[GRASS-SVN] r54278 - grass/trunk/lib/init
Fri Dec 14 02:01:45 PST 2012
Author: neteler
Date: 2012-12-14 02:01:45 -0800 (Fri, 14 Dec 2012)
New Revision: 54278
   grass/trunk/lib/init/variables.html
document r54264
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2012-12-14 00:02:34 UTC (rev 54277)
+++ grass/trunk/lib/init/variables.html	2012-12-14 10:01:45 UTC (rev 54278)
@@ -208,7 +208,14 @@
   <!-- HB Sept 2005: I don't think this exists anymore:
        <p>GRASS_STDERR
 	 <br>  set to any value to prevent user mail on error
+  <dt>GRASS_SKIP_MAPSET_OWNER_CHECK</dt>
+  <dd>By default it is not possible to work with MAPSETs that are
+    not owned by current user. Setting this variable to any non-empty value
+    allows the check to be skipped.</dd>
   <dt>GRASS_SH</dt>
   <dd>[shell scripts on Windows]<br>
     path to bourne shell interpreter used to run shell scripts.</dd>
