[GRASS-SVN] r54239 - in grass/trunk/gui/wxpython: . animation dbmgr docs gmodeler mapswipe psmap rlisetup
svn_grass at osgeo.org
Fri Dec 7 14:27:03 PST 2012
Author: martinl
Date: 2012-12-07 14:27:03 -0800 (Fri, 07 Dec 2012)
New Revision: 54239
Added:
grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html
Removed:
grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/animation/g.gui.animation.html
grass/trunk/gui/wxpython/dbmgr/manager.py
grass/trunk/gui/wxpython/docs/wxGUI.Components.html
grass/trunk/gui/wxpython/docs/wxGUI.html
grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.html
grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.html
grass/trunk/gui/wxpython/psmap/g.gui.psmap.html
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
add g.gui.dbmgr (Attribute Table Manager)
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/Makefile 2012-12-07 22:27:03 UTC (rev 54239)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap
+SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr
EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc
include $(MODULE_TOPDIR)/include/Make/Dir.make
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.html
--- grass/trunk/gui/wxpython/animation/g.gui.animation.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -54,6 +54,7 @@
<p>
<em>
<a href="g.gui.html">g.gui</a>,
+ <a href="g.gui.dbmgr.html">g.gui.dbmgr</a>,
<a href="g.gui.gmodeler.html">g.gui.gmodeler</a>,
<a href="g.gui.mapswipe.html">g.gui.mapswipe</a>,
<a href="g.gui.psmap.html">g.gui.psmap</a>,
Copied: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html (from rev 54237, grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html)
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html (rev 0)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -0,0 +1,66 @@
+<!-- meta page description: wxGUI Attribute Table Manager -->
+<!-- meta page index: wxGUI -->
+<h2>DESCRIPTION</h2>
+<em>Attribute table manager</em> allows to:
+<ul>
+ <li>Browse attribute data of vector map, perform SQL select
+ statements</li>
+ <li>Modify attribute data, insert new records to attribute table,
+ delete existing records</li>
+ <li>Highlight selected items in the Map Display Window</li>
+ <li>Extract selected items into a new vector map</li>
+ <li>Modify attribute table - add, drop, rename columns</li>
+ <li>Modify vector map DB connection settings - add, remove or
+ modify layers</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="wxGUI.html">wxGUI</a><br>
+ <a href="wxGUI.Components.html">wxGUI components</a>
+</em>
+<p>
+<em>
+<a href="db.columns.html">db.columns</a>,
+<a href="db.connect.html">db.connect</a>,
+<a href="db.describe.html">db.describe</a>,
+<a href="db.drivers.html">db.drivers</a>,
+<a href="db.execute.html">db.execute</a>,
+<a href="db.select.html">db.select</a>,
+<a href="db.tables.html">db.tables</a>
+</em>
+<p>
+<em>
+<a href="v.db.addcolumn.html">v.db.addcolumn</a>,
+<a href="v.db.connect.html">v.db.connect</a>,
+<a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
+<a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
+<a href="v.what.html">v.what</a>
+</em>
+<p>
+<em>
+ <a href="g.gui.html">g.gui</a>,
+ <a href="g.gui.animation.html">g.gui.animation</a>,
+ <a href="g.gui.gmodeler.html">g.gui.gmodeler</a>,
+ <a href="g.gui.mapswipe.html">g.gui.mapswipe</a>,
+ <a href="g.gui.psmap.html">g.gui.psmap</a>,
+ <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>
+</em>
+<p>
+See also <a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Attribute_table_manager">wiki</a> page.
+<h2>AUTHORS</h2>
+Martin Landa, <a href="http://www.fbk.eu">FBK-irst</a> (2007-2008), Trento, Italy, and <a href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic<br>
+Michael Barton, Arizona State University, USA<br>
+Jachym Cepicky
+<p>
+<i>$Date$</i>
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py 2012-12-07 22:27:03 UTC (rev 54239)
@@ -9,10 +9,6 @@
It also uses some functions at
http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/426407
- at code
-python dbm.py vector at mapset
- at endcode
List of classes:
- manager::AttributeManager
@@ -23,19 +19,18 @@
@author Jachym Cepicky <jachym.cepicky gmail.com>
@author Martin Landa <landa.martin gmail.com>
- at author Refactoring by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)"""
+ at author Refactoring by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
import sys
import os
-if __name__ == "__main__":
- sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
-from core import globalvar
import wx
import wx.lib.flatnotebook as FN
import grass.script as grass
+from core import globalvar
from core.gcmd import GMessage
from core.debug import Debug
from dbmgr.base import DbMgrBase
@@ -198,29 +193,3 @@
DbMgrBase.UpdateDialog(self, layer = layer)
# set current page selection
self.notebook.SetSelectionByName('layers')
-def main(argv = None):
- import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
- if argv is None:
- argv = sys.argv
- if len(argv) != 2:
- print >> sys.stderr, __doc__
- sys.exit()
- #some applications might require image handlers
- wx.InitAllImageHandlers()
- app = wx.PySimpleApp()
- f = AttributeManager(parent = None, id = wx.ID_ANY,
- title = "%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
- argv[1]),
- size = (900,600), vectorName = argv[1])
- f.Show()
- app.MainLoop()
-if __name__ == '__main__':
- main()
Deleted: grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -1,56 +0,0 @@
-<!-- meta page description: wxGUI Attribute Table Manager -->
-<!-- meta page index: wxGUI -->
-<h2>DESCRIPTION</h2>
-<em>Attribute table manager</em> allows to:
-<ul>
- <li>Browse attribute data of vector map, perform SQL select
- statements</li>
- <li>Modify attribute data, insert new records to attribute table,
- delete existing records</li>
- <li>Highlight selected items in the Map Display Window</li>
- <li>Extract selected items into a new vector map</li>
- <li>Modify attribute table - add, drop, rename columns</li>
- <li>Modify vector map DB connection settings - add, remove or
- modify layers</li>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
- <a href="wxGUI.html">wxGUI</a><br>
- <a href="wxGUI.Components.html">wxGUI components</a>
-</em>
-<p>
-<em>
-<a href="db.columns.html">db.columns</a>,
-<a href="db.connect.html">db.connect</a>,
-<a href="db.describe.html">db.describe</a>,
-<a href="db.drivers.html">db.drivers</a>,
-<a href="db.execute.html">db.execute</a>,
-<a href="db.select.html">db.select</a>,
-<a href="db.tables.html">db.tables</a>
-</em>
-<p>
-<em>
-<a href="v.db.addcolumn.html">v.db.addcolumn</a>,
-<a href="v.db.connect.html">v.db.connect</a>,
-<a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
-<a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
-<a href="v.what.html">v.what</a>
-</em>
-<p>
-See also <a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Attribute_table_manager">wiki</a> page.
-<h2>AUTHORS</h2>
-<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin Landa</a>, <a href="http://www.fbk.eu">FBK-irst</a> (2007-2008), Trento, Italy, and <a href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic<br>
-Michael Barton, Arizona State University, USA<br>
-Jachym Cepicky
-<p>
-<i>$Date$</i>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Components.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Components.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Components.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -5,7 +5,8 @@
<ul>
<li><a href="wxGUI.Nviz.html">3D Viewer</a></li>
- <li><a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a></li>
+ <li><a href="wxGUI.dbmgr.html">Attribute Table Manager</a>
+ - <em><a href="g.gui.dbmgr.html">g.gui.dbmgr</a></em></li>
<li><a href="wxGUI.psmap.html">Cartographic Composer</a>
- <em><a href="g.gui.psmap.html">g.gui.psmap</a></em></li>
<li><a href="wxGUI.gmodeler.html">Graphical Modeler</a>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -267,7 +267,7 @@
<dt><img src="icons/table.png" alt="icon">
<em>Show attribute table</em></dt>
- <dd>Opens <em><a href="wxGUI.Attribute_Table_Manager.html">attribute table manager</a></em> for selected vector map.</dd>
+ <dd>Opens <em><a href="wxGUI.dbmgr.html">attribute table manager</a></em> for selected vector map.</dd>
<dt><img src="icons/layer-open.png" alt="icon">
<em>Import raster or vector data</em></dt>
@@ -637,7 +637,7 @@
<h2>AUTHORS</h2>
Daniel Calvelo Aros<br>
Jachym Cepicky<br>
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.html
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -43,6 +43,7 @@
<em>
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.html
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -44,6 +44,7 @@
<em>
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.html
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -199,6 +199,7 @@
<em>
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2012-12-07 21:53:25 UTC (rev 54238)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2012-12-07 22:27:03 UTC (rev 54239)
@@ -17,6 +17,7 @@
<em>
