[GRASS-SVN] r54238 - grass/trunk/scripts/v.db.reconnect.all
svn_grass at osgeo.org
Fri Dec 7 13:53:25 PST 2012
Author: martinl
Date: 2012-12-07 13:53:25 -0800 (Fri, 07 Dec 2012)
New Revision: 54238
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
v.db.reconnnect.all: bugfix - don't use substituted new_database
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2012-12-07 20:35:43 UTC (rev 54237)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2012-12-07 21:53:25 UTC (rev 54238)
@@ -181,9 +181,9 @@
create_index(new_driver, new_database, new_schema_table,
table + '_' + key, key)
- # reconnect tables
+ # reconnect tables (don't use substituted new_database)
if 0 != grass.run_command('v.db.connect', flags = 'o', quiet = True, map = vect,
- layer = layer, driver = new_driver, database = new_database,
+ layer = layer, driver = new_driver, database = options['new_database'],
table = new_schema_table, key = key):
grass.warning(_("Operation canceled"))
