[GRASS-SVN] r54190 - grass-addons/grass6/display/d.barb
Tue Dec 4 20:58:58 PST 2012
Author: hamish
Date: 2012-12-04 20:58:58 -0800 (Tue, 04 Dec 2012)
New Revision: 54190
   grass-addons/grass6/display/d.barb/draw.c
   grass-addons/grass6/display/d.barb/grid.c
   grass-addons/grass6/display/d.barb/legend.c
   grass-addons/grass6/display/d.barb/local_proto.h
   grass-addons/grass6/display/d.barb/main.c
   grass-addons/grass6/display/d.barb/points.c
implement smaller barbs
Modified: grass-addons/grass6/display/d.barb/draw.c
--- grass-addons/grass6/display/d.barb/draw.c	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/draw.c	2012-12-05 04:58:58 UTC (rev 54190)
@@ -11,6 +11,7 @@
 void draw_barb(double easting, double northing, double velocity,
 	       double compass_deg, int color, double scale, int style)
+    double radius;
     G_debug(3, "in draw_barb()");
     //dbg:    unknown_(594578,4920392);
@@ -20,7 +21,7 @@
     R_move_abs((int)(D_u_to_d_col(easting) + 0.5),
 	       (int)(D_u_to_d_row(northing) + 0.5));
-    if (style != TYPE_BARB) {
+    if (style == TYPE_ARROW || style == TYPE_STRAW) {
 	if (velocity == velocity)	/* ie not NaN */
 	    arrow_mag(easting, northing, compass_deg, velocity, style);
 	else
@@ -31,14 +32,18 @@
 	/* calc barb parameters */
 	//dbg: compass_deg=0;
 	/* draw barb bits */
-	draw_circle(easting, northing, 10.0, FALSE);
-	draw_feather(easting, northing, 10.0 /*radius */ , velocity,
+	if (style == TYPE_SMLBARB)
+	    radius = 5.0;
+	else
+	    radius = 10.0;
+	draw_circle(easting, northing, radius, FALSE);
+	draw_feather(easting, northing, radius, velocity,
 		     compass_deg);
 	//dbg:      int i;
 	//      for (i=0; i < 360; i+=20)
 	//          draw_feather(easting, northing, 20.0 /*radius*/, velocity, i);
     return;
Modified: grass-addons/grass6/display/d.barb/grid.c
--- grass-addons/grass6/display/d.barb/grid.c	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/grid.c	2012-12-05 04:58:58 UTC (rev 54190)
@@ -32,7 +32,7 @@
 	G_fatal_error(_("Problem reading range file"));
     G_get_fp_range_min_max(&range, &mag_min, &mag_max);
 	scale *= 1.5 / fabs(mag_max);
     G_debug(3, "scaling=%.2f  rast_max=%.2f", scale, mag_max);
Modified: grass-addons/grass6/display/d.barb/legend.c
--- grass-addons/grass6/display/d.barb/legend.c	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/legend.c	2012-12-05 04:58:58 UTC (rev 54190)
@@ -17,7 +17,7 @@
     G_debug(1, "Doing legend ... (%d entries)", num_velos);
-    if (style == TYPE_BARB)
+    if (style == TYPE_BARB || style == TYPE_SMLBARB)
 	angle = -90;
     else
 	angle = 90;
@@ -55,7 +55,7 @@
 	/* X: right justify the text + 10px buffer (a wee bit more for wind barbs) */
 	/* text width is 0.81 of text height? so even though we set width
 	   to txsiz with R_text_size(), we still have to reduce.. hmmm */
 	    R_move_rel(-20 - (strlen(buff) * key_fontsize * 0.81), 0);
 	else
 	    R_move_rel(-10 - (strlen(buff) * key_fontsize * 0.81), 0);
Modified: grass-addons/grass6/display/d.barb/local_proto.h
--- grass-addons/grass6/display/d.barb/local_proto.h	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/local_proto.h	2012-12-05 04:58:58 UTC (rev 54190)
@@ -8,7 +8,8 @@
 /* barb flavours */
 #define TYPE_STRAW 0
 #define TYPE_BARB 1
-#define TYPE_ARROW 2
+#define TYPE_SMLBARB 2
+#define TYPE_ARROW 3
 #define RpD ((2 * M_PI) / 360.)	/* radians/degree */
 #define D2R(d) (double)(d * RpD)	/* degrees->radians */
Modified: grass-addons/grass6/display/d.barb/main.c
--- grass-addons/grass6/display/d.barb/main.c	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/main.c	2012-12-05 04:58:58 UTC (rev 54190)
@@ -7,7 +7,7 @@
  * AUTHORS:     Hamish Bowman, Dunedin, New Zealand
  *              Grid code derived from d.rast.arrow
- * COPYRIGHT:   (c) 2008-2011 by Hamish Bowman, and The GRASS Development Team
+ * COPYRIGHT:   (c) 2008-2012 by Hamish Bowman, and The GRASS Development Team
  *              This program is free software under the GNU General Public
  *              License (>=v2). Read the file COPYING that comes with GRASS
  *              for details.
@@ -86,7 +86,7 @@
     style_opt->key = "style";
     style_opt->type = TYPE_STRING;
     style_opt->answer = "arrow";
-    style_opt->options = "arrow,barb,straw";
+    style_opt->options = "arrow,barb,small_barb,straw";
     style_opt->description = _("Style");
     color_opt = G_define_standard_option(G_OPT_C_FG);
@@ -206,6 +206,8 @@
 	style = TYPE_ARROW;
     else if (G_strcasecmp(style_opt->answer, "barb") == 0)
 	style = TYPE_BARB;
+    else if (G_strcasecmp(style_opt->answer, "small_barb") == 0)
+	style = TYPE_SMLBARB;
     else if (G_strcasecmp(style_opt->answer, "straw") == 0)
 	style = TYPE_STRAW;
     else
Modified: grass-addons/grass6/display/d.barb/points.c
--- grass-addons/grass6/display/d.barb/points.c	2012-12-04 19:43:50 UTC (rev 54189)
+++ grass-addons/grass6/display/d.barb/points.c	2012-12-05 04:58:58 UTC (rev 54190)
@@ -78,10 +78,11 @@
     peak = max_magnitude(magn, num_pts);
     G_debug(2, "  peak = %.2f", peak);
-    if (style == TYPE_BARB && peak > 150)
-	G_warning(_("Maximum wind barb displayed is 150 knots"));
+    if (style == TYPE_BARB || style == TYPE_SMLBARB) {
+	if(peak > 150)
+	    G_warning(_("Maximum wind barb displayed is 150 knots"));
     peak = 1.;			// TODO: window width * 0.20
     scale_fact = (peak) * scale;
