[GRASS-SVN] r54286 - in grass/trunk/imagery/i.ortho.photo: . i.ortho.elev
Fri Dec 14 14:06:52 PST 2012
Author: mmetz
Date: 2012-12-14 14:06:52 -0800 (Fri, 14 Dec 2012)
New Revision: 54286
Added:
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/
   grass/trunk/imagery/i.ortho.photo/i.photo.rectify/
Removed:
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/ask_elev.c
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/elev.h
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/local_proto.h
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/mod_elev.c
   grass/trunk/imagery/i.ortho.photo/Makefile
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/Makefile
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
add i.ortho.elev
Modified: grass/trunk/imagery/i.ortho.photo/Makefile
--- grass/trunk/imagery/i.ortho.photo/Makefile	2012-12-14 22:03:48 UTC (rev 54285)
+++ grass/trunk/imagery/i.ortho.photo/Makefile	2012-12-14 22:06:52 UTC (rev 54286)
@@ -2,20 +2,14 @@
 MODULE_TOPDIR = ../..
 SUBDIRS1 = \
-	menu \
-	photo.2image \
-	photo.2target \
-	photo.camera \
-	photo.elev \
-	photo.init \
-	photo.rectify \
-	photo.target
+	i.ortho.elev \
+	i.photo.rectify
-SUBDIRS = libes $(SUBDIRS1)
+SUBDIRS = lib $(SUBDIRS1)
 include $(MODULE_TOPDIR)/include/Make/Dir.make
-$(SUBDIRS1): libes
+$(SUBDIRS1): lib
 default: parsubdirs
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/Makefile
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/Makefile	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/Makefile	2012-12-14 22:06:52 UTC (rev 54286)
@@ -1,15 +1,12 @@
 MODULE_TOPDIR = ../../..
-PGM = i.photo.elev
+PGM = i.ortho.elev
-EXTRA_CFLAGS = -I../libes
+LIBES     = $(IMAGERYLIB) $(GISLIB) $(IORTHOLIB) $(GMATHLIB)
+DEPENDENCIES= $(IMAGERYDEP) $(IORTHODEP) $(GISDEP) $(GMATHDEP)
-LIBES     = $(IMAGERYLIB) $(GISLIB) $(IORTHOLIB) $(VASKLIB) $(CURSES) $(GMATHLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(IORTHODEP) $(GISDEP) $(VASKDEP) $(GMATHDEP)
+EXTRA_CFLAGS = -I../lib
 include $(MODULE_TOPDIR)/include/Make/Module.make
-default: etc
-htmletc:
-	@echo no docs needed for $(PGM)
+default: cmd
Deleted: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/ask_elev.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/ask_elev.c	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/ask_elev.c	2012-12-14 22:06:52 UTC (rev 54286)
@@ -1,50 +0,0 @@
-/* ask_elev .c */
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/vask.h>
-#include "elev.h"
-int ask_elev(char *group, char *location, char *mapset)
-    char buf[100];
-    char t1[80];
-    char t2[80];
-    sprintf(t1, "Please select the elevation raster map for group <%s>",
-	    group);
-    sprintf(t2, "Elevation raster map: ");
-    V_clear();
-    V_line(1, t1);
-    V_line(4, t2);
-    V_line(6, "(enter list for a list of existing raster maps)");
-    V_ques(elev_layer, 's', 4, 28, 20);
-    for (;;) {
-	V_intrpt_ok();
-	if (!V_call())
-	    exit(0);
-	if (*elev_layer == 0)
-	    exit(0);
-	if (strcmp(elev_layer, "list") == 0) {
-	    G_set_list_hit_return(1);
-	    G_list_element("cell", "raster", "", 0);
-	else if ((mapset_elev = G_find_cell(elev_layer, "")) == NULL) {
-	    sprintf(buf,
-		    "\n\nraster-file %s not found - select another file\n",
-		    elev_layer);
-	    G_warning(buf);
-	    *elev_layer = 0;
-	    continue;
-	else
-	    break;
-    /* mod_elev_data(); */
-    return 0;
Deleted: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/elev.h
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/elev.h	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/elev.h	2012-12-14 22:06:52 UTC (rev 54286)
@@ -1,16 +0,0 @@
-extern char *elev_layer;
-extern char *mapset_elev;
-extern char *tl;
-extern char *math_exp;
-extern char *units;
-extern char *nd;
-/* ask_elev.c */
-int ask_elev(char *, char *, char *);
-/* main.c */
-int select_current_env(void);
-int select_target_env(void);
-/* mod_elev.c */
-int mod_elev_data(void);
Deleted: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/local_proto.h
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/local_proto.h	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/local_proto.h	2012-12-14 22:06:52 UTC (rev 54286)
@@ -1,9 +0,0 @@
-/* ask_elev.c */
-/* main.c */
-/* mod_elev.c */
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/main.c	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2012-12-14 22:06:52 UTC (rev 54286)
@@ -8,9 +8,10 @@
  *               Bernhard Reiter <bernhard intevation.de>,
  *               Glynn Clements <glynn gclements.plus.com>
  *               Hamish Bowman
+ *               Markus Metz
  * PURPOSE:      Select the elevation model
- * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2012 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -19,7 +20,7 @@
 /* read the target for the block and cast it into the alternate GRASS env */
-#define MAIN
 #include <stdlib.h>
 #include <stdio.h>
 #include <unistd.h>
@@ -28,45 +29,56 @@
 #include <grass/imagery.h>
 #include <grass/glocale.h>
 #include "orthophoto.h"
-#include "elev.h"
 static int which_env;
-char *elev_layer;
-char *mapset_elev;
-char *tl;
-char *math_exp;
-char *units;
-char *nd;
+int select_current_env(void);
+int select_target_env(void);
 int main(int argc, char *argv[])
     struct GModule *module;
-    struct Option *group_opt;
+    struct Option *group_opt, *elev_opt;
+    struct Flag *list_flag;
     char location[GMAPSET_MAX];
     char mapset[GMAPSET_MAX];
     char group[GNAME_MAX];
+    char *elev_layer;
+    char *mapset_elev;
+    char *tl;
+    char *math_exp;
+    char *units;
+    char *nd;
     char buf[100];
     int stat;
+    int overwrite;
-    /* must run in a term window */
-    G_putenv("GRASS_UI_TERM", "1");
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("imagery, orthorectify");
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("orthorectify"));
     module->description =
-	_("Interactively select or modify the target elevation model.");
+	_("Select or modify the target elevation model.");
     group_opt = G_define_standard_option(G_OPT_I_GROUP);
     group_opt->description =
 	_("Name of imagery group for ortho-rectification");
+    elev_opt = G_define_standard_option(G_OPT_R_ELEV);
+    elev_opt->required = NO;
+    elev_opt->description =
+	_("Name of elevation map to use for ortho-rectification");
+    list_flag = G_define_flag();
+    list_flag->key = 'l';
+    list_flag->description =
+	_("List available raster maps in target mapset and exit");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -88,18 +100,15 @@
     G_suppress_warnings(1);
     if (!I_get_target(group, location, mapset)) {
-	sprintf(buf, _("Target information for group [%s] missing\n"), group);
-	goto error;
+	G_fatal_error(_("Please select a target for group [%s] first"), group);
     G_suppress_warnings(0);
     sprintf(buf, "%s/%s", G_gisdbase(), location);
     if (access(buf, 0) != 0) {
-	sprintf(buf, _("Target location [%s] not found\n"), location);
-	goto error;
+	G_fatal_error(_("Target location [%s] not found\n"), location);
-    I_get_group_elev(group, elev_layer, mapset_elev, tl, math_exp, units, nd);
     G__create_alt_env();
     G__setenv("LOCATION_NAME", location);
@@ -111,27 +120,49 @@
 	G__switch_search_path();
 	which_env = 0;
-	/* get elevation layer raster map  in target location */
 	select_target_env();
-	ask_elev(group, location, mapset);
+	if (list_flag->answer) {
+	    /* list raster maps in target location */
-	/* select current location */
-	select_current_env();
+	    /* select current location */
+	    select_current_env();
+	else {
+	    if (!elev_opt->answer) {
+		G_fatal_error(_("Elevation map name is missing. Please set '%s' option"),
+		    elev_opt->key);
+	    /* elevation map exists in target ? */
+	    if (G_find_raster2(elev_opt->answer, mapset) == NULL) {
+		G_fatal_error(_("Raster map <%s> not found"), elev_opt->answer);
-	I_put_group_elev(group, elev_layer, mapset_elev, tl,
-			 math_exp, units, nd);
+	    I_get_group_elev(group, elev_layer, mapset_elev, tl, math_exp, units, nd);
+	    overwrite = G__getenv("OVERWRITE") != NULL;
+	    if (!overwrite && *elev_layer) {
+		G_warning(_("Elevation for group <%s> is already set to <%s>"),
+		          group, elev_layer);
+	    I_put_group_elev(group, elev_opt->answer, mapset_elev, tl,
+			     math_exp, units, nd);
 	exit(EXIT_SUCCESS);
-    sprintf(buf, _("Mapset [%s] in target location [%s] - "), mapset, location);
-    strcat(buf, stat == 0 ? _("permission denied\n") : _("not found\n"));
-  error:
-    strcat(buf, _("Please select a target for group"));
-    strcat(buf, group);
-    G_suppress_warnings(0);
-    G_fatal_error(buf);
+    G_fatal_error(_("Mapset [%s] in target location [%s] - %s "),
+                  mapset, location,
+		  stat == 0 ? _("permission denied\n") : _("not found\n"));
Deleted: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/mod_elev.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.elev/mod_elev.c	2012-11-21 12:38:16 UTC (rev 53950)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/mod_elev.c	2012-12-14 22:06:52 UTC (rev 54286)
@@ -1,47 +0,0 @@
-/* mod_elev.c */
-#include "elev.h"
-#define ZERO_DATA  0
-    short ok;
-    tl = G_location();
-    sprintf(units, "METERS");
-    ok = 0;
-    while (!ok) {
-	/* List options on the screen for the user to answer */
-	ok = 1;
-	V_clear();
-	V_line(1, "Please check the elevation data convention:");
-	V_line(3,
-	       "ELEV_DATA  =  CELL FILE  [MAPSET  in  LOCATION] [MATH EXPERSION][UNITS]");
-	V_line(6, "CELL FILE :       ");
-	V_line(7, "MAPSET :          ");
-	V_line(8, "LOCATION :        ");
-	V_line(9, "MATH EXPRESSION : ");
-	V_line(10, "UNITS :           ");
-	V_line(12, "NO DATA VALUES  : ");
-	V_const(elev_layer, 's', 6, 20, 40);
-	V_const(mapset_elev, 's', 7, 20, 40);
-	V_const(tl, 's', 8, 20, 40);
-	V_ques(math_exp, 's', 9, 20, 40);
-	V_const(units, 's', 10, 20, 10);
-	V_ques(nd, 's', 12, 20, 10);
-	V_intrpt_ok();
-	if (!V_call())
-	    exit(1);
-    return 0;
