[GRASS-SVN] r54191 - grass-addons/grass6/imagery/i.spec.unmix
Tue Dec 4 23:11:05 PST 2012
Author: rashadkm
Date: 2012-12-04 23:11:05 -0800 (Tue, 04 Dec 2012)
New Revision: 54191
   grass-addons/grass6/imagery/i.spec.unmix/main.c
updated comment style for i.spec.unmix main.c
Modified: grass-addons/grass6/imagery/i.spec.unmix/main.c
--- grass-addons/grass6/imagery/i.spec.unmix/main.c	2012-12-05 04:58:58 UTC (rev 54190)
+++ grass-addons/grass6/imagery/i.spec.unmix/main.c	2012-12-05 07:11:05 UTC (rev 54191)
@@ -113,8 +113,7 @@
 		    parm.group->answer,
 		    parm.result->answer,
 		    parm.iter->answer, parm.error->answer);
-    //G_warning("printing A******");
-    //G_matrix_print2(A,"A");
     /* ATTENTION: Internally we work here with col-oriented matrixfile,
      *  but the user has to enter the spectra row-wise for his/her's
@@ -126,7 +125,7 @@
      *             m: rows
     /* 1. Check matrix orthogonality:
      *    Ref: Youngsinn Sohn, Roger M. McCoy 1997: Mapping desert shrub
@@ -136,53 +135,49 @@
      * 2. Beside checking matrix orthogonality we find out the maximum
-     *    entry of the matrix for configuring stepsize mu later.  */
+     *    entry of the matrix for configuring stepsize mu later.
     /* go columnwise through matrix */
     for (i = 0; i < A->cols; i++) {
 	vec_struct *Avector1, *Avector2;
 	double max1, max2;
 	Avector1 = G_matvect_get_column2(A, i);
-	// G_matrix_print(Avector1);
-	//G_warning("Avector1: %d", Avector1->rows);
-	// get the max. element of this vector
+	/* get the max. element of this vector */
 	max1 = G_vector_norm_maxval(Avector1, 1);
 	double temp = max1;
 	for (j = 0; j < A->cols; j++) {
 	    if (j != i) {
-		// get next col in A
+		/* get next col in A */
 		Avector2 = G_matvect_get_column(A, j);
-		//G_matrix_print(Avector2);
 		max2 = G_vector_norm_maxval(Avector2, 1);
-		//G_warning("max2: %lf", max2);
 		if (max2 > max1)
 		    temp = max2;
-		//G_warning("temp: %lf", temp);
+		/* find max of matrix A */
 		if (temp > max_total)
 		    max_total = temp;
-		// find max of matrix A
-		//        max_total = (find_max (max1, max2), max_total);
-		//G_warning("max_total: %lf", max_total);
-		// save angle in degree
+		/* G_warning("max_total: %lf", max_total); */
+		/* save angle in degree */
 		anglefield[i][j] = spectral_angle(Avector1, Avector2);
-		//G_warning("anglefield[i][j]: %lf", anglefield[i][j]);
+		/* G_warning("anglefield[i][j]: %lf", anglefield[i][j]); */
@@ -212,24 +207,22 @@
     if (!error)
 	G_message(_("Spectral matrix is o.k. Proceeding..."));
-    // Begin calculations
-    // 1. contraint SUM xi = 1
-    //   add last row "1" elements to Matrix A, store in A_tilde
-    //   A_tilde is one row-dimension more than A
+  /* Begin calculations
+   * 1. contraint SUM xi = 1
+   *   add last row "1" elements to Matrix A, store in A_tilde
+   *   A_tilde is one row-dimension more than A
-    // memory allocation
+    /* memory allocation */
     A_tilde = G_matrix_init(A->rows + 1, A->cols, A->rows + 1);
     if (A_tilde == NULL)
 	G_fatal_error(_("Unable to allocate memory for matrix"));
-    //G_message("rrrr%d", A_tilde->rows);
     for (i = 0; i < A->rows; i++)
 	    G_matrix_set_element(A_tilde, i, j,
@@ -237,49 +230,47 @@
-    // fill last row with 1 elements
+    /* fill last row with 1 elements  */
     for (j = 0; j < A_tilde->cols; j++) {
-	//G_message("Row: %d, Col:%d",i,j);
 	G_matrix_set_element(A_tilde, i, j, GAMMA);
-    //G_matrix_print2(A_tilde, "A_tilde");
+    /* G_matrix_print2(A_tilde, "A_tilde"); */
-    // now we have an overdetermined (non-square) system
+    /* now we have an overdetermined (non-square) system
-    // We have a least square problem here: error minimization
-    //                             T          -1         T
-    // unknown fraction = [A_tilde * A_tilde]  * A_tilde * b
-    // A_tilde is the non-square matrix with first constraint in last row.
-    // b is pixel vector from satellite image
-    // Solve this by deriving above equation and searching the
-    // minimum of this error function in an iterative loop within
-    // both constraints.
+    * We have a least square problem here: error minimization
+    *                             T          -1         T
+    * unknown fraction = [A_tilde * A_tilde]  * A_tilde * b
+    * A_tilde is the non-square matrix with first constraint in last row.
+    * b is pixel vector from satellite image
+    * Solve this by deriving above equation and searching the
+    * minimum of this error function in an iterative loop within
+    * both constraints.
+    /* calculate the transpose of A_tilde */
-    // calculate the transpose of A_tilde
-    //G_matrix_print(A_tilde);
     A_tilde_trans = G_matrix_transpose(A_tilde);
-    //G_matrix_print2(A_tilde_trans, "A_tilde_trans");
-    // initialize some values
-    // step size must be small enough for covergence  of iteration:
-    //  mu = 0.000001;      step size for spectra in range of W/m^2/um
-    //  mu = 0.000000001;   step size for spectra in range of mW/m^2/um
-    //  mu = 0.000001;      step size for spectra in range of reflectance
+    /* initialize some values
-    // check  max_total for number of digits to configure mu size
-    mu = 0.0001 * pow(10, -1 * ceil(log10(max_total)));
+    *  step size must be small enough for covergence  of iteration:
+    *  mu = 0.000001;      step size for spectra in range of W/m^2/um
+    *  mu = 0.000000001;   step size for spectra in range of mW/m^2/um
+    *  mu = 0.000001;      step size for spectra in range of reflectance
+    *  check  max_total for number of digits to configure mu size
+    *  mu = 0.0001 * pow(10, -1 * ceil(log10(max_total)));
-    //G_message("mu = %lf", mu);
     startvector = G_vec_get2(A->cols, startvector);
@@ -289,25 +280,25 @@
-    A_times_startvector = G_vec_get2(A_tilde->rows, A_times_startvector);	// length: no. of bands   //
-    errorvector = G_vec_get2(A_tilde->rows, errorvector);	// length: no. of bands   //
-    temp = G_vec_get2(A_tilde->cols, temp);	// length: no. of spectra //
-    //  A_tilde_trans_mu = m_get(A_tilde->m,A_tilde->n);
+    A_times_startvector = G_vec_get2(A_tilde->rows, A_times_startvector);	/* length: no. of bands   */
+    errorvector = G_vec_get2(A_tilde->rows, errorvector);	/* length: no. of bands   */
+    temp = G_vec_get2(A_tilde->cols, temp);	/* length: no. of spectra */
+    /*  A_tilde_trans_mu = m_get(A_tilde->m,A_tilde->n); */
-    // length: no. of bands
+    /* length: no. of bands   */
     if (A_times_startvector == NULL)
 	G_fatal_error(_("Unable to allocate memory for vector"));
     if (errorvector == NULL)
-    // length: no. of spectra
+    /* length: no. of spectra */
     if (temp == NULL)
@@ -317,32 +308,29 @@
     if (A_tilde_trans_mu == NULL)
-    // Now we can calculated the fractions pixelwise
-    nrows = G_window_rows();	// get geographical region
+    /* Now we can calculated the fractions pixelwise */
+    nrows = G_window_rows();	/* get geographical region  */
     ncols = G_window_cols();
     G_message(_("Calculating for %i x %i pixels (%i bands) = %i pixelvectors."),
 	      nrows, ncols, Ref.nfiles, (ncols * ncols));
-    //G_vec_print(A_times_startvector, "A_times_startvectorq");
     for (row = 0; row < nrows; row++) {
 	int col, band;
 	G_percent(row, nrows, 1);
-	// get one row for all bands
+	/* get one row for all bands */
 	for (band = 0; band < Ref.nfiles; band++)
 	    if (G_get_map_row(cellfd[band], cell[band], row) < 0)
 		G_fatal_error(_("Unable to get map row [%d]"), row);
-	// for (band = 0; band < Ref.nfiles; band++)
-	//  if (G_get_map_row (cellfd[band], cell[band], row) < 0)
-	//  G_fatal_error (_("Unable to get map row [%d]"), row);
-	//G_message("row: %d, nrows: %d", row, nrows);
+	/* for (band = 0; band < Ref.nfiles; band++)
+	*  if (G_get_map_row (cellfd[band], cell[band], row) < 0)
+	*  G_fatal_error (_("Unable to get map row [%d]"), row);
 	for (col = 0; col < ncols; col++) {
@@ -352,79 +340,66 @@
 	    int iterations = 0;
-	    // get pixel values of each band and store in b vector:
-	    // length: no. of bands + 1 (GAMMA)
+	    /* get pixel values of each band and store in b vector: */
+	    /* length: no. of bands + 1 (GAMMA) */
 	    b_gamma = G_vec_get2(A_tilde->rows, b_gamma);
-	    //            b_gamma = G_vector_init (A_tilde->rows, 1, RVEC);
+	    /* b_gamma = G_vector_init (A_tilde->rows, 1, RVEC); */
 	    if (b_gamma == NULL)
-	    //G_message("%d", A_tilde->rows);
 	    for (band = 0; band < Ref.nfiles; band++) {
 		b_gamma->ve[band] = cell[band][col];
-		//G_message("band: %d col: %d", band,col);
-		//G_matrix_set_element (b_gamma, 0, band, cell[band][col]);
+		/*G_matrix_set_element (b_gamma, 0, band, cell[band][col]); */
-	    // add GAMMA for 1. constraint as last element
+	    /* add GAMMA for 1. constraint as last element */
 	    b_gamma->ve[Ref.nfiles] = GAMMA;
-	    ///            G_matrix_set_element (b_gamma, 0, Ref.nfiles, GAMMA);
+	    /* G_matrix_set_element (b_gamma, 0, Ref.nfiles, GAMMA); */
-	    //G_matrix_print(b_gamma,"b_gamma");
 	    for (k = 0; k < A_tilde->cols; k++)
 		startvector->ve[k] = (1.0 / A_tilde->cols);
-	    //               G_matrix_set_element (startvector, k,0, (1.0 / A_tilde->cols));
-	    //G_matrix_print(startvector,"startvector1");
+	    /* G_matrix_set_element (startvector, k,0, (1.0 / A_tilde->cols)); */
+	    /* G_matrix_print(startvector,"startvector1");  */
+	    /* calculate fraction vector for current pixel
+	    * Result is stored in fractions vector
+	    * with second constraint: Sum x_i = 1
-	    //G_matrix_print(b_gamma, "b_gama");
-	    // calculate fraction vector for current pixel
-	    // Result is stored in fractions vector
-	    // with second constraint: Sum x_i = 1
+	    * get start vector and initialize it with equal fractions:
+	    * using the neighbor pixelvector as startvector
-	    //G_vec_print(startvector, "startvector");
-	    // get start vector and initialize it with equal fractions:
-	    // using the neighbor pixelvector as startvector
-	    // solve with iterative solution:
+	    /* solve with iterative solution: */
 	    while (fabs(change) > 0.0001) {
-		    mv_mlt(A_tilde, startvector, A_times_startvector);
+		A_times_startvector =   mv_mlt(A_tilde, startvector, A_times_startvector);
-		//G_vec_print(A_times_startvector, "xx");
-		errorvector =
-		    v_sub(A_times_startvector, b_gamma, errorvector);
-		//G_vec_print(A_times_startvector, "errorvector");
-		A_tilde_trans_mu =
-		    sm_mlt(mu, A_tilde_trans, A_tilde_trans_mu);
+		errorvector = v_sub(A_times_startvector, b_gamma, errorvector);
-		//G_matrix_print(A_tilde_trans_mu,"A_tilde_trans_mu");
+		A_tilde_trans_mu =  sm_mlt(mu, A_tilde_trans, A_tilde_trans_mu);
 		temp = mv_mlt(A_tilde_trans_mu, errorvector, temp);
-		startvector = v_sub(startvector, temp, startvector);	// update startvector //
+		startvector = v_sub(startvector, temp, startvector);	/* update startvector */
-		// if one element gets negative, set it to zero //
-		for (k = 0; k < (A_tilde->cols); k++)	// no. of spectra times //
+		/* if one element gets negative, set it to zero */
+		for (k = 0; k < (A_tilde->cols); k++)	/* no. of spectra times */
 		    if (startvector->ve[k] < 0)
 			startvector->ve[k] = 0;
-		// Check the deviation //
+		/* Check the deviation */
 		double norm2 = v_norm2(errorvector);
 		change = deviation - norm2;
@@ -432,131 +407,46 @@
 		iterations++;
-		// if(fabs (change) > 0.0001)
-		//G_message("change=%lf, deviation=%lf",change, 0.0001);
+      /* G_debug (5, "Change: %g - deviation: %g",   change, deviation); */
-		// go a small step into direction of negative gradient
-		// errorvector = A_tilde * startvector - b_gamma
-		//              mv_mlt(A_tilde, startvector, A_times_startvector);
-		   //G_matrix_print(A_times_startvector,"A_times_startvector");
-		   //G_matrix_print(b_gamma, "b_gamma");
-		   //G_matrix_print(errorvector, "errorvector");
-		   G_vector_sub (A_times_startvector, b_gamma, errorvector);
-		   //                sm_mlt(mu, A_tilde_trans, A_tilde_trans_mu);
-		   //                mv_mlt(A_tilde_trans_mu, errorvector, temp);
-		   G_vector_sub (startvector, temp, startvector);
-		   for (k = 0; k < A_tilde->cols; k++)  // no. of spectra times
-		   //                    if (startvector->ve[k] < 0)
-		   //                        startvector->ve[k] = 0;
-		   //G_message("get_element: %lf", G_matrix_get_element (startvector, startvector->cols, k));
-		   if ((G_matrix_get_element (startvector, startvector->cols, k) < 0))
-		   G_matrix_set_element (startvector, startvector->cols, k, 0);
-		   //G_message("A_tilde->cols: %d", A_tilde->cols); //4
-		   double norm_euclid = G_vector_norm_euclid (errorvector);
-		   // G_message("norm_euclid : %lf", norm_euclid );
-		   change = deviation - norm_euclid;
-		   deviation = G_vector_norm_euclid (errorvector);
-		   // G_message ("Change: %g - deviation: %g",  change, deviation);
-		   G_debug (5, "Change: %g - deviation: %g",
-		   change, deviation);
+	    /*----------  end of second contraint -----------------------
+	    * store fractions in resulting rows of resulting files
+	    * (number of bands = vector dimension)
+	    /* write result in full percent */
 	    VEC *fraction;
-	    //G_message("fcol %d  and A->cols %d", startvector->dim, A->cols);
-	    fraction = G_vec_get(A->cols);	// length: no. of spectra //
+	    fraction = G_vec_get(A->cols);	/* length: no. of spectra */
 	    error = deviation / v_norm2(b_gamma);
 	    fraction = G_vec_copy(startvector);
-	    // write result in full percent //
-	    for (i = 0; i < A->cols; i++)	// no. of spectra //
+	    for (i = 0; i < A->cols; i++)	/* no. of spectra */
 		result_cell[i][col] = (CELL) (100 * fraction->ve[i]);
-	    // save error and iterations//
+	    /* save error and iterations */
 	    error_cell[col] = (CELL) (100 * error);
 	    iter_cell[col] = iterations;
-	    //V_FREE(fraction);
-	    //V_FREE(b);
+	    /****V_FREE(fraction);
+	    V_FREE(b);
+	} /* end cols loop */
-	    //----------  end of second contraint -----------------------
-	    // store fractions in resulting rows of resulting files
-	    // (number of bands = vector dimension)
-	    //G_matrix_print(fraction,"fraction"); //same as startvector
-	    //G_message ("fraction->rows: %d",fraction->rows);
-	    //G_message ("i=%d, col=%d",i,col);
-	       double dd = G_matrix_get_element (fraction,  i, 0);
-	       dd = 100*dd;
-	       result_cell[i][col] = (CELL) dd;
-	       //result_cell[i][col] = (CELL)(100 * G_matrix_get_element (fraction, fraction->rows-1, i));
-	       error_cell[col] = (CELL) (100 * error);
-	       iter_cell[col] = iterations;
-	       G_vector_free (fraction);
-	       // G_vector_free (b);
-	}			//end cols loop
-	//G_message("finished %d of %d", row,nrows);
-	// write the resulting rows into output files:
+	/* write the resulting rows into output files: */
 	    G_put_map_row(resultfd[i], result_cell[i]);
 	if (error_fd > 0)
@@ -565,29 +455,27 @@
 	if (iter_fd > 0)
 	    G_put_map_row(iter_fd, iter_cell);
-    }				// rows loop
+    }		/* end rows loop */
     G_percent(row, nrows, 2);
-    // close files
-    for (i = 0; i < Ref.nfiles; i++)	// no. of bands
+    /* close files */
+    for (i = 0; i < Ref.nfiles; i++)	/* no. of bands */
 	G_unopen_cell(cellfd[i]);
 	char command[1080];
 	G_close_cell(resultfd[i]);
-	// make grey scale color table
+	/* make grey scale color table */
 	sprintf(result_name, "%s.%d", parm.result->answer, (i + 1));
 	sprintf(command, "r.colors map=%s color=rules <<EOF\n"
 		"0 0 0 0 \n" "201 0 255 0\n" "end\n" "EOF", result_name);
+	/* G_system (command); */
-	//G_message(command);
-	//G_system (command);
-	// create histogram
+	/* create histogram */
 	do_histogram(result_name, Ref.file[i].mapset);
@@ -597,7 +485,7 @@
 	G_close_cell(error_fd);
 	sprintf(command, "r.colors map=%s color=gyr >/dev/null",
     if (iter_fd > 0)
@@ -607,7 +495,5 @@
     make_history(result_name, parm.group->answer, parm.matrixfile->answer);
     exit(EXIT_SUCCESS);
