[GRASS-SVN] r54279 - grass/trunk/scripts/r.tileset
svn_grass at osgeo.org
Fri Dec 14 05:06:54 PST 2012
Author: neteler
Date: 2012-12-14 05:06:53 -0800 (Fri, 14 Dec 2012)
New Revision: 54279
grass/trunk/scripts/r.tileset/r.tileset.html
example fix
Modified: grass/trunk/scripts/r.tileset/r.tileset.html
--- grass/trunk/scripts/r.tileset/r.tileset.html 2012-12-14 10:01:45 UTC (rev 54278)
+++ grass/trunk/scripts/r.tileset/r.tileset.html 2012-12-14 13:06:53 UTC (rev 54279)
@@ -15,7 +15,8 @@
twice the necessary information. Furthermore, generating a tiling near
a divergant point of a source projection, such as the poles of a
cylindrical source projections, results in divergence of the tile set.
-<p>Not generating "optimal" tilings may have another consequence; the
+<p>
+Not generating "optimal" tilings may have another consequence; the
aspect ratio of cells in the destination region will not necessarily
carry over to the source region and generated tiles may have cells of
strange aspect ratios. This might be a problem for some map request
@@ -62,14 +63,16 @@
Generates tiles in latitude longitude that cover the current
region, each tile will be less than 1024 cells high and 2048 cells
across. The bounds and sizes of tiles in the output are separated by | (pipe):
-<p><div class="code"><pre>
+<p>
+<div class="code"><pre>
r.tileset sourceproj=+init=epsg:4326 maxrows=1024 maxcols=2048
</pre></div>
Generates tiles in latitude longitude projection that cover the
named region "ne-rio". The tiles will have 2 cells of overlap. The
output format will be strings like the bbox requests for WMS servers:
+<p>
r.tileset sourceproj=+init=epsg:4326 overlap=2 -w region=ne-rio
</pre></div>
@@ -79,15 +82,17 @@
is in a format where each line is in shell script style. The
substitution <code>`g.proj -j location=IrishGrid`</code> will only
work in a unix style shell:
-r.tileset sourceproj=`g.proj -j location=IrishGrid` maxrows=400 maxcols=300 overlap=3 -g
+<p>
+r.tileset sourceproj="`g.proj -j location=IrishGrid`" maxrows=400 maxcols=300 overlap=3 -g
</pre></div>
<h2>BUGS</h2>
<ul>
<li><em>r.tileset</em> does not know about meridians that
-"wrap-around" in projections. </ul>
+"wrap-around" in projections.</li>
+</ul>
<h2>AUTHORS</h2>
@@ -95,4 +100,5 @@
Cedric Shock<br>
Updated for GRASS 7 by Martin Landa, CTU in Prague, Czech Republic
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
