_message("%s", separator);
- G_warning(_("Cleaning polygons, result is not guaranteed!"));
+ G_message(_("Cleaning polygons"));
if (snap >= 0) {
@@ -1150,6 +1155,7 @@
/* Boundaries are hopefully clean, build areas */
+ Vect_build_partial(&Tmp, GV_BUILD_NONE);
Vect_build_partial(&Tmp, GV_BUILD_ATTACH_ISLES);
/* Calculate new centroids for all areas, centroids have the same id as area */
@@ -1266,14 +1272,18 @@
sprintf(buf, _("Overlapping area: %G (%d areas)\n"), overlap_area,
n_overlaps);
- G_message(_("Overlapping area: %G (%d areas)"), overlap_area,
- n_overlaps);
+ if (n_overlaps) {
+ G_message(_("Overlapping area: %G (%d areas)"), overlap_area,
+ n_overlaps);
Vect_hist_write(&Map, buf);
sprintf(buf, _("Area without category: %G (%d areas)\n"), nocat_area,
n_nocat);
- G_message(_("Area without category: %G (%d areas)"), nocat_area,
- n_nocat);
+ if (n_nocat) {
+ G_message(_("Area without category: %G (%d areas)"), nocat_area,
+ n_nocat);
@@ -1290,7 +1300,7 @@
Vect_build(&Map);
- if (flag.no_clean->answer)
+ if (0 && flag.no_clean->answer)
Vect_topo_check(&Map, NULL);
Vect_close(&Map);
@@ -1326,9 +1336,9 @@
G_message(_("Region for the current mapset updated"));
- if (with_z && !flag.z->answer)
+ if (input3d && flag.force2d->answer)
G_warning(_("Input data contains 3D features. Created vector is 2D only, "
- "use -z flag to import 3D vector."));
+ "disable -2 flag to import 3D vector."));
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.in.ogr/v.in.ogr.html
--- grass/trunk/vector/v.in.ogr/v.in.ogr.html 2012-12-04 18:35:24 UTC (rev 54188)
+++ grass/trunk/vector/v.in.ogr/v.in.ogr.html 2012-12-04 19:43:50 UTC (rev 54189)
@@ -238,5 +238,7 @@
Radim Blazek, ITC-irst, Trento, Italy
<br>
Location and spatial extent support by Markus Neteler and Paul Kelly
+<br>
+Markus Metz
<p><i>Last changed: $Date$</i>
