[GRASS-SVN] r54287 - in grass/trunk/imagery/i.ortho.photo: . i.ortho.rectify
svn_grass at osgeo.org
Fri Dec 14 14:11:27 PST 2012
Author: mmetz
Date: 2012-12-14 14:11:26 -0800 (Fri, 14 Dec 2012)
New Revision: 54287
Added:
grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/
grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/i.ortho.rectify.html
Removed:
grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/description.html
grass/trunk/imagery/i.ortho.photo/i.photo.rectify/
grass/trunk/imagery/i.ortho.photo/Makefile
grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/Makefile
i.photo.rectify -> i.ortho.rectify
Modified: grass/trunk/imagery/i.ortho.photo/Makefile
--- grass/trunk/imagery/i.ortho.photo/Makefile 2012-12-14 22:06:52 UTC (rev 54286)
+++ grass/trunk/imagery/i.ortho.photo/Makefile 2012-12-14 22:11:26 UTC (rev 54287)
@@ -3,7 +3,7 @@
SUBDIRS1 = \
i.ortho.elev \
- i.photo.rectify
+ i.ortho.rectify
SUBDIRS = lib $(SUBDIRS1)
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/Makefile
--- grass/trunk/imagery/i.ortho.photo/i.photo.rectify/Makefile 2012-12-14 22:06:52 UTC (rev 54286)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/Makefile 2012-12-14 22:11:26 UTC (rev 54287)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../../..
-PGM = i.photo.rectify
+PGM = i.ortho.rectify
# for DEBUG3 see README!
#EXTRA_CFLAGS = -I../libes -DDEBUG3
Deleted: grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/description.html
--- grass/trunk/imagery/i.ortho.photo/i.photo.rectify/description.html 2012-12-14 22:06:52 UTC (rev 54286)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/description.html 2012-12-14 22:11:26 UTC (rev 54287)
@@ -1,110 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.photo.rectify</EM> rectifies an image by using the image to photo
-coordinate transformation matrix created by <A HREF="i.photo.2image.html">i.photo.2image</A>
-and the rectification parameters created by <A HREF="i.photo.2target.html">i.photo.2target</A>.
-Rectification is the process by which the geometry of an image is made
-planimetric. This is accomplished by mapping an image from one coordinate
-system to another. In <EM>i.photo.rectify</EM> the parameters computed by
-<A HREF="i.photo.2image.html">i.photo.2image</A> and
-<A HREF="i.photo.2target.html">i.photo.2target</A> are used in equations to
-convert x,y image coordinates to standard map coordinates for each pixel in
-the image. The result is an image with a standard map coordinate system,
-compensated for relief distortions and photographic tilt. Upon completion of
-the program the rectified image is deposited in a previously targeted GRASS
-LOCATION.
-<P>
-Images can be resampled with various different interpolation methods:
-nearest neighbor assignment, bilinear and bicubic interpolation. The
-bilinear and bicubic interpolation methods are also available with a
-fallback option. These methods "fall back" to simpler interpolation
-methods along NULL borders. That is, from bicubic to bilinear to nearest.
-<P>
-The process may take an hour or more depending on the size of the image,
-the speed of the computer, the number files, and the size and resolution
-of the selected window.
-<P>
-The rectified image will be located in the target LOCATION when the program
-is completed. The original unrectified files are not modified or removed.
-<P>
-The optional <em>angle</em> output holds the camera angle in degrees to
-the local surface, considering local slope and aspect. A value of 90
-degrees indicates that the camera angle was orthogonal to the local
-surface, a value of 0 degrees indicates that the camera angle was
-parallel to the local surface and negative values indicate that the
-surface was invisible to the camera. As a rule of thumb, values below 30
-degrees indicate problem areas where the orthorectified output will
-appear blurred. Because terrain shadowing effects are not considered,
-areas with high camera angles may also appear blurred if they are located
-(viewed from the camera position) behind mountain ridges or peaks.
-<P>
-<EM>i.photo.rectify</EM> can be run directly, specifying options in the
-command line or the GUI, or it can be invoked as OPTION 8 through
-<A HREF="i.ortho.photo.html">i.ortho.photo</A>. If invoked though
-<A HREF="i.ortho.photo.html">i.ortho.photo</A>, an interactive terminal
-is used to determine the options.
-<H4>Interactive mode</H4>
-<P> You are first asked if all images within the imagery group should
-be rectified. If this option is not chosen, you are asked to specify for
-each image within the imagery group whether it should be rectified or not.
-<P>
-More than one file may be rectified at a time. Each file
-should have a unique output file name. The next prompt asks you for an
-extension to be appended to the rectified images.
-<P>
-The next prompt will ask you whether a camera angle map should be
-produced and if yes, what should be its name.
-<P>
-After that you are asked if overwriting existing maps in the target
-location and mapset should be allowed.
-<P>
-The next prompt asks you to select one of two windows:
-<P>
-<PRE>
- Please select one of the following options
- 1. Use the current window in the target location
- 2. Determine the smallest window which covers the image
-</PRE>
-<P>
-If you choose option 2, you can also specify a desired target resolution.
-<P>
-<EM>i.photo.rectify</EM> will only rectify that portion of the
-image that occurs within the chosen window. Only that portion will be
-relocated in the target database. It is therefore important to check the
-current window in the target LOCATION if choice number one is selected.
-<P>
-Next you are asked to select an interpolation method.
-<PRE>
- Please select one of the following interpolation methods
- 1. nearest neighbor
- 2. bilinear
- 3. bicubic
- 4. bilinear with fallback
- 5. bicubic with fallback
-</PRE>
-<P>
-The last prompt will ask you about the amount of memory to be used by
-<EM>i.photo.rectify</EM>.
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="i.ortho.photo.html">i.ortho.photo</A><br>
-<A HREF="i.photo.camera.html">i.photo.camera</A><br>
-<A HREF="i.photo.2image.html">i.photo.2image</A><br>
-<A HREF="i.photo.2target.html">i.photo.2target</A><br>
-<A HREF="i.photo.init.html">i.photo.init</A><br>
-<A HREF="i.rectify.html">i.rectify</A><br>
-</EM>
-<H2>AUTHOR</H2>
-Mike Baba, DBA Systems, Inc.<br>
-Updated rectification and elevation map to FP 1/2002 Markus Neteler<br>
-Bugfixes and enhancements 12/2010 Markus Metz
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/i.ortho.rectify.html (from rev 54286, grass/trunk/imagery/i.ortho.photo/i.photo.rectify/description.html)
--- grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/i.ortho.rectify.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/i.ortho.rectify.html 2012-12-14 22:11:26 UTC (rev 54287)
@@ -0,0 +1,110 @@
+<H2>DESCRIPTION</H2>
+<EM>i.photo.rectify</EM> rectifies an image by using the image to photo
+coordinate transformation matrix created by <A HREF="i.photo.2image.html">i.photo.2image</A>
+and the rectification parameters created by <A HREF="i.photo.2target.html">i.photo.2target</A>.
+Rectification is the process by which the geometry of an image is made
+planimetric. This is accomplished by mapping an image from one coordinate
+system to another. In <EM>i.photo.rectify</EM> the parameters computed by
+<A HREF="i.photo.2image.html">i.photo.2image</A> and
+<A HREF="i.photo.2target.html">i.photo.2target</A> are used in equations to
+convert x,y image coordinates to standard map coordinates for each pixel in
+the image. The result is an image with a standard map coordinate system,
+compensated for relief distortions and photographic tilt. Upon completion of
+the program the rectified image is deposited in a previously targeted GRASS
+LOCATION.
+<P>
+Images can be resampled with various different interpolation methods:
+nearest neighbor assignment, bilinear and bicubic interpolation. The
+bilinear and bicubic interpolation methods are also available with a
+fallback option. These methods "fall back" to simpler interpolation
+methods along NULL borders. That is, from bicubic to bilinear to nearest.
+<P>
+The process may take an hour or more depending on the size of the image,
+the speed of the computer, the number files, and the size and resolution
+of the selected window.
+<P>
+The rectified image will be located in the target LOCATION when the program
+is completed. The original unrectified files are not modified or removed.
+<P>
+The optional <em>angle</em> output holds the camera angle in degrees to
+the local surface, considering local slope and aspect. A value of 90
+degrees indicates that the camera angle was orthogonal to the local
+surface, a value of 0 degrees indicates that the camera angle was
+parallel to the local surface and negative values indicate that the
+surface was invisible to the camera. As a rule of thumb, values below 30
+degrees indicate problem areas where the orthorectified output will
+appear blurred. Because terrain shadowing effects are not considered,
+areas with high camera angles may also appear blurred if they are located
+(viewed from the camera position) behind mountain ridges or peaks.
+<P>
+<EM>i.photo.rectify</EM> can be run directly, specifying options in the
+command line or the GUI, or it can be invoked as OPTION 8 through
+<A HREF="i.ortho.photo.html">i.ortho.photo</A>. If invoked though
+<A HREF="i.ortho.photo.html">i.ortho.photo</A>, an interactive terminal
+is used to determine the options.
+<H4>Interactive mode</H4>
+<P> You are first asked if all images within the imagery group should
+be rectified. If this option is not chosen, you are asked to specify for
+each image within the imagery group whether it should be rectified or not.
+<P>
+More than one file may be rectified at a time. Each file
+should have a unique output file name. The next prompt asks you for an
+extension to be appended to the rectified images.
+<P>
+The next prompt will ask you whether a camera angle map should be
+produced and if yes, what should be its name.
+<P>
+After that you are asked if overwriting existing maps in the target
+location and mapset should be allowed.
+<P>
+The next prompt asks you to select one of two windows:
+<P>
+<PRE>
+ Please select one of the following options
+ 1. Use the current window in the target location
+ 2. Determine the smallest window which covers the image
+</PRE>
+<P>
+If you choose option 2, you can also specify a desired target resolution.
+<P>
+<EM>i.photo.rectify</EM> will only rectify that portion of the
+image that occurs within the chosen window. Only that portion will be
+relocated in the target database. It is therefore important to check the
+current window in the target LOCATION if choice number one is selected.
+<P>
+Next you are asked to select an interpolation method.
+<PRE>
+ Please select one of the following interpolation methods
+ 1. nearest neighbor
+ 2. bilinear
+ 3. bicubic
+ 4. bilinear with fallback
+ 5. bicubic with fallback
+</PRE>
+<P>
+The last prompt will ask you about the amount of memory to be used by
+<EM>i.photo.rectify</EM>.
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="i.ortho.photo.html">i.ortho.photo</A><br>
+<A HREF="i.photo.camera.html">i.photo.camera</A><br>
+<A HREF="i.photo.2image.html">i.photo.2image</A><br>
+<A HREF="i.photo.2target.html">i.photo.2target</A><br>
+<A HREF="i.photo.init.html">i.photo.init</A><br>
+<A HREF="i.rectify.html">i.rectify</A><br>
+</EM>
+<H2>AUTHOR</H2>
+Mike Baba, DBA Systems, Inc.<br>
+Updated rectification and elevation map to FP 1/2002 Markus Neteler<br>
+Bugfixes and enhancements 12/2010 Markus Metz
+<p>
+<i>Last changed: $Date$</i>
