[GRASS-SVN] r54223 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Thu Dec 6 06:04:06 PST 2012
Author: martinl
Date: 2012-12-06 06:04:05 -0800 (Thu, 06 Dec 2012)
New Revision: 54223
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: map layer menu - minor clean (multiple maps selected)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-12-06 13:08:08 UTC (rev 54222)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-12-06 14:04:05 UTC (rev 54223)
@@ -398,29 +398,25 @@
self.popupMenu.Append(self.popupID['remove'], text = _("Remove"))
self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id = self.popupID['remove'])
- if ltype != "command":
+ if ltype != "command" and numSelected == 1:
self.popupMenu.Append(self.popupID['rename'], text = _("Rename"))
self.Bind(wx.EVT_MENU, self.OnRenameLayer, id = self.popupID['rename'])
- if numSelected > 1:
- self.popupMenu.Enable(self.popupID['rename'], False)
# map layer items
if ltype not in ("group", "command"):
- self.popupMenu.AppendSeparator()
- self.popupMenu.Append(self.popupID['opacity'], text = _("Change opacity level"))
- self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id = self.popupID['opacity'])
- self.popupMenu.Append(self.popupID['properties'], text = _("Properties"))
- self.Bind(wx.EVT_MENU, self.OnPopupProperties, id = self.popupID['properties'])
+ if numSelected == 1:
+ self.popupMenu.AppendSeparator()
+ self.popupMenu.Append(self.popupID['opacity'], text = _("Change opacity level"))
+ self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id = self.popupID['opacity'])
+ self.popupMenu.Append(self.popupID['properties'], text = _("Properties"))
+ self.Bind(wx.EVT_MENU, self.OnPopupProperties, id = self.popupID['properties'])
- self.popupMenu.Enable(self.popupID['opacity'], False)
- self.popupMenu.Enable(self.popupID['properties'], False)
+ if ltype in ('raster', 'vector', '3d-raster') and self.lmgr.IsPaneShown('toolbarNviz'):
+ self.popupMenu.Append(self.popupID['nviz'], _("3D view properties"))
+ self.Bind (wx.EVT_MENU, self.OnNvizProperties, id = self.popupID['nviz'])
- if ltype in ('raster', 'vector', '3d-raster') and self.lmgr.IsPaneShown('toolbarNviz'):
- self.popupMenu.Append(self.popupID['nviz'], _("3D view properties"))
- self.Bind (wx.EVT_MENU, self.OnNvizProperties, id = self.popupID['nviz'])
if ltype in ('raster', 'vector', 'rgb'):
self.popupMenu.Append(self.popupID['zoom'], text = _("Zoom to selected map(s)"))
self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id = self.popupID['zoom'])
self.popupMenu.Append(self.popupID['region'], text = _("Set computational region from selected map(s)"))
@@ -433,7 +429,7 @@
mltype = None
# vector layers (specific items)
- if mltype and mltype == "vector":
+ if mltype and mltype == "vector" and numSelected == 1:
self.popupMenu.Append(self.popupID['export'], text = _("Export"))
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.out.ogr',
@@ -504,52 +500,33 @@
self.popupMenu.Append(self.popupID['meta'], _("Metadata"))
self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
- self.popupMenu.Enable(self.popupID['attr'], False)
- self.popupMenu.Enable(self.popupID['edit0'], False)
- self.popupMenu.Enable(self.popupID['edit1'], False)
- self.popupMenu.Enable(self.popupID['meta'], False)
- self.popupMenu.Enable(self.popupID['bgmap'], False)
- self.popupMenu.Enable(self.popupID['topo'], False)
- self.popupMenu.Enable(self.popupID['export'], False)
# raster layers (specific items)
elif mltype and mltype == "raster":
self.popupMenu.Append(self.popupID['zoom1'], text = _("Zoom to selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id = self.popupID['zoom1'])
self.popupMenu.Append(self.popupID['region1'], text = _("Set computational region from selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id = self.popupID['region1'])
- self.popupMenu.Append(self.popupID['export'], text = _("Export"))
- self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
- 'input=%s' % mapLayer.GetName()]),
- id = self.popupID['export'])
- self.popupMenu.Append(self.popupID['color'], _("Set color table"))
- self.Bind (wx.EVT_MENU, self.OnRasterColorTable, id = self.popupID['color'])
- self.popupMenu.Append(self.popupID['hist'], _("Histogram"))
- self.Bind (wx.EVT_MENU, self.OnHistogram, id = self.popupID['hist'])
- self.popupMenu.Append(self.popupID['univar'], _("Univariate raster statistics"))
- self.Bind (wx.EVT_MENU, self.OnUnivariateStats, id = self.popupID['univar'])
- self.popupMenu.Append(self.popupID['prof'], _("Profile"))
- self.Bind (wx.EVT_MENU, self.OnProfile, id = self.popupID['prof'])
- self.popupMenu.Append(self.popupID['meta'], _("Metadata"))
- self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
- self.popupMenu.Enable(self.popupID['zoom1'], False)
- self.popupMenu.Enable(self.popupID['region1'], False)
- self.popupMenu.Enable(self.popupID['color'], False)
- self.popupMenu.Enable(self.popupID['hist'], False)
- self.popupMenu.Enable(self.popupID['univar'], False)
- self.popupMenu.Enable(self.popupID['prof'], False)
- if self.lmgr.IsPaneShown('toolbarNviz'):
- self.popupMenu.Enable(self.popupID['nviz'], False)
+ self.popupMenu.Append(self.popupID['export'], text = _("Export"))
+ self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
+ 'input=%s' % mapLayer.GetName()]),
+ id = self.popupID['export'])
+ self.popupMenu.Append(self.popupID['color'], _("Set color table"))
+ self.Bind (wx.EVT_MENU, self.OnRasterColorTable, id = self.popupID['color'])
+ self.popupMenu.Append(self.popupID['hist'], _("Histogram"))
+ self.Bind (wx.EVT_MENU, self.OnHistogram, id = self.popupID['hist'])
+ self.popupMenu.Append(self.popupID['univar'], _("Univariate raster statistics"))
+ self.Bind (wx.EVT_MENU, self.OnUnivariateStats, id = self.popupID['univar'])
+ self.popupMenu.Append(self.popupID['prof'], _("Profile"))
+ self.Bind (wx.EVT_MENU, self.OnProfile, id = self.popupID['prof'])
+ self.popupMenu.Append(self.popupID['meta'], _("Metadata"))
+ self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
