[GRASS-SVN] r54235 - in grass-addons/grass7/vector: . v.class.mlpy
Fri Dec 7 09:13:07 PST 2012
Author: wenzeslaus
Date: 2012-12-07 09:13:06 -0800 (Fri, 07 Dec 2012)
New Revision: 54235
Added:
   grass-addons/grass7/vector/v.class.mlpy/
   grass-addons/grass7/vector/v.class.mlpy/Makefile
   grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html
   grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py
v.class.mlpy: initial commit, basic functionality included
Added: grass-addons/grass7/vector/v.class.mlpy/Makefile
--- grass-addons/grass7/vector/v.class.mlpy/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.class.mlpy/Makefile	2012-12-07 17:13:06 UTC (rev 54235)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.class.mlpy
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html
--- grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html	2012-12-07 17:13:06 UTC (rev 54235)
@@ -0,0 +1,72 @@
+<h2>DESCRIPTION</h2>
+<em>v.class.mlpy</em> classifies vector features. It is an interface to mlpy
+library. Classification is supervised and based on attribut table data.
+Geometry is not used. Training dataset is always required.
+<h2>NOTES</h2>
+This script needs mlpy to be installed. You can download mlpy and installation
+instructions from the official mlpy website
+(<a href="http://mlpy.sourceforge.net/">http://mlpy.sourceforge.net/</a>).
+<h2>EXAMPLE</h2>
+This is a North Carolina example which generates vector data for classification
+from raster maps.
+<div class="code"><pre>
+# generate random points used as an input
+v.random output=points_unknown n=1000
+v.db.addtable map=points_unknown
+# generate random points used as training dataset
+v.random output=points_known n=100
+v.db.addtable map=points_known
+# fill attribute tables
+MAPS=$(g.mlist type=rast pattern="lsat*" exclude="*87*" mapset=PERMANENT sep=" ")
+let NUM=0
+for MAP in $MAPS
+do
+let NUM++
+    v.db.addcolumn map=points_unknown layer=1 columns="map_$NUM integer"
+    v.db.addcolumn map=points_known layer=1 columns="map_$NUM integer"
+    v.what.rast map=points_unknown layer=1 raster=$MAP column=map_$NUM
+    v.what.rast map=points_known layer=1 raster=$MAP column=map_$NUM
+done
+# fill the class (category) column with correct values for training dataset
+v.db.addcolumn map=points_known layer=1 columns="landclass integer"
+v.what.rast map=points_known layer=1 raster=landclass96 column=landclass
+# set color table
+r.colors.out map=landclass96 rules=tmp_color_rules_file \
+| v.colors map=points_known column=landclass layer=1 rules=tmp_color_rules_file
+rm tmp_color_rules_file
+# do the classification
+v.class.mlpy input=points_unknown training=points_known class_column=landclass
+# set color table
+| v.colors map=points_unknown column=landclass layer=1 rules=tmp_color_rules_file
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="v.class">v.class</a></em><br>
+<h2>REFERENCES</h2>
+D. Albanese, R. Visintainer, S. Merler, S. Riccadonna, G. Jurman, C. Furlanello.
+<em>mlpy: Machine Learning Python</em>, 2012.
+<a href="http://arxiv.org/abs/1202.6548">arXiv:1202.6548</a>
+<h2>AUTHOR</h2>
+Vaclav Petras,
+<a href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic
+<p>
+<i>Last changed: $Date: 2012-09-09 21:11:23 +0200 (Sun, 09 Sep 2012) $</i>
Added: grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py
--- grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py	2012-12-07 17:13:06 UTC (rev 54235)
@@ -0,0 +1,336 @@
+#!/usr/bin/env python
+# MODULE:    Map Swipe
+# AUTHOR(S): Vaclav Petras
+# PURPOSE:   Classifies features in vecor map.
+# COPYRIGHT: (C) 2012 by Vaclav Petras, and the GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%module
+#%  description: Vector supervised classification tool which uses attributes as classification parametres (order of columns matters, names not), cat column identifies feature, class_column is excluded from classification parametres.
+#%  keywords: vector, classification, supervised
+#%end
+#%option G_OPT_V_MAP
+#%  key: input
+#%  description: Input vector map (attribut table required)
+#%  required: yes
+#%  multiple: no
+#%end
+#%  key: training
+#%  description: Training vector map (attribut table required)
+#%  required: yes
+#%  multiple: no
+#%end
+#%option G_OPT_V_FIELD
+#%  key: class_column
+#%  type: string
+#%  label: Name of column containing class
+#%  description: Used for both input/output and training dataset. If column does not exists in input map attribute table, it will be created.
+#%  required: no
+#%  multiple: no
+#%  answer: class
+#%end
+#%option
+#%  key: columns
+#%  type: string
+#%  label: Columns to be used in classification
+#%  description: Columns to be used in classification. If left empty, all columns will be used for classification except for class_column and cat column.
+#%  required: no
+#%  multiple: yes
+#%end
+# TODO: add other classifiers
+# TODO: improve doc
+# TODO: input/training could be multiple
+# TODO: handle layers
+# TODO: ouput to new map (all classes/one class), depens what is faster
+import grass.script as grass
+import numpy as np
+try:
+    import mlpy
+except ImportError:
+    grass.fatal(_("Cannot import mlpy (http://mlpy.sourceforge.net) library."
+                  " Please install it or ensure that it is on path"
+                  " (use PYTHONPATH variable)."))
+# Pytlit has a problem with this mlpy and v.class.mlpy.py
+# thus, warinings for objects from mlpy has to be disabled
+def addColumn(mapName, columnName, columnType):
+    """Adds column to the map's table."""
+    columnDefinition = columnName + ' ' + columnType
+    grass.run_command('v.db.addcolumn', map=mapName,
+                      columns=columnDefinition)
+def hasColumn(tableDescription, column):
+    """Checks if the column is in the table description
+    @todo This should be part of some object in the lib.
+    for col in tableDescription['cols']:
+        if col[0] == column:
+            return True
+    return False
+def updateColumn(mapName, column, cats, values=None):
+    """!Updates column values for rows with a given categories.
+    \param cats categories to be updated
+    or a list of tuples (cat, value) if \p values is None
+    \param values to be set for column (same length as cats) or \c None
+    statements = ''
+    for i in range(len(cats)):
+        if values is None:
+            cat = str(cats[i][0])
+            val = str(cats[i][1])
+        else:
+            cat = str(cats[i])
+            val = str(values[i])
+        statement = 'UPDATE ' + mapName + ' SET '
+        statement += column + ' = ' + val
+        statement += ' WHERE cat = ' + cat
+        statements += statement + ';\n'
+    grass.write_command('db.execute', input='-', stdin=statements)
+class Classifier:
+    """!Interface class between mlpy and other code
+    It does not uses numpy in the interface bu this may be wrong.
+    def __init__(self):
+        self.mlclassifier = mlpy.DLDA(delta=0.01)  # pylint: disable=E1101
+    def learn(self, values, classes):
+        self.mlclassifier.learn(np.array(values), np.array(classes))
+    def pred(self, values):
+        return self.mlclassifier.pred(np.array(values))
+# TODO: raise exception when str can not be float
+# TODO: repair those functions, probably create a class
+# TODO: use numpy or array
+def fromDbTableToSimpleTable(dbTable, columnsDescription, columnWithClass):
+    sTable = []
+    for row in dbTable:
+        sRow = []
+        for i, col in enumerate(row):
+            columnName = columnsDescription[i][0]
+            if columnName != columnWithClass and columnName != 'cat':
+                sRow.append(float(col))
+        sTable.append(sRow)
+    return sTable
+def extractColumnWithClass(dbTable, columnsDescription, columnWithClass):
+    classColumn = []
+            if columnName == columnWithClass:
+                classColumn.append(float(col))
+    return classColumn
+def extractNthColumn(dbTable, columnNumber):
+    classColumn = []
+            if columnNumber == i:
+def extractColumnWithCats(dbTable, columnsDescription):
+    column = []
+            if columnName == 'cat':
+                column.append(float(col))
+    return column
+# unused
+def fatal_noAttributeTable(mapName):
+    grass.fatal(_("Vector map <%s> has no or empty attribute table")
+                % mapName)
+def fatal_noEnoughColumns(mapName, ncols, required):
+    grass.fatal(_("Not enough columns in vector map <%(map)s>"
+                  " (found %(ncols)s, expected at least %(r)s")
+                % {'map': mapName, 'ncols': ncols, 'r': required})
+def fatal_noClassColumn(mapName, columnName):
+    grass.fatal(_("Vector map <%(map)s> does not have"
+                  " the column <%(col)s> cointaining class")
+                % {'map': mapName, 'col': columnName})
+def fatal_noRows(mapName):
+    grass.fatal(_("Empty attribute table for map vector <%(map)s>")
+                % {'map': mapName})
+def checkNcols(mapName, tableDescription, requiredNcols):
+    ncols = tableDescription['ncols']
+    if ncols < requiredNcols:
+        fatal_noEnoughColumns(mapName, ncols, requiredNcols)
+def checkNrows(mapName, tableDescription):
+    if not tableDescription['nrows'] > 0:
+        fatal_noRows(mapName)
+def checkDbConnection(mapName):
+    """! Checks if vector map has an attribute table.
+    \todo check layer
+    ret = grass.vector_db(mapName)
+    if not ret:
+        grass.fatal(_("Vector map <%s> has no attribute table") % mapName)
+def main():
+    options, unused = grass.parser()
+    mapName = options['input']
+    trainingMapName = options['training']
+    columnWithClass = options['class_column']
+    useAllColumns = True
+    if options['columns']:
+        # columns as string
+        columns = options['columns'].strip()
+        useAllColumns = False
+    # TODO: allow same input and output map only if --overwrite was specified
+    # TODO: is adding column overwriting or overwriting is only updating of existing?
+    # variable names conected to training dataset have training prefix
+    # variable names conected to classified dataset have no prefix
+    # checking database connection (if map has a table)
+    # TODO: layer
+    checkDbConnection(trainingMapName)
+    checkDbConnection(mapName)
+    # loading descriptions first to check them
+    trainingTableDescription = grass.db_describe(table=trainingMapName)
+    if useAllColumns:
+        trainingMinNcols = 3
+        checkNcols(trainingMapName, trainingTableDescription, trainingMinNcols)
+    else:
+        pass
+    checkNrows(trainingMapName, trainingTableDescription)
+    if not hasColumn(trainingTableDescription, columnWithClass):
+        fatal_noClassColumn(trainingMapName, columnWithClass)
+    tableDescription = grass.db_describe(table=mapName)
+    if useAllColumns:
+        minNcols = 2
+        checkNcols(mapName, tableDescription, minNcols)
+    else:
+        pass
+    checkNrows(mapName, tableDescription)
+    # TODO: check same (+-1) number of columns
+    # loadnig data
+    # TODO: make fun from this
+    if useAllColumns:
+        dbTable = grass.db_select(table=trainingMapName)
+    else:
+        # assuming that columns concatenated by comma
+        sql = 'SELECT %s,%s FROM %s' % (columnWithClass, columns, trainingMapName)
+        dbTable = grass.db_select(sql=sql)
+    trainingParameters = fromDbTableToSimpleTable(dbTable,
+                                                  columnsDescription=trainingTableDescription['cols'],
+                                                  columnWithClass=columnWithClass)
+    if useAllColumns:
+        trainingClasses = extractColumnWithClass(dbTable,
+    else:
+        # FIXME: magic num?
+        trainingClasses = extractNthColumn(dbTable, 0)
+    # TODO: hard coded 'cat'?
+    if useAllColumns:
+        dbTable = grass.db_select(table=mapName)
+    else:
+        sql = 'SELECT %s,%s FROM %s' % ('cat', columns, mapName)
+    parameters = fromDbTableToSimpleTable(dbTable,
+                                          columnsDescription=tableDescription['cols'],
+    if useAllColumns:
+        cats = extractColumnWithCats(dbTable, columnsDescription=tableDescription['cols'])
+    else:
+        cats = extractNthColumn(dbTable, 0)
+    # since dbTable can be big it is better to avoid to have it in memory twice
+    del dbTable
+    del trainingTableDescription
+    classifier = Classifier()
+    classifier.learn(trainingParameters, trainingClasses)
+    classes = classifier.pred(parameters)
+    # add column only if not exists and the classification was successful
+    if not hasColumn(tableDescription, columnWithClass):
+        addColumn(mapName, columnWithClass, 'int')
+    updateColumn(mapName, columnWithClass, cats, classes)
+    # TODO: outupt as a new map (use INSERT, can be faster)
+    # TODO: output as a new layer?
+if __name__ == "__main__":
+    main()
Property changes on: grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py
___________________________________________________________________
Added: svn:executable
