[GRASS-SVN] r54236 - grass/trunk/scripts/r.unpack
svn_grass at osgeo.org
Fri Dec 7 12:22:18 PST 2012
Author: martinl
Date: 2012-12-07 12:22:17 -0800 (Fri, 07 Dec 2012)
New Revision: 54236
grass/trunk/scripts/r.unpack/r.unpack.py
r.unpack: fix for fully qualified map names
various minor issues
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2012-12-07 17:13:06 UTC (rev 54235)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2012-12-07 20:22:17 UTC (rev 54236)
@@ -5,7 +5,7 @@
# AUTHOR(S): Hamish Bowman, Otago University, New Zealand
# Converted to Python by Martin Landa <landa.martin gmail.com>
# PURPOSE: Unpack up a raster map packed with r.pack
-# COPYRIGHT: (C) 2004-2008, 2010 by the GRASS Development Team
+# COPYRIGHT: (C) 2004-2008, 2010-2012 by the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -22,14 +22,17 @@
#%option G_OPT_F_INPUT
#% description: Name of input pack file
#% gisprompt: old,file,bin_input
+#% key_desc: name.pack
#%end
#%option G_OPT_R_OUTPUT
#% description: Name for output raster map (default: taken from input file internals)
#% required: no
+#% guisection: Output settings
#%end
#%flag
#% key: o
#% description: Override projection check (use current location's projection)
#%end
import os
@@ -52,7 +55,7 @@
grass.debug('tmp_dir = %s' % tmp_dir)
if not os.path.exists(infile):
- grass.fatal(_("File <%s> not found" % infile))
+ grass.fatal(_("File <%s> not found") % infile)
gisenv = grass.gisenv()
mset_dir = os.path.join(gisenv['GISDBASE'],
@@ -70,21 +73,23 @@
if options['output']:
map_name = options['output']
else:
- map_name = data_name
+ map_name = data_name.split('@')[0]
gfile = grass.find_file(name = map_name, element = 'cell',
mapset = '.')
- overwrite = os.getenv('GRASS_OVERWRITE')
- if gfile['file'] and overwrite != '1':
- grass.fatal(_("Raster map <%s> already exists") % map_name)
+ if gfile['file']:
+ if os.environ.get('GRASS_OVERWRITE', '0') != '1':
+ grass.fatal(_("Raster map <%s> already exists") % map_name)
+ else:
+ grass.warning(_("Raster map <%s> already exists and will be overwritten") % map_name)
# extract data
tar.extractall()
os.chdir(data_name)
# check projection compatibility in a rather crappy way
- if not grass.compare_key_value_text_files('PROJ_INFO', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')) or\
- not grass.compare_key_value_text_files('PROJ_UNITS', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')):
+ if not grass.compare_key_value_text_files('PROJ_INFO', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')) or \
+ not grass.compare_key_value_text_files('PROJ_UNITS', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')):
if flags['o']:
grass.warning(_("Projection information does not match. Proceeding..."))
else:
@@ -105,7 +110,7 @@
else:
shutil.copyfile(element, os.path.join(mset_dir, element, map_name))
- grass.verbose(_("Raster map saved to <%s>") % map_name)
+ grass.message(_("Raster map <%s> unpacked") % map_name)
if __name__ == "__main__":
options, flags = grass.parser()
