[GRASS-SVN] r54224 - in grass/trunk/gui/wxpython: gui_core mapdisp mapswipe nviz
svn_grass at osgeo.org
Thu Dec 6 09:34:58 PST 2012
Author: annakrat
Date: 2012-12-06 09:34:57 -0800 (Thu, 06 Dec 2012)
New Revision: 54224
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapswipe/frame.py
grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
grass/trunk/gui/wxpython/mapswipe/mapwindow.py
grass/trunk/gui/wxpython/mapswipe/toolbars.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
wxGUI/mapswipe: add text label with map name
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -564,7 +564,14 @@
self._preparePan(mapWindow = win)
def OnPointer(self, event):
+ """!Set pointer mode (dragging overlays)"""
+ toolbar = self.GetMapToolbar()
+ self.SwitchTool(toolbar, event)
self.GetFirstWindow().mouse['use'] = 'pointer'
+ self.GetFirstWindow().SetCursor(self.cursors["default"])
+ self.GetSecondWindow().mouse['use'] = 'pointer'
+ self.GetSecondWindow().SetCursor(self.cursors["default"])
def OnRender(self, event):
"""!Re-render map composition (each map layer)
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -796,14 +796,14 @@
self.dragimg.DoDrawImage(dc, moveto)
self.dragimg.EndDrag()
- def DragItem(self, id, event):
+ def DragItem(self, id, coords):
"""!Drag an overlay decoration item
if id == 99 or id == '' or id == None: return
Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
x, y = self.lastpos
- dx = event.GetX() - x
- dy = event.GetY() - y
+ dx = coords[0] - x
+ dy = coords[1] - y
self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
r = self.pdc.GetIdBounds(id)
@@ -826,7 +826,7 @@
r = r.Union(r2)
r.Inflate(4,4)
self.RefreshRect(r, False)
- self.lastpos = (event.GetX(), event.GetY())
+ self.lastpos = (coords[0], coords[1])
def MouseDraw(self, pdc = None, begin = None, end = None):
"""!Mouse box or line from 'begin' to 'end'
@@ -1083,7 +1083,8 @@
elif (self.mouse['use'] == 'pointer' and
not digitToolbar and
self.dragid != None):
- self.DragItem(self.dragid, event)
+ coords = event.GetPositionTuple()
+ self.DragItem(self.dragid, coords)
# dragging anything else - rubber band box or line
else:
@@ -1128,13 +1129,13 @@
elif self.mouse['use'] == 'pointer':
# get decoration or text id
- self.idlist = []
+ idlist = []
self.dragid = ''
self.lastpos = self.mouse['begin']
idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
self.hitradius)
if 99 in idlist:
- idlist.remove(99)
+ idlist.remove(99)
if idlist != []:
self.dragid = idlist[0] #drag whatever is on top
else:
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -314,6 +314,7 @@
message += _("Map <%s> not found.") % maps[1]
GError(parent = self, message = message)
dlg.Destroy()
+ self.SetRasterNames()
self.ZoomToMap()
dlg.Destroy()
@@ -452,7 +453,21 @@
self._mgr.Update()
splitter.OnSashChanged(None)
self.OnSize(None)
+ def OnAddText(self, event):
+ """!Double click on text overlay
+ So far not implemented.
+ pass
+ def SetRasterNames(self):
+ if self.rasters['first']:
+ self.GetFirstWindow().SetRasterNameText(self.rasters['first'], 101)
+ if self.rasters['second']:
+ self.GetSecondWindow().SetRasterNameText(self.rasters['second'], 102)
def GetMapToolbar(self):
"""!Returns toolbar with zooming tools"""
return self.toolbars['swipeMap']
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -80,6 +80,8 @@
if second:
frame.SetSecondRaster(second)
+ frame.SetRasterNames()
+ frame.ZoomToMap()
frame.Show()
app.MainLoop()
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -119,6 +119,38 @@
return super(SwipeBufferedWindow, self).Draw(pdc, img, drawid, pdctype, coords)
+ def OnLeftDown(self, event):
+ """!Left mouse button pressed.
+ In case of 'pointer' mode, coordinates must be adjusted.
+ if self.mouse['use'] == 'pointer':
+ evX, evY = event.GetPositionTuple()[:]
+ imX, imY = self.GetImageCoords()
+ self.lastpos = evX + imX, evY + imY
+ # get decoration or text id
+ self.dragid = None
+ idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
+ self.hitradius)
+ if 99 in idlist:
+ idlist.remove(99)
+ if idlist:
+ self.dragid = idlist[0] #drag whatever is on top
+ else:
+ super(SwipeBufferedWindow, self).OnLeftDown(event)
+ def OnDragging(self, event):
+ """!Mouse dragging - overlay (text) is moving.
+ Coordinates must be adjusted.
+ if (self.mouse['use'] == 'pointer' and self.dragid != None):
+ self.DragItem(self.dragid, (evX + imX, evY + imY))
+ else:
+ super(SwipeBufferedWindow, self).OnDragging(event)
def TranslateImage(self, dx, dy):
"""!Translate image and redraw.
@@ -126,8 +158,14 @@
self.pdc.TranslateId(self.imageId, dx, dy)
self.Refresh()
+ def SetRasterNameText(self, name, textId):
+ """!Sets text label with map name."""
+ self.textdict[textId] = {'bbox': wx.Rect(), 'coords': [10, 10],
+ 'font': self.GetFont(), 'color': wx.BLACK,
+ 'rotation': 0, 'text': name,
+ 'active': True}
def MouseActions(self, event):
"""!Handle mouse events and if needed let parent frame know"""
super(SwipeBufferedWindow, self).MouseActions(event)
Modified: grass/trunk/gui/wxpython/mapswipe/toolbars.py
--- grass/trunk/gui/wxpython/mapswipe/toolbars.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/mapswipe/toolbars.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -58,6 +58,9 @@
("erase", icons["erase"],
self.parent.OnErase),
(None, ), # creates separator
+ ("pointer", icons["pointer"],
+ self.parent.OnPointer,
+ wx.ITEM_CHECK),
("pan", icons["pan"],
self.parent.OnPan,
wx.ITEM_CHECK), # toggle tool
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2012-12-06 14:04:05 UTC (rev 54223)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2012-12-06 17:34:57 UTC (rev 54224)
@@ -693,7 +693,7 @@
if self.dragid > 0:
+ self.DragItem(self.dragid, event.GetPositionTuple())
if self.mouse['use'] == 'rotate':
dx, dy = event.GetX() - self.mouse['tmp'][0], event.GetY() - self.mouse['tmp'][1]
@@ -909,14 +909,14 @@
self.render['quick'] = True
self.Refresh(False)
if not id: return
Debug.msg (5, "GLWindow.DragItem(): id=%d" % id)
x, y = self.mouse['tmp']
for texture in self.imagelist:
if texture.id == id:
texture.MoveTexture(dx, dy)
@@ -925,7 +925,7 @@
self.Refresh(False)
- self.mouse['tmp'] = (event.GetX(), event.GetY())
+ self.mouse['tmp'] = coords
def ZoomBack(self):
"""!Set previous view in history list
